  4. iobroker geht nicht nach stromausfall
    5.1k
154 Beiträge 7 Kommentatoren 21.6k Aufrufe 5 Beobachtet
    @esmax666 sagte in iobroker geht nicht nach stromausfall:
    wie kann man ein Files über SSH kopieren ?
    Mit
    scp /quelldatei //ZIEL
    Esmax666
    #144
    @thomas-braun so ?
    scp /C:\Users\esmax\Downloads\iobroker_2022_09_21-02_40_10_backupiobroker.tar.gz //opt/iobroker/backups
    • E Esmax666
      ok jetzt passt:
      nur seltsam er hat kein downgrade gemacht
      esmax@ubuntu:~$ iob stop
      esmax@ubuntu:~$ npm install iobroker.js-controller@3.3.22
      up to date, audited 282 packages in 3s
      9 packages are looking for funding
        run `npm fund` for details
      7 vulnerabilities (1 low, 5 moderate, 1 high)
      To address issues that do not require attention, run:
        npm audit fix
      To address all issues (including breaking changes), run:
        npm audit fix --force
      Run `npm audit` for details.
      esmax@ubuntu:~$ iob start
      esmax@ubuntu:~$ iob status
      Objects type: jsonl
      States  type: jsonl
      esmax@ubuntu:~$ iob list instances
      + system.adapter.admin.0                  : admin                 : ubuntu                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : ubuntu                                   -  enabled
      + system.adapter.discovery.0              : discovery             : ubuntu                                   -  enabled
      + instance is alive
      esmax@ubuntu:~$
      Skript v.2023-06-20
      *** BASE SYSTEM ***
       Static hostname: ubuntu
             Icon name: computer
            Machine ID: 7be3a0aee2194ee18739a3f0fb03a71f
               Boot ID: c9f47a2216fa43918fa2392ef232ef9a
      Operating System: Ubuntu 23.04
                Kernel: Linux 6.2.0-1013-raspi
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       20:58:29 up 54 min,  2 users,  load average: 0.17, 0.24, 0.22
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=58.9'C
      volt=0.8600V
      *** Time and Time Zones ***
                     Local time: Tue 2023-09-26 20:58:30 CEST
                 Universal time: Tue 2023-09-26 18:58:30 UTC
                       RTC time: n/a
                      Time zone: Europe/Paris (CEST, +0200)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      esmax
      /home/esmax
      esmax adm dialout cdrom sudo audio video plugdev games users input render netdev gpio spi i2c iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.2G        739M        5.8G        3.2M        2.0G        7.4G
      Swap:             0B          0B          0B
      Total:          8.2G        739M        5.8G
               7809 M total memory
                704 M used memory
                616 M active memory
               1350 M inactive memory
               5531 M free memory
                 99 M buffer memory
               1785 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      Filesystem     Type   Size  Used Avail Use% Mounted on
      tmpfs          tmpfs  781M  3.1M  778M   1% /run
      /dev/mmcblk0p2 ext4    59G  4.8G   52G   9% /
      tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
      /dev/mmcblk0p1 vfat   253M  151M  102M  60% /boot/firmware
      tmpfs          tmpfs  781M  4.0K  781M   1% /run/user/1000
      [Tue Sep 26 20:04:09 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 dwc_otg.lpm_enable=0 console=tty1 root=LABEL=writable rootfstype=ext4 rootwait fixrtc quiet splash
      [Tue Sep 26 20:04:19 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      [Tue Sep 26 20:04:19 2023] EXT4-fs (mmcblk0p2): mounted filesystem 25a83575-fd50-4dcc-85e0-e3a81c621aa2 with ordered data mode. Quota mode: none.
      [Tue Sep 26 20:04:22 2023] EXT4-fs (mmcblk0p2): re-mounted 25a83575-fd50-4dcc-85e0-e3a81c621aa2. Quota mode: none.
      TARGET              SOURCE         FSTYPE   OPTIONS
      /                   /dev/mmcblk0p2 ext4     rw,relatime,discard,errors=remount-ro,commit=30
      |-/snap/core22/611  /dev/loop0     squashfs ro,nodev,relatime,errors=continue,threads=single
      |-/snap/core22/867  /dev/loop1     squashfs ro,nodev,relatime,errors=continue,threads=single
      |-/snap/lxd/25755   /dev/loop2     squashfs ro,nodev,relatime,errors=continue,threads=single
      |-/snap/snapd/18600 /dev/loop3     squashfs ro,nodev,relatime,errors=continue,threads=single
      |-/snap/lxd/24646   /dev/loop4     squashfs ro,nodev,relatime,errors=continue,threads=single
      `-/boot/firmware    /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.4G    /var/
      677M    /var/lib
      626M    /var/cache
      614M    /var/cache/apt
      528M    /var/cache/apt/archives
      Archived and active journals take up 39.0M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      19M     /opt/iobroker/iobroker-data/
      15M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      3.8M    /opt/iobroker/iobroker-data/objects.jsonl
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x lunar/main arm64 Packages
           18.13.0+dfsg1-1ubuntu2 500
              500 http://ports.ubuntu.com/ubuntu-ports lunar/universe arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.backitup.0               : backitup              : ubuntu                                   -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.10.1   , installed 6.3.5  [Updatable]
      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
      Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
      Objects and States
      Objects:        142
      States:         105
      Hit:1 http://ports.ubuntu.com/ubuntu-ports lunar InRelease
      Hit:2 http://ports.ubuntu.com/ubuntu-ports lunar-updates InRelease
      Hit:3 http://ports.ubuntu.com/ubuntu-ports lunar-backports InRelease
      Hit:4 https://deb.nodesource.com/node_18.x lunar InRelease
      Hit:5 http://ports.ubuntu.com/ubuntu-ports lunar-security InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       51024      8657/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       52828      8657/iobroker.js-co
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          45437      1/init
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        19378      539/systemd-resolve
      tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        19380      539/systemd-resolve
      tcp6       0      0 :::22                   :::*                    LISTEN      0          21209      1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          45439      1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       52867      8686/io.admin.0
      udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        19379      539/systemd-resolve
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        19377      539/systemd-resolve
      udp        0      0 192.168.178.51:68       0.0.0.0:*                           998        19983      793/systemd-network
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          47435      1/init
      udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                998        19990      793/systemd-network
      udp6       0      0 :::111                  :::*                                0          47437      1/init
      2023-09-26 20:57:19.162  - info: host.ubuntu added notifications configuration of host
      2023-09-26 20:57:19.717  - info: host.ubuntu Delete state "system.host.ubuntu.versions.nodeCurrent"
      2023-09-26 20:57:19.726  - info: host.ubuntu 3 instances found
      2023-09-26 20:57:19.737  - info: host.ubuntu starting 3 instances
      2023-09-26 20:57:19.811  - info: host.ubuntu instance system.adapter.admin.0 started with pid 8686
      2023-09-26 20:57:19.841  - info: host.ubuntu Delete state "system.host.ubuntu.versions.nodeNewest"
      2023-09-26 20:57:19.909  - info: host.ubuntu Delete state "system.host.ubuntu.versions.nodeNewestNext"
      2023-09-26 20:57:19.927  - info: host.ubuntu Delete state "system.host.ubuntu.versions.npmCurrent"
      2023-09-26 20:57:19.946  - info: host.ubuntu Delete state "system.host.ubuntu.versions.npmNewest"
      2023-09-26 20:57:19.965  - info: host.ubuntu Delete state "system.host.ubuntu.versions.npmNewestNext"
      2023-09-26 20:57:19.984  - info: host.ubuntu Some obsolete host states deleted.
      2023-09-26 20:57:22.810  - info: admin.0 (8686) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 4.0.24
      2023-09-26 20:57:22.899  - info: admin.0 (8686) requesting all states
      2023-09-26 20:57:22.900  - info: admin.0 (8686) requesting all objects
      2023-09-26 20:57:23.469  - info: admin.0 (8686) received all objects
      2023-09-26 20:57:23.778  - info: admin.0 (8686) http server listening on port 8081
      2023-09-26 20:57:23.780  - info: admin.0 (8686) Use link "http://localhost:8081" to configure.
      2023-09-26 20:57:23.796  - info: admin.0 (8686) socket.io server listening on port 8081
      2023-09-26 20:57:23.842  - info: host.ubuntu instance system.adapter.discovery.0 started with pid 8710
      2023-09-26 20:57:23.965  - info: admin.0 (8686) ==> Connected system.user.admin from ::ffff:192.168.178.39
      2023-09-26 20:57:24.230  - info: admin.0 (8686) ==> Connected system.user.admin from ::ffff:192.168.178.39
      2023-09-26 20:57:26.295  - info: discovery.0 (8710) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.17.1, js-controller: 4.0.24
      2023-09-26 20:57:27.790  - info: host.ubuntu instance system.adapter.backitup.0 started with pid 8733
      2023-09-26 20:57:30.561  - info: backitup.0 (8733) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.1, js-controller: 4.0.24
      2023-09-26 20:57:30.720  - info: backitup.0 (8733) [iobroker] backup will be activated at 02:40 every 1 day(s)
      iob diag has finished.
      Press any key for a summary
      #145
      Nee, 'er' hat den js-controller jetzt nochmal dort installiert, wo der admin 'ihm' gesagt hat, das er hin soll. Kurz: Du stehst im falschen Verzeichnis.
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
      muss das lauten.
      E 1 Antwort Letzte Antwort
      • E Esmax666
        @thomas-braun so ?
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        #146
        @esmax666
        Für so etwas verwende ich WinSCP
        https://winscp.net/eng/download.php
        Da hast du die typische Commander ansicht mit 2 Seiten. Eine Lokal und eine eine oder mehrere SSH-Sessions.
        Da kann man auch mal schnell was nachschauen.
        Meine Adapter und Widgets
        Links im Profil
          cd /opt/iobroker
          muss das lauten.
          Esmax666
          #147
          @thomas-braun said in iobroker geht nicht nach stromausfall:
          omg danke :)
          • OliverIOO OliverIO
            @esmax666
            Esmax666
            #148
            @oliverio
            wow war wirklich einfach
            problem ist genau wie letzte Woche:
            Nach mein backup startet iobroker einfach nicht mehr
            smax@ubuntu:/opt/iobroker/backups$ iobroker stop
            esmax@ubuntu:/opt/iobroker/backups$ iobroker restore iobroker_2022_09_21-02_40_10_backupiobroker.tar.gz
            iobroker controller daemon is not running
            host.ubuntu OK.
            host.ubuntu Clear all objects and states...
            clean 142 objects...
            Server Objects 127.0.0.1:36324 Error from InMemDB: Error: Object is marked as non deletable
            [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
            [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
            [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"]}}
            [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
            [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}}
            [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.repositories"]}}
            clean 105 states...
            host.ubuntu done.
            host.ubuntu Processed 0/3050 states
            host.ubuntu Processed 200/3050 states
            host.ubuntu Processed 400/3050 states
            host.ubuntu Processed 600/3050 states
            host.ubuntu Processed 800/3050 states
            host.ubuntu Processed 1000/3050 states
            host.ubuntu Processed 1200/3050 states
            host.ubuntu Processed 1400/3050 states
            host.ubuntu Processed 1600/3050 states
            host.ubuntu Processed 1800/3050 states
            host.ubuntu Processed 2000/3050 states
            host.ubuntu Processed 2200/3050 states
            host.ubuntu Processed 2400/3050 states
            host.ubuntu Processed 2600/3050 states
            host.ubuntu Processed 2800/3050 states
            host.ubuntu Processed 3000/3050 states
            3050 states restored.
            host.ubuntu Processed 0/4382 objects
            host.ubuntu Processed 200/4382 objects
            host.ubuntu Processed 400/4382 objects
            host.ubuntu Processed 600/4382 objects
            host.ubuntu Processed 800/4382 objects
            host.ubuntu Processed 1000/4382 objects
            host.ubuntu Processed 1200/4382 objects
            host.ubuntu Processed 1400/4382 objects
            host.ubuntu Processed 1600/4382 objects
            host.ubuntu Processed 1800/4382 objects
            host.ubuntu Processed 2000/4382 objects
            host.ubuntu Processed 2200/4382 objects
            host.ubuntu Processed 2400/4382 objects
            host.ubuntu Processed 2600/4382 objects
            host.ubuntu Processed 2800/4382 objects
            host.ubuntu Processed 3000/4382 objects
            host.ubuntu Processed 3200/4382 objects
            host.ubuntu Processed 3400/4382 objects
            host.ubuntu Processed 3600/4382 objects
            host.ubuntu Processed 3800/4382 objects
            host.ubuntu Processed 4000/4382 objects
            host.ubuntu Processed 4200/4382 objects
            4382 objects restored.
            host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular (1).woff
            host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.eot
            host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.ttf
            host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.woff
            host.ubuntu Upload user file "vis.0/HeatingControl/images/MaterialIcons-Regular.woff2
            host.ubuntu Upload user file "vis.0/HeatingControl/images/edit_copy.svg
            host.ubuntu Upload user file "vis.0/HeatingControl/images/fts_window_1w.svg
            host.ubuntu Upload user file "vis.0/HeatingControl/images/fts_window_1w_open.svg
            host.ubuntu Upload user file "vis.0/HeatingControl/images/heatingcontrol.png
            host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-blau-128x128.png
            host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-blau-512x512.png
            host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gelb-128x128.png
            host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gelb-512x512.png
            host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-grau-128x128.png
            host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-grau-512x512.png
            host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gruen-128x128.png
            host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-gruen-512x512.png
            host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-rot-128x128.png
            host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-rot-512x512.png
            host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-weiss-128x128.png
            host.ubuntu Upload user file "vis.0/HeatingControl/images/ioBrokerLogo-weiss-512x512.png
            host.ubuntu Upload user file "vis.0/HeatingControl/images/it_wifi.svg
            host.ubuntu Upload user file "vis.0/HeatingControl/vis-user.css
            host.ubuntu Upload user file "vis.0/HeatingControl/vis-views.json
            host.ubuntu Upload user file "vis.0/main/vis-views.json
            upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
            upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
            upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map application/json
            upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js.map application/json
            upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js application/javascript
            upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js.map application/json
            upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js application/javascript
            upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js.map application/json
            upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js application/javascript
            upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js.map custom/static/js/main.681927cc.js.map application/json
            upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js custom/static/js/main.681927cc.js application/javascript
            upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
            upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
            upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
            upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json
            upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
            upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
            upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
            upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/es.json custom/i18n/es.json application/json
            upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/en.json custom/i18n/en.json application/json
            upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/de.json custom/i18n/de.json application/json
            upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
            upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
            upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
            upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
            upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
            upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
            upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
            upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
            upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
            upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
            upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
            upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
            upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
            upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
            upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
            upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
            upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
            upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
            upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
            upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
            upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
            System successfully restored!
            esmax@ubuntu:/opt/iobroker/backups$ iobroker start
            • E Esmax666
              @oliverio
              host.ubuntu OK.
              clean 105 states...
              host.ubuntu done.
              #149
              Danach geht es erst richtig los.
              Schau in das
              iob logs --watch
              rein.
                Schau in das
                iob logs --watch
                rein.
                Esmax666
                schrieb am zuletzt editiert von Esmax666
                #150
                @thomas-braun stat.txt
                vielleicht muss man ein downgrade von iobroker komplet machen genau wie admin :/
                • E Esmax666
                  #151
                  @esmax666
                  Keine Ahnung. Mit solchen Oldtimer-Versionen beschäftige ich mich eigentlich auch nicht.
                    @esmax666
                    Esmax666
                    #152
                    @thomas-braun könntest du mein stat.txt öffnen ? da ist alles drin
                    sonst diag:
                    Skript v.2023-06-20
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                     21:29:22 up  1:25,  2 users,  load average: 0.96, 0.93, 0.65
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    temp=68.6'C
                    volt=0.9260V
                                   Local time: Tue 2023-09-26 21:29:22 CEST
                               Universal time: Tue 2023-09-26 19:29:22 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    esmax
                    /home/esmax
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            8.2G        601M        5.8G        3.3M        2.1G        7.6G
                    Swap:             0B          0B          0B
                    Total:          8.2G        601M        5.8G
                             7809 M total memory
                              573 M used memory
                              588 M active memory
                             1334 M inactive memory
                             5572 M free memory
                              104 M buffer memory
                             1876 M swap cache
                                0 M total swap
                                0 M used swap
                                0 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /dev/mmcblk0p2 ext4    59G  4.9G   51G   9% /
                    /var:
                    1.4G    /var/
                    677M    /var/lib
                    626M    /var/cache
                    614M    /var/cache/apt
                    4.5M    /opt/iobroker/backups/
                    31M     /opt/iobroker/iobroker-data/
                    19M     /opt/iobroker/iobroker-data/files
                    11M     /opt/iobroker/iobroker-data/objects.jsonl
                    1.6M    /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
                    /usr/bin/npm            9.6.7
                    /usr/bin/npx            9.6.7
                    nodejs:
                      Version table:
                    ioBroker Status
                     Cannot read system.config: null (OK when migrating or restoring)
                     Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    No connection to databases possible ...
                    Objects:                    file on 127.0.0.1
                    States:                     file on 127.0.0.1
                    js-controller:  3.3.22
                    admin:          6.3.5
                    Adapter State
                    + instance is alive
                    Cannot get list: undefined
                    Error: Object "system.config" not found
                    • E Esmax666
                      sonst diag:
                      Skript v.2023-06-20
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x0
                      temp=68.6'C
                      volt=0.9260V
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      esmax
                      /home/esmax
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:             0B          0B          0B
                               7809 M total memory
                                573 M used memory
                                588 M active memory
                               5572 M free memory
                                104 M buffer memory
                               1876 M swap cache
                                  0 M total swap
                                  0 M used swap
                                  0 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      1.4G    /var/
                      677M    /var/lib
                      626M    /var/cache
                      614M    /var/cache/apt
                      /usr/bin/npm            9.6.7
                      /usr/bin/npx            9.6.7
                      nodejs:
                        Version table:
                      ioBroker Status
                      admin:          6.3.5
                      Adapter State
                      + instance is alive
                      #153
                      @esmax666
                      Ich weiß nicht was passiert, wenn man soweit runterspringt. Offenbar nix gutes.
                        @esmax666
                        Esmax666
                        #154
                        wie soll am besten iobroker wieder neu installieren ?
                        iob fix hat leider nichts gebracht
                        dann würde ich noch admin downgrade machen
