  4. Mit conbee2 von deconz zu zigbee Adapter wechseln
    5.2k
118 Beiträge 8 Kommentatoren 12.4k Aufrufe 7 Beobachtet
  • D docsnyder7
    @dp20eic
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: evccpi
             Icon name: computer
            Machine ID: 82971e2b59e04cc6823b9b47e5bb8656
               Boot ID: e4ca9566265a45c2a18449101ce5c4b0
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     20:16:02 up 43 min,  3 users,  load average: 0.75, 0.64, 0.59
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=49.1'C
    volt=0.9360V
    *** Time and Time Zones ***
                   Local time: Thu 2023-09-21 20:16:02 CEST
               Universal time: Thu 2023-09-21 18:16:02 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    docsn
    /home/docsn
    docsn adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.8G        2.0G        4.6G         21M        1.3G        5.7G
    Swap:            99M          0B         99M
    Total:          7.9G        2.0G        4.7G
             7811 M total memory
             1960 M used memory
             2458 M active memory
              590 M inactive memory
             4552 M free memory
               78 M buffer memory
             1219 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      459G   12G  429G   3% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
    [Thu Sep 21 19:32:25 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:98:BE:6A vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=5f70fa40-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Sep 21 19:32:29 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Sep 21 19:32:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Thu Sep 21 19:32:31 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    5.1G    /var/
    4.4G    /var/log
    4.2G    /var/log/journal/82971e2b59e04cc6823b9b47e5bb8656
    437M    /var/cache
    Archived and active journals take up 4.1G in the file system.
    /opt/iobroker/backups:
    187M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    313M    /opt/iobroker/iobroker-data/
    254M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    45M     /opt/iobroker/iobroker-data/files/devices.admin/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    9.7M    /opt/iobroker/iobroker-data/objects.jsonl
    8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    @docsnyder7 der ist noch nicht fertig
    • D docsnyder7
      @dp20eic
      gar nicht WLAN... bis heute über den Deconz Adapter rein für zigbee
      brauch der auch WLAN?
      @docsnyder7 sagte in Mit conbee2 von deconz zu zigbee Adapter wechseln:
      Moin,
      da bin ich raus, ich kenne nur USB-Sticks oder Zigbee Sticks, die WLAN können, was man da für Deconz einstellen muss, kann ich nicht sagen, sorry.
      Serial settings
      Hier hast Du ein Gerät angegeben, das an einem USB Port hängt
      # Serial settings
      serial:
        # Location of CC2531 USB sniffer
        port: /dev/ttyACM0
      Dann passt das nicht, denn z2m versucht das Gerät zu erreichen.
      Bernd
      P.S.: Sorry, bin schon alt, hatte vorhin schon einmal in einem anderen Thread mit z2m zu tun, da ging es um ein WLAN fähigen Zigbee Stick.
        docsnyder7
                             v.2023-06-20
                 Icon name: computer
              Architecture: arm64
        Kernel:                 aarch64
        Userland:               arm64
        User-ID:                1000
        X-Server:               true
        Pending OS-Updates:     5
        Pending iob updates:    3
        Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:            7.8G        1.9G        4.4G         21M        1.5G        5.7G
        Swap:            99M          0B         99M
        Total:          7.9G        1.9G        4.5G
        Active iob-Instances:   31
        Active repo(s): stable
        ioBroker Core:          js-controller           5.0.12
                                admin                   6.10.1
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : evccpi                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : evccpi                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                8536
        States:                 6689
        Size of iob-Database:
        9.9M    /opt/iobroker/iobroker-data/objects.jsonl
        8.7M    /opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
          Moin,
          Serial settings
          # Serial settings
          serial:
            port: /dev/ttyACM0
          Bernd
          docsnyder7
          @dp20eic
          homeassistant: false
          frontend:
            port: 8080
          mqtt:
            base_topic: zigbee2mqtt
            server: mqtt://localhost:1883
          serial:
            adapter: deconz
            port: /dev/ttyACM0
          advanced:
            network_key:
              - 141
              - 93
              - 59
              - 154
              - 208
              - 213
              - 231
              - 68
              - 150
              - 73
              - 156
              - 197
              - 4
              - 79
              - 188
              - 50
            pan_id: 32585
            ext_pan_id:
              - 79
              - 241
              - 73
              - 17
              - 19
              - 123
          • D docsnyder7
                                 v.2023-06-20
                     Icon name: computer
                  Architecture: arm64
            Kernel:                 aarch64
            Userland:               arm64
            User-ID:                1000
            X-Server:               true
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
            MEMORY:
            Swap:            99M          0B         99M
                                    admin                   6.10.1
            Objects type: jsonl
            States  type: jsonl
            Objects:                8536
            States:                 6689
            @docsnyder7 in der full Ausgabe fehlt noch ne Menge
            • D docsnyder7
              @dp20eic
              der shelly läuft auf 1882
              hab grad alles gelöscht, reboot und bin dabei Z2M komplett neu aufzusetzen...
              Conbee auch nochmal resetet
              Zigbee2MQTT:info  2023-09-21 19:43:31: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2023-09-21.19-43-31' filename: log.txt
              Zigbee2MQTT:info  2023-09-21 19:43:31: Starting Zigbee2MQTT version 1.33.0 (commit #f224ef7)
              Zigbee2MQTT:info  2023-09-21 19:43:31: Starting zigbee-herdsman (0.18.5)
              Zigbee2MQTT:error 2023-09-21 19:43:31: Error while starting zigbee-herdsman
              Zigbee2MQTT:error 2023-09-21 19:43:31: Failed to start zigbee
              Zigbee2MQTT:error 2023-09-21 19:43:31: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
              Zigbee2MQTT:error 2023-09-21 19:43:31: Exiting...
              Zigbee2MQTT:error 2023-09-21 19:43:32: Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
                  at SerialPort.<anonymous> (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:200:28)
                  at SerialPort._error (/opt/zigbee2mqtt/node_modules/@serialport/stream/dist/index.js:75:22)
                  at /opt/zigbee2mqtt/node_modules/@serialport/stream/dist/index.js:111:18
              muss auf den stick auch noch was geflasht werden?
              musste noch einen Nachtrag in der yaml machen wegen dem conbee
              adapter: deconz
              auch das hilft nix
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              Die Fehlermeldung ist ja ziemlich eindeutig. Sicher, dass du da den korrekten Eintrag drin hast? Und sicher, dass alle anderen Adapter, etc. beendet sind?
              • Marc BergM Marc Berg
                docsnyder7
                schrieb am zuletzt editiert von docsnyder7
                @marc-berg
                docsn@evccpi:/opt/zigbee2mqtt $ ls -l /dev/serial/by-id
                insgesamt 0
                lrwxrwxrwx 1 root root 13 21. Sep 19:32 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2598659-if00 -> ../../ttyACM0
                lrwxrwxrwx 1 root root 13 21. Sep 19:32 usb-FTDI_FT232R_USB_UART_A10MKTHB-if00-port0 -> ../../ttyUSB0
                darf ich mich nach dem Reset überhaupt einloggen auf dem conbee
                • D docsnyder7
                  @marc-berg
                  insgesamt 0
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  Du musst alles andere, was sonst noch auf den Stick zugreift, beenden.
                    docsnyder7
                    @marc-berg
                    es greift nix mehr zu... die phoscon Oberfläche ist aus, hab nach dem Zurücksetzen noch nichtmal ein neues PW vergeben, DECONZ Adapter ist auch deinstalliert
                    zumindest bekomme ich jetzt die pan und soweiter mit Daten gefüllt
                    • D docsnyder7
                      @marc-berg
                      Marc BergM Offline
                      Marc BergM Offline
                      Marc Berg
                      was füllst du wo?
                        was füllst du wo?
                        docsnyder7
                        @marc-berg
                        habe zu anfang keine Einträge unter pan_id usw bekommen, die kommen jetzt
                        in einigen Foren wird der Porteintrag abgeändert...
                        port: >-
                            /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2426882-if00
                        Ergebniss
                        > zigbee2mqtt@1.33.0 start
                        > node index.js
                        Zigbee2MQTT:info  2023-09-21 20:52:07: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2023-09-21.20-52-07' filename: log.txt
                        Zigbee2MQTT:info  2023-09-21 20:52:07: Starting Zigbee2MQTT version 1.33.0 (commit #f224ef7)
                        Zigbee2MQTT:info  2023-09-21 20:52:07: Starting zigbee-herdsman (0.18.5)
                        Zigbee2MQTT:error 2023-09-21 20:52:08: Error while starting zigbee-herdsman
                        Zigbee2MQTT:error 2023-09-21 20:52:08: Failed to start zigbee
                        Zigbee2MQTT:error 2023-09-21 20:52:08: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
                        Zigbee2MQTT:error 2023-09-21 20:52:08: Exiting...
                        Zigbee2MQTT:error 2023-09-21 20:52:08: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2426882-if00'
                        • D docsnyder7
                          @marc-berg
                          port: >-
                          Ergebniss
                          > node index.js
                          Marc BergM Offline
                          Marc BergM Offline
                          Marc Berg
                          vorhin hast du diese ID hier gezeigt:
                          da passt was nicht. DE2426882 oder DE2598659???
                            docsnyder7
                            @marc-berg
                            die 2598659 ist meine ID... das Muster war die 2426882... nach der Vorgabe hab ich dann meine angepasst
                            • D docsnyder7
                              @marc-berg
                              Marc BergM Offline
                              Marc BergM Offline
                              Marc Berg
                              Aber die Fehlermeldung lautet doch, dass er die DE2426882 nicht finden kann. Das ist doch dann die falsche.
                                docsnyder7
                                @marc-berg
                                docsn@evccpi:/opt/zigbee2mqtt $ npm start
                                > node index.js
                                Zigbee2MQTT:info  2023-09-21 21:11:45: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2023-09-21.21-11-45' filename: log.txt
                                Zigbee2MQTT:info  2023-09-21 21:11:45: Starting Zigbee2MQTT version 1.33.0 (commit #f224ef7)
                                Zigbee2MQTT:info  2023-09-21 21:11:45: Starting zigbee-herdsman (0.18.5)
                                Zigbee2MQTT:error 2023-09-21 21:11:46: Error while starting zigbee-herdsman
                                Zigbee2MQTT:error 2023-09-21 21:11:46: Failed to start zigbee
                                Zigbee2MQTT:error 2023-09-21 21:11:46: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
                                Zigbee2MQTT:error 2023-09-21 21:11:46: Exiting...
                                Zigbee2MQTT:error 2023-09-21 21:11:46: Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2598659-if00'
                                frontend:
                                  port: 8080
                                mqtt:
                                serial:
                                  adapter: deconz
                                  port: >-
                                advanced:
                                  network_key:
                                    - 81
                                    - 57
                                    - 96
                                    - 198
                                    - 234
                                    - 212
                                    - 78
                                    - 33
                                    - 164
                                    - 186
                                    - 34
                                    - 234
                                    - 242
                                    - 153
                                    - 45
                                    - 192
                                  pan_id: 54324
                                  ext_pan_id:
                                    - 107
                                    - 4
                                    - 141
                                    - 94
                                    - 182
                                    - 189
                                    - 222
                                    - 1
                                D ? 2 Antworten Letzte Antwort
                                • D docsnyder7
                                  @marc-berg
                                  > node index.js
                                  frontend:
                                    port: 8080
                                  mqtt:
                                  serial:
                                    adapter: deconz
                                    port: >-
                                  advanced:
                                    network_key:
                                      - 81
                                      - 57
                                      - 96
                                      - 198
                                      - 234
                                      - 212
                                      - 78
                                      - 33
                                      - 164
                                      - 186
                                      - 34
                                      - 234
                                      - 242
                                      - 153
                                      - 45
                                      - 192
                                    pan_id: 54324
                                    ext_pan_id:
                                      - 107
                                      - 4
                                      - 141
                                      - 94
                                      - 182
                                      - 189
                                      - 222
                                      - 1
                                  docsnyder7
                                  Könnte man das alles mit einem anderen Stick vereinfachen... zb Sonoff
                                  • D docsnyder7
                                    Marc BergM Offline
                                    Marc BergM Offline
                                    Marc Berg
                                    Das funktioniert unabhängig vom verwendeten Stick. Ich lese aus der Fehlermeldung immer noch, dass der Stick schon in Benutzung ist. Könnte es sein, das du Z2M bereits als Service startest und zusätzlich über „npm start“?
                                      docsnyder7
                                      @marc-berg
                                      service ist nicht im autostart, zusätzlich händisch gestopt... Conbee zurückgesetzt.... reboot....
                                      NIX
                                      • D docsnyder7
                                        @marc-berg
                                        NIX
                                        Marc BergM Offline
                                        Marc BergM Offline
                                        Marc Berg
                                        @docsnyder7
                                        Die Langversion von
                                        iob diag
                                        bitte noch hier rein.
                                          @docsnyder7
                                          Die Langversion von
                                          iob diag
                                          docsnyder7
                                          @marc-berg
                                          Skript v.2023-06-20
                                          *** BASE SYSTEM ***
                                                   Icon name: computer
                                                     Boot ID: c0d30cedbf3f4ad28aa5deafb466f56d
                                                Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : arm64
                                           07:53:17 up  1:02,  3 users,  load average: 0.58, 0.78, 0.61
                                          CPU threads: 4
                                          Raspberry only:
                                          throttled=0x0
                                          temp=50.1'C
                                          volt=0.9360V
                                                         Local time: Fri 2023-09-22 07:53:17 CEST
                                                     Universal time: Fri 2023-09-22 05:53:17 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          docsn
                                          /home/docsn
                                          X-Server:       true
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            7.8G        1.9G        4.8G         21M        1.1G        5.7G
                                          Swap:            99M          0B         99M
                                          Total:          7.9G        1.9G        4.9G
                                                   7811 M total memory
                                                   1919 M used memory
                                                   2346 M active memory
                                                    497 M inactive memory
                                                   4765 M free memory
                                                     85 M buffer memory
                                                   1040 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          [Fri Sep 22 06:50:44 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:98:BE:6A vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=5f70fa40-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                          [Fri Sep 22 06:50:48 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Fri Sep 22 06:50:48 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                          [Fri Sep 22 06:50:50 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                          /var:
                                          5.2G    /var/
                                          4.4G    /var/log
                                          4.1G    /var/log/journal/82971e2b59e04cc6823b9b47e5bb8656
                                          539M    /var/cache
                                          Archived and active journals take up 4.0G in the file system.
                                          196M    /opt/iobroker/backups/
                                          319M    /opt/iobroker/iobroker-data/
                                          18M     /opt/iobroker/iobroker-data/objects.jsonl
                                          /usr/bin/npm            9.6.7
                                          /usr/bin/npx            9.6.7
                                          nodejs:
                                            Version table:
                                          Errors in npm tree: 0
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          No configuration change needed.
                                          Multihost discovery server: disabled
                                          Discovery authentication:   enabled
                                          Persistent activation:      disabled
                                          Objects:                    jsonl on 127.0.0.1
                                          States:                     jsonl on 127.0.0.1
                                          Core adapters versions
                                          js-controller:  5.0.12
                                          admin:          6.10.1
                                          javascript:     7.1.4
                                          Adapters from github:   3
                                          Adapter State
                                          + system.adapter.alexa2.0                 : alexa2                : evccpi                                   -  enabled
                                          + system.adapter.backitup.0               : backitup              : evccpi                                   -  enabled
                                          + system.adapter.cloud.0                  : cloud                 : evccpi                                   -  enabled
                                            system.adapter.daswetter.0              : daswetter             : evccpi                                   -  enabled
                                            system.adapter.devices.0                : devices               : evccpi                                   -  enabled
                                          + system.adapter.discovery.0              : discovery             : evccpi                                   -  enabled
                                          + system.adapter.email.0                  : email                 : evccpi                                   -  enabled
                                          + system.adapter.evcc.0                   : evcc                  : evccpi                                   -  enabled, port: 7070
                                          + system.adapter.fritzdect.0              : fritzdect             : evccpi                                   -  enabled
                                          + system.adapter.geofency.0               : geofency              : evccpi                                   -  enabled, port: 7999, bind: 0.0.0.0
                                          + system.adapter.history.0                : history               : evccpi                                   -  enabled
                                          + system.adapter.homee.0                  : homee                 : evccpi                                   -  enabled
                                            system.adapter.ical.0                   : ical                  : evccpi                                   -  enabled
                                            system.adapter.ical.1                   : ical                  : evccpi                                   - disabled
                                            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : evccpi                                   -  enabled
                                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : evccpi                                   -  enabled
                                            system.adapter.influxdb.0               : influxdb              : evccpi                                   - disabled, port: 8086
                                          + system.adapter.iot.0                    : iot                   : evccpi                                   -  enabled
                                          + system.adapter.javascript.0             : javascript            : evccpi                                   -  enabled
                                          + system.adapter.modbus.0                 : modbus                : evccpi                                   -  enabled
                                            system.adapter.mqtt.0                   : mqtt                  : evccpi                                   - disabled, port: 1883, bind: 0.0.0.0
                                            system.adapter.net-tools.0              : net-tools             : evccpi                                   - disabled
                                          + system.adapter.onvif.0                  : onvif                 : evccpi                                   -  enabled
                                            system.adapter.ping.0                   : ping                  : evccpi                                   - disabled
                                          + system.adapter.pushover.0               : pushover              : evccpi                                   -  enabled
                                          + system.adapter.pvforecast.0             : pvforecast            : evccpi                                   -  enabled
                                          + system.adapter.rpi2.0                   : rpi2                  : evccpi                                   -  enabled
                                            system.adapter.schoolfree.0             : schoolfree            : evccpi                                   -  enabled
                                          + system.adapter.shelly.0                 : shelly                : evccpi                                   -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.shelly.1                 : shelly                : evccpi                                   -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.shuttercontrol.0         : shuttercontrol        : evccpi                                   -  enabled
                                          + system.adapter.time-switch.0            : time-switch           : evccpi                                   -  enabled
                                          + system.adapter.tr-064.0                 : tr-064                : evccpi                                   -  enabled
                                          + system.adapter.tr-064.1                 : tr-064                : evccpi                                   -  enabled
                                          + system.adapter.tr-064.2                 : tr-064                : evccpi                                   -  enabled
                                          + system.adapter.tr-064.3                 : tr-064                : evccpi                                   -  enabled
                                          + system.adapter.trashschedule.0          : trashschedule         : evccpi                                   -  enabled
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : evccpi                                   -  enabled
                                          + system.adapter.vis-inventwo.0           : vis-inventwo          : evccpi                                   -  enabled
                                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : evccpi                                   -  enabled
                                            system.adapter.vis-weather.0            : vis-weather           : evccpi                                   -  enabled
                                            system.adapter.vis.0                    : vis                   : evccpi                                   -  enabled
                                          + instance is alive
                                          ioBroker-Repositories
                                          Installed ioBroker-Instances
                                          Used repository: stable
                                          Adapter    "admin"        : 6.10.1   , installed 6.10.1
                                          Adapter    "alexa2"       : 3.25.2   , installed 3.24.1 [Updatable]
                                          Adapter    "backitup"     : 2.8.1    , installed 2.6.23 [Updatable]
                                          Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                                          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                                          Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                          Adapter    "email"        : 1.2.0    , installed 1.2.0
                                          Adapter    "evcc"         : 0.0.10   , installed 0.0.10
                                          Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                                          Adapter    "geofency"     : 1.2.4    , installed 1.2.4
                                          Adapter    "history"      : 2.2.6    , installed 2.2.6
                                          Adapter    "homee"        : 1.2.0    , installed 1.2.0
                                          Adapter    "ical"         : 1.13.3   , installed 1.13.3
                                          Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                                          Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                          Controller "js-controller": 5.0.12   , installed 5.0.12
                                          Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                                          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                                          Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                                          Adapter    "onvif"        : 1.0.5    , installed 1.0.5
                                          Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                                          Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
                                          Adapter    "schoolfree"   : 1.1.2    , installed 1.1.1  [Updatable]
                                          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                                          Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                                          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                                          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                                          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                          Adapter    "web"          : 6.1.2    , installed 6.1.2
                                          Adapter    "ws"           : 2.5.5    , installed 2.5.5
                                          Objects and States
                                          Objects:        8536
                                          States:         6690
                                          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                          W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                          W: Some index files failed to download. They have been ignored, or old ones used instead.
                                          Hit:1 http://deb.debian.org/debian bullseye InRelease
                                          Get:2 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
                                          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                          Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
                                          Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Get:6 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
                                          Hit:7 https://phoscon.de/apt/deconz bullseye InRelease
                                          Get:8 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
                                          Err:2 https://packages.grafana.com/oss/deb stable InRelease
                                          Fetched 9713 B in 2s (4265 B/s)
                                          Reading package lists...
                                          Pending Updates: 5
                                          *** Listening Ports ***
                                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       22586      2287/io.shelly.0
                                          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          14064      652/vncserver-x11-c
                                          tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       22603      2352/sshd: docsn@pt
                                          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       23907      434/deCONZ
                                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       24720      434/deCONZ
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16390      656/sshd: /usr/sbin
                                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14055      638/cupsd
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16013      839/iobroker.js-con
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18756      839/iobroker.js-con
                                          tcp6       0      0 :::5900                 :::*                    LISTEN      0          14063      652/vncserver-x11-c
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          16392      656/sshd: /usr/sbin
                                          tcp6       0      0 :::5021                 :::*                    LISTEN      116        27604      4039/evcc
                                          tcp6       0      0 :::8887                 :::*                    LISTEN      116        28720      4039/evcc
                                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        15485      650/influxd
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22968      2747/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19285      1417/io.admin.0
                                          tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       22602      2352/sshd: docsn@pt
                                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14054      638/cupsd
                                          tcp6       0      0 :::7070                 :::*                    LISTEN      116        31319      4039/evcc
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14107      510/dhcpcd
                                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16411      666/cups-browsed
                                          udp        0      0 0.0.0.0:58081           0.0.0.0:*                           108        15257      429/avahi-daemon: r
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        31317      4039/evcc
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15255      429/avahi-daemon: r
                                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21684      2341/io.shelly.1
                                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       23910      434/deCONZ
                                          udp6       0      0 :::56841                :::*                                108        15258      429/avahi-daemon: r
                                          udp6       0      0 :::546                  :::*                                0          11177      510/dhcpcd
                                          udp6       0      0 :::5353                 :::*                                116        31318      4039/evcc
                                          udp6       0      0 :::5353                 :::*                                108        15256      429/avahi-daemon: r
                                          2023-09-22 07:47:44.048  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:47:59.069  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:48:44.074  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:48:59.075  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:49:14.074  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:49:29.079  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:49:44.080  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:50:00.046  - debug: shuttercontrol.0 (2814) calculate astrodata ...
                                          2023-09-22 07:50:00.048  - debug: shuttercontrol.0 (2814) Sun Azimut: 97°
                                          2023-09-22 07:50:00.049  - debug: shuttercontrol.0 (2814) Sun Elevation: 6.1°
                                          2023-09-22 07:50:14.094  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:50:29.083  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:50:59.089  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:51:14.094  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:51:29.093  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:51:44.095  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:52:14.093  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:52:29.105  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:52:59.109  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:53:14.119  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:53:29.125  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:53:44.120  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:53:59.127  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:54:14.124  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          2023-09-22 07:54:29.128  - info: shelly.1 (2341) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
                                          iob diag has finished.
                                          Copy text starting here
                                                               v.2023-06-20
                                                   Icon name: computer
                                                Architecture: arm64
                                          Kernel:                 aarch64
                                          Userland:               arm64
                                          User-ID:                1000
                                          X-Server:               true
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
                                          MEMORY:
                                          Mem:            7.8G        1.9G        4.8G         21M        1.1G        5.8G
                                          Swap:            99M          0B         99M
                                          Active iob-Instances:   30
        admin                   6.10.1
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                8536
                                          States:                 6690
                                          5.8M    /opt/iobroker/iobroker-data/states.jsonl
