  4. Zigbee Geräte fehlen nach Upgrade auf JS-Controller 5.0
26 Beiträge 3 Kommentatoren 2.6k Aufrufe 3 Beobachtet
  • P peterredl
    Ich hoffe, das ist die full Version...
    Skript v.2023-06-20
    *** BASE SYSTEM ***
    Static hostname: q4os-desktop
    Icon name: computer-desktop
    Chassis: desktop
    Machine ID: 163dfadd781c44cd94d7a397cdd870ff
    Boot ID: aec401992f534ee8ad15c09fdff5e2d4
    Operating System: Debian GNU/Linux 11 (bullseye)
    Kernel: Linux 5.10.0-21-amd64
    Architecture: x86-64
    model name : Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz
    Docker : false
    Virtualization : none
    Kernel : x86_64
    Userland : amd64
    Systemuptime and Load:
    14:33:42 up 1:41, 1 user, load average: 1.26, 1.06, 1.22
    CPU threads: 4
    *** Time and Time Zones ***
    Local time: Sun 2023-09-17 14:33:42 CEST
    Universal time: Sun 2023-09-17 12:33:42 UTC
    RTC time: Sun 2023-09-17 12:33:42
    Time zone: Europe/Vienna (CEST, +0200)
    NTP service: active
    RTC in local TZ: no
    *** User and Groups ***
    peter
    /home/peter
    peter dialout cdrom floppy sudo audio dip video plugdev users netdev lpadmin bluetooth scanner iobroker
    *** X-Server-Setup ***
    X-Server: true
    Desktop: trinity
    Terminal: x11
    Boot Target: graphical.target
    *** MEMORY ***
    total used free shared buff/cache available
    Mem: 15G 4.3G 9.0G 289M 2.7G 11G
    Swap: 9.2G 0B 9.2G
    Total: 25G 4.3G 18G
        15893 M total memory
         4286 M used memory
          649 M active memory
         5612 M inactive memory
         8956 M free memory
          181 M buffer memory
         2468 M swap cache
         9167 M total swap
            0 M used swap
         9167 M free swap
    *** FILESYSTEM ***
    df: /run/user/1000/doc: Operation not permitted
    Filesystem Type Size Used Avail Use% Mounted on
    udev devtmpfs 7.8G 0 7.8G 0% /dev
    tmpfs tmpfs 1.6G 2.8M 1.6G 1% /run
    /dev/mapper/q4os--desktop--vg-root ext4 91G 25G 62G 29% /
    tmpfs tmpfs 7.8G 56M 7.8G 1% /dev/shm
    tmpfs tmpfs 5.0M 8.0K 5.0M 1% /run/lock
    /dev/nvme0n1p1 ext2 470M 366M 80M 83% /boot
    tmpfs tmpfs 1.6G 36K 1.6G 1% /run/user/1000
    [Sun Sep 17 12:51:57 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Sep 17 12:51:57 2023] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
    [Sun Sep 17 12:51:58 2023] EXT4-fs (nvme0n1p1): mounting ext2 file system using the ext4 subsystem
    [Sun Sep 17 12:51:58 2023] EXT4-fs (nvme0n1p1): mounted filesystem without journal. Opts: (null)
    TARGET SOURCE FSTYPE OPTIONS
    / /dev/mapper/q4os--desktop--vg-root ext4 rw,relatime,errors=remount-ro
    |-/run/user/1000/doc portal fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot /dev/nvme0n1p1 ext2 rw,relatime
    /var:
    6.3G /var/
    4.2G /var/log/journal/163dfadd781c44cd94d7a397cdd870ff
    4.2G /var/log
    1.8G /var/lib
    Archived and active journals take up 160.0M in the file system.
    /opt/iobroker/backups:
    89M /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.4G /opt/iobroker/iobroker-data/
    2.0G /opt/iobroker/iobroker-data/history
    202M /opt/iobroker/iobroker-data/files
    167M /opt/iobroker/iobroker-data/backup-objects
    52M /opt/iobroker/iobroker-data/files/javascript.admin
    35M /opt/iobroker/iobroker-data/states.jsonl
    23M /opt/iobroker/iobroker-data/objects.jsonl
    21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    16M /opt/iobroker/iobroker-data/objects.json.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs v16.19.1
    /usr/bin/node v16.19.1
    /usr/bin/npm 8.19.3
    /usr/bin/npx 8.19.3
    nodejs:
    Installed: 16.19.1-deb-1nodesource1
    Candidate: 16.20.2-deb-1nodesource1
    Version table:
    16.20.2-deb-1nodesource1 500
    500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
    *** 16.19.1-deb-1nodesource1 100
    12.22.12~dfsg-1~deb11u4 500
    500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
    12.22.12~dfsg-1~deb11u3 500
    500 http://ftp.at.debian.org/debian bullseye/main amd64 Packages
    500 http://ftp.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: homebridge-ewelink@^11.0.2, required by iobroker.ham@5.3.1
    npm ERR! /home/peter/.npm/_logs/2023-09-17T12_33_51_450Z-debug-0.log
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication: enabled
    Persistent activation: disabled
    Objects: jsonl on 127.0.0.1
    States: jsonl on 127.0.0.1
    Core adapters versions
    js-controller: 5.0.12
    admin: 6.8.0
    javascript: 7.1.4
    Adapters from github: 0
    Adapter State
    • system.adapter.admin.0 : admin : q4os-desktop - enabled, port: 8081, bind: 0.0.0.0, run as: admin
    • system.adapter.alexa2.0 : alexa2 : q4os-desktop - enabled
    • system.adapter.backitup.0 : backitup : q4os-desktop - enabled
    • system.adapter.bosch-ebike.0 : bosch-ebike : q4os-desktop - enabled
    • system.adapter.broadlink2.0 : broadlink2 : q4os-desktop - enabled
      system.adapter.cloud.0 : cloud : q4os-desktop - disabled
      system.adapter.daswetter.0 : daswetter : q4os-desktop - enabled
    • system.adapter.device-reminder.0 : device-reminder : q4os-desktop - enabled
    • system.adapter.device-watcher.0 : device-watcher : q4os-desktop - enabled
    • system.adapter.discovery.0 : discovery : q4os-desktop - enabled
    • system.adapter.fb-checkpresence.0 : fb-checkpresence : q4os-desktop - enabled
      system.adapter.flot.0 : flot : q4os-desktop - enabled
    • system.adapter.fronius.0 : fronius : q4os-desktop - enabled
      system.adapter.fuelpricemonitor.0 : fuelpricemonitor : q4os-desktop - enabled
    • system.adapter.go-e.0 : go-e : q4os-desktop - enabled
    • system.adapter.ham.0 : ham : q4os-desktop - enabled
    • system.adapter.history.0 : history : q4os-desktop - enabled
    • system.adapter.hmip.0 : hmip : q4os-desktop - enabled
    • system.adapter.hs100.0 : hs100 : q4os-desktop - enabled
      system.adapter.info.0 : info : q4os-desktop - enabled
    • system.adapter.iot.0 : iot : q4os-desktop - enabled
    • system.adapter.javascript.0 : javascript : q4os-desktop - enabled
    • system.adapter.mercedesme.0 : mercedesme : q4os-desktop - enabled
    • system.adapter.mihome.0 : mihome : q4os-desktop - enabled, port: 9898, bind: 0.0.0.0
    • system.adapter.mqtt.0 : mqtt : q4os-desktop - enabled, port: 1886, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0 : netatmo-crawler : q4os-desktop - enabled
    • system.adapter.netatmo.0 : netatmo : q4os-desktop - enabled
    • system.adapter.opendtu.0 : opendtu : q4os-desktop - enabled
    • system.adapter.shelly.0 : shelly : q4os-desktop - enabled, port: 1882, bind: 0.0.0.0
    • system.adapter.sonoff.0 : sonoff : q4os-desktop - enabled, port: 1884, bind: 0.0.0.0
    • system.adapter.sureflap.0 : sureflap : q4os-desktop - enabled
    • system.adapter.telegram.0 : telegram : q4os-desktop - enabled, port: 8443, bind: 0.0.0.0
    • system.adapter.tuya.0 : tuya : q4os-desktop - enabled
      system.adapter.vis-hqwidgets.0 : vis-hqwidgets : q4os-desktop - enabled
    • system.adapter.vis-inventwo.0 : vis-inventwo : q4os-desktop - enabled
      system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : q4os-desktop - enabled
      system.adapter.vis-timeandweather.0 : vis-timeandweather : q4os-desktop - enabled
      system.adapter.vis-weather.0 : vis-weather : q4os-desktop - enabled
      system.adapter.vis.0 : vis : q4os-desktop - enabled
    • system.adapter.web.0 : web : q4os-desktop - enabled, port: 8082, bind: 0.0.0.0, run as: admin
    • system.adapter.zigbee.0 : zigbee : q4os-desktop - enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    • instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter "admin" : 6.8.0 , installed 6.8.0
    Adapter "alexa2" : 3.24.1 , installed 3.24.1
    Adapter "backitup" : 2.6.23 , installed 2.6.23
    Adapter "bosch-ebike" : 0.0.3 , installed 0.0.3
    Adapter "broadlink2" : 2.1.5 , installed 2.1.5
    Adapter "cloud" : 4.4.1 , installed 4.4.1
    Adapter "daswetter" : 3.1.10 , installed 3.1.10
    Adapter "device-reminder": 1.2.9 , installed 1.2.9
    Adapter "device-watcher": 2.9.3 , installed 2.9.3
    Adapter "discovery" : 3.1.0 , installed 3.1.0
    Adapter "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter "flot" : 1.12.0 , installed 1.12.0
    Adapter "fronius" : 1.1.3 , installed 1.1.3
    Adapter "fuelpricemonitor": 0.3.6 , installed 0.3.6
    Adapter "go-e" : 1.0.27 , installed 1.0.27
    Adapter "ham" : 5.3.1 , installed 5.3.1
    Adapter "history" : 2.2.6 , installed 2.2.6
    Adapter "hmip" : 1.20.0 , installed 1.20.0
    Adapter "hs100" : 2.1.2 , installed 2.1.2
    Adapter "info" : 1.9.26 , installed 1.9.26
    Adapter "iot" : 1.14.5 , installed 1.14.5
    Adapter "javascript" : 7.1.4 , installed 7.1.4
    Controller "js-controller": 5.0.12 , installed 5.0.12
    Adapter "mercedesme" : 0.1.1 , installed 0.1.1
    Adapter "mihome" : 1.4.0 , installed 1.4.0
    Adapter "mqtt" : 4.1.1 , installed 4.1.1
    Adapter "netatmo" : 3.1.0 , installed 3.1.0
    Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1
    Adapter "opendtu" : 0.1.7 , installed 0.1.7
    Adapter "shelly" : 6.4.1 , installed 6.4.1
    Adapter "simple-api" : 2.7.2 , installed 2.7.2
    Adapter "socketio" : 6.5.5 , installed 6.5.5
    Adapter "sonoff" : 2.5.3 , installed 2.5.3
    Adapter "sureflap" : 1.2.0 , installed 1.2.0
    Adapter "telegram" : 1.16.0 , installed 1.16.0
    Adapter "tuya" : 3.14.2 , installed 3.14.2
    Adapter "vis" : 1.4.16 , installed 1.4.16
    Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
    Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
    Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
    Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
    Adapter "vis-weather" : 2.5.6 , installed 2.5.6
    Adapter "web" : 6.1.2 , installed 6.1.2
    Adapter "ws" : 2.5.5 , installed 2.5.5
    Adapter "zigbee" : 1.8.23 , installed 1.8.23
    Objects and States
    Objects: 27363
    States: 20597
    E: Failed to fetch http://ppa.launchpad.net/morphis/anbox-support/ubuntu/dists/jammy/InRelease 403 Forbidden [IP: 185.125.190.52 80]
    E: The repository 'http://ppa.launchpad.net/morphis/anbox-support/ubuntu jammy InRelease' is not signed.
    E: The repository 'http://security.debian.org bullseye/updates Release' does not have a Release file.
    Pending Updates: 203
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
    tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 0 19753 1264/exim4
    tcp 0 0 127.0.0.1:1883 0.0.0.0:* LISTEN 114 19499 662/mosquitto
    tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 22616 1601/io.sonoff.0
    tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 0 15224 986/smbd
    tcp 0 0 0.0.0.0:1886 0.0.0.0:* LISTEN 1001 24947 2158/io.mqtt.0
    tcp 0 0 127.0.0.1:3551 0.0.0.0:* LISTEN 0 20164 931/apcupsd
    tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 20811 633/iobroker.js-con
    tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 20788 633/iobroker.js-con
    tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 0 15225 986/smbd
    tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 9850 1/init
    tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 20497 632/cupsd
    tcp6 0 0 ::1:25 :::* LISTEN 0 19754 1264/exim4
    tcp6 0 0 ::1:1883 :::* LISTEN 114 19500 662/mosquitto
    tcp6 0 0 :::445 :::* LISTEN 0 15222 986/smbd
    tcp6 0 0 :::139 :::* LISTEN 0 15223 986/smbd
    tcp6 0 0 :::111 :::* LISTEN 0 9854 1/init
    tcp6 0 0 :::8081 :::* LISTEN 1001 20981 1342/io.admin.0
    tcp6 0 0 :::8082 :::* LISTEN 1001 56228 5884/io.web.0
    tcp6 0 0 :::6547 :::* LISTEN 0 19234 668/java
    tcp6 0 0 ::1:631 :::* LISTEN 0 20496 632/cupsd
    udp 0 0 0.0.0.0:45081 0.0.0.0:* 106 18261 566/avahi-daemon: r
    udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 26664 2102/io.ham.0
    udp 0 0 224.0.0.251:5353 0.0.0.0:* 1000 23241 1657/chrome
    udp 0 0 0.0.0.0:5353 0.0.0.0:* 106 18259 566/avahi-daemon: r
    udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 22575 1586/io.shelly.0
    udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 21162 1616/io.tuya.0
    udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 21163 1616/io.tuya.0
    udp 0 0 0.0.0.0:15001 0.0.0.0:* 1001 25907 2417/io.broadlink2.
    udp 0 0 0.0.0.0:56606 0.0.0.0:* 1001 27109 2417/io.broadlink2.
    udp 0 0 0.0.0.0:111 0.0.0.0:* 0 9851 1/init
    udp 0 0 192.168.2.255:137 0.0.0.0:* 0 18964 895/nmbd
    udp 0 0 192.168.2.222:137 0.0.0.0:* 0 18963 895/nmbd
    udp 0 0 0.0.0.0:137 0.0.0.0:* 0 18950 895/nmbd
    udp 0 0 192.168.2.255:138 0.0.0.0:* 0 18966 895/nmbd
    udp 0 0 192.168.2.222:138 0.0.0.0:* 0 18965 895/nmbd
    udp 0 0 0.0.0.0:138 0.0.0.0:* 0 18951 895/nmbd
    udp 0 0 0.0.0.0:631 0.0.0.0:* 0 20516 743/cups-browsed
    udp 0 0 0.0.0.0:9898 0.0.0.0:* 1001 23354 2147/io.mihome.0
    udp 0 0 0.0.0.0:43843 0.0.0.0:* 1001 25293 2417/io.broadlink2.
    udp6 0 0 :::5353 :::* 106 18260 566/avahi-daemon: r
    udp6 0 0 :::46479 :::* 0 19222 668/java
    udp6 0 0 :::111 :::* 0 9857 1/init
    udp6 0 0 :::3052 :::* 0 20869 668/java
    udp6 0 0 :::60662 :::* 106 18262 566/avahi-daemon: r
    2023-09-17 14:30:00.036 - info: host.q4os-desktop instance system.adapter.netatmo-crawler.0 started with pid 8970
    2023-09-17 14:30:01.380 - info: netatmo-crawler.0 (8970) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v16.19.1, js-controller: 5.0.12
    2023-09-17 14:30:01.456 - info: netatmo-crawler.0 (8970) Getting data for stationid:70:ee:50:53:39:f8
    2023-09-17 14:30:01.804 - warn: netatmo-crawler.0 (8970) Could not work with station 1 - Message: Error: undefined is not a valid state value
    2023-09-17 14:30:01.807 - info: netatmo-crawler.0 (8970) Getting data for stationid:70:ee:50:7f:96:be
    2023-09-17 14:30:02.094 - warn: netatmo-crawler.0 (8970) Could not work with station 2 - Message: Error: undefined is not a valid state value
    2023-09-17 14:30:02.095 - info: netatmo-crawler.0 (8970) Getting data for stationid:70:ee:50:27:ac:9a
    2023-09-17 14:30:02.394 - warn: netatmo-crawler.0 (8970) Could not work with station 3 - Message: Error: undefined is not a valid state value
    2023-09-17 14:30:02.397 - info: netatmo-crawler.0 (8970) Getting data for stationid:70:ee:50:96:a4:36
    2023-09-17 14:30:03.866 - info: netatmo-crawler.0 (8970) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2023-09-17 14:30:04.399 - info: host.q4os-desktop instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-17 14:33:11.113 - info: ham.0 (2102) stateChange ham.0.Messsteckdose.Messsteckdose-History.S2R1 {"val":"uLYLAAAAAADPcqsqAQ4BAgXADwAAAAAAAAAAAQE=","ack":true,"ts":1694953991111,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991111}
    2023-09-17 14:33:11.154 - info: ham.0 (2102) stateChange ham.0.Device3c65fe-Sonoff-Schalter.Device3c65fe-Sonoff-Schalter-History.S2R1 {"val":"1DahAgAAAACz8hUoAQ4BwA/AD+ENAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
    2023-09-17 14:33:11.155 - info: ham.0 (2102) stateChange ham.0.S26Hauseingang.S26Hauseingang-History.S2R1 {"val":"IjF+AQAAAABl+DgpAQ4BwA/AD7mTAAAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
    2023-09-17 14:33:11.157 - info: ham.0 (2102) stateChange ham.0.Abstellraum.Abstellraum-History.S2R1 {"val":"+D9jAwAAAACP6VMnAQ4BwA/AD6CNAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
    2023-09-17 14:33:11.161 - info: ham.0 (2102) stateChange ham.0.Bau-WC-Licht.Bau-WC-Licht-History.S2R1 {"val":"NjGIAgAAAABR+C4oAQ4BwA/ADxoDAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
    2023-09-17 14:33:11.161 - info: ham.0 (2102) stateChange ham.0.Device4d7fc5-S26-Sonoff-Ham.Device4d7fc5-S26-Sonoff-Ham-History.S2R1 {"val":"aiefAgAAAAAdAhgoAQ4BwA/AD5ANAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
    2023-09-17 14:33:11.163 - info: ham.0 (2102) stateChange ham.0.Device3be921-S20-Sonoff-1.Device3be921-S20-Sonoff-1-History.S2R1 {"val":"aiefAgAAAAAdAhgoAQ4BwA/AD6QNAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
    2023-09-17 14:33:11.165 - info: ham.0 (2102) stateChange ham.0.Device6aae8d-Sonoff-Schalter.Device6aae8d-Sonoff-Schalter-History.S2R1 {"val":"1DahAgAAAACz8hUoAQ4BwA/AD/AOAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
    2023-09-17 14:33:11.166 - info: ham.0 (2102) stateChange ham.0.Device4110d0-Sonoff-Schalter.Device4110d0-Sonoff-Schalter-History.S2R1 {"val":"1DahAgAAAACz8hUoAQ4BwA/AD+YNAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
    2023-09-17 14:33:11.168 - info: ham.0 (2102) stateChange ham.0.Christbaum.Christbaum-History.S2R1 {"val":"+D9jAwAAAACP6VMnAQ4BwA/AD4RfAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
    2023-09-17 14:33:11.170 - info: ham.0 (2102) stateChange ham.0.Vitrine.Vitrine-History.S2R1 {"val":"1DahAgAAAACz8hUoAQ4BwA/AD/MNAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
    2023-09-17 14:33:11.172 - info: ham.0 (2102) stateChange ham.0.Garagentor.Garagentor-History.S2R1 {"val":"+D9jAwAAAACP6VMnAQ4BwA/ADzFwAQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
    2023-09-17 14:33:11.173 - info: ham.0 (2102) stateChange ham.0.Toilette.Toilette-History.S2R1 {"val":"+D9jAwAAAACP6VMnAQ4BwA/ADxZ+AQAAAAAAAQE=","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
    2023-09-17 14:33:11.175 - info: ham.0 (2102) stateChange ham.0.Pool.Pool-History.S2R1 {"val":"CdqjAgAAAAB+TxMoAgECDgHAD8APAwkBAAAAAAABAQ==","ack":true,"ts":1694953991153,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1694953991153}
    iob diag has finished.
    Press any key for a summary
    @peterredl sagte in Zigbee Geräte fehlen nach Upgrade auf JS-Controller 5.0:
    Desktop: trinity
    Denn kannste direkt schon mal ausschalten. Ersatzlos.
    P 1 Antwort Letzte Antwort
      Desktop: trinity
      peterredl
      sorry, mit mir ist es nicht leicht....
      was soll ich wo ausschalten?
      • P peterredl
        @peterredl
        sudo systemctl set-default multi-user.target
        sudo systemctl isolate multi-user.target
        • P peterredl
          @peterredl
          Deine Distribution ist irgendwie sehr schräg aufgestellt...
            @peterredl
            peterredl
            Ich bin wohl der größte Trottel….
            Jetzt habe ich deine Eingaben eingegeben und jetzt verlangt er das Desktop Login von mir. Weiß ich nicht mehr und komme nicht mehr ins System. Auch ein Neustart des Rechners hilft nicht. Jetzt schreibe ich von meinem Tablet. Ich denke, jetzt wird nur mehr eine komplette Neuinstallation des Rechners helfen….
            Verzweiflung pur !!!!
            • P peterredl
              Für verbummelte Passworte kann ich ja nun nix.
              • P peterredl
                Dann nimm diesmal ein reines Debian Bookworm, ohne Desktop.
                Das q4-Dingsi scheint mir jedenfalls eh etwas 'komisch'.
                  peterredl
                  Sorry, war wirklich nicht böse gemeint. Ich habe den Rechner vor Jahren aufgesetzt und seitdem ist er gelaufen und hat mich nie nach einem Login gefragt….
                  Ich danke dir für deine Bemühungen und hoffe, dass ich nach dem neuaufstzen des Rechners, den IoBroker wieder aufsetzen kann und das letzte Backup wieder einspielen kann. Danke.
                  • P peterredl
                    peterredl
                    @peterredl
                    Ich bin wieder im System. Logindaten gefunden.
                    Alles läuft wieder bis auf den Zigbee Adapter….
                    Hast vielleicht diesbezüglich noch einen Tip für mich ?
                    GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                    • P peterredl
                      @peterredl
                      GlasfaserG Offline
                      GlasfaserG Offline
                      ioBroker Log zeigen !
                      EDIT :
                      Hast du auch mal dein gesamtes Sytem neu gestartet !?
                      • P peterredl
                        @peterredl
                        @peterredl
                        iob diag
                        sagt?
                        Da hängen auch noch knapp zweihundert Updates in der Pipeline. Die solltest du zunächst mal einspielen.
