  4. Synology Docker Multihost
10 Beiträge 4 Kommentatoren 1.4k Aufrufe 4 Beobachtet
    Skol
    Hallo Leute,
    ich möchte ein Multihost System mit meiner Synology (Docker) und einem Raspberry verbinden.
    Auf der Synology läuft in Docker:
    • Portainer
    • iobroker
    • redis
    Multihost ist lt. iobroker Doku aktiviert - link
    Tricky war das setzen der Redis.conf, da es das file einfach nicht gibt.
    Angeblich sollte das aber mit folgendem code im redis container funktionieren:
    root@818c4be48c4f:/data# redis-cli
    127.0.0.1:6379> set bind 0.0.0.0
    OK
    127.0.0.1:6379> set protected_mode no
    OK
    127.0.0.1:6379> save
    OK
    (1.43s)
    127.0.0.1:6379> quit
    Auf dem Host hab ich die mit iobroker setup custom folgendes eingestellt:
    Current configuration:
    - Objects database:
      - Type: file
      - Host/Unix Socket: 127.0.0.1
      - Port: 9001
    - States database:
      - Type: redis
      - Host/Unix Socket: 172.18.0.3
      - Port: 6379
    - Data Directory: ../../iobroker-data/
    Gestartet mit:
    iobroker multihost enable
    Multihost discovery server activated on this host. If iobroker is currently not running please start befeore trying to discover this host.
    Important: Multihost discovery works with UDP packets. Make sure they are routed correctly in your network. If you use Docker you also need to configure this correctly.
    Multihost discovery will be automatically deactivated after 15 minutes. If you want to activate it permanently use the --persist flag
    Discovery authentication activated.
    Enter secret phrase for connection: ****
    Repeat secret phrase for connection: ****
    Changing objects server to accept connections on all IP addresses.
    Please check the binding of redis service. By default it is only local: http://download.redis.io/redis-stable/redis.conf
    Change "bind 127.0.0.1" to "bind 0.0.0.0" or to others.
    Please restart ioBroker for the changes to take effect: "iobroker restart"
    Multihost discovery server: enabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    file on 0.0.0.0
    States:                     redis on 172.18.0.3
    Am Slave ist folgendes eingestellt:
    - Objects database:
      - Type: file
      - Host/Unix Socket: 192.168.1.14
      - Port: 9001
    - States database:
      - Type: redis
      - Port: 6379
    - Host name: IOB_raspberry
    Auf dem Slave kann ich mich aber verdammt noch mal nicht verbinden. Dort bekomme ich immer folgende Fehlermeldung:
    $ iobroker multihost connect
    No connection to states 192.168.1.14:6379[redis]
    Nach einer wirklich schlaflosen Nacht und einigen Bier versuche ich somit auf diesem Weg um eure Hilfe zu bitten. Ich seh den Wald vor lauter Bäumen nicht mehr.
    Dankeschön!
    HomoranH OliverIOO 2 Antworten Letzte Antwort
    • S Skol
      Hallo Leute,
      • Portainer
      • iobroker
      • redis
      OK
      OK
      OK
      (1.43s)
      - Objects database:
        - Type: file
        - Port: 9001
      - States database:
        - Type: redis
        - Port: 6379
      Gestartet mit:
      - Objects database:
        - Type: file
        - Port: 9001
      - States database:
        - Type: redis
        - Port: 6379
      Dankeschön!
      @skol sagte in Synology Docker Multihost:
      die Krux mit Containern! Deswegen nutze ich sie nicht.
      nur ein Hinweis: sind alle Ports durchgereicht?
      dann bin ich leider wieder raus
        Skol
        Tja leider brauch ich Docker...
        NetStat Synology - 192.168.1.14
        root@IOB_Synology:/opt/iobroker# netstat
        Active Internet connections (w/o servers)
        Proto Recv-Q Send-Q Local Address           Foreign Address         State
        tcp        0      0 localhost:46208         localhost:9001          ESTABLISHED
        tcp        0      0 localhost:9001          localhost:46208         ESTABLISHED
        tcp        0      0 localhost:9001          localhost:46180         ESTABLISHED
        tcp        0      0 IOB_Synology:58226      redis.iob_private:6379  ESTABLISHED
        tcp        0      0 localhost:46182         localhost:9001          ESTABLISHED
        tcp        0      0 IOB_Synology:58236      redis.iob_private:6379  ESTABLISHED
        tcp        0      0 IOB_Synology:58224      redis.iob_private:6379  ESTABLISHED
        tcp        0      0 localhost:9001          localhost:46206         ESTABLISHED
        tcp        0      0 localhost:9001          localhost:46182         ESTABLISHED
        tcp        0      0 IOB_Synology:58234      redis.iob_private:6379  ESTABLISHED
        tcp        0      0 localhost:9001          localhost:46172         ESTABLISHED
        tcp        0      0 localhost:9001          localhost:46204         ESTABLISHED
        tcp        0      0 IOB_Synology:9001       192.168.1.11:42354      ESTABLISHED
        tcp        0      0 localhost:46178         localhost:9001          ESTABLISHED
        tcp        0      0 localhost:46170         localhost:9001          ESTABLISHED
        tcp        0      0 localhost:46172         localhost:9001          ESTABLISHED
        tcp        0      0 IOB_Synology:58262      redis.iob_private:6379  ESTABLISHED
        tcp        0      0 IOB_Synology:58260      redis.iob_private:6379  ESTABLISHED
        tcp        0      0 IOB_Synology:58264      redis.iob_private:6379  ESTABLISHED
        tcp        0      0 localhost:9001          localhost:46178         ESTABLISHED
        tcp        0      0 localhost:9001          localhost:46170         ESTABLISHED
        tcp        0      0 localhost:46206         localhost:9001          ESTABLISHED
        tcp        0      0 IOB_Synology:9001       192.168.1.11:42346      ESTABLISHED
        tcp        0      0 localhost:46180         localhost:9001          ESTABLISHED
        tcp        0      0 IOB_Synology:58238      redis.iob_private:6379  ESTABLISHED
        tcp        0      0 localhost:46204         localhost:9001          ESTABLISHED
        tcp6       0      0 iobroker.iob_publi:8081 192.168.1.28:63176      ESTABLISHED
        Active UNIX domain sockets (w/o servers)
        Proto RefCnt Flags       Type       State         I-Node   Path
        unix  3      [ ]         STREAM     CONNECTED     2504088
        unix  3      [ ]         STREAM     CONNECTED     2504091
        unix  3      [ ]         STREAM     CONNECTED     2504945
        unix  3      [ ]         STREAM     CONNECTED     2504947
        unix  3      [ ]         STREAM     CONNECTED     2504089
        unix  3      [ ]         STREAM     CONNECTED     2504946
        unix  3      [ ]         STREAM     CONNECTED     2504948
        unix  3      [ ]         STREAM     CONNECTED     2504090
        Netstat Raspberry (Slave) - 192.168.1.11
        tcp        0     64 192.168.1.11:ssh        192.168.1.28:50225      ESTABLISHED
        tcp        0      0 192.168.1.11:55316      192.168.1.14:9001       ESTABLISHED
        tcp        0      0 192.168.1.11:55310      192.168.1.14:9001       ESTABLISHED
        tcp        0      0 192.168.1.11:48260      192.168.1.14:9001       TIME_WAIT
        tcp        0      0 192.168.1.11:48262      192.168.1.14:9001       TIME_WAIT
        • S Skol
          Skol
          Eventuell liegt es doch an der Verbindung zu Redis.
          Wie stelle ich unter Portainer den Pfad zu dieser verdammten redis.conf ein?
          Redis hätte gerne folgendes im Startcommand - Was geb ich da beim Portainer ein?
          docker run -v /myredis/conf:/usr/local/etc/redis --name myredis redis redis-server /usr/local/etc/redis/redis.conf
          • S Skol
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
              Skol
              Danke...
              Wieder ein Schritt weiter.
              Es lag wirklich an den IP Settings.
              Läuft Redis unter Docker so muss man beim Verbinden vom iobroker slave andere Verbindungsdaten eingeben
              - Objects database:
                - Type: file
                - Host/Unix Socket: 192.168.1.14 -> IP Adresse Iobroker Master
                - Port: 9001
              - States database:
                - Type: redis
                - Host/Unix Socket: 192.168.1.10 -> IP Adresse Docker System
                - Port: 6379
              Damit hats dann schlussendlich geklappt. Was so ein paar Zahlen ausmachen können.
              • S Skol
                Hallo Leute,
                • Portainer
                • iobroker
                • redis
                OK
                OK
                OK
                (1.43s)
                - Objects database:
                  - Type: file
                  - Port: 9001
                - States database:
                  - Type: redis
                  - Port: 6379
                Gestartet mit:
                - Objects database:
                  - Type: file
                  - Port: 9001
                - States database:
                  - Type: redis
                  - Port: 6379
                Dankeschön!
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                @skol
                Oh man, docker nicht als vm Ersatz einsetzen
                und alles in ein Image installieren.
                Lieber 2 Container erstellen und die netztechnisch einkapseln
                So kannst du jeden Container einfach upgraden falls es notwendig ist.
                So wie du es jetzt gemacht hast musst du beim Upgrade von Iobroker
                Auch gleich noch Redis neu installieren
                Mit docker-compose, was in portainer stacks genannt wird, sind solle zusammengehörenden Services auch wirklich einfach erstellt.
                Ich füge nachher mal meine Definition hier an. Ich verwende allerdings ein macvlan, was den Stress mit Port mappings noch weiter reduziert.
                so sieht meine docker-compose/stacks aus
                version: '3'
                services:
                  iobrokerprod4:
                    restart: always
                    image: buanet/iobroker:latest
                    container_name: iobrokerprod4
                    hostname: iobrokerprod4
                    ports:
                      - "8081:8081"
                    environment:
                        SETGID: 1001
                        SETUID: 1001
                    volumes:
                      - /home/iobroker/docker/volume/iobroker_prod4:/opt/iobroker
                      - /media/iobroker_backup/:/opt/iobroker/backup
                    networks:
                      dockerMACVLAN:
                        ipv4_address: 192.168.1.85
                      iobrokerprod4:
                  redis4:
                    image: "redis:alpine"
                    volumes:
                      - /home/iobroker/docker/volume/redis_prod4:/data
                    networks:
                      iobrokerprod4:
                networks:
                  dockerMACVLAN:
                    external: true
                  iobrokerprod4:
                anmerkungen:
                • die servicenamen iobrokerprod4 und redis4 legt docker normalerweise innerhalb der container als hostnamen an, daher sind die container im gemeinsamen netzwerk darunter auch ansprechbar und man muss sich nicht mit den internen ip adressen rumärgern
                • in dieser konfiguration ist nur der iobroker unter einer eigenen macvlan ip adresse im lan erreichbar. dadurch das iobroker und redis in einem weiteren netzwerk konfiguriert worden sind (erkennbar, das bei beiden noch ipbrokerprod4 eingetragen ist, kann iobroker redis erreichen. redis ist aber erstmal von keinem anderen container erreichbar und brauch daher auch keine eigene ip adresse.
                • im iobroker habe ich über die custom konfiguration dann einfach den redis konfigurier. als ip adresse dann einfach den hostnamen (also hier redis4) eingeben. mittlerweile hat das iobroker image auch environment variablen, da könntest du dir selbst das sparen indem du die daten direkt hier in der docker-compose/stacks-konfiguration mit einträgs
                • alle volatilen daten wurden als volume definiert und auf die eine festplatte gelegt, von wo sie dann weggesichert werden können, sofern man nicht iobroker backup verwendet. diese vorgehensweise nehm ich allerdings bei allen meinen containern. dann ist es einheitlich
                • mit dieser konfiguration bist du in der lage jeden container einzeln voneinander upzugraden, ohne den anderen container zu beeinflussen.
                Meine Adapter und Widgets
                Links im Profil
                • OliverIOO OliverIO
                  @skol
                  version: '3'
                  services:
                    iobrokerprod4:
                      restart: always
                      ports:
                        - "8081:8081"
                      environment:
                          SETGID: 1001
                          SETUID: 1001
                      volumes:
                      networks:
                        dockerMACVLAN:
                        iobrokerprod4:
                    redis4:
                      volumes:
                      networks:
                        iobrokerprod4:
                  networks:
                    dockerMACVLAN:
                      external: true
                    iobrokerprod4:
                  anmerkungen:
                  Skol
                  @oliverio Danke für die Hilfe
                  Nachdem mir gerade alles abgestürzt ist (frage lieber nicht) bin ich gerade am Neu aufsetzen.
                  Idee wäre das mit Stacks zu probieren, da es wirklich schneller geht - wenns läuft.
                  Ich hätte es nach deiner Anleitung probiert mit (da die genial einfacher ist)
                  version: '3'
                  services:
                    iobroker:
                      restart: always
                      image: buanet/iobroker:latest-v9
                      hostname: iob_synology
                      ports:
                        - "8081:8081"
                      environment:
                        - IOB_STATESDB_HOST=redis
                        - IOB_STATESDB_PORT=6379
                        - IOB_STATESDB_TYPE=redis
                        - IOB_MULTIHOST=master
                      volumes:
                        - /volume1/docker/iobroker_data:/opt/iobroker
                      networks:
                        dockerMACVLAN:
                          ipv4_address: 192.168.1.14
                        internal:
                      depends_on:
                        - redis
                    redis:
                      container_name: redis
                      image: redis:latest
                      restart: always
                      ports:
                        - "6379:6379"
                      volumes:
                        - /volume1/docker/redis_data:/data
                      mem_swappiness: -1
                      networks:
                        internal:
                    influxdb:
                      container_name: influxdb
                      image: influxdb:1.8.10
                      hostname: influxdb
                      restart: always
                      networks:
                        internal:
                      ports:
                        - "8086:8086"
                      volumes:
                        - /volume1/docker/influxdb_data:/var/lib/influxdb
                  networks:
                    dockerMACVLAN:
                      external: true
                    internal:
                  Aber es wird immer rumgejammert beim dockerMACVLAN
                  failed to deploy a stack: service "iobroker" refers to undefined network dockerMACVLAN: invalid compose project
                  Hast du eine Idee woran es bei mir noch scheitern könnte?
                  Danke!
                  • S Skol
                    version: '3'
                    services:
                      iobroker:
                        restart: always
                        ports:
                          - "8081:8081"
                        environment:
                        volumes:
                        networks:
                          dockerMACVLAN:
                          internal:
                        depends_on:
                          - redis
                      redis:
                        image: redis:latest
                        restart: always
                        ports:
                          - "6379:6379"
                        volumes:
                        mem_swappiness: -1
                        networks:
                          internal:
                      influxdb:
                        hostname: influxdb
                        restart: always
                        networks:
                          internal:
                        ports:
                          - "8086:8086"
                        volumes:
                    networks:
                      dockerMACVLAN:
                        external: true
                      internal:
                    Danke!
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @skol
                    Ja
                    Das macvlan habe ich vorab erstellt.
                    Das docker weiß er muss es nicht erstellen steht da external tru dran.
                    Also musst du noch das macvlan erstellen.
                    Ich habe den Namen dockerMACVLAN gewählt, du kannst auch einen anderen Namen wählen, musst halt dann die Anweisungen anpassen
                    Als Anleitung kannst du hier schauen
                    https://smarthome.buanet.de/2020/09/macvlan-ueber-portainer-einrichten/
                    Links im Profil
                      @skol
                      Ja
                      Skol
                      @oliverio Herr im Himmel, ich könnte dir die Füße küssen. Jetzt läuft wieder alles wie es soll. Bei Redis war auch noch ein kleiner Fehler. Mit den Stacks lässt sich wirklich alles super einfach starten.
                      version: '3'
                      services:
                        iobroker:
                          restart: always
                          hostname: IOB_synology
                          ports:
                            - "8081:8081"
                          environment:
                          volumes:
                          networks:
                            iob_public:
                            iob_private:
                          depends_on:
                            - redis
                        redis:
                          image: redis:latest
                          restart: always
                          ports:
                            - "6379:6379"
                          volumes:
                            - /volume1/docker/redis_data:/usr/local/etc/redis
                          mem_swappiness: -1
                          command: redis-server /usr/local/etc/redis/redis.conf
                          networks:
                            iob_private:
                        influxdb:
                          hostname: influxdb
                          restart: always
                          networks:
                            iob_private:
                          ports:
                            - "8086:8086"
                          volumes:
                      networks:
                        iob_public:
                          external: true
                        iob_private:
