  4. Iobroker Admin Webseite nicht erreichbar
115 Beiträge 12 Kommentatoren 28.4k Aufrufe 11 Beobachtet
  • S Schtallone
    @fastfoot
    Neustart durchgeführt (per portainer). Aber kein Zugriff unter http://192.168.1.10. Weder mit Firefox, noch mit Edge
    -----              Welcome to your ioBroker Docker container!              -----
    -----                    Startupscript is now running!                     -----
    -----                          Please be patient!                          -----
    -----                          System Information                          -----
    -----                    arch:                x86_64                       -----
    -----                    hostname:            iobroker                     -----
    -----                          Version Information                         -----
    -----                    image:               v8.1.0                       -----
    -----                    build:               2023-09-14T23:45:28+00:00    -----
    -----                    node:                v18.17.1                     -----
    -----                    npm:                 9.6.7                        -----
    -----                        Environment Variables                         -----
    -----                    SETGID:              1000                         -----
    -----                    SETUID:              1000                         -----
    -----                   Step 1 of 5: Preparing container                   -----
    This is not the first run of this container. Skipping first run preparation.
    -----             Step 2 of 5: Detecting ioBroker installation             -----
    Existing installation of ioBroker detected in "/opt/iobroker".
    -----             Step 3 of 5: Checking ioBroker installation              -----
    (Re)setting permissions (This might take a while! Please be patient!)... Done.
    Fixing "sudo-bug" by replacing sudo with gosu... Done.
    Checking Database connection... Done.
    Hostname in ioBroker matches the hostname of this container.
    No action required.
    -----                Step 4 of 5: Applying special settings                -----
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
    -----                    Step 5 of 5: ioBroker startup                     -----
    Starting ioBroker...
    ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
    ================================== > LOG REDIRECT system.adapter.jarvis.0 => true [starting]
    host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
    host.iobroker check instance "system.adapter.influxdb.0" for host "iobroker"
    host.iobroker check instance "system.adapter.javascript.0" for host "iobroker"
    host.iobroker check instance "system.adapter.node-red.0" for host "iobroker"
    host.iobroker check instance "system.adapter.pushover.0" for host "iobroker"
    host.iobroker check instance "system.adapter.telegram.0" for host "iobroker"
    host.iobroker check instance "system.adapter.ical.0" for host "iobroker"
    host.iobroker check instance "system.adapter.meross.0" for host "iobroker"
    host.iobroker check instance "system.adapter.modbus.0" for host "iobroker"
    host.iobroker check instance "system.adapter.mqtt.0" for host "iobroker"
    host.iobroker check instance "system.adapter.mqtt.1" for host "iobroker"
    host.iobroker check instance "system.adapter.netatmo.0" for host "iobroker"
    host.iobroker check instance "system.adapter.shelly.0" for host "iobroker"
    host.iobroker check instance "system.adapter.sonos.0" for host "iobroker"
    host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
    host.iobroker check instance "system.adapter.cloud.0" for host "iobroker"
    host.iobroker check instance "system.adapter.device-watcher.0" for host "iobroker"
    host.iobroker check instance "system.adapter.dwd.0" for host "iobroker"
    host.iobroker check instance "system.adapter.energiefluss.0" for host "iobroker"
    host.iobroker check instance "system.adapter.feiertage.0" for host "iobroker"
    host.iobroker check instance "system.adapter.jarvis.0" for host "iobroker"
    host.iobroker check instance "system.adapter.pvforecast.0" for host "iobroker"
    host.iobroker check instance "system.adapter.schoolfree.0" for host "iobroker"
    host.iobroker check instance "system.adapter.shuttercontrol.0" for host "iobroker"
    host.iobroker check instance "system.adapter.snmp.0" for host "iobroker"
    host.iobroker check instance "system.adapter.sourceanalytix.0" for host "iobroker"
    host.iobroker check instance "system.adapter.terminal.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vw-connect.0" for host "iobroker"
    host.iobroker check instance "system.adapter.web.0" for host "iobroker"
    ag info: {"uuid":"6d14edbb-f528-4e48-8c5a-71f2c407bd7e","language":"de","country":"Germany","hosts":[{"version":"5.0.12","platform":"Javascript/Node.js","type":"linux"}],"node":"v18.17.1","arch":"x64","docker":true,"adapters":{"admin":{"version":"6.10.1","platform":"Javascript/Node.js"},"alias-manager":{"version":"1.2.6","platform":"Javascript/Node.js"},"backitup":{"version":"2.8.1","platform":"Javascript/Node.js"},"cloud":{"version":"4.4.1","platform":"Javascript/Node.js"},"device-watcher":{"version":"2.9.3","platform":"Javascript/Node.js"},"devices":{"version":"1.1.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.2.0","platform":"Javascript/Node.js"},"dwd":{"version":"2.8.5","platform":"Javascript/Node.js"},"energiefluss":{"version":"3.5.0","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.4","platform":"Javascript/Node.js"},"ical":{"version":"1.13.3","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"jarvis":{"version":"3.1.8","platform":"Javascript/Node.js"},"javascript":{"version":"7.1.4","platform":"Javascript/Node.js"},"meross":{"version":"1.15.1","platform":"Javascript/Node.js"},"modbus":{"version":"5.0.11","platform":"Javascript/Node.js"},"moma":{"version":"1.2.9","platform":"Javascript/Node.js"},"mqtt":{"version":"4.1.1","platform":"Javascript/Node.js"},"netatmo":{"version":"3.1.0","platform":"Javascript/Node.js"},"node-red":{"version":"4.0.3","platform":"Javascript/Node.js"},"pushover":{"version":"3.0.4","platform":"Javascript/Node.js"},"pvforecast":{"version":"2.7.1","platform":"Javascript/Node.js"},"schoolfree":{"version":"1.1.2","platform":"Javascript/Node.js"},"shelly":{"version":"6.4.1","platform":"Javascript/Node.js"},"shuttercontrol":{"version":"1.6.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.7.2","platform":"Javascript/Node.js"},"snmp":{"version":"2.4.11","platform":"Javascript/Node.js"},"socketio":{"version":"6.5.5","platform":"Javascript/Node.js"},"sonos":{"version":"2.3.1","platform":"Javascript/Node.js"},"sourceanalytix":{"version":"0.4.14","platform":"Javascript/Node.js"},"telegram":{"version":"1.16.0","platform":"Javascript/Node.js"},"terminal":{"version":"1.0.0","platform":"Javascript/Node.js"},"vw-connect":{"version":"0.1.2","platform":"Javascript/Node.js"},"web":{"version":"6.1.2","platform":"Javascript/Node.js"},"ws":{"version":"2.5.5","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":31,"compactMode":false,"noCompactInstances":0,"model":"Intel(R) Celeron(R) J4005 CPU @ 2.00GHz","cpus":2,"mem":8170733568,"ostype":"Linux","city":"Oerlinghausen"}
    fastfoot
    #90
    @schtallone sieht top aus. ein allerletzter versuch:
    iob add admin.1 --port 4711
    danach http://192.168.1.10:4711
    • F fastfoot
      Schtallone
      #91
      @fastfoot said in Iobroker Admin Webseite nicht erreichbar:
      root@iobroker:/opt/iobroker# iob add admin.1 --port 4711
      host.iobroker create instance admin
      host.iobroker object system.adapter.admin.1.alive created
      host.iobroker object system.adapter.admin.1.connected created
      host.iobroker object system.adapter.admin.1.compactMode created
      host.iobroker object system.adapter.admin.1.cpu created
      host.iobroker object system.adapter.admin.1.cputime created
      host.iobroker object system.adapter.admin.1.memHeapUsed created
      host.iobroker object system.adapter.admin.1.memHeapTotal created
      host.iobroker object system.adapter.admin.1.memRss created
      host.iobroker object system.adapter.admin.1.uptime created
      host.iobroker object system.adapter.admin.1.inputCount created
      host.iobroker object system.adapter.admin.1.outputCount created
      host.iobroker object system.adapter.admin.1.eventLoopLag created
      host.iobroker object system.adapter.admin.1.sigKill created
      host.iobroker object system.adapter.admin.1.logLevel created
      host.iobroker object system.adapter.admin.upload created
      host.iobroker object admin.1.info created
      host.iobroker object admin.1 created
      host.iobroker object admin.1.info.connected created
      host.iobroker object admin.1.info.connection created
      host.iobroker object admin.1.info.newsFeed created
      host.iobroker object admin.1.info.newsETag created
      host.iobroker object admin.1.info.newsLastId created
      host.iobroker object admin.1.info.updatesList created
      host.iobroker Set default value of admin.1.info.connected:
      host.iobroker Set default value of admin.1.info.connection: false
      host.iobroker Set default value of admin.1.info.updatesList:
      host.iobroker object system.adapter.admin.1 created
      aber kein Zugriff
      F 1 Antwort Letzte Antwort
      • S Schtallone
        @glasfaser
        Firefox im privaten Modus mit der genannten IP http://192.168.1.10:8081 geht nicht
        GlasfaserG Offline
        GlasfaserG Offline
        #92
        @schtallone sagte in Iobroker Admin Webseite nicht erreichbar:
        @glasfaser
        Nimm mal einen Browser mit dem du noch nie ioBroker aufgerufen hast !
        • S Schtallone
          aber kein Zugriff
          fastfoot
          #93
          aber kein Zugriff
          also jetzt bin ich wirklich am Ende meines Wissens. Alle Einstellungen scheinen zu stimmen, du rufst richtig mit http:// auf, das Start Log sieht super aus
          wenn du aus windows auf die 192.168.1.10 pingst, geht das?
          • F fastfoot
            aber kein Zugriff
            Schtallone
            #94
            192.168.1.10
            ja, keine Paketverluste
            • GlasfaserG Glasfaser
              @glasfaser
              Schtallone
              #95
              @glasfaser
              Edge wäre der Browser gewesen, aber geht auch nicht
              • S Schtallone
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                #96
                @schtallone
                Was hast du sonst noch ...
                Firewall
                Pi-Hole
                Adblocker
                • S Schtallone
                  192.168.1.10
                  fastfoot
                  #97
                  @schtallone
                  mit Handy?
                  Hast du einen Ad-Blocker am Laufen(der private Mode sollte den eig. ausgeschaltet haben)
                  • F fastfoot
                    @schtallone
                    mit Handy?
                    Schtallone
                    #98
                    @fastfoot
                    Ad-blocker ist deaktiviert. Mit HAndy auch probiert, kein Zugriff. WIndows Firewall läuft
                    GlasfaserG F 2 Antworten Letzte Antwort
                    • S Schtallone
                      @fastfoot
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #99
                      @schtallone
                      Nur mal zum mitschreiben ...
                      du hast ein Probleme gehabt mit deinem bestehenden Container / iobroker
                      Neuen Container mit ioBroker erstellt inkl. der neuen IP 192.168.1.10
                      dann gestartet und per backitup dein Backup eingespielt
                      Nach der Restore danach kein zugriff mehr über die IP 192.168.1.10
                      F S 2 Antworten Letzte Antwort
                      • S Schtallone
                        @fastfoot
                        fastfoot
                        #100
                        @schtallone du solltest eig. auch ein qnet-dhcp-eth0-79e6cc Netzwerk haben, kannst das im Portainer auswählen?
                        • S Schtallone
                          @glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #101
                          @fastfoot
                          Hat er
                          @glasfaser
                            @schtallone
                            fastfoot
                            #102
                            @glasfaser sagte in Iobroker Admin Webseite nicht erreichbar:
                            es ist nicht der hostname, iob l a hat das gezeigt und auch das Start-Log
                              @fastfoot
                              Hat er
                              @glasfaser
                              fastfoot
                              #103
                              Hat er
                              nein, das gezeigte ist statisch bei dem man die IP Adresse vorgibt, das dhcp holt sich die IP vom Router
                                @schtallone
                                Schtallone
                                #104
                                @glasfaser
                                ja, ich habe den Container neu aufgesetzt und dann mit backup restore im Webfenster die wiederherstellung gemacht. Dies hat dann nicht funktioniert und dann kam ich auch nicht mehr auf den iobroker drauf. Dann habe ich mehrere male den Container erneuert und per console das restore gemacht.
                                Letzenendes habe ich den persistenten Ordner aus einen Backup wiederhhergestellt und versucht, den iobroker damit wieder zzu starten (also so wie er vorgestern war) Das ist das Datum des Backups.
                                Un da bin ich jetzt
                                • S Schtallone
                                  @glasfaser
                                  Un da bin ich jetzt
                                  Schtallone
                                  #105
                                  So, ich habe mir nochmals die gemappten Ordner angeschaut im Portainer.
                                  So sah das aus:
                                  Ich habe nun die beiden komischen Einträge gelöscht und nur noch das binding von /opt/iobroker gelassen. Nachdem der Container neu aufgesetzt war, komme ich auf den iobroker drauf.
                                  • S Schtallone
                                    So sah das aus:
                                    Schtallone
                                    #106
                                    ich frage michh nur, was das mit dem Zugriff zu tun haben soll.
                                    • S Schtallone
                                      fastfoot
                                      #107
                                      @schtallone du hast verschiedene iobroker installationen durch das mapping vorgegeben, das kann nicht funktionieren.
                                      dass du dieses Mapping verändert hast hattest du aber nicht erwähnt!!
                                      • F fastfoot
                                        Schtallone
                                        #108
                                        @fastfoot
                                        Ich hatte es auch nicht verändert. Das habe ichh so von dem vorher funktionierenden Container übernommen.
                                        Ich habe mir aber paralell zu unseren Diskussionen hier auch nochmals von Buanet die Tutorials durchgelesen und da war nur von dem einen Binding die Rede.
                                        • S Schtallone
                                          @fastfoot
                                          Schtallone
                                          #109
                                          Nichts desto Trotz: Sehr sehr vielen DANK! Für Eure Hilfe hier und Eure Ausdauer zu dieser unnchristlichen Zeit.
                                          Ich starte gerade alle Adapter und es sieht sehr gut aus bisher. Morgen geht es weiter. Gute Nacht und nochmals vielen DANK an Euch.
