  4. Iobroker Admin Webseite nicht erreichbar
115 Beiträge 12 Kommentatoren 28.4k Aufrufe 11 Beobachtet
  • F fastfoot
    @schtallone ok, das sieht jetzt alles gut und richtig aus, mache mal einen Container Neustart, das Log war ja ruhig
    Schtallone
    schrieb am zuletzt editiert von Schtallone
    #89
    @fastfoot
    Neustart durchgeführt (per portainer). Aber kein Zugriff unter http://192.168.1.10. Weder mit Firefox, noch mit Edge
    -----              Welcome to your ioBroker Docker container!              -----
    -----                    Startupscript is now running!                     -----
    -----                          Please be patient!                          -----
    -----                          System Information                          -----
    -----                    arch:                x86_64                       -----
    -----                    hostname:            iobroker                     -----
    -----                          Version Information                         -----
    -----                    image:               v8.1.0                       -----
    -----                    build:               2023-09-14T23:45:28+00:00    -----
    -----                    node:                v18.17.1                     -----
    -----                    npm:                 9.6.7                        -----
    -----                        Environment Variables                         -----
    -----                    SETGID:              1000                         -----
    -----                    SETUID:              1000                         -----
    -----                   Step 1 of 5: Preparing container                   -----
    This is not the first run of this container. Skipping first run preparation.
    -----             Step 2 of 5: Detecting ioBroker installation             -----
    Existing installation of ioBroker detected in "/opt/iobroker".
    -----             Step 3 of 5: Checking ioBroker installation              -----
    (Re)setting permissions (This might take a while! Please be patient!)... Done.
    Fixing "sudo-bug" by replacing sudo with gosu... Done.
    Checking Database connection... Done.
    Hostname in ioBroker matches the hostname of this container.
    No action required.
    -----                Step 4 of 5: Applying special settings                -----
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
    -----                    Step 5 of 5: ioBroker startup                     -----
    Starting ioBroker...
    ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
    ================================== > LOG REDIRECT system.adapter.jarvis.0 => true [starting]
    host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
    host.iobroker check instance "system.adapter.influxdb.0" for host "iobroker"
    host.iobroker check instance "system.adapter.javascript.0" for host "iobroker"
    host.iobroker check instance "system.adapter.node-red.0" for host "iobroker"
    host.iobroker check instance "system.adapter.pushover.0" for host "iobroker"
    host.iobroker check instance "system.adapter.telegram.0" for host "iobroker"
    host.iobroker check instance "system.adapter.ical.0" for host "iobroker"
    host.iobroker check instance "system.adapter.meross.0" for host "iobroker"
    host.iobroker check instance "system.adapter.modbus.0" for host "iobroker"
    host.iobroker check instance "system.adapter.mqtt.0" for host "iobroker"
    host.iobroker check instance "system.adapter.mqtt.1" for host "iobroker"
    host.iobroker check instance "system.adapter.netatmo.0" for host "iobroker"
    host.iobroker check instance "system.adapter.shelly.0" for host "iobroker"
    host.iobroker check instance "system.adapter.sonos.0" for host "iobroker"
    host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
    host.iobroker check instance "system.adapter.cloud.0" for host "iobroker"
    host.iobroker check instance "system.adapter.device-watcher.0" for host "iobroker"
    host.iobroker check instance "system.adapter.dwd.0" for host "iobroker"
    host.iobroker check instance "system.adapter.energiefluss.0" for host "iobroker"
    host.iobroker check instance "system.adapter.feiertage.0" for host "iobroker"
    host.iobroker check instance "system.adapter.jarvis.0" for host "iobroker"
    host.iobroker check instance "system.adapter.pvforecast.0" for host "iobroker"
    host.iobroker check instance "system.adapter.schoolfree.0" for host "iobroker"
    host.iobroker check instance "system.adapter.shuttercontrol.0" for host "iobroker"
    host.iobroker check instance "system.adapter.snmp.0" for host "iobroker"
    host.iobroker check instance "system.adapter.sourceanalytix.0" for host "iobroker"
    host.iobroker check instance "system.adapter.terminal.0" for host "iobroker"
    host.iobroker check instance "system.adapter.vw-connect.0" for host "iobroker"
    host.iobroker check instance "system.adapter.web.0" for host "iobroker"
    ag info: {"uuid":"6d14edbb-f528-4e48-8c5a-71f2c407bd7e","language":"de","country":"Germany","hosts":[{"version":"5.0.12","platform":"Javascript/Node.js","type":"linux"}],"node":"v18.17.1","arch":"x64","docker":true,"adapters":{"admin":{"version":"6.10.1","platform":"Javascript/Node.js"},"alias-manager":{"version":"1.2.6","platform":"Javascript/Node.js"},"backitup":{"version":"2.8.1","platform":"Javascript/Node.js"},"cloud":{"version":"4.4.1","platform":"Javascript/Node.js"},"device-watcher":{"version":"2.9.3","platform":"Javascript/Node.js"},"devices":{"version":"1.1.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.2.0","platform":"Javascript/Node.js"},"dwd":{"version":"2.8.5","platform":"Javascript/Node.js"},"energiefluss":{"version":"3.5.0","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.4","platform":"Javascript/Node.js"},"ical":{"version":"1.13.3","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"jarvis":{"version":"3.1.8","platform":"Javascript/Node.js"},"javascript":{"version":"7.1.4","platform":"Javascript/Node.js"},"meross":{"version":"1.15.1","platform":"Javascript/Node.js"},"modbus":{"version":"5.0.11","platform":"Javascript/Node.js"},"moma":{"version":"1.2.9","platform":"Javascript/Node.js"},"mqtt":{"version":"4.1.1","platform":"Javascript/Node.js"},"netatmo":{"version":"3.1.0","platform":"Javascript/Node.js"},"node-red":{"version":"4.0.3","platform":"Javascript/Node.js"},"pushover":{"version":"3.0.4","platform":"Javascript/Node.js"},"pvforecast":{"version":"2.7.1","platform":"Javascript/Node.js"},"schoolfree":{"version":"1.1.2","platform":"Javascript/Node.js"},"shelly":{"version":"6.4.1","platform":"Javascript/Node.js"},"shuttercontrol":{"version":"1.6.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.7.2","platform":"Javascript/Node.js"},"snmp":{"version":"2.4.11","platform":"Javascript/Node.js"},"socketio":{"version":"6.5.5","platform":"Javascript/Node.js"},"sonos":{"version":"2.3.1","platform":"Javascript/Node.js"},"sourceanalytix":{"version":"0.4.14","platform":"Javascript/Node.js"},"telegram":{"version":"1.16.0","platform":"Javascript/Node.js"},"terminal":{"version":"1.0.0","platform":"Javascript/Node.js"},"vw-connect":{"version":"0.1.2","platform":"Javascript/Node.js"},"web":{"version":"6.1.2","platform":"Javascript/Node.js"},"ws":{"version":"2.5.5","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":31,"compactMode":false,"noCompactInstances":0,"model":"Intel(R) Celeron(R) J4005 CPU @ 2.00GHz","cpus":2,"mem":8170733568,"ostype":"Linux","city":"Oerlinghausen"}
    F 1 Antwort Letzte Antwort
    • S Schtallone
      @fastfoot
      No action required.
      fastfoot
      #90
      @schtallone sieht top aus. ein allerletzter versuch:
      iob add admin.1 --port 4711
      danach http://192.168.1.10:4711
      • F fastfoot
        Schtallone
        #91
        @fastfoot said in Iobroker Admin Webseite nicht erreichbar:
        root@iobroker:/opt/iobroker# iob add admin.1 --port 4711
        host.iobroker create instance admin
        host.iobroker object system.adapter.admin.1.alive created
        host.iobroker object system.adapter.admin.1.connected created
        host.iobroker object system.adapter.admin.1.compactMode created
        host.iobroker object system.adapter.admin.1.cpu created
        host.iobroker object system.adapter.admin.1.cputime created
        host.iobroker object system.adapter.admin.1.memHeapUsed created
        host.iobroker object system.adapter.admin.1.memHeapTotal created
        host.iobroker object system.adapter.admin.1.memRss created
        host.iobroker object system.adapter.admin.1.uptime created
        host.iobroker object system.adapter.admin.1.inputCount created
        host.iobroker object system.adapter.admin.1.outputCount created
        host.iobroker object system.adapter.admin.1.eventLoopLag created
        host.iobroker object system.adapter.admin.1.sigKill created
        host.iobroker object system.adapter.admin.1.logLevel created
        host.iobroker object system.adapter.admin.upload created
        host.iobroker object admin.1.info created
        host.iobroker object admin.1 created
        host.iobroker object admin.1.info.connected created
        host.iobroker object admin.1.info.connection created
        host.iobroker object admin.1.info.newsFeed created
        host.iobroker object admin.1.info.newsETag created
        host.iobroker object admin.1.info.newsLastId created
        host.iobroker object admin.1.info.updatesList created
        host.iobroker Set default value of admin.1.info.connected:
        host.iobroker Set default value of admin.1.info.connection: false
        host.iobroker Set default value of admin.1.info.updatesList:
        host.iobroker object system.adapter.admin.1 created
        aber kein Zugriff
        • S Schtallone
          @glasfaser
          Firefox im privaten Modus mit der genannten IP http://192.168.1.10:8081 geht nicht
          GlasfaserG Offline
          GlasfaserG Offline
          #92
          @schtallone sagte in Iobroker Admin Webseite nicht erreichbar:
          @glasfaser
          Nimm mal einen Browser mit dem du noch nie ioBroker aufgerufen hast !
          • S Schtallone
            aber kein Zugriff
            fastfoot
            #93
            aber kein Zugriff
            also jetzt bin ich wirklich am Ende meines Wissens. Alle Einstellungen scheinen zu stimmen, du rufst richtig mit http:// auf, das Start Log sieht super aus
            wenn du aus windows auf die 192.168.1.10 pingst, geht das?
            • F fastfoot
              aber kein Zugriff
              Schtallone
              #94
              192.168.1.10
              ja, keine Paketverluste
              • GlasfaserG Glasfaser
                @glasfaser
                Schtallone
                #95
                @glasfaser
                Edge wäre der Browser gewesen, aber geht auch nicht
                • S Schtallone
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #96
                  @schtallone
                  Was hast du sonst noch ...
                  Firewall
                  Pi-Hole
                  Adblocker
                  • S Schtallone
                    192.168.1.10
                    fastfoot
                    #97
                    @schtallone
                    mit Handy?
                    Hast du einen Ad-Blocker am Laufen(der private Mode sollte den eig. ausgeschaltet haben)
                    • F fastfoot
                      @schtallone
                      mit Handy?
                      Schtallone
                      #98
                      @fastfoot
                      Ad-blocker ist deaktiviert. Mit HAndy auch probiert, kein Zugriff. WIndows Firewall läuft
                      GlasfaserG F 2 Antworten Letzte Antwort
                      • S Schtallone
                        @fastfoot
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #99
                        @schtallone
                        Nur mal zum mitschreiben ...
                        du hast ein Probleme gehabt mit deinem bestehenden Container / iobroker
                        Neuen Container mit ioBroker erstellt inkl. der neuen IP 192.168.1.10
                        dann gestartet und per backitup dein Backup eingespielt
                        Nach der Restore danach kein zugriff mehr über die IP 192.168.1.10
                        F S 2 Antworten Letzte Antwort
                        • S Schtallone
                          @fastfoot
                          fastfoot
                          #100
                          @schtallone du solltest eig. auch ein qnet-dhcp-eth0-79e6cc Netzwerk haben, kannst das im Portainer auswählen?
                          • S Schtallone
                            @glasfaser
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #101
                            @fastfoot
                            Hat er
                            @glasfaser
                              @schtallone
                              fastfoot
                              #102
                              @glasfaser sagte in Iobroker Admin Webseite nicht erreichbar:
                              es ist nicht der hostname, iob l a hat das gezeigt und auch das Start-Log
                                @fastfoot
                                Hat er
                                @glasfaser
                                fastfoot
                                #103
                                Hat er
                                nein, das gezeigte ist statisch bei dem man die IP Adresse vorgibt, das dhcp holt sich die IP vom Router
                                  @schtallone
                                  Schtallone
                                  #104
                                  @glasfaser
                                  ja, ich habe den Container neu aufgesetzt und dann mit backup restore im Webfenster die wiederherstellung gemacht. Dies hat dann nicht funktioniert und dann kam ich auch nicht mehr auf den iobroker drauf. Dann habe ich mehrere male den Container erneuert und per console das restore gemacht.
                                  Letzenendes habe ich den persistenten Ordner aus einen Backup wiederhhergestellt und versucht, den iobroker damit wieder zzu starten (also so wie er vorgestern war) Das ist das Datum des Backups.
                                  Un da bin ich jetzt
                                  • S Schtallone
                                    @glasfaser
                                    Un da bin ich jetzt
                                    Schtallone
                                    #105
                                    So, ich habe mir nochmals die gemappten Ordner angeschaut im Portainer.
                                    So sah das aus:
                                    Ich habe nun die beiden komischen Einträge gelöscht und nur noch das binding von /opt/iobroker gelassen. Nachdem der Container neu aufgesetzt war, komme ich auf den iobroker drauf.
                                    • S Schtallone
                                      So sah das aus:
                                      Schtallone
                                      #106
                                      ich frage michh nur, was das mit dem Zugriff zu tun haben soll.
                                      • S Schtallone
                                        fastfoot
                                        #107
                                        @schtallone du hast verschiedene iobroker installationen durch das mapping vorgegeben, das kann nicht funktionieren.
                                        dass du dieses Mapping verändert hast hattest du aber nicht erwähnt!!
                                        • F fastfoot
                                          Schtallone
                                          #108
                                          @fastfoot
                                          Ich hatte es auch nicht verändert. Das habe ichh so von dem vorher funktionierenden Container übernommen.
                                          Ich habe mir aber paralell zu unseren Diskussionen hier auch nochmals von Buanet die Tutorials durchgelesen und da war nur von dem einen Binding die Rede.
