  4. Iobroker Admin Webseite nicht erreichbar
115 Beiträge 12 Kommentatoren 28.4k Aufrufe 11 Beobachtet
  • F fastfoot
    @schtallone iob logs --watch
    Schtallone
    #78
    @fastfoot said in Iobroker Admin Webseite nicht erreichbar:
    iob logs --watch
    root@iobroker:/opt/iobroker# iob logs --watch
    2023-09-15 22:31:47.193  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-09-15 22:31:47.196  - info: admin.0 (171) Got terminate signal TERMINATE_YOURSELF
    2023-09-15 22:31:47.200  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
    2023-09-15 22:31:47.198  - info: admin.0 (171) terminating https server on port 8081
    2023-09-15 22:31:47.199  - info: admin.0 (171) terminating
    2023-09-15 22:31:47.200  - info: admin.0 (171) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-15 22:31:47.701  - info: admin.0 (171) terminating
    2023-09-15 22:31:47.799  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-15 22:31:50.467  - info: host.iobroker instance system.adapter.admin.0 started with pid 7961
    2023-09-15 22:31:52.473  - info: admin.0 (7961) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 5.0.12
    2023-09-15 22:31:52.512  - info: admin.0 (7961) requesting all objects
    2023-09-15 22:31:55.383  - info: admin.0 (7961) received all objects
    2023-09-15 22:31:55.604  - info: admin.0 (7961) Request actual repository...
    2023-09-15 22:31:55.644  - info: admin.0 (7961) socket.io server listening on port 8081
    2023-09-15 22:31:55.646  - info: admin.0 (7961) http server listening on port 8081
    2023-09-15 22:31:55.646  - info: admin.0 (7961) Use link "http://127.0.0.1:8081" to configure.
    2023-09-15 22:31:56.264  - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    2023-09-15 22:31:57.324  - info: admin.0 (7961) Repository received successfully.
    2023-09-15 22:32:57.000  - info: host.iobroker received SIGTERM
    2023-09-15 22:32:57.001  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-09-15 22:32:57.002  - info: host.iobroker stopInstance system.adapter.influxdb.0 (force=false, process=false)
    2023-09-15 22:32:57.002  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=false)
    2023-09-15 22:32:57.002  - info: host.iobroker stopInstance system.adapter.node-red.0 (force=false, process=false)
    2023-09-15 22:32:57.002  - info: host.iobroker stopInstance system.adapter.pushover.0 (force=false, process=false)
    2023-09-15 22:32:57.002  - info: host.iobroker stopInstance system.adapter.telegram.0 (force=false, process=false)
    2023-09-15 22:32:57.002  - info: host.iobroker stopInstance system.adapter.ical.0 (force=false, process=false)
    2023-09-15 22:32:57.003  - info: host.iobroker stopInstance system.adapter.meross.0 (force=false, process=false)
    2023-09-15 22:32:57.003  - info: host.iobroker stopInstance system.adapter.modbus.0 (force=false, process=false)
    2023-09-15 22:32:57.006  - info: host.iobroker stopInstance system.adapter.mqtt.0 (force=false, process=false)
    2023-09-15 22:32:57.006  - info: host.iobroker stopInstance system.adapter.mqtt.1 (force=false, process=false)
    2023-09-15 22:32:57.006  - info: host.iobroker stopInstance system.adapter.netatmo.0 (force=false, process=false)
    2023-09-15 22:32:57.006  - info: host.iobroker stopInstance system.adapter.shelly.0 (force=false, process=false)
    2023-09-15 22:32:57.006  - info: host.iobroker stopInstance system.adapter.sonos.0 (force=false, process=false)
    2023-09-15 22:32:57.006  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-09-15 22:32:57.007  - info: host.iobroker stopInstance system.adapter.cloud.0 (force=false, process=false)
    2023-09-15 22:32:57.007  - info: host.iobroker stopInstance system.adapter.device-watcher.0 (force=false, process=false)
    2023-09-15 22:32:57.007  - info: host.iobroker stopInstance system.adapter.dwd.0 (force=false, process=false)
    2023-09-15 22:32:57.007  - info: host.iobroker stopInstance system.adapter.energiefluss.0 (force=false, process=false)
    2023-09-15 22:32:57.007  - info: host.iobroker stopInstance system.adapter.feiertage.0 (force=false, process=false)
    2023-09-15 22:32:57.007  - info: host.iobroker stopInstance system.adapter.jarvis.0 (force=false, process=false)
    2023-09-15 22:32:57.008  - info: host.iobroker stopInstance system.adapter.pvforecast.0 (force=false, process=false)
    2023-09-15 22:32:57.008  - info: host.iobroker stopInstance system.adapter.schoolfree.0 (force=false, process=false)
    2023-09-15 22:32:57.008  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=false)
    2023-09-15 22:32:57.008  - info: host.iobroker stopInstance system.adapter.snmp.0 (force=false, process=false)
    2023-09-15 22:32:57.008  - info: host.iobroker stopInstance system.adapter.sourceanalytix.0 (force=false, process=false)
    2023-09-15 22:32:57.008  - info: host.iobroker stopInstance system.adapter.terminal.0 (force=false, process=false)
    2023-09-15 22:32:57.008  - info: host.iobroker stopInstance system.adapter.vw-connect.0 (force=false, process=false)
    2023-09-15 22:32:57.008  - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=false)
    2023-09-15 22:32:57.017  - info: admin.0 (7961) Got terminate signal TERMINATE_YOURSELF
    2023-09-15 22:32:57.018  - info: admin.0 (7961) terminating http server on port 8081
    2023-09-15 22:32:57.019  - info: admin.0 (7961) terminating
    2023-09-15 22:32:57.020  - info: admin.0 (7961) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-15 22:32:57.024  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
    2023-09-15 22:32:57.022  - info: backitup.0 (206) Got terminate signal TERMINATE_YOURSELF
    2023-09-15 22:32:57.025  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
    2023-09-15 22:32:57.023  - info: backitup.0 (206) cleaned everything up...
    2023-09-15 22:32:57.024  - info: backitup.0 (206) terminating
    2023-09-15 22:32:57.033  - info: backitup.0 (206) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-15 22:32:57.520  - info: admin.0 (7961) terminating
    2023-09-15 22:32:57.534  - info: backitup.0 (206) terminating
    2023-09-15 22:32:57.633  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-15 22:32:57.687  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-15 22:32:57.687  - info: host.iobroker All instances are stopped.
    2023-09-15 22:32:57.889  - info: host.iobroker terminated
    2023-09-15 22:33:54.601  - info: host.iobroker iobroker.js-controller version 5.0.12 js-controller starting
    2023-09-15 22:33:54.604  - info: host.iobroker Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-09-15 22:33:54.605  - info: host.iobroker hostname: iobroker, node: v18.17.1
    2023-09-15 22:33:54.605  - info: host.iobroker ip addresses: 192.168.1.10
    2023-09-15 22:33:55.673  - info: host.iobroker connected to Objects and States
    2023-09-15 22:33:55.763  - info: host.iobroker added notifications configuration of host
    2023-09-15 22:33:56.274  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
    2023-09-15 22:33:56.275  - info: host.iobroker 31 instances found
    2023-09-15 22:33:56.308  - info: host.iobroker starting 2 instances
    2023-09-15 22:33:56.370  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
    2023-09-15 22:33:56.397  - info: host.iobroker instance system.adapter.admin.0 started with pid 173
    2023-09-15 22:33:56.440  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
    2023-09-15 22:33:56.444  - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
    2023-09-15 22:33:56.450  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
    2023-09-15 22:33:56.499  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
    2023-09-15 22:33:56.510  - info: host.iobroker Some obsolete host states deleted.
    2023-09-15 22:33:58.380  - info: admin.0 (173) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 5.0.12
    2023-09-15 22:33:58.428  - info: admin.0 (173) requesting all objects
    2023-09-15 22:34:00.698  - info: host.iobroker instance system.adapter.backitup.0 started with pid 196
    2023-09-15 22:34:00.799  - info: admin.0 (173) received all objects
    2023-09-15 22:34:02.176  - info: admin.0 (173) Request actual repository...
    2023-09-15 22:34:02.377  - info: admin.0 (173) socket.io server listening on port 8081
    2023-09-15 22:34:02.395  - info: admin.0 (173) http server listening on port 8081
    2023-09-15 22:34:02.395  - info: admin.0 (173) Use link "http://127.0.0.1:8081" to configure.
    2023-09-15 22:34:04.300  - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    2023-09-15 22:34:05.770  - info: admin.0 (173) Repository received successfully.
    2023-09-15 22:34:05.952  - info: backitup.0 (196) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.1, js-controller: 5.0.12
    2023-09-15 22:34:06.021  - info: backitup.0 (196) [iobroker] backup will be activated at 03:00 every 1 day(s)
    2023-09-15 22:45:43.352  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-09-15 22:45:43.355  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
    2023-09-15 22:45:43.355  - info: admin.0 (173) Got terminate signal TERMINATE_YOURSELF
    2023-09-15 22:45:43.356  - info: admin.0 (173) terminating http server on port 8081
    2023-09-15 22:45:43.357  - info: admin.0 (173) terminating
    2023-09-15 22:45:43.360  - info: admin.0 (173) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-15 22:45:43.861  - info: admin.0 (173) terminating
    2023-09-15 22:45:43.971  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-15 22:45:46.452  - info: host.iobroker instance system.adapter.admin.0 started with pid 789
    2023-09-15 22:45:48.152  - info: admin.0 (789) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 5.0.12
    2023-09-15 22:45:48.200  - info: admin.0 (789) requesting all objects
    2023-09-15 22:45:49.995  - info: admin.0 (789) received all objects
    2023-09-15 22:45:50.198  - info: admin.0 (789) Request actual repository...
    2023-09-15 22:45:50.212  - info: admin.0 (789) socket.io server listening on port 8081
    2023-09-15 22:45:50.214  - info: admin.0 (789) http server listening on port 8081
    2023-09-15 22:45:50.214  - info: admin.0 (789) Use link "http://127.0.0.1:8081" to configure.
    2023-09-15 22:45:50.617  - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    2023-09-15 22:45:51.628  - info: admin.0 (789) Repository received successfully.
    2023-09-15 22:46:24.635  - info: host.iobroker received SIGTERM
    2023-09-15 22:46:24.643  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-09-15 22:46:24.644  - info: host.iobroker stopInstance system.adapter.influxdb.0 (force=false, process=false)
    2023-09-15 22:46:24.644  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=false)
    2023-09-15 22:46:24.644  - info: host.iobroker stopInstance system.adapter.node-red.0 (force=false, process=false)
    2023-09-15 22:46:24.644  - info: host.iobroker stopInstance system.adapter.pushover.0 (force=false, process=false)
    2023-09-15 22:46:24.644  - info: host.iobroker stopInstance system.adapter.telegram.0 (force=false, process=false)
    2023-09-15 22:46:24.644  - info: host.iobroker stopInstance system.adapter.ical.0 (force=false, process=false)
    2023-09-15 22:46:24.645  - info: host.iobroker stopInstance system.adapter.meross.0 (force=false, process=false)
    2023-09-15 22:46:24.645  - info: host.iobroker stopInstance system.adapter.modbus.0 (force=false, process=false)
    2023-09-15 22:46:24.645  - info: host.iobroker stopInstance system.adapter.mqtt.0 (force=false, process=false)
    2023-09-15 22:46:24.645  - info: host.iobroker stopInstance system.adapter.mqtt.1 (force=false, process=false)
    2023-09-15 22:46:24.645  - info: host.iobroker stopInstance system.adapter.netatmo.0 (force=false, process=false)
    2023-09-15 22:46:24.645  - info: host.iobroker stopInstance system.adapter.shelly.0 (force=false, process=false)
    2023-09-15 22:46:24.646  - info: host.iobroker stopInstance system.adapter.sonos.0 (force=false, process=false)
    2023-09-15 22:46:24.646  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-09-15 22:46:24.646  - info: host.iobroker stopInstance system.adapter.cloud.0 (force=false, process=false)
    2023-09-15 22:46:24.646  - info: host.iobroker stopInstance system.adapter.device-watcher.0 (force=false, process=false)
    2023-09-15 22:46:24.646  - info: host.iobroker stopInstance system.adapter.dwd.0 (force=false, process=false)
    2023-09-15 22:46:24.646  - info: host.iobroker stopInstance system.adapter.energiefluss.0 (force=false, process=false)
    2023-09-15 22:46:24.647  - info: host.iobroker stopInstance system.adapter.feiertage.0 (force=false, process=false)
    2023-09-15 22:46:24.647  - info: host.iobroker stopInstance system.adapter.jarvis.0 (force=false, process=false)
    2023-09-15 22:46:24.647  - info: host.iobroker stopInstance system.adapter.pvforecast.0 (force=false, process=false)
    2023-09-15 22:46:24.647  - info: host.iobroker stopInstance system.adapter.schoolfree.0 (force=false, process=false)
    2023-09-15 22:46:24.647  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=false)
    2023-09-15 22:46:24.647  - info: host.iobroker stopInstance system.adapter.snmp.0 (force=false, process=false)
    2023-09-15 22:46:24.648  - info: host.iobroker stopInstance system.adapter.sourceanalytix.0 (force=false, process=false)
    2023-09-15 22:46:24.648  - info: host.iobroker stopInstance system.adapter.terminal.0 (force=false, process=false)
    2023-09-15 22:46:24.648  - info: host.iobroker stopInstance system.adapter.vw-connect.0 (force=false, process=false)
    2023-09-15 22:46:24.648  - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=false)
    2023-09-15 22:46:24.659  - info: admin.0 (789) Got terminate signal TERMINATE_YOURSELF
    2023-09-15 22:46:24.660  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
    2023-09-15 22:46:24.660  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
    2023-09-15 22:46:24.662  - info: backitup.0 (196) Got terminate signal TERMINATE_YOURSELF
    2023-09-15 22:46:24.660  - info: admin.0 (789) terminating http server on port 8081
    2023-09-15 22:46:24.661  - info: admin.0 (789) terminating
    2023-09-15 22:46:24.662  - info: admin.0 (789) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-15 22:46:24.663  - info: backitup.0 (196) cleaned everything up...
    2023-09-15 22:46:24.663  - info: backitup.0 (196) terminating
    2023-09-15 22:46:24.664  - info: backitup.0 (196) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-15 22:46:25.164  - info: admin.0 (789) terminating
    2023-09-15 22:46:25.165  - info: backitup.0 (196) terminating
    2023-09-15 22:46:25.283  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-15 22:46:25.329  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-15 22:46:25.330  - info: host.iobroker All instances are stopped.
    2023-09-15 22:46:25.582  - info: host.iobroker terminated
    2023-09-15 22:47:17.603  - info: host.iobroker iobroker.js-controller version 5.0.12 js-controller starting
    2023-09-15 22:47:17.607  - info: host.iobroker Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-09-15 22:47:17.607  - info: host.iobroker hostname: iobroker, node: v18.17.1
    2023-09-15 22:47:17.607  - info: host.iobroker ip addresses: 192.168.1.10
    2023-09-15 22:47:18.636  - info: host.iobroker connected to Objects and States
    2023-09-15 22:47:18.674  - info: host.iobroker added notifications configuration of host
    2023-09-15 22:47:19.207  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
    2023-09-15 22:47:19.208  - info: host.iobroker 31 instances found
    2023-09-15 22:47:19.241  - info: host.iobroker starting 2 instances
    2023-09-15 22:47:19.307  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
    2023-09-15 22:47:19.334  - info: host.iobroker instance system.adapter.admin.0 started with pid 177
    2023-09-15 22:47:19.386  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
    2023-09-15 22:47:19.431  - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
    2023-09-15 22:47:19.435  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
    2023-09-15 22:47:19.448  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
    2023-09-15 22:47:19.451  - info: host.iobroker Some obsolete host states deleted.
    2023-09-15 22:47:21.211  - info: admin.0 (177) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 5.0.12
    2023-09-15 22:47:21.259  - info: admin.0 (177) requesting all objects
    2023-09-15 22:47:23.454  - info: host.iobroker instance system.adapter.backitup.0 started with pid 199
    2023-09-15 22:47:23.543  - info: admin.0 (177) received all objects
    2023-09-15 22:47:24.055  - info: admin.0 (177) Request actual repository...
    2023-09-15 22:47:24.148  - info: admin.0 (177) socket.io server listening on port 8081
    2023-09-15 22:47:24.152  - info: admin.0 (177) http server listening on port 8081
    2023-09-15 22:47:24.153  - info: admin.0 (177) Use link "http://127.0.0.1:8081" to configure.
    2023-09-15 22:47:25.698  - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    2023-09-15 22:47:27.298  - info: admin.0 (177) Repository received successfully.
    2023-09-15 22:47:27.668  - info: backitup.0 (199) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.1, js-controller: 5.0.12
    2023-09-15 22:47:27.787  - info: backitup.0 (199) [iobroker] backup will be activated at 03:00 every 1 day(s)
    2023-09-15 22:48:05.167  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-09-15 22:48:05.171  - info: admin.0 (177) Got terminate signal TERMINATE_YOURSELF
    2023-09-15 22:48:05.173  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
    2023-09-15 22:48:05.172  - info: admin.0 (177) terminating http server on port 8081
    2023-09-15 22:48:05.173  - info: admin.0 (177) terminating
    2023-09-15 22:48:05.174  - info: admin.0 (177) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-15 22:48:05.675  - info: admin.0 (177) terminating
    2023-09-15 22:48:05.781  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-15 22:48:08.290  - info: host.iobroker instance system.adapter.admin.0 started with pid 280
    2023-09-15 22:48:10.082  - info: admin.0 (280) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 5.0.12
    2023-09-15 22:48:10.126  - info: admin.0 (280) requesting all objects
    2023-09-15 22:48:11.903  - info: admin.0 (280) received all objects
    2023-09-15 22:48:12.123  - info: admin.0 (280) Request actual repository...
    2023-09-15 22:48:12.139  - info: admin.0 (280) socket.io server listening on port 8081
    2023-09-15 22:48:12.140  - info: admin.0 (280) http server listening on port 8081
    2023-09-15 22:48:12.140  - info: admin.0 (280) Use link "http://127.0.0.1:8081" to configure.
    2023-09-15 22:48:12.666  - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    2023-09-15 22:48:13.751  - info: admin.0 (280) Repository received successfully.
    2023-09-15 22:48:46.318  - info: host.iobroker received SIGTERM
    2023-09-15 22:48:46.319  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-09-15 22:48:46.321  - info: host.iobroker stopInstance system.adapter.influxdb.0 (force=false, process=false)
    2023-09-15 22:48:46.322  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=false)
    2023-09-15 22:48:46.322  - info: host.iobroker stopInstance system.adapter.node-red.0 (force=false, process=false)
    2023-09-15 22:48:46.322  - info: host.iobroker stopInstance system.adapter.pushover.0 (force=false, process=false)
    2023-09-15 22:48:46.322  - info: host.iobroker stopInstance system.adapter.telegram.0 (force=false, process=false)
    2023-09-15 22:48:46.322  - info: host.iobroker stopInstance system.adapter.ical.0 (force=false, process=false)
    2023-09-15 22:48:46.322  - info: host.iobroker stopInstance system.adapter.meross.0 (force=false, process=false)
    2023-09-15 22:48:46.323  - info: host.iobroker stopInstance system.adapter.modbus.0 (force=false, process=false)
    2023-09-15 22:48:46.323  - info: host.iobroker stopInstance system.adapter.mqtt.0 (force=false, process=false)
    2023-09-15 22:48:46.323  - info: host.iobroker stopInstance system.adapter.mqtt.1 (force=false, process=false)
    2023-09-15 22:48:46.323  - info: host.iobroker stopInstance system.adapter.netatmo.0 (force=false, process=false)
    2023-09-15 22:48:46.323  - info: host.iobroker stopInstance system.adapter.shelly.0 (force=false, process=false)
    2023-09-15 22:48:46.323  - info: host.iobroker stopInstance system.adapter.sonos.0 (force=false, process=false)
    2023-09-15 22:48:46.324  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-09-15 22:48:46.324  - info: host.iobroker stopInstance system.adapter.cloud.0 (force=false, process=false)
    2023-09-15 22:48:46.324  - info: host.iobroker stopInstance system.adapter.device-watcher.0 (force=false, process=false)
    2023-09-15 22:48:46.324  - info: host.iobroker stopInstance system.adapter.dwd.0 (force=false, process=false)
    2023-09-15 22:48:46.327  - info: host.iobroker stopInstance system.adapter.energiefluss.0 (force=false, process=false)
    2023-09-15 22:48:46.327  - info: host.iobroker stopInstance system.adapter.feiertage.0 (force=false, process=false)
    2023-09-15 22:48:46.328  - info: host.iobroker stopInstance system.adapter.jarvis.0 (force=false, process=false)
    2023-09-15 22:48:46.328  - info: host.iobroker stopInstance system.adapter.pvforecast.0 (force=false, process=false)
    2023-09-15 22:48:46.328  - info: host.iobroker stopInstance system.adapter.schoolfree.0 (force=false, process=false)
    2023-09-15 22:48:46.328  - info: host.iobroker stopInstance system.adapter.shuttercontrol.0 (force=false, process=false)
    2023-09-15 22:48:46.328  - info: host.iobroker stopInstance system.adapter.snmp.0 (force=false, process=false)
    2023-09-15 22:48:46.328  - info: host.iobroker stopInstance system.adapter.sourceanalytix.0 (force=false, process=false)
    2023-09-15 22:48:46.329  - info: host.iobroker stopInstance system.adapter.terminal.0 (force=false, process=false)
    2023-09-15 22:48:46.329  - info: host.iobroker stopInstance system.adapter.vw-connect.0 (force=false, process=false)
    2023-09-15 22:48:46.329  - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=false)
    2023-09-15 22:48:46.348  - info: admin.0 (280) Got terminate signal TERMINATE_YOURSELF
    2023-09-15 22:48:46.349  - info: admin.0 (280) terminating http server on port 8081
    2023-09-15 22:48:46.350  - info: admin.0 (280) terminating
    2023-09-15 22:48:46.355  - info: admin.0 (280) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-15 22:48:46.358  - info: backitup.0 (199) Got terminate signal TERMINATE_YOURSELF
    2023-09-15 22:48:46.365  - info: backitup.0 (199) cleaned everything up...
    2023-09-15 22:48:46.366  - info: backitup.0 (199) terminating
    2023-09-15 22:48:46.374  - info: backitup.0 (199) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-15 22:48:46.396  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
    2023-09-15 22:48:46.418  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
    2023-09-15 22:48:46.857  - info: admin.0 (280) terminating
    2023-09-15 22:48:46.874  - info: backitup.0 (199) terminating
    2023-09-15 22:48:46.960  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-15 22:48:47.017  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-15 22:48:47.017  - info: host.iobroker All instances are stopped.
    2023-09-15 22:48:47.258  - info: host.iobroker terminated
    2023-09-15 22:49:38.890  - info: host.iobroker iobroker.js-controller version 5.0.12 js-controller starting
    2023-09-15 22:49:38.893  - info: host.iobroker Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-09-15 22:49:38.894  - info: host.iobroker hostname: iobroker, node: v18.17.1
    2023-09-15 22:49:38.894  - info: host.iobroker ip addresses: 192.168.1.10
    2023-09-15 22:49:39.945  - info: host.iobroker connected to Objects and States
    2023-09-15 22:49:39.987  - info: host.iobroker added notifications configuration of host
    2023-09-15 22:49:40.643  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
    2023-09-15 22:49:40.644  - info: host.iobroker 31 instances found
    2023-09-15 22:49:40.675  - info: host.iobroker starting 2 instances
    2023-09-15 22:49:40.774  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
    2023-09-15 22:49:40.814  - info: host.iobroker instance system.adapter.admin.0 started with pid 184
    2023-09-15 22:49:40.871  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
    2023-09-15 22:49:40.915  - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
    2023-09-15 22:49:40.919  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
    2023-09-15 22:49:40.929  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
    2023-09-15 22:49:40.976  - info: host.iobroker Some obsolete host states deleted.
    2023-09-15 22:49:42.703  - info: admin.0 (184) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 5.0.12
    2023-09-15 22:49:42.752  - info: admin.0 (184) requesting all objects
    2023-09-15 22:49:44.633  - info: admin.0 (184) received all objects
    2023-09-15 22:49:45.085  - info: host.iobroker instance system.adapter.backitup.0 started with pid 207
    2023-09-15 22:49:45.452  - info: admin.0 (184) Request actual repository...
    2023-09-15 22:49:45.580  - info: admin.0 (184) socket.io server listening on port 8081
    2023-09-15 22:49:45.585  - info: admin.0 (184) http server listening on port 8081
    2023-09-15 22:49:45.585  - info: admin.0 (184) Use link "http://127.0.0.1:8081" to configure.
    2023-09-15 22:49:46.538  - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    2023-09-15 22:49:47.657  - info: backitup.0 (207) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.1, js-controller: 5.0.12
    2023-09-15 22:49:48.017  - info: backitup.0 (207) [iobroker] backup will be activated at 03:00 every 1 day(s)
    2023-09-15 22:49:48.829  - info: admin.0 (184) Repository received successfully.
    HomoranH GlasfaserG 2 Antworten Letzte Antwort
      @schtallone in der adresszeile anklicken und nachsehen
      Schtallone
      #79
      F 1 Antwort Letzte Antwort
      • S Schtallone
        iob logs --watch
        #80
        @schtallone sagte in Iobroker Admin Webseite nicht erreichbar:
        • S Schtallone
          iob logs --watch
          GlasfaserG Offline
          GlasfaserG Offline
          #81
          @schtallone
          Hast du den Container im Bridge mode ... erstellt !?
          • GlasfaserG Glasfaser
            @schtallone
            Schtallone
            #82
            @glasfaser
            nein, so
            • S Schtallone
              @marc-berg dann letzeres, habe keine ports weitergeleitet und andere container gehen auch aufzurufen wie nodered, grafana usw
              #83
              hatten wir schon
              • S Schtallone
                @glasfaser
                nein, so
                GlasfaserG Offline
                GlasfaserG Offline
                #84
                nein, so
                zeige mal das so
                Beispiel:
                  nein, so
                  zeige mal das so
                  Beispiel:
                  Schtallone
                  #85
                  @glasfaser
                  • S Schtallone
                    fastfoot
                    #86
                    @schtallone einen hab ich noch, zeige mal iob l a, das Adapterlisting
                    • F fastfoot
                      Schtallone
                      #87
                      iob l a
                      root@iobroker:/opt/iobroker# iob l a
                      system.adapter.admin                   : admin          - v6.10.1
                      system.adapter.alias-manager           : alias-manager  - v1.2.6
                      system.adapter.backitup                : backitup       - v2.8.1
                      system.adapter.cloud                   : cloud          - v4.4.1
                      system.adapter.device-watcher          : device-watcher - v2.9.3
                      system.adapter.devices                 : devices        - v1.1.5
                      system.adapter.discovery               : discovery      - v3.2.0
                      system.adapter.dwd                     : dwd            - v2.8.5
                      system.adapter.energiefluss            : energiefluss   - v3.5.0
                      system.adapter.feiertage               : feiertage      - v1.1.4
                      system.adapter.ical                    : ical           - v1.13.3
                      system.adapter.influxdb                : influxdb       - v3.2.0
                      system.adapter.jarvis                  : jarvis         - v3.1.8
                      system.adapter.javascript              : javascript     - v7.1.4
                      system.adapter.meross                  : meross         - v1.15.1
                      system.adapter.modbus                  : modbus         - v5.0.11
                      system.adapter.moma                    : moma           - v1.2.9
                      system.adapter.mqtt                    : mqtt           - v4.1.1
                      system.adapter.netatmo                 : netatmo        - v3.1.0
                      system.adapter.node-red                : node-red       - v4.0.3
                      system.adapter.pushover                : pushover       - v3.0.4
                      system.adapter.pvforecast              : pvforecast     - v2.7.1
                      system.adapter.schoolfree              : schoolfree     - v1.1.2
                      system.adapter.shelly                  : shelly         - v6.4.1
                      system.adapter.shuttercontrol          : shuttercontrol - v1.6.2
                      system.adapter.simple-api              : simple-api     - v2.7.2
                      system.adapter.snmp                    : snmp           - v2.4.11
                      system.adapter.socketio                : socketio       - v6.5.5
                      system.adapter.sonos                   : sonos          - v2.3.1
                      system.adapter.sourceanalytix          : sourceanalytix - v0.4.14
                      system.adapter.telegram                : telegram       - v1.16.0
                      system.adapter.terminal                : terminal       - v1.0.0
                      system.adapter.vw-connect              : vw-connect     - v0.1.2
                      system.adapter.web                     : web            - v6.1.2
                      system.adapter.ws                      : ws             - v2.5.5
                      • S Schtallone
                        iob l a
                        fastfoot
                        #88
                        @schtallone ok, das sieht jetzt alles gut und richtig aus, mache mal einen Container Neustart, das Log war ja ruhig
                        • F fastfoot
                          Schtallone
                          schrieb am zuletzt editiert von Schtallone
                          #89
                          @fastfoot
                          Neustart durchgeführt (per portainer). Aber kein Zugriff unter http://192.168.1.10. Weder mit Firefox, noch mit Edge
                          -----              Welcome to your ioBroker Docker container!              -----
                          -----                    Startupscript is now running!                     -----
                          -----                          Please be patient!                          -----
                          -----                          System Information                          -----
                          -----                    arch:                x86_64                       -----
                          -----                    hostname:            iobroker                     -----
                          -----                          Version Information                         -----
                          -----                    image:               v8.1.0                       -----
                          -----                    build:               2023-09-14T23:45:28+00:00    -----
                          -----                    node:                v18.17.1                     -----
                          -----                    npm:                 9.6.7                        -----
                          -----                        Environment Variables                         -----
                          -----                    SETGID:              1000                         -----
                          -----                    SETUID:              1000                         -----
                          -----                   Step 1 of 5: Preparing container                   -----
                          This is not the first run of this container. Skipping first run preparation.
                          -----             Step 2 of 5: Detecting ioBroker installation             -----
                          Existing installation of ioBroker detected in "/opt/iobroker".
                          -----             Step 3 of 5: Checking ioBroker installation              -----
                          (Re)setting permissions (This might take a while! Please be patient!)... Done.
                          Fixing "sudo-bug" by replacing sudo with gosu... Done.
                          Checking Database connection... Done.
                          Hostname in ioBroker matches the hostname of this container.
                          No action required.
                          -----                Step 4 of 5: Applying special settings                -----
                          Some adapters have special requirements/ settings which can be activated by the use of environment variables.
                          For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
                          -----                    Step 5 of 5: ioBroker startup                     -----
                          Starting ioBroker...
                          ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
                          ================================== > LOG REDIRECT system.adapter.jarvis.0 => true [starting]
                          host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.influxdb.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.javascript.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.node-red.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.pushover.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.telegram.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.ical.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.meross.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.modbus.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.mqtt.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.mqtt.1" for host "iobroker"
                          host.iobroker check instance "system.adapter.netatmo.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.shelly.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.sonos.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.cloud.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.device-watcher.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.dwd.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.energiefluss.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.feiertage.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.jarvis.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.pvforecast.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.schoolfree.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.shuttercontrol.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.snmp.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.sourceanalytix.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.terminal.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.vw-connect.0" for host "iobroker"
                          host.iobroker check instance "system.adapter.web.0" for host "iobroker"
                          ag info: {"uuid":"6d14edbb-f528-4e48-8c5a-71f2c407bd7e","language":"de","country":"Germany","hosts":[{"version":"5.0.12","platform":"Javascript/Node.js","type":"linux"}],"node":"v18.17.1","arch":"x64","docker":true,"adapters":{"admin":{"version":"6.10.1","platform":"Javascript/Node.js"},"alias-manager":{"version":"1.2.6","platform":"Javascript/Node.js"},"backitup":{"version":"2.8.1","platform":"Javascript/Node.js"},"cloud":{"version":"4.4.1","platform":"Javascript/Node.js"},"device-watcher":{"version":"2.9.3","platform":"Javascript/Node.js"},"devices":{"version":"1.1.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.2.0","platform":"Javascript/Node.js"},"dwd":{"version":"2.8.5","platform":"Javascript/Node.js"},"energiefluss":{"version":"3.5.0","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.4","platform":"Javascript/Node.js"},"ical":{"version":"1.13.3","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"jarvis":{"version":"3.1.8","platform":"Javascript/Node.js"},"javascript":{"version":"7.1.4","platform":"Javascript/Node.js"},"meross":{"version":"1.15.1","platform":"Javascript/Node.js"},"modbus":{"version":"5.0.11","platform":"Javascript/Node.js"},"moma":{"version":"1.2.9","platform":"Javascript/Node.js"},"mqtt":{"version":"4.1.1","platform":"Javascript/Node.js"},"netatmo":{"version":"3.1.0","platform":"Javascript/Node.js"},"node-red":{"version":"4.0.3","platform":"Javascript/Node.js"},"pushover":{"version":"3.0.4","platform":"Javascript/Node.js"},"pvforecast":{"version":"2.7.1","platform":"Javascript/Node.js"},"schoolfree":{"version":"1.1.2","platform":"Javascript/Node.js"},"shelly":{"version":"6.4.1","platform":"Javascript/Node.js"},"shuttercontrol":{"version":"1.6.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.7.2","platform":"Javascript/Node.js"},"snmp":{"version":"2.4.11","platform":"Javascript/Node.js"},"socketio":{"version":"6.5.5","platform":"Javascript/Node.js"},"sonos":{"version":"2.3.1","platform":"Javascript/Node.js"},"sourceanalytix":{"version":"0.4.14","platform":"Javascript/Node.js"},"telegram":{"version":"1.16.0","platform":"Javascript/Node.js"},"terminal":{"version":"1.0.0","platform":"Javascript/Node.js"},"vw-connect":{"version":"0.1.2","platform":"Javascript/Node.js"},"web":{"version":"6.1.2","platform":"Javascript/Node.js"},"ws":{"version":"2.5.5","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":31,"compactMode":false,"noCompactInstances":0,"model":"Intel(R) Celeron(R) J4005 CPU @ 2.00GHz","cpus":2,"mem":8170733568,"ostype":"Linux","city":"Oerlinghausen"}
                          • S Schtallone
                            @fastfoot
                            No action required.
                            fastfoot
                            #90
                            @schtallone sieht top aus. ein allerletzter versuch:
                            iob add admin.1 --port 4711
                            danach http://192.168.1.10:4711
                            • F fastfoot
                              Schtallone
                              #91
                              root@iobroker:/opt/iobroker# iob add admin.1 --port 4711
                              host.iobroker create instance admin
                              host.iobroker object system.adapter.admin.1.alive created
                              host.iobroker object system.adapter.admin.1.connected created
                              host.iobroker object system.adapter.admin.1.compactMode created
                              host.iobroker object system.adapter.admin.1.cpu created
                              host.iobroker object system.adapter.admin.1.cputime created
                              host.iobroker object system.adapter.admin.1.memHeapUsed created
                              host.iobroker object system.adapter.admin.1.memHeapTotal created
                              host.iobroker object system.adapter.admin.1.memRss created
                              host.iobroker object system.adapter.admin.1.uptime created
                              host.iobroker object system.adapter.admin.1.inputCount created
                              host.iobroker object system.adapter.admin.1.outputCount created
                              host.iobroker object system.adapter.admin.1.eventLoopLag created
                              host.iobroker object system.adapter.admin.1.sigKill created
                              host.iobroker object system.adapter.admin.1.logLevel created
                              host.iobroker object system.adapter.admin.upload created
                              host.iobroker object admin.1.info created
                              host.iobroker object admin.1 created
                              host.iobroker object admin.1.info.connected created
                              host.iobroker object admin.1.info.connection created
                              host.iobroker object admin.1.info.newsFeed created
                              host.iobroker object admin.1.info.newsETag created
                              host.iobroker object admin.1.info.newsLastId created
                              host.iobroker object admin.1.info.updatesList created
                              host.iobroker Set default value of admin.1.info.connected:
                              host.iobroker Set default value of admin.1.info.connection: false
                              host.iobroker Set default value of admin.1.info.updatesList:
                              host.iobroker object system.adapter.admin.1 created
                              aber kein Zugriff
                              • S Schtallone
                                @glasfaser
                                Firefox im privaten Modus mit der genannten IP http://192.168.1.10:8081 geht nicht
                                GlasfaserG Offline
                                GlasfaserG Offline
                                #92
                                @glasfaser
                                Nimm mal einen Browser mit dem du noch nie ioBroker aufgerufen hast !
                                • S Schtallone
                                  aber kein Zugriff
                                  fastfoot
                                  #93
                                  aber kein Zugriff
                                  also jetzt bin ich wirklich am Ende meines Wissens. Alle Einstellungen scheinen zu stimmen, du rufst richtig mit http:// auf, das Start Log sieht super aus
                                  wenn du aus windows auf die 192.168.1.10 pingst, geht das?
                                  • F fastfoot
                                    aber kein Zugriff
                                    Schtallone
                                    #94
                                    192.168.1.10
                                    ja, keine Paketverluste
                                      @glasfaser
                                      Schtallone
                                      #95
                                      @glasfaser
                                      Edge wäre der Browser gewesen, aber geht auch nicht
                                      • S Schtallone
                                        @glasfaser
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        #96
                                        @schtallone
                                        Was hast du sonst noch ...
                                        Firewall
                                        Pi-Hole
                                        Adblocker
                                        • S Schtallone
                                          192.168.1.10
                                          fastfoot
                                          #97
                                          @schtallone
                                          mit Handy?
                                          Hast du einen Ad-Blocker am Laufen(der private Mode sollte den eig. ausgeschaltet haben)
