  3. Einsteigerfragen
  4. Installation
  5. Troubleshooting NodeJS update
nodejs 18nodejs update
504 Beiträge 60 Kommentatoren 239.8k Aufrufe 52 Beobachtet
    @stoni
    Erstmal schauen wo die liegt:
    ls -lAh
    Stoni
    #258
    pi@raspberrypi:~ $ ls -lAh
    insgesamt 19M
    -rw------- 1 pi pi 7,1K 15. Sep 16:56 .bash_history
    -rw-r--r-- 1 pi pi  220 26. Sep 2019  .bash_logout
    -rw-r--r-- 1 pi pi 3,6K 27. Nov 2019  .bashrc
    drwxr-xr-x 3 pi pi 4,0K 27. Nov 2019  .cache
    drwx------ 3 pi pi 4,0K 27. Nov 2019  .config
    -rw-r--r-- 1 pi pi 161K 30. Nov 2020  deCONZ_ConBeeII_0x26680700.bin.GCF
    drwx------ 3 pi pi 4,0K 27. Nov 2019  .gnupg
    drwxr-xr-x 2 pi pi 4,0K 27. Nov 2019  .iobroker
    drwxr-xr-x 3 pi pi 4,0K 27. Nov 2019  .local
    drwxr-xr-x 6 pi pi 4,0K 27. Aug 2020  node-v14.9.0-linux-armv6l
    -rw-r--r-- 1 pi pi  19M 27. Aug 2020  node-v14.9.0-linux-armv6l.tar.xz
    drwxr-xr-x 4 pi pi 4,0K 27. Nov 2019  .npm
    -rw------- 1 pi pi   36 27. Nov 2019  .npmrc
    -rw-r--r-- 1 pi pi  807 26. Sep 2019  .profile
    • S Stoni
      insgesamt 19M
      Thomas BraunT Offline
      #259
      @stoni sagte in Troubleshooting NodeJS update:
      rm -rf node-v14.9*
      Und dann versuch mal das Skript von hier:
        rm -rf node-v14.9*
        Stoni
        #260
        @thomas-braun sagte in Troubleshooting NodeJS update:
        rm -rf node-v14.9*
        ioBroker nodejs fixer 2023-09-07
        Recommended nodejs-version is: 16.20.2
        Checking your installation now. Please be patient!
        Your current setup is:
        /usr/bin/nodejs         v14.21.3
        /usr/bin/node           v14.21.3
        /usr/bin/npm            6.14.18
        /usr/local/bin/npx              6.14.8
        /usr/bin/corepack       0.15.1
        *** nodejs is NOT correctly installed ***
        I found these nodejs versions available for installation:
        nodejs:
          Installed: 14.21.3-deb-1nodesource1
          Candidate: 14.21.3-deb-1nodesource1
          Version table:
         *** 14.21.3-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
             12.22.12~dfsg-1~deb11u4 500
        Your nodejs-Installation seems to be not correct. Shall we try to fix it?
        Press <y> to continue or any other key to quit
        nehme mal an yes?
        • S Stoni
          rm -rf node-v14.9*
          nodejs:
            Version table:
          nehme mal an yes?
          #261
          nehme mal an yes?
          Klar. Die nächste Frage auch bejahen.
            nehme mal an yes?
            Stoni
            #262
            @thomas-braun update auf 16.2.0.2 läuft
            • S Stoni
              #263
              @stoni
              Dann auf der Basis den iobroker updaten/upgraden, laufen lassen und final nochmal dieses Skript. Dürfte dich dann auf nodejs@18 beamen.
                @stoni
                Stoni
                #264
                @thomas-braun 18.17.1 wurde bereits installiert. Das tool gefällt mir.
                jetzt nochmal update und upgrade?
                • S Stoni
                  #265
                  Vom iobroker?
                    Vom iobroker?
                    Stoni
                    schrieb am zuletzt editiert von Stoni
                    #266
                    @thomas-braun hab irgendwie probleme mit dem Forum. Es aktualisiert sich sehr langsam und hängt.
                    Wenn node jetzt aktuell ist, wie gehe ich weiter vor?
                    js-controller und Admin müssten geupdatet werden
                    • S Stoni
                      #267
                      Wo hängste denn jetzt genau?
                      iob diag
                      anschauen.
                      • S Stoni
                        #268
                        @stoni
                        Im Grund aber
                        iob update
                        iob upgrade all
                        iob stop
                        iob upgrade self
                        iob restart
                          @stoni
                          Im Grund aber
                          iob update
                          iob upgrade all
                          iob stop
                          iob upgrade self
                          iob restart
                          Stoni
                          #269
                          @thomas-braun Ja das habe ich gesucht.
                          Damit würde ich aber alle Adapter auf den aktuellen Stand bringen oder?
                          Was wenn ich einzelne Adapter nicht updaten möchte?
                          • S Stoni
                            #270
                            Würde ich im Zuge des upgrades auf js-controller 5 aber tunlichst machen. Diverse Adapter wurden an den angepasst.
                              Stoni
                              #271
                              @thomas-braun Na dann mache ich das mal. Kann ja notfalls wieder downgraden oder? Glaube der mqtt war es, der in einer höheren Version plötzlich nicht mehr mit meiner Wärmepumpe gesprochen hat.
                              Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                              • S Stoni
                                #272
                                Dann musst du dir den anschauen.
                                • S Stoni
                                  #273
                                  @stoni Dann zieh auf jeden Fall vorher ein Backup für alle Fälle
                                  • S Stoni
                                    #274
                                    Könnte aber ja auch an der veralteten nodejs-Version gelegen haben...
                                      Stoni
                                      #275
                                      @Homoran @Thomas-Braun Backup hab ich mit Backitup erstellt und per Winscp auf den Laptop gezogen.
                                      In Putty wird jetzt jeder Adapter einzeln abgefragt. Ich update mal fleißig. Melde mich. Bis dahin besten DANK!
                                        Stoni
                                        #276
                                        Soweit scheint alles zu laufen. Der Log zeigt noch einige Warnungen. Durch Neustart der Adapter wird das aber sukzessive behoben.
                                        Also nochmal besten dank. Der Puls normalisiert sich langsam.
                                        Eine One Button-Lösung wäre beim Update wünschenswert, aber vmtl nicht realisierbar.
                                        VG Stoni
                                        • S Stoni
                                          VG Stoni
                                          #277
                                          gibt es doch. im Admin.
                                          nur Adapter mit Update anzeigen filtern, dann erscheint der Button
                                          und dann kannst du sogar auswählen
