- ioBroker Community Home
- Deutsch
- Off Topic
- Homekit-controller lässt sich nicht installieren
Ohje, is ne Menge.
*** BASE SYSTEM *** Static hostname: iobrokerNUC Icon name: computer-desktop Chassis: desktop 🖥️ Machine ID: 5d7cb8cbe58a4a17a905354431cfbb8d Boot ID: 200f822a21c448e884941fd698e54ca1 Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-12-amd64 Architecture: x86-64 Hardware Vendor: Default string Hardware Model: Default string Firmware Version: 5.27 model name : Intel(R) N95 Docker : false Virtualization : none Kernel : x86_64 Userland : amd64 Systemuptime and Load: 16:48:21 up 3:32, 3 users, load average: 0.43, 0.35, 0.26 CPU threads: 4 *** Time and Time Zones *** Local time: Fri 2023-09-15 16:48:21 CEST Universal time: Fri 2023-09-15 14:48:21 UTC RTC time: Fri 2023-09-15 14:48:21 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** root /root root *** X-Server-Setup *** X-Server: true Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 16G 5.5G 4.6G 210M 7.0G 11G Swap: 1.0G 0B 1.0G Total: 17G 5.5G 5.6G 15767 M total memory 5258 M used memory 1133 M active memory 9391 M inactive memory 4349 M free memory 242 M buffer memory 6451 M swap cache 975 M total swap 0 M used swap 975 M free swap *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 7.7G 0 7.7G 0% /dev tmpfs tmpfs 1.6G 1.5M 1.6G 1% /run /dev/sda2 ext4 467G 9.8G 434G 3% / tmpfs tmpfs 7.7G 792K 7.7G 1% /dev/shm tmpfs tmpfs 5.0M 12K 5.0M 1% /run/lock /dev/sda1 vfat 511M 5.9M 506M 2% /boot/efi tmpfs tmpfs 1.6G 3.7M 1.6G 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none. [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): re-mounted. Quota mode: none. Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,relatime,errors=remount-ro |-/run/user/1000/doc portal fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 `-/boot/efi /dev/sda1 vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro Files in neuralgic directories: /var: 503M /var/ 231M /var/cache 221M /var/cache/apt 216M /var/lib 145M /var/cache/apt/archives Archived and active journals take up 32.0M in the file system. /opt/iobroker/backups: 71M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 784M /opt/iobroker/iobroker-data/ 698M /opt/iobroker/iobroker-data/files 119M /opt/iobroker/iobroker-data/files/vis-2 78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png 71M /opt/iobroker/iobroker-data/files/vis-2/static The five largest files in iobroker-data are: 73M /opt/iobroker/iobroker-data/objects.jsonl 41M /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.67295ba8.js.map *** NodeJS-Installation *** /usr/bin/nodejs v18.17.1 /usr/bin/node v18.17.1 /usr/bin/npm 9.6.7 /usr/bin/npx 9.6.7 nodejs: Installed: 18.17.1-deb-1nodesource1 Candidate: 18.17.1-deb-1nodesource1 Version table: *** 18.17.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages 100 /var/lib/dpkg/status 18.13.0+dfsg1-1 500 500 http://deb.debian.org/debian bookworm/main amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: 0 *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl No configuration change needed. Multihost discovery server: disabled Discovery authentication: enabled Persistent activation: disabled Objects: jsonl on 127.0.0.1 States: jsonl on 127.0.0.1 Core adapters versions js-controller: 5.0.12 admin: 6.10.1 javascript: 7.1.4 Adapters from github: 5 Adapter State + system.adapter.admin.0 : admin : iobrokerNUC - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin system.adapter.admin.1 : admin : iobrokerNUC - disabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alexa2.0 : alexa2 : iobrokerNUC - disabled + system.adapter.backitup.0 : backitup : iobrokerNUC - enabled system.adapter.ble.0 : ble : iobrokerNUC - disabled system.adapter.broadlink2.0 : broadlink2 : iobrokerNUC - disabled system.adapter.cameras.0 : cameras : iobrokerNUC - disabled, port: 8200, bind: 0.0.0.0 system.adapter.chromecast.0 : chromecast : iobrokerNUC - disabled system.adapter.cloud.0 : cloud : iobrokerNUC - disabled system.adapter.daswetter.0 : daswetter : iobrokerNUC - disabled system.adapter.devices.0 : devices : iobrokerNUC - disabled system.adapter.discovery.0 : discovery : iobrokerNUC - disabled system.adapter.ecovacs-deebot.2 : ecovacs-deebot : iobrokerNUC - disabled system.adapter.ecovacs-deebot.3 : ecovacs-deebot : iobrokerNUC - disabled system.adapter.ecovacs-deebot.4 : ecovacs-deebot : iobrokerNUC - disabled system.adapter.energiefluss.0 : energiefluss : iobrokerNUC - disabled system.adapter.eusec.0 : eusec : iobrokerNUC - disabled system.adapter.feiertage.0 : feiertage : iobrokerNUC - disabled system.adapter.flot.0 : flot : iobrokerNUC - disabled system.adapter.fritzbox.0 : fritzbox : iobrokerNUC - disabled system.adapter.fritzdect.0 : fritzdect : iobrokerNUC - disabled system.adapter.fullcalendar.0 : fullcalendar : iobrokerNUC - disabled system.adapter.fullybrowser.0 : fullybrowser : iobrokerNUC - disabled system.adapter.govee-app.0 : govee-app : iobrokerNUC - disabled system.adapter.habpanel.0 : habpanel : iobrokerNUC - disabled system.adapter.history.0 : history : iobrokerNUC - disabled system.adapter.hm-rega.0 : hm-rega : iobrokerNUC - disabled system.adapter.hm-rpc.0 : hm-rpc : iobrokerNUC - disabled, port: 0 system.adapter.hm-rpc.1 : hm-rpc : iobrokerNUC - disabled, port: 0 system.adapter.homeconnect.0 : homeconnect : iobrokerNUC - disabled system.adapter.homekit-controller.0 : homekit-controller : iobrokerNUC - disabled system.adapter.homepilot20.0 : homepilot20 : iobrokerNUC - disabled system.adapter.hue-extended.0 : hue-extended : iobrokerNUC - disabled system.adapter.hue.0 : hue : iobrokerNUC - disabled, port: 443 system.adapter.ical.0 : ical : iobrokerNUC - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : iobrokerNUC - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobrokerNUC - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobrokerNUC - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobrokerNUC - disabled system.adapter.influxdb.0 : influxdb : iobrokerNUC - disabled, port: 8090 system.adapter.info.0 : info : iobrokerNUC - disabled system.adapter.iot.0 : iot : iobrokerNUC - disabled system.adapter.javascript.0 : javascript : iobrokerNUC - disabled system.adapter.linux-control.0 : linux-control : iobrokerNUC - disabled system.adapter.material.0 : material : iobrokerNUC - disabled system.adapter.mihome-vacuum.0 : mihome-vacuum : iobrokerNUC - disabled, port: 54321 system.adapter.mihome.0 : mihome : iobrokerNUC - disabled, port: 9898, bind: 0.0.0.0 system.adapter.mobile.0 : mobile : iobrokerNUC - disabled system.adapter.mqtt.0 : mqtt : iobrokerNUC - disabled, port: 1888, bind: 0.0.0.0 system.adapter.musiccast.0 : musiccast : iobrokerNUC - disabled system.adapter.net-tools.0 : net-tools : iobrokerNUC - disabled system.adapter.netatmo.0 : netatmo : iobrokerNUC - disabled system.adapter.netatmo.1 : netatmo : iobrokerNUC - disabled system.adapter.node-red.0 : node-red : iobrokerNUC - disabled, port: 1880, bind: 192.168.178.143 system.adapter.radar2.0 : radar2 : iobrokerNUC - disabled system.adapter.sayit.0 : sayit : iobrokerNUC - disabled system.adapter.scenes.0 : scenes : iobrokerNUC - disabled system.adapter.shelly.0 : shelly : iobrokerNUC - disabled, port: 1886, bind: 0.0.0.0 system.adapter.simple-api.0 : simple-api : iobrokerNUC - disabled, port: 8087, bind: 192.168.178.143, run as: admin system.adapter.slideshow.0 : slideshow : iobrokerNUC - disabled system.adapter.smartthings.0 : smartthings : iobrokerNUC - disabled system.adapter.socketio.0 : socketio : iobrokerNUC - disabled, port: 8085, bind: 0.0.0.0, run as: admin system.adapter.sonoff.0 : sonoff : iobrokerNUC - disabled, port: 1883, bind: 192.168.178.143 system.adapter.sourceanalytix.0 : sourceanalytix : iobrokerNUC - disabled system.adapter.synology.0 : synology : iobrokerNUC - disabled, port: 5000 system.adapter.telegram.0 : telegram : iobrokerNUC - disabled, port: 8443, bind: 0.0.0.0 system.adapter.terminal.0 : terminal : iobrokerNUC - disabled, port: 8088, bind: 0.0.0.0, run as: admin system.adapter.text2command.0 : text2command : iobrokerNUC - disabled system.adapter.tileboard.0 : tileboard : iobrokerNUC - disabled system.adapter.tr-064.0 : tr-064 : iobrokerNUC - disabled system.adapter.tuya.0 : tuya : iobrokerNUC - disabled system.adapter.vis-2.0 : vis-2 : iobrokerNUC - disabled system.adapter.vis-bars.0 : vis-bars : iobrokerNUC - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobrokerNUC - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : iobrokerNUC - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobrokerNUC - disabled system.adapter.vis-google-fonts.0 : vis-google-fonts : iobrokerNUC - disabled system.adapter.vis-history.0 : vis-history : iobrokerNUC - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobrokerNUC - disabled system.adapter.vis-icontwo.0 : vis-icontwo : iobrokerNUC - disabled system.adapter.vis-inventwo.0 : vis-inventwo : iobrokerNUC - disabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobrokerNUC - disabled system.adapter.vis-justgage.0 : vis-justgage : iobrokerNUC - disabled system.adapter.vis-keyboard.0 : vis-keyboard : iobrokerNUC - disabled system.adapter.vis-lcars.0 : vis-lcars : iobrokerNUC - disabled system.adapter.vis-map.0 : vis-map : iobrokerNUC - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : iobrokerNUC - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobrokerNUC - disabled system.adapter.vis-metro.0 : vis-metro : iobrokerNUC - disabled system.adapter.vis-players.0 : vis-players : iobrokerNUC - disabled system.adapter.vis-plumb.0 : vis-plumb : iobrokerNUC - disabled system.adapter.vis-rgraph.0 : vis-rgraph : iobrokerNUC - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobrokerNUC - disabled system.adapter.vis-weather.0 : vis-weather : iobrokerNUC - disabled system.adapter.vis.0 : vis : iobrokerNUC - disabled system.adapter.web.0 : web : iobrokerNUC - disabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobrokerNUC - disabled system.adapter.wifilight.0 : wifilight : iobrokerNUC - disabled system.adapter.yeelight-2.0 : yeelight-2 : iobrokerNUC - disabled system.adapter.yr.0 : yr : iobrokerNUC - disabled system.adapter.zigbee.0 : zigbee : iobrokerNUC - disabled, port: /dev/ttyUSB0 system.adapter.zigbee2mqtt.0 : zigbee2mqtt : iobrokerNUC - disabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobrokerNUC - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.8.0 , installed 6.10.1 Adapter "alexa2" : 3.24.1 , installed 3.25.2 Adapter "backitup" : 2.6.23 , installed 2.8.1 Adapter "broadlink2" : 2.1.5 , installed 2.1.5 Adapter "chromecast" : 3.0.3 , installed 3.0.3 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "daswetter" : 3.1.10 , installed 3.1.10 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 3.1.0 , installed 4.0.0 Adapter "ecovacs-deebot": 1.4.13 , installed 1.4.13 Adapter "eusec" : 1.1.2 , installed 1.1.2 Adapter "feiertage" : 1.1.0 , installed 1.1.4 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzbox" : 0.2.1 , installed 0.5.0 Adapter "fritzdect" : 2.3.1 , installed 2.3.1 Adapter "fullcalendar" : 1.2.0 , installed 2.2.6 Adapter "fullybrowser" : 2.1.2 , installed 2.1.2 Adapter "habpanel" : 0.5.0 , installed 0.5.0 Adapter "history" : 2.2.6 , installed 2.2.6 Adapter "hm-rega" : 3.0.47 , installed 4.0.0 Adapter "hm-rpc" : 1.15.19 , installed 1.15.19 Adapter "homeconnect" : 1.1.1 , installed 1.1.1 Adapter "hue" : 3.9.5 , installed 3.10.0 Adapter "hue-extended" : 2.0.0 , installed 2.0.0 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "info" : 1.9.26 , installed 2.0.0 Adapter "iot" : 1.14.5 , installed 2.0.11 Adapter "javascript" : 7.1.4 , installed 7.1.4 Controller "js-controller": 5.0.12 , installed 5.0.12 Adapter "linux-control": 1.1.5 , installed 1.1.5 Adapter "material" : 1.3.1 , installed 1.3.1 Adapter "mihome" : 1.4.0 , installed 1.4.0 Adapter "mihome-vacuum": 3.11.0 , installed 4.0.0 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "mqtt" : 4.1.1 , installed 4.1.1 Adapter "musiccast" : 1.1.0 , installed 1.1.0 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "netatmo" : 3.1.0 , installed 3.1.0 Adapter "node-red" : 4.0.3 , installed 4.0.3 Adapter "radar2" : 2.0.7 , installed 2.0.7 Adapter "sayit" : 3.0.5 , installed 3.0.5 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 6.4.1 , installed 6.4.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartthings" : 0.0.4 , installed 0.0.4 Adapter "socketio" : 6.5.5 , installed 6.5.3 [Updatable] Adapter "sonoff" : 2.5.3 , installed 2.5.7 Adapter "synology" : 2.1.13 , installed 3.0.0 Adapter "telegram" : 1.16.0 , installed 1.16.0 Adapter "terminal" : 1.0.0 , installed 1.0.0 Adapter "text2command" : 3.0.2 , installed 3.0.2 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "tuya" : 3.14.2 , installed 3.14.2 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 0.96.0 , installed 0.96.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-justgage" : 1.0.2 , installed 1.0.2 Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2 Adapter "vis-lcars" : 1.1.1 , installed 1.1.1 Adapter "vis-map" : 1.0.4 , installed 1.0.4 Adapter "vis-material-advanced": 1.7.2, installed 1.7.4 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.6 , installed 2.5.6 Adapter "web" : 6.1.2 , installed 6.1.1 [Updatable] Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3 Adapter "wifilight" : 1.1.4 , installed 1.1.4 Adapter "ws" : 2.5.5 , installed 2.5.3 [Updatable] Adapter "yeelight-2" : 1.2.1 , installed 1.2.1 Adapter "yr" : 5.3.0 , installed 5.3.0 Adapter "zigbee" : 1.8.23 , installed 1.8.24 Adapter "zigbee2mqtt" : 2.13.1 , installed 2.13.1 Objects and States Please stand by - This may take a while Objects: 37997 States: 31034 *** OS-Repositories and Updates *** W: http://deb.anydesk.com/dists/all/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details. Hit:1 https://deb.nodesource.com/node_18.x bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm InRelease Hit:3 http://security.debian.org/debian-security bookworm-security InRelease Hit:4 http://deb.anydesk.com all InRelease Reading package lists... W: http://deb.anydesk.com/dists/all/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details. Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:37838 0.0.0.0:* LISTEN 0 188418 28229/anydesk tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 21612 662/cupsd tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 212660 43636/iobroker.js-c tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 211792 43636/iobroker.js-c tcp 0 0 0.0.0.0:7070 0.0.0.0:* LISTEN 0 145110 28229/anydesk tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 166031 33594/sshd: /usr/sb tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 135901 1/init tcp 0 0 127.0.0.1:4101 0.0.0.0:* LISTEN 0 21672 544/brltty tcp6 0 0 ::1:4101 :::* LISTEN 0 17962 544/brltty tcp6 0 0 :::8081 :::* LISTEN 1001 211857 43667/io.admin.0 tcp6 0 0 ::1:631 :::* LISTEN 0 21611 662/cupsd tcp6 0 0 :::22 :::* LISTEN 0 166033 33594/sshd: /usr/sb tcp6 0 0 :::111 :::* LISTEN 0 136579 1/init udp 0 0 0.0.0.0:56190 0.0.0.0:* 103 17893 594/avahi-daemon: r udp 0 0 0.0.0.0:111 0.0.0.0:* 0 137387 1/init udp 0 0 0.0.0.0:631 0.0.0.0:* 0 23634 907/cups-browsed udp 0 0 0.0.0.0:50001 0.0.0.0:* 0 146842 28229/anydesk udp 0 0 0.0.0.0:5353 0.0.0.0:* 103 17891 594/avahi-daemon: r udp6 0 0 :::111 :::* 0 136581 1/init udp6 0 0 :::52127 :::* 103 17894 594/avahi-daemon: r udp6 0 0 :::5353 :::* 103 17892 594/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-09-15 15:18:57.566 - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call) 2023-09-15 15:19:42.074 - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:69843) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_18_57_748Z-debug-0.log 2023-09-15 15:19:42.074 - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1 2023-09-15 15:19:43.092 - info: host.iobrokerNUC iobroker exit 25 2023-09-15 15:23:58.531 - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC 2023-09-15 15:23:59.537 - info: host.iobrokerNUC iobroker NPM version: 9.6.7 2023-09-15 15:23:59.537 - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call) 2023-09-15 15:24:04.010 - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:70887) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_23_59_740Z-debug-0.log 2023-09-15 15:24:04.011 - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1 2023-09-15 15:24:05.036 - info: host.iobrokerNUC iobroker exit 25 2023-09-15 15:34:53.572 - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC 2023-09-15 15:34:54.600 - info: host.iobrokerNUC iobroker NPM version: 9.6.7 2023-09-15 15:34:54.601 - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call) 2023-09-15 15:35:04.442 - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:73159) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log 2023-09-15 15:35:04.443 - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1 2023-09-15 15:35:05.468 - info: host.iobrokerNUC iobroker exit 25 2023-09-15 16:34:59.946 - info: admin.0 (43667) ==> Connected system.user.admin from ::ffff:192.168.178.105 2023-09-15 16:35:01.497 - info: host.iobrokerNUC Updating repository "stable" under "http://download.iobroker.net/sources-dist.json" 2023-09-15 16:39:44.533 - info: admin.0 (43667) <== Disconnect system.user.admin from ::ffff:192.168.178.105 2023-09-15 16:39:53.534 - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC 2023-09-15 16:39:54.568 - info: host.iobrokerNUC iobroker NPM version: 9.6.7 2023-09-15 16:39:54.569 - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call) 2023-09-15 16:40:03.838 - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:85655) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T14_39_54_749Z-debug-0.log 2023-09-15 16:40:03.838 - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1 2023-09-15 16:40:04.857 - info: host.iobrokerNUC iobroker exit 25======================= SUMMARY ======================= v.2023-06-20 Static hostname: iobrokerNUC Icon name: computer-desktop Chassis: desktop 🖥️ Machine ID: 5d7cb8cbe58a4a17a905354431cfbb8d Boot ID: 200f822a21c448e884941fd698e54ca1 Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-12-amd64 Architecture: x86-64 Hardware Vendor: Default string Hardware Model: Default string Firmware Version: 5.27 Installation: native Kernel: x86_64 Userland: amd64 Timezone: Europe/Berlin (CEST, +0200) User-ID: 0 X-Server: true Boot Target: graphical.target Pending OS-Updates: 0 -
HAt nicht funktioniert, kam Forbidden, sry.
Ohje, is ne Menge.
*** BASE SYSTEM *** Static hostname: iobrokerNUC Icon name: computer-desktop Chassis: desktop 🖥️ Machine ID: 5d7cb8cbe58a4a17a905354431cfbb8d Boot ID: 200f822a21c448e884941fd698e54ca1 Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-12-amd64 Architecture: x86-64 Hardware Vendor: Default string Hardware Model: Default string Firmware Version: 5.27 model name : Intel(R) N95 Docker : false Virtualization : none Kernel : x86_64 Userland : amd64 Systemuptime and Load: 16:48:21 up 3:32, 3 users, load average: 0.43, 0.35, 0.26 CPU threads: 4 *** Time and Time Zones *** Local time: Fri 2023-09-15 16:48:21 CEST Universal time: Fri 2023-09-15 14:48:21 UTC RTC time: Fri 2023-09-15 14:48:21 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** root /root root *** X-Server-Setup *** X-Server: true Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 16G 5.5G 4.6G 210M 7.0G 11G Swap: 1.0G 0B 1.0G Total: 17G 5.5G 5.6G 15767 M total memory 5258 M used memory 1133 M active memory 9391 M inactive memory 4349 M free memory 242 M buffer memory 6451 M swap cache 975 M total swap 0 M used swap 975 M free swap *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 7.7G 0 7.7G 0% /dev tmpfs tmpfs 1.6G 1.5M 1.6G 1% /run /dev/sda2 ext4 467G 9.8G 434G 3% / tmpfs tmpfs 7.7G 792K 7.7G 1% /dev/shm tmpfs tmpfs 5.0M 12K 5.0M 1% /run/lock /dev/sda1 vfat 511M 5.9M 506M 2% /boot/efi tmpfs tmpfs 1.6G 3.7M 1.6G 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none. [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): re-mounted. Quota mode: none. Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,relatime,errors=remount-ro |-/run/user/1000/doc portal fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 `-/boot/efi /dev/sda1 vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro Files in neuralgic directories: /var: 503M /var/ 231M /var/cache 221M /var/cache/apt 216M /var/lib 145M /var/cache/apt/archives Archived and active journals take up 32.0M in the file system. /opt/iobroker/backups: 71M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 784M /opt/iobroker/iobroker-data/ 698M /opt/iobroker/iobroker-data/files 119M /opt/iobroker/iobroker-data/files/vis-2 78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png 71M /opt/iobroker/iobroker-data/files/vis-2/static The five largest files in iobroker-data are: 73M /opt/iobroker/iobroker-data/objects.jsonl 41M /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.67295ba8.js.map *** NodeJS-Installation *** /usr/bin/nodejs v18.17.1 /usr/bin/node v18.17.1 /usr/bin/npm 9.6.7 /usr/bin/npx 9.6.7 nodejs: Installed: 18.17.1-deb-1nodesource1 Candidate: 18.17.1-deb-1nodesource1 Version table: *** 18.17.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages 100 /var/lib/dpkg/status 18.13.0+dfsg1-1 500 500 http://deb.debian.org/debian bookworm/main amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: 0 *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl No configuration change needed. Multihost discovery server: disabled Discovery authentication: enabled Persistent activation: disabled Objects: jsonl on 127.0.0.1 States: jsonl on 127.0.0.1 Core adapters versions js-controller: 5.0.12 admin: 6.10.1 javascript: 7.1.4 Adapters from github: 5 Adapter State + system.adapter.admin.0 : admin : iobrokerNUC - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin system.adapter.admin.1 : admin : iobrokerNUC - disabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alexa2.0 : alexa2 : iobrokerNUC - disabled + system.adapter.backitup.0 : backitup : iobrokerNUC - enabled system.adapter.ble.0 : ble : iobrokerNUC - disabled system.adapter.broadlink2.0 : broadlink2 : iobrokerNUC - disabled system.adapter.cameras.0 : cameras : iobrokerNUC - disabled, port: 8200, bind: 0.0.0.0 system.adapter.chromecast.0 : chromecast : iobrokerNUC - disabled system.adapter.cloud.0 : cloud : iobrokerNUC - disabled system.adapter.daswetter.0 : daswetter : iobrokerNUC - disabled system.adapter.devices.0 : devices : iobrokerNUC - disabled system.adapter.discovery.0 : discovery : iobrokerNUC - disabled system.adapter.ecovacs-deebot.2 : ecovacs-deebot : iobrokerNUC - disabled system.adapter.ecovacs-deebot.3 : ecovacs-deebot : iobrokerNUC - disabled system.adapter.ecovacs-deebot.4 : ecovacs-deebot : iobrokerNUC - disabled system.adapter.energiefluss.0 : energiefluss : iobrokerNUC - disabled system.adapter.eusec.0 : eusec : iobrokerNUC - disabled system.adapter.feiertage.0 : feiertage : iobrokerNUC - disabled system.adapter.flot.0 : flot : iobrokerNUC - disabled system.adapter.fritzbox.0 : fritzbox : iobrokerNUC - disabled system.adapter.fritzdect.0 : fritzdect : iobrokerNUC - disabled system.adapter.fullcalendar.0 : fullcalendar : iobrokerNUC - disabled system.adapter.fullybrowser.0 : fullybrowser : iobrokerNUC - disabled system.adapter.govee-app.0 : govee-app : iobrokerNUC - disabled system.adapter.habpanel.0 : habpanel : iobrokerNUC - disabled system.adapter.history.0 : history : iobrokerNUC - disabled system.adapter.hm-rega.0 : hm-rega : iobrokerNUC - disabled system.adapter.hm-rpc.0 : hm-rpc : iobrokerNUC - disabled, port: 0 system.adapter.hm-rpc.1 : hm-rpc : iobrokerNUC - disabled, port: 0 system.adapter.homeconnect.0 : homeconnect : iobrokerNUC - disabled system.adapter.homekit-controller.0 : homekit-controller : iobrokerNUC - disabled system.adapter.homepilot20.0 : homepilot20 : iobrokerNUC - disabled system.adapter.hue-extended.0 : hue-extended : iobrokerNUC - disabled system.adapter.hue.0 : hue : iobrokerNUC - disabled, port: 443 system.adapter.ical.0 : ical : iobrokerNUC - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : iobrokerNUC - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobrokerNUC - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobrokerNUC - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobrokerNUC - disabled system.adapter.influxdb.0 : influxdb : iobrokerNUC - disabled, port: 8090 system.adapter.info.0 : info : iobrokerNUC - disabled system.adapter.iot.0 : iot : iobrokerNUC - disabled system.adapter.javascript.0 : javascript : iobrokerNUC - disabled system.adapter.linux-control.0 : linux-control : iobrokerNUC - disabled system.adapter.material.0 : material : iobrokerNUC - disabled system.adapter.mihome-vacuum.0 : mihome-vacuum : iobrokerNUC - disabled, port: 54321 system.adapter.mihome.0 : mihome : iobrokerNUC - disabled, port: 9898, bind: 0.0.0.0 system.adapter.mobile.0 : mobile : iobrokerNUC - disabled system.adapter.mqtt.0 : mqtt : iobrokerNUC - disabled, port: 1888, bind: 0.0.0.0 system.adapter.musiccast.0 : musiccast : iobrokerNUC - disabled system.adapter.net-tools.0 : net-tools : iobrokerNUC - disabled system.adapter.netatmo.0 : netatmo : iobrokerNUC - disabled system.adapter.netatmo.1 : netatmo : iobrokerNUC - disabled system.adapter.node-red.0 : node-red : iobrokerNUC - disabled, port: 1880, bind: 192.168.178.143 system.adapter.radar2.0 : radar2 : iobrokerNUC - disabled system.adapter.sayit.0 : sayit : iobrokerNUC - disabled system.adapter.scenes.0 : scenes : iobrokerNUC - disabled system.adapter.shelly.0 : shelly : iobrokerNUC - disabled, port: 1886, bind: 0.0.0.0 system.adapter.simple-api.0 : simple-api : iobrokerNUC - disabled, port: 8087, bind: 192.168.178.143, run as: admin system.adapter.slideshow.0 : slideshow : iobrokerNUC - disabled system.adapter.smartthings.0 : smartthings : iobrokerNUC - disabled system.adapter.socketio.0 : socketio : iobrokerNUC - disabled, port: 8085, bind: 0.0.0.0, run as: admin system.adapter.sonoff.0 : sonoff : iobrokerNUC - disabled, port: 1883, bind: 192.168.178.143 system.adapter.sourceanalytix.0 : sourceanalytix : iobrokerNUC - disabled system.adapter.synology.0 : synology : iobrokerNUC - disabled, port: 5000 system.adapter.telegram.0 : telegram : iobrokerNUC - disabled, port: 8443, bind: 0.0.0.0 system.adapter.terminal.0 : terminal : iobrokerNUC - disabled, port: 8088, bind: 0.0.0.0, run as: admin system.adapter.text2command.0 : text2command : iobrokerNUC - disabled system.adapter.tileboard.0 : tileboard : iobrokerNUC - disabled system.adapter.tr-064.0 : tr-064 : iobrokerNUC - disabled system.adapter.tuya.0 : tuya : iobrokerNUC - disabled system.adapter.vis-2.0 : vis-2 : iobrokerNUC - disabled system.adapter.vis-bars.0 : vis-bars : iobrokerNUC - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobrokerNUC - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : iobrokerNUC - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobrokerNUC - disabled system.adapter.vis-google-fonts.0 : vis-google-fonts : iobrokerNUC - disabled system.adapter.vis-history.0 : vis-history : iobrokerNUC - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobrokerNUC - disabled system.adapter.vis-icontwo.0 : vis-icontwo : iobrokerNUC - disabled system.adapter.vis-inventwo.0 : vis-inventwo : iobrokerNUC - disabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobrokerNUC - disabled system.adapter.vis-justgage.0 : vis-justgage : iobrokerNUC - disabled system.adapter.vis-keyboard.0 : vis-keyboard : iobrokerNUC - disabled system.adapter.vis-lcars.0 : vis-lcars : iobrokerNUC - disabled system.adapter.vis-map.0 : vis-map : iobrokerNUC - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : iobrokerNUC - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobrokerNUC - disabled system.adapter.vis-metro.0 : vis-metro : iobrokerNUC - disabled system.adapter.vis-players.0 : vis-players : iobrokerNUC - disabled system.adapter.vis-plumb.0 : vis-plumb : iobrokerNUC - disabled system.adapter.vis-rgraph.0 : vis-rgraph : iobrokerNUC - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobrokerNUC - disabled system.adapter.vis-weather.0 : vis-weather : iobrokerNUC - disabled system.adapter.vis.0 : vis : iobrokerNUC - disabled system.adapter.web.0 : web : iobrokerNUC - disabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobrokerNUC - disabled system.adapter.wifilight.0 : wifilight : iobrokerNUC - disabled system.adapter.yeelight-2.0 : yeelight-2 : iobrokerNUC - disabled system.adapter.yr.0 : yr : iobrokerNUC - disabled system.adapter.zigbee.0 : zigbee : iobrokerNUC - disabled, port: /dev/ttyUSB0 system.adapter.zigbee2mqtt.0 : zigbee2mqtt : iobrokerNUC - disabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobrokerNUC - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.8.0 , installed 6.10.1 Adapter "alexa2" : 3.24.1 , installed 3.25.2 Adapter "backitup" : 2.6.23 , installed 2.8.1 Adapter "broadlink2" : 2.1.5 , installed 2.1.5 Adapter "chromecast" : 3.0.3 , installed 3.0.3 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "daswetter" : 3.1.10 , installed 3.1.10 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 3.1.0 , installed 4.0.0 Adapter "ecovacs-deebot": 1.4.13 , installed 1.4.13 Adapter "eusec" : 1.1.2 , installed 1.1.2 Adapter "feiertage" : 1.1.0 , installed 1.1.4 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzbox" : 0.2.1 , installed 0.5.0 Adapter "fritzdect" : 2.3.1 , installed 2.3.1 Adapter "fullcalendar" : 1.2.0 , installed 2.2.6 Adapter "fullybrowser" : 2.1.2 , installed 2.1.2 Adapter "habpanel" : 0.5.0 , installed 0.5.0 Adapter "history" : 2.2.6 , installed 2.2.6 Adapter "hm-rega" : 3.0.47 , installed 4.0.0 Adapter "hm-rpc" : 1.15.19 , installed 1.15.19 Adapter "homeconnect" : 1.1.1 , installed 1.1.1 Adapter "hue" : 3.9.5 , installed 3.10.0 Adapter "hue-extended" : 2.0.0 , installed 2.0.0 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "info" : 1.9.26 , installed 2.0.0 Adapter "iot" : 1.14.5 , installed 2.0.11 Adapter "javascript" : 7.1.4 , installed 7.1.4 Controller "js-controller": 5.0.12 , installed 5.0.12 Adapter "linux-control": 1.1.5 , installed 1.1.5 Adapter "material" : 1.3.1 , installed 1.3.1 Adapter "mihome" : 1.4.0 , installed 1.4.0 Adapter "mihome-vacuum": 3.11.0 , installed 4.0.0 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "mqtt" : 4.1.1 , installed 4.1.1 Adapter "musiccast" : 1.1.0 , installed 1.1.0 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "netatmo" : 3.1.0 , installed 3.1.0 Adapter "node-red" : 4.0.3 , installed 4.0.3 Adapter "radar2" : 2.0.7 , installed 2.0.7 Adapter "sayit" : 3.0.5 , installed 3.0.5 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 6.4.1 , installed 6.4.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartthings" : 0.0.4 , installed 0.0.4 Adapter "socketio" : 6.5.5 , installed 6.5.3 [Updatable] Adapter "sonoff" : 2.5.3 , installed 2.5.7 Adapter "synology" : 2.1.13 , installed 3.0.0 Adapter "telegram" : 1.16.0 , installed 1.16.0 Adapter "terminal" : 1.0.0 , installed 1.0.0 Adapter "text2command" : 3.0.2 , installed 3.0.2 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "tuya" : 3.14.2 , installed 3.14.2 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 0.96.0 , installed 0.96.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-justgage" : 1.0.2 , installed 1.0.2 Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2 Adapter "vis-lcars" : 1.1.1 , installed 1.1.1 Adapter "vis-map" : 1.0.4 , installed 1.0.4 Adapter "vis-material-advanced": 1.7.2, installed 1.7.4 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.6 , installed 2.5.6 Adapter "web" : 6.1.2 , installed 6.1.1 [Updatable] Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3 Adapter "wifilight" : 1.1.4 , installed 1.1.4 Adapter "ws" : 2.5.5 , installed 2.5.3 [Updatable] Adapter "yeelight-2" : 1.2.1 , installed 1.2.1 Adapter "yr" : 5.3.0 , installed 5.3.0 Adapter "zigbee" : 1.8.23 , installed 1.8.24 Adapter "zigbee2mqtt" : 2.13.1 , installed 2.13.1 Objects and States Please stand by - This may take a while Objects: 37997 States: 31034 *** OS-Repositories and Updates *** W: http://deb.anydesk.com/dists/all/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details. Hit:1 https://deb.nodesource.com/node_18.x bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm InRelease Hit:3 http://security.debian.org/debian-security bookworm-security InRelease Hit:4 http://deb.anydesk.com all InRelease Reading package lists... W: http://deb.anydesk.com/dists/all/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details. Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:37838 0.0.0.0:* LISTEN 0 188418 28229/anydesk tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 21612 662/cupsd tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 212660 43636/iobroker.js-c tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 211792 43636/iobroker.js-c tcp 0 0 0.0.0.0:7070 0.0.0.0:* LISTEN 0 145110 28229/anydesk tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 166031 33594/sshd: /usr/sb tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 135901 1/init tcp 0 0 127.0.0.1:4101 0.0.0.0:* LISTEN 0 21672 544/brltty tcp6 0 0 ::1:4101 :::* LISTEN 0 17962 544/brltty tcp6 0 0 :::8081 :::* LISTEN 1001 211857 43667/io.admin.0 tcp6 0 0 ::1:631 :::* LISTEN 0 21611 662/cupsd tcp6 0 0 :::22 :::* LISTEN 0 166033 33594/sshd: /usr/sb tcp6 0 0 :::111 :::* LISTEN 0 136579 1/init udp 0 0 0.0.0.0:56190 0.0.0.0:* 103 17893 594/avahi-daemon: r udp 0 0 0.0.0.0:111 0.0.0.0:* 0 137387 1/init udp 0 0 0.0.0.0:631 0.0.0.0:* 0 23634 907/cups-browsed udp 0 0 0.0.0.0:50001 0.0.0.0:* 0 146842 28229/anydesk udp 0 0 0.0.0.0:5353 0.0.0.0:* 103 17891 594/avahi-daemon: r udp6 0 0 :::111 :::* 0 136581 1/init udp6 0 0 :::52127 :::* 103 17894 594/avahi-daemon: r udp6 0 0 :::5353 :::* 103 17892 594/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-09-15 15:18:57.566 - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call) 2023-09-15 15:19:42.074 - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:69843) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_18_57_748Z-debug-0.log 2023-09-15 15:19:42.074 - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1 2023-09-15 15:19:43.092 - info: host.iobrokerNUC iobroker exit 25 2023-09-15 15:23:58.531 - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC 2023-09-15 15:23:59.537 - info: host.iobrokerNUC iobroker NPM version: 9.6.7 2023-09-15 15:23:59.537 - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call) 2023-09-15 15:24:04.010 - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:70887) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_23_59_740Z-debug-0.log 2023-09-15 15:24:04.011 - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1 2023-09-15 15:24:05.036 - info: host.iobrokerNUC iobroker exit 25 2023-09-15 15:34:53.572 - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC 2023-09-15 15:34:54.600 - info: host.iobrokerNUC iobroker NPM version: 9.6.7 2023-09-15 15:34:54.601 - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call) 2023-09-15 15:35:04.442 - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:73159) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log 2023-09-15 15:35:04.443 - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1 2023-09-15 15:35:05.468 - info: host.iobrokerNUC iobroker exit 25 2023-09-15 16:34:59.946 - info: admin.0 (43667) ==> Connected system.user.admin from ::ffff:192.168.178.105 2023-09-15 16:35:01.497 - info: host.iobrokerNUC Updating repository "stable" under "http://download.iobroker.net/sources-dist.json" 2023-09-15 16:39:44.533 - info: admin.0 (43667) <== Disconnect system.user.admin from ::ffff:192.168.178.105 2023-09-15 16:39:53.534 - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC 2023-09-15 16:39:54.568 - info: host.iobrokerNUC iobroker NPM version: 9.6.7 2023-09-15 16:39:54.569 - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call) 2023-09-15 16:40:03.838 - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:85655) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T14_39_54_749Z-debug-0.log 2023-09-15 16:40:03.838 - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1 2023-09-15 16:40:04.857 - info: host.iobrokerNUC iobroker exit 25======================= SUMMARY ======================= v.2023-06-20 Static hostname: iobrokerNUC Icon name: computer-desktop Chassis: desktop 🖥️ Machine ID: 5d7cb8cbe58a4a17a905354431cfbb8d Boot ID: 200f822a21c448e884941fd698e54ca1 Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-12-amd64 Architecture: x86-64 Hardware Vendor: Default string Hardware Model: Default string Firmware Version: 5.27 Installation: native Kernel: x86_64 Userland: amd64 Timezone: Europe/Berlin (CEST, +0200) User-ID: 0 X-Server: true Boot Target: graphical.target Pending OS-Updates: 0@sirdrinsalot sagte in Homekit-controller lässt sich nicht installieren:
User-ID: 0
X-Server: true
Boot Target: graphical.targetRoot und Desktop...
'nuff seen.
Schalt den Krampf aus und agier da als Standard-User. -
Statt spoiler die codetags verwenden.
@thomas-braun sagte in Homekit-controller lässt sich nicht installieren:
habs gefixt
der Installationsfixer: curl -fsL https://iobroker.net/fix.sh | bash - -
habs gefixt
@homoran sagte in Homekit-controller lässt sich nicht installieren:
habs gefixt
Den Desktop und den root? Respekt!
habs gefixt
habs gefixt
Natürlich!
ist jetzt forbidden!kein Support per PN! - Fragen im Forum stellen - Benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.
Mein Standarduser hat keine Rootrechte, hat mich nur im Nachhinein als root angemeldet für Reparaturversuche.
Ohne root hats eben auch nicht funktioniert. -
habs gefixt
Natürlich!
ist jetzt forbidden!@homoran sagte in Homekit-controller lässt sich nicht installieren:
Ja, das ohnehin. AnyDesk ist auch verboten.
Ohne root hats eben auch nicht funktioniert.@sirdrinsalot und root verbiegt noch die letzten Rechte vom user iobroker
dann nimm jetzt den root und gib deinem user roottechte.
melde dich dann als user an und machiob stop iob fix iob startkein Support per PN! - Fragen im Forum stellen - Benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.
Ohne root hats eben auch nicht funktioniert.@sirdrinsalot sagte in Homekit-controller lässt sich nicht installieren:
Richtig, der sollte aber per sudo in die root-Rolle wechseln können. Man meldet sich niemals als root an. Schon gar nicht auf einem Desktop.
Auf dem raspberry hat alles immer genauso funktioniert, deswegen dacht ich das es so auch geht.
Wie schaltet man den ab? -
Wie schaltet man den ab?sudo systemctl set-default multi-user.target sudo systemctl isolate multi-user.target -
ich glaub ich schieb das mal ins offtopic.
Probleme mit der Homekit controller Installation ist mit Sicherheit kein Bug von ioBroker!kein Support per PN! - Fragen im Forum stellen - Benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.
Danke erstmal für die schnelle Hilfe, kann es erst morgen weiter testen.
Bin halt leider ein kompletter linux DAU. Wenn man die Zeit hätte sich mehr damit zu beschäftigen.Naja, vielen Dank erstmal.
Moin
Habe jetzt nochmal alles platt gemacht und wieder iobroker auf Windows installiert.
Kam der selbe Fehler. Habe dann die python pfade angepasst und Visual Studio 2017 installiert statt 22, mit dem funktionierte es nicht und jetzt läuft alles.Danke nochmals.
Moin
@sirdrinsalot kannst du genau beschreiben, was du gemacht hast, damit das klappt?
Bei mir kommt auch Error 25 unter Windows mit:
Installing iobroker.homekit-controller@0.5.9... (System call)
npm ERR! code 1npm ERR! path C:\ioBroker\node_modules@abandonware\noblenpm ERR! command failednpm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node-gyp-buildnpm ERR!
usw.
Den Noble Ordner gibt es nicht in @abandonware
@SirDrinsAlot ich habe ähnliche Probleme unter Windows.
wie hast du es letztendlich doch zum laufen bekommen?Grüße
Basti -
Moin
@sirdrinsalot Ich habe leider ebenfalls das Problem unter Windows und wäre für hilfreiche Tipps sehr dankbar! Visual Studio 2017 habe ich auch installiert. Wie passt man die Python Pfade entsprechend an?
Dank Dir schon vorab!
