  3. Off Topic
  4. Homekit-controller lässt sich nicht installieren
    6.0k
28 Beiträge 7 Kommentatoren 3.2k Aufrufe 7 Beobachtet
  • S SirDrinsAlot
    Wenn ich wüsste was das wäre... Linux ist nicht mein Gebiet.
    @sirdrinsalot
    Lass mal sehen wie du da womit unterwegs bist.
    iob diag
    Langfassung.
      SirDrinsAlot
      Ohje, is ne Menge.
       *** BASE SYSTEM ***
       Static hostname: iobrokerNUC
             Icon name: computer-desktop
               Chassis: desktop 🖥️
            Machine ID: 5d7cb8cbe58a4a17a905354431cfbb8d
               Boot ID: 200f822a21c448e884941fd698e54ca1
                Kernel: Linux 6.1.0-12-amd64
          Architecture: x86-64
       Hardware Vendor: Default string
        Hardware Model: Default string
      Firmware Version: 5.27
      model name      : Intel(R) N95
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       16:48:21 up  3:32,  3 users,  load average: 0.43, 0.35, 0.26
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Fri 2023-09-15 16:48:21 CEST
                 Universal time: Fri 2023-09-15 14:48:21 UTC
                       RTC time: Fri 2023-09-15 14:48:21
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             16G        5.5G        4.6G        210M        7.0G         11G
      Swap:           1.0G          0B        1.0G
      Total:           17G        5.5G        5.6G
              15767 M total memory
               5258 M used memory
               1133 M active memory
               9391 M inactive memory
               4349 M free memory
                242 M buffer memory
               6451 M swap cache
                975 M total swap
                  0 M used swap
                975 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  7.7G     0  7.7G   0% /dev
      tmpfs          tmpfs     1.6G  1.5M  1.6G   1% /run
      /dev/sda2      ext4      467G  9.8G  434G   3% /
      tmpfs          tmpfs     7.7G  792K  7.7G   1% /dev/shm
      tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
      /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
      tmpfs          tmpfs     1.6G  3.7M  1.6G   1% /run/user/1000
      [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET               SOURCE    FSTYPE      OPTIONS
      /                    /dev/sda2 ext4        rw,relatime,errors=remount-ro
      |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot/efi          /dev/sda1 vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      /var:
      503M    /var/
      231M    /var/cache
      221M    /var/cache/apt
      216M    /var/lib
      145M    /var/cache/apt/archives
      Archived and active journals take up 32.0M in the file system.
      /opt/iobroker/backups:
      71M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      784M    /opt/iobroker/iobroker-data/
      698M    /opt/iobroker/iobroker-data/files
      119M    /opt/iobroker/iobroker-data/files/vis-2
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      71M     /opt/iobroker/iobroker-data/files/vis-2/static
      73M     /opt/iobroker/iobroker-data/objects.jsonl
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.67295ba8.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.10.1
      javascript:     7.1.4
      Adapters from github:   5
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobrokerNUC                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.admin.1                  : admin                 : iobrokerNUC                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : iobrokerNUC                              - disabled
      + system.adapter.backitup.0               : backitup              : iobrokerNUC                              -  enabled
        system.adapter.ble.0                    : ble                   : iobrokerNUC                              - disabled
        system.adapter.broadlink2.0             : broadlink2            : iobrokerNUC                              - disabled
        system.adapter.cameras.0                : cameras               : iobrokerNUC                              - disabled, port: 8200, bind: 0.0.0.0
        system.adapter.chromecast.0             : chromecast            : iobrokerNUC                              - disabled
        system.adapter.cloud.0                  : cloud                 : iobrokerNUC                              - disabled
        system.adapter.daswetter.0              : daswetter             : iobrokerNUC                              - disabled
        system.adapter.devices.0                : devices               : iobrokerNUC                              - disabled
        system.adapter.discovery.0              : discovery             : iobrokerNUC                              - disabled
        system.adapter.ecovacs-deebot.2         : ecovacs-deebot        : iobrokerNUC                              - disabled
        system.adapter.ecovacs-deebot.3         : ecovacs-deebot        : iobrokerNUC                              - disabled
        system.adapter.ecovacs-deebot.4         : ecovacs-deebot        : iobrokerNUC                              - disabled
        system.adapter.energiefluss.0           : energiefluss          : iobrokerNUC                              - disabled
        system.adapter.eusec.0                  : eusec                 : iobrokerNUC                              - disabled
        system.adapter.feiertage.0              : feiertage             : iobrokerNUC                              - disabled
        system.adapter.flot.0                   : flot                  : iobrokerNUC                              - disabled
        system.adapter.fritzbox.0               : fritzbox              : iobrokerNUC                              - disabled
        system.adapter.fritzdect.0              : fritzdect             : iobrokerNUC                              - disabled
        system.adapter.fullcalendar.0           : fullcalendar          : iobrokerNUC                              - disabled
        system.adapter.fullybrowser.0           : fullybrowser          : iobrokerNUC                              - disabled
        system.adapter.govee-app.0              : govee-app             : iobrokerNUC                              - disabled
        system.adapter.habpanel.0               : habpanel              : iobrokerNUC                              - disabled
        system.adapter.history.0                : history               : iobrokerNUC                              - disabled
        system.adapter.hm-rega.0                : hm-rega               : iobrokerNUC                              - disabled
        system.adapter.hm-rpc.0                 : hm-rpc                : iobrokerNUC                              - disabled, port: 0
        system.adapter.hm-rpc.1                 : hm-rpc                : iobrokerNUC                              - disabled, port: 0
        system.adapter.homeconnect.0            : homeconnect           : iobrokerNUC                              - disabled
        system.adapter.homekit-controller.0     : homekit-controller    : iobrokerNUC                              - disabled
        system.adapter.homepilot20.0            : homepilot20           : iobrokerNUC                              - disabled
        system.adapter.hue-extended.0           : hue-extended          : iobrokerNUC                              - disabled
        system.adapter.hue.0                    : hue                   : iobrokerNUC                              - disabled, port: 443
        system.adapter.ical.0                   : ical                  : iobrokerNUC                              - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobrokerNUC                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobrokerNUC                              - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobrokerNUC                              - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobrokerNUC                              - disabled
        system.adapter.influxdb.0               : influxdb              : iobrokerNUC                              - disabled, port: 8090
        system.adapter.info.0                   : info                  : iobrokerNUC                              - disabled
        system.adapter.iot.0                    : iot                   : iobrokerNUC                              - disabled
        system.adapter.javascript.0             : javascript            : iobrokerNUC                              - disabled
        system.adapter.linux-control.0          : linux-control         : iobrokerNUC                              - disabled
        system.adapter.material.0               : material              : iobrokerNUC                              - disabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobrokerNUC                              - disabled, port: 54321
        system.adapter.mihome.0                 : mihome                : iobrokerNUC                              - disabled, port: 9898, bind: 0.0.0.0
        system.adapter.mobile.0                 : mobile                : iobrokerNUC                              - disabled
        system.adapter.mqtt.0                   : mqtt                  : iobrokerNUC                              - disabled, port: 1888, bind: 0.0.0.0
        system.adapter.musiccast.0              : musiccast             : iobrokerNUC                              - disabled
        system.adapter.net-tools.0              : net-tools             : iobrokerNUC                              - disabled
        system.adapter.netatmo.0                : netatmo               : iobrokerNUC                              - disabled
        system.adapter.netatmo.1                : netatmo               : iobrokerNUC                              - disabled
        system.adapter.node-red.0               : node-red              : iobrokerNUC                              - disabled, port: 1880, bind: 192.168.178.143
        system.adapter.radar2.0                 : radar2                : iobrokerNUC                              - disabled
        system.adapter.sayit.0                  : sayit                 : iobrokerNUC                              - disabled
        system.adapter.scenes.0                 : scenes                : iobrokerNUC                              - disabled
        system.adapter.shelly.0                 : shelly                : iobrokerNUC                              - disabled, port: 1886, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : iobrokerNUC                              - disabled, port: 8087, bind: 192.168.178.143, run as: admin
        system.adapter.slideshow.0              : slideshow             : iobrokerNUC                              - disabled
        system.adapter.smartthings.0            : smartthings           : iobrokerNUC                              - disabled
        system.adapter.socketio.0               : socketio              : iobrokerNUC                              - disabled, port: 8085, bind: 0.0.0.0, run as: admin
        system.adapter.sonoff.0                 : sonoff                : iobrokerNUC                              - disabled, port: 1883, bind: 192.168.178.143
        system.adapter.sourceanalytix.0         : sourceanalytix        : iobrokerNUC                              - disabled
        system.adapter.synology.0               : synology              : iobrokerNUC                              - disabled, port: 5000
        system.adapter.telegram.0               : telegram              : iobrokerNUC                              - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.terminal.0               : terminal              : iobrokerNUC                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
        system.adapter.text2command.0           : text2command          : iobrokerNUC                              - disabled
        system.adapter.tileboard.0              : tileboard             : iobrokerNUC                              - disabled
        system.adapter.tr-064.0                 : tr-064                : iobrokerNUC                              - disabled
        system.adapter.tuya.0                   : tuya                  : iobrokerNUC                              - disabled
        system.adapter.vis-2.0                  : vis-2                 : iobrokerNUC                              - disabled
        system.adapter.vis-bars.0               : vis-bars              : iobrokerNUC                              - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobrokerNUC                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokerNUC                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobrokerNUC                              - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobrokerNUC                              - disabled
        system.adapter.vis-history.0            : vis-history           : iobrokerNUC                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobrokerNUC                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobrokerNUC                              - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokerNUC                              - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokerNUC                              - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobrokerNUC                              - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobrokerNUC                              - disabled
        system.adapter.vis-lcars.0              : vis-lcars             : iobrokerNUC                              - disabled
        system.adapter.vis-map.0                : vis-map               : iobrokerNUC                              - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobrokerNUC                              - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokerNUC                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobrokerNUC                              - disabled
        system.adapter.vis-players.0            : vis-players           : iobrokerNUC                              - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobrokerNUC                              - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobrokerNUC                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokerNUC                              - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobrokerNUC                              - disabled
        system.adapter.vis.0                    : vis                   : iobrokerNUC                              - disabled
        system.adapter.web.0                    : web                   : iobrokerNUC                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobrokerNUC                              - disabled
        system.adapter.wifilight.0              : wifilight             : iobrokerNUC                              - disabled
        system.adapter.yeelight-2.0             : yeelight-2            : iobrokerNUC                              - disabled
        system.adapter.yr.0                     : yr                    : iobrokerNUC                              - disabled
        system.adapter.zigbee.0                 : zigbee                : iobrokerNUC                              - disabled, port: /dev/ttyUSB0
        system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobrokerNUC                              - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.8.0    , installed 6.10.1
      Adapter    "alexa2"       : 3.24.1   , installed 3.25.2
      Adapter    "backitup"     : 2.6.23   , installed 2.8.1
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "discovery"    : 3.1.0    , installed 4.0.0
      Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
      Adapter    "eusec"        : 1.1.2    , installed 1.1.2
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.4
      Adapter    "fritzbox"     : 0.2.1    , installed 0.5.0
      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
      Adapter    "fullcalendar" : 1.2.0    , installed 2.2.6
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "hm-rega"      : 3.0.47   , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
      Adapter    "hue"          : 3.9.5    , installed 3.10.0
      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "info"         : 1.9.26   , installed 2.0.0
      Adapter    "iot"          : 1.14.5   , installed 2.0.11
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mihome-vacuum": 3.11.0   , installed 4.0.0
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "musiccast"    : 1.1.0    , installed 1.1.0
      Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "radar2"       : 2.0.7    , installed 2.0.7
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
      Adapter    "socketio"     : 6.5.5    , installed 6.5.3  [Updatable]
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
      Adapter    "synology"     : 2.1.13   , installed 3.0.0
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.4
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.2    , installed 6.1.1  [Updatable]
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "ws"           : 2.5.5    , installed 2.5.3  [Updatable]
      Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.24
      Adapter    "zigbee2mqtt"  : 2.13.1   , installed 2.13.1
      Objects and States
      Objects:        37997
      States:         31034
      W: http://deb.anydesk.com/dists/all/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      Hit:1 https://deb.nodesource.com/node_18.x bookworm InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:4 http://deb.anydesk.com all InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:37838           0.0.0.0:*               LISTEN      0          188418     28229/anydesk
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          21612      662/cupsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       212660     43636/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       211792     43636/iobroker.js-c
      tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          145110     28229/anydesk
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          166031     33594/sshd: /usr/sb
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          135901     1/init
      tcp        0      0 127.0.0.1:4101          0.0.0.0:*               LISTEN      0          21672      544/brltty
      tcp6       0      0 ::1:4101                :::*                    LISTEN      0          17962      544/brltty
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       211857     43667/io.admin.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          21611      662/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          166033     33594/sshd: /usr/sb
      tcp6       0      0 :::111                  :::*                    LISTEN      0          136579     1/init
      udp        0      0 0.0.0.0:56190           0.0.0.0:*                           103        17893      594/avahi-daemon: r
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          137387     1/init
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23634      907/cups-browsed
      udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          146842     28229/anydesk
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           103        17891      594/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          136581     1/init
      udp6       0      0 :::52127                :::*                                103        17894      594/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                103        17892      594/avahi-daemon: r
      2023-09-15 15:18:57.566  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
      2023-09-15 15:19:42.074  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:69843) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_18_57_748Z-debug-0.log
      2023-09-15 15:19:42.074  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
      2023-09-15 15:19:43.092  - info: host.iobrokerNUC iobroker exit 25
      2023-09-15 15:23:58.531  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
      2023-09-15 15:23:59.537  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
      2023-09-15 15:23:59.537  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
      2023-09-15 15:24:04.010  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:70887) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_23_59_740Z-debug-0.log
      2023-09-15 15:24:04.011  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
      2023-09-15 15:24:05.036  - info: host.iobrokerNUC iobroker exit 25
      2023-09-15 15:34:53.572  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
      2023-09-15 15:34:54.600  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
      2023-09-15 15:34:54.601  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
      2023-09-15 15:35:04.442  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:73159) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log
      2023-09-15 15:35:04.443  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
      2023-09-15 15:35:05.468  - info: host.iobrokerNUC iobroker exit 25
      2023-09-15 16:34:59.946  - info: admin.0 (43667) ==> Connected system.user.admin from ::ffff:192.168.178.105
      2023-09-15 16:35:01.497  - info: host.iobrokerNUC Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2023-09-15 16:39:44.533  - info: admin.0 (43667) <== Disconnect system.user.admin from ::ffff:192.168.178.105
      2023-09-15 16:39:53.534  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
      2023-09-15 16:39:54.568  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
      2023-09-15 16:39:54.569  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
      2023-09-15 16:40:03.838  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:85655) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T14_39_54_749Z-debug-0.log
      2023-09-15 16:40:03.838  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
      2023-09-15 16:40:04.857  - info: host.iobrokerNUC iobroker exit 25
                           v.2023-06-20
               Chassis: desktop 🖥️
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                0
      X-Server:               true
      Pending OS-Updates:     0
      • S SirDrinsAlot
        Ohje, is ne Menge.
         *** BASE SYSTEM ***
                 Chassis: desktop 🖥️
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        root
        /root
        root
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           1.0G          0B        1.0G
                 5258 M used memory
                 4349 M free memory
                  242 M buffer memory
                 6451 M swap cache
                  975 M total swap
                    0 M used swap
                  975 M free swap
        *** FILESYSTEM ***
        /var:
        503M    /var/
        231M    /var/cache
        221M    /var/cache/apt
        216M    /var/lib
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.10.1
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        37997
        States:         31034
        Pending Updates: 0
                             v.2023-06-20
                 Chassis: desktop 🖥️
        Kernel:                 x86_64
        Userland:               amd64
        User-ID:                0
        X-Server:               true
        @sirdrinsalot
        Statt spoiler die codetags verwenden.
          SirDrinsAlot
          HAt nicht funktioniert, kam Forbidden, sry.
          • S SirDrinsAlot
            Ohje, is ne Menge.
             *** BASE SYSTEM ***
                     Chassis: desktop 🖥️
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 4
                          NTP service: active
                      RTC in local TZ: no
            root
            /root
            root
            X-Server:       true
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           1.0G          0B        1.0G
                     5258 M used memory
                     4349 M free memory
                      242 M buffer memory
                     6451 M swap cache
                      975 M total swap
                        0 M used swap
                      975 M free swap
            *** FILESYSTEM ***
            /var:
            503M    /var/
            231M    /var/cache
            221M    /var/cache/apt
            216M    /var/lib
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Version table:
                 18.13.0+dfsg1-1 500
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.10.1
            javascript:     7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        37997
            States:         31034
            Pending Updates: 0
                                 v.2023-06-20
                     Chassis: desktop 🖥️
            Kernel:                 x86_64
            Userland:               amd64
            User-ID:                0
            X-Server:               true
            @sirdrinsalot sagte in Homekit-controller lässt sich nicht installieren:
            User-ID: 0
            X-Server: true
            Boot Target: graphical.target
            Root und Desktop...
            'nuff seen.
            Schalt den Krampf aus und agier da als Standard-User.
              @sirdrinsalot
              @thomas-braun sagte in Homekit-controller lässt sich nicht installieren:
              @sirdrinsalot
              habs gefixt
                @sirdrinsalot
                habs gefixt
                @homoran sagte in Homekit-controller lässt sich nicht installieren:
                habs gefixt
                Den Desktop und den root? Respekt!
                  habs gefixt
                  habs gefixt
                  Natürlich!
                  ist jetzt forbidden!
                    SirDrinsAlot
                    Mein Standarduser hat keine Rootrechte, hat mich nur im Nachhinein als root angemeldet für Reparaturversuche.
                    Ohne root hats eben auch nicht funktioniert.
                      habs gefixt
                      Natürlich!
                      Ja, das ohnehin. AnyDesk ist auch verboten.
                      • S SirDrinsAlot
                        @sirdrinsalot und root verbiegt noch die letzten Rechte vom user iobroker
                        dann nimm jetzt den root und gib deinem user roottechte.
                        melde dich dann als user an und mach
                        iob stop
                        iob fix
                        iob start
                        • S SirDrinsAlot
                          Richtig, der sollte aber per sudo in die root-Rolle wechseln können. Man meldet sich niemals als root an. Schon gar nicht auf einem Desktop.
                            SirDrinsAlot
                            Auf dem raspberry hat alles immer genauso funktioniert, deswegen dacht ich das es so auch geht.
                            Wie schaltet man den ab?
                            • S SirDrinsAlot
                              @sirdrinsalot
                              sudo systemctl set-default multi-user.target
                              sudo systemctl isolate multi-user.target
                                ich glaub ich schieb das mal ins offtopic.
                                Probleme mit der Homekit controller Installation ist mit Sicherheit kein Bug von ioBroker!
                                  SirDrinsAlot
                                  Danke erstmal für die schnelle Hilfe, kann es erst morgen weiter testen.
                                  Bin halt leider ein kompletter linux DAU. Wenn man die Zeit hätte sich mehr damit zu beschäftigen.
                                  Naja, vielen Dank erstmal.
                                    SirDrinsAlot
                                    Moin
                                    Habe jetzt nochmal alles platt gemacht und wieder iobroker auf Windows installiert.
                                    Kam der selbe Fehler. Habe dann die python pfade angepasst und Visual Studio 2017 installiert statt 22, mit dem funktionierte es nicht und jetzt läuft alles.
                                    Danke nochmals.
                                    D H 2 Antworten Letzte Antwort
                                    • S SirDrinsAlot
                                      Moin
                                      Danke nochmals.
                                      drdolittle
                                      @sirdrinsalot kannst du genau beschreiben, was du gemacht hast, damit das klappt?
                                      Bei mir kommt auch Error 25 unter Windows mit:
                                      Installing iobroker.homekit-controller@0.5.9... (System call)
                                      npm ERR! code 1npm ERR! path C:\ioBroker\node_modules@abandonware\noblenpm ERR! command failednpm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node-gyp-buildnpm ERR!
                                      usw.
                                      Den Noble Ordner gibt es nicht in @abandonware
                                        BastiBerlin
                                        @SirDrinsAlot ich habe ähnliche Probleme unter Windows.
                                        wie hast du es letztendlich doch zum laufen bekommen?
                                        Basti
                                        • S SirDrinsAlot
                                          Moin
                                          Danke nochmals.
                                          hendrikmj
                                          @sirdrinsalot Ich habe leider ebenfalls das Problem unter Windows und wäre für hilfreiche Tipps sehr dankbar! Visual Studio 2017 habe ich auch installiert. Wie passt man die Python Pfade entsprechend an?
                                          Dank Dir schon vorab!
