  4. Vis Adapter nach Backup mit Fehlermeldung
    1.0k
    6.1k
24 Beiträge 4 Kommentatoren 3.3k Aufrufe 3 Beobachtet
  • J Jacke
    Hatte das schon eingegeben
    nils@IoBroker:~$ iobroker install iobroker.vis --debug
    NPM version: 9.6.7
    Installing iobroker.vis@1.1.1... (System call)
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/iobroker.vis
    npm ERR! command failed
    npm ERR! command sh -c node main.js --install
    npm ERR! node:internal/modules/cjs/loader:1080
    npm ERR!   throw err;
    npm ERR!   ^
    npm ERR!
    npm ERR! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
    npm ERR! Require stack:
    npm ERR! - /opt/iobroker/node_modules/iobroker.vis/lib/utils.js
    npm ERR! - /opt/iobroker/node_modules/iobroker.vis/main.js
    npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
    npm ERR!     at Module._load (node:internal/modules/cjs/loader:922:27)
    npm ERR!     at Module.require (node:internal/modules/cjs/loader:1143:19)
    npm ERR!     at require (node:internal/modules/cjs/helpers:121:18)
    npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.vis/lib/utils.js:63:25)
    npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    npm ERR!     at Module.load (node:internal/modules/cjs/loader:1119:32)
    npm ERR!     at Module._load (node:internal/modules/cjs/loader:960:12)
    npm ERR!     at Module.require (node:internal/modules/cjs/loader:1143:19) {
    npm ERR!   code: 'MODULE_NOT_FOUND',
    npm ERR!   requireStack: [
    npm ERR!     '/opt/iobroker/node_modules/iobroker.vis/lib/utils.js',
    npm ERR!     '/opt/iobroker/node_modules/iobroker.vis/main.js'
    npm ERR!   ]
    npm ERR! }
    npm ERR!
    npm ERR! Node.js v18.17.1
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-12T13_28_36_864Z-debug-0.log
    npm ERR! code 1
    npm ERR!   throw err;
    npm ERR!   ^
    npm ERR!
    npm ERR!   ]
    npm ERR! }
    npm ERR!
    host.IoBroker Cannot install iobroker.vis@1.1.1: 1
    @jacke wenn dann iob upgrade vis@1.4.10 --debug
      @jacke
      iob diag
      in der Langfassung bitte.
      Jacke
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : lxc
      Distributor ID: Ubuntu
      Description:    Ubuntu 23.04
      Release:        23.04
      Codename:       lunar
      PRETTY_NAME="Ubuntu 23.04"
      NAME="Ubuntu"
      VERSION_ID="23.04"
      VERSION="23.04 (Lunar Lobster)"
      VERSION_CODENAME=lunar
      ID=ubuntu
      ID_LIKE=debian
      HOME_URL="https://www.ubuntu.com/"
      SUPPORT_URL="https://help.ubuntu.com/"
      BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
      PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
      UBUNTU_CODENAME=lunar
      LOGO=ubuntu-logo
      Systemuptime and Load:
       15:33:27 up  1:46,  2 users,  load average: 0.99, 1.09, 1.09
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Tue 2023-09-12 15:33:27 CEST
                 Universal time: Tue 2023-09-12 13:33:27 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      nils
      /home/nils
      nils sudo users iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.3G        3.4G        418M        143K        459M        878M
      Swap:             0B          0B          0B
      Total:          4.3G        3.4G        418M
               4096 M total memory
               3258 M used memory
                252 M active memory
               3143 M inactive memory
                399 M free memory
                  0 M buffer memory
                438 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      Filesystem                            Type   Size  Used Avail Use% Mounted on
      /dev/mapper/data_ssd-vm--100--disk--0 ext4    18G  4.7G   13G  28% /
      none                                  tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                                 tmpfs   12G     0   12G   0% /dev/shm
      tmpfs                                 tmpfs  4.7G  136K  4.7G   1% /run
      tmpfs                                 tmpfs  5.0M     0  5.0M   0% /run/lock
      tmpfs                                 tmpfs  2.4G     0  2.4G   0% /run/user/1000
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET SOURCE                                FSTYPE OPTIONS
      /      /dev/mapper/data_ssd-vm--100--disk--0 ext4   rw,relatime,stripe=16
      /var:
      504M    /var/
      246M    /var/cache
      240M    /var/cache/apt
      233M    /var/lib
      153M    /var/cache/apt/archives
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      102M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      756M    /opt/iobroker/iobroker-data/
      398M    /opt/iobroker/iobroker-data/files
      249M    /opt/iobroker/iobroker-data/esphome.0/.esphome
      248M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      31M     /opt/iobroker/iobroker-data/states.jsonl
      28M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/grillthermometer/.pioenvs/grillthermometer/firmware.elf
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.67295ba8.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x lunar/main amd64 Packages
           18.13.0+dfsg1-1ubuntu2 500
              500 http://archive.ubuntu.com/ubuntu lunar/universe amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.5.8
      javascript:     7.1.4
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
        system.adapter.awattar.0                : awattar               : IoBroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : IoBroker                                 -  enabled
        system.adapter.devices.0                : devices               : IoBroker                                 - disabled
        system.adapter.discovery.0              : discovery             : IoBroker                                 - disabled
      + system.adapter.energiefluss.0           : energiefluss          : IoBroker                                 -  enabled
        system.adapter.esphome.0                : esphome               : IoBroker                                 - disabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : IoBroker                                 - disabled
        system.adapter.flot.0                   : flot                  : IoBroker                                 - disabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : IoBroker                                 -  enabled
      + system.adapter.history.0                : history               : IoBroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: IoBroker                                 - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : IoBroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : IoBroker                                 - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : IoBroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoBroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IoBroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : IoBroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : IoBroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
      + system.adapter.melcloud.0               : melcloud              : IoBroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
      + system.adapter.modbus.1                 : modbus                : IoBroker                                 -  enabled
      + system.adapter.mqtt-client.0            : mqtt-client           : IoBroker                                 -  enabled, port: 1883
      + system.adapter.mqtt.1                   : mqtt                  : IoBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.2                   : mqtt                  : IoBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : IoBroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.ping.0                   : ping                  : IoBroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : IoBroker                                 -  enabled, port: 8006
      + system.adapter.pvforecast.0             : pvforecast            : IoBroker                                 -  enabled
      + system.adapter.pvforecast.1             : pvforecast            : IoBroker                                 -  enabled
      + system.adapter.ring.0                   : ring                  : IoBroker                                 -  enabled
      + system.adapter.s7.0                     : s7                    : IoBroker                                 -  enabled
        system.adapter.scenes.0                 : scenes                : IoBroker                                 - disabled
      + system.adapter.shelly.0                 : shelly                : IoBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.socketio.0               : socketio              : IoBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : IoBroker                                 -  enabled
      + system.adapter.sql.0                    : sql                   : IoBroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : IoBroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : IoBroker                                 - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : IoBroker                                 -  enabled
      + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.windows-control.0        : windows-control       : IoBroker                                 -  enabled
      + system.adapter.worx.0                   : worx                  : IoBroker                                 -  enabled
      + system.adapter.zigbee.1                 : zigbee                : IoBroker                                 -  enabled, port: tcp://192.168.1.145:5000
      + instance is alive
      ioBroker-Repositories
      default       : http://download.iobroker.net/sources-dist-latest.json
      latest        : http://download.iobroker.net/sources-dist.json
      Active repo(s): default, latest
      Installed ioBroker-Instances
      Used repositories: default, latest
      a Objects database error: read ECONNRESET
       States database error: connect ECONNREFUSED 0.0.0.0:9000
       Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      Adapter    "admin"        : 6.8.0    , installed 6.5.8  [Updatable]
      Adapter    "alexa2"       : 3.24.1   , installed 3.25.1
      Adapter    "awattar"      : 1.0.6    , installed 1.0.6
      Adapter    "backitup"     : 2.6.23   , installed 2.7.0
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "discovery"    : 3.1.0    , installed 4.0.0
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "info"         : 1.9.26   , installed 2.0.0
      Adapter    "iot"          : 1.14.5   , installed 2.0.11
      Adapter    "javascript"   : 7.0.3    , installed 7.1.4
      Controller "js-controller": 4.0.24   , installed 5.0.12
      Adapter    "melcloud"     : 1.3.5    , installed 1.3.5
      Adapter    "mihome-vacuum": 3.11.0   , installed 4.0.0
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.4
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "proxmox"      : 1.3.5    , installed 2.0.2
      Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
      Adapter    "ring"         : 3.2.2    , installed 3.4.1
      Adapter    "s7"           : 1.3.15   , installed 1.3.15
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "socketio"     : 6.5.3    , installed 6.5.3
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "weatherunderground": 3.4.2, installed 3.6.0
      Adapter    "web"          : 6.1.1    , installed 6.1.1
      Adapter    "windows-control": 0.1.5  , installed 0.1.5
      Adapter    "worx"         : 2.3.2    , installed 2.3.2
      Adapter    "ws"           : 2.5.4    , installed 2.5.3  [Updatable]
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.24
      Objects and States
      Objects:        21779
      States:         15752
      aHit:1 https://deb.nodesource.com/node_18.x lunar InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu lunar InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu lunar-updates InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu lunar-security InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        791290896  102/systemd-resolve
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          791292090  311/master
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       791957309  119661/iobroker.js-
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       791957316  119661/iobroker.js-
      tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        791290898  102/systemd-resolve
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          791289333  1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          791292091  311/master
      tcp6       0      0 :::111                  :::*                    LISTEN      0          791289335  1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          791289693  1/init
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        23.04
      Codename:       lunar
      NAME="Ubuntu"
      VERSION_ID="23.04"
      ID=ubuntu
      ID_LIKE=debian
      LOGO=ubuntu-logo
       15:35:36 up  1:48,  2 users,  load average: 8.31, 5.39, 2.77
      CPU threads: 2
                     Local time: Tue 2023-09-12 15:35:36 CEST
                 Universal time: Tue 2023-09-12 13:35:36 UTC
                       RTC time: n/a
                RTC in local TZ: no
      nils
      /home/nils
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.3G        2.2G        1.4G        143K        688M        2.1G
      Swap:             0B          0B          0B
      Total:          4.3G        2.2G        1.4G
               4096 M total memory
               2100 M used memory
                301 M active memory
               2368 M inactive memory
               1338 M free memory
                  0 M buffer memory
                656 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /dev/mapper/data_ssd-vm--100--disk--0 ext4    18G  4.7G   12G  29% /
      /var:
      504M    /var/
      246M    /var/cache
      240M    /var/cache/apt
      233M    /var/lib
      764M    /opt/iobroker/iobroker-data/
      36M     /opt/iobroker/iobroker-data/objects.jsonl
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.5.8
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        21785
      States:         15809
      Pending Updates: 0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       791965434  120858/node-red
      tcp6       0      0 :::8086                 :::*                    LISTEN      1001       791965010  120494/io.admin.0
      udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        791290897  102/systemd-resolve
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        791290895  102/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          791289334  1/init
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       791969211  121288/io.mihome-va
      udp6       0      0 :::111                  :::*                                0          791289336  1/init
      2023-09-12 15:36:08.673  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.symbol_desc2 with Bewölkt mit leichtem Regen
      2023-09-12 15:36:08.676  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.symbol_value2 with 6
      2023-09-12 15:36:08.710  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.symbol_desc with Bewölkt mit leichtem Regen
      2023-09-12 15:36:08.711  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.symbol_value with 6
      2023-09-12 15:36:08.716  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.iconURL with /adapter/daswetter/icons/tiempo-weather/galeria1/6.png
      2023-09-12 15:36:08.772  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.wind_symbolB with 40
      2023-09-12 15:36:08.798  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.wind_symbol with 16
      2023-09-12 15:36:08.800  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.wind_dir with NW
      2023-09-12 15:36:08.804  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.wind_value with 5 km/h
      2023-09-12 15:36:08.967  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.windIconURL with /adapter/daswetter/icons/viento-wind/undefined/40.png
      2023-09-12 15:36:09.046  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.windgusts_value with 26 km/h
      2023-09-12 15:36:09.122  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.rain_value with 0.4 mm
      2023-09-12 15:36:09.125  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.humidity_value with 97
      2023-09-12 15:36:09.127  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.pressure_value with 1013 mb
      2023-09-12 15:36:09.146  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.clouds_value with 58%
      2023-09-12 15:36:09.263  - warn: modbus.1 (121314) Poll error count: 1 code: {"errorCode":131,"exceptionCode":10,"message":"GATEWAY PATH UNAVAILABLE"}
      2023-09-12 15:36:09.281  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.snowline_value with 3600 m
      2023-09-12 15:36:09.301  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.uv_index_value with 0
      2023-09-12 15:36:09.303  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.windchill_value with 17 °C
      2023-09-12 15:36:09.307  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9 with null  {"type":"channel","common":{"name":"Hour 9","role":"weather"}}
      2023-09-12 15:36:09.407  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.current with null  {"type":"channel","common":{"name":"current ","role":"weather"}}
      2023-09-12 15:36:09.429  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9.hour_value with 09:00
      2023-09-12 15:36:09.527  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9.temp_value with 18 °C
      2023-09-12 15:36:09.544  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9.symbol_desc2 with Bewölkt
      2023-09-12 15:36:09.569  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9.symbol_value2 with 3
      iob diag has finished.
      Press any key for a summary
        Jacke
        @homoran said in Vis Adapter nach Backup mit Fehlermeldung:
        nils@IoBroker:~$ iob upgrade vis@1.4.10 --debug
        Adapter "vis"            is not installed.
        kommt dann
        • J Jacke
          kommt dann
          @jacke dann iob install vis@1.4.10 --debug
          • J Jacke
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Docker          : false
            Release:        23.04
            Codename:       lunar
            NAME="Ubuntu"
            VERSION_ID="23.04"
            ID=ubuntu
            ID_LIKE=debian
            LOGO=ubuntu-logo
            CPU threads: 2
                             RTC time: n/a
                      RTC in local TZ: no
            nils
            /home/nils
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:             0B          0B          0B
                     4096 M total memory
                     3258 M used memory
                      252 M active memory
                      399 M free memory
                        0 M buffer memory
                      438 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            *** FILESYSTEM ***
            /var:
            504M    /var/
            246M    /var/cache
            240M    /var/cache/apt
            233M    /var/lib
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.5.8
            javascript:     7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        21779
            States:         15752
            Pending Updates: 0
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Docker          : false
            Release:        23.04
            Codename:       lunar
            NAME="Ubuntu"
            VERSION_ID="23.04"
            ID=ubuntu
            ID_LIKE=debian
            LOGO=ubuntu-logo
            CPU threads: 2
                             RTC time: n/a
                      RTC in local TZ: no
            nils
            /home/nils
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:             0B          0B          0B
                     4096 M total memory
                     2100 M used memory
                      301 M active memory
                     1338 M free memory
                        0 M buffer memory
                      656 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            *** FILESYSTEM ***
            /var:
            504M    /var/
            246M    /var/cache
            240M    /var/cache/apt
            233M    /var/lib
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.5.8
            javascript:     7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        21785
            States:         15809
            Pending Updates: 0
            @jacke sagte in Vis Adapter nach Backup mit Fehlermeldung:
            Ubuntu 23.04
            Ich hätte ja die LTS-Version genommen. Diese Interims-Releases bei ubuntu leben nur 9 Monate. Oder halt gleich das 'Original'-Debian in aktueller Fassung.
            Swap: 0B 0B 0B
            Swap auch nicht vollständig deaktivieren. Das wird u. U. benötigt.
            Setz den 'nils' in die Gruppe 'adm'.
            Entweder/Oder. Beide Repos pallel aktiv sorgt ggf. für Trouble.
            debug: daswetter.0
            Setze Instanzen nur auf debug, wenn du das auch tust. Ansonsten ballert es dir nur das LogFile zu.
              Jacke
              dann kommt wieder diese fehlermeldung
              NPM version: 9.6.7
              Installing iobroker.vis@1.4.10... (System call)
              npm ERR! code 6
              npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-12T13_53_10_553Z-debug-0.log
              npm ERR! code 6
              host.IoBroker Cannot install iobroker.vis@1.4.10: 6
              • J Jacke
                NPM version: 9.6.7
                npm ERR! code 6
                npm ERR! code 6
                Was steht da drin?
                • J Offline
                  Jacke
                  0 verbose cli /usr/bin/node /usr/bin/npm
                  1 info using npm@9.6.7
                  2 info using node@v18.17.1
                  3 timing npm:load:whichnode Completed in 1ms
                  4 timing config:load:defaults Completed in 1ms
                  5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 0ms
                  6 timing config:load:builtin Completed in 1ms
                  7 timing config:load:cli Completed in 1ms
                  8 timing config:load:env Completed in 0ms
                  9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
                  10 timing config:load:project Completed in 2ms
                  11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                  12 timing config:load:user Completed in 0ms
                  13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                  14 timing config:load:global Completed in 0ms
                  15 timing config:load:setEnvs Completed in 1ms
                  16 timing config:load Completed in 7ms
                  17 timing npm:load:configload Completed in 7ms
                  18 timing npm:load:mkdirpcache Completed in 1ms
                  19 timing npm:load:mkdirplogs Completed in 0ms
                  20 verbose title npm install iobroker.vis@1.4.10
                  21 verbose argv "install" "--save-exact" "iobroker.vis@1.4.10"
                  22 timing npm:load:setTitle Completed in 1ms
                  23 timing config:load:flatten Completed in 2ms
                  24 timing npm:load:display Completed in 3ms
                  25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-09-12T13_53_10_553Z-
                  26 verbose logfile /home/iobroker/.npm/_logs/2023-09-12T13_53_10_553Z-debug-0.log
                  27 timing npm:load:logFile Completed in 7ms
                  28 timing npm:load:timers Completed in 0ms
                  29 timing npm:load:configScope Completed in 0ms
                  30 timing npm:load Completed in 20ms
                  31 timing arborist:ctor Completed in 1ms
                  32 silly logfile start cleaning logs, removing 5 files
                  33 timing idealTree:init Completed in 985ms
                  34 timing idealTree:userRequests Completed in 8ms
                  35 silly idealTree buildDeps
                  36 silly fetch manifest iobroker.vis@1.4.10
                  37 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                  38 silly logfile done cleaning log files
                  39 http fetch GET 200 https://registry.npmjs.org/iobroker.vis 1057ms (cache revalidated)
                  40 silly placeDep ROOT iobroker.vis@1.4.10 OK for: iobroker.inst@3.0.0 want: 1.4.10
                  41 silly fetch manifest jsonwebtoken@^8.5.1
                  42 silly fetch manifest axios@^0.24.0
                  43 http fetch GET 200 https://registry.npmjs.org/jsonwebtoken 59ms (cache revalidated)
                  44 http fetch GET 200 https://registry.npmjs.org/axios 107ms (cache revalidated)
                  45 timing idealTree:#root Completed in 1180ms
                  46 silly placeDep node_modules/iobroker.vis axios@0.24.0 OK for: iobroker.vis@1.4.10 want: ^0.24.0
                  47 silly placeDep node_modules/iobroker.vis jsonwebtoken@8.5.1 OK for: iobroker.vis@1.4.10 want: ^8.5.1
                  48 silly fetch manifest jws@^3.2.2
                  49 silly fetch manifest ms@^2.1.1
                  50 silly fetch manifest semver@^5.6.0
                  51 http fetch GET 200 https://registry.npmjs.org/ms 39ms (cache revalidated)
                  52 http fetch GET 200 https://registry.npmjs.org/jws 45ms (cache revalidated)
                  53 http fetch GET 200 https://registry.npmjs.org/semver 85ms (cache revalidated)
                  54 timing idealTree:node_modules/iobroker.vis Completed in 91ms
                  55 timing idealTree:node_modules/iobroker.vis/node_modules/axios Completed in 0ms
                  56 silly placeDep node_modules/iobroker.vis jws@3.2.2 OK for: jsonwebtoken@8.5.1 want: ^3.2.2
                  57 silly fetch manifest jwa@^1.4.1
                  58 silly placeDep node_modules/iobroker.vis ms@2.1.3 OK for: jsonwebtoken@8.5.1 want: ^2.1.1
                  59 silly placeDep node_modules/iobroker.vis semver@5.7.2 OK for: jsonwebtoken@8.5.1 want: ^5.6.0
                  60 http fetch GET 200 https://registry.npmjs.org/jwa 36ms (cache revalidated)
                  61 timing idealTree:node_modules/iobroker.vis/node_modules/jsonwebtoken Completed in 40ms
                  62 silly placeDep node_modules/iobroker.vis jwa@1.4.1 OK for: jws@3.2.2 want: ^1.4.1
                  63 timing idealTree:node_modules/iobroker.vis/node_modules/jws Completed in 2ms
                  64 timing idealTree:node_modules/iobroker.vis/node_modules/jwa Completed in 0ms
                  65 timing idealTree:node_modules/iobroker.vis/node_modules/ms Completed in 0ms
                  66 timing idealTree:node_modules/iobroker.vis/node_modules/semver Completed in 0ms
                  67 timing idealTree:buildDeps Completed in 1313ms
                  68 timing idealTree:fixDepFlags Completed in 8ms
                  69 timing idealTree Completed in 2323ms
                  70 timing reify:loadTrees Completed in 2324ms
                  71 timing reify:diffTrees Completed in 26ms
                  72 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv' ]
                  73 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1' ]
                  74 silly reify mark retired [
                  74 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus'
                  74 silly reify ]
                  75 silly reify mark retired [
                  75 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit'
                  75 silly reify ]
                  76 silly reify mark retired [
                  76 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2'
                  76 silly reify ]
                  77 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4' ]
                  78 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios' ]
                  79 silly reify mark retired [
                  79 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf'
                  79 silly reify ]
                  80 silly reify mark retired [
                  80 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless'
                  80 silly reify ]
                  81 silly reify mark retired [
                  81 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript',
                  81 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee',
                  81 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake'
                  81 silly reify ]
                  82 silly reify mark retired [
                  82 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream'
                  82 silly reify ]
                  83 silly reify mark retired [
                  83 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is'
                  83 silly reify ]
                  84 silly reify mark retired [
                  84 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser'
                  84 silly reify ]
                  85 silly reify mark retired [
                  85 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash'
                  85 silly reify ]
                  86 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug' ]
                  87 silly reify mark retired [
                  87 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream'
                  87 silly reify ]
                  88 silly reify mark retired [
                  88 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dewpoint'
                  88 silly reify ]
                  89 silly reify mark retired [
                  89 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn'
                  89 silly reify ]
                  90 silly reify mark retired [
                  90 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend'
                  90 silly reify ]
                  91 silly reify mark retired [
                  91 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf'
                  91 silly reify ]
                  92 silly reify mark retired [
                  92 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal'
                  92 silly reify ]
                  93 silly reify mark retired [
                  93 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify'
                  93 silly reify ]
                  94 silly reify mark retired [
                  94 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/follow-redirects'
                  94 silly reify ]
                  95 silly reify mark retired [
                  95 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent'
                  95 silly reify ]
                  96 silly reify mark retired [
                  96 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data'
                  96 silly reify ]
                  97 silly reify mark retired [
                  97 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass'
                  97 silly reify ]
                  98 silly reify mark retired [
                  98 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema'
                  98 silly reify ]
                  99 silly reify mark retired [
                  99 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator'
                  99 silly reify ]
                  100 silly reify mark retired [
                  100 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature'
                  100 silly reify ]
                  101 silly reify mark retired [
                  101 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate'
                  101 silly reify ]
                  102 silly reify mark retired [
                  102 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits'
                  102 silly reify ]
                  103 silly reify mark retired [
                  103 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray'
                  103 silly reify ]
                  104 silly reify mark retired [
                  104 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray'
                  104 silly reify ]
                  105 silly reify mark retired [
                  105 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream'
                  105 silly reify ]
                  106 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn' ]
                  107 silly reify mark retired [
                  107 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema'
                  107 silly reify ]
                  108 silly reify mark retired [
                  108 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse'
                  108 silly reify ]
                  109 silly reify mark retired [
                  109 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe'
                  109 silly reify ]
                  110 silly reify mark retired [
                  110 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata'
                  110 silly reify ]
                  111 silly reify mark retired [
                  111 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim'
                  111 silly reify ]
                  112 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip' ]
                  113 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie' ]
                  114 silly reify mark retired [
                  114 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout'
                  114 silly reify ]
                  115 silly reify mark retired [
                  115 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache'
                  115 silly reify ]
                  116 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/luxon' ]
                  117 silly reify mark retired [
                  117 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db'
                  117 silly reify ]
                  118 silly reify mark retired [
                  118 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types'
                  118 silly reify ]
                  119 silly reify mark retired [
                  119 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist'
                  119 silly reify ]
                  120 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms' ]
                  121 silly reify mark retired [
                  121 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect',
                  121 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect'
                  121 silly reify ]
                  122 silly reify mark retired [
                  122 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule'
                  122 silly reify ]
                  123 silly reify mark retired [
                  123 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign'
                  123 silly reify ]
                  124 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako' ]
                  125 silly reify mark retired [
                  125 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now'
                  125 silly reify ]
                  126 silly reify mark retired [
                  126 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors'
                  126 silly reify ]
                  127 silly reify mark retired [
                  127 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args'
                  127 silly reify ]
                  128 silly reify mark retired [
                  128 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-from-env'
                  128 silly reify ]
                  129 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl' ]
                  130 silly reify mark retired [
                  130 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode'
                  130 silly reify ]
                  131 silly reify mark retired [
                  131 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream'
                  131 silly reify ]
                  132 silly reify mark retired [
                  132 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request'
                  132 silly reify ]
                  133 silly reify mark retired [
                  133 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer'
                  133 silly reify ]
                  134 silly reify mark retired [
                  134 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer'
                  134 silly reify ]
                  135 silly reify mark retired [
                  135 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver',
                  135 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver'
                  135 silly reify ]
                  136 silly reify mark retired [
                  136 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate'
                  136 silly reify ]
                  137 silly reify mark retired [
                  137 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions'
                  137 silly reify ]
                  138 silly reify mark retired [
                  138 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder'
                  138 silly reify ]
                  139 silly reify mark retired [
                  139 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2'
                  139 silly reify ]
                  140 silly reify mark retired [
                  140 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie'
                  140 silly reify ]
                  141 silly reify mark retired [
                  141 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent'
                  141 silly reify ]
                  142 silly reify mark retired [
                  142 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl'
                  142 silly reify ]
                  143 silly reify mark retired [
                  143 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript',
                  143 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc',
                  143 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver'
                  143 silly reify ]
                  144 silly reify mark retired [
                  144 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js'
                  144 silly reify ]
                  145 silly reify mark retired [
                  145 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate'
                  145 silly reify ]
                  146 silly reify mark retired [
                  146 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid',
                  146 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid'
                  146 silly reify ]
                  147 silly reify mark retired [
                  147 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror'
                  147 silly reify ]
                  148 silly reify mark retired [
                  148 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc'
                  148 silly reify ]
                  149 silly reify mark retired [
                  149 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan',
                  149 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake'
                  149 silly reify ]
                  150 silly reify mark retired [
                  150 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist'
                  150 silly reify ]
                  151 silly reify mark retired [
                  151 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types'
                  151 silly reify ]
                  152 silly reify mark retired [
                  152 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless'
                  152 silly reify ]
                  153 silly reify mark retired [
                  153 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'
                  153 silly reify ]
                  154 silly reify mark retired [
                  154 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request'
                  154 silly reify ]
                  155 silly reify mark retired [
                  155 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie'
                  155 silly reify ]
                  156 silly reify mark retired [
                  156 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk',
                  156 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv',
                  156 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign',
                  156 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify'
                  156 silly reify ]
                  157 silly reify moves {
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ajv-JWAHQ164',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asn1-begjjmYE',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.assert-plus-CvwT5c2f',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asynckit-s0phpr5l',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws-sign2-i67xE5NL',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws4-ewgSeGU1',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.axios-2R4cHyIW',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bcrypt-pbkdf-FkcXJSG6',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.caseless-H2SaxUok',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.coffeescript-btitSxqy',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.coffee-Ne3HN5Co',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.cake-vF6kAtwy',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.combined-stream-HoYmPyrw',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.cron-parser-sKzHTBDX',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.dashdash-nWlk69uH',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.debug-A3k10AtD',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.delayed-stream-qacC3mjc',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dewpoint': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.dewpoint-AaQYzDAj',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ecc-jsbn-W1wmyGbT',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extend-pv2WceUi',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extsprintf-l37IDaAf',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-deep-equal-JqieQuGS',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-json-stable-stringify-zZtSpvEn',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/follow-redirects': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.follow-redirects-UwNlikdb',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.forever-agent-hJzMqug0',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.form-data-f5gN4soy',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.getpass-kOCUh1aA',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-schema-rWbJu3Hi',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-validator-eyrBsHVJ',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-signature-oUoVxdIq',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.immediate-mU3gxEZk',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.inherits-n3Ch46Yn',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-typedarray-kgxdw7hd',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isarray-5wOzaH7B',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isstream-kucfBgOe',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsbn-7awNYEqn',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-gJeujQHS',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-traverse-lxkTlMes',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-stringify-safe-6OEF7DXQ',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsonata-sj644a8k',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsprim-Hb03jZ2t',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jszip-E0haUyzW',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lie-rDNcdBdn',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.long-timeout-UsqWplKY',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lru-cache-pTWFZBit',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/luxon': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.luxon-dE07SiDk',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-db-ILNMz48k',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-types-vVlqwvNj',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.minimist-HEtqlfZM',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ms-T3oF4fuS',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-inspect-7uCQsf40',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-inspect-RjTdcqZj',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-schedule-NrCn8xB6',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.oauth-sign-4TUsb1Hr',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pako-rbL7BtOy',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.performance-now-rzc7QsAk',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.picocolors-DQ4TN0mE',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.process-nextick-args-1FsUsOM8',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-from-env': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.proxy-from-env-PQWlh40C',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.psl-P3JlcAO8',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.punycode-l3TLrnOQ',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.readable-stream-DGJrLMhV',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.request-IwHtFKjv',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safe-buffer-GY19LMpy',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safer-buffer-VoLQjGhM',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.semver-Dy7i6zG2',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.setimmediate-rLmz5kvN',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sorted-array-functions-b2PxWBDs',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.string_decoder-QqeclkYI',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.suncalc2-tGRLIVnX',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tough-cookie-msAnSxYU',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tunnel-agent-oUVQRXxE',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tweetnacl-BnSTSyIu',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.typescript-EcwXdkx5',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsc-0PIrZBWg',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsserver-QDbM4cAE',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uri-js-8VwjhWYz',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.util-deprecate-e5GNBBxw',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uuid-0rL1ORyz',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.uuid-gQ53C49H',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.verror-EsRYTvUd',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.virtual-tsc-Z1y2mItj',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wake_on_lan-aA1sq5Hq',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.wake-PZWgBD8w',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yallist-Jj27Vzng',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.request-jbJT2ToX',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.tough-cookie-ZhFQ7n2j',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sshpk-29rDccd4',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-conv-dbhOTJ0f',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-sign-0kGWm4VB',
                  157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-verify-Bif9pYCN'
                  157 silly reify }
                  158 timing reify:retireShallow Completed in 12ms
                  159 timing reify:createSparse Completed in 1ms
                  160 timing reify:loadBundles Completed in 0ms
                  161 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
                  162 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
                  163 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
                  164 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
                  165 timing reifyNode:node_modules/osx-temperature-sensor Completed in 2ms
                  166 timing reifyNode:node_modules/fsevents Completed in 2ms
                  167 silly tarball no local data for iobroker.vis@https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.10.tgz. Extracting by manifest.
                  168 timing reifyNode:node_modules/iobroker.vis/node_modules/ms Completed in 28ms
                  169 timing reifyNode:node_modules/iobroker.vis/node_modules/jwa Completed in 28ms
                  170 timing reifyNode:node_modules/iobroker.vis/node_modules/semver Completed in 30ms
                  171 timing reifyNode:node_modules/iobroker.vis/node_modules/jws Completed in 30ms
                  172 timing reifyNode:node_modules/iobroker.vis/node_modules/jsonwebtoken Completed in 32ms
                  173 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 36ms
                  174 http fetch GET 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.10.tgz 6369ms (cache miss)
                  175 timing reifyNode:node_modules/iobroker.vis Completed in 6375ms
                  176 timing reify:unpack Completed in 6376ms
                  177 timing reify:unretire Completed in 1ms
                  178 timing build:queue Completed in 1ms
                  179 timing build:link:node_modules/iobroker.vis/node_modules/semver Completed in 2ms
                  180 timing build:link Completed in 2ms
                  181 info run iobroker.vis@1.4.10 install node_modules/iobroker.vis node main.js --install
                  182 info run iobroker.vis@1.4.10 install { code: 6, signal: null }
                  183 timing reify:rollback:createSparse Completed in 22ms
                  184 timing reify:rollback:retireShallow Completed in 5ms
                  185 timing command:install Completed in 10973ms
                  186 verbose stack Error: command failed
                  186 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
                  186 verbose stack     at ChildProcess.emit (node:events:514:28)
                  186 verbose stack     at maybeClose (node:internal/child_process:1091:16)
                  186 verbose stack     at ChildProcess._handle.onexit (node:internal/child_process:302:5)
                  187 verbose pkgid iobroker.vis@1.4.10
                  188 verbose cwd /opt/iobroker
                  189 verbose Linux 5.15.102-1-pve
                  190 verbose node v18.17.1
                  191 verbose npm  v9.6.7
                  192 error code 6
                  193 error path /opt/iobroker/node_modules/iobroker.vis
                  194 error command failed
                  195 error command sh -c node main.js --install
                  196 verbose exit 6
                  197 timing npm Completed in 11133ms
                  198 verbose unfinished npm timer reify 1694526790712
                  199 verbose unfinished npm timer reify:build 1694526799454
                  200 verbose unfinished npm timer build 1694526799455
                  201 verbose unfinished npm timer build:deps 1694526799455
                  202 verbose unfinished npm timer build:run:install 1694526799459
                  203 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1694526799459
                  204 verbose code 6
                  205 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-12T13_53_10_553Z-debug-0.log
                  und einmal
                  3 timing npm:load:whichnode Completed in 6ms
                  4 timing config:load:defaults Completed in 2ms
                  6 timing config:load:builtin Completed in 0ms
                  7 timing config:load:cli Completed in 2ms
                  9 timing config:load:file:/.npmrc Completed in 0ms
                  10 timing config:load:project Completed in 1ms
                  11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
                  12 timing config:load:user Completed in 1ms
                  16 timing config:load Completed in 8ms
                  17 timing npm:load:configload Completed in 8ms
                  18 timing npm:load:mkdirpcache Completed in 0ms
                  21 verbose argv "--version"
                  25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-09-12T13_54_41_911Z-
                  26 verbose logfile /home/iobroker/.npm/_logs/2023-09-12T13_54_41_911Z-debug-0.log
                  27 timing npm:load:logFile Completed in 10ms
                  30 timing npm:load Completed in 28ms
                  31 verbose exit 0
                  32 timing npm Completed in 33ms
                  33 info ok
                    Ubuntu 23.04
                    Swap: 0B 0B 0B
                    debug: daswetter.0
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @thomas-braun sagte in Vis Adapter nach Backup mit Fehlermeldung:
                    nur 9 Monate
                    bis Januar 2024
                    ich würde einfach neu aufsetzen mit dem passenden OS und backup einspielen, bevor da jetzt lang rum gesucht wird
                    Swap: 0B 0B 0B
                    deswegen wird dir wahrscheinlich der LXC abgeschmiert sein
                    • J Offline
                      Jacke
                      so mit
                      nils@IoBroker:~$ iob install vis@1.4.6 --debug
                      NPM version: 9.6.7
                      Installing iobroker.vis@1.4.6... (System call)
                      added 6 packages, and removed 91 packages in 7s
                      173 packages are looking for funding
                        run `npm fund` for details
                      host.IoBroker install adapter vis@1.4.6
                      upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                      upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                      upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                      upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                      upload [323] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                      upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/checkbox.png icon/checkbox.png image/png
                      upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/img/camera.png img/camera.png image/png
                      upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/128/png.png js/fm/icon/mine/128/png.png image/png
                      upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/css/farbtastic.css lib/css/farbtastic.css text/css
                      upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/signals/online.png signals/online.png image/png
                      upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ContainerView.png widgets/basic/img/Prev_ContainerView.png image/png
                      upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_Shape.png widgets/basic/img/Prev_Shape.png image/png
                      upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueBoolCtrlSvg.png widgets/basic/img/Prev_ValueBoolCtrlSvg.png image/png
                      upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueString.png widgets/basic/img/Prev_ValueString.png image/png
                      upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/micInactive.svg widgets/basic/img/micInactive.svg image/svg+xml
                      upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/info/js/words.js widgets/info/js/words.js application/javascript
                      upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui/img/Prev_ContainerDialogExternal.png widgets/jqui/img/Prev_ContainerDialogExternal.png image/png
                      upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Swipe.png widgets/swipe/img/Prev_Swipe.png image/png
                      upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/noSwipe.jpg widgets/swipe/img/noSwipe.jpg image/jpeg
                      upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout-shapes.js widgets/swipe/js/jquery.roundabout-shapes.js application/javascript
                      upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js widgets/swipe/js/jquery.roundabout.min.js application/javascript
                      upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
                      upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html text/html
                      upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
                      upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png widgets/tabs/styles/images/indicator.png image/png
                      upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActive.png widgets/tabs/styles/images/indicatorActive.png image/png
                      upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
                      upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow.png widgets/tabs/styles/images/leftPanelArrow.png image/png
                      upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
                      upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow.png widgets/tabs/styles/images/rightPanelArrow.png image/png
                      upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
                      upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css.orig widgets/tabs/styles/jquery.sliderTabs.css.orig false
                      upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
                      upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
                      upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
                      upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/homematic.html text/html
                      upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
                      upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/weather.html text/html
                      host.IoBroker object system.adapter.vis created/updated
                      Update "system.adapter.vis.0"
                      hat es geklappt und danach habe ich auf 1.4.16 aktualisiert
                      jetzt läuft es.
                      @crunchip
                      das komische war der LXC ließ sich auch nicht mehr starten. ich lasse jetzt erstmal die Ubuntu laufen und versuche es nochmal mit Debian mit Swap und mehr speicher.
                      • J Jacke
                        so mit
                        NPM version: 9.6.7
                        jetzt läuft es.
                        @crunchip
                        crunchipC Abwesend
                        crunchipC Abwesend
                        aber vor dem backup zurückspielen, vis normal installieren
                          @crunchip sagte in Vis Adapter nach Backup mit Fehlermeldung:
                          aber vor dem backup vis normal installieren
                          RESTORE
                            RESTORE
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @homoran habs Wort zurückspielen vergessen und oben korrigiert
