  4. Vis Adapter nach Backup mit Fehlermeldung
    1.0k
    6.1k
24 Beiträge 4 Kommentatoren 3.3k Aufrufe 3 Beobachtet
  • J Jacke
    @thomas-braun ok im terminal wie würde der Befehl aussehen
    npn install iobroker.vis --debug
    crunchipC Offline
    crunchipC Offline
    @jacke sagte in Vis Adapter nach Backup mit Fehlermeldung:
    npn
    is falsch
    • J Jacke
      Am besten von npm ganz die Finger lassen.
      iobroker add vis --host DEINHOSTNAME --debug
        Jacke
        Hatte das schon eingegeben
        nils@IoBroker:~$ iobroker install iobroker.vis --debug
        NPM version: 9.6.7
        Installing iobroker.vis@1.1.1... (System call)
        npm ERR! code 1
        npm ERR! path /opt/iobroker/node_modules/iobroker.vis
        npm ERR! command failed
        npm ERR! command sh -c node main.js --install
        npm ERR! node:internal/modules/cjs/loader:1080
        npm ERR!   throw err;
        npm ERR!   ^
        npm ERR!
        npm ERR! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
        npm ERR! Require stack:
        npm ERR! - /opt/iobroker/node_modules/iobroker.vis/lib/utils.js
        npm ERR! - /opt/iobroker/node_modules/iobroker.vis/main.js
        npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        npm ERR!     at Module._load (node:internal/modules/cjs/loader:922:27)
        npm ERR!     at Module.require (node:internal/modules/cjs/loader:1143:19)
        npm ERR!     at require (node:internal/modules/cjs/helpers:121:18)
        npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.vis/lib/utils.js:63:25)
        npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1256:14)
        npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        npm ERR!     at Module.load (node:internal/modules/cjs/loader:1119:32)
        npm ERR!     at Module._load (node:internal/modules/cjs/loader:960:12)
        npm ERR!     at Module.require (node:internal/modules/cjs/loader:1143:19) {
        npm ERR!   code: 'MODULE_NOT_FOUND',
        npm ERR!   requireStack: [
        npm ERR!     '/opt/iobroker/node_modules/iobroker.vis/lib/utils.js',
        npm ERR!     '/opt/iobroker/node_modules/iobroker.vis/main.js'
        npm ERR!   ]
        npm ERR! }
        npm ERR!
        npm ERR! Node.js v18.17.1
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-12T13_28_36_864Z-debug-0.log
        npm ERR! code 1
        npm ERR!   throw err;
        npm ERR!   ^
        npm ERR!
        npm ERR!   ]
        npm ERR! }
        npm ERR!
        host.IoBroker Cannot install iobroker.vis@1.1.1: 1
        • J Jacke
          NPM version: 9.6.7
          npm ERR! code 1
          npm ERR!   throw err;
          npm ERR!   ^
          npm ERR!
          npm ERR!   ]
          npm ERR! }
          npm ERR!
          npm ERR! code 1
          npm ERR!   throw err;
          npm ERR!   ^
          npm ERR!
          npm ERR!   ]
          npm ERR! }
          npm ERR!
          @jacke
          iob diag
          in der Langfassung bitte.
          • J Jacke
            NPM version: 9.6.7
            npm ERR! code 1
            npm ERR!   throw err;
            npm ERR!   ^
            npm ERR!
            npm ERR!   ]
            npm ERR! }
            npm ERR!
            npm ERR! code 1
            npm ERR!   throw err;
            npm ERR!   ^
            npm ERR!
            npm ERR!   ]
            npm ERR! }
            npm ERR!
            @jacke wenn dann iob upgrade vis@1.4.10 --debug
              @jacke
              iob diag
              Jacke
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Architecture    : x86_64
              Docker          : false
              Virtualization  : lxc
              Distributor ID: Ubuntu
              Description:    Ubuntu 23.04
              Release:        23.04
              Codename:       lunar
              PRETTY_NAME="Ubuntu 23.04"
              NAME="Ubuntu"
              VERSION_ID="23.04"
              VERSION="23.04 (Lunar Lobster)"
              VERSION_CODENAME=lunar
              ID=ubuntu
              ID_LIKE=debian
              HOME_URL="https://www.ubuntu.com/"
              SUPPORT_URL="https://help.ubuntu.com/"
              BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
              PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
              UBUNTU_CODENAME=lunar
              LOGO=ubuntu-logo
              Systemuptime and Load:
               15:33:27 up  1:46,  2 users,  load average: 0.99, 1.09, 1.09
              CPU threads: 2
              *** Time and Time Zones ***
                             Local time: Tue 2023-09-12 15:33:27 CEST
                         Universal time: Tue 2023-09-12 13:33:27 UTC
                               RTC time: n/a
                            NTP service: inactive
                        RTC in local TZ: no
              *** User and Groups ***
              nils
              /home/nils
              nils sudo users iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            4.3G        3.4G        418M        143K        459M        878M
              Swap:             0B          0B          0B
              Total:          4.3G        3.4G        418M
                       4096 M total memory
                       3258 M used memory
                        252 M active memory
                       3143 M inactive memory
                        399 M free memory
                          0 M buffer memory
                        438 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              Filesystem                            Type   Size  Used Avail Use% Mounted on
              /dev/mapper/data_ssd-vm--100--disk--0 ext4    18G  4.7G   13G  28% /
              none                                  tmpfs  492K  4.0K  488K   1% /dev
              tmpfs                                 tmpfs   12G     0   12G   0% /dev/shm
              tmpfs                                 tmpfs  4.7G  136K  4.7G   1% /run
              tmpfs                                 tmpfs  5.0M     0  5.0M   0% /run/lock
              tmpfs                                 tmpfs  2.4G     0  2.4G   0% /run/user/1000
              dmesg: read kernel buffer failed: Operation not permitted
              TARGET SOURCE                                FSTYPE OPTIONS
              /      /dev/mapper/data_ssd-vm--100--disk--0 ext4   rw,relatime,stripe=16
              /var:
              504M    /var/
              246M    /var/cache
              240M    /var/cache/apt
              233M    /var/lib
              153M    /var/cache/apt/archives
              Archived and active journals take up 8.0M in the file system.
              /opt/iobroker/backups:
              102M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              756M    /opt/iobroker/iobroker-data/
              398M    /opt/iobroker/iobroker-data/files
              249M    /opt/iobroker/iobroker-data/esphome.0/.esphome
              248M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              31M     /opt/iobroker/iobroker-data/states.jsonl
              28M     /opt/iobroker/iobroker-data/objects.jsonl
              24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/grillthermometer/.pioenvs/grillthermometer/firmware.elf
              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.67295ba8.js.map
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.17.1
              /usr/bin/node           v18.17.1
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              nodejs:
                Installed: 18.17.1-deb-1nodesource1
                Candidate: 18.17.1-deb-1nodesource1
                Version table:
               *** 18.17.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x lunar/main amd64 Packages
                   18.13.0+dfsg1-1ubuntu2 500
                      500 http://archive.ubuntu.com/ubuntu lunar/universe amd64 Packages
              No problems detected
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.12
              admin:          6.5.8
              javascript:     7.1.4
              Adapters from github:   1
              Adapter State
              + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
                system.adapter.awattar.0                : awattar               : IoBroker                                 - disabled
              + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                system.adapter.daswetter.0              : daswetter             : IoBroker                                 -  enabled
                system.adapter.devices.0                : devices               : IoBroker                                 - disabled
                system.adapter.discovery.0              : discovery             : IoBroker                                 - disabled
              + system.adapter.energiefluss.0           : energiefluss          : IoBroker                                 -  enabled
                system.adapter.esphome.0                : esphome               : IoBroker                                 - disabled
                system.adapter.fb-checkpresence.0       : fb-checkpresence      : IoBroker                                 - disabled
                system.adapter.flot.0                   : flot                  : IoBroker                                 - disabled
              + system.adapter.heatingcontrol.0         : heatingcontrol        : IoBroker                                 -  enabled
              + system.adapter.history.0                : history               : IoBroker                                 -  enabled
                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: IoBroker                                 - disabled
                system.adapter.icons-icons8.0           : icons-icons8          : IoBroker                                 - disabled
                system.adapter.icons-material-png.0     : icons-material-png    : IoBroker                                 - disabled
                system.adapter.icons-material-svg.0     : icons-material-svg    : IoBroker                                 - disabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoBroker                                 - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IoBroker                                 - disabled
              + system.adapter.influxdb.0               : influxdb              : IoBroker                                 -  enabled, port: 8086
              + system.adapter.info.0                   : info                  : IoBroker                                 -  enabled
              + system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
              + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
              + system.adapter.melcloud.0               : melcloud              : IoBroker                                 -  enabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
              + system.adapter.modbus.1                 : modbus                : IoBroker                                 -  enabled
              + system.adapter.mqtt-client.0            : mqtt-client           : IoBroker                                 -  enabled, port: 1883
              + system.adapter.mqtt.1                   : mqtt                  : IoBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.mqtt.2                   : mqtt                  : IoBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
              + system.adapter.node-red.0               : node-red              : IoBroker                                 -  enabled, port: 1880, bind: 0.0.0.0
              + system.adapter.ping.0                   : ping                  : IoBroker                                 -  enabled
              + system.adapter.proxmox.0                : proxmox               : IoBroker                                 -  enabled, port: 8006
              + system.adapter.pvforecast.0             : pvforecast            : IoBroker                                 -  enabled
              + system.adapter.pvforecast.1             : pvforecast            : IoBroker                                 -  enabled
              + system.adapter.ring.0                   : ring                  : IoBroker                                 -  enabled
              + system.adapter.s7.0                     : s7                    : IoBroker                                 -  enabled
                system.adapter.scenes.0                 : scenes                : IoBroker                                 - disabled
              + system.adapter.shelly.0                 : shelly                : IoBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                system.adapter.socketio.0               : socketio              : IoBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
              + system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.sourceanalytix.0         : sourceanalytix        : IoBroker                                 -  enabled
              + system.adapter.sql.0                    : sql                   : IoBroker                                 -  enabled
              + system.adapter.telegram.0               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.telegram.1               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.text2command.0           : text2command          : IoBroker                                 -  enabled
                system.adapter.vis.0                    : vis                   : IoBroker                                 - disabled
                system.adapter.weatherunderground.0     : weatherunderground    : IoBroker                                 -  enabled
              + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.windows-control.0        : windows-control       : IoBroker                                 -  enabled
              + system.adapter.worx.0                   : worx                  : IoBroker                                 -  enabled
              + system.adapter.zigbee.1                 : zigbee                : IoBroker                                 -  enabled, port: tcp://192.168.1.145:5000
              + instance is alive
              ioBroker-Repositories
              default       : http://download.iobroker.net/sources-dist-latest.json
              latest        : http://download.iobroker.net/sources-dist.json
              Active repo(s): default, latest
              Installed ioBroker-Instances
              Used repositories: default, latest
              a Objects database error: read ECONNRESET
               States database error: connect ECONNREFUSED 0.0.0.0:9000
               Objects database error: connect ECONNREFUSED 0.0.0.0:9001
              Adapter    "admin"        : 6.8.0    , installed 6.5.8  [Updatable]
              Adapter    "alexa2"       : 3.24.1   , installed 3.25.1
              Adapter    "awattar"      : 1.0.6    , installed 1.0.6
              Adapter    "backitup"     : 2.6.23   , installed 2.7.0
              Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
              Adapter    "devices"      : 1.1.5    , installed 1.1.5
              Adapter    "discovery"    : 3.1.0    , installed 4.0.0
              Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
              Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
              Adapter    "history"      : 2.2.6    , installed 2.2.6
              Adapter    "info"         : 1.9.26   , installed 2.0.0
              Adapter    "iot"          : 1.14.5   , installed 2.0.11
              Adapter    "javascript"   : 7.0.3    , installed 7.1.4
              Controller "js-controller": 4.0.24   , installed 5.0.12
              Adapter    "melcloud"     : 1.3.5    , installed 1.3.5
              Adapter    "mihome-vacuum": 3.11.0   , installed 4.0.0
              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
              Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
              Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.4
              Adapter    "node-red"     : 4.0.3    , installed 4.0.3
              Adapter    "proxmox"      : 1.3.5    , installed 2.0.2
              Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
              Adapter    "ring"         : 3.2.2    , installed 3.4.1
              Adapter    "s7"           : 1.3.15   , installed 1.3.15
              Adapter    "shelly"       : 6.4.1    , installed 6.4.1
              Adapter    "socketio"     : 6.5.3    , installed 6.5.3
              Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
              Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
              Adapter    "telegram"     : 1.16.0   , installed 1.16.0
              Adapter    "text2command" : 3.0.2    , installed 3.0.2
              Adapter    "weatherunderground": 3.4.2, installed 3.6.0
              Adapter    "web"          : 6.1.1    , installed 6.1.1
              Adapter    "windows-control": 0.1.5  , installed 0.1.5
              Adapter    "worx"         : 2.3.2    , installed 2.3.2
              Adapter    "ws"           : 2.5.4    , installed 2.5.3  [Updatable]
              Adapter    "zigbee"       : 1.8.23   , installed 1.8.24
              Objects and States
              Objects:        21779
              States:         15752
              aHit:1 https://deb.nodesource.com/node_18.x lunar InRelease
              Hit:2 http://archive.ubuntu.com/ubuntu lunar InRelease
              Hit:3 http://archive.ubuntu.com/ubuntu lunar-updates InRelease
              Hit:4 http://archive.ubuntu.com/ubuntu lunar-security InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        791290896  102/systemd-resolve
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          791292090  311/master
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       791957309  119661/iobroker.js-
              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       791957316  119661/iobroker.js-
              tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        791290898  102/systemd-resolve
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          791289333  1/init
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          791292091  311/master
              tcp6       0      0 :::111                  :::*                    LISTEN      0          791289335  1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          791289693  1/init
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:        23.04
              Codename:       lunar
              NAME="Ubuntu"
              VERSION_ID="23.04"
              ID=ubuntu
              ID_LIKE=debian
              LOGO=ubuntu-logo
               15:35:36 up  1:48,  2 users,  load average: 8.31, 5.39, 2.77
              CPU threads: 2
                             Local time: Tue 2023-09-12 15:35:36 CEST
                         Universal time: Tue 2023-09-12 13:35:36 UTC
                               RTC time: n/a
                        RTC in local TZ: no
              nils
              /home/nils
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            4.3G        2.2G        1.4G        143K        688M        2.1G
              Swap:             0B          0B          0B
              Total:          4.3G        2.2G        1.4G
                       4096 M total memory
                       2100 M used memory
                        301 M active memory
                       2368 M inactive memory
                       1338 M free memory
                          0 M buffer memory
                        656 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              /dev/mapper/data_ssd-vm--100--disk--0 ext4    18G  4.7G   12G  29% /
              /var:
              504M    /var/
              246M    /var/cache
              240M    /var/cache/apt
              233M    /var/lib
              764M    /opt/iobroker/iobroker-data/
              36M     /opt/iobroker/iobroker-data/objects.jsonl
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.5.8
              javascript:     7.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        21785
              States:         15809
              Pending Updates: 0
              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       791965434  120858/node-red
              tcp6       0      0 :::8086                 :::*                    LISTEN      1001       791965010  120494/io.admin.0
              udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        791290897  102/systemd-resolve
              udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        791290895  102/systemd-resolve
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          791289334  1/init
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       791969211  121288/io.mihome-va
              udp6       0      0 :::111                  :::*                                0          791289336  1/init
              2023-09-12 15:36:08.673  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.symbol_desc2 with Bewölkt mit leichtem Regen
              2023-09-12 15:36:08.676  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.symbol_value2 with 6
              2023-09-12 15:36:08.710  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.symbol_desc with Bewölkt mit leichtem Regen
              2023-09-12 15:36:08.711  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.symbol_value with 6
              2023-09-12 15:36:08.716  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.iconURL with /adapter/daswetter/icons/tiempo-weather/galeria1/6.png
              2023-09-12 15:36:08.772  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.wind_symbolB with 40
              2023-09-12 15:36:08.798  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.wind_symbol with 16
              2023-09-12 15:36:08.800  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.wind_dir with NW
              2023-09-12 15:36:08.804  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.wind_value with 5 km/h
              2023-09-12 15:36:08.967  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.windIconURL with /adapter/daswetter/icons/viento-wind/undefined/40.png
              2023-09-12 15:36:09.046  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.windgusts_value with 26 km/h
              2023-09-12 15:36:09.122  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.rain_value with 0.4 mm
              2023-09-12 15:36:09.125  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.humidity_value with 97
              2023-09-12 15:36:09.127  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.pressure_value with 1013 mb
              2023-09-12 15:36:09.146  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.clouds_value with 58%
              2023-09-12 15:36:09.263  - warn: modbus.1 (121314) Poll error count: 1 code: {"errorCode":131,"exceptionCode":10,"message":"GATEWAY PATH UNAVAILABLE"}
              2023-09-12 15:36:09.281  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.snowline_value with 3600 m
              2023-09-12 15:36:09.301  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.uv_index_value with 0
              2023-09-12 15:36:09.303  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.windchill_value with 17 °C
              2023-09-12 15:36:09.307  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9 with null  {"type":"channel","common":{"name":"Hour 9","role":"weather"}}
              2023-09-12 15:36:09.407  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.current with null  {"type":"channel","common":{"name":"current ","role":"weather"}}
              2023-09-12 15:36:09.429  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9.hour_value with 09:00
              2023-09-12 15:36:09.527  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9.temp_value with 18 °C
              2023-09-12 15:36:09.544  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9.symbol_desc2 with Bewölkt
              2023-09-12 15:36:09.569  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9.symbol_value2 with 3
              iob diag has finished.
              Press any key for a summary
                Jacke
                @homoran said in Vis Adapter nach Backup mit Fehlermeldung:
                nils@IoBroker:~$ iob upgrade vis@1.4.10 --debug
                Adapter "vis"            is not installed.
                kommt dann
                • J Jacke
                  kommt dann
                  @jacke dann iob install vis@1.4.10 --debug
                  • J Jacke
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        23.04
                    Codename:       lunar
                    NAME="Ubuntu"
                    VERSION_ID="23.04"
                    ID=ubuntu
                    ID_LIKE=debian
                    LOGO=ubuntu-logo
                    CPU threads: 2
                                     RTC time: n/a
                              RTC in local TZ: no
                    nils
                    /home/nils
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:             0B          0B          0B
                             4096 M total memory
                             3258 M used memory
                              252 M active memory
                              399 M free memory
                                0 M buffer memory
                              438 M swap cache
                                0 M total swap
                                0 M used swap
                                0 M free swap
                    *** FILESYSTEM ***
                    /var:
                    504M    /var/
                    246M    /var/cache
                    240M    /var/cache/apt
                    233M    /var/lib
                    /usr/bin/npm            9.6.7
                    /usr/bin/npx            9.6.7
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.5.8
                    javascript:     7.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        21779
                    States:         15752
                    Pending Updates: 0
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        23.04
                    Codename:       lunar
                    NAME="Ubuntu"
                    VERSION_ID="23.04"
                    ID=ubuntu
                    ID_LIKE=debian
                    LOGO=ubuntu-logo
                    CPU threads: 2
                                     RTC time: n/a
                              RTC in local TZ: no
                    nils
                    /home/nils
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:             0B          0B          0B
                             4096 M total memory
                             2100 M used memory
                              301 M active memory
                             1338 M free memory
                                0 M buffer memory
                              656 M swap cache
                                0 M total swap
                                0 M used swap
                                0 M free swap
                    *** FILESYSTEM ***
                    /var:
                    504M    /var/
                    246M    /var/cache
                    240M    /var/cache/apt
                    233M    /var/lib
                    /usr/bin/npm            9.6.7
                    /usr/bin/npx            9.6.7
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.5.8
                    javascript:     7.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        21785
                    States:         15809
                    Pending Updates: 0
                    Ubuntu 23.04
                    Ich hätte ja die LTS-Version genommen. Diese Interims-Releases bei ubuntu leben nur 9 Monate. Oder halt gleich das 'Original'-Debian in aktueller Fassung.
                    Swap: 0B 0B 0B
                    Swap auch nicht vollständig deaktivieren. Das wird u. U. benötigt.
                    Setz den 'nils' in die Gruppe 'adm'.
                    Entweder/Oder. Beide Repos pallel aktiv sorgt ggf. für Trouble.
                    debug: daswetter.0
                    Setze Instanzen nur auf debug, wenn du das auch tust. Ansonsten ballert es dir nur das LogFile zu.
                      Jacke
                      dann kommt wieder diese fehlermeldung
                      NPM version: 9.6.7
                      Installing iobroker.vis@1.4.10... (System call)
                      npm ERR! code 6
                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-12T13_53_10_553Z-debug-0.log
                      npm ERR! code 6
                      host.IoBroker Cannot install iobroker.vis@1.4.10: 6
                      • J Jacke
                        NPM version: 9.6.7
                        npm ERR! code 6
                        npm ERR! code 6
                        Was steht da drin?
                        • J Offline
                          Jacke
                          0 verbose cli /usr/bin/node /usr/bin/npm
                          1 info using npm@9.6.7
                          2 info using node@v18.17.1
                          3 timing npm:load:whichnode Completed in 1ms
                          4 timing config:load:defaults Completed in 1ms
                          5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 0ms
                          6 timing config:load:builtin Completed in 1ms
                          7 timing config:load:cli Completed in 1ms
                          8 timing config:load:env Completed in 0ms
                          9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
                          10 timing config:load:project Completed in 2ms
                          11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                          12 timing config:load:user Completed in 0ms
                          13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                          14 timing config:load:global Completed in 0ms
                          15 timing config:load:setEnvs Completed in 1ms
                          16 timing config:load Completed in 7ms
                          17 timing npm:load:configload Completed in 7ms
                          18 timing npm:load:mkdirpcache Completed in 1ms
                          19 timing npm:load:mkdirplogs Completed in 0ms
                          20 verbose title npm install iobroker.vis@1.4.10
                          21 verbose argv "install" "--save-exact" "iobroker.vis@1.4.10"
                          22 timing npm:load:setTitle Completed in 1ms
                          23 timing config:load:flatten Completed in 2ms
                          24 timing npm:load:display Completed in 3ms
                          25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-09-12T13_53_10_553Z-
                          26 verbose logfile /home/iobroker/.npm/_logs/2023-09-12T13_53_10_553Z-debug-0.log
                          27 timing npm:load:logFile Completed in 7ms
                          28 timing npm:load:timers Completed in 0ms
                          29 timing npm:load:configScope Completed in 0ms
                          30 timing npm:load Completed in 20ms
                          31 timing arborist:ctor Completed in 1ms
                          32 silly logfile start cleaning logs, removing 5 files
                          33 timing idealTree:init Completed in 985ms
                          34 timing idealTree:userRequests Completed in 8ms
                          35 silly idealTree buildDeps
                          36 silly fetch manifest iobroker.vis@1.4.10
                          37 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                          38 silly logfile done cleaning log files
                          39 http fetch GET 200 https://registry.npmjs.org/iobroker.vis 1057ms (cache revalidated)
                          40 silly placeDep ROOT iobroker.vis@1.4.10 OK for: iobroker.inst@3.0.0 want: 1.4.10
                          41 silly fetch manifest jsonwebtoken@^8.5.1
                          42 silly fetch manifest axios@^0.24.0
                          43 http fetch GET 200 https://registry.npmjs.org/jsonwebtoken 59ms (cache revalidated)
                          44 http fetch GET 200 https://registry.npmjs.org/axios 107ms (cache revalidated)
                          45 timing idealTree:#root Completed in 1180ms
                          46 silly placeDep node_modules/iobroker.vis axios@0.24.0 OK for: iobroker.vis@1.4.10 want: ^0.24.0
                          47 silly placeDep node_modules/iobroker.vis jsonwebtoken@8.5.1 OK for: iobroker.vis@1.4.10 want: ^8.5.1
                          48 silly fetch manifest jws@^3.2.2
                          49 silly fetch manifest ms@^2.1.1
                          50 silly fetch manifest semver@^5.6.0
                          51 http fetch GET 200 https://registry.npmjs.org/ms 39ms (cache revalidated)
                          52 http fetch GET 200 https://registry.npmjs.org/jws 45ms (cache revalidated)
                          53 http fetch GET 200 https://registry.npmjs.org/semver 85ms (cache revalidated)
                          54 timing idealTree:node_modules/iobroker.vis Completed in 91ms
                          55 timing idealTree:node_modules/iobroker.vis/node_modules/axios Completed in 0ms
                          56 silly placeDep node_modules/iobroker.vis jws@3.2.2 OK for: jsonwebtoken@8.5.1 want: ^3.2.2
                          57 silly fetch manifest jwa@^1.4.1
                          58 silly placeDep node_modules/iobroker.vis ms@2.1.3 OK for: jsonwebtoken@8.5.1 want: ^2.1.1
                          59 silly placeDep node_modules/iobroker.vis semver@5.7.2 OK for: jsonwebtoken@8.5.1 want: ^5.6.0
                          60 http fetch GET 200 https://registry.npmjs.org/jwa 36ms (cache revalidated)
                          61 timing idealTree:node_modules/iobroker.vis/node_modules/jsonwebtoken Completed in 40ms
                          62 silly placeDep node_modules/iobroker.vis jwa@1.4.1 OK for: jws@3.2.2 want: ^1.4.1
                          63 timing idealTree:node_modules/iobroker.vis/node_modules/jws Completed in 2ms
                          64 timing idealTree:node_modules/iobroker.vis/node_modules/jwa Completed in 0ms
                          65 timing idealTree:node_modules/iobroker.vis/node_modules/ms Completed in 0ms
                          66 timing idealTree:node_modules/iobroker.vis/node_modules/semver Completed in 0ms
                          67 timing idealTree:buildDeps Completed in 1313ms
                          68 timing idealTree:fixDepFlags Completed in 8ms
                          69 timing idealTree Completed in 2323ms
                          70 timing reify:loadTrees Completed in 2324ms
                          71 timing reify:diffTrees Completed in 26ms
                          72 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv' ]
                          73 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1' ]
                          74 silly reify mark retired [
                          74 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus'
                          74 silly reify ]
                          75 silly reify mark retired [
                          75 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit'
                          75 silly reify ]
                          76 silly reify mark retired [
                          76 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2'
                          76 silly reify ]
                          77 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4' ]
                          78 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios' ]
                          79 silly reify mark retired [
                          79 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf'
                          79 silly reify ]
                          80 silly reify mark retired [
                          80 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless'
                          80 silly reify ]
                          81 silly reify mark retired [
                          81 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript',
                          81 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee',
                          81 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake'
                          81 silly reify ]
                          82 silly reify mark retired [
                          82 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream'
                          82 silly reify ]
                          83 silly reify mark retired [
                          83 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is'
                          83 silly reify ]
                          84 silly reify mark retired [
                          84 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser'
                          84 silly reify ]
                          85 silly reify mark retired [
                          85 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash'
                          85 silly reify ]
                          86 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug' ]
                          87 silly reify mark retired [
                          87 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream'
                          87 silly reify ]
                          88 silly reify mark retired [
                          88 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dewpoint'
                          88 silly reify ]
                          89 silly reify mark retired [
                          89 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn'
                          89 silly reify ]
                          90 silly reify mark retired [
                          90 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend'
                          90 silly reify ]
                          91 silly reify mark retired [
                          91 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf'
                          91 silly reify ]
                          92 silly reify mark retired [
                          92 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal'
                          92 silly reify ]
                          93 silly reify mark retired [
                          93 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify'
                          93 silly reify ]
                          94 silly reify mark retired [
                          94 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/follow-redirects'
                          94 silly reify ]
                          95 silly reify mark retired [
                          95 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent'
                          95 silly reify ]
                          96 silly reify mark retired [
                          96 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data'
                          96 silly reify ]
                          97 silly reify mark retired [
                          97 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass'
                          97 silly reify ]
                          98 silly reify mark retired [
                          98 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema'
                          98 silly reify ]
                          99 silly reify mark retired [
                          99 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator'
                          99 silly reify ]
                          100 silly reify mark retired [
                          100 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature'
                          100 silly reify ]
                          101 silly reify mark retired [
                          101 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate'
                          101 silly reify ]
                          102 silly reify mark retired [
                          102 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits'
                          102 silly reify ]
                          103 silly reify mark retired [
                          103 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray'
                          103 silly reify ]
                          104 silly reify mark retired [
                          104 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray'
                          104 silly reify ]
                          105 silly reify mark retired [
                          105 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream'
                          105 silly reify ]
                          106 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn' ]
                          107 silly reify mark retired [
                          107 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema'
                          107 silly reify ]
                          108 silly reify mark retired [
                          108 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse'
                          108 silly reify ]
                          109 silly reify mark retired [
                          109 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe'
                          109 silly reify ]
                          110 silly reify mark retired [
                          110 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata'
                          110 silly reify ]
                          111 silly reify mark retired [
                          111 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim'
                          111 silly reify ]
                          112 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip' ]
                          113 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie' ]
                          114 silly reify mark retired [
                          114 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout'
                          114 silly reify ]
                          115 silly reify mark retired [
                          115 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache'
                          115 silly reify ]
                          116 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/luxon' ]
                          117 silly reify mark retired [
                          117 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db'
                          117 silly reify ]
                          118 silly reify mark retired [
                          118 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types'
                          118 silly reify ]
                          119 silly reify mark retired [
                          119 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist'
                          119 silly reify ]
                          120 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms' ]
                          121 silly reify mark retired [
                          121 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect',
                          121 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect'
                          121 silly reify ]
                          122 silly reify mark retired [
                          122 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule'
                          122 silly reify ]
                          123 silly reify mark retired [
                          123 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign'
                          123 silly reify ]
                          124 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako' ]
                          125 silly reify mark retired [
                          125 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now'
                          125 silly reify ]
                          126 silly reify mark retired [
                          126 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors'
                          126 silly reify ]
                          127 silly reify mark retired [
                          127 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args'
                          127 silly reify ]
                          128 silly reify mark retired [
                          128 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-from-env'
                          128 silly reify ]
                          129 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl' ]
                          130 silly reify mark retired [
                          130 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode'
                          130 silly reify ]
                          131 silly reify mark retired [
                          131 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream'
                          131 silly reify ]
                          132 silly reify mark retired [
                          132 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request'
                          132 silly reify ]
                          133 silly reify mark retired [
                          133 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer'
                          133 silly reify ]
                          134 silly reify mark retired [
                          134 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer'
                          134 silly reify ]
                          135 silly reify mark retired [
                          135 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver',
                          135 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver'
                          135 silly reify ]
                          136 silly reify mark retired [
                          136 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate'
                          136 silly reify ]
                          137 silly reify mark retired [
                          137 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions'
                          137 silly reify ]
                          138 silly reify mark retired [
                          138 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder'
                          138 silly reify ]
                          139 silly reify mark retired [
                          139 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2'
                          139 silly reify ]
                          140 silly reify mark retired [
                          140 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie'
                          140 silly reify ]
                          141 silly reify mark retired [
                          141 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent'
                          141 silly reify ]
                          142 silly reify mark retired [
                          142 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl'
                          142 silly reify ]
                          143 silly reify mark retired [
                          143 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript',
                          143 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc',
                          143 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver'
                          143 silly reify ]
                          144 silly reify mark retired [
                          144 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js'
                          144 silly reify ]
                          145 silly reify mark retired [
                          145 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate'
                          145 silly reify ]
                          146 silly reify mark retired [
                          146 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid',
                          146 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid'
                          146 silly reify ]
                          147 silly reify mark retired [
                          147 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror'
                          147 silly reify ]
                          148 silly reify mark retired [
                          148 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc'
                          148 silly reify ]
                          149 silly reify mark retired [
                          149 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan',
                          149 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake'
                          149 silly reify ]
                          150 silly reify mark retired [
                          150 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist'
                          150 silly reify ]
                          151 silly reify mark retired [
                          151 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types'
                          151 silly reify ]
                          152 silly reify mark retired [
                          152 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless'
                          152 silly reify ]
                          153 silly reify mark retired [
                          153 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'
                          153 silly reify ]
                          154 silly reify mark retired [
                          154 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request'
                          154 silly reify ]
                          155 silly reify mark retired [
                          155 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie'
                          155 silly reify ]
                          156 silly reify mark retired [
                          156 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk',
                          156 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv',
                          156 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign',
                          156 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify'
                          156 silly reify ]
                          157 silly reify moves {
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ajv-JWAHQ164',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asn1-begjjmYE',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.assert-plus-CvwT5c2f',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asynckit-s0phpr5l',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws-sign2-i67xE5NL',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws4-ewgSeGU1',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.axios-2R4cHyIW',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bcrypt-pbkdf-FkcXJSG6',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.caseless-H2SaxUok',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.coffeescript-btitSxqy',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.coffee-Ne3HN5Co',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.cake-vF6kAtwy',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.combined-stream-HoYmPyrw',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.cron-parser-sKzHTBDX',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.dashdash-nWlk69uH',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.debug-A3k10AtD',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.delayed-stream-qacC3mjc',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dewpoint': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.dewpoint-AaQYzDAj',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ecc-jsbn-W1wmyGbT',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extend-pv2WceUi',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extsprintf-l37IDaAf',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-deep-equal-JqieQuGS',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-json-stable-stringify-zZtSpvEn',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/follow-redirects': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.follow-redirects-UwNlikdb',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.forever-agent-hJzMqug0',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.form-data-f5gN4soy',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.getpass-kOCUh1aA',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-schema-rWbJu3Hi',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-validator-eyrBsHVJ',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-signature-oUoVxdIq',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.immediate-mU3gxEZk',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.inherits-n3Ch46Yn',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-typedarray-kgxdw7hd',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isarray-5wOzaH7B',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isstream-kucfBgOe',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsbn-7awNYEqn',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-gJeujQHS',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-traverse-lxkTlMes',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-stringify-safe-6OEF7DXQ',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsonata-sj644a8k',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsprim-Hb03jZ2t',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jszip-E0haUyzW',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lie-rDNcdBdn',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.long-timeout-UsqWplKY',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lru-cache-pTWFZBit',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/luxon': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.luxon-dE07SiDk',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-db-ILNMz48k',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-types-vVlqwvNj',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.minimist-HEtqlfZM',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ms-T3oF4fuS',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-inspect-7uCQsf40',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-inspect-RjTdcqZj',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-schedule-NrCn8xB6',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.oauth-sign-4TUsb1Hr',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pako-rbL7BtOy',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.performance-now-rzc7QsAk',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.picocolors-DQ4TN0mE',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.process-nextick-args-1FsUsOM8',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-from-env': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.proxy-from-env-PQWlh40C',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.psl-P3JlcAO8',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.punycode-l3TLrnOQ',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.readable-stream-DGJrLMhV',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.request-IwHtFKjv',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safe-buffer-GY19LMpy',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safer-buffer-VoLQjGhM',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.semver-Dy7i6zG2',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.setimmediate-rLmz5kvN',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sorted-array-functions-b2PxWBDs',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.string_decoder-QqeclkYI',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.suncalc2-tGRLIVnX',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tough-cookie-msAnSxYU',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tunnel-agent-oUVQRXxE',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tweetnacl-BnSTSyIu',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.typescript-EcwXdkx5',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsc-0PIrZBWg',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsserver-QDbM4cAE',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uri-js-8VwjhWYz',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.util-deprecate-e5GNBBxw',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uuid-0rL1ORyz',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.uuid-gQ53C49H',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.verror-EsRYTvUd',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.virtual-tsc-Z1y2mItj',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wake_on_lan-aA1sq5Hq',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.wake-PZWgBD8w',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yallist-Jj27Vzng',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.request-jbJT2ToX',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.tough-cookie-ZhFQ7n2j',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sshpk-29rDccd4',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-conv-dbhOTJ0f',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-sign-0kGWm4VB',
                          157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-verify-Bif9pYCN'
                          157 silly reify }
                          158 timing reify:retireShallow Completed in 12ms
                          159 timing reify:createSparse Completed in 1ms
                          160 timing reify:loadBundles Completed in 0ms
                          161 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
                          162 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
                          163 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
                          164 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
                          165 timing reifyNode:node_modules/osx-temperature-sensor Completed in 2ms
                          166 timing reifyNode:node_modules/fsevents Completed in 2ms
                          167 silly tarball no local data for iobroker.vis@https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.10.tgz. Extracting by manifest.
                          168 timing reifyNode:node_modules/iobroker.vis/node_modules/ms Completed in 28ms
                          169 timing reifyNode:node_modules/iobroker.vis/node_modules/jwa Completed in 28ms
                          170 timing reifyNode:node_modules/iobroker.vis/node_modules/semver Completed in 30ms
                          171 timing reifyNode:node_modules/iobroker.vis/node_modules/jws Completed in 30ms
                          172 timing reifyNode:node_modules/iobroker.vis/node_modules/jsonwebtoken Completed in 32ms
                          173 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 36ms
                          174 http fetch GET 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.10.tgz 6369ms (cache miss)
                          175 timing reifyNode:node_modules/iobroker.vis Completed in 6375ms
                          176 timing reify:unpack Completed in 6376ms
                          177 timing reify:unretire Completed in 1ms
                          178 timing build:queue Completed in 1ms
                          179 timing build:link:node_modules/iobroker.vis/node_modules/semver Completed in 2ms
                          180 timing build:link Completed in 2ms
                          181 info run iobroker.vis@1.4.10 install node_modules/iobroker.vis node main.js --install
                          182 info run iobroker.vis@1.4.10 install { code: 6, signal: null }
                          183 timing reify:rollback:createSparse Completed in 22ms
                          184 timing reify:rollback:retireShallow Completed in 5ms
                          185 timing command:install Completed in 10973ms
                          186 verbose stack Error: command failed
                          186 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
                          186 verbose stack     at ChildProcess.emit (node:events:514:28)
                          186 verbose stack     at maybeClose (node:internal/child_process:1091:16)
                          186 verbose stack     at ChildProcess._handle.onexit (node:internal/child_process:302:5)
                          187 verbose pkgid iobroker.vis@1.4.10
                          188 verbose cwd /opt/iobroker
                          189 verbose Linux 5.15.102-1-pve
                          190 verbose node v18.17.1
                          191 verbose npm  v9.6.7
                          192 error code 6
                          193 error path /opt/iobroker/node_modules/iobroker.vis
                          194 error command failed
                          195 error command sh -c node main.js --install
                          196 verbose exit 6
                          197 timing npm Completed in 11133ms
                          198 verbose unfinished npm timer reify 1694526790712
                          199 verbose unfinished npm timer reify:build 1694526799454
                          200 verbose unfinished npm timer build 1694526799455
                          201 verbose unfinished npm timer build:deps 1694526799455
                          202 verbose unfinished npm timer build:run:install 1694526799459
                          203 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1694526799459
                          204 verbose code 6
                          205 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-12T13_53_10_553Z-debug-0.log
                          und einmal
                          3 timing npm:load:whichnode Completed in 6ms
                          4 timing config:load:defaults Completed in 2ms
                          6 timing config:load:builtin Completed in 0ms
                          7 timing config:load:cli Completed in 2ms
                          9 timing config:load:file:/.npmrc Completed in 0ms
                          10 timing config:load:project Completed in 1ms
                          11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
                          12 timing config:load:user Completed in 1ms
                          16 timing config:load Completed in 8ms
                          17 timing npm:load:configload Completed in 8ms
                          18 timing npm:load:mkdirpcache Completed in 0ms
                          21 verbose argv "--version"
                          25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-09-12T13_54_41_911Z-
                          26 verbose logfile /home/iobroker/.npm/_logs/2023-09-12T13_54_41_911Z-debug-0.log
                          27 timing npm:load:logFile Completed in 10ms
                          30 timing npm:load Completed in 28ms
                          31 verbose exit 0
                          32 timing npm Completed in 33ms
                          33 info ok
                            Ubuntu 23.04
                            Swap: 0B 0B 0B
                            debug: daswetter.0
                            crunchipC Offline
                            crunchipC Offline
                            @thomas-braun sagte in Vis Adapter nach Backup mit Fehlermeldung:
                            nur 9 Monate
                            bis Januar 2024
                            ich würde einfach neu aufsetzen mit dem passenden OS und backup einspielen, bevor da jetzt lang rum gesucht wird
                            Swap: 0B 0B 0B
                            deswegen wird dir wahrscheinlich der LXC abgeschmiert sein
                            • J Offline
                              Jacke
                              so mit
                              nils@IoBroker:~$ iob install vis@1.4.6 --debug
                              NPM version: 9.6.7
                              Installing iobroker.vis@1.4.6... (System call)
                              added 6 packages, and removed 91 packages in 7s
                              173 packages are looking for funding
                                run `npm fund` for details
                              host.IoBroker install adapter vis@1.4.6
                              upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                              upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                              upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                              upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                              upload [323] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                              upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/checkbox.png icon/checkbox.png image/png
                              upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/img/camera.png img/camera.png image/png
                              upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/128/png.png js/fm/icon/mine/128/png.png image/png
                              upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/css/farbtastic.css lib/css/farbtastic.css text/css
                              upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/signals/online.png signals/online.png image/png
                              upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ContainerView.png widgets/basic/img/Prev_ContainerView.png image/png
                              upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_Shape.png widgets/basic/img/Prev_Shape.png image/png
                              upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueBoolCtrlSvg.png widgets/basic/img/Prev_ValueBoolCtrlSvg.png image/png
                              upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueString.png widgets/basic/img/Prev_ValueString.png image/png
                              upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/micInactive.svg widgets/basic/img/micInactive.svg image/svg+xml
                              upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/info/js/words.js widgets/info/js/words.js application/javascript
                              upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui/img/Prev_ContainerDialogExternal.png widgets/jqui/img/Prev_ContainerDialogExternal.png image/png
                              upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Swipe.png widgets/swipe/img/Prev_Swipe.png image/png
                              upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/noSwipe.jpg widgets/swipe/img/noSwipe.jpg image/jpeg
                              upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout-shapes.js widgets/swipe/js/jquery.roundabout-shapes.js application/javascript
                              upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js widgets/swipe/js/jquery.roundabout.min.js application/javascript
                              upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
                              upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html text/html
                              upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
                              upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png widgets/tabs/styles/images/indicator.png image/png
                              upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActive.png widgets/tabs/styles/images/indicatorActive.png image/png
                              upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
                              upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow.png widgets/tabs/styles/images/leftPanelArrow.png image/png
                              upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
                              upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow.png widgets/tabs/styles/images/rightPanelArrow.png image/png
                              upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
                              upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css.orig widgets/tabs/styles/jquery.sliderTabs.css.orig false
                              upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
                              upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
                              upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
                              upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/homematic.html text/html
                              upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
                              upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/weather.html text/html
                              host.IoBroker object system.adapter.vis created/updated
                              Update "system.adapter.vis.0"
                              hat es geklappt und danach habe ich auf 1.4.16 aktualisiert
                              jetzt läuft es.
                              @crunchip
                              das komische war der LXC ließ sich auch nicht mehr starten. ich lasse jetzt erstmal die Ubuntu laufen und versuche es nochmal mit Debian mit Swap und mehr speicher.
                              • J Jacke
                                so mit
                                NPM version: 9.6.7
                                jetzt läuft es.
                                @crunchip
                                crunchipC Offline
                                crunchipC Offline
                                @jacke sagte in Vis Adapter nach Backup mit Fehlermeldung:
                                aber vor dem backup zurückspielen, vis normal installieren
                                  @crunchip sagte in Vis Adapter nach Backup mit Fehlermeldung:
                                  aber vor dem backup vis normal installieren
                                  RESTORE
                                    RESTORE
                                    crunchipC Offline
                                    crunchipC Offline
                                    @homoran habs Wort zurückspielen vergessen und oben korrigiert
