  4. Vis Adapter nach Backup mit Fehlermeldung
    1.0k
    6.1k
24 Beiträge 4 Kommentatoren 3.3k Aufrufe 3 Beobachtet
  • J Offline
    Jacke
    Hallo ich habe mein System neu aufgesetzt. Und beim Vis Adapter kommt folgende Fehlermeldung
    $ iobroker add vis --host IoBroker
    NPM version: 9.6.7
    Installing iobroker.vis@1.1.1... (System call)
    npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! node:internal/modules/cjs/loader:1080npm ERR! throw err;npm ERR! ^npm ERR! npm ERR! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'npm ERR! Require stack:npm ERR! - /opt/iobroker/node_modules/iobroker.vis/lib/utils.jsnpm ERR! - /opt/iobroker/node_modules/iobroker.vis/main.jsnpm ERR! at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)npm ERR! at Module._load (node:internal/modules/cjs/loader:922:27)npm ERR! at Module.require (node:internal/modules/cjs/loader:1143:19)npm ERR! at require (node:internal/modules/cjs/helpers:121:18)npm ERR! at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.vis/lib/utils.js:63:25)npm ERR! at Module._compile (node:internal/modules/cjs/loader:1256:14)npm ERR! at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)npm ERR! at Module.load (node:internal/modules/cjs/loader:1119:32)npm ERR! at Module._load (node:internal/modules/cjs/loader:960:12)npm ERR! at Module.require (node:internal/modules/cjs/loader:1143:19) {npm ERR! code: 'MODULE_NOT_FOUND',npm ERR! requireStack: [npm ERR! '/opt/iobroker/node_modules/iobroker.vis/lib/utils.js',npm ERR! '/opt/iobroker/node_modules/iobroker.vis/main.js'npm ERR! ]npm ERR! }npm ERR! npm ERR! Node.js v18.17.1npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-12T12_29_48_543Z-debug-0.log
    host.IoBroker Cannot install iobroker.vis@1.1.1: 1
    ERROR: Process exited with code 25
    Hat jemand eine Idee?
    • J Jacke
      NPM version: 9.6.7
      @jacke sagte in Vis Adapter nach Backup mit Fehlermeldung:
      hast du vor dem Restore vis manuell installiert?
        Jacke
        ich meine ja habe es heute schon fünfmal neu aufgesetzt weil irgend etwas immer nicht funktioniert hat. Bitte nicht nochmal installieren. bei den ersten mal ist die LXC immer abgestürzt.
        Ich wollte von node 16 auf 18 auf meinem produktiv system. da leif dann aber s7 nicht. also habe ich mal einen neuen container aufgemacht, hier ging s7 dann. ich kam von ubuntu 21.04 auf debian 12. dann habe ich mein Backup eingespielt und der Proxmox Container ist gecrasht und ließ sich nicht mehr starten. mit Ubuntu 23 ging es jetzt bis auf vis und ESP Home
        HomoranH crunchipC 2 Antworten Letzte Antwort
        • J Jacke
          @jacke ich weiss nicht was du mir sagen willst!
          Vielleicht ist die Ausgabe von iob diag hilfreich
          allerdings sind mir
          die LXC
          zu suspekt. da kenne ich mich nicht aus
          • J Jacke
            NPM version: 9.6.7
            Mit --debug installieren.
            • J Jacke
              crunchipC Offline
              crunchipC Offline
              hätte möglicherweise ein iobroker rebuild <adaptername> --install geholfen
              log Ausgabe im Proxmox?
                Jacke
                @thomas-braun ok im terminal wie würde der Befehl aussehen
                npn install iobroker.vis --debug
                crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                • J Jacke
                  crunchipC Offline
                  crunchipC Offline
                  npn
                  is falsch
                  • J Jacke
                    Am besten von npm ganz die Finger lassen.
                    iobroker add vis --host DEINHOSTNAME --debug
                      Jacke
                      Hatte das schon eingegeben
                      nils@IoBroker:~$ iobroker install iobroker.vis --debug
                      NPM version: 9.6.7
                      npm ERR! code 1
                      npm ERR!   throw err;
                      npm ERR!   ^
                      npm ERR!
                      npm ERR!   ]
                      npm ERR! }
                      npm ERR!
                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-12T13_28_36_864Z-debug-0.log
                      npm ERR! code 1
                      npm ERR!   throw err;
                      npm ERR!   ^
                      npm ERR!
                      npm ERR!   ]
                      npm ERR! }
                      npm ERR!
                      • J Jacke
                        NPM version: 9.6.7
                        npm ERR! code 1
                        npm ERR!   throw err;
                        npm ERR!   ^
                        npm ERR!
                        npm ERR!   ]
                        npm ERR! }
                        npm ERR!
                        npm ERR! code 1
                        npm ERR!   throw err;
                        npm ERR!   ^
                        npm ERR!
                        npm ERR!   ]
                        npm ERR! }
                        npm ERR!
                        @jacke
                        iob diag
                        in der Langfassung bitte.
                        • J Jacke
                          NPM version: 9.6.7
                          npm ERR! code 1
                          npm ERR!   throw err;
                          npm ERR!   ^
                          npm ERR!
                          npm ERR!   ]
                          npm ERR! }
                          npm ERR!
                          npm ERR! code 1
                          npm ERR!   throw err;
                          npm ERR!   ^
                          npm ERR!
                          npm ERR!   ]
                          npm ERR! }
                          npm ERR!
                          @jacke wenn dann iob upgrade vis@1.4.10 --debug
                            @jacke
                            iob diag
                            Jacke
                            Skript v.2023-04-16
                            *** BASE SYSTEM ***
                            Architecture    : x86_64
                            Docker          : false
                            Virtualization  : lxc
                            Distributor ID: Ubuntu
                            Description:    Ubuntu 23.04
                            Release:        23.04
                            Codename:       lunar
                            PRETTY_NAME="Ubuntu 23.04"
                            NAME="Ubuntu"
                            VERSION_ID="23.04"
                            VERSION="23.04 (Lunar Lobster)"
                            VERSION_CODENAME=lunar
                            ID=ubuntu
                            ID_LIKE=debian
                            HOME_URL="https://www.ubuntu.com/"
                            SUPPORT_URL="https://help.ubuntu.com/"
                            BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
                            PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
                            UBUNTU_CODENAME=lunar
                            LOGO=ubuntu-logo
                            Systemuptime and Load:
                             15:33:27 up  1:46,  2 users,  load average: 0.99, 1.09, 1.09
                            CPU threads: 2
                            *** Time and Time Zones ***
                                           Local time: Tue 2023-09-12 15:33:27 CEST
                                       Universal time: Tue 2023-09-12 13:33:27 UTC
                                             RTC time: n/a
                                          NTP service: inactive
                                      RTC in local TZ: no
                            *** User and Groups ***
                            nils
                            /home/nils
                            nils sudo users iobroker
                            *** X-Server-Setup ***
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            4.3G        3.4G        418M        143K        459M        878M
                            Swap:             0B          0B          0B
                            Total:          4.3G        3.4G        418M
                                     4096 M total memory
                                     3258 M used memory
                                      252 M active memory
                                     3143 M inactive memory
                                      399 M free memory
                                        0 M buffer memory
                                      438 M swap cache
                                        0 M total swap
                                        0 M used swap
                                        0 M free swap
                            *** FILESYSTEM ***
                            Filesystem                            Type   Size  Used Avail Use% Mounted on
                            /dev/mapper/data_ssd-vm--100--disk--0 ext4    18G  4.7G   13G  28% /
                            none                                  tmpfs  492K  4.0K  488K   1% /dev
                            tmpfs                                 tmpfs   12G     0   12G   0% /dev/shm
                            tmpfs                                 tmpfs  4.7G  136K  4.7G   1% /run
                            tmpfs                                 tmpfs  5.0M     0  5.0M   0% /run/lock
                            tmpfs                                 tmpfs  2.4G     0  2.4G   0% /run/user/1000
                            dmesg: read kernel buffer failed: Operation not permitted
                            TARGET SOURCE                                FSTYPE OPTIONS
                            /      /dev/mapper/data_ssd-vm--100--disk--0 ext4   rw,relatime,stripe=16
                            /var:
                            504M    /var/
                            246M    /var/cache
                            240M    /var/cache/apt
                            233M    /var/lib
                            153M    /var/cache/apt/archives
                            Archived and active journals take up 8.0M in the file system.
                            /opt/iobroker/backups:
                            102M    /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            756M    /opt/iobroker/iobroker-data/
                            398M    /opt/iobroker/iobroker-data/files
                            249M    /opt/iobroker/iobroker-data/esphome.0/.esphome
                            248M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
                            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                            31M     /opt/iobroker/iobroker-data/states.jsonl
                            28M     /opt/iobroker/iobroker-data/objects.jsonl
                            24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/grillthermometer/.pioenvs/grillthermometer/firmware.elf
                            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.67295ba8.js.map
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Installed: 18.17.1-deb-1nodesource1
                              Candidate: 18.17.1-deb-1nodesource1
                              Version table:
                             *** 18.17.1-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_18.x lunar/main amd64 Packages
                                 18.13.0+dfsg1-1ubuntu2 500
                                    500 http://archive.ubuntu.com/ubuntu lunar/universe amd64 Packages
                            No problems detected
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            js-controller:  5.0.12
                            admin:          6.5.8
                            javascript:     7.1.4
                            Adapters from github:   1
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
                            + system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
                              system.adapter.awattar.0                : awattar               : IoBroker                                 - disabled
                            + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                              system.adapter.daswetter.0              : daswetter             : IoBroker                                 -  enabled
                              system.adapter.devices.0                : devices               : IoBroker                                 - disabled
                              system.adapter.discovery.0              : discovery             : IoBroker                                 - disabled
                            + system.adapter.energiefluss.0           : energiefluss          : IoBroker                                 -  enabled
                              system.adapter.esphome.0                : esphome               : IoBroker                                 - disabled
                              system.adapter.fb-checkpresence.0       : fb-checkpresence      : IoBroker                                 - disabled
                              system.adapter.flot.0                   : flot                  : IoBroker                                 - disabled
                            + system.adapter.heatingcontrol.0         : heatingcontrol        : IoBroker                                 -  enabled
                            + system.adapter.history.0                : history               : IoBroker                                 -  enabled
                              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: IoBroker                                 - disabled
                              system.adapter.icons-icons8.0           : icons-icons8          : IoBroker                                 - disabled
                              system.adapter.icons-material-png.0     : icons-material-png    : IoBroker                                 - disabled
                              system.adapter.icons-material-svg.0     : icons-material-svg    : IoBroker                                 - disabled
                              system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoBroker                                 - disabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IoBroker                                 - disabled
                            + system.adapter.influxdb.0               : influxdb              : IoBroker                                 -  enabled, port: 8086
                            + system.adapter.info.0                   : info                  : IoBroker                                 -  enabled
                            + system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
                            + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
                            + system.adapter.melcloud.0               : melcloud              : IoBroker                                 -  enabled
                            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
                            + system.adapter.modbus.1                 : modbus                : IoBroker                                 -  enabled
                            + system.adapter.mqtt-client.0            : mqtt-client           : IoBroker                                 -  enabled, port: 1883
                            + system.adapter.mqtt.1                   : mqtt                  : IoBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.mqtt.2                   : mqtt                  : IoBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                            + system.adapter.node-red.0               : node-red              : IoBroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                            + system.adapter.ping.0                   : ping                  : IoBroker                                 -  enabled
                            + system.adapter.proxmox.0                : proxmox               : IoBroker                                 -  enabled, port: 8006
                            + system.adapter.pvforecast.0             : pvforecast            : IoBroker                                 -  enabled
                            + system.adapter.pvforecast.1             : pvforecast            : IoBroker                                 -  enabled
                            + system.adapter.ring.0                   : ring                  : IoBroker                                 -  enabled
                            + system.adapter.s7.0                     : s7                    : IoBroker                                 -  enabled
                              system.adapter.scenes.0                 : scenes                : IoBroker                                 - disabled
                            + system.adapter.shelly.0                 : shelly                : IoBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                              system.adapter.socketio.0               : socketio              : IoBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                            + system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.sourceanalytix.0         : sourceanalytix        : IoBroker                                 -  enabled
                            + system.adapter.sql.0                    : sql                   : IoBroker                                 -  enabled
                            + system.adapter.telegram.0               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.telegram.1               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.text2command.0           : text2command          : IoBroker                                 -  enabled
                              system.adapter.vis.0                    : vis                   : IoBroker                                 - disabled
                              system.adapter.weatherunderground.0     : weatherunderground    : IoBroker                                 -  enabled
                            + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + system.adapter.windows-control.0        : windows-control       : IoBroker                                 -  enabled
                            + system.adapter.worx.0                   : worx                  : IoBroker                                 -  enabled
                            + system.adapter.zigbee.1                 : zigbee                : IoBroker                                 -  enabled, port: tcp://192.168.1.145:5000
                            + instance is alive
                            ioBroker-Repositories
                            default       : http://download.iobroker.net/sources-dist-latest.json
                            latest        : http://download.iobroker.net/sources-dist.json
                            Active repo(s): default, latest
                            Installed ioBroker-Instances
                            Used repositories: default, latest
                            a Objects database error: read ECONNRESET
                             States database error: connect ECONNREFUSED 0.0.0.0:9000
                             Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                            Adapter    "admin"        : 6.8.0    , installed 6.5.8  [Updatable]
                            Adapter    "alexa2"       : 3.24.1   , installed 3.25.1
                            Adapter    "awattar"      : 1.0.6    , installed 1.0.6
                            Adapter    "backitup"     : 2.6.23   , installed 2.7.0
                            Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                            Adapter    "devices"      : 1.1.5    , installed 1.1.5
                            Adapter    "discovery"    : 3.1.0    , installed 4.0.0
                            Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                            Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                            Adapter    "history"      : 2.2.6    , installed 2.2.6
                            Adapter    "info"         : 1.9.26   , installed 2.0.0
                            Adapter    "iot"          : 1.14.5   , installed 2.0.11
                            Adapter    "javascript"   : 7.0.3    , installed 7.1.4
                            Controller "js-controller": 4.0.24   , installed 5.0.12
                            Adapter    "melcloud"     : 1.3.5    , installed 1.3.5
                            Adapter    "mihome-vacuum": 3.11.0   , installed 4.0.0
                            Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                            Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                            Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.4
                            Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                            Adapter    "proxmox"      : 1.3.5    , installed 2.0.2
                            Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
                            Adapter    "ring"         : 3.2.2    , installed 3.4.1
                            Adapter    "s7"           : 1.3.15   , installed 1.3.15
                            Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                            Adapter    "socketio"     : 6.5.3    , installed 6.5.3
                            Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
                            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                            Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                            Adapter    "text2command" : 3.0.2    , installed 3.0.2
                            Adapter    "weatherunderground": 3.4.2, installed 3.6.0
                            Adapter    "web"          : 6.1.1    , installed 6.1.1
                            Adapter    "windows-control": 0.1.5  , installed 0.1.5
                            Adapter    "worx"         : 2.3.2    , installed 2.3.2
                            Adapter    "ws"           : 2.5.4    , installed 2.5.3  [Updatable]
                            Adapter    "zigbee"       : 1.8.23   , installed 1.8.24
                            Objects and States
                            Objects:        21779
                            States:         15752
                            aHit:1 https://deb.nodesource.com/node_18.x lunar InRelease
                            Hit:2 http://archive.ubuntu.com/ubuntu lunar InRelease
                            Hit:3 http://archive.ubuntu.com/ubuntu lunar-updates InRelease
                            Hit:4 http://archive.ubuntu.com/ubuntu lunar-security InRelease
                            Reading package lists...
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        791290896  102/systemd-resolve
                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          791292090  311/master
                            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       791957309  119661/iobroker.js-
                            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       791957316  119661/iobroker.js-
                            tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        791290898  102/systemd-resolve
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          791289333  1/init
                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          791292091  311/master
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          791289335  1/init
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          791289693  1/init
                            Skript v.2023-04-16
                            *** BASE SYSTEM ***
                            Docker          : false
                            Release:        23.04
                            Codename:       lunar
                            NAME="Ubuntu"
                            VERSION_ID="23.04"
                            ID=ubuntu
                            ID_LIKE=debian
                            LOGO=ubuntu-logo
                             15:35:36 up  1:48,  2 users,  load average: 8.31, 5.39, 2.77
                            CPU threads: 2
                                           Local time: Tue 2023-09-12 15:35:36 CEST
                                       Universal time: Tue 2023-09-12 13:35:36 UTC
                                             RTC time: n/a
                                      RTC in local TZ: no
                            nils
                            /home/nils
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            4.3G        2.2G        1.4G        143K        688M        2.1G
                            Swap:             0B          0B          0B
                            Total:          4.3G        2.2G        1.4G
                                     4096 M total memory
                                     2100 M used memory
                                      301 M active memory
                                     2368 M inactive memory
                                     1338 M free memory
                                        0 M buffer memory
                                      656 M swap cache
                                        0 M total swap
                                        0 M used swap
                                        0 M free swap
                            *** FILESYSTEM ***
                            /dev/mapper/data_ssd-vm--100--disk--0 ext4    18G  4.7G   12G  29% /
                            /var:
                            504M    /var/
                            246M    /var/cache
                            240M    /var/cache/apt
                            233M    /var/lib
                            764M    /opt/iobroker/iobroker-data/
                            36M     /opt/iobroker/iobroker-data/objects.jsonl
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.5.8
                            javascript:     7.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        21785
                            States:         15809
                            Pending Updates: 0
                            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       791965434  120858/node-red
                            tcp6       0      0 :::8086                 :::*                    LISTEN      1001       791965010  120494/io.admin.0
                            udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        791290897  102/systemd-resolve
                            udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        791290895  102/systemd-resolve
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          791289334  1/init
                            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       791969211  121288/io.mihome-va
                            udp6       0      0 :::111                  :::*                                0          791289336  1/init
                            2023-09-12 15:36:08.673  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.symbol_desc2 with Bewölkt mit leichtem Regen
                            2023-09-12 15:36:08.676  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.symbol_value2 with 6
                            2023-09-12 15:36:08.710  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.symbol_desc with Bewölkt mit leichtem Regen
                            2023-09-12 15:36:08.711  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.symbol_value with 6
                            2023-09-12 15:36:08.716  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.iconURL with /adapter/daswetter/icons/tiempo-weather/galeria1/6.png
                            2023-09-12 15:36:08.772  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.wind_symbolB with 40
                            2023-09-12 15:36:08.798  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.wind_symbol with 16
                            2023-09-12 15:36:08.800  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.wind_dir with NW
                            2023-09-12 15:36:08.804  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.wind_value with 5 km/h
                            2023-09-12 15:36:08.967  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.windIconURL with /adapter/daswetter/icons/viento-wind/undefined/40.png
                            2023-09-12 15:36:09.046  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.windgusts_value with 26 km/h
                            2023-09-12 15:36:09.122  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.rain_value with 0.4 mm
                            2023-09-12 15:36:09.125  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.humidity_value with 97
                            2023-09-12 15:36:09.127  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.pressure_value with 1013 mb
                            2023-09-12 15:36:09.146  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.clouds_value with 58%
                            2023-09-12 15:36:09.263  - warn: modbus.1 (121314) Poll error count: 1 code: {"errorCode":131,"exceptionCode":10,"message":"GATEWAY PATH UNAVAILABLE"}
                            2023-09-12 15:36:09.281  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.snowline_value with 3600 m
                            2023-09-12 15:36:09.301  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.uv_index_value with 0
                            2023-09-12 15:36:09.303  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_8.windchill_value with 17 °C
                            2023-09-12 15:36:09.307  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9 with null  {"type":"channel","common":{"name":"Hour 9","role":"weather"}}
                            2023-09-12 15:36:09.407  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.current with null  {"type":"channel","common":{"name":"current ","role":"weather"}}
                            2023-09-12 15:36:09.429  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9.hour_value with 09:00
                            2023-09-12 15:36:09.527  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9.temp_value with 18 °C
                            2023-09-12 15:36:09.544  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9.symbol_desc2 with Bewölkt
                            2023-09-12 15:36:09.569  - debug: daswetter.0 (121421) insert NextHours.Location_1.Day_1.Hour_9.symbol_value2 with 3
                            iob diag has finished.
                            Press any key for a summary
                              Jacke
                              @homoran said in Vis Adapter nach Backup mit Fehlermeldung:
                              nils@IoBroker:~$ iob upgrade vis@1.4.10 --debug
                              Adapter "vis"            is not installed.
                              kommt dann
                              • J Jacke
                                kommt dann
                                @jacke dann iob install vis@1.4.10 --debug
                                • J Jacke
                                  Skript v.2023-04-16
                                  *** BASE SYSTEM ***
                                  Docker          : false
                                  Release:        23.04
                                  Codename:       lunar
                                  NAME="Ubuntu"
                                  VERSION_ID="23.04"
                                  ID=ubuntu
                                  ID_LIKE=debian
                                  LOGO=ubuntu-logo
                                  CPU threads: 2
                                                   RTC time: n/a
                                            RTC in local TZ: no
                                  nils
                                  /home/nils
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:             0B          0B          0B
                                           4096 M total memory
                                           3258 M used memory
                                            252 M active memory
                                            399 M free memory
                                              0 M buffer memory
                                            438 M swap cache
                                              0 M total swap
                                              0 M used swap
                                              0 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  504M    /var/
                                  246M    /var/cache
                                  240M    /var/cache/apt
                                  233M    /var/lib
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.5.8
                                  javascript:     7.1.4
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        21779
                                  States:         15752
                                  Pending Updates: 0
                                  Skript v.2023-04-16
                                  *** BASE SYSTEM ***
                                  Docker          : false
                                  Release:        23.04
                                  Codename:       lunar
                                  NAME="Ubuntu"
                                  VERSION_ID="23.04"
                                  ID=ubuntu
                                  ID_LIKE=debian
                                  LOGO=ubuntu-logo
                                  CPU threads: 2
                                                   RTC time: n/a
                                            RTC in local TZ: no
                                  nils
                                  /home/nils
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:             0B          0B          0B
                                           4096 M total memory
                                           2100 M used memory
                                            301 M active memory
                                           1338 M free memory
                                              0 M buffer memory
                                            656 M swap cache
                                              0 M total swap
                                              0 M used swap
                                              0 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  504M    /var/
                                  246M    /var/cache
                                  240M    /var/cache/apt
                                  233M    /var/lib
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.5.8
                                  javascript:     7.1.4
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        21785
                                  States:         15809
                                  Pending Updates: 0
                                  Ubuntu 23.04
                                  Ich hätte ja die LTS-Version genommen. Diese Interims-Releases bei ubuntu leben nur 9 Monate. Oder halt gleich das 'Original'-Debian in aktueller Fassung.
                                  Swap: 0B 0B 0B
                                  Swap auch nicht vollständig deaktivieren. Das wird u. U. benötigt.
                                  Setz den 'nils' in die Gruppe 'adm'.
                                  Entweder/Oder. Beide Repos pallel aktiv sorgt ggf. für Trouble.
                                  debug: daswetter.0
                                  Setze Instanzen nur auf debug, wenn du das auch tust. Ansonsten ballert es dir nur das LogFile zu.
                                    Jacke
                                    dann kommt wieder diese fehlermeldung
                                    NPM version: 9.6.7
                                    Installing iobroker.vis@1.4.10... (System call)
                                    npm ERR! code 6
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-12T13_53_10_553Z-debug-0.log
                                    npm ERR! code 6
                                    host.IoBroker Cannot install iobroker.vis@1.4.10: 6
                                    • J Jacke
                                      NPM version: 9.6.7
                                      npm ERR! code 6
                                      npm ERR! code 6
                                      Was steht da drin?
                                      • J Offline
                                        Jacke
                                        0 verbose cli /usr/bin/node /usr/bin/npm
                                        1 info using npm@9.6.7
                                        2 info using node@v18.17.1
                                        3 timing npm:load:whichnode Completed in 1ms
                                        4 timing config:load:defaults Completed in 1ms
                                        5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 0ms
                                        6 timing config:load:builtin Completed in 1ms
                                        7 timing config:load:cli Completed in 1ms
                                        8 timing config:load:env Completed in 0ms
                                        9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
                                        10 timing config:load:project Completed in 2ms
                                        11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                                        12 timing config:load:user Completed in 0ms
                                        13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                                        14 timing config:load:global Completed in 0ms
                                        15 timing config:load:setEnvs Completed in 1ms
                                        16 timing config:load Completed in 7ms
                                        17 timing npm:load:configload Completed in 7ms
                                        18 timing npm:load:mkdirpcache Completed in 1ms
                                        19 timing npm:load:mkdirplogs Completed in 0ms
                                        20 verbose title npm install iobroker.vis@1.4.10
                                        21 verbose argv "install" "--save-exact" "iobroker.vis@1.4.10"
                                        22 timing npm:load:setTitle Completed in 1ms
                                        23 timing config:load:flatten Completed in 2ms
                                        24 timing npm:load:display Completed in 3ms
                                        25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-09-12T13_53_10_553Z-
                                        26 verbose logfile /home/iobroker/.npm/_logs/2023-09-12T13_53_10_553Z-debug-0.log
                                        27 timing npm:load:logFile Completed in 7ms
                                        28 timing npm:load:timers Completed in 0ms
                                        29 timing npm:load:configScope Completed in 0ms
                                        30 timing npm:load Completed in 20ms
                                        31 timing arborist:ctor Completed in 1ms
                                        32 silly logfile start cleaning logs, removing 5 files
                                        33 timing idealTree:init Completed in 985ms
                                        34 timing idealTree:userRequests Completed in 8ms
                                        35 silly idealTree buildDeps
                                        36 silly fetch manifest iobroker.vis@1.4.10
                                        37 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                                        38 silly logfile done cleaning log files
                                        39 http fetch GET 200 https://registry.npmjs.org/iobroker.vis 1057ms (cache revalidated)
                                        40 silly placeDep ROOT iobroker.vis@1.4.10 OK for: iobroker.inst@3.0.0 want: 1.4.10
                                        41 silly fetch manifest jsonwebtoken@^8.5.1
                                        42 silly fetch manifest axios@^0.24.0
                                        43 http fetch GET 200 https://registry.npmjs.org/jsonwebtoken 59ms (cache revalidated)
                                        44 http fetch GET 200 https://registry.npmjs.org/axios 107ms (cache revalidated)
                                        45 timing idealTree:#root Completed in 1180ms
                                        46 silly placeDep node_modules/iobroker.vis axios@0.24.0 OK for: iobroker.vis@1.4.10 want: ^0.24.0
                                        47 silly placeDep node_modules/iobroker.vis jsonwebtoken@8.5.1 OK for: iobroker.vis@1.4.10 want: ^8.5.1
                                        48 silly fetch manifest jws@^3.2.2
                                        49 silly fetch manifest ms@^2.1.1
                                        50 silly fetch manifest semver@^5.6.0
                                        51 http fetch GET 200 https://registry.npmjs.org/ms 39ms (cache revalidated)
                                        52 http fetch GET 200 https://registry.npmjs.org/jws 45ms (cache revalidated)
                                        53 http fetch GET 200 https://registry.npmjs.org/semver 85ms (cache revalidated)
                                        54 timing idealTree:node_modules/iobroker.vis Completed in 91ms
                                        55 timing idealTree:node_modules/iobroker.vis/node_modules/axios Completed in 0ms
                                        56 silly placeDep node_modules/iobroker.vis jws@3.2.2 OK for: jsonwebtoken@8.5.1 want: ^3.2.2
                                        57 silly fetch manifest jwa@^1.4.1
                                        58 silly placeDep node_modules/iobroker.vis ms@2.1.3 OK for: jsonwebtoken@8.5.1 want: ^2.1.1
                                        59 silly placeDep node_modules/iobroker.vis semver@5.7.2 OK for: jsonwebtoken@8.5.1 want: ^5.6.0
                                        60 http fetch GET 200 https://registry.npmjs.org/jwa 36ms (cache revalidated)
                                        61 timing idealTree:node_modules/iobroker.vis/node_modules/jsonwebtoken Completed in 40ms
                                        62 silly placeDep node_modules/iobroker.vis jwa@1.4.1 OK for: jws@3.2.2 want: ^1.4.1
                                        63 timing idealTree:node_modules/iobroker.vis/node_modules/jws Completed in 2ms
                                        64 timing idealTree:node_modules/iobroker.vis/node_modules/jwa Completed in 0ms
                                        65 timing idealTree:node_modules/iobroker.vis/node_modules/ms Completed in 0ms
                                        66 timing idealTree:node_modules/iobroker.vis/node_modules/semver Completed in 0ms
                                        67 timing idealTree:buildDeps Completed in 1313ms
                                        68 timing idealTree:fixDepFlags Completed in 8ms
                                        69 timing idealTree Completed in 2323ms
                                        70 timing reify:loadTrees Completed in 2324ms
                                        71 timing reify:diffTrees Completed in 26ms
                                        72 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv' ]
                                        73 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1' ]
                                        74 silly reify mark retired [
                                        74 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus'
                                        74 silly reify ]
                                        75 silly reify mark retired [
                                        75 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit'
                                        75 silly reify ]
                                        76 silly reify mark retired [
                                        76 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2'
                                        76 silly reify ]
                                        77 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4' ]
                                        78 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios' ]
                                        79 silly reify mark retired [
                                        79 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf'
                                        79 silly reify ]
                                        80 silly reify mark retired [
                                        80 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless'
                                        80 silly reify ]
                                        81 silly reify mark retired [
                                        81 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript',
                                        81 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee',
                                        81 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake'
                                        81 silly reify ]
                                        82 silly reify mark retired [
                                        82 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream'
                                        82 silly reify ]
                                        83 silly reify mark retired [
                                        83 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is'
                                        83 silly reify ]
                                        84 silly reify mark retired [
                                        84 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser'
                                        84 silly reify ]
                                        85 silly reify mark retired [
                                        85 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash'
                                        85 silly reify ]
                                        86 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug' ]
                                        87 silly reify mark retired [
                                        87 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream'
                                        87 silly reify ]
                                        88 silly reify mark retired [
                                        88 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dewpoint'
                                        88 silly reify ]
                                        89 silly reify mark retired [
                                        89 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn'
                                        89 silly reify ]
                                        90 silly reify mark retired [
                                        90 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend'
                                        90 silly reify ]
                                        91 silly reify mark retired [
                                        91 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf'
                                        91 silly reify ]
                                        92 silly reify mark retired [
                                        92 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal'
                                        92 silly reify ]
                                        93 silly reify mark retired [
                                        93 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify'
                                        93 silly reify ]
                                        94 silly reify mark retired [
                                        94 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/follow-redirects'
                                        94 silly reify ]
                                        95 silly reify mark retired [
                                        95 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent'
                                        95 silly reify ]
                                        96 silly reify mark retired [
                                        96 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data'
                                        96 silly reify ]
                                        97 silly reify mark retired [
                                        97 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass'
                                        97 silly reify ]
                                        98 silly reify mark retired [
                                        98 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema'
                                        98 silly reify ]
                                        99 silly reify mark retired [
                                        99 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator'
                                        99 silly reify ]
                                        100 silly reify mark retired [
                                        100 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature'
                                        100 silly reify ]
                                        101 silly reify mark retired [
                                        101 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate'
                                        101 silly reify ]
                                        102 silly reify mark retired [
                                        102 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits'
                                        102 silly reify ]
                                        103 silly reify mark retired [
                                        103 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray'
                                        103 silly reify ]
                                        104 silly reify mark retired [
                                        104 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray'
                                        104 silly reify ]
                                        105 silly reify mark retired [
                                        105 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream'
                                        105 silly reify ]
                                        106 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn' ]
                                        107 silly reify mark retired [
                                        107 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema'
                                        107 silly reify ]
                                        108 silly reify mark retired [
                                        108 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse'
                                        108 silly reify ]
                                        109 silly reify mark retired [
                                        109 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe'
                                        109 silly reify ]
                                        110 silly reify mark retired [
                                        110 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata'
                                        110 silly reify ]
                                        111 silly reify mark retired [
                                        111 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim'
                                        111 silly reify ]
                                        112 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip' ]
                                        113 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie' ]
                                        114 silly reify mark retired [
                                        114 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout'
                                        114 silly reify ]
                                        115 silly reify mark retired [
                                        115 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache'
                                        115 silly reify ]
                                        116 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/luxon' ]
                                        117 silly reify mark retired [
                                        117 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db'
                                        117 silly reify ]
                                        118 silly reify mark retired [
                                        118 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types'
                                        118 silly reify ]
                                        119 silly reify mark retired [
                                        119 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist'
                                        119 silly reify ]
                                        120 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms' ]
                                        121 silly reify mark retired [
                                        121 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect',
                                        121 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect'
                                        121 silly reify ]
                                        122 silly reify mark retired [
                                        122 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule'
                                        122 silly reify ]
                                        123 silly reify mark retired [
                                        123 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign'
                                        123 silly reify ]
                                        124 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako' ]
                                        125 silly reify mark retired [
                                        125 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now'
                                        125 silly reify ]
                                        126 silly reify mark retired [
                                        126 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors'
                                        126 silly reify ]
                                        127 silly reify mark retired [
                                        127 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args'
                                        127 silly reify ]
                                        128 silly reify mark retired [
                                        128 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-from-env'
                                        128 silly reify ]
                                        129 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl' ]
                                        130 silly reify mark retired [
                                        130 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode'
                                        130 silly reify ]
                                        131 silly reify mark retired [
                                        131 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream'
                                        131 silly reify ]
                                        132 silly reify mark retired [
                                        132 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request'
                                        132 silly reify ]
                                        133 silly reify mark retired [
                                        133 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer'
                                        133 silly reify ]
                                        134 silly reify mark retired [
                                        134 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer'
                                        134 silly reify ]
                                        135 silly reify mark retired [
                                        135 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver',
                                        135 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver'
                                        135 silly reify ]
                                        136 silly reify mark retired [
                                        136 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate'
                                        136 silly reify ]
                                        137 silly reify mark retired [
                                        137 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions'
                                        137 silly reify ]
                                        138 silly reify mark retired [
                                        138 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder'
                                        138 silly reify ]
                                        139 silly reify mark retired [
                                        139 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2'
                                        139 silly reify ]
                                        140 silly reify mark retired [
                                        140 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie'
                                        140 silly reify ]
                                        141 silly reify mark retired [
                                        141 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent'
                                        141 silly reify ]
                                        142 silly reify mark retired [
                                        142 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl'
                                        142 silly reify ]
                                        143 silly reify mark retired [
                                        143 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript',
                                        143 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc',
                                        143 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver'
                                        143 silly reify ]
                                        144 silly reify mark retired [
                                        144 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js'
                                        144 silly reify ]
                                        145 silly reify mark retired [
                                        145 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate'
                                        145 silly reify ]
                                        146 silly reify mark retired [
                                        146 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid',
                                        146 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid'
                                        146 silly reify ]
                                        147 silly reify mark retired [
                                        147 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror'
                                        147 silly reify ]
                                        148 silly reify mark retired [
                                        148 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc'
                                        148 silly reify ]
                                        149 silly reify mark retired [
                                        149 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan',
                                        149 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake'
                                        149 silly reify ]
                                        150 silly reify mark retired [
                                        150 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist'
                                        150 silly reify ]
                                        151 silly reify mark retired [
                                        151 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types'
                                        151 silly reify ]
                                        152 silly reify mark retired [
                                        152 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless'
                                        152 silly reify ]
                                        153 silly reify mark retired [
                                        153 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'
                                        153 silly reify ]
                                        154 silly reify mark retired [
                                        154 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request'
                                        154 silly reify ]
                                        155 silly reify mark retired [
                                        155 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie'
                                        155 silly reify ]
                                        156 silly reify mark retired [
                                        156 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk',
                                        156 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv',
                                        156 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign',
                                        156 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify'
                                        156 silly reify ]
                                        157 silly reify moves {
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ajv-JWAHQ164',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asn1-begjjmYE',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.assert-plus-CvwT5c2f',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asynckit-s0phpr5l',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws-sign2-i67xE5NL',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws4-ewgSeGU1',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.axios-2R4cHyIW',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bcrypt-pbkdf-FkcXJSG6',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.caseless-H2SaxUok',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.coffeescript-btitSxqy',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.coffee-Ne3HN5Co',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.cake-vF6kAtwy',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.combined-stream-HoYmPyrw',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.cron-parser-sKzHTBDX',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.dashdash-nWlk69uH',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.debug-A3k10AtD',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.delayed-stream-qacC3mjc',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dewpoint': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.dewpoint-AaQYzDAj',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ecc-jsbn-W1wmyGbT',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extend-pv2WceUi',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extsprintf-l37IDaAf',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-deep-equal-JqieQuGS',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-json-stable-stringify-zZtSpvEn',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/follow-redirects': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.follow-redirects-UwNlikdb',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.forever-agent-hJzMqug0',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.form-data-f5gN4soy',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.getpass-kOCUh1aA',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-schema-rWbJu3Hi',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-validator-eyrBsHVJ',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-signature-oUoVxdIq',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.immediate-mU3gxEZk',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.inherits-n3Ch46Yn',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-typedarray-kgxdw7hd',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isarray-5wOzaH7B',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isstream-kucfBgOe',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsbn-7awNYEqn',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-gJeujQHS',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-traverse-lxkTlMes',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-stringify-safe-6OEF7DXQ',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsonata-sj644a8k',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsprim-Hb03jZ2t',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jszip-E0haUyzW',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lie-rDNcdBdn',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.long-timeout-UsqWplKY',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lru-cache-pTWFZBit',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/luxon': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.luxon-dE07SiDk',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-db-ILNMz48k',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-types-vVlqwvNj',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.minimist-HEtqlfZM',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ms-T3oF4fuS',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-inspect-7uCQsf40',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-inspect-RjTdcqZj',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-schedule-NrCn8xB6',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.oauth-sign-4TUsb1Hr',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pako-rbL7BtOy',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.performance-now-rzc7QsAk',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.picocolors-DQ4TN0mE',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.process-nextick-args-1FsUsOM8',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-from-env': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.proxy-from-env-PQWlh40C',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.psl-P3JlcAO8',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.punycode-l3TLrnOQ',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.readable-stream-DGJrLMhV',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.request-IwHtFKjv',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safe-buffer-GY19LMpy',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safer-buffer-VoLQjGhM',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.semver-Dy7i6zG2',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.setimmediate-rLmz5kvN',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sorted-array-functions-b2PxWBDs',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.string_decoder-QqeclkYI',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.suncalc2-tGRLIVnX',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tough-cookie-msAnSxYU',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tunnel-agent-oUVQRXxE',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tweetnacl-BnSTSyIu',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.typescript-EcwXdkx5',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsc-0PIrZBWg',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsserver-QDbM4cAE',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uri-js-8VwjhWYz',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.util-deprecate-e5GNBBxw',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uuid-0rL1ORyz',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.uuid-gQ53C49H',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.verror-EsRYTvUd',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.virtual-tsc-Z1y2mItj',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wake_on_lan-aA1sq5Hq',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.wake-PZWgBD8w',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yallist-Jj27Vzng',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.request-jbJT2ToX',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.tough-cookie-ZhFQ7n2j',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sshpk-29rDccd4',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-conv-dbhOTJ0f',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-sign-0kGWm4VB',
                                        157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-verify-Bif9pYCN'
                                        157 silly reify }
                                        158 timing reify:retireShallow Completed in 12ms
                                        159 timing reify:createSparse Completed in 1ms
                                        160 timing reify:loadBundles Completed in 0ms
                                        161 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
                                        162 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
                                        163 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
                                        164 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
                                        165 timing reifyNode:node_modules/osx-temperature-sensor Completed in 2ms
                                        166 timing reifyNode:node_modules/fsevents Completed in 2ms
                                        167 silly tarball no local data for iobroker.vis@https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.10.tgz. Extracting by manifest.
                                        168 timing reifyNode:node_modules/iobroker.vis/node_modules/ms Completed in 28ms
                                        169 timing reifyNode:node_modules/iobroker.vis/node_modules/jwa Completed in 28ms
                                        170 timing reifyNode:node_modules/iobroker.vis/node_modules/semver Completed in 30ms
                                        171 timing reifyNode:node_modules/iobroker.vis/node_modules/jws Completed in 30ms
                                        172 timing reifyNode:node_modules/iobroker.vis/node_modules/jsonwebtoken Completed in 32ms
                                        173 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 36ms
                                        174 http fetch GET 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.10.tgz 6369ms (cache miss)
                                        175 timing reifyNode:node_modules/iobroker.vis Completed in 6375ms
                                        176 timing reify:unpack Completed in 6376ms
                                        177 timing reify:unretire Completed in 1ms
                                        178 timing build:queue Completed in 1ms
                                        179 timing build:link:node_modules/iobroker.vis/node_modules/semver Completed in 2ms
                                        180 timing build:link Completed in 2ms
                                        181 info run iobroker.vis@1.4.10 install node_modules/iobroker.vis node main.js --install
                                        182 info run iobroker.vis@1.4.10 install { code: 6, signal: null }
                                        183 timing reify:rollback:createSparse Completed in 22ms
                                        184 timing reify:rollback:retireShallow Completed in 5ms
                                        185 timing command:install Completed in 10973ms
                                        186 verbose stack Error: command failed
                                        186 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
                                        186 verbose stack     at ChildProcess.emit (node:events:514:28)
                                        186 verbose stack     at maybeClose (node:internal/child_process:1091:16)
                                        186 verbose stack     at ChildProcess._handle.onexit (node:internal/child_process:302:5)
                                        187 verbose pkgid iobroker.vis@1.4.10
                                        188 verbose cwd /opt/iobroker
                                        189 verbose Linux 5.15.102-1-pve
                                        190 verbose node v18.17.1
                                        191 verbose npm  v9.6.7
                                        192 error code 6
                                        193 error path /opt/iobroker/node_modules/iobroker.vis
                                        194 error command failed
                                        195 error command sh -c node main.js --install
                                        196 verbose exit 6
                                        197 timing npm Completed in 11133ms
                                        198 verbose unfinished npm timer reify 1694526790712
                                        199 verbose unfinished npm timer reify:build 1694526799454
                                        200 verbose unfinished npm timer build 1694526799455
                                        201 verbose unfinished npm timer build:deps 1694526799455
                                        202 verbose unfinished npm timer build:run:install 1694526799459
                                        203 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1694526799459
                                        204 verbose code 6
                                        205 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-12T13_53_10_553Z-debug-0.log
                                        und einmal
                                        3 timing npm:load:whichnode Completed in 6ms
                                        4 timing config:load:defaults Completed in 2ms
                                        6 timing config:load:builtin Completed in 0ms
                                        7 timing config:load:cli Completed in 2ms
                                        9 timing config:load:file:/.npmrc Completed in 0ms
                                        10 timing config:load:project Completed in 1ms
                                        11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
                                        12 timing config:load:user Completed in 1ms
                                        16 timing config:load Completed in 8ms
                                        17 timing npm:load:configload Completed in 8ms
                                        18 timing npm:load:mkdirpcache Completed in 0ms
                                        21 verbose argv "--version"
                                        25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-09-12T13_54_41_911Z-
                                        26 verbose logfile /home/iobroker/.npm/_logs/2023-09-12T13_54_41_911Z-debug-0.log
                                        27 timing npm:load:logFile Completed in 10ms
                                        30 timing npm:load Completed in 28ms
                                        31 verbose exit 0
                                        32 timing npm Completed in 33ms
                                        33 info ok
                                          Ubuntu 23.04
                                          Swap: 0B 0B 0B
                                          debug: daswetter.0
                                          crunchipC Offline
                                          crunchipC Offline
                                          @thomas-braun sagte in Vis Adapter nach Backup mit Fehlermeldung:
                                          nur 9 Monate
                                          bis Januar 2024
                                          ich würde einfach neu aufsetzen mit dem passenden OS und backup einspielen, bevor da jetzt lang rum gesucht wird
                                          Swap: 0B 0B 0B
                                          deswegen wird dir wahrscheinlich der LXC abgeschmiert sein
