  3. Off Topic
  4. Docker buanet startet nicht mehr (Synology NAS)
    1.0k
    6.1k
21 Beiträge 5 Kommentatoren 2.7k Aufrufe 3 Beobachtet
  • S StefanRS
    @marc-berg ja unter log sind Daten vorhanden. Die Festplatte ist nicht voll. Sind noch 1,xTB frei.
    Marc BergM Offline
    Marc BergM Offline
    Marc Berg
    @stefanrs sagte in Docker buanet startet nicht mehr (Synology NAS):
    Naja, reinschauen in die aktuelle Log-Datei wäre schon nicht schlecht. Vielleicht gibt's da noch neue Erkenntnisse.
    • Marc BergM Marc Berg
      StefanRS
      @marc-berg : Anbei ein Auszug von den letzten Einträgen
      (ADAPTER_REQUESTED_TERMINATION)
      2023-09-08 17:56:21.033  - info: host.IOBroker All instances are stopped.
      2023-09-08 17:56:21.070  - info: host.IOBroker instance system.adapter.mihome-vacuum.3 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-08 17:56:21.070  - info: host.IOBroker All instances are stopped.
      2023-09-08 17:56:21.436  - info: host.IOBroker instance system.adapter.trashschedule.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-08 17:56:21.436  - info: host.IOBroker All instances are stopped.
      2023-09-08 17:56:21.471  - info: host.IOBroker instance system.adapter.simple-api.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-08 17:56:21.471  - info: host.IOBroker All instances are stopped.
      2023-09-08 17:56:21.472  - info: host.IOBroker instance system.adapter.tankerkoenig.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-08 17:56:21.472  - info: host.IOBroker All instances are stopped.
      2023-09-08 17:56:21.524  - info: host.IOBroker instance system.adapter.denon.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-08 17:56:21.524  - info: host.IOBroker All instances are stopped.
      2023-09-08 17:56:21.524  - info: host.IOBroker instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-08 17:56:21.556  - info: host.IOBroker instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-08 17:56:21.556  - info: host.IOBroker All instances are stopped.
      2023-09-08 17:56:21.557  - info: host.IOBroker instance system.adapter.reolink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-08 17:56:21.557  - info: host.IOBroker All instances are stopped.
      2023-09-08 17:56:21.582  - info: host.IOBroker instance system.adapter.reolink.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-08 17:56:21.583  - info: host.IOBroker All instances are stopped.
      2023-09-08 17:56:21.761  - warn: host.IOBroker Cannot get view: Connection is closed.
      2023-09-08 17:56:21.762  - warn: host.IOBroker Cannot get view: Connection is closed.
      2023-09-08 17:56:21.763  - info: host.IOBroker instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-08 17:56:21.763  - info: host.IOBroker All instances are stopped.
      2023-09-08 17:56:21.763  - info: host.IOBroker instance system.adapter.hue.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-08 17:56:21.764  - info: host.IOBroker All instances are stopped.
      2023-09-08 17:56:21.764  - info: host.IOBroker instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-08 17:56:21.764  - info: host.IOBroker instance system.adapter.telegram.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      • S StefanRS
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        Hm, da kann ich nichts draus ablesen. Das Log ist auch nicht komplett. Ein vollständiger Durchlauf eines Startversuches wäre sicher besser zu sehen.
        • S StefanRS
          Hab ich gemacht. Hier der LOG Auszug.
          date	stream	content
          2023/09/08 19:03:15	stdout
          2023/09/08 19:03:15	stdout	--------------------------------------------------------------------------------
          2023/09/08 19:03:15	stdout	-----             Step 2 of 5: Detecting ioBroker installation             -----
          2023/09/08 19:03:15	stdout	Registering maintenance script as command... Done.
          2023/09/08 19:03:12	stdout	Updating Linux packages on first run... Done.
          2023/09/08 19:03:07	stdout
          2023/09/08 19:03:07	stdout	--------------------------------------------------------------------------------
          2023/09/08 19:03:07	stdout	-----                   Step 1 of 5: Preparing container                   -----
          2023/09/08 19:03:07	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          2023/09/08 19:03:07	stdout	!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
          2023/09/08 19:03:07	stdout	!!!!     For more information see ioBroker Docker image documentation:      !!!!
          2023/09/08 19:03:07	stdout	!!!!          Please make sure to deactivate if no longer needed.           !!!!
          2023/09/08 19:03:07	stdout	!!!! This will extend the logging output and may slow down container start. !!!!
          2023/09/08 19:03:07	stdout	!!!!               Environment variable DEBUG is set to true.               !!!!
          2023/09/08 19:03:07	stdout	!!!!                            DEBUG LOG ACTIVE                            !!!!
          2023/09/08 19:03:07	stdout	-----                    SETUID:              1000                         -----
          2023/09/08 19:03:07	stdout	-----                    SETGID:              1000                         -----
          2023/09/08 19:03:07	stdout	-----                    DEBUG:               true                         -----
          2023/09/08 19:03:07	stdout	-----                        Environment Variables                         -----
          2023/09/08 19:03:07	stdout	-----        -----
          2023/09/08 19:03:07	stdout	-----                    npm:                 9.6.7                        -----
          2023/09/08 19:03:07	stdout	-----                    node:                v18.17.1                     -----
          2023/09/08 19:03:07	stdout	-----                    build:               2023-08-19T23:45:39+00:00    -----
          2023/09/08 19:03:07	stdout	-----                    image:               v8.1.0                       -----
          2023/09/08 19:03:07	stdout	-----                          Version Information                         -----
          2023/09/08 19:03:07	stdout	-----                    hostname:            IOBroker                     -----
          2023/09/08 19:03:07	stdout	-----                    arch:                x86_64                       -----
          2023/09/08 19:03:07	stdout	-----                          System Information                          -----
          2023/09/08 19:03:07	stdout	-----                          Please be patient!                          -----
          2023/09/08 19:03:07	stdout	-----                    Startupscript is now running!                     -----
          2023/09/08 19:03:07	stdout	-----              Welcome to your ioBroker Docker container!              -----
          2023/09/08 19:03:07	stdout	----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
          2023/09/08 19:03:07	stdout	----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
          2023/09/08 19:03:07	stdout	----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
          2023/09/08 19:03:07	stdout	----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
          2023/09/08 19:03:07	stdout	----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
          2023/09/08 19:03:07	stdout	----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
          2023/09/08 19:03:07	stdout	-------------------------     2023-09-08 19:03:07      -------------------------
          2023/09/08 19:03:03	stdout	(Re)setting permissions (This might take a while! Please be patient!)... /opt/scripts/iobroker_startup.sh: line 231:   359 Killed                  chown -R "$setuid":"$setgid" /opt/iobroker
          2023/09/08 19:03:02	stdout
          2023/09/08 19:03:02	stdout	--------------------------------------------------------------------------------
          2023/09/08 19:03:02	stdout	-----             Step 3 of 5: Checking ioBroker installation              -----
          2023/09/08 19:03:01	stdout	Existing installation of ioBroker detected in "/opt/iobroker".
          2023/09/08 19:03:00	stdout
          2023/09/08 19:03:00	stdout	--------------------------------------------------------------------------------
          2023/09/08 19:03:00	stdout	-----             Step 2 of 5: Detecting ioBroker installation             -----
          2023/09/08 19:03:00	stdout	Registering maintenance script as command... Done.
          2023/09/08 19:02:57	stdout	Updating Linux packages on first run... Done.
          2023/09/08 19:02:52	stdout
          2023/09/08 19:02:52	stdout	--------------------------------------------------------------------------------
          2023/09/08 19:02:52	stdout	-----                   Step 1 of 5: Preparing container                   -----
          2023/09/08 19:02:52	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          2023/09/08 19:02:52	stdout	!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
          2023/09/08 19:02:52	stdout	!!!!     For more information see ioBroker Docker image documentation:      !!!!
          2023/09/08 19:02:52	stdout	!!!!          Please make sure to deactivate if no longer needed.           !!!!
          2023/09/08 19:02:52	stdout	!!!! This will extend the logging output and may slow down container start. !!!!
          2023/09/08 19:02:52	stdout	!!!!               Environment variable DEBUG is set to true.               !!!!
          2023/09/08 19:02:52	stdout	!!!!                            DEBUG LOG ACTIVE                            !!!!
          2023/09/08 19:02:52	stdout	-----                    SETUID:              1000                         -----
          2023/09/08 19:02:52	stdout	-----                    SETGID:              1000                         -----
          2023/09/08 19:02:52	stdout	-----                    DEBUG:               true                         -----
          2023/09/08 19:02:52	stdout	-----                        Environment Variables                         -----
          2023/09/08 19:02:52	stdout	-----        -----
          2023/09/08 19:02:52	stdout	-----                    npm:                 9.6.7                        -----
          2023/09/08 19:02:51	stdout	-----                    node:                v18.17.1                     -----
          2023/09/08 19:02:51	stdout	-----                    build:               2023-08-19T23:45:39+00:00    -----
          2023/09/08 19:02:51	stdout	-----                    image:               v8.1.0                       -----
          2023/09/08 19:02:51	stdout	-----                          Version Information                         -----
          2023/09/08 19:02:51	stdout	-----        -----
          2023/09/08 19:02:51	stdout	-----                    hostname:            IOBroker                     -----
          2023/09/08 19:02:51	stdout	-----                    arch:                x86_64                       -----
          2023/09/08 19:02:51	stdout	-----                          System Information                          -----
          2023/09/08 19:02:51	stdout	--------------------------------------------------------------------------------
          2023/09/08 19:02:51	stdout	-----                          Please be patient!                          -----
          2023/09/08 19:02:51	stdout	-----                    Startupscript is now running!                     -----
          2023/09/08 19:02:51	stdout	-----              Welcome to your ioBroker Docker container!              -----
          2023/09/08 19:02:51	stdout	----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
          2023/09/08 19:02:51	stdout	----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
          2023/09/08 19:02:51	stdout	----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
          2023/09/08 19:02:51	stdout	----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
          2023/09/08 19:02:51	stdout	----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
          2023/09/08 19:02:51	stdout	----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
          2023/09/08 19:02:51	stdout	-------------------------     2023-09-08 19:02:51      -------------------------
          2023/09/08 19:02:47	stdout	(Re)setting permissions (This might take a while! Please be patient!)... /opt/scripts/iobroker_startup.sh: line 231:   359 Killed                  chown -R "$setuid":"$setgid" /opt/iobroker
          2023/09/08 19:02:47	stdout	--------------------------------------------------------------------------------
          2023/09/08 19:02:47	stdout	-----             Step 3 of 5: Checking ioBroker installation              -----
          2023/09/08 19:02:45	stdout	Existing installation of ioBroker detected in "/opt/iobroker".
          2023/09/08 19:02:44	stdout
          2023/09/08 19:02:44	stdout	--------------------------------------------------------------------------------
          2023/09/08 19:02:44	stdout	-----             Step 2 of 5: Detecting ioBroker installation             -----
          2023/09/08 19:02:44	stdout	Registering maintenance script as command... Done.
          2023/09/08 19:02:41	stdout	Updating Linux packages on first run... Done.
          2023/09/08 19:02:36	stdout
          2023/09/08 19:02:36	stdout	--------------------------------------------------------------------------------
          2023/09/08 19:02:36	stdout	-----                   Step 1 of 5: Preparing container                   -----
          2023/09/08 19:02:36	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          2023/09/08 19:02:36	stdout	!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
          2023/09/08 19:02:36	stdout	!!!!     For more information see ioBroker Docker image documentation:      !!!!
          2023/09/08 19:02:36	stdout	!!!!          Please make sure to deactivate if no longer needed.           !!!!
          2023/09/08 19:02:36	stdout	!!!! This will extend the logging output and may slow down container start. !!!!
          2023/09/08 19:02:36	stdout	!!!!               Environment variable DEBUG is set to true.               !!!!
          2023/09/08 19:02:36	stdout	!!!!                            DEBUG LOG ACTIVE                            !!!!
          2023/09/08 19:02:36	stdout	-----                    SETUID:              1000                         -----
          2023/09/08 19:02:36	stdout	-----                    SETGID:              1000                         -----
          2023/09/08 19:02:36	stdout	-----                    DEBUG:               true                         -----
          2023/09/08 19:02:36	stdout	-----                        Environment Variables                         -----
          2023/09/08 19:02:36	stdout	-----        -----
          2023/09/08 19:02:36	stdout	-----                    npm:                 9.6.7                        -----
          2023/09/08 19:02:35	stdout	-----                    node:                v18.17.1                     -----
          2023/09/08 19:02:35	stdout	-----                    build:               2023-08-19T23:45:39+00:00    -----
          2023/09/08 19:02:35	stdout	-----                    image:               v8.1.0                       -----
          2023/09/08 19:02:35	stdout	-----                          Version Information                         -----
          2023/09/08 19:02:35	stdout	-----        -----
          2023/09/08 19:02:35	stdout	-----                    hostname:            IOBroker                     -----
          2023/09/08 19:02:35	stdout	-----                    arch:                x86_64                       -----
          2023/09/08 19:02:35	stdout	-----                          System Information                          -----
          2023/09/08 19:02:35	stdout	--------------------------------------------------------------------------------
          2023/09/08 19:02:35	stdout	-----                          Please be patient!                          -----
          2023/09/08 19:02:35	stdout	-----                    Startupscript is now running!                     -----
          2023/09/08 19:02:35	stdout	-----              Welcome to your ioBroker Docker container!              -----
          2023/09/08 19:02:35	stdout	----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
          2023/09/08 19:02:35	stdout	----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
          2023/09/08 19:02:35	stdout	----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
          2023/09/08 19:02:35	stdout	----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
          2023/09/08 19:02:35	stdout	----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
          2023/09/08 19:02:35	stdout	----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
          2023/09/08 19:02:35	stdout	-------------------------     2023-09-08 19:02:35      -------------------------
          2023/09/08 19:02:32	stdout	(Re)setting permissions (This might take a while! Please be patient!)... /opt/scripts/iobroker_startup.sh: line 231:   359 Killed                  chown -R "$setuid":"$setgid" /opt/iobroker
          2023/09/08 19:02:30	stdout
          2023/09/08 19:02:30	stdout	--------------------------------------------------------------------------------
          2023/09/08 19:02:30	stdout	-----             Step 3 of 5: Checking ioBroker installation              -----
          2023/09/08 19:02:30	stdout	Existing installation of ioBroker detected in "/opt/iobroker".
          2023/09/08 19:02:28	stdout
          2023/09/08 19:02:28	stdout	--------------------------------------------------------------------------------
          2023/09/08 19:02:28	stdout	-----             Step 2 of 5: Detecting ioBroker installation             -----
          2023/09/08 19:02:28	stdout	Registering maintenance script as command... Done.
          2023/09/08 19:02:25	stdout	Updating Linux packages on first run... Done.
          2023/09/08 19:02:20	stdout
          2023/09/08 19:02:20	stdout	--------------------------------------------------------------------------------
          2023/09/08 19:02:20	stdout	-----                   Step 1 of 5: Preparing container                   -----
          2023/09/08 19:02:20	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          2023/09/08 19:02:20	stdout	!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
          2023/09/08 19:02:20	stdout	!!!!     For more information see ioBroker Docker image documentation:      !!!!
          2023/09/08 19:02:20	stdout	!!!!          Please make sure to deactivate if no longer needed.           !!!!
          2023/09/08 19:02:20	stdout	!!!! This will extend the logging output and may slow down container start. !!!!
          2023/09/08 19:02:20	stdout	!!!!               Environment variable DEBUG is set to true.               !!!!
          2023/09/08 19:02:20	stdout	!!!!                            DEBUG LOG ACTIVE                            !!!!
          2023/09/08 19:02:20	stdout	-----                    SETUID:              1000                         -----
          2023/09/08 19:02:20	stdout	-----                    SETGID:              1000                         -----
          2023/09/08 19:02:20	stdout	-----                    DEBUG:               true                         -----
          2023/09/08 19:02:20	stdout	-----                        Environment Variables                         -----
          2023/09/08 19:02:20	stdout	-----        -----
          2023/09/08 19:02:20	stdout	-----                    npm:                 9.6.7                        -----
          2023/09/08 19:02:20	stdout	-----                    node:                v18.17.1                     -----
          2023/09/08 19:02:20	stdout	-----                    build:               2023-08-19T23:45:39+00:00    -----
          2023/09/08 19:02:20	stdout	-----                    image:               v8.1.0                       -----
          2023/09/08 19:02:20	stdout	-----                          Version Information                         -----
          2023/09/08 19:02:20	stdout	-----                    hostname:            IOBroker                     -----
          2023/09/08 19:02:20	stdout	-----                    arch:                x86_64                       -----
          2023/09/08 19:02:20	stdout	-----                          System Information                          -----
          2023/09/08 19:02:20	stdout	-----                          Please be patient!                          -----
          2023/09/08 19:02:20	stdout	-----                    Startupscript is now running!                     -----
          2023/09/08 19:02:20	stdout	-----              Welcome to your ioBroker Docker container!              -----
          2023/09/08 19:02:20	stdout	----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
          2023/09/08 19:02:20	stdout	----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
          2023/09/08 19:02:20	stdout	----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
          2023/09/08 19:02:20	stdout	----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
          2023/09/08 19:02:20	stdout	----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
          2023/09/08 19:02:20	stdout	----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
          GlasfaserG Offline
          GlasfaserG Offline
          Da stimmt etwas mit den Ordnerrechten nicht ... hast du ein Mount !?
          EDIT :
          so sieht es sonst aus ... mit Done :
          (Re)setting permissions (This might take a while! Please be patient!)... Done.
          Fixing "sudo-bug" by replacing sudo with gosu... Done.
          • GlasfaserG Glasfaser
            EDIT :
            StefanRS
            @glasfaser was genau meinst du mit Mount?
            Habe die Rechte nochmal überprüft. Steht alles auf lesen/schreiben. Zugriff ist vorhanden.
              StefanRS
              @marc-berg leider sind das die letzten Einträge. Ab dann ging es nicht mehr und er schreibt bzw. legt keinen neuen LOG mehr im Laufwerk ab.
              • S StefanRS
                GlasfaserG Offline
                GlasfaserG Offline
                ob der Ordner /opt/iobroker außerhalb vom Container ist
                schonmal die Synology danach mal neu gestartet !?
                  StefanRS
                  @glasfaser danke für den Tipp mit dem Neustart von der NAS. Jetzt geht es wieder.
                  Peinlich, das hätte ich auch gleich machen können :-)
                  • S StefanRS
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @stefanrs
                    Was war jetzt damit !?
                    @glasfaser sagte in Docker buanet startet nicht mehr (Synology NAS):
                    So ganz Normal ist das nicht , da muß noch was passiert sein !
                      @stefanrs
                      StefanRS
                      @glasfaser
                      der Ordner liegt genauso wie auf deinem Screenshot zu sehen ist. So sieht es bei mir auch aus (bis auf die Bezeichnung)
                      • S StefanRS
                        @glasfaser
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @stefanrs
                        OK ... dachte ich mir !
                        und wie schon geschrieben ... Normal ist das nicht !
                        Welche DSM Version hast du
                        und wieviel Container laufen !?
                          @stefanrs
                          StefanRS
                          @glasfaser
                          es läuft nur der eine Container und ich habe Version 7.2-64570 drauf
                          • S StefanRS
                            @glasfaser
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @stefanrs
                            Top UpToDate 👍
                            Dann klemmte da etwas .... würde ich aber mal beobachten .. warum !
                              @stefanrs
                              Top UpToDate 👍
                              StefanRS
                              @glasfaser
                              Ja werde ich beobachten. Auf jeden Fall danke nochmal für deine Hilfe.
                              Bin echt froh, dass es wieder geht. Mein ganzes Smart Home etc baut auf IOBroker auf.
                              Hab schon Panik bekommen. Da sind einige Stunden für ins Lang gegangen :-)
                              mcBirneM 1 Antwort Letzte Antwort
