  4. [Neuer Adapter] mediola-gateway
    apollon77A
136 Beiträge 20 Kommentatoren 33.7k Aufrufe 18 Beobachtet
  • L line
    @oelison anbei der Log. Hoffe es passt so. Danke
    2023-07-25 22:30:23.503 - info: host.raspberrypi stopInstance system.adapter.mediola-gateway.0 (force=false, process=true)
    2023-07-25 22:30:23.512 - info: mediola-gateway.0 (37773) Got terminate signal TERMINATE_YOURSELF
    2023-07-25 22:30:23.517 - info: mediola-gateway.0 (37773) terminating
    2023-07-25 22:30:23.519 - info: mediola-gateway.0 (37773) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-25 22:30:23.597 - info: host.raspberrypi stopInstance system.adapter.mediola-gateway.0 send kill signal
    2023-07-25 22:30:24.172 - info: host.raspberrypi instance system.adapter.mediola-gateway.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-25 22:30:26.790 - info: host.raspberrypi instance system.adapter.mediola-gateway.0 started with pid 37803
    2023-07-25 22:30:30.540 - debug: mediola-gateway.0 (37803) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-07-25 22:30:30.636 - debug: mediola-gateway.0 (37803) Objects client ready ... initialize now
    2023-07-25 22:30:30.644 - debug: mediola-gateway.0 (37803) Objects create System PubSub Client
    2023-07-25 22:30:30.648 - debug: mediola-gateway.0 (37803) Objects create User PubSub Client
    2023-07-25 22:30:30.780 - debug: mediola-gateway.0 (37803) Objects client initialize lua scripts
    2023-07-25 22:30:30.797 - debug: mediola-gateway.0 (37803) Objects connected to redis: 127.0.0.1:9001
    2023-07-25 22:30:30.843 - debug: mediola-gateway.0 (37803) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-07-25 22:30:30.866 - debug: mediola-gateway.0 (37803) States create System PubSub Client
    2023-07-25 22:30:30.869 - debug: mediola-gateway.0 (37803) States create User PubSub Client
    2023-07-25 22:30:30.953 - debug: mediola-gateway.0 (37803) States connected to redis: 127.0.0.1:9000
    2023-07-25 22:30:31.424 - info: mediola-gateway.0 (37803) starting. Version 0.1.4 (non-npm: oelison/ioBroker.mediola-gateway#more_info) in /opt/iobroker/node_modules/iobroker.mediola-gateway, node: v18.16.1, js-controller: 4.0.24
    2023-07-25 22:30:31.528 - info: mediola-gateway.0 (37803) auto detection: true
    2023-07-25 22:30:31.549 - debug: mediola-gateway.0 (37803) UDP socket listening on 0.0.0.0:1902
    2023-07-25 22:30:31.624 - debug: mediola-gateway.0 (37803) out RECEIVED: 192.168.178.53:1901 - DHCP:TRUE
    HWV:C3
    VER:1.24.0
    VID:FFFF
    IP:192.168.178.53
    SN:255.255.255.0
    GW:192.168.178.1
    DNS:192.168.178.1
    MAC:40-66-7a-00-89-2c
    |end
    2023-07-25 22:30:31.629 - info: mediola-gateway.0 (37803) DHCP:TRUE
    2023-07-25 22:30:31.630 - info: mediola-gateway.0 (37803) HWV:C3
    2023-07-25 22:30:31.631 - info: mediola-gateway.0 (37803) VER:1.24.0
    2023-07-25 22:30:31.632 - info: mediola-gateway.0 (37803) VID:FFFF
    2023-07-25 22:30:31.632 - info: mediola-gateway.0 (37803) IP:192.168.178.53
    2023-07-25 22:30:31.633 - info: mediola-gateway.0 (37803) SN:255.255.255.0
    2023-07-25 22:30:31.635 - info: mediola-gateway.0 (37803) GW:192.168.178.1
    2023-07-25 22:30:31.637 - info: mediola-gateway.0 (37803) DNS:192.168.178.1
    2023-07-25 22:30:31.638 - info: mediola-gateway.0 (37803) MAC:40-66-7a-00-89-2c
    2023-07-25 22:30:31.639 - info: mediola-gateway.0 (37803) NAME:AIO GATEWAY
    2023-07-25 22:30:31.640 - info: mediola-gateway.0 (37803)
    2023-07-25 22:30:31.641 - info: mediola-gateway.0 (37803) Mediola connected with ip:192.168.178.53 and mac:40-66-7a-00-89-2c
    2023-07-25 22:30:31.642 - debug: mediola-gateway.0 (37803) url request to mediola: http://192.168.178.53/command?XC_USER=xxx@xxx.de&XC_PASS=xxx&XC_FNC=getstates
    2023-07-25 22:30:31.887 - debug: mediola-gateway.0 (37803) {XC_SUC}[{"type":"BK","sid":"01","adr":"032753","config":"","state":""},{"type":"BK","sid":"02","adr":"032750","config":"","state":""},{"type":"BK","sid":"03","adr":"032752","config":"","state":""},{"type":"BK","sid":"04","adr":"032754","config":"","state":""}]
    2023-07-25 22:30:31.888 - debug: mediola-gateway.0 (37803) mediola device found data: {XC_SUC}[{"type":"BK","sid":"01","adr":"032753","config":"","state":""},{"type":"BK","sid":"02","adr":"032750","config":"","state":""},{"type":"BK","sid":"03","adr":"032752","config":"","state":""},{"type":"BK","sid":"04","adr":"032754","config":"","state":""}]
    2023-07-25 22:30:31.890 - debug: mediola-gateway.0 (37803) {"type":"BK","sid":"01","adr":"032753","config":"","state":""}
    2023-07-25 22:30:31.905 - debug: mediola-gateway.0 (37803) {"type":"BK","sid":"02","adr":"032750","config":"","state":""}
    2023-07-25 22:30:31.908 - debug: mediola-gateway.0 (37803) {"type":"BK","sid":"03","adr":"032752","config":"","state":""}
    2023-07-25 22:30:31.912 - debug: mediola-gateway.0 (37803) {"type":"BK","sid":"04","adr":"032754","config":"","state":""}
    oelisonO
    oelisonO
    oelison
    @line Bitte eine PM an die Mailadresse vom Readme.md des Adapters. Dann können wir die Steuerbefehle vieleicht generieren.
    I like Rust. ioBroker-Adapter: matrix, mediola-gateway, support for reolink
    • oelisonO
      oelisonO
      oelison
      Hallo Mediola Nutzer, nach einiger arbeit mit KeuleHD (github user) und Line (in diesem Forum). Habe ich eine Version 1.0.0 herausgegeben. Die ersten RF Aktoren sind damit ansteuerbar. Das sind WIR (WR), Roto (BK) und Nobily (NY). Die WIR sind richtig gut. Die werden automatisch erkannt und können auch teil angesteuert werden (in 10% Schritten). Die BK werden automatisch erkannt, aber geht nur rauf, runter und stop. Die Nobily zicken noch etwas herum, da ist manuelle arbeit notwendig. Im Readme steht mehr dazu. Bitte mal testen, wenn noch jemand sowas hat. Oder andere, dann werde ich die Rollos gerne hinzufügen.
      R 1 Antwort Letzte Antwort
      • oelisonO oelison
        R
        R
        rofo1968
        @oelison Hallo, ich bin noch ein sehr neuer und daher unerfahrener iobrocker-nutzer. Derzeit habe ich drei Rolläden von Roto, die ich über das Mediola-Gateway bediene. Nach der Installation werden die Geräte ausgelesen und die Statuspunkte angelegt
        Wenn ich die Beschreibung richtig verstehe, sollte ein action Ordner vorhanden sein, dieser fehlt bei mir.
        oelisonO 1 Antwort Letzte Antwort
        • R rofo1968
          oelisonO
          oelisonO
          oelison
          @rofo1968 Hallo. Sieht nach einem alten Stand aus. Ich habe vor kurzem die Version 1.0.1 released. Diese ist noch nicht in der Stable-liste. Bitte diese installieren.
          Wenn es dann noch nicht geht, bitte die Instanz auf Debug stellen und im log nach der Instanz filtern und hier posten.
          • oelisonO oelison
            R
            R
            rofo1968
            @oelison Hallo, sieht jetzt perfekt aus, funktioniert auch alles!
            Super Arbeit, vielen Dank!
            oelisonO B 2 Antworten Letzte Antwort
            • R rofo1968
              oelisonO
              oelisonO
              oelison
              @rofo1968 Super, das freut mich.
              EzifoxE 1 Antwort Letzte Antwort
              • oelisonO oelison
                EzifoxE
                EzifoxE
                Ezifox
                @oelison
                Hallo ich bin Neu hier und Anfänger im Iobroker.
                Ich habe schon alles mögliche versucht,aber ich bekomme den Mediola Adapter nicht zum laufen.Hier die Logdatei ich hoffe Sie können mir auf den richtigen Weg führen.iobroker.2023-09-08.log
                Danke Im Voraus
                • EzifoxE Ezifox
                  @oelison
                  Danke Im Voraus
                  oelisonO
                  oelisonO
                  oelison
                  Hallo @ezifox,
                  In dem log ist schön zu sehen, dass die Version 1.0.1 startet im Auto Mode. Anscheinend wird aber kein Mediola Gatway gefunden. Was für ein Gateway haben Sie denn? Kennen Sie die IP Adresse? Dann einfach mal diese eintragen und den Auto Mode abschalten. Bisher hat der Adapter aber das Gateway automatisch gefunden. Gruß Christian
                  • oelisonO oelison
                    Hallo @ezifox,
                    EzifoxE
                    EzifoxE
                    Ezifox
                    @oelison
                    Danke für die rasche Antwort.
                    Habe einen AIO GATEWAY V6 version: C3 (1.24.0)
                    Ich habe es mit der IP Adresse des Gateways 10.0.0.1 und der MAC Adresse versucht. Leider das selbe Ergebnis.
                    • EzifoxE Ezifox
                      @oelison
                      oelisonO
                      oelisonO
                      oelison
                      @ezifox
                      Bitte mal im WebBrowser folgendes aufrufen:
                      http://10.0.0.1/command?XC_FNC=getstates
                      Da sollte dann sowas wie
                      {XC_SUC}
                      Rauskommen.
                      • oelisonO oelison
                        @ezifox
                        {XC_SUC}
                        Rauskommen.
                        EzifoxE
                        EzifoxE
                        Ezifox
                        @oelison
                        Das ist die Antwort
                        {"XC_ERR":{"code":"000007","msg":"access denied"}}
                        • EzifoxE Ezifox
                          @oelison
                          Das ist die Antwort
                          oelisonO
                          oelisonO
                          oelison
                          schrieb am zuletzt editiert von oelison
                          @ezifox
                          Okay, dann musst Du einen Usernamen und ein Passwort vergeben haben. Dann wieder alles auf Auto und die anderen Hacken weg und Name und Passwort setzen.
                          Hiermit kann Name und Passwort getestet werden:
                          http://ip-of-mediola/command?XC_USER=username&XC_PASS=password&XC_FNC=getstates
                          ip-of-mediola ist ja klar und username und password ersetzen.
                          • oelisonO oelison
                            @ezifox
                            EzifoxE
                            EzifoxE
                            Ezifox
                            @oelison
                            {XC_ERR}{"code":"010000"}
                            Ich habe im Mediola Configtool nur ein Passwort vergeben, keinen Nutzernamen.
                            • EzifoxE Ezifox
                              @oelison
                              oelisonO
                              oelisonO
                              oelison
                              @ezifox
                              Versuchs mal mit admin als user. Das sollte der default user sein. Ich habe aber nur eine V4, da könnte das anders sein.
                              -1
                              • oelisonO oelison
                                @ezifox
                                EzifoxE
                                EzifoxE
                                Ezifox
                                @oelison
                                Ich hatte zuvor schon sämtliche User probiert.
                                Admin,Admin,Root,email,etc… auch lehr gelassen, leider ohne Erfolg.
                                Mit der App IQONTROL NEO komme ich auf den Gateway.
                                • EzifoxE Ezifox
                                  @oelison
                                  oelisonO
                                  oelisonO
                                  oelison
                                  @ezifox
                                  Bei meiner V4 ist die api immer ohne name und passwort, egal ob ich ein config passwort gesetzt habe oder nicht. Ist es möglich einen User anzulegen?
                                  • oelisonO oelison
                                    @ezifox
                                    EzifoxE
                                    EzifoxE
                                    Ezifox
                                    @oelison
                                    Bin noch Anfänger. Brauche ich eine api für meinen Gateway und wo bekomme ich die?
                                    User finde ich nichts um einen anzulegen.
                                    • EzifoxE Ezifox
                                      @oelison
                                      oelisonO
                                      oelisonO
                                      oelison
                                      @ezifox
                                      Mit dem Webaufruf hast Du die API ja schon verwendet. Das ist die Verbindung die mein Adapter verwendet.
                                      Weiter oben in diesem Thread sind ja die Erfolgsmeldungen von line, hier wurde name und passwort gesetzt und es war auch ein V6 (keine + soweit ich weiß).
                                      Wenn wir das debuggen wollen, dann solltest Du mir eine Mail schreiben. (siehe readme).
                                      Alternativ kannst Du das Passwort löschen, aber dann verlierst Du Deinen Cloud zugriff.
                                      • oelisonO oelison
                                        @ezifox
                                        EzifoxE
                                        EzifoxE
                                        Ezifox
                                        @oelison
                                        Habe es mit anderen User getestet.
                                        {XC_SUC}[{"type":"RT","sid":"01","adr":"B3DD1F","config":"","state":""},{"type":"RT","sid":"02","adr":"F8A4FE","config":"","state":""},{"type":"RT","sid":"03","adr":"856236","config":"","state":""},{"type":"EVENT","adr":"05","state":"1"},{"type":"EVENT","adr":"04","state":"1"}]
                                        oelisonO 2 Antworten Letzte Antwort
                                        • EzifoxE Ezifox
                                          @oelison
                                          oelisonO
                                          oelisonO
                                          oelison
                                          @ezifox Dann sollte der Rest jetzt auch im Adapter gehen, wenn Du den User da mit Passwort einträgst. Wo legt man den User an? Könnte anderen hier helfen, die an der gleichen Stelle klemmen.
                                          84.0k
