  4. iobroker kaum benutzbar - redis 100%
    5.2k
89 Beiträge 9 Kommentatoren 10.8k Aufrufe 4 Beobachtet
    @caravandriver sagte in iobroker kaum benutzbar - redis 100%:
    17.080 * 10000 changes in 60 seconds. Saving...
    ist nicht dein Ernst?
    und du wunderst dich dass es klemmt?
    caravandriverC Offline
    caravandriver
    Nein, ich wunder mich nicht, aber warum ist das so? Ich habe nichts irgendwo eingestellt das sagt "mach das so"...
    • caravandriverC caravandriver
      @dp20eic
      ls -la /var/log/redis/*
      ls: cannot access '/var/log/redis/*': Permission denied
      sudo  ls -la /var/log/redis/*
      ls: cannot access '/var/log/redis/*': No such file or directory
      mit einem sudo chmod -R 777 /var/log/redis/
      komme ich nun dran...
      iobroker@SmarthomeVM:~$ tail -f /var/log/redis/redis-server.log
      197:M 05 Sep 2023 09:36:07.012 * 10000 changes in 60 seconds. Saving...
      197:M 05 Sep 2023 09:36:07.022 * Background saving started by pid 1919271
      1919271:C 05 Sep 2023 09:36:16.429 * DB saved on disk
      1919271:C 05 Sep 2023 09:36:16.440 * RDB: 24 MB of memory used by copy-on-write
      197:M 05 Sep 2023 09:36:16.462 * Background saving terminated with success
      197:M 05 Sep 2023 09:37:17.080 * 10000 changes in 60 seconds. Saving...
      197:M 05 Sep 2023 09:37:17.089 * Background saving started by pid 1920931
      1920931:C 05 Sep 2023 09:37:26.622 * DB saved on disk
      1920931:C 05 Sep 2023 09:37:26.633 * RDB: 18 MB of memory used by copy-on-write
      197:M 05 Sep 2023 09:37:26.737 * Background saving terminated with success
      197:M 05 Sep 2023 09:38:27.057 * 10000 changes in 60 seconds. Saving...
      197:M 05 Sep 2023 09:38:27.066 * Background saving started by pid 1922567
      1922567:C 05 Sep 2023 09:38:36.614 * DB saved on disk
      1922567:C 05 Sep 2023 09:38:36.625 * RDB: 18 MB of memory used by copy-on-write
      197:M 05 Sep 2023 09:38:36.650 * Background saving terminated with success
      197:M 05 Sep 2023 09:39:37.073 * 10000 changes in 60 seconds. Saving...
      197:M 05 Sep 2023 09:39:37.082 * Background saving started by pid 1924186
      1924186:C 05 Sep 2023 09:39:47.195 * DB saved on disk
      1924186:C 05 Sep 2023 09:39:47.207 * RDB: 22 MB of memory used by copy-on-write
      197:M 05 Sep 2023 09:39:47.241 * Background saving terminated with success
      197:M 05 Sep 2023 09:40:48.076 * 10000 changes in 60 seconds. Saving...
      197:M 05 Sep 2023 09:40:48.085 * Background saving started by pid 1925897
      10000 Änderungen in 60 sek??? Das ist viel, oder? Wo sehe ich was das macht?
      Am Rande: 777 rekursiv über ein Verzeichnis kippen ist immer die allerallerschlechteste Herangehensweise.
      Ich vermute, da fehlt die Mitgliedschaft in einer Gruppe 'redis' oder ähnliches.
      • OliverIOO OliverIO
        @caravandriver
        In der Instanz Sicht des iobrokers kann man sehen wieviele Events pro Eintrag vorkommen.
        Das ist ein Hinweis auf dir Anzahl der gelesenen und geschriebenen datenpunkte.
        caravandriver
        schrieb am zuletzt editiert von caravandriver
        @oliverio
        hier?
        Ja, ich habe einige Javascripte. Die machen am meisten. Aber: Wie finde ich raus, welches da am meisten input macht? ggf ist ja eines kaputt..
        Aber: Auch wenn ich javascript anhalte wird es nicht besser.
        HomoranH OliverIOO 2 Antworten Letzte Antwort
          @oliverio
          hier?
          @caravandriver hast du alle hunderte Instanzen aud Logstufe debug?
          caravandriverC 1 Antwort Letzte Antwort
            caravandriver
            @homoran Nein, alle sind auf "Error"
              Moin,
              doch hast Du, aus Deiner Konfiguration
              ################################ SNAPSHOTTING  ################################
              # Save the DB on disk:
              #   save <seconds> <changes>
              #   Will save the DB if both the given number of seconds and the given
              #   number of write operations against the DB occurred.
              #   In the example below the behavior will be to save:
              #   after 900 sec (15 min) if at least 1 key changed
              #   after 300 sec (5 min) if at least 10 keys changed
              #   after 60 sec if at least 10000 keys changed
              #   Note: you can disable saving completely by commenting out all "save" lines.
              #   It is also possible to remove all the previously configured save
              #   points by adding a save directive with a single empty string argument
              #   like in the following example:
              #   save ""
              save 900 1
              save 300 10
              save 60 10000
              redis-server:
              Installed: 5:6.0.16-1+deb11u2
              Candidate: 5:6.0.16-1+deb11u2
              Auf meinem Office PC sehe ich das aktuell Version 7.0 aktuell ist, keine Ahnung, ob es da auch eine aktuellere Version für Bullseye gibt.
              Keine Gute Idee, was sagt denn
              # ls -la /var/log
              Bernd
                Moin,
                #   save ""
                save 900 1
                save 300 10
                save 60 10000
                redis-server:
                # ls -la /var/log
                Bernd
                caravandriver
                @dp20eic
                Bewusst habe ich da nichts geändert.
                Kannst du mir einfach deine Konfig geben bzw. die relevanten Zeilen sagen, die ich ändern sollte?
                  @oliverio
                  hier?
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  du kannst auch noch auf sonoff und vedirect schauen, die sind auch noch recht hoch.
                  die frage ist auch immer wie fein granular du tatsächlich die werte aufzeichnen willst. ich weiß leider nicht genau welche zeitscheibe diese werte da anzeigen, aber ich schätze es ist der durchschnitt in einer minute oder weniger.
                  hast du noch history angeschaltet?
                  bei javascript, kannst du natürlich die skripte der reihe nach abschalten und schauen wo es die größten Auswirkungen hat. extra logging einbauen würde ich nur mit bedacht, da das uU extreme Auswirkungen auf die Performance hat.
                  primär würde ich aber nach den skripten schauen, die sich mit sonoff und vedirect beschäftigen.
                  die Anzahl bei admin ist auch relativ hoch, aber das dürfte eigentlich nur die interne berichterstattung der adapter sein (datenpunkte system.*).
                  im Zweifel könnte es auch sein, das du für dein Szenario dann auch am Ende der Performance angelangt bist und einen stärkeren Prozessor brauchst. Ein SAP für ein Großunternehmen lässt sich auch nicht auf einem Consumer-PC betreiben.
                  :) oder du skalierst redis und stellst mehrere rechner für die redis-db bereit. https://redis.io/docs/management/scaling/.
                  Meine Adapter und Widgets
                  Links im Profil
                    caravandriver
                    @oliverio
                    Der ve.direkt ließt glaube ich sogar jede Sekunde, aber das kann man nirgendwo einstellen. 1x / Minute würde mir ja reichen...
                    SQL History ist für keinen ve.direct Wert an.
                    Javascript einzeln durchtesten ist eine Wochenaufgabe... Sind so 200 Scripte.
                      @dp20eic
                      Moin,
                      ich nutze kein Redis, ich kenne das nur von der Arbeit und da haben das auch Kollegen betreut. Da mich das Thema aber jetzt interessiert, werde ich mir schon mal das Grundwissen anlesen, sobald dann meine neuen Rechner da sind, werde ich mir ein HA Redis aufbauen.
                      So lange musst Du wohl selbst Zeit investieren und lesen oder Fernsehen (YT).
                      Redis
                      https://redis.io/docs/getting-started/
                      https://redis.io/docs/management/persistence/
                      Interessante Daten zum laufenden Radis
                      # systemctl status redis.service
                      Nach der PID Nummer suchen ``Main PID: 5409 (redis-server)``
                      # cat /proc/PID/limits
                      Bernd
                      P.S.: Ich hatte es ja oben schon mal angedeutet, einfach eine Konfiguration, von anderen, zu übernehmen, ist nicht klug, das kann funktionieren, muss es aber nicht, jede Installation / Konfiguration ist unterschiedlich und muss somit auch individuell angepasst werden.
                        Moin,
                        Redis
                        Bernd
                        caravandriver
                        @dp20eic
                        Ich bin davon ausgegangen, das du eine Ahnung hast, welchen Parameter zu übernehmen sinn machen würde.
                        Daher meine Frage.
                        Ich habe mal diese Änderung vorgenommen:
                        save 900 1
                        #save 300 10
                        #save 60 10000
                        Das ist wie gesagt, das erste Mal, das ich die Datei anpacke.
                        Ro75R ? 2 Antworten Letzte Antwort
                          @dp20eic
                          Daher meine Frage.
                          save 900 1
                          #save 300 10
                          #save 60 10000
                          Ro75R Online
                          Ro75R Online
                          Ro75
                          @caravandriver schau mal hier. Da gibt's auch einiges und configs Link Text
                          Ro75.
                          • Ro75R Ro75
                            Ro75.
                            caravandriver
                            @ro75
                            Ich habe den iobroker Proxmox-Container auf SSD gelegt.
                            Dieser war noch auf der alten HDD.
                            Dazu meine anpassung der redis.conf
                            save 900 1
                            #save 300 10
                            #save 60 10000
                            Bisher kein Performanceproblem mehr. Der CPU-Load ist drastisch gefallen (vorher > 3), jetzt 0,5 - 0,8.
                            Ro75R HomoranH 2 Antworten Letzte Antwort
                              @ro75
                              save 900 1
                              #save 300 10
                              #save 60 10000
                              Ro75R Online
                              Ro75R Online
                              Ro75
                              schrieb am zuletzt editiert von Ro75
                              save 900 1
                              Na das klingt gut. Allerdings mit diesen Werten wird dein System wohl permanent auf die SSD speichern, sprich mehrere hundert MB in sehr kurzen Intervallen.
                              Kannst das ja prüfen in
                              /var/lib/redis
                              Ich würde den Wert nach oben anpassen.
                              Ro75.
                              EDIT: Ich habe bei mir stehen:
                              save 43200 50000
                              Damit speichert er entweder aller 12 Stunden oder wenn mindestens 50000 Änderungen erfolgt sind.
                              OliverIOO caravandriverC 2 Antworten Letzte Antwort
                              • Ro75R Ro75
                                save 900 1
                                /var/lib/redis
                                Ro75.
                                save 43200 50000
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                @ro75
                                wenn der rechner allerdings abstürzt, ist das dann auch der maximale Verlust der daten, da sie noch nicht geschrieben worden sind
                                Links im Profil
                                Ro75R 1 Antwort Letzte Antwort
                                  @ro75
                                  save 900 1
                                  #save 300 10
                                  #save 60 10000
                                  #66
                                  dann hatte die Platte wahrscheinlich einen Schuss und/oder der Datentransfer.
                                  Load average enthält auch die I/O Zeiten.
                                  Wenn dann die States und Objects nicht schnell genug geschrieben werden können, klemmt's natürlich in der redis.
                                    @ro75
                                    Ro75R Online
                                    Ro75R Online
                                    Ro75
                                    #67
                                    @oliverio das ist korrekt. Die Daten der History sind da und wären nicht betroffen. Alle anderen Daten wären wieder innerhalb kurzer Zeit aktuell - stört also auch nicht.
                                    Nur Änderungen an der VIS wären tragisch. Von daher mache ich zur Sicherheit nach Änderungen in der VIS ein:
                                    redis-cli bgsave
                                    Das muss jeder für sich selbst entscheiden. Ich habe für mich das erreicht was ich wollte:
                                    1. Hohe Performance
                                    2. Geringer Verbrauch von Ressourcen
                                    3. Geringe Belastung der SSD.
                                    Ro75.
                                      @dp20eic
                                      Daher meine Frage.
                                      save 900 1
                                      #save 300 10
                                      #save 60 10000
                                      #68
                                      @dp20eic
                                      Moin,
                                      Ahnung habe ich schon, ich bin davon ausgegangen, dass Du lesen kannst :)
                                      Wie schon gesagt, all das ist von Deinen Präferenzen abhängig.
                                      Noch ein paar Hinweise
                                      • HDD hast Du ja schon aus dem Spiel genommen
                                      • Redis ist eine inMemory Datenbank, also stark abhängig davon wie viel Speicher man zugeteilt hat -> maxmemory
                                      • Wie ist die Anforderung an die Persistance
                                        • siehe @Ro75 https://forum.iobroker.net/topic/67997/iobroker-kaum-benutzbar-redis-100/67?_=1694012868449
                                      • Es gibt Kernel Parameter, die im Standard nicht optimal für Redis sind
                                        • daher würde ich Redis nicht da betreiben, wo auch alles andere läuft
                                      • Ich würde immer ein HA Cluster aufbauen und Persistenz abschalten, durch das Cluster ist die Datensicherheit gegeben
                                      Bernd
                                        @dp20eic
                                        Moin,
                                        Bernd
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #69
                                        @dp20eic sagte in iobroker kaum benutzbar - redis 100%:
                                        ja wobei es nicht immer eine klassische HA sein muss
                                        schon mal was von Sentinel gehört ?
                                        ? HomoranH 2 Antworten Letzte Antwort
                                        • arteckA arteck
                                          #70
                                          @arteck sagte in iobroker kaum benutzbar - redis 100%:
                                          Moin,
                                          ja, habe vorhin erst etwas darüber gelesen, besser überflogen, war dann aber schon wieder aus dem Sinn :)
                                          Bernd
