  3. Off Topic
  4. Upgrade von Debian 11/Bullseye auf 12/Bookworm
upgrade bullseye bookworm
351 Beiträge 51 Kommentatoren 116.4k Aufrufe 52 Beobachtet
  • R Rico Sander
    @thomas-braun Moin Allerseits,
    ich häng mich mal an den Thread ran:
    Nach dem erfolgreichen Upgrade auf bookworm am 21.07.23 hatte ich heute wieder einmal routinemäßig ein OS-Update angestoßen. Nun schien da irgendwas schief gelaufen zu sein. Hat das damit zu tun, dass bookworm noch nicht vollständig für pi bereitsteht?
    pi@raspberrypi:~ $ sudo apt-get update && sudo apt-get upgrade -y
    Ign:1 http://raspbian.raspberrypi.org/raspbian booworm InRelease
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm InRelease
    Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
    Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
    Err:6 http://raspbian.raspberrypi.org/raspbian booworm Release
      404  Not Found [IP: 93.93.128.193 80]
    Hit:7 https://deb.nodesource.com/node_18.x bookworm InRelease
    Reading package lists... Done
    E: The repository 'http://raspbian.raspberrypi.org/raspbian booworm Release' does not have a Release file.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    W: http://security.debian.org/debian-security/dists/bookworm-security/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    W: http://deb.debian.org/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    W: http://archive.raspberrypi.org/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    W: http://deb.debian.org/debian/dists/bookworm-updates/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    pi@raspberrypi:~ $
    Oder liegt der Fehler bei mir?
    Danke für Aufklärung, schönes WE.
    #173
    @pi-ter
    booworm
    Da fehlt ein k ...
    Das nodesource Repo muss aber auch umgestellt werden. Der letzte Stand ist im howto aus meiner Signatur zu finden.
    Und schieb die keys woanders hin:
    sudo cp /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
    R 3 Antworten Letzte Antwort
    • DJMarc75D DJMarc75
      @pi-ter sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
      da fehlt ein k
      Rico Sander
      #174
      @djmarc75 sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
      da fehlt ein k
      Ja, sehe ich jetzt auch. Danke.
      Merkwürdig: In meiner "Kopiervorlage" für die sources.list gibt es diesen Tipper nicht.
      Egal, aber hätte es nicht dann auch schon beim Upgrade Probleme geben müssen?
      Wie dem auch sei... Update läuft jetzt erst einmal. Und wie es bislang aussieht wohl ohne Fehler. Schaun wir mal...
      Wenns nicht geht, wie man will
      - muss mans tun, wie man kann.
        @pi-ter
        booworm
        Da fehlt ein k ...
        Rico Sander
        #175
        Ah ok ..., 31.08.23 - na da bin ich ja dann noch zeitnah dran.
        Da das Update noch läuft, werde ich es danach gleich mal angehen.
        Danke für den Hinweis.
        Schönes WE
        • R Rico Sander
          da fehlt ein k
          #176
          @pi-ter
          Warum nimmst du nicht diese Befehle?
          Da ist kein Tippfehler drin:
          sudo sed -i 's/bullseye/bookworm/g' /etc/apt/sources.list
          sudo sed -i 's/bullseye/bookworm/g' /etc/apt/sources.list.d/*
          R 1 Antwort Letzte Antwort
            @pi-ter
            Rico Sander
            #177
            Hm.. die stehen auch in meiner "Kopiervorlage" und ich denke, dass ich die auch verwendet habe. Eigentlich habe ich die Anleitung punktuell abgearbeitet.
            Vlt. ist da schon was quer gelaufen. Weiß ich nun nicht mehr. Letztlich hatte im Juli das erfolgreiche Upgrade gezählt.
            Andere Frage zu dieser Änderung per 31. August:
            Habe ich diese Info im abonnierten feed übersehen oder war das eher Insiderwissen?
              @pi-ter
              booworm
              Da fehlt ein k ...
              Rico Sander
              #178
              @thomas-braun sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
              @pi-ter
              pi@raspberrypi:~ $ sudo rm `sudo find / -name nodesource.gpg`
              pi@raspberrypi:~ $ sudo rm `sudo find / -name nodesource.key`
              rm: missing operand
              Try 'rm --help' for more information.
              pi@raspberrypi:~ $
              Blöd gelaufen?
              • R Rico Sander
                #179
                Welcher abonnierte Feed?
                • R Rico Sander
                  @pi-ter
                  rm: missing operand
                  pi@raspberrypi:~ $
                  Blöd gelaufen?
                  #180
                  @pi-ter
                  Nein, nicht blödgelaufen, es gibt die Datei nur nicht.
                  Man könnte die Meldung unterdrücken, hab ich aber in dem Fall drauf verzichtet.
                    Rico Sander
                    #181
                    Der zum Beispiel:
                    https://forum.iobroker.net/recentposts.rss
                      @pi-ter
                      booworm
                      Da fehlt ein k ...
                      Rico Sander
                      #182
                      Stunden später:
                      • Die Aufgaben bezüglich 31.08. abgearbeitet,
                      • restliche Adapter aktualisiert
                      • OS- Update
                      Magst Du bitte mal schauen, ob nun alles passt oder ob es noch Handlungsbedarf gibt:
                                           v.2023-04-16
                      Operatingsystem:        Raspbian GNU/Linux 12 (bookworm)
                      Kernel:                 6.1.21-v8+
                      Installation:           Native
                      User-ID:                1000
                      X-Server:               false
                      Pending OS-Updates:     0
                      Pending iob updates:    1
                      Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                              /usr/bin/node           v18.17.1
                                              /usr/bin/npm            9.6.7
                                              /usr/bin/npx            9.6.7
                      Recommended versions are nodejs 18.x.y and npm 9.x.y
                      MEMORY:
                      Mem:            4.0G        906M        2.6G        503K        522M        3.1G
                      Swap:           104M          0B        104M
                      Total:          4.1G        906M        2.7G
                      Active iob-Instances:   19
                      ioBroker Core:          js-controller           4.0.24
                                              admin                   6.8.0
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                4721
                      States:                 4005
                      Size of iob-Database:
                      11M     /opt/iobroker/iobroker-data/objects.jsonl
                      4.2M    /opt/iobroker/iobroker-data/objects.json.migrated
                      4.2M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                      3.5M    /opt/iobroker/iobroker-data/states.jsonl
                      500K    /opt/iobroker/iobroker-data/states.json.migrated
                      500K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                      Danke...
                      • R Rico Sander
                        Stunden später:
                        • OS- Update
                                             v.2023-04-16
                        Kernel:                 6.1.21-v8+
                        User-ID:                1000
                        X-Server:               false
                                                /usr/bin/npm            9.6.7
                                                /usr/bin/npx            9.6.7
                        MEMORY:
                        Swap:           104M          0B        104M
                                                admin                   6.8.0
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                4721
                        States:                 4005
                        Danke...
                        #183
                        Boot Target: graphical.target
                        Würde ich auf multi-user.taget bringen.
                        Geht in raspi-config:
                        1, S5, B1
                          1, S5, B1
                          Rico Sander
                          #184
                          Done!
                                               v.2023-04-16
                          Kernel:                 6.1.21-v8+
                          User-ID:                1000
                          X-Server:               false
                          Boot Target:            multi-user.target
                          Danke...
                          • R Rico Sander
                            Done!
                                                 v.2023-04-16
                            Kernel:                 6.1.21-v8+
                            User-ID:                1000
                            X-Server:               false
                            Danke...
                            #185
                            @pi-ter
                            Gib mal die Langfassung zum Besten.
                            R 2 Antworten Letzte Antwort
                              @pi-ter
                              Rico Sander
                              #186
                              @thomas-braun ,
                              Gern:
                                                   v.2023-04-16
                              Kernel:                 6.1.21-v8+
                              User-ID:                1000
                              X-Server:               false
                                                      /usr/bin/npm            9.6.7
                                                      /usr/bin/npx            9.6.7
                              MEMORY:
                              Mem:            4.0G        1.2G        2.3G        503K        648M        2.8G
                              Swap:           104M          0B        104M
                              Total:          4.1G        1.2G        2.4G
                                                      admin                   6.8.0
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                4721
                              States:                 3990
                              20M     /opt/iobroker/iobroker-data/objects.jsonl
                              2.6M    /opt/iobroker/iobroker-data/states.jsonl
                              • R Rico Sander
                                @thomas-braun ,
                                Gern:
                                                     v.2023-04-16
                                Kernel:                 6.1.21-v8+
                                User-ID:                1000
                                X-Server:               false
                                                        /usr/bin/npm            9.6.7
                                                        /usr/bin/npx            9.6.7
                                MEMORY:
                                Swap:           104M          0B        104M
                                                        admin                   6.8.0
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                4721
                                States:                 3990
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                #187
                                Gern:
                                Das ist die Kurzfassung ;)
                                Lehrling seit 1975 !!!
                                  @pi-ter
                                  Rico Sander
                                  #188
                                  Moin,
                                  da ich betreffs multi-user.taget gestern nur einen Schnipsel aus diag gepostet hatte, nahm ich an, dass Du die komplette Zusammenfassung wolltest.
                                  Aber bevor ich die tatsächliche Langfassung bringe, noch eine Frage:
                                  Was triggert, ob bei neofetch die Beere oder der Bookworm als Logo ausgegeben wird. Ist zwar nicht wirklich wichtig, interessiert mich nur halt. Auf dem Raspi 3 mit pihole mit bookworm wird der Wurm angezeigt, auf dem Raspi 4 mit iobroker die Beere. Beide laufen auf 64bit...
                                  Skript v.2023-04-16
                                  *** BASE SYSTEM ***
                                  Model           : Raspberry Pi 4 Model B Rev 1.1
                                  Architecture    : aarch64
                                  Docker          : false
                                  Virtualization  : none
                                  Distributor ID: Raspbian
                                  Description:    Raspbian GNU/Linux 12 (bookworm)
                                  Release:        12
                                  Codename:       bookworm
                                  PRETTY_NAME="Raspbian GNU/Linux 12 (bookworm)"
                                  NAME="Raspbian GNU/Linux"
                                  VERSION_ID="12"
                                  VERSION="12 (bookworm)"
                                  VERSION_CODENAME=bookworm
                                  ID=raspbian
                                  ID_LIKE=debian
                                  HOME_URL="http://www.raspbian.org/"
                                  SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                  BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                  Systemuptime and Load:
                                   08:39:38 up 15 min,  2 users,  load average: 1.77, 1.53, 0.87
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  Other values than 0x0 hint to temperature/voltage problems
                                  temp=55.5'C
                                  volt=0.8688V
                                  *** Time and Time Zones ***
                                                 Local time: Sun 2023-09-03 08:39:38 CEST
                                             Universal time: Sun 2023-09-03 06:39:38 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** User and Groups ***
                                  pi
                                  /home/pi
                                  pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                  *** X-Server-Setup ***
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            4.0G        938M        2.6G        499K        546M        3.0G
                                  Swap:           104M          0B        104M
                                  Total:          4.1G        938M        2.7G
                                           3794 M total memory
                                            894 M used memory
                                            858 M active memory
                                            339 M inactive memory
                                           2454 M free memory
                                             83 M buffer memory
                                            437 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /dev/root      ext4       29G  7.2G   21G  26% /
                                  devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                  tmpfs          tmpfs     759M  484K  759M   1% /run
                                  tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
                                  /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                                  /dev/sda1      ext4       14G  1.3G   12G  10% /media/USBintern
                                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                  [Sun Sep  3 08:24:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:2D:5B:0D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=83dc1cec-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                                  [Sun Sep  3 08:24:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Sun Sep  3 08:24:30 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                  [Sun Sep  3 08:24:33 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                  [Sun Sep  3 08:24:36 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                  TARGET             SOURCE         FSTYPE OPTIONS
                                  /                  /dev/mmcblk0p2 ext4   rw,noatime
                                  |-/boot            /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                  `-/media/USBintern /dev/sda1      ext4   rw,relatime
                                  /var:
                                  1.9G    /var/
                                  1.2G    /var/cache/apt
                                  1.2G    /var/cache
                                  1.1G    /var/cache/apt/archives
                                  528M    /var/log
                                  Archived and active journals take up 524.2M in the file system.
                                  /opt/iobroker/backups:
                                  4.0K    /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  437M    /opt/iobroker/iobroker-data/
                                  300M    /opt/iobroker/iobroker-data/files
                                  88M     /opt/iobroker/iobroker-data/files/echarts.admin
                                  88M     /opt/iobroker/iobroker-data/backup-objects
                                  57M     /opt/iobroker/iobroker-data/files/echarts
                                  31M     /opt/iobroker/iobroker-data/objects.jsonl
                                  23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                                  23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                                  23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
                                  *** NodeJS-Installation ***
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
                                  nodejs:
                                    Installed: 18.17.1-1nodesource1
                                    Candidate: 18.17.1-1nodesource1
                                    Version table:
                                   *** 18.17.1-1nodesource1 500
                                          500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                       18.17.0-1nodesource1 500
                                       18.16.1-1nodesource1 500
                                       18.16.0-1nodesource1 500
                                       18.15.0-1nodesource1 500
                                       18.14.2-1nodesource1 500
                                       18.14.1-1nodesource1 500
                                       18.14.0-1nodesource1 500
                                       18.13.0+dfsg1-1+rpi1 500
                                          500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
                                       18.13.0-1nodesource1 500
                                       18.12.0-1nodesource1 500
                                       18.11.0-1nodesource1 500
                                       18.10.0-1nodesource1 500
                                       18.9.1-1nodesource1 500
                                       18.9.0-1nodesource1 500
                                       18.8.0-1nodesource1 500
                                       18.7.0-1nodesource1 500
                                       18.6.0-1nodesource1 500
                                       18.5.0-1nodesource1 500
                                       18.4.0-1nodesource1 500
                                       18.3.0-1nodesource1 500
                                       18.2.0-1nodesource1 500
                                       18.1.0-1nodesource1 500
                                       18.0.0-1nodesource1 500
                                  No problems detected
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Core adapters versions
                                  js-controller:  4.0.24
                                  admin:          6.8.0
                                  javascript:     7.0.3
                                  Adapters from github:   0
                                  Adapter State
                                  + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
                                    system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                                    system.adapter.echarts.0                : echarts               : raspberrypi                              - disabled
                                  + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                                  + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                                    system.adapter.ham.0                    : ham                   : raspberrypi                              - disabled
                                  + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                  + system.adapter.hs100.0                  : hs100                 : raspberrypi                              -  enabled
                                  + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                  + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                                  + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                                    system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
                                    system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                                  + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                  + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                  + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
                                  + instance is alive
                                  ioBroker-Repositories
                                  Stable (default): http://download.iobroker.net/sources-dist.json
                                  Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                  Installed ioBroker-Instances
                                  Adapter    "admin"        : 6.8.0    , installed 6.8.0
                                  Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
                                  Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                                  Adapter    "deyeidc"      : 0.0.11   , installed 0.0.11
                                  Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                                  Adapter    "email"        : 1.2.0    , installed 1.2.0
                                  Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                                  Adapter    "ham"          : 5.3.1    , installed 4.0.2  [Updatable]
                                  Adapter    "history"      : 2.2.6    , installed 2.2.6
                                  Adapter    "hs100"        : 2.1.2    , installed 2.1.2
                                  Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                  Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                                  Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                                  Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                                  Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                                  Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                                  Adapter    "socketio"     : 6.5.2    , installed 6.5.2
                                  Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                                  Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                                  Adapter    "web"          : 6.1.0    , installed 6.1.0
                                  Adapter    "ws"           : 2.5.3    , installed 2.5.3
                                  Objects and States
                                  Objects:        4721
                                  States:         4005
                                  Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
                                  Hit:2 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
                                  Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14093      733/io.sonoff.0
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15571      518/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12781      518/iobroker.js-con
                                  tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       16353      1341/io.jarvis.0
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15517      581/sshd: /usr/sbin
                                  tcp6       0      0 :::8091                 :::*                    LISTEN      1001       18051      1561/io.lovelace.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12863      634/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15931      969/io.web.0
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          15519      581/sshd: /usr/sbin
                                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       14173      787/io.shelly.0
                                  udp        0      0 0.0.0.0:42766           0.0.0.0:*                           108        13606      369/avahi-daemon: r
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12172      650/dhcpcd
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13604      369/avahi-daemon: r
                                  udp6       0      0 :::51524                :::*                                108        13607      369/avahi-daemon: r
                                  udp6       0      0 :::5353                 :::*                                108        13605      369/avahi-daemon: r
                                  2023-09-03 08:40:38.898  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.name changed: FRITZ!DECT 400 #3 (ack = true)
                                  2023-09-03 08:40:38.902  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.battery changed: 50 (ack = true)
                                  2023-09-03 08:40:38.905  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.batterylow changed: false (ack = true)
                                  2023-09-03 08:40:38.909  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.button.130960001449-0.id changed: 5000 (ack = true)
                                  2023-09-03 08:40:38.913  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.button.130960001449-0.name changed: FRITZ!DECT 400 #3: kurz (ack = true)
                                  2023-09-03 08:40:38.916  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.button.130960001449-0.lastpressedtimestamp changed: Sat Aug 26 2023 12:51:16 GMT+0200 (Central European Summer Time) (ack = true)
                                  2023-09-03 08:40:38.920  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.button.130960001449-9.id changed: 5001 (ack = true)
                                  2023-09-03 08:40:38.923  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.button.130960001449-9.name changed: FRITZ!DECT 400 #3: lang (ack = true)
                                  2023-09-03 08:40:38.928  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.synchronized changed: false (ack = true)
                                  2023-09-03 08:40:38.939  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.id changed: 900 (ack = true)
                                  2023-09-03 08:40:38.943  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.fwversion changed: 1.0 (ack = true)
                                  2023-09-03 08:40:38.946  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.manufacturer changed: AVM (ack = true)
                                  2023-09-03 08:40:38.949  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.present changed: true (ack = true)
                                  2023-09-03 08:40:38.952  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.txbusy changed: false (ack = true)
                                  2023-09-03 08:40:38.955  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.name changed: Außenbereich (ack = true)
                                  2023-09-03 08:40:38.958  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.state changed: false (ack = true)
                                  2023-09-03 08:40:38.962  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.mode changed: auto (ack = true)
                                  2023-09-03 08:40:38.964  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.lock changed: false (ack = true)
                                  2023-09-03 08:40:38.967  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.devicelock changed: false (ack = true)
                                  2023-09-03 08:40:38.970  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.state changed: false (ack = true)
                                  2023-09-03 08:40:38.974  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.voltage changed: 234.211 (ack = true)
                                  2023-09-03 08:40:38.977  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.power changed: 0 (ack = true)
                                  2023-09-03 08:40:38.980  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.energy changed: 38558 (ack = true)
                                  2023-09-03 08:40:38.984  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.masterdeviceid changed: 0 (ack = true)
                                  2023-09-03 08:40:38.987  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.members changed: 17 (ack = true)
                                  Schönen Sonntag zunächst...
                                  crunchipC Thomas BraunT ? 3 Antworten Letzte Antwort
                                  • R Rico Sander
                                    Moin,
                                    Skript v.2023-04-16
                                    *** BASE SYSTEM ***
                                    Docker          : false
                                    Release:        12
                                    Codename:       bookworm
                                    VERSION_ID="12"
                                    ID=raspbian
                                    ID_LIKE=debian
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    temp=55.5'C
                                    volt=0.8688V
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:           104M          0B        104M
                                             3794 M total memory
                                              894 M used memory
                                              858 M active memory
                                             2454 M free memory
                                               83 M buffer memory
                                              437 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    1.9G    /var/
                                    1.2G    /var/cache/apt
                                    1.2G    /var/cache
                                    528M    /var/log
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.8.0
                                    javascript:     7.0.3
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        4721
                                    States:         4005
                                    Pending Updates: 0
                                    crunchipC Offline
                                    crunchipC Offline
                                    #189
                                    debug: fritzdect.0
                                    dein loglevel steht auf debug, stell das mal zurück auf z.b. info
                                    • R Rico Sander
                                      Moin,
                                      Skript v.2023-04-16
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:        12
                                      Codename:       bookworm
                                      VERSION_ID="12"
                                      ID=raspbian
                                      ID_LIKE=debian
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=55.5'C
                                      volt=0.8688V
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:           104M          0B        104M
                                               3794 M total memory
                                                894 M used memory
                                                858 M active memory
                                               2454 M free memory
                                                 83 M buffer memory
                                                437 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      1.9G    /var/
                                      1.2G    /var/cache/apt
                                      1.2G    /var/cache
                                      528M    /var/log
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.8.0
                                      javascript:     7.0.3
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        4721
                                      States:         4005
                                      Pending Updates: 0
                                      #190
                                      @pi-ter
                                      Passt.
                                      Zu neofetch: Keine Ahnung.
                                      • R Rico Sander
                                        Moin,
                                        Skript v.2023-04-16
                                        *** BASE SYSTEM ***
                                        Docker          : false
                                        Release:        12
                                        Codename:       bookworm
                                        VERSION_ID="12"
                                        ID=raspbian
                                        ID_LIKE=debian
                                        CPU threads: 4
                                        Raspberry only:
                                        throttled=0x0
                                        temp=55.5'C
                                        volt=0.8688V
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:           104M          0B        104M
                                                 3794 M total memory
                                                  894 M used memory
                                                  858 M active memory
                                                 2454 M free memory
                                                   83 M buffer memory
                                                  437 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /var:
                                        1.9G    /var/
                                        1.2G    /var/cache/apt
                                        1.2G    /var/cache
                                        528M    /var/log
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.8.0
                                        javascript:     7.0.3
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        4721
                                        States:         4005
                                        Pending Updates: 0
                                        #191
                                        Moin,
                                        Du hast bei einem oder vielleicht auch noch bei anderen Adaptern den Log Level auf Debug stehen, das schreibt Dir das iobroker Log voll, wenn Du aktuell kein Fehler suchst, solltest Du das auf info oder error stellen.
                                        Keine Ahnung, ob ich Dich richtig verstehe, aber das, was man da normalerweise beim Login sieht, steht in der Datei /etc/motd, oder meinst Du das, was beim Booten angezeigt wird, das steuert man über Grub.
                                        Bernd
                                        P.S.: opps, man sollte nicht anfangen zu schreiben, dann Frühstücken und dann erst abschicken, dazu sind die User hier einfach zu schnell :)
                                          debug: fritzdect.0
                                          Rico Sander
                                          #192
                                          @crunchip
                                          Ja, richtig. Muss ich wieder zurückstellen... Trifft auf andere Adapter auch zu.
                                          Danke für die Erinnerung.
