[Problem] Dream btw. Enigma2 Adapter
Konnte den Adapter leider nicht installieren:
$ ./iobroker url "https://github.com/Matten-Matten/iobroker.enigma2" install https://github.com/Matten-Matten/iobroker.enigma2/tarball/master npm install https://github.com/Matten-Matten/iobroker.enigma2/tarball/master --production --prefix "/opt/iobroker" (System call) npm WARN excluding symbolic link node_modules/request/node_modules/.bin/har-validator -> ../har-validator/bin/har-validatornpm WARN excluding symbolic link node_modules/request/node_modules/.bin/uuid -> ../node-uuid/bin/uuid npm ERR! Linux 4.4.0-89-genericnpm ERR! argv "/root/.nvm/versions/node/v6.11.0/bin/node" "/root/.nvm/versions/node/v6.11.0/bin/npm" "install" "https://github.com/Matten-Matten/iobroker.enigma2/tarball/master" "--production" "--prefix" "/opt/iobroker" npm ERR! node v6.11.0 npm ERR! npm v3.10.10 npm ERR! path /tmp/npm-13415-92695ca7/unpack-1811fc56/package.json npm ERR! code ENOENT npm ERR! errno -2 npm ERR! syscall open npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-13415-92695ca7/unpack-1811fc56/package.json' npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-13415-92695ca7/unpack-1811fc56/package.json' npm ERR! enoent This is most likely not a problem with npm itself npm ERR! enoent and is related to npm not being able to find a file. npm ERR! enoent npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log ERROR: host.automation Cannot install https://github.com/Matten-Matten/iobroker.enigma2/tarball/master: 254 ERROR: process exited with code 25 ```` `so hab ich es auch nicht installiert bekommen. deshalb hab ich den ganzen Ordner immer in ioBroker\node_modules eingefügt.
ich hab auch nicht die Programmier Kenntnisse um so ein Fehler zu beheben. sry :(
Es wäre vorteilhafter, wenn du den original Adapter geforked hättest und per push request der eigentliche Entwickler deine Änderungen in den richtigen Adapter einfügt.
Dein Adapter basiert nämlich auf einer alten Version des originals.
Dein Adapter basiert nämlich auf einer alten Version des originals. `
Wie gesagt ich bin eigentlich nur Anwender. Hab lediglich für mich ein paar Veränderungen hinzugefügt und wollte es hier teilen. Hab den Adapter nur für mich in Enigma2 umbenannt, da er ja mit alle Boxen (webif oder openwebif ) funktioniert. Ich hab gesehen, dass du bereits Veränderungen am vuplus Adapter vorgenommen hast, sonst nimm doch alles nützliche aus meinen Veränderungen und füge die dem vuplus Adapter hinzu.
(Hatte den vuplus Adapter nach deinen Veränderungen nochmals versucht übers iobroker.admin webif zu installieren aber ohne erfolg. auch wenn ich den manuell in den Ordner schiebe und hochlade, kann ich zwar den Adapter einrichten und starten, jedoch steigt er gleich mit Fehlermeldung aus und stoppt.)
Okay, dass mein Adapter nen Fehler bringt, ist mir bisher nicht bekannt.
Bei mir läuft er super. Was für ein Fehler kommt denn im Log? Vorher braucht man ja auch noch nicht drüber nachdenken, die beiden Adapter zusammenzulegen, sonst holt man den Fehler ggf. noch mit.
iobroker 2017-09-20 10:01:01.178 info exit 25
iobroker 2017-09-20 10:01:01.169 error host.ioBroker Cannot install https://github.com/vader722/ioBroker.vuplus/tarball/master: 254
iobroker 2017-09-20 10:01:01.153 info npm ERR! /npm-debug.log
iobroker 2017-09-20 10:01:01.149 info npm ERR! Please include the following file with any support request:
iobroker 2017-09-20 10:01:01.098 info npm ERR! enoent
iobroker 2017-09-20 10:01:01.098 info npm ERR! enoent and is related to npm not being able to find a file.
iobroker 2017-09-20 10:01:01.098 info npm ERR! enoent This is most likely not a problem with npm itself
iobroker 2017-09-20 10:01:01.098 info npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-24311-36afe482/unpack-15dbad0b/package.json'
iobroker 2017-09-20 10:01:01.098 info npm ERR! syscall open
iobroker 2017-09-20 10:01:01.098 info npm ERR! errno -2
iobroker 2017-09-20 10:01:01.098 info npm ERR! code ENOENT
iobroker 2017-09-20 10:01:01.098 info npm ERR! path /tmp/npm-24311-36afe482/unpack-15dbad0b/package.json
iobroker 2017-09-20 10:01:01.098 info npm ERR! npm v3.10.10
iobroker 2017-09-20 10:01:01.098 info npm ERR! node v6.11.3
iobroker 2017-09-20 10:01:01.098 info npm ERR! Linux 4.9.0-3-amd64npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "https://github.com/vader722/ioBroker.vuplus/tarball/master" "--production" "--prefix" "/opt/iobroker"das kommt bei mir -
Bekomme auch beide Adapter nicht über Git installiert. Und wie Matten Matten schon schrieb, den VU+ bekam ich auch damals nicht über Git installiert und auch jetzt eben nicht.
Gleicher Fehler wie gst666 gepostet hat.
Damals hatte ich den vu+ dann in den Ordner gepackt, aber richtig lief er nicht, siehe Fehler Log von kmxak.
Wäre echt top wenn ihr vllt beide zusammen legen könntet und die Fehler natürlich vorher beseitigt [emoji3]
Trotzdem schon mal danke für die Arbeit und den/die Adapter. [emoji106]
Gesendet von meinem VTR-L09 mit Tapatalk
Das ist natürlich insofern problematisch, als dass es am Adapter vermutlich selber liegt und nicht an meinen Änderungen. Denn an der Installationsroutine habe ich nicht gewerkelt und da scheint das Problem zu sein.
Da ich aber nicht der Eigentümer des github Projektes bin, ist das debuggen nicht ganz so einfach. Bin da jetzt auch nicht der vollprofi, was die Adaptererstellung angeht. Habe nur nur ein bestehendes erweitert. Aber mal so ins blaue raus geschossen. Könnte es vielleicht daran liegen, dass ihr eine veraltete NodeJS Version installiert habt?
Ich denke nicht das die 6er veraltet ist ;)
Welche Version hast du denn?
Bin auf node 6.11.2 und npm 3.10.10
ich konnte den Adapter normal installieren, aber hier ein paar Fehler aus dem LOG:
Wenn der Receiver an ist kommt folgender Fehler:
vuplus.0 2017-10-29 08:47:35.552 error No e2state foundWenn der Receiver im Deepsleep ist rastet das Teil komplett aus:
vuplus.0 2017-10-29 08:43:44.399 error Error for "GETDOWNMIX': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:44.395 error Error for "GETCURRENT': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:44.393 error Error for "GETVOLUME': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:44.389 error Error for "GETINFO': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:44.387 error Error for "GETSTANDBY': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:39.428 error Error for "GETDOWNMIX': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:39.426 error Error for "GETCURRENT': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:39.424 error Error for "GETVOLUME': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:39.422 error Error for "GETINFO': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:39.420 error Error for "GETSTANDBY': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:34.373 error Error for "GETDOWNMIX': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:34.368 error Error for "GETCURRENT': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:34.362 error Error for "GETVOLUME': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:34.356 error Error for "GETINFO': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:34.353 error Error for "GETSTANDBY': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:29.350 error Error for "GETDOWNMIX': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:29.348 error Error for "GETCURRENT': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:29.346 error Error for "GETVOLUME': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:29.344 error Error for "GETINFO': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:29.342 error Error for "GETSTANDBY': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:24.411 error Error for "GETDOWNMIX': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:24.409 error Error for "GETCURRENT': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:24.407 error Error for "GETVOLUME': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:24.405 error Error for "GETINFO': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:24.403 error Error for "GETSTANDBY': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:19.326 error Error for "GETDOWNMIX': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:19.322 error Error for "GETCURRENT': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:19.319 error Error for "GETVOLUME': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:19.317 error Error for "GETINFO': received error: connect ECONNREFUSED 192.168.188.30:80 vuplus.0 2017-10-29 08:43:19.315 error Error for "GETSTANDBY': received error: connect ECONNREFUSED 192.168.188.30:80Gruß Lars
Wenn der Receiver im Deepsleep ist rastet das Teil komplett aus: `
klinkt logisch bei deepsleep schaltet er auch die nertzwerkarte aus soweit ich weis mit logischer folge das der adapter ihn nicht mehr erreichen kan
~Dutch
Eigentlich ja, sollte aber keine Fehler produzieren.
Wenn false dann aus, aber keine Fehler.
~Dutch `
Das Problem liegt glaube ich an der VU Box. Ich kann die WebIF Oberfläche seit dem letzten Update auch nicht mehr aufrufen, obwohl die VU im Netzwerk ist.
Ich kann die WebIF Oberfläche seit dem letzten Update auch nicht mehr aufrufen `
kann ich nicht bestätigen, alles da -
Okay, bei mir aber definitiv EIN Problem.Kann die Box zwar anpingen, aber weder per http erreichen, noch per ioBroker. Ist mir aber mehr zufällig aufgefallen und noch nicht weiter verfolgt.
Versuche doch mal Webif über die Box zu löschen und neu zu installieren. Scheint ja ein Problem der Box zu sein.
Okay, bei mir aber definitiv EIN Problem.Kann die Box zwar anpingen, aber weder per http erreichen, noch per ioBroker. Ist mir aber mehr zufällig aufgefallen und noch nicht weiter verfolgt. `
Also meine Box funktioniert prima über das WebIF und auch die Verbindung vom Adapter wird mit grün dargestellt, aber ich hab im Log alles voll von dieser Meldung:````
vuplus.0 2017-11-07 21:11:05.053 error No e2state found
vuplus.0 2017-11-07 21:11:00.036 error No e2state found
vuplus.0 2017-11-07 21:10:55.018 error No e2state found
vuplus.0 2017-11-07 21:10:50.639 error No e2state found
