  4. Absturz bei Aktualisierung - Neustart nicht möglich!
    5.2k
139 Beiträge 8 Kommentatoren 19.7k Aufrufe 7 Beobachtet
  • L LaBamba
    @homoran said in Absturz bei Aktualisierung - Neustart nicht möglich!:
    iob diag
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     17:56:14 up 2 min,  2 users,  load average: 2.28, 0.94, 0.36
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=37.4'C
    volt=0.8625V
    *** Time and Time Zones ***
                   Local time: Tue 2023-08-29 17:56:14 CEST
               Universal time: Tue 2023-08-29 15:56:14 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G         63M        3.2G        8.0M        538M        3.6G
    Swap:           99M          0B         99M
    Total:         3.9G         63M        3.3G
             3838 M total memory
               63 M used memory
              299 M active memory
              152 M inactive memory
             3236 M free memory
              127 M buffer memory
              410 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G   27G  864M  97% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G  8.6M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Tue Aug 29 17:53:51 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:09:ED:BB vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d9b3f436-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Tue Aug 29 17:53:52 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Tue Aug 29 17:53:52 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Tue Aug 29 17:53:52 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Tue Aug 29 17:53:52 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Tue Aug 29 17:53:52 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Aug 29 17:53:55 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    573M    /var/
    287M    /var/cache
    274M    /var/cache/apt
    215M    /var/cache/apt/archives
    125M    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    436M    /opt/iobroker/backups/
    1.9M    /opt/iobroker/backups/scripte/common
    948K    /opt/iobroker/backups/scripte/common/Raffstore
    340K    /opt/iobroker/backups/scripte/common/Rolladen
    /opt/iobroker/iobroker-data:
    3.7G    /opt/iobroker/iobroker-data/
    2.7G    /opt/iobroker/iobroker-data/history
    750M    /opt/iobroker/iobroker-data/files
    154M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/iobroker.icons-open-icon-library-png
    42M     /opt/iobroker/iobroker-data/states.jsonl
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    node:internal/modules/cjs/loader:1080
      throw err;
    Error: Cannot find module 'node-forge'
    Require stack:
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        at Module._load (node:internal/modules/cjs/loader:922:27)
        at Module.require (node:internal/modules/cjs/loader:1143:19)
        at require (node:internal/modules/cjs/helpers:121:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:7:15)
        at Module._compile (node:internal/modules/cjs/loader:1256:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        at Module.load (node:internal/modules/cjs/loader:1119:32)
        at Module._load (node:internal/modules/cjs/loader:960:12)
        at Module.require (node:internal/modules/cjs/loader:1143:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Node.js v18.17.1
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.17.1
    Core adapters versions
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.17.1
    js-controller:
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.17.1
    admin:
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.17.1
    javascript:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @apollon/iobroker-tools@0.2.1 /opt/iobroker/node_modules/@apollon/iobroker-tools
    npm ERR! extraneous: @aws-crypto/crc32@3.0.0 /opt/iobroker/node_modules/@aws-crypto/crc32
    npm ERR! extraneous: @aws-crypto/ie11-detection@3.0.0 /opt/iobroker/node_modules/@aws-crypto/ie11-detection
    npm ERR! extraneous: @aws-crypto/sha256-browser@3.0.0 /opt/iobroker/node_modules/@aws-crypto/sha256-browser
    npm ERR! extraneous: @aws-crypto/sha256-js@3.0.0 /opt/iobroker/node_modules/@aws-crypto/sha256-js
    npm ERR! extraneous: @aws-crypto/supports-web-crypto@3.0.0 /opt/iobroker/node_modules/@aws-crypto/supports-web-crypto
    npm ERR! extraneous: @aws-crypto/util@3.0.0 /opt/iobroker/node_modules/@aws-crypto/util
    npm ERR! extraneous: @aws-sdk/client-cognito-identity@3.398.0 /opt/iobroker/node_modules/@aws-sdk/client-cognito-identity
    npm ERR! extraneous: @aws-sdk/client-sso@3.398.0 /opt/iobroker/node_modules/@aws-sdk/client-sso
    npm ERR! extraneous: @aws-sdk/client-sts@3.398.0 /opt/iobroker/node_modules/@aws-sdk/client-sts
    npm ERR! extraneous: @aws-sdk/credential-provider-cognito-identity@3.398.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-cognito-identity
    npm ERR! extraneous: @aws-sdk/credential-provider-env@3.398.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-env
    npm ERR! extraneous: @aws-sdk/credential-provider-ini@3.398.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-ini
    npm ERR! extraneous: @aws-sdk/credential-provider-node@3.398.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-node
    npm ERR! extraneous: @aws-sdk/credential-provider-process@3.398.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-process
    npm ERR! extraneous: @aws-sdk/credential-provider-sso@3.398.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-sso
    npm ERR! extraneous: @aws-sdk/credential-provider-web-identity@3.398.0 /opt/iobroker/node_modules/@aws-sdk/credential-provider-web-identity
    npm ERR! extraneous: @aws-sdk/credential-providers@3.398.0 /opt/iobroker/node_modules/@aws-sdk/credential-providers
    npm ERR! extraneous: @aws-sdk/middleware-host-header@3.398.0 /opt/iobroker/node_modules/@aws-sdk/middleware-host-header
    npm ERR! extraneous: @aws-sdk/middleware-logger@3.398.0 /opt/iobroker/node_modules/@aws-sdk/middleware-logger
    npm ERR! extraneous: @aws-sdk/middleware-recursion-detection@3.398.0 /opt/iobroker/node_modules/@aws-sdk/middleware-recursion-detection
    npm ERR! extraneous: @aws-sdk/middleware-sdk-sts@3.398.0 /opt/iobroker/node_modules/@aws-sdk/middleware-sdk-sts
    npm ERR! extraneous: @aws-sdk/middleware-signing@3.398.0 /opt/iobroker/node_modules/@aws-sdk/middleware-signing
    npm ERR! extraneous: @aws-sdk/middleware-user-agent@3.398.0 /opt/iobroker/node_modules/@aws-sdk/middleware-user-agent
    npm ERR! extraneous: @aws-sdk/token-providers@3.398.0 /opt/iobroker/node_modules/@aws-sdk/token-providers
    npm ERR! extraneous: @aws-sdk/types@3.398.0 /opt/iobroker/node_modules/@aws-sdk/types
    npm ERR! extraneous: @aws-sdk/util-endpoints@3.398.0 /opt/iobroker/node_modules/@aws-sdk/util-endpoints
    npm ERR! extraneous: @aws-sdk/util-locate-window@3.310.0 /opt/iobroker/node_modules/@aws-sdk/util-locate-window
    npm ERR! extraneous: @aws-sdk/util-user-agent-browser@3.398.0 /opt/iobroker/node_modules/@aws-sdk/util-user-agent-browser
    npm ERR! extraneous: @aws-sdk/util-user-agent-node@3.398.0 /opt/iobroker/node_modules/@aws-sdk/util-user-agent-node
    npm ERR! extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
    npm ERR! extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
    npm ERR! extraneous: @iobroker/webserver@0.3.6 /opt/iobroker/node_modules/@iobroker/webserver
    npm ERR! extraneous: @microsoft/microsoft-graph-types@2.38.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
    npm ERR! extraneous: @mongodb-js/saslprep@1.1.0 /opt/iobroker/node_modules/@mongodb-js/saslprep
    npm ERR! extraneous: @serialport/binding-mock@10.2.2 /opt/iobroker/node_modules/@serialport/binding-mock
    npm ERR! extraneous: @serialport/bindings-cpp@11.0.3 /opt/iobroker/node_modules/@serialport/bindings-cpp
    npm ERR! extraneous: @serialport/bindings-interface@1.2.2 /opt/iobroker/node_modules/@serialport/bindings-interface
    npm ERR! extraneous: @serialport/parser-byte-length@11.0.1 /opt/iobroker/node_modules/@serialport/parser-byte-length
    npm ERR! extraneous: @serialport/parser-cctalk@11.0.1 /opt/iobroker/node_modules/@serialport/parser-cctalk
    npm ERR! extraneous: @serialport/parser-delimiter@11.0.1 /opt/iobroker/node_modules/@serialport/parser-delimiter
    npm ERR! extraneous: @serialport/parser-inter-byte-timeout@11.0.1 /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
    npm ERR! extraneous: @serialport/parser-packet-length@11.0.1 /opt/iobroker/node_modules/@serialport/parser-packet-length
    npm ERR! extraneous: @serialport/parser-readline@11.0.1 /opt/iobroker/node_modules/@serialport/parser-readline
    npm ERR! extraneous: @serialport/parser-ready@11.0.1 /opt/iobroker/node_modules/@serialport/parser-ready
    npm ERR! extraneous: @serialport/parser-regex@11.0.1 /opt/iobroker/node_modules/@serialport/parser-regex
    npm ERR! extraneous: @serialport/parser-slip-encoder@11.0.1 /opt/iobroker/node_modules/@serialport/parser-slip-encoder
    npm ERR! extraneous: @serialport/parser-spacepacket@11.0.1 /opt/iobroker/node_modules/@serialport/parser-spacepacket
    npm ERR! extraneous: @serialport/stream@11.0.1 /opt/iobroker/node_modules/@serialport/stream
    npm ERR! extraneous: @smithy/abort-controller@2.0.5 /opt/iobroker/node_modules/@smithy/abort-controller
    npm ERR! extraneous: @smithy/config-resolver@2.0.5 /opt/iobroker/node_modules/@smithy/config-resolver
    npm ERR! extraneous: @smithy/credential-provider-imds@2.0.5 /opt/iobroker/node_modules/@smithy/credential-provider-imds
    npm ERR! extraneous: @smithy/eventstream-codec@2.0.5 /opt/iobroker/node_modules/@smithy/eventstream-codec
    npm ERR! extraneous: @smithy/fetch-http-handler@2.0.5 /opt/iobroker/node_modules/@smithy/fetch-http-handler
    npm ERR! extraneous: @smithy/hash-node@2.0.5 /opt/iobroker/node_modules/@smithy/hash-node
    npm ERR! extraneous: @smithy/invalid-dependency@2.0.5 /opt/iobroker/node_modules/@smithy/invalid-dependency
    npm ERR! extraneous: @smithy/is-array-buffer@2.0.0 /opt/iobroker/node_modules/@smithy/is-array-buffer
    npm ERR! extraneous: @smithy/middleware-content-length@2.0.5 /opt/iobroker/node_modules/@smithy/middleware-content-length
    npm ERR! extraneous: @smithy/middleware-endpoint@2.0.5 /opt/iobroker/node_modules/@smithy/middleware-endpoint
    npm ERR! extraneous: @smithy/middleware-retry@2.0.5 /opt/iobroker/node_modules/@smithy/middleware-retry
    npm ERR! extraneous: @smithy/middleware-serde@2.0.5 /opt/iobroker/node_modules/@smithy/middleware-serde
    npm ERR! extraneous: @smithy/middleware-stack@2.0.0 /opt/iobroker/node_modules/@smithy/middleware-stack
    npm ERR! extraneous: @smithy/node-config-provider@2.0.5 /opt/iobroker/node_modules/@smithy/node-config-provider
    npm ERR! extraneous: @smithy/node-http-handler@2.0.5 /opt/iobroker/node_modules/@smithy/node-http-handler
    npm ERR! extraneous: @smithy/property-provider@2.0.5 /opt/iobroker/node_modules/@smithy/property-provider
    npm ERR! extraneous: @smithy/protocol-http@2.0.5 /opt/iobroker/node_modules/@smithy/protocol-http
    npm ERR! extraneous: @smithy/querystring-builder@2.0.5 /opt/iobroker/node_modules/@smithy/querystring-builder
    npm ERR! extraneous: @smithy/querystring-parser@2.0.5 /opt/iobroker/node_modules/@smithy/querystring-parser
    npm ERR! extraneous: @smithy/service-error-classification@2.0.0 /opt/iobroker/node_modules/@smithy/service-error-classification
    npm ERR! extraneous: @smithy/shared-ini-file-loader@2.0.5 /opt/iobroker/node_modules/@smithy/shared-ini-file-loader
    npm ERR! extraneous: @smithy/signature-v4@2.0.5 /opt/iobroker/node_modules/@smithy/signature-v4
    npm ERR! extraneous: @smithy/smithy-client@2.0.5 /opt/iobroker/node_modules/@smithy/smithy-client
    npm ERR! extraneous: @smithy/types@2.2.2 /opt/iobroker/node_modules/@smithy/types
    npm ERR! extraneous: @smithy/url-parser@2.0.5 /opt/iobroker/node_modules/@smithy/url-parser
    npm ERR! extraneous: @smithy/util-base64@2.0.0 /opt/iobroker/node_modules/@smithy/util-base64
    npm ERR! extraneous: @smithy/util-body-length-browser@2.0.0 /opt/iobroker/node_modules/@smithy/util-body-length-browser
    npm ERR! extraneous: @smithy/util-body-length-node@2.1.0 /opt/iobroker/node_modules/@smithy/util-body-length-node
    npm ERR! extraneous: @smithy/util-buffer-from@2.0.0 /opt/iobroker/node_modules/@smithy/util-buffer-from
    npm ERR! extraneous: @smithy/util-config-provider@2.0.0 /opt/iobroker/node_modules/@smithy/util-config-provider
    npm ERR! extraneous: @smithy/util-defaults-mode-browser@2.0.5 /opt/iobroker/node_modules/@smithy/util-defaults-mode-browser
    npm ERR! extraneous: @smithy/util-defaults-mode-node@2.0.5 /opt/iobroker/node_modules/@smithy/util-defaults-mode-node
    npm ERR! extraneous: @smithy/util-hex-encoding@2.0.0 /opt/iobroker/node_modules/@smithy/util-hex-encoding
    npm ERR! extraneous: @smithy/util-middleware@2.0.0 /opt/iobroker/node_modules/@smithy/util-middleware
    npm ERR! extraneous: @smithy/util-retry@2.0.0 /opt/iobroker/node_modules/@smithy/util-retry
    npm ERR! extraneous: @smithy/util-stream@2.0.5 /opt/iobroker/node_modules/@smithy/util-stream
    npm ERR! extraneous: @smithy/util-uri-escape@2.0.0 /opt/iobroker/node_modules/@smithy/util-uri-escape
    npm ERR! extraneous: @smithy/util-utf8@2.0.0 /opt/iobroker/node_modules/@smithy/util-utf8
    npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modules/@socket.io/component-emitter
    npm ERR! extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
    npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
    npm ERR! extraneous: @types/cors@2.8.13 /opt/iobroker/node_modules/@types/cors
    npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: @types/webidl-conversions@7.0.0 /opt/iobroker/node_modules/@types/webidl-conversions
    npm ERR! extraneous: @types/whatwg-url@8.2.2 /opt/iobroker/node_modules/@types/whatwg-url
    npm ERR! extraneous: acorn-walk@8.2.0 /opt/iobroker/node_modules/acorn-walk
    npm ERR! extraneous: acorn@8.7.1 /opt/iobroker/node_modules/acorn
    npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/ajv
    npm ERR! extraneous: any-promise@1.3.0 /opt/iobroker/node_modules/any-promise
    npm ERR! extraneous: argparse@2.0.1 /opt/iobroker/node_modules/argparse
    npm ERR! extraneous: array-buffer-byte-length@1.0.0 /opt/iobroker/node_modules/array-buffer-byte-length
    npm ERR! extraneous: arraybuffer.prototype.slice@1.0.1 /opt/iobroker/node_modules/arraybuffer.prototype.slice
    npm ERR! extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
    npm ERR! extraneous: async-limiter@1.0.1 /opt/iobroker/node_modules/async-limiter
    npm ERR! extraneous: available-typed-arrays@1.0.5 /opt/iobroker/node_modules/available-typed-arrays
    npm ERR! extraneous: b4a@1.6.4 /opt/iobroker/node_modules/b4a
    npm ERR! extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
    npm ERR! extraneous: boolbase@1.0.0 /opt/iobroker/node_modules/boolbase
    npm ERR! extraneous: bowser@2.11.0 /opt/iobroker/node_modules/bowser
    npm ERR! extraneous: bson@4.7.2 /opt/iobroker/node_modules/bson
    npm ERR! extraneous: buffer-crc32@0.2.13 /opt/iobroker/node_modules/buffer-crc32
    npm ERR! extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
    npm ERR! extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
    npm ERR! extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
    npm ERR! extraneous: cheerio-select@1.6.0 /opt/iobroker/node_modules/cheerio-select
    npm ERR! extraneous: cheerio@1.0.0-rc.10 /opt/iobroker/node_modules/cheerio
    npm ERR! extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
    npm ERR! extraneous: coap@0.26.0 /opt/iobroker/node_modules/coap
    npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
    npm ERR! extraneous: commist@1.1.0 /opt/iobroker/node_modules/commist
    npm ERR! extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
    npm ERR! extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
    npm ERR! extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
    npm ERR! extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
    npm ERR! extraneous: cronosjs@1.7.1 /opt/iobroker/node_modules/cronosjs
    npm ERR! extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
    npm ERR! extraneous: crypto@1.0.1 /opt/iobroker/node_modules/crypto
    npm ERR! extraneous: css-select@4.3.0 /opt/iobroker/node_modules/css-select
    npm ERR! extraneous: css-what@6.1.0 /opt/iobroker/node_modules/css-what
    npm ERR! extraneous: debounce@1.2.1 /opt/iobroker/node_modules/debounce
    npm ERR! extraneous: dom-serializer@1.4.1 /opt/iobroker/node_modules/dom-serializer
    npm ERR! extraneous: domelementtype@2.3.0 /opt/iobroker/node_modules/domelementtype
    npm ERR! extraneous: domhandler@4.3.1 /opt/iobroker/node_modules/domhandler
    npm ERR! extraneous: domutils@2.8.0 /opt/iobroker/node_modules/domutils
    npm ERR! extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
    npm ERR! extraneous: duplexify@4.1.2 /opt/iobroker/node_modules/duplexify
    npm ERR! extraneous: entities@2.2.0 /opt/iobroker/node_modules/entities
    npm ERR! extraneous: es-set-tostringtag@2.0.1 /opt/iobroker/node_modules/es-set-tostringtag
    npm ERR! extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
    npm ERR! extraneous: express-fileupload@1.4.0 /opt/iobroker/node_modules/express-fileupload
    npm ERR! extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
    npm ERR! extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
    npm ERR! extraneous: fast-xml-parser@4.2.5 /opt/iobroker/node_modules/fast-xml-parser
    npm ERR! extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
    npm ERR! extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
    npm ERR! extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
    npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
    npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
    npm ERR! extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
    npm ERR! extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
    npm ERR! extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
    npm ERR! extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
    npm ERR! extraneous: get-symbol-description@1.0.0 /opt/iobroker/node_modules/get-symbol-description
    npm ERR! extraneous: globalthis@1.0.3 /opt/iobroker/node_modules/globalthis
    npm ERR! extraneous: google-auth-library@8.9.0 /opt/iobroker/node_modules/google-auth-library
    npm ERR! extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
    npm ERR! extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
    npm ERR! extraneous: gopd@1.0.1 /opt/iobroker/node_modules/gopd
    npm ERR! extraneous: gridstack@0.6.4 /opt/iobroker/node_modules/gridstack
    npm ERR! extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
    npm ERR! extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
    npm ERR! extraneous: has-tostringtag@1.0.0 /opt/iobroker/node_modules/has-tostringtag
    npm ERR! extraneous: hash-sum@2.0.0 /opt/iobroker/node_modules/hash-sum
    npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/he
    npm ERR! extraneous: help-me@3.0.0 /opt/iobroker/node_modules/help-me
    npm ERR! extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
    npm ERR! extraneous: hpagent@1.0.0 /opt/iobroker/node_modules/hpagent
    npm ERR! extraneous: htmlparser2@6.1.0 /opt/iobroker/node_modules/htmlparser2
    npm ERR! extraneous: internal-slot@1.0.5 /opt/iobroker/node_modules/internal-slot
    npm ERR! invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
    npm ERR! invalid: iobroker.alarm@3.3.12 /opt/iobroker/node_modules/iobroker.alarm
    npm ERR! invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
    npm ERR! invalid: iobroker.devices@ /opt/iobroker/node_modules/iobroker.devices
    npm ERR! invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
    npm ERR! invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
    npm ERR! invalid: iobroker.icons-open-icon-library-png@0.1.3 /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png
    npm ERR! invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
    npm ERR! invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
    npm ERR! invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
    npm ERR! invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
    npm ERR! invalid: iobroker.shelly@ /opt/iobroker/node_modules/iobroker.shelly
    npm ERR! invalid: iobroker.vis-icontwo@ /opt/iobroker/node_modules/iobroker.vis-icontwo
    npm ERR! invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
    npm ERR! invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
    npm ERR! invalid: iobroker.vis-plumb@ /opt/iobroker/node_modules/iobroker.vis-plumb
    npm ERR! invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
    npm ERR! invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
    npm ERR! invalid: iobroker.zigbee@ /opt/iobroker/node_modules/iobroker.zigbee
    npm ERR! extraneous: ipaddr.js@2.1.0 /opt/iobroker/node_modules/ipaddr.js
    npm ERR! extraneous: is-array-buffer@3.0.2 /opt/iobroker/node_modules/is-array-buffer
    npm ERR! extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
    npm ERR! extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
    npm ERR! extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
    npm ERR! extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
    npm ERR! extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
    npm ERR! extraneous: is-negative-zero@2.0.2 /opt/iobroker/node_modules/is-negative-zero
    npm ERR! extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
    npm ERR! extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
    npm ERR! extraneous: is-shared-array-buffer@1.0.2 /opt/iobroker/node_modules/is-shared-array-buffer
    npm ERR! extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
    npm ERR! extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
    npm ERR! extraneous: is-typed-array@1.1.12 /opt/iobroker/node_modules/is-typed-array
    npm ERR! extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
    npm ERR! extraneous: jquery@ /opt/iobroker/node_modules/jquery
    npm ERR! extraneous: js-sdsl@4.3.0 /opt/iobroker/node_modules/js-sdsl
    npm ERR! extraneous: js-yaml@4.1.0 /opt/iobroker/node_modules/js-yaml
    npm ERR! extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
    npm ERR! extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
    npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
    npm ERR! extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
    npm ERR! extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
    npm ERR! extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
    npm ERR! extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
    npm ERR! extraneous: media-typer@1.1.0 /opt/iobroker/node_modules/media-typer
    npm ERR! extraneous: memory-pager@1.5.0 /opt/iobroker/node_modules/memory-pager
    npm ERR! extraneous: mixin-deep@2.0.1 /opt/iobroker/node_modules/mixin-deep
    npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
    npm ERR! extraneous: mongodb-connection-string-url@2.6.0 /opt/iobroker/node_modules/mongodb-connection-string-url
    npm ERR! extraneous: mqtt@4.3.7 /opt/iobroker/node_modules/mqtt
    npm ERR! extraneous: mz@2.7.0 /opt/iobroker/node_modules/mz
    npm ERR! extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
    npm ERR! extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
    npm ERR! extraneous: node-aead-crypto-android-arm-eabi@ /opt/iobroker/node_modules/node-aead-crypto-android-arm-eabi
    npm ERR! extraneous: node-aead-crypto-android-arm64@ /opt/iobroker/node_modules/node-aead-crypto-android-arm64
    npm ERR! extraneous: node-aead-crypto-darwin-arm64@ /opt/iobroker/node_modules/node-aead-crypto-darwin-arm64
    npm ERR! extraneous: node-aead-crypto-darwin-universal@ /opt/iobroker/node_modules/node-aead-crypto-darwin-universal
    npm ERR! extraneous: node-aead-crypto-darwin-x64@ /opt/iobroker/node_modules/node-aead-crypto-darwin-x64
    npm ERR! extraneous: node-aead-crypto-linux-arm-gnueabihf@3.0.1 /opt/iobroker/node_modules/node-aead-crypto-linux-arm-gnueabihf
    npm ERR! extraneous: node-aead-crypto-linux-arm64-gnu@ /opt/iobroker/node_modules/node-aead-crypto-linux-arm64-gnu
    npm ERR! extraneous: node-aead-crypto-linux-arm64-musl@ /opt/iobroker/node_modules/node-aead-crypto-linux-arm64-musl
    npm ERR! extraneous: node-aead-crypto-linux-x64-gnu@ /opt/iobroker/node_modules/node-aead-crypto-linux-x64-gnu
    npm ERR! extraneous: node-aead-crypto-linux-x64-musl@ /opt/iobroker/node_modules/node-aead-crypto-linux-x64-musl
    npm ERR! extraneous: node-aead-crypto-win32-arm64-msvc@ /opt/iobroker/node_modules/node-aead-crypto-win32-arm64-msvc
    npm ERR! extraneous: node-aead-crypto-win32-ia32-msvc@ /opt/iobroker/node_modules/node-aead-crypto-win32-ia32-msvc
    npm ERR! extraneous: node-aead-crypto-win32-x64-msvc@ /opt/iobroker/node_modules/node-aead-crypto-win32-x64-msvc
    npm ERR! extraneous: node-gyp-build@4.6.0 /opt/iobroker/node_modules/node-gyp-build
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
    npm ERR! extraneous: node-rest-client@3.1.1 /opt/iobroker/node_modules/node-rest-client
    npm ERR! extraneous: node-watch@0.7.3 /opt/iobroker/node_modules/node-watch
    npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
    npm ERR! extraneous: nth-check@2.1.1 /opt/iobroker/node_modules/nth-check
    npm ERR! extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/number-allocator
    npm ERR! extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
    npm ERR! extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
    npm ERR! extraneous: parse5-htmlparser2-tree-adapter@6.0.1 /opt/iobroker/node_modules/parse5-htmlparser2-tree-adapter
    npm ERR! extraneous: parse5@6.0.1 /opt/iobroker/node_modules/parse5
    npm ERR! extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
    npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
    npm ERR! extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
    npm ERR! extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
    npm ERR! extraneous: regenerator-runtime@0.14.0 /opt/iobroker/node_modules/regenerator-runtime
    npm ERR! extraneous: regexp.prototype.flags@1.5.0 /opt/iobroker/node_modules/regexp.prototype.flags
    npm ERR! extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
    npm ERR! extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
    npm ERR! extraneous: rfdc@1.3.0 /opt/iobroker/node_modules/rfdc
    npm ERR! extraneous: safe-array-concat@1.0.0 /opt/iobroker/node_modules/safe-array-concat
    npm ERR! extraneous: safe-regex-test@1.0.0 /opt/iobroker/node_modules/safe-regex-test
    npm ERR! extraneous: serialport@11.0.1 /opt/iobroker/node_modules/serialport
    npm ERR! extraneous: shelly-iot@1.1.2 /opt/iobroker/node_modules/shelly-iot
    npm ERR! extraneous: slip@1.0.2 /opt/iobroker/node_modules/slip
    npm ERR! extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
    npm ERR! extraneous: socks@2.7.1 /opt/iobroker/node_modules/socks
    npm ERR! extraneous: sparse-bitfield@3.0.3 /opt/iobroker/node_modules/sparse-bitfield
    npm ERR! extraneous: split2@3.2.2 /opt/iobroker/node_modules/split2
    npm ERR! extraneous: streamx@2.15.1 /opt/iobroker/node_modules/streamx
    npm ERR! extraneous: string.prototype.trim@1.2.7 /opt/iobroker/node_modules/string.prototype.trim
    npm ERR! extraneous: string.prototype.trimend@1.0.6 /opt/iobroker/node_modules/string.prototype.trimend
    npm ERR! extraneous: string.prototype.trimstart@1.0.6 /opt/iobroker/node_modules/string.prototype.trimstart
    npm ERR! extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
    npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
    npm ERR! extraneous: systeminformation@5.21.1 /opt/iobroker/node_modules/systeminformation
    npm ERR! extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
    npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/tar-stream
    npm ERR! extraneous: tcp-ping@0.1.1 /opt/iobroker/node_modules/tcp-ping
    npm ERR! extraneous: thenify-all@1.6.0 /opt/iobroker/node_modules/thenify-all
    npm ERR! extraneous: thenify@3.3.1 /opt/iobroker/node_modules/thenify
    npm ERR! extraneous: tough-cookie@4.0.0 /opt/iobroker/node_modules/tough-cookie
    npm ERR! extraneous: tr46@3.0.0 /opt/iobroker/node_modules/tr46
    npm ERR! extraneous: typed-array-buffer@1.0.0 /opt/iobroker/node_modules/typed-array-buffer
    npm ERR! extraneous: typed-array-byte-length@1.0.0 /opt/iobroker/node_modules/typed-array-byte-length
    npm ERR! extraneous: typed-array-byte-offset@1.0.0 /opt/iobroker/node_modules/typed-array-byte-offset
    npm ERR! extraneous: typed-array-length@1.0.4 /opt/iobroker/node_modules/typed-array-length
    npm ERR! extraneous: typescript@ /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
    npm ERR! extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
    npm ERR! extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! extraneous: webdav@4.11.2 /opt/iobroker/node_modules/webdav
    npm ERR! extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
    npm ERR! extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
    npm ERR! extraneous: whatwg-url@11.0.0 /opt/iobroker/node_modules/whatwg-url
    npm ERR! extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
    npm ERR! extraneous: which-typed-array@1.1.11 /opt/iobroker/node_modules/which-typed-array
    npm ERR! extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
    npm ERR! extraneous: zigbee-herdsman-converters@ /opt/iobroker/node_modules/zigbee-herdsman-converters
    npm ERR! extraneous: zigbee-herdsman@ /opt/iobroker/node_modules/zigbee-herdsman
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-08-29T15_56_27_213Z-debug-0.log
    Adapters from github:   2
    Adapter State
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.17.1
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.17.1
    ioBroker-Repositories
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.17.1
    Installed ioBroker-Instances
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.17.1
    Objects and States
    Objects:        0
    States:         0
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14231      499/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16184      359/cupsd
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          16337      508/xrdp-sesman
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14233      499/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16183      359/cupsd
    tcp6       0      0 :::3389                 :::*                    LISTEN      110        18505      524/xrdp
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19479      430/dhcpcd
    udp        0      0 0.0.0.0:33389           0.0.0.0:*                           108        16488      389/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16859      466/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16486      389/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          18863      430/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        16487      389/avahi-daemon: r
    udp6       0      0 :::42303                :::*                                108        16489      389/avahi-daemon: r
    2023-08-29 10:32:12.862  - info: host.raspberrypi All instances are stopped.
    2023-08-29 10:32:12.870  - info: sonoff.0 (20084) terminating
    2023-08-29 10:32:12.873  - info: sonoff.0 (20084) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-08-29 10:32:12.883  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
    2023-08-29 10:32:12.886  - info: host.raspberrypi instance system.adapter.socketio.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-29 10:32:12.888  - info: host.raspberrypi All instances are stopped.
    2023-08-29 10:32:12.925  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
    2023-08-29 10:32:12.926  - info: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-29 10:32:12.927  - info: host.raspberrypi All instances are stopped.
    2023-08-29 10:32:12.930  - info: node-red.0 (19816) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-08-29 10:32:12.960  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
    2023-08-29 10:32:12.961  - info: host.raspberrypi instance system.adapter.tankerkoenig.3 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-29 10:32:12.963  - info: host.raspberrypi All instances are stopped.
    2023-08-29 10:32:12.987  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
    2023-08-29 10:32:12.988  - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-29 10:32:12.988  - info: host.raspberrypi All instances are stopped.
    2023-08-29 10:32:13.209  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
    2023-08-29 10:32:13.210  - info: host.raspberrypi instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-29 10:32:13.210  - info: host.raspberrypi All instances are stopped.
    2023-08-29 10:32:13.274  - info: history.0 (19692) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-08-29 10:32:13.283  - info: host.raspberrypi terminated
    2023-08-29 10:32:13.570  - info: simple-api.0 (30475) terminating http server on port 8087
    2023-08-29 10:32:15.117  - info: simple-api.0 (30475) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-08-29 10:32:17.686  - error: simple-api.0 (30475) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2023-08-29 10:32:18.300  - warn: simple-api.0 (30475) get state error: Connection is closed.
    iob diag has finished.
    @labamba sagte in Absturz bei Aktualisierung - Neustart nicht möglich!:
    *** FILESYSTEM ***
    Moin,
    ich wieder hole mich, aber angeblich hast Du doch Platz geschaffen?
    *** FILESYSTEM ***
    Aber wie @Thomas-Braun schon anmerkte, die Kiste immer ordentlich stoppen und wieder starten, aktuell scheint das root Device nur lesend eingebunden zu sein, außer da kamen noch Meldungen, die aber vom iob diag nicht mit angezeigt wurden/werden
    Keine Ahnung, ob Du bei Dir die kleinen Helfer-Tools ncdu oder gdu installiert hast, damit kann man sehr schön sehen wo am meisten Platz verschwendet wird.
    # sudo ncdu /
    oder
    # sudo gdu /
    Aber erst schauen, dass da diese Meldungen weg sind, also einen sauberen reboot machen.
    # sudo reboot
    Bernd
      Dein Dateisystem hat 'nen Schuß.
      Fahr die Kiste IMMER sauber herunter, hinterrücks vom Strom ziehen ist nicht sauber heruntergefahren...
      Dann bring das System von 'buster' auf 'bullseye'.
      Danach:
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      LaBamba
      Von buster auf bullseye funktioniert nicht
      pi@raspberrypi:~ $ sudo apt update
      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      OK:3 https://deb.nodesource.com/node_18.x bullseye InRelease
      Aktualisierung für 1155 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
      pi@raspberrypi:~ $ sudo apt full-upgrade
      Paketaktualisierung (Upgrade) wird berechnet... Fehler!
      Einige Pakete konnten nicht installiert werden. Das kann bedeuten, dass
      Sie eine unmögliche Situation angefordert haben oder, wenn Sie die
      Unstable-Distribution verwenden, dass einige erforderliche Pakete noch
      nicht erstellt wurden oder Incoming noch nicht verlassen haben.
      Die folgenden Informationen helfen Ihnen vielleicht, die Situation zu lösen:
      Die folgenden Pakete haben unerfüllte Abhängigkeiten:
       libc6-dev : Beschädigt: libgcc-8-dev (< 8.4.0-2~) aber 8.3.0-6+rpi1 soll installiert werden
      E: Fehler: Unterbrechungen durch pkgProblemResolver::Resolve hervorgerufen; dies könnte durch zurückgehaltene Pakete verursacht worden sein.
      pi@raspberrypi:~ $
      • L LaBamba
        pi@raspberrypi:~ $
        @labamba
        Ich glaube zu gcc8 stand was im How to drin...
        L 3 Antworten Letzte Antwort
          @labamba
          LaBamba
          Jetzt ist der Umstieg fast reibungslos durchgelaufen.
          Jedoch habe ich jetzt überhaupt keinen Zugriff mehr auf die raspberry.
            @labamba
            LaBamba
            Jetzt habe ich versucht eine Sicherung der SD Karte aus dem letzten Jahr zu verwenden. Leider auch keinen Zugriff mehr auf die raspberry.
              @labamba
              LaBamba
              schrieb am zuletzt editiert von LaBamba
              Mit raspberrypi kann ich zugreifen jedoch nicht mehr mit der IP Adresse. Verändert hat diese sich aber auch nicht.
              Die Sicherung bekomme ich aber auch nicht zum laufen.
              IP Adresse stimmt aber laut fritz.box
              Verstehe nicht warum die Clones der SD-Karte nicht einmal funktionieren. Vor der Umstellung auf bullseye hat das wenigstens funktioniert.
              • L LaBamba
                @labamba
                Keine Ahnung was du da treibst.
                Läuft SSH auf der Kiste?
                Schau in
                sudo raspi-config
                rein.
                L 1 Antwort Letzte Antwort
                  @labamba
                  Schau in
                  sudo raspi-config
                  rein.
                  LaBamba
                  @thomas-braun said in Absturz bei Aktualisierung - Neustart nicht möglich!:
                  sudo raspi-config
                  Kenne ich mich nicht da drin aus
                  • L LaBamba
                    sudo raspi-config
                    @labamba
                    Es gibt einen Punkt für 'SSH', der auch genau so bezeichnet ist
                    • L LaBamba
                      sudo raspi-config
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @labamba https://www.raspberrypi.com/documentation/computers/remote-access.html#enabling-the-server
                        @labamba
                        LaBamba
                        Das habe ich jetzt wieder hinbekommen.
                        Der Computername würde von raspberrypi4 auf raspberrypi geändert. laufen tut trotzdem nichts
                        • L LaBamba
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @labamba was läuft nicht?
                          anderer Hostname jetzt?
                          • L Offline
                            LaBamba
                            @crunchip
                            1. Wie bekomme ich es hin, dass die SD Karte (clone) wieder läuft?
                              Ist Priorität Nummer 1!
                            Systemupdate stelle ich jetzt mal hinten an.
                            Ich habe keine Ahnung warum ein SD Clone nicht funktionieren sollte.
                              LaBamba
                              @crunchip
                              pi@raspberrypi:~ $ ifconfig
                              eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                                      inet 192.168.178.59  netmask 255.255.255.0  broadcast 192.168.178.255
                                      inet6 2003:c2:cf45:8b00:304a:414b:1cdc:c603  prefixlen 64  scopeid 0x0<global>
                                      inet6 fe80::518b:e996:ea0:a73e  prefixlen 64  scopeid 0x20<link>
                                      ether dc:a6:32:09:ed:bb  txqueuelen 1000  (Ethernet)
                                      RX packets 804454  bytes 247284418 (235.8 MiB)
                                      RX errors 0  dropped 0  overruns 0  frame 0
                                      TX packets 811024  bytes 103434722 (98.6 MiB)
                                      TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
                              lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
                                      inet 127.0.0.1  netmask 255.0.0.0
                                      inet6 ::1  prefixlen 128  scopeid 0x10<host>
                                      loop  txqueuelen 1000  (Lokale Schleife)
                                      RX packets 22377811  bytes 4593167616 (4.2 GiB)
                                      TX packets 22377811  bytes 4593167616 (4.2 GiB)
                              wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                                      inet6 fe80::3921:a2d8:ee62:9dc3  prefixlen 64  scopeid 0x20<link>
                                      ether dc:a6:32:09:ed:bc  txqueuelen 1000  (Ethernet)
                                      RX packets 235379  bytes 40400826 (38.5 MiB)
                                      RX errors 0  dropped 19  overruns 0  frame 0
                                      TX packets 216932  bytes 229360211 (218.7 MiB)
                              pi@raspberrypi:~ $
                              Mein LAN-Adresse ist die xxx.xxx.xxx.59
                              • L LaBamba
                                @crunchip
                                crunchipC Abwesend
                                crunchipC Abwesend
                                was läuft da nicht?
                                  @labamba
                                  Ja.
                                  LaBamba
                                  pi@raspberrypi:~ $ iob diag
                                  iobroker [command]
                                  Commands:
                                    iobroker setup                                               Setup ioBroker
                                    iobroker start [all|<adapter>.<instance>]                    Starts the js-con        troller or a specified adapter instance
                                    iobroker stop [<adapter>.<instance>]                         stops the js-cont        roller or a specified adapter instance
                                    iobroker restart [<adapter>.<instance>]                      Restarts js-contr        oller or a specified adapter instance  [aliases: r]
                                    iobroker debug <adapter>[.<instance>]                        Starts a Node.js        debugging session for the adapter instance
                                    iobroker info                                                Shows the host in        fo
                                    iobroker logs [<adapter>]                                    Monitor log
                                    iobroker add <adapter> [desiredNumber]                       Add instance of a        dapter  [aliases: a]
                                    iobroker install <adapter>                                   Installs a specif        ied adapter  [aliases: i]
                                    iobroker rebuild [<module>]                                  Rebuild all nativ        e modules or path
                                    iobroker url <url> [<name>]                                  Install adapter f        rom specified url, e.g. GitHub
                                    iobroker del <adapter>                                       Remove adapter an        d all instances from this host  [aliases: delete]
                                    iobroker del <adapter>.<instance>                            Remove adapter in        stance  [aliases: delete]
                                    iobroker update [<repositoryUrl>]                            Update repository        and list adapters
                                    iobroker upgrade                                             Upgrade managemen        t
                                    iobroker upload [all|<adapter>]                              Upload management        [aliases: u]
                                    iobroker object                                              Object management        [aliases: o]
                                    iobroker state                                               State management        [aliases: s]
                                    iobroker message <adapter>[.instance] <command> [<message>]  Send message to a        dapter instance/s
                                    iobroker list <type> [<filter>]                              List all entries,        like objects
                                    iobroker chmod <mode> <file>                                 Change file right        s
                                    iobroker chown <user> <group> <file>                         Change file owner        ship
                                    iobroker touch <file>                                        Touch file
                                    iobroker rm <file>                                           Remove file
                                    iobroker file                                                File management
                                    iobroker user                                                User commands
                                    iobroker group                                               group management
                                    iobroker host <hostname>                                     Set host to given        hostname
                                    iobroker set <adapter>.<instance>                            Change settings o        f adapter config
                                    iobroker license <license.file or license.text>              Update license by        given file
                                    iobroker cert                                                Certificate manag        ement
                                    iobroker clean <yes>                                         Clears all object        s and states
                                    iobroker backup                                              Create backup
                                    iobroker restore <backup name or path>                       Restore a specifi        ed backup
                                    iobroker validate <backup name or path>                      Validate a specif        ied backup
                                    iobroker status [all|<adapter>.<instance>]                   Status of ioBroke        r or adapter instance  [aliases: isrun]
                                    iobroker repo [<name>]                                       Show repo informa        tion
                                    iobroker uuid                                                Show uuid of the        installation  [aliases: id]
                                    iobroker unsetup                                             Reset license, in        stallation secret and language
                                    iobroker fix                                                 Execute the insta        llation fixer script, this updates your ioBroker installation
                                    iobroker multihost                                           Multihost managem        ent
                                    iobroker compact                                             compact group man        agement
                                    iobroker plugin                                              Plugin management
                                    iobroker version [<adapter>]                                 Show version of j        s-controller or specified adapter  [aliases: v]
                                  Options:
                                    --help  Show help  [boolean]
                                  pi@raspberrypi:~ $
                                  • L LaBamba
                                    iobroker [command]
                                    Commands:
                                    Options:
                                    pi@raspberrypi:~ $
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    @labamba ist das jetzt das alte oder neue System?
                                      was läuft da nicht?
                                      LaBamba
                                      @crunchip
                                      Normalerweise hat man den SD-Karten Clon eingelegt und der iobroker ist auf einer alten abgespeicherten Version gelaufen.
                                      Der Start ist jetzt aber nicht mehr möglich.
                                        LaBamba
                                        @crunchip
                                        Das alte System!
                                        L crunchipC 2 Antworten Letzte Antwort
                                        • L LaBamba
                                          @crunchip
                                          Das alte System!
                                          LaBamba
                                          @labamba
                                          Das Neue ist glaube ich vollständig kaputt.
                                          Nachdem ich aber auf einer andern SD-Karte von 'buster' auf 'bullseye' wechseln wollte geht auch der SD-Clone der alten SD nicht mehr.
