  4. DWD und Das Wetter Adapter
    3.1k
    3.1k
23 Beiträge 5 Kommentatoren 1.0k Aufrufe 4 Beobachtet
  • DJMarc75D DJMarc75
    @longbow
    Das könnte irgendwas mit dem JS-Controller zu tun haben.
    Zeig mal bitte
    iob diag
    LongbowL Online
    LongbowL Online
    Longbow
    @djmarc75
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : lxc
    Distributor ID: Ubuntu
    Description:    Ubuntu 22.04.3 LTS
    Release:        22.04
    Codename:       jammy
    PRETTY_NAME="Ubuntu 22.04.3 LTS"
    NAME="Ubuntu"
    VERSION_ID="22.04"
    VERSION="22.04.3 LTS (Jammy Jellyfish)"
    VERSION_CODENAME=jammy
    ID=ubuntu
    ID_LIKE=debian
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    UBUNTU_CODENAME=jammy
    Systemuptime and Load:
     15:18:25 up 3 days, 17:27,  2 users,  load average: 2.52, 2.71, 2.90
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Tue 2023-08-29 15:18:25 CEST
               Universal time: Tue 2023-08-29 13:18:25 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             15G        5.7G        8.7G        0.0K        1.5G         10G
    Swap:           8.2G          0B        8.2G
    Total:           24G        5.7G         16G
            15894 M total memory
             5683 M used memory
              632 M active memory
             6065 M inactive memory
             8733 M free memory
                0 M buffer memory
             1476 M swap cache
             8191 M total swap
                0 M used swap
             8191 M free swap
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--213--disk--0 ext4    54G   11G   41G  22% /
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs  3.2G  120K  3.2G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--213--disk--0 ext4   rw,relatime,stripe=16
    /var:
    4.6G    /var/
    4.0G    /var/log/journal/ddbba1a4925941c98f0be027bc45e442
    4.0G    /var/log
    340M    /var/cache
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    406M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    944M    /opt/iobroker/iobroker-data/
    669M    /opt/iobroker/iobroker-data/files
    126M    /opt/iobroker/iobroker-data/backup-objects
    88M     /opt/iobroker/iobroker-data/files/echarts.admin
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    72M     /opt/iobroker/iobroker-data/states.jsonl
    52M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Docker          : false
    Release:        22.04
    Codename:       jammy
    NAME="Ubuntu"
    VERSION_ID="22.04"
    ID=ubuntu
    ID_LIKE=debian
    CPU threads: 4
                     RTC time: n/a
              RTC in local TZ: no
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Swap:           8.2G          0B        8.2G
    Total:           24G        5.7G         16G
             5683 M used memory
              632 M active memory
             8733 M free memory
                0 M buffer memory
             1476 M swap cache
             8191 M total swap
                0 M used swap
             8191 M free swap
    *** FILESYSTEM ***
    /var:
    4.6G    /var/
    4.0G    /var/log
    340M    /var/cache
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Version table:
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Adapter State
    + system.adapter.admin.0                  : admin                 : Iobroker-test                            -  enabled, port: 8777, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : Iobroker-test                            -  enabled
      system.adapter.alias-manager.0          : alias-manager         : Iobroker-test                            - disabled
    + system.adapter.backitup.0               : backitup              : Iobroker-test                            -  enabled
    + system.adapter.cameras.0                : cameras               : Iobroker-test                            -  enabled, port: 8200, bind: 127.0.0.1
      system.adapter.chromecast.0             : chromecast            : Iobroker-test                            - disabled
    + system.adapter.cloud.0                  : cloud                 : Iobroker-test                            -  enabled
      system.adapter.daswetter.0              : daswetter             : Iobroker-test                            -  enabled
      system.adapter.devices.0                : devices               : Iobroker-test                            -  enabled
    + system.adapter.discovery.0              : discovery             : Iobroker-test                            -  enabled
    + system.adapter.dwd.0                    : dwd                   : Iobroker-test                            -  enabled
    + system.adapter.echarts.0                : echarts               : Iobroker-test                            -  enabled
    + system.adapter.email.0                  : email                 : Iobroker-test                            -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Iobroker-test                            -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : Iobroker-test                            -  enabled
    + system.adapter.eusec.0                  : eusec                 : Iobroker-test                            -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : Iobroker-test                            -  enabled
    + system.adapter.fb-checkpresence.1       : fb-checkpresence      : Iobroker-test                            -  enabled
      system.adapter.flot.0                   : flot                  : Iobroker-test                            - disabled
    + system.adapter.followthesun.0           : followthesun          : Iobroker-test                            -  enabled
      system.adapter.geofency.0               : geofency              : Iobroker-test                            - disabled, port: 7999, bind: 0.0.0.0
      system.adapter.heatingcontrol.0         : heatingcontrol        : Iobroker-test                            - disabled
    + system.adapter.history.0                : history               : Iobroker-test                            -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : Iobroker-test                            -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : Iobroker-test                            -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : Iobroker-test                            -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : Iobroker-test                            -  enabled
      system.adapter.hue-extended.0           : hue-extended          : Iobroker-test                            - disabled
    + system.adapter.hue.0                    : hue                   : Iobroker-test                            -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : Iobroker-test                            -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: Iobroker-test                            - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : Iobroker-test                            - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : Iobroker-test                            - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : Iobroker-test                            - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : Iobroker-test                            - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Iobroker-test                            - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Iobroker-test                            - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Iobroker-test                            - disabled
    + system.adapter.influxdb.0               : influxdb              : Iobroker-test                            -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : Iobroker-test                            -  enabled
    + system.adapter.iot.0                    : iot                   : Iobroker-test                            -  enabled
    + system.adapter.javascript.0             : javascript            : Iobroker-test                            -  enabled
      system.adapter.klf200.0                 : klf200                : Iobroker-test                            -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : Iobroker-test                            -  enabled, port: 54321
    + system.adapter.modbus.0                 : modbus                : Iobroker-test                            -  enabled
      system.adapter.mqtt-client.0            : mqtt-client           : Iobroker-test                            - disabled, port: 1883
    + system.adapter.mqtt.0                   : mqtt                  : Iobroker-test                            -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.myenergi.0               : myenergi              : Iobroker-test                            -  enabled
    + system.adapter.netatmo.0                : netatmo               : Iobroker-test                            -  enabled
    + system.adapter.nina.0                   : nina                  : Iobroker-test                            -  enabled
    + system.adapter.nuki.0                   : nuki                  : Iobroker-test                            -  enabled
    + system.adapter.openweathermap.0         : openweathermap        : Iobroker-test                            -  enabled
      system.adapter.parser.0                 : parser                : Iobroker-test                            - disabled
      system.adapter.places.0                 : places                : Iobroker-test                            - disabled
    + system.adapter.pollenflug.0             : pollenflug            : Iobroker-test                            -  enabled
    + system.adapter.proxmox.0                : proxmox               : Iobroker-test                            -  enabled, port: 8006
    + system.adapter.pushover.0               : pushover              : Iobroker-test                            -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : Iobroker-test                            -  enabled
    + system.adapter.robonect.0               : robonect              : Iobroker-test                            -  enabled
      system.adapter.rtspstream.0             : rtspstream            : Iobroker-test                            - disabled, port: 9088
      system.adapter.samsung.0                : samsung               : Iobroker-test                            - disabled
    + system.adapter.scenes.0                 : scenes                : Iobroker-test                            -  enabled
    + system.adapter.shelly.0                 : shelly                : Iobroker-test                            -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartgarden.0            : smartgarden           : Iobroker-test                            -  enabled
    + system.adapter.smartthings.0            : smartthings           : Iobroker-test                            -  enabled
    + system.adapter.sonos.0                  : sonos                 : Iobroker-test                            -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : Iobroker-test                            -  enabled
    + system.adapter.statistics.0             : statistics            : Iobroker-test                            -  enabled
    + system.adapter.synology.0               : synology              : Iobroker-test                            -  enabled, port: 5001
      system.adapter.synology.1               : synology              : Iobroker-test                            - disabled, port: 5001
    + system.adapter.tankerkoenig.0           : tankerkoenig          : Iobroker-test                            -  enabled
    + system.adapter.telegram.0               : telegram              : Iobroker-test                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : Iobroker-test                            -  enabled
    + system.adapter.tr-064.1                 : tr-064                : Iobroker-test                            -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : Iobroker-test                            -  enabled
    + system.adapter.tuya.0                   : tuya                  : Iobroker-test                            -  enabled
    + system.adapter.tvprogram.0              : tvprogram             : Iobroker-test                            -  enabled
    + system.adapter.upnp.0                   : upnp                  : Iobroker-test                            -  enabled
      system.adapter.vis-bars.0               : vis-bars              : Iobroker-test                            - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Iobroker-test                            - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : Iobroker-test                            - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : Iobroker-test                            - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : Iobroker-test                            -  enabled
      system.adapter.vis-history.0            : vis-history           : Iobroker-test                            - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Iobroker-test                            - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : Iobroker-test                            - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : Iobroker-test                            -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : Iobroker-test                            - disabled
      system.adapter.vis-map.0                : vis-map               : Iobroker-test                            - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : Iobroker-test                            - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : Iobroker-test                            -  enabled
      system.adapter.vis-metro.0              : vis-metro             : Iobroker-test                            - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : Iobroker-test                            - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : Iobroker-test                            - disabled
      system.adapter.vis.0                    : vis                   : Iobroker-test                            -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : Iobroker-test                            -  enabled
    + system.adapter.vw-connect.1             : vw-connect            : Iobroker-test                            -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : Iobroker-test                            -  enabled
    + system.adapter.web.0                    : web                   : Iobroker-test                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wolf-smartset.0          : wolf-smartset         : Iobroker-test                            -  enabled
    + system.adapter.wolf.0                   : wolf                  : Iobroker-test                            -  enabled, port: 12004, bind: 0.0.0.0
    + system.adapter.ws.0                     : ws                    : Iobroker-test                            -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.youtube.0                : youtube               : Iobroker-test                            -  enabled
      system.adapter.yr.0                     : yr                    : Iobroker-test                            -  enabled
    + instance is alive
    Used repository: stable
    Adapter    "admin"        : 6.8.0    , installed 6.8.0
    Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
    Adapter    "alias-manager": 1.2.4    , installed 1.2.6
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "eusec"        : 1.1.1    , installed 1.1.1
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "followthesun" : 0.4.2    , installed 0.4.1  [Updatable]
    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hue"          : 3.9.5    , installed 3.9.5
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "klf200"       : 1.0.1    , installed 1.0.1
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
    Adapter    "parser"       : 1.3.2    , installed 1.3.2
    Adapter    "places"       : 1.1.2    , installed 1.1.2
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
    Adapter    "robonect"     : 0.1.4    , installed 0.1.4
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "withings"     : 0.0.13   , installed 0.0.13
    Adapter    "wolf"         : 1.7.0    , installed 1.7.0
    Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
    Adapter    "youtube"      : 4.2.1    , installed 4.2.1
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        70890
    Hit:1 https://deb.nodesource.com/node_18.x jammy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Reading package lists...
    Pending Updates: 17
    *** Listening Ports ***
    tcp        0      0 192.168.178.213:2001    0.0.0.0:*               LISTEN      1000       134283856  33130/io.hm-rpc.1
    tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      1000       134298364  34136/go2rtc
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          42784434   1/init
    tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1000       134278690  32860/io.hm-rpc.0
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        42784711   118/systemd-resolve
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      113        42787856   145/mosquitto
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       134281530  32965/io.shelly.0
    tcp        0      0 0.0.0.0:12004           0.0.0.0:*               LISTEN      1000       134282199  33085/io.wolf.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       134276662  32650/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       134276655  32650/iobroker.js-c
    tcp        0      0 127.0.0.1:8200          0.0.0.0:*               LISTEN      1000       134298215  34104/io.cameras.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          42785434   316/master
    tcp6       0      0 :::8777                 :::*                    LISTEN      1000       134277405  32675/io.admin.0
    tcp6       0      0 :::8554                 :::*                    LISTEN      1000       134298359  34136/go2rtc
    tcp6       0      0 :::111                  :::*                    LISTEN      0          42784436   1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          42785209   1/init
    tcp6       0      0 :::1984                 :::*                    LISTEN      1000       134298358  34136/go2rtc
    tcp6       0      0 :::1883                 :::*                    LISTEN      113        42787857   145/mosquitto
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          42785435   316/master
    tcp6       0      0 :::3500                 :::*                    LISTEN      1000       134282316  32980/io.sonos.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       134296855  33999/io.ws.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       134296785  33984/io.web.0
    tcp6       0      0 :::8000                 :::*                    LISTEN      1000       134300448  33891/io.upnp.0
    udp        0      0 0.0.0.0:58377           0.0.0.0:*                           1000       134298381  34119/io.eusec.0
    udp        0      0 0.0.0.0:50671           0.0.0.0:*                           1000       134299871  34119/io.eusec.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       134294394  33891/io.upnp.0
    udp        0      0 0.0.0.0:42966           0.0.0.0:*                           1000       134299889  34119/io.eusec.0
    udp        0      0 0.0.0.0:43291           0.0.0.0:*                           1000       138645628  34119/io.eusec.0
    udp        0      0 0.0.0.0:35184           0.0.0.0:*                           1000       138636952  34119/io.eusec.0
    udp        0      0 0.0.0.0:52729           0.0.0.0:*                           1000       134291236  33891/io.upnp.0
    udp        0      0 0.0.0.0:53121           0.0.0.0:*                           1000       136555816  34119/io.eusec.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       134281312  32905/io.mihome-vac
    udp        0      0 192.168.178.213:5353    0.0.0.0:*                           1000       134283352  33025/io.tr-064.1
    udp        0      0 192.168.178.213:5353    0.0.0.0:*                           1000       134283324  33010/io.tr-064.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       134281955  33040/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       134281956  33040/io.tuya.0
    udp        0      0 0.0.0.0:56958           0.0.0.0:*                           1000       136555224  34119/io.eusec.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        42784710   118/systemd-resolve
    udp        0      0 0.0.0.0:57410           0.0.0.0:*                           1000       138634891  34119/io.eusec.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          42784435   1/init
    udp        0      0 0.0.0.0:8555            0.0.0.0:*                           1000       134298360  34136/go2rtc
    udp6       0      0 :::111                  :::*                                0          42784437   1/init
    udp6       0      0 :::8443                 :::*                                1000       134298365  34136/go2rtc
    2023-08-29 15:23:06.849  - warn: fb-checkpresence.0 (33265) getWlBlInfo TypeError: Cannot read properties of null (reading 'length')
    2023-08-29 15:24:03.588  - info: javascript.0 (32749) script.js.SolarEgde-Script: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
    2023-08-29 15:24:03.814  - info: dwd.0 (51237) force terminating after 4 minutes
    2023-08-29 15:24:03.815  - info: dwd.0 (51237) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-08-29 15:24:04.504  - error: dwd.0 (51237) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-08-29 15:24:04.504  - error: dwd.0 (51237) unhandled promise rejection: DB closed
    2023-08-29 15:24:04.507  - error: dwd.0 (51237) Error: DB closed
        at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
        at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
        at Object.onceWrapper (node:events:629:26)
        at Socket.emit (node:events:514:28)
        at Socket.emit (node:domain:489:12)
        at TCP.<anonymous> (node:net:323:12)
    2023-08-29 15:24:04.507  - error: dwd.0 (51237) DB closed
    2023-08-29 15:24:06.016  - info: dwd.0 (51237) terminating with timeout
    2023-08-29 15:24:08.306  - info: host.Iobroker-test instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-29 15:24:14.456  - info: smartgarden.0 (33801) 3/ on_pong: ++ pong'ed ++
    2023-08-29 15:25:01.008  - warn: fb-checkpresence.0 (33265) getWlBlInfo TypeError: Cannot read properties of null (reading 'length')
    2023-08-29 15:25:03.022  - info: host.Iobroker-test instance system.adapter.dwd.0 started with pid 51552
    2023-08-29 15:25:03.574  - info: javascript.0 (32749) script.js.SolarEgde-Script: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
    2023-08-29 15:25:07.441  - info: javascript.0 (32749) script.js.SolarEgde-Script: Der Energieertrag der Anlage "2712611" wird verarbeitet.
    2023-08-29 15:26:03.493  - info: javascript.0 (32749) script.js.SolarEgde-Script: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
    2023-08-29 15:26:37.247  - info: dwd.0 (51552) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 4.0.24
    2023-08-29 15:26:44.457  - info: smartgarden.0 (33801) 3/ on_pong: ++ pong'ed ++
    2023-08-29 15:27:03.504  - info: javascript.0 (32749) script.js.SolarEgde-Script: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
    iob diag has finished.
    Press any key for a summary
                         v.2023-04-16
    Operatingsystem:        Ubuntu 22.04.3 LTS
    Kernel:                 5.15.30-2-pve
    Installation:           lxc
    User-ID:                1002
    X-Server:               false
    Pending OS-Updates:     17
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Swap:           8.2G          0B        8.2G
    Total:           24G        5.7G         16G
    Active iob-Instances:   61
    Active repo(s): stable
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.8.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                70890
    States:                 59474
    Size of iob-Database:
    101M    /opt/iobroker/iobroker-data/states.jsonl
    Das sollte es sein oder
    DJMarc75D 2 Antworten Letzte Antwort
    • LongbowL Longbow
      @djmarc75
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        22.04
      Codename:       jammy
      NAME="Ubuntu"
      VERSION_ID="22.04"
      ID=ubuntu
      ID_LIKE=debian
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           8.2G          0B        8.2G
      Total:           24G        5.7G         16G
               5683 M used memory
                632 M active memory
               8733 M free memory
                  0 M buffer memory
               1476 M swap cache
               8191 M total swap
                  0 M used swap
               8191 M free swap
      *** FILESYSTEM ***
      /var:
      4.6G    /var/
      4.0G    /var/log
      340M    /var/cache
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        22.04
      Codename:       jammy
      NAME="Ubuntu"
      VERSION_ID="22.04"
      ID=ubuntu
      ID_LIKE=debian
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           8.2G          0B        8.2G
      Total:           24G        5.7G         16G
               5683 M used memory
                632 M active memory
               8733 M free memory
                  0 M buffer memory
               1476 M swap cache
               8191 M total swap
                  0 M used swap
               8191 M free swap
      *** FILESYSTEM ***
      /var:
      4.6G    /var/
      4.0G    /var/log
      340M    /var/cache
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Adapter State
      + instance is alive
      Objects and States
      Objects:        70890
      Pending Updates: 17
                           v.2023-04-16
      Installation:           lxc
      User-ID:                1002
      X-Server:               false
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      MEMORY:
      Swap:           8.2G          0B        8.2G
      Total:           24G        5.7G         16G
                              admin                   6.8.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                70890
      States:                 59474
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @longbow sagte in DWD und Das Wetter Adapter:
      Ja, aber da scheint ja vieles krumm zu sein... vll kann da mal @Thomas-Braun einen Blick drauf werfen ?!
      Lehrling seit 1975 !!!
      LongbowL 2 Antworten Letzte Antwort
        LongbowL Online
        LongbowL Online
        Longbow
        @djmarc75 Also bis jetzt läuft das gut das system... @Thomas-Braun Bi gespannt...
        • LongbowL Longbow
          @longbow
          So auf den ersten Blick sehe ich nix wirklich krummes.
          Nur der bemerkenswert hohe Arbeitsspeicherverbrauch fällt auf.
          Relativiert sich aber wieder, wenn man die
          berücksichtigt.
            @longbow
            berücksichtigt.
            LongbowL Online
            LongbowL Online
            Longbow
            @thomas-braun Ok danke... und an was könnte es liegen, das die beiden nicht gehen?
              @longbow
              berücksichtigt.
              LongbowL Online
              LongbowL Online
              Longbow
              @thomas-braun gibt es eine gute Anleitung, wie man einen iobroker aufsetzt?
                LongbowL Online
                LongbowL Online
                Longbow
                @djmarc75 was ist nach deiner ansicht alles krumm
                • LongbowL Longbow
                  @djmarc75
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:        22.04
                  Codename:       jammy
                  NAME="Ubuntu"
                  VERSION_ID="22.04"
                  ID=ubuntu
                  ID_LIKE=debian
                  CPU threads: 4
                                   RTC time: n/a
                            RTC in local TZ: no
                  X-Server:       false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Swap:           8.2G          0B        8.2G
                  Total:           24G        5.7G         16G
                           5683 M used memory
                            632 M active memory
                           8733 M free memory
                              0 M buffer memory
                           1476 M swap cache
                           8191 M total swap
                              0 M used swap
                           8191 M free swap
                  *** FILESYSTEM ***
                  /var:
                  4.6G    /var/
                  4.0G    /var/log
                  340M    /var/cache
                  /usr/bin/npm            9.6.7
                  /usr/bin/npx            9.6.7
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:        22.04
                  Codename:       jammy
                  NAME="Ubuntu"
                  VERSION_ID="22.04"
                  ID=ubuntu
                  ID_LIKE=debian
                  CPU threads: 4
                                   RTC time: n/a
                            RTC in local TZ: no
                  X-Server:       false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Swap:           8.2G          0B        8.2G
                  Total:           24G        5.7G         16G
                           5683 M used memory
                            632 M active memory
                           8733 M free memory
                              0 M buffer memory
                           1476 M swap cache
                           8191 M total swap
                              0 M used swap
                           8191 M free swap
                  *** FILESYSTEM ***
                  /var:
                  4.6G    /var/
                  4.0G    /var/log
                  340M    /var/cache
                  /usr/bin/npm            9.6.7
                  /usr/bin/npx            9.6.7
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        70890
                  Pending Updates: 17
                                       v.2023-04-16
                  Installation:           lxc
                  User-ID:                1002
                  X-Server:               false
                                          /usr/bin/npm            9.6.7
                                          /usr/bin/npx            9.6.7
                  MEMORY:
                  Swap:           8.2G          0B        8.2G
                  Total:           24G        5.7G         16G
                                          admin                   6.8.0
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                70890
                  States:                 59474
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  Ist "etwas" hoch und ich bin irritiert wegen:
                  und
                  muss jetzt aber nix heissen, daher hab ich ja @Thomas-Braun mit ins Boot genommen, der kennt sich da viiiieeeel besser aus ;)
                    und
                    @djmarc75 sagte in DWD und Das Wetter Adapter:
                    Dürfte am Setup als LXC liegen.
                    Da fehlt der User in einer der beiden Gruppen.
                    LongbowL 1 Antwort Letzte Antwort
                      LongbowL Online
                      LongbowL Online
                      Longbow
                      @thomas-braun wie bekomme ich es besser hin das Setup vom LXC?
                      und was meinst du mit dem User in einer der beiden Gruppen?
                      Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
                      • LongbowL Longbow
                        Kann ich dir nicht sagen, ich verwende keine Container. Ist mir zu kompliziert. :-)
                        Den user mit der uid=1002 in die Gruppe adm oder systemd-journal packen.
                        Hast du die Ausgabe von iob diag gekürzt? Üblicherweise gibt es da einen Block mit den usernames. Genau für solche Fälle nämlich...
                          LongbowL Online
                          LongbowL Online
                          Longbow
                          wie nutzt du das?
                          Meinst du das?
                          *** User and Groups ***
                          cliffkirchhof
                          /home/cliffkirchhof
                          cliffkirchhof iobroker adm
                          • LongbowL Longbow
                            wie nutzt du das?
                            Meinst du das?
                            cliffkirchhof
                            /home/cliffkirchhof
                            cliffkirchhof
                            Dann so:
                            sudo usermod -a -G adm cliffkirchhof
                            Einmal den cliffkirchhof aus- und wieder einloggen, erst dann stehen die Gruppen richtig.
                            • LongbowL Longbow
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              Du nutzt ja sicherlich Proxmox ?!
                              Warum nutzt man nicht die offizielle Anleitung ?
                              https://www.iobroker.net/#de/documentation/install/proxmox.md
                                LongbowL Online
                                LongbowL Online
                                Longbow
                                @djmarc75 macht es sind, auf Ubuntu 22.04.3 von 20.04.6 update zu daten vor dem Installieren des iobrokers oder kann das auch später gemacht werden ?
                                DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                                • LongbowL Longbow
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  ich hab keine Ahnung, ich nutze kein Ubuntu, sondern Debian. Da kann ich Dir leider nix zu sagen.
                                  • LongbowL Longbow
                                    @longbow
                                    Es macht immer Sinn eine aktuelle stabile Distribution zu fahren. Die Reihenfolge ist da aber nicht gar so wichtig.
                                    • C Offline
                                      chuck2941
                                      schrieb am zuletzt editiert von chuck2941
                                      Abend zusammen,
                                      ich habe im Log immer wieder Fehlermeldungen von dem Adapter, kann jemand sagen was das zu bedeuten hat?
                                      Laufen tut der Adapter und auf der VIS ist auch alles korrekt.
                                      Ro75R 1 Antwort Letzte Antwort
                                      • C chuck2941
                                        Abend zusammen,
                                        Ro75R Offline
                                        Ro75R Offline
                                        Ro75
                                        @chuck2941
                                        erhöhe bei das Wetter das Zeitlimit
                                        Ro75.
                                        C 1 Antwort Letzte Antwort
                                        • Ro75R Ro75
                                          @chuck2941
                                          Ro75.
                                          chuck2941
                                          @ro75 ok danke für den Hinweis, werde ich heute Abend mal ausprobieren.
