  4. DWD und Das Wetter Adapter
    3.2k
    3.1k
23 Beiträge 5 Kommentatoren 1.0k Aufrufe 4 Beobachtet
  • LongbowL Online
    LongbowL Online
    Longbow
    Hallo
    keine Ahnung wieso und warum, aber die beiden Adapter spinnen seit einigen Tage leider.
    In dem Protokoll steht Folgendes, ständig über 100 Fehlermeldung von den.
    Zeit
    error
    Nachricht
    dwd.0
    2023-08-29 14:49:04.761	error	DB closed
    dwd.0
    2023-08-29 14:49:04.761	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:629:26) at Socket.emit (node:events:514:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:323:12)
    dwd.0
    2023-08-29 14:49:04.758	error	unhandled promise rejection: DB closed
    dwd.0
    2023-08-29 14:49:04.758	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    eusec.0
    2023-08-29 14:48:47.412	error	Station T8124P2022222014 - All address lookup tentatives failed.
    host.Iobroker-test
    2023-08-29 14:46:28.560	error	instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
    daswetter.0
    2023-08-29 14:46:24.676	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_24.wind_symbol": Connection is closed.
    daswetter.0
    2023-08-29 14:46:24.676	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_24.wind_symbolB": Connection is closed.
    daswetter.0
    2023-08-29 14:46:24.675	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_24.iconURL: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_24.iconURL": Connection is closed.]
    • LongbowL Longbow
      Hallo
      Zeit
      error
      Nachricht
      dwd.0
      dwd.0
      dwd.0
      dwd.0
      eusec.0
      host.Iobroker-test
      daswetter.0
      daswetter.0
      daswetter.0
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @longbow
      Das könnte irgendwas mit dem JS-Controller zu tun haben.
      Zeig mal bitte
      iob diag
      Lehrling seit 1975 !!!
      LongbowL 1 Antwort Letzte Antwort
      • DJMarc75D DJMarc75
        @longbow
        Zeig mal bitte
        iob diag
        LongbowL Online
        LongbowL Online
        Longbow
        @djmarc75
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Architecture    : x86_64
        Docker          : false
        Virtualization  : lxc
        Distributor ID: Ubuntu
        Description:    Ubuntu 22.04.3 LTS
        Release:        22.04
        Codename:       jammy
        PRETTY_NAME="Ubuntu 22.04.3 LTS"
        NAME="Ubuntu"
        VERSION_ID="22.04"
        VERSION="22.04.3 LTS (Jammy Jellyfish)"
        VERSION_CODENAME=jammy
        ID=ubuntu
        ID_LIKE=debian
        HOME_URL="https://www.ubuntu.com/"
        SUPPORT_URL="https://help.ubuntu.com/"
        BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
        PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
        UBUNTU_CODENAME=jammy
        Systemuptime and Load:
         15:18:25 up 3 days, 17:27,  2 users,  load average: 2.52, 2.71, 2.90
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Tue 2023-08-29 15:18:25 CEST
                   Universal time: Tue 2023-08-29 13:18:25 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:             15G        5.7G        8.7G        0.0K        1.5G         10G
        Swap:           8.2G          0B        8.2G
        Total:           24G        5.7G         16G
                15894 M total memory
                 5683 M used memory
                  632 M active memory
                 6065 M inactive memory
                 8733 M free memory
                    0 M buffer memory
                 1476 M swap cache
                 8191 M total swap
                    0 M used swap
                 8191 M free swap
        *** FILESYSTEM ***
        Filesystem                       Type   Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--213--disk--0 ext4    54G   11G   41G  22% /
        none                             tmpfs  492K  4.0K  488K   1% /dev
        tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
        tmpfs                            tmpfs  3.2G  120K  3.2G   1% /run
        tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--213--disk--0 ext4   rw,relatime,stripe=16
        /var:
        4.6G    /var/
        4.0G    /var/log/journal/ddbba1a4925941c98f0be027bc45e442
        4.0G    /var/log
        340M    /var/cache
        Archived and active journals take up 16.0M in the file system.
        /opt/iobroker/backups:
        406M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        944M    /opt/iobroker/iobroker-data/
        669M    /opt/iobroker/iobroker-data/files
        126M    /opt/iobroker/iobroker-data/backup-objects
        88M     /opt/iobroker/iobroker-data/files/echarts.admin
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        72M     /opt/iobroker/iobroker-data/states.jsonl
        52M     /opt/iobroker/iobroker-data/objects.jsonl
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        22.04
        Codename:       jammy
        NAME="Ubuntu"
        VERSION_ID="22.04"
        ID=ubuntu
        ID_LIKE=debian
        CPU threads: 4
                         RTC time: n/a
                  RTC in local TZ: no
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:           8.2G          0B        8.2G
        Total:           24G        5.7G         16G
                 5683 M used memory
                  632 M active memory
                 8733 M free memory
                    0 M buffer memory
                 1476 M swap cache
                 8191 M total swap
                    0 M used swap
                 8191 M free swap
        *** FILESYSTEM ***
        /var:
        4.6G    /var/
        4.0G    /var/log
        340M    /var/cache
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Adapter State
        + system.adapter.admin.0                  : admin                 : Iobroker-test                            -  enabled, port: 8777, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : Iobroker-test                            -  enabled
          system.adapter.alias-manager.0          : alias-manager         : Iobroker-test                            - disabled
        + system.adapter.backitup.0               : backitup              : Iobroker-test                            -  enabled
        + system.adapter.cameras.0                : cameras               : Iobroker-test                            -  enabled, port: 8200, bind: 127.0.0.1
          system.adapter.chromecast.0             : chromecast            : Iobroker-test                            - disabled
        + system.adapter.cloud.0                  : cloud                 : Iobroker-test                            -  enabled
          system.adapter.daswetter.0              : daswetter             : Iobroker-test                            -  enabled
          system.adapter.devices.0                : devices               : Iobroker-test                            -  enabled
        + system.adapter.discovery.0              : discovery             : Iobroker-test                            -  enabled
        + system.adapter.dwd.0                    : dwd                   : Iobroker-test                            -  enabled
        + system.adapter.echarts.0                : echarts               : Iobroker-test                            -  enabled
        + system.adapter.email.0                  : email                 : Iobroker-test                            -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Iobroker-test                            -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : Iobroker-test                            -  enabled
        + system.adapter.eusec.0                  : eusec                 : Iobroker-test                            -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : Iobroker-test                            -  enabled
        + system.adapter.fb-checkpresence.1       : fb-checkpresence      : Iobroker-test                            -  enabled
          system.adapter.flot.0                   : flot                  : Iobroker-test                            - disabled
        + system.adapter.followthesun.0           : followthesun          : Iobroker-test                            -  enabled
          system.adapter.geofency.0               : geofency              : Iobroker-test                            - disabled, port: 7999, bind: 0.0.0.0
          system.adapter.heatingcontrol.0         : heatingcontrol        : Iobroker-test                            - disabled
        + system.adapter.history.0                : history               : Iobroker-test                            -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : Iobroker-test                            -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : Iobroker-test                            -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : Iobroker-test                            -  enabled, port: 0
        + system.adapter.homeconnect.0            : homeconnect           : Iobroker-test                            -  enabled
          system.adapter.hue-extended.0           : hue-extended          : Iobroker-test                            - disabled
        + system.adapter.hue.0                    : hue                   : Iobroker-test                            -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : Iobroker-test                            -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: Iobroker-test                            - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : Iobroker-test                            - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : Iobroker-test                            - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : Iobroker-test                            - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : Iobroker-test                            - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Iobroker-test                            - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Iobroker-test                            - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Iobroker-test                            - disabled
        + system.adapter.influxdb.0               : influxdb              : Iobroker-test                            -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : Iobroker-test                            -  enabled
        + system.adapter.iot.0                    : iot                   : Iobroker-test                            -  enabled
        + system.adapter.javascript.0             : javascript            : Iobroker-test                            -  enabled
          system.adapter.klf200.0                 : klf200                : Iobroker-test                            -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : Iobroker-test                            -  enabled, port: 54321
        + system.adapter.modbus.0                 : modbus                : Iobroker-test                            -  enabled
          system.adapter.mqtt-client.0            : mqtt-client           : Iobroker-test                            - disabled, port: 1883
        + system.adapter.mqtt.0                   : mqtt                  : Iobroker-test                            -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.myenergi.0               : myenergi              : Iobroker-test                            -  enabled
        + system.adapter.netatmo.0                : netatmo               : Iobroker-test                            -  enabled
        + system.adapter.nina.0                   : nina                  : Iobroker-test                            -  enabled
        + system.adapter.nuki.0                   : nuki                  : Iobroker-test                            -  enabled
        + system.adapter.openweathermap.0         : openweathermap        : Iobroker-test                            -  enabled
          system.adapter.parser.0                 : parser                : Iobroker-test                            - disabled
          system.adapter.places.0                 : places                : Iobroker-test                            - disabled
        + system.adapter.pollenflug.0             : pollenflug            : Iobroker-test                            -  enabled
        + system.adapter.proxmox.0                : proxmox               : Iobroker-test                            -  enabled, port: 8006
        + system.adapter.pushover.0               : pushover              : Iobroker-test                            -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : Iobroker-test                            -  enabled
        + system.adapter.robonect.0               : robonect              : Iobroker-test                            -  enabled
          system.adapter.rtspstream.0             : rtspstream            : Iobroker-test                            - disabled, port: 9088
          system.adapter.samsung.0                : samsung               : Iobroker-test                            - disabled
        + system.adapter.scenes.0                 : scenes                : Iobroker-test                            -  enabled
        + system.adapter.shelly.0                 : shelly                : Iobroker-test                            -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.smartgarden.0            : smartgarden           : Iobroker-test                            -  enabled
        + system.adapter.smartthings.0            : smartthings           : Iobroker-test                            -  enabled
        + system.adapter.sonos.0                  : sonos                 : Iobroker-test                            -  enabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : Iobroker-test                            -  enabled
        + system.adapter.statistics.0             : statistics            : Iobroker-test                            -  enabled
        + system.adapter.synology.0               : synology              : Iobroker-test                            -  enabled, port: 5001
          system.adapter.synology.1               : synology              : Iobroker-test                            - disabled, port: 5001
        + system.adapter.tankerkoenig.0           : tankerkoenig          : Iobroker-test                            -  enabled
        + system.adapter.telegram.0               : telegram              : Iobroker-test                            -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : Iobroker-test                            -  enabled
        + system.adapter.tr-064.1                 : tr-064                : Iobroker-test                            -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : Iobroker-test                            -  enabled
        + system.adapter.tuya.0                   : tuya                  : Iobroker-test                            -  enabled
        + system.adapter.tvprogram.0              : tvprogram             : Iobroker-test                            -  enabled
        + system.adapter.upnp.0                   : upnp                  : Iobroker-test                            -  enabled
          system.adapter.vis-bars.0               : vis-bars              : Iobroker-test                            - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Iobroker-test                            - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : Iobroker-test                            - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : Iobroker-test                            - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : Iobroker-test                            -  enabled
          system.adapter.vis-history.0            : vis-history           : Iobroker-test                            - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Iobroker-test                            - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : Iobroker-test                            - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : Iobroker-test                            -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : Iobroker-test                            - disabled
          system.adapter.vis-map.0                : vis-map               : Iobroker-test                            - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : Iobroker-test                            - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : Iobroker-test                            -  enabled
          system.adapter.vis-metro.0              : vis-metro             : Iobroker-test                            - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : Iobroker-test                            - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : Iobroker-test                            - disabled
          system.adapter.vis.0                    : vis                   : Iobroker-test                            -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : Iobroker-test                            -  enabled
        + system.adapter.vw-connect.1             : vw-connect            : Iobroker-test                            -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : Iobroker-test                            -  enabled
        + system.adapter.web.0                    : web                   : Iobroker-test                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.wolf-smartset.0          : wolf-smartset         : Iobroker-test                            -  enabled
        + system.adapter.wolf.0                   : wolf                  : Iobroker-test                            -  enabled, port: 12004, bind: 0.0.0.0
        + system.adapter.ws.0                     : ws                    : Iobroker-test                            -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          system.adapter.youtube.0                : youtube               : Iobroker-test                            -  enabled
          system.adapter.yr.0                     : yr                    : Iobroker-test                            -  enabled
        + instance is alive
        Used repository: stable
        Adapter    "admin"        : 6.8.0    , installed 6.8.0
        Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
        Adapter    "alias-manager": 1.2.4    , installed 1.2.6
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "echarts"      : 1.5.1    , installed 1.5.1
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "eusec"        : 1.1.1    , installed 1.1.1
        Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "followthesun" : 0.4.2    , installed 0.4.1  [Updatable]
        Adapter    "geofency"     : 1.2.4    , installed 1.2.4
        Adapter    "hass"         : 1.4.0    , installed 1.4.0
        Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
        Adapter    "history"      : 2.2.6    , installed 2.2.6
        Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
        Adapter    "hue"          : 3.9.5    , installed 3.9.5
        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "iot"          : 1.14.5   , installed 1.14.5
        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
        Adapter    "klf200"       : 1.0.1    , installed 1.0.1
        Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
        Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "nuki"         : 1.6.0    , installed 1.6.0
        Adapter    "openweathermap": 0.3.9   , installed 0.3.9
        Adapter    "parser"       : 1.3.2    , installed 1.3.2
        Adapter    "places"       : 1.1.2    , installed 1.1.2
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
        Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
        Adapter    "robonect"     : 0.1.4    , installed 0.1.4
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
        Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
        Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
        Adapter    "sonos"        : 2.3.1    , installed 2.3.1
        Adapter    "statistics"   : 2.3.0    , installed 2.3.0
        Adapter    "synology"     : 2.1.13   , installed 2.1.13
        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
        Adapter    "unifi"        : 0.6.6    , installed 0.6.6
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
        Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
        Adapter    "withings"     : 0.0.13   , installed 0.0.13
        Adapter    "wolf"         : 1.7.0    , installed 1.7.0
        Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
        Adapter    "youtube"      : 4.2.1    , installed 4.2.1
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Objects and States
        Objects:        70890
        Hit:1 https://deb.nodesource.com/node_18.x jammy InRelease
        Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
        Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
        Reading package lists...
        Pending Updates: 17
        *** Listening Ports ***
        tcp        0      0 192.168.178.213:2001    0.0.0.0:*               LISTEN      1000       134283856  33130/io.hm-rpc.1
        tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      1000       134298364  34136/go2rtc
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          42784434   1/init
        tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1000       134278690  32860/io.hm-rpc.0
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        42784711   118/systemd-resolve
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      113        42787856   145/mosquitto
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       134281530  32965/io.shelly.0
        tcp        0      0 0.0.0.0:12004           0.0.0.0:*               LISTEN      1000       134282199  33085/io.wolf.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       134276662  32650/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       134276655  32650/iobroker.js-c
        tcp        0      0 127.0.0.1:8200          0.0.0.0:*               LISTEN      1000       134298215  34104/io.cameras.0
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          42785434   316/master
        tcp6       0      0 :::8777                 :::*                    LISTEN      1000       134277405  32675/io.admin.0
        tcp6       0      0 :::8554                 :::*                    LISTEN      1000       134298359  34136/go2rtc
        tcp6       0      0 :::111                  :::*                    LISTEN      0          42784436   1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          42785209   1/init
        tcp6       0      0 :::1984                 :::*                    LISTEN      1000       134298358  34136/go2rtc
        tcp6       0      0 :::1883                 :::*                    LISTEN      113        42787857   145/mosquitto
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          42785435   316/master
        tcp6       0      0 :::3500                 :::*                    LISTEN      1000       134282316  32980/io.sonos.0
        tcp6       0      0 :::8084                 :::*                    LISTEN      1000       134296855  33999/io.ws.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       134296785  33984/io.web.0
        tcp6       0      0 :::8000                 :::*                    LISTEN      1000       134300448  33891/io.upnp.0
        udp        0      0 0.0.0.0:58377           0.0.0.0:*                           1000       134298381  34119/io.eusec.0
        udp        0      0 0.0.0.0:50671           0.0.0.0:*                           1000       134299871  34119/io.eusec.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       134294394  33891/io.upnp.0
        udp        0      0 0.0.0.0:42966           0.0.0.0:*                           1000       134299889  34119/io.eusec.0
        udp        0      0 0.0.0.0:43291           0.0.0.0:*                           1000       138645628  34119/io.eusec.0
        udp        0      0 0.0.0.0:35184           0.0.0.0:*                           1000       138636952  34119/io.eusec.0
        udp        0      0 0.0.0.0:52729           0.0.0.0:*                           1000       134291236  33891/io.upnp.0
        udp        0      0 0.0.0.0:53121           0.0.0.0:*                           1000       136555816  34119/io.eusec.0
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       134281312  32905/io.mihome-vac
        udp        0      0 192.168.178.213:5353    0.0.0.0:*                           1000       134283352  33025/io.tr-064.1
        udp        0      0 192.168.178.213:5353    0.0.0.0:*                           1000       134283324  33010/io.tr-064.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       134281955  33040/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       134281956  33040/io.tuya.0
        udp        0      0 0.0.0.0:56958           0.0.0.0:*                           1000       136555224  34119/io.eusec.0
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        42784710   118/systemd-resolve
        udp        0      0 0.0.0.0:57410           0.0.0.0:*                           1000       138634891  34119/io.eusec.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          42784435   1/init
        udp        0      0 0.0.0.0:8555            0.0.0.0:*                           1000       134298360  34136/go2rtc
        udp6       0      0 :::111                  :::*                                0          42784437   1/init
        udp6       0      0 :::8443                 :::*                                1000       134298365  34136/go2rtc
        2023-08-29 15:23:06.849  - warn: fb-checkpresence.0 (33265) getWlBlInfo TypeError: Cannot read properties of null (reading 'length')
        2023-08-29 15:24:03.588  - info: javascript.0 (32749) script.js.SolarEgde-Script: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
        2023-08-29 15:24:03.814  - info: dwd.0 (51237) force terminating after 4 minutes
        2023-08-29 15:24:03.815  - info: dwd.0 (51237) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-08-29 15:24:04.504  - error: dwd.0 (51237) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-08-29 15:24:04.504  - error: dwd.0 (51237) unhandled promise rejection: DB closed
        2023-08-29 15:24:04.507  - error: dwd.0 (51237) Error: DB closed
        2023-08-29 15:24:04.507  - error: dwd.0 (51237) DB closed
        2023-08-29 15:24:06.016  - info: dwd.0 (51237) terminating with timeout
        2023-08-29 15:24:08.306  - info: host.Iobroker-test instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-08-29 15:24:14.456  - info: smartgarden.0 (33801) 3/ on_pong: ++ pong'ed ++
        2023-08-29 15:25:01.008  - warn: fb-checkpresence.0 (33265) getWlBlInfo TypeError: Cannot read properties of null (reading 'length')
        2023-08-29 15:25:03.022  - info: host.Iobroker-test instance system.adapter.dwd.0 started with pid 51552
        2023-08-29 15:25:03.574  - info: javascript.0 (32749) script.js.SolarEgde-Script: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
        2023-08-29 15:25:07.441  - info: javascript.0 (32749) script.js.SolarEgde-Script: Der Energieertrag der Anlage "2712611" wird verarbeitet.
        2023-08-29 15:26:03.493  - info: javascript.0 (32749) script.js.SolarEgde-Script: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
        2023-08-29 15:26:37.247  - info: dwd.0 (51552) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 4.0.24
        2023-08-29 15:26:44.457  - info: smartgarden.0 (33801) 3/ on_pong: ++ pong'ed ++
        2023-08-29 15:27:03.504  - info: javascript.0 (32749) script.js.SolarEgde-Script: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
        iob diag has finished.
        Press any key for a summary
                             v.2023-04-16
        Operatingsystem:        Ubuntu 22.04.3 LTS
        Kernel:                 5.15.30-2-pve
        Installation:           lxc
        User-ID:                1002
        X-Server:               false
        Pending OS-Updates:     17
        Pending iob updates:    1
        Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Swap:           8.2G          0B        8.2G
        Total:           24G        5.7G         16G
        Active iob-Instances:   61
        Active repo(s): stable
        ioBroker Core:          js-controller           4.0.24
                                admin                   6.8.0
        Objects type: jsonl
        States  type: jsonl
        Objects:                70890
        States:                 59474
        Size of iob-Database:
        101M    /opt/iobroker/iobroker-data/states.jsonl
        Das sollte es sein oder
        DJMarc75D 2 Antworten Letzte Antwort
        • LongbowL Longbow
          @djmarc75
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        22.04
          Codename:       jammy
          NAME="Ubuntu"
          VERSION_ID="22.04"
          ID=ubuntu
          ID_LIKE=debian
          CPU threads: 4
                           RTC time: n/a
                    RTC in local TZ: no
          X-Server:       false
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:           8.2G          0B        8.2G
          Total:           24G        5.7G         16G
                   5683 M used memory
                    632 M active memory
                   8733 M free memory
                      0 M buffer memory
                   1476 M swap cache
                   8191 M total swap
                      0 M used swap
                   8191 M free swap
          *** FILESYSTEM ***
          /var:
          4.6G    /var/
          4.0G    /var/log
          340M    /var/cache
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        22.04
          Codename:       jammy
          NAME="Ubuntu"
          VERSION_ID="22.04"
          ID=ubuntu
          ID_LIKE=debian
          CPU threads: 4
                           RTC time: n/a
                    RTC in local TZ: no
          X-Server:       false
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:           8.2G          0B        8.2G
          Total:           24G        5.7G         16G
                   5683 M used memory
                    632 M active memory
                   8733 M free memory
                      0 M buffer memory
                   1476 M swap cache
                   8191 M total swap
                      0 M used swap
                   8191 M free swap
          *** FILESYSTEM ***
          /var:
          4.6G    /var/
          4.0G    /var/log
          340M    /var/cache
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Adapter State
          + instance is alive
          Objects and States
          Objects:        70890
          Pending Updates: 17
                               v.2023-04-16
          Installation:           lxc
          User-ID:                1002
          X-Server:               false
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
          MEMORY:
          Swap:           8.2G          0B        8.2G
          Total:           24G        5.7G         16G
                                  admin                   6.8.0
          Objects type: jsonl
          States  type: jsonl
          Objects:                70890
          States:                 59474
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @longbow sagte in DWD und Das Wetter Adapter:
          Ja, aber da scheint ja vieles krumm zu sein... vll kann da mal @Thomas-Braun einen Blick drauf werfen ?!
          LongbowL 2 Antworten Letzte Antwort
            LongbowL Online
            LongbowL Online
            Longbow
            @djmarc75 Also bis jetzt läuft das gut das system... @Thomas-Braun Bi gespannt...
            • LongbowL Longbow
              @longbow
              So auf den ersten Blick sehe ich nix wirklich krummes.
              Nur der bemerkenswert hohe Arbeitsspeicherverbrauch fällt auf.
              Relativiert sich aber wieder, wenn man die
              berücksichtigt.
                @longbow
                berücksichtigt.
                LongbowL Online
                LongbowL Online
                Longbow
                @thomas-braun Ok danke... und an was könnte es liegen, das die beiden nicht gehen?
                  @longbow
                  berücksichtigt.
                  LongbowL Online
                  LongbowL Online
                  Longbow
                  @thomas-braun gibt es eine gute Anleitung, wie man einen iobroker aufsetzt?
                    LongbowL Online
                    LongbowL Online
                    Longbow
                    @djmarc75 was ist nach deiner ansicht alles krumm
                    • LongbowL Longbow
                      @djmarc75
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Docker          : false
                      Release:        22.04
                      Codename:       jammy
                      NAME="Ubuntu"
                      VERSION_ID="22.04"
                      ID=ubuntu
                      ID_LIKE=debian
                      CPU threads: 4
                                       RTC time: n/a
                                RTC in local TZ: no
                      X-Server:       false
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                      Swap:           8.2G          0B        8.2G
                      Total:           24G        5.7G         16G
                               5683 M used memory
                                632 M active memory
                               8733 M free memory
                                  0 M buffer memory
                               1476 M swap cache
                               8191 M total swap
                                  0 M used swap
                               8191 M free swap
                      *** FILESYSTEM ***
                      /var:
                      4.6G    /var/
                      4.0G    /var/log
                      340M    /var/cache
                      /usr/bin/npm            9.6.7
                      /usr/bin/npx            9.6.7
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Docker          : false
                      Release:        22.04
                      Codename:       jammy
                      NAME="Ubuntu"
                      VERSION_ID="22.04"
                      ID=ubuntu
                      ID_LIKE=debian
                      CPU threads: 4
                                       RTC time: n/a
                                RTC in local TZ: no
                      X-Server:       false
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                      Swap:           8.2G          0B        8.2G
                      Total:           24G        5.7G         16G
                               5683 M used memory
                                632 M active memory
                               8733 M free memory
                                  0 M buffer memory
                               1476 M swap cache
                               8191 M total swap
                                  0 M used swap
                               8191 M free swap
                      *** FILESYSTEM ***
                      /var:
                      4.6G    /var/
                      4.0G    /var/log
                      340M    /var/cache
                      /usr/bin/npm            9.6.7
                      /usr/bin/npx            9.6.7
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        70890
                      Pending Updates: 17
                                           v.2023-04-16
                      Installation:           lxc
                      User-ID:                1002
                      X-Server:               false
                                              /usr/bin/npm            9.6.7
                                              /usr/bin/npx            9.6.7
                      MEMORY:
                      Swap:           8.2G          0B        8.2G
                      Total:           24G        5.7G         16G
                                              admin                   6.8.0
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                70890
                      States:                 59474
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      Ist "etwas" hoch und ich bin irritiert wegen:
                      und
                      muss jetzt aber nix heissen, daher hab ich ja @Thomas-Braun mit ins Boot genommen, der kennt sich da viiiieeeel besser aus ;)
                        und
                        @djmarc75 sagte in DWD und Das Wetter Adapter:
                        Dürfte am Setup als LXC liegen.
                        Da fehlt der User in einer der beiden Gruppen.
                          LongbowL Online
                          LongbowL Online
                          Longbow
                          @thomas-braun wie bekomme ich es besser hin das Setup vom LXC?
                          und was meinst du mit dem User in einer der beiden Gruppen?
                          Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
                          • LongbowL Longbow
                            Kann ich dir nicht sagen, ich verwende keine Container. Ist mir zu kompliziert. :-)
                            Den user mit der uid=1002 in die Gruppe adm oder systemd-journal packen.
                            Hast du die Ausgabe von iob diag gekürzt? Üblicherweise gibt es da einen Block mit den usernames. Genau für solche Fälle nämlich...
                              LongbowL Online
                              LongbowL Online
                              Longbow
                              wie nutzt du das?
                              Meinst du das?
                              *** User and Groups ***
                              cliffkirchhof
                              /home/cliffkirchhof
                              cliffkirchhof iobroker adm
                              • LongbowL Longbow
                                wie nutzt du das?
                                Meinst du das?
                                cliffkirchhof
                                /home/cliffkirchhof
                                cliffkirchhof
                                Dann so:
                                sudo usermod -a -G adm cliffkirchhof
                                Einmal den cliffkirchhof aus- und wieder einloggen, erst dann stehen die Gruppen richtig.
                                • LongbowL Longbow
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  Du nutzt ja sicherlich Proxmox ?!
                                  Warum nutzt man nicht die offizielle Anleitung ?
                                  https://www.iobroker.net/#de/documentation/install/proxmox.md
                                    LongbowL Online
                                    LongbowL Online
                                    Longbow
                                    @djmarc75 macht es sind, auf Ubuntu 22.04.3 von 20.04.6 update zu daten vor dem Installieren des iobrokers oder kann das auch später gemacht werden ?
                                    DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                                    • LongbowL Longbow
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      ich hab keine Ahnung, ich nutze kein Ubuntu, sondern Debian. Da kann ich Dir leider nix zu sagen.
                                      • LongbowL Longbow
                                        @longbow
                                        Es macht immer Sinn eine aktuelle stabile Distribution zu fahren. Die Reihenfolge ist da aber nicht gar so wichtig.
                                        • C Offline
                                          chuck2941
                                          schrieb am zuletzt editiert von chuck2941
                                          Abend zusammen,
                                          ich habe im Log immer wieder Fehlermeldungen von dem Adapter, kann jemand sagen was das zu bedeuten hat?
                                          Laufen tut der Adapter und auf der VIS ist auch alles korrekt.
                                          Ro75R 1 Antwort Letzte Antwort
