  4. DWD und Das Wetter Adapter
    3.1k
    3.1k
23 Beiträge 5 Kommentatoren 1.0k Aufrufe 4 Beobachtet
  • LongbowL Longbow
    Hallo
    keine Ahnung wieso und warum, aber die beiden Adapter spinnen seit einigen Tage leider.
    In dem Protokoll steht Folgendes, ständig über 100 Fehlermeldung von den.
    Zeit
    error
    Nachricht
    dwd.0
    2023-08-29 14:49:04.761	error	DB closed
    dwd.0
    2023-08-29 14:49:04.761	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:629:26) at Socket.emit (node:events:514:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:323:12)
    dwd.0
    2023-08-29 14:49:04.758	error	unhandled promise rejection: DB closed
    dwd.0
    2023-08-29 14:49:04.758	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    eusec.0
    2023-08-29 14:48:47.412	error	Station T8124P2022222014 - All address lookup tentatives failed.
    host.Iobroker-test
    2023-08-29 14:46:28.560	error	instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
    daswetter.0
    2023-08-29 14:46:24.676	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_24.wind_symbol": Connection is closed.
    daswetter.0
    2023-08-29 14:46:24.676	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_24.wind_symbolB": Connection is closed.
    daswetter.0
    2023-08-29 14:46:24.675	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_24.iconURL: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_24.iconURL": Connection is closed.]
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @longbow
    Das könnte irgendwas mit dem JS-Controller zu tun haben.
    Zeig mal bitte
    iob diag
    Lehrling seit 1975 !!!
    LongbowL 1 Antwort Letzte Antwort
    • DJMarc75D DJMarc75
      @longbow
      Zeig mal bitte
      iob diag
      LongbowL Offline
      LongbowL Offline
      Longbow
      @djmarc75
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : lxc
      Distributor ID: Ubuntu
      Description:    Ubuntu 22.04.3 LTS
      Release:        22.04
      Codename:       jammy
      PRETTY_NAME="Ubuntu 22.04.3 LTS"
      NAME="Ubuntu"
      VERSION_ID="22.04"
      VERSION="22.04.3 LTS (Jammy Jellyfish)"
      VERSION_CODENAME=jammy
      ID=ubuntu
      ID_LIKE=debian
      HOME_URL="https://www.ubuntu.com/"
      SUPPORT_URL="https://help.ubuntu.com/"
      BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
      PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
      UBUNTU_CODENAME=jammy
      Systemuptime and Load:
       15:18:25 up 3 days, 17:27,  2 users,  load average: 2.52, 2.71, 2.90
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Tue 2023-08-29 15:18:25 CEST
                 Universal time: Tue 2023-08-29 13:18:25 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             15G        5.7G        8.7G        0.0K        1.5G         10G
      Swap:           8.2G          0B        8.2G
      Total:           24G        5.7G         16G
              15894 M total memory
               5683 M used memory
                632 M active memory
               6065 M inactive memory
               8733 M free memory
                  0 M buffer memory
               1476 M swap cache
               8191 M total swap
                  0 M used swap
               8191 M free swap
      *** FILESYSTEM ***
      Filesystem                       Type   Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--213--disk--0 ext4    54G   11G   41G  22% /
      none                             tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
      tmpfs                            tmpfs  3.2G  120K  3.2G   1% /run
      tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--213--disk--0 ext4   rw,relatime,stripe=16
      /var:
      4.6G    /var/
      4.0G    /var/log/journal/ddbba1a4925941c98f0be027bc45e442
      4.0G    /var/log
      340M    /var/cache
      Archived and active journals take up 16.0M in the file system.
      /opt/iobroker/backups:
      406M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      944M    /opt/iobroker/iobroker-data/
      669M    /opt/iobroker/iobroker-data/files
      126M    /opt/iobroker/iobroker-data/backup-objects
      88M     /opt/iobroker/iobroker-data/files/echarts.admin
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      72M     /opt/iobroker/iobroker-data/states.jsonl
      52M     /opt/iobroker/iobroker-data/objects.jsonl
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        22.04
      Codename:       jammy
      NAME="Ubuntu"
      VERSION_ID="22.04"
      ID=ubuntu
      ID_LIKE=debian
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           8.2G          0B        8.2G
      Total:           24G        5.7G         16G
               5683 M used memory
                632 M active memory
               8733 M free memory
                  0 M buffer memory
               1476 M swap cache
               8191 M total swap
                  0 M used swap
               8191 M free swap
      *** FILESYSTEM ***
      /var:
      4.6G    /var/
      4.0G    /var/log
      340M    /var/cache
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Adapter State
      + system.adapter.admin.0                  : admin                 : Iobroker-test                            -  enabled, port: 8777, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : Iobroker-test                            -  enabled
        system.adapter.alias-manager.0          : alias-manager         : Iobroker-test                            - disabled
      + system.adapter.backitup.0               : backitup              : Iobroker-test                            -  enabled
      + system.adapter.cameras.0                : cameras               : Iobroker-test                            -  enabled, port: 8200, bind: 127.0.0.1
        system.adapter.chromecast.0             : chromecast            : Iobroker-test                            - disabled
      + system.adapter.cloud.0                  : cloud                 : Iobroker-test                            -  enabled
        system.adapter.daswetter.0              : daswetter             : Iobroker-test                            -  enabled
        system.adapter.devices.0                : devices               : Iobroker-test                            -  enabled
      + system.adapter.discovery.0              : discovery             : Iobroker-test                            -  enabled
      + system.adapter.dwd.0                    : dwd                   : Iobroker-test                            -  enabled
      + system.adapter.echarts.0                : echarts               : Iobroker-test                            -  enabled
      + system.adapter.email.0                  : email                 : Iobroker-test                            -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Iobroker-test                            -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : Iobroker-test                            -  enabled
      + system.adapter.eusec.0                  : eusec                 : Iobroker-test                            -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : Iobroker-test                            -  enabled
      + system.adapter.fb-checkpresence.1       : fb-checkpresence      : Iobroker-test                            -  enabled
        system.adapter.flot.0                   : flot                  : Iobroker-test                            - disabled
      + system.adapter.followthesun.0           : followthesun          : Iobroker-test                            -  enabled
        system.adapter.geofency.0               : geofency              : Iobroker-test                            - disabled, port: 7999, bind: 0.0.0.0
        system.adapter.heatingcontrol.0         : heatingcontrol        : Iobroker-test                            - disabled
      + system.adapter.history.0                : history               : Iobroker-test                            -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : Iobroker-test                            -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : Iobroker-test                            -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : Iobroker-test                            -  enabled, port: 0
      + system.adapter.homeconnect.0            : homeconnect           : Iobroker-test                            -  enabled
        system.adapter.hue-extended.0           : hue-extended          : Iobroker-test                            - disabled
      + system.adapter.hue.0                    : hue                   : Iobroker-test                            -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : Iobroker-test                            -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: Iobroker-test                            - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : Iobroker-test                            - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : Iobroker-test                            - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : Iobroker-test                            - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : Iobroker-test                            - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Iobroker-test                            - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Iobroker-test                            - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Iobroker-test                            - disabled
      + system.adapter.influxdb.0               : influxdb              : Iobroker-test                            -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : Iobroker-test                            -  enabled
      + system.adapter.iot.0                    : iot                   : Iobroker-test                            -  enabled
      + system.adapter.javascript.0             : javascript            : Iobroker-test                            -  enabled
        system.adapter.klf200.0                 : klf200                : Iobroker-test                            -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : Iobroker-test                            -  enabled, port: 54321
      + system.adapter.modbus.0                 : modbus                : Iobroker-test                            -  enabled
        system.adapter.mqtt-client.0            : mqtt-client           : Iobroker-test                            - disabled, port: 1883
      + system.adapter.mqtt.0                   : mqtt                  : Iobroker-test                            -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.myenergi.0               : myenergi              : Iobroker-test                            -  enabled
      + system.adapter.netatmo.0                : netatmo               : Iobroker-test                            -  enabled
      + system.adapter.nina.0                   : nina                  : Iobroker-test                            -  enabled
      + system.adapter.nuki.0                   : nuki                  : Iobroker-test                            -  enabled
      + system.adapter.openweathermap.0         : openweathermap        : Iobroker-test                            -  enabled
        system.adapter.parser.0                 : parser                : Iobroker-test                            - disabled
        system.adapter.places.0                 : places                : Iobroker-test                            - disabled
      + system.adapter.pollenflug.0             : pollenflug            : Iobroker-test                            -  enabled
      + system.adapter.proxmox.0                : proxmox               : Iobroker-test                            -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : Iobroker-test                            -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : Iobroker-test                            -  enabled
      + system.adapter.robonect.0               : robonect              : Iobroker-test                            -  enabled
        system.adapter.rtspstream.0             : rtspstream            : Iobroker-test                            - disabled, port: 9088
        system.adapter.samsung.0                : samsung               : Iobroker-test                            - disabled
      + system.adapter.scenes.0                 : scenes                : Iobroker-test                            -  enabled
      + system.adapter.shelly.0                 : shelly                : Iobroker-test                            -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.smartgarden.0            : smartgarden           : Iobroker-test                            -  enabled
      + system.adapter.smartthings.0            : smartthings           : Iobroker-test                            -  enabled
      + system.adapter.sonos.0                  : sonos                 : Iobroker-test                            -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : Iobroker-test                            -  enabled
      + system.adapter.statistics.0             : statistics            : Iobroker-test                            -  enabled
      + system.adapter.synology.0               : synology              : Iobroker-test                            -  enabled, port: 5001
        system.adapter.synology.1               : synology              : Iobroker-test                            - disabled, port: 5001
      + system.adapter.tankerkoenig.0           : tankerkoenig          : Iobroker-test                            -  enabled
      + system.adapter.telegram.0               : telegram              : Iobroker-test                            -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : Iobroker-test                            -  enabled
      + system.adapter.tr-064.1                 : tr-064                : Iobroker-test                            -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : Iobroker-test                            -  enabled
      + system.adapter.tuya.0                   : tuya                  : Iobroker-test                            -  enabled
      + system.adapter.tvprogram.0              : tvprogram             : Iobroker-test                            -  enabled
      + system.adapter.upnp.0                   : upnp                  : Iobroker-test                            -  enabled
        system.adapter.vis-bars.0               : vis-bars              : Iobroker-test                            - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Iobroker-test                            - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : Iobroker-test                            - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : Iobroker-test                            - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : Iobroker-test                            -  enabled
        system.adapter.vis-history.0            : vis-history           : Iobroker-test                            - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Iobroker-test                            - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : Iobroker-test                            - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : Iobroker-test                            -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : Iobroker-test                            - disabled
        system.adapter.vis-map.0                : vis-map               : Iobroker-test                            - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : Iobroker-test                            - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : Iobroker-test                            -  enabled
        system.adapter.vis-metro.0              : vis-metro             : Iobroker-test                            - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : Iobroker-test                            - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : Iobroker-test                            - disabled
        system.adapter.vis.0                    : vis                   : Iobroker-test                            -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : Iobroker-test                            -  enabled
      + system.adapter.vw-connect.1             : vw-connect            : Iobroker-test                            -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : Iobroker-test                            -  enabled
      + system.adapter.web.0                    : web                   : Iobroker-test                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wolf-smartset.0          : wolf-smartset         : Iobroker-test                            -  enabled
      + system.adapter.wolf.0                   : wolf                  : Iobroker-test                            -  enabled, port: 12004, bind: 0.0.0.0
      + system.adapter.ws.0                     : ws                    : Iobroker-test                            -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.youtube.0                : youtube               : Iobroker-test                            -  enabled
        system.adapter.yr.0                     : yr                    : Iobroker-test                            -  enabled
      + instance is alive
      Used repository: stable
      Adapter    "admin"        : 6.8.0    , installed 6.8.0
      Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
      Adapter    "alias-manager": 1.2.4    , installed 1.2.6
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "eusec"        : 1.1.1    , installed 1.1.1
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "followthesun" : 0.4.2    , installed 0.4.1  [Updatable]
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
      Adapter    "hue"          : 3.9.5    , installed 3.9.5
      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "iot"          : 1.14.5   , installed 1.14.5
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Adapter    "klf200"       : 1.0.1    , installed 1.0.1
      Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
      Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "nuki"         : 1.6.0    , installed 1.6.0
      Adapter    "openweathermap": 0.3.9   , installed 0.3.9
      Adapter    "parser"       : 1.3.2    , installed 1.3.2
      Adapter    "places"       : 1.1.2    , installed 1.1.2
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
      Adapter    "robonect"     : 0.1.4    , installed 0.1.4
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
      Adapter    "sonos"        : 2.3.1    , installed 2.3.1
      Adapter    "statistics"   : 2.3.0    , installed 2.3.0
      Adapter    "synology"     : 2.1.13   , installed 2.1.13
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
      Adapter    "unifi"        : 0.6.6    , installed 0.6.6
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      Adapter    "withings"     : 0.0.13   , installed 0.0.13
      Adapter    "wolf"         : 1.7.0    , installed 1.7.0
      Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
      Adapter    "youtube"      : 4.2.1    , installed 4.2.1
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Objects and States
      Objects:        70890
      Hit:1 https://deb.nodesource.com/node_18.x jammy InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
      Reading package lists...
      Pending Updates: 17
      *** Listening Ports ***
      tcp        0      0 192.168.178.213:2001    0.0.0.0:*               LISTEN      1000       134283856  33130/io.hm-rpc.1
      tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      1000       134298364  34136/go2rtc
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          42784434   1/init
      tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1000       134278690  32860/io.hm-rpc.0
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        42784711   118/systemd-resolve
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      113        42787856   145/mosquitto
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       134281530  32965/io.shelly.0
      tcp        0      0 0.0.0.0:12004           0.0.0.0:*               LISTEN      1000       134282199  33085/io.wolf.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       134276662  32650/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       134276655  32650/iobroker.js-c
      tcp        0      0 127.0.0.1:8200          0.0.0.0:*               LISTEN      1000       134298215  34104/io.cameras.0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          42785434   316/master
      tcp6       0      0 :::8777                 :::*                    LISTEN      1000       134277405  32675/io.admin.0
      tcp6       0      0 :::8554                 :::*                    LISTEN      1000       134298359  34136/go2rtc
      tcp6       0      0 :::111                  :::*                    LISTEN      0          42784436   1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          42785209   1/init
      tcp6       0      0 :::1984                 :::*                    LISTEN      1000       134298358  34136/go2rtc
      tcp6       0      0 :::1883                 :::*                    LISTEN      113        42787857   145/mosquitto
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          42785435   316/master
      tcp6       0      0 :::3500                 :::*                    LISTEN      1000       134282316  32980/io.sonos.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1000       134296855  33999/io.ws.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       134296785  33984/io.web.0
      tcp6       0      0 :::8000                 :::*                    LISTEN      1000       134300448  33891/io.upnp.0
      udp        0      0 0.0.0.0:58377           0.0.0.0:*                           1000       134298381  34119/io.eusec.0
      udp        0      0 0.0.0.0:50671           0.0.0.0:*                           1000       134299871  34119/io.eusec.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       134294394  33891/io.upnp.0
      udp        0      0 0.0.0.0:42966           0.0.0.0:*                           1000       134299889  34119/io.eusec.0
      udp        0      0 0.0.0.0:43291           0.0.0.0:*                           1000       138645628  34119/io.eusec.0
      udp        0      0 0.0.0.0:35184           0.0.0.0:*                           1000       138636952  34119/io.eusec.0
      udp        0      0 0.0.0.0:52729           0.0.0.0:*                           1000       134291236  33891/io.upnp.0
      udp        0      0 0.0.0.0:53121           0.0.0.0:*                           1000       136555816  34119/io.eusec.0
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       134281312  32905/io.mihome-vac
      udp        0      0 192.168.178.213:5353    0.0.0.0:*                           1000       134283352  33025/io.tr-064.1
      udp        0      0 192.168.178.213:5353    0.0.0.0:*                           1000       134283324  33010/io.tr-064.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       134281955  33040/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       134281956  33040/io.tuya.0
      udp        0      0 0.0.0.0:56958           0.0.0.0:*                           1000       136555224  34119/io.eusec.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        42784710   118/systemd-resolve
      udp        0      0 0.0.0.0:57410           0.0.0.0:*                           1000       138634891  34119/io.eusec.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          42784435   1/init
      udp        0      0 0.0.0.0:8555            0.0.0.0:*                           1000       134298360  34136/go2rtc
      udp6       0      0 :::111                  :::*                                0          42784437   1/init
      udp6       0      0 :::8443                 :::*                                1000       134298365  34136/go2rtc
      2023-08-29 15:23:06.849  - warn: fb-checkpresence.0 (33265) getWlBlInfo TypeError: Cannot read properties of null (reading 'length')
      2023-08-29 15:24:03.588  - info: javascript.0 (32749) script.js.SolarEgde-Script: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
      2023-08-29 15:24:03.814  - info: dwd.0 (51237) force terminating after 4 minutes
      2023-08-29 15:24:03.815  - info: dwd.0 (51237) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-08-29 15:24:04.504  - error: dwd.0 (51237) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-08-29 15:24:04.504  - error: dwd.0 (51237) unhandled promise rejection: DB closed
      2023-08-29 15:24:04.507  - error: dwd.0 (51237) Error: DB closed
      2023-08-29 15:24:04.507  - error: dwd.0 (51237) DB closed
      2023-08-29 15:24:06.016  - info: dwd.0 (51237) terminating with timeout
      2023-08-29 15:24:08.306  - info: host.Iobroker-test instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-08-29 15:24:14.456  - info: smartgarden.0 (33801) 3/ on_pong: ++ pong'ed ++
      2023-08-29 15:25:01.008  - warn: fb-checkpresence.0 (33265) getWlBlInfo TypeError: Cannot read properties of null (reading 'length')
      2023-08-29 15:25:03.022  - info: host.Iobroker-test instance system.adapter.dwd.0 started with pid 51552
      2023-08-29 15:25:03.574  - info: javascript.0 (32749) script.js.SolarEgde-Script: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
      2023-08-29 15:25:07.441  - info: javascript.0 (32749) script.js.SolarEgde-Script: Der Energieertrag der Anlage "2712611" wird verarbeitet.
      2023-08-29 15:26:03.493  - info: javascript.0 (32749) script.js.SolarEgde-Script: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
      2023-08-29 15:26:37.247  - info: dwd.0 (51552) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 4.0.24
      2023-08-29 15:26:44.457  - info: smartgarden.0 (33801) 3/ on_pong: ++ pong'ed ++
      2023-08-29 15:27:03.504  - info: javascript.0 (32749) script.js.SolarEgde-Script: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
      iob diag has finished.
      Press any key for a summary
                           v.2023-04-16
      Operatingsystem:        Ubuntu 22.04.3 LTS
      Kernel:                 5.15.30-2-pve
      Installation:           lxc
      User-ID:                1002
      X-Server:               false
      Pending OS-Updates:     17
      Pending iob updates:    1
      Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Swap:           8.2G          0B        8.2G
      Total:           24G        5.7G         16G
      Active iob-Instances:   61
      Active repo(s): stable
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.8.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                70890
      States:                 59474
      Size of iob-Database:
      101M    /opt/iobroker/iobroker-data/states.jsonl
      Das sollte es sein oder
      DJMarc75D 2 Antworten Letzte Antwort
      • LongbowL Longbow
        @djmarc75
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        22.04
        Codename:       jammy
        NAME="Ubuntu"
        VERSION_ID="22.04"
        ID=ubuntu
        ID_LIKE=debian
        CPU threads: 4
                         RTC time: n/a
                  RTC in local TZ: no
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:           8.2G          0B        8.2G
        Total:           24G        5.7G         16G
                 5683 M used memory
                  632 M active memory
                 8733 M free memory
                    0 M buffer memory
                 1476 M swap cache
                 8191 M total swap
                    0 M used swap
                 8191 M free swap
        *** FILESYSTEM ***
        /var:
        4.6G    /var/
        4.0G    /var/log
        340M    /var/cache
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        22.04
        Codename:       jammy
        NAME="Ubuntu"
        VERSION_ID="22.04"
        ID=ubuntu
        ID_LIKE=debian
        CPU threads: 4
                         RTC time: n/a
                  RTC in local TZ: no
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:           8.2G          0B        8.2G
        Total:           24G        5.7G         16G
                 5683 M used memory
                  632 M active memory
                 8733 M free memory
                    0 M buffer memory
                 1476 M swap cache
                 8191 M total swap
                    0 M used swap
                 8191 M free swap
        *** FILESYSTEM ***
        /var:
        4.6G    /var/
        4.0G    /var/log
        340M    /var/cache
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Adapter State
        + instance is alive
        Objects and States
        Objects:        70890
        Pending Updates: 17
                             v.2023-04-16
        Installation:           lxc
        User-ID:                1002
        X-Server:               false
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        MEMORY:
        Swap:           8.2G          0B        8.2G
        Total:           24G        5.7G         16G
                                admin                   6.8.0
        Objects type: jsonl
        States  type: jsonl
        Objects:                70890
        States:                 59474
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @longbow sagte in DWD und Das Wetter Adapter:
        Ja, aber da scheint ja vieles krumm zu sein... vll kann da mal @Thomas-Braun einen Blick drauf werfen ?!
        LongbowL 2 Antworten Letzte Antwort
          LongbowL Offline
          LongbowL Offline
          Longbow
          @djmarc75 Also bis jetzt läuft das gut das system... @Thomas-Braun Bi gespannt...
          • LongbowL Longbow
            @longbow
            So auf den ersten Blick sehe ich nix wirklich krummes.
            Nur der bemerkenswert hohe Arbeitsspeicherverbrauch fällt auf.
            Relativiert sich aber wieder, wenn man die
            berücksichtigt.
              @longbow
              berücksichtigt.
              LongbowL Offline
              LongbowL Offline
              Longbow
              @thomas-braun Ok danke... und an was könnte es liegen, das die beiden nicht gehen?
                @longbow
                berücksichtigt.
                LongbowL Offline
                LongbowL Offline
                Longbow
                @thomas-braun gibt es eine gute Anleitung, wie man einen iobroker aufsetzt?
                  LongbowL Offline
                  LongbowL Offline
                  Longbow
                  @djmarc75 was ist nach deiner ansicht alles krumm
                  • LongbowL Longbow
                    @djmarc75
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        22.04
                    Codename:       jammy
                    NAME="Ubuntu"
                    VERSION_ID="22.04"
                    ID=ubuntu
                    ID_LIKE=debian
                    CPU threads: 4
                                     RTC time: n/a
                              RTC in local TZ: no
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:           8.2G          0B        8.2G
                    Total:           24G        5.7G         16G
                             5683 M used memory
                              632 M active memory
                             8733 M free memory
                                0 M buffer memory
                             1476 M swap cache
                             8191 M total swap
                                0 M used swap
                             8191 M free swap
                    *** FILESYSTEM ***
                    /var:
                    4.6G    /var/
                    4.0G    /var/log
                    340M    /var/cache
                    /usr/bin/npm            9.6.7
                    /usr/bin/npx            9.6.7
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        22.04
                    Codename:       jammy
                    NAME="Ubuntu"
                    VERSION_ID="22.04"
                    ID=ubuntu
                    ID_LIKE=debian
                    CPU threads: 4
                                     RTC time: n/a
                              RTC in local TZ: no
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:           8.2G          0B        8.2G
                    Total:           24G        5.7G         16G
                             5683 M used memory
                              632 M active memory
                             8733 M free memory
                                0 M buffer memory
                             1476 M swap cache
                             8191 M total swap
                                0 M used swap
                             8191 M free swap
                    *** FILESYSTEM ***
                    /var:
                    4.6G    /var/
                    4.0G    /var/log
                    340M    /var/cache
                    /usr/bin/npm            9.6.7
                    /usr/bin/npx            9.6.7
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        70890
                    Pending Updates: 17
                                         v.2023-04-16
                    Installation:           lxc
                    User-ID:                1002
                    X-Server:               false
                                            /usr/bin/npm            9.6.7
                                            /usr/bin/npx            9.6.7
                    MEMORY:
                    Swap:           8.2G          0B        8.2G
                    Total:           24G        5.7G         16G
                                            admin                   6.8.0
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                70890
                    States:                 59474
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    Ist "etwas" hoch und ich bin irritiert wegen:
                    und
                    muss jetzt aber nix heissen, daher hab ich ja @Thomas-Braun mit ins Boot genommen, der kennt sich da viiiieeeel besser aus ;)
                      und
                      @djmarc75 sagte in DWD und Das Wetter Adapter:
                      Dürfte am Setup als LXC liegen.
                      Da fehlt der User in einer der beiden Gruppen.
                        LongbowL Offline
                        LongbowL Offline
                        Longbow
                        @thomas-braun wie bekomme ich es besser hin das Setup vom LXC?
                        und was meinst du mit dem User in einer der beiden Gruppen?
                        Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
                        • LongbowL Longbow
                          Kann ich dir nicht sagen, ich verwende keine Container. Ist mir zu kompliziert. :-)
                          Den user mit der uid=1002 in die Gruppe adm oder systemd-journal packen.
                          Hast du die Ausgabe von iob diag gekürzt? Üblicherweise gibt es da einen Block mit den usernames. Genau für solche Fälle nämlich...
                            LongbowL Offline
                            LongbowL Offline
                            Longbow
                            wie nutzt du das?
                            Meinst du das?
                            *** User and Groups ***
                            cliffkirchhof
                            /home/cliffkirchhof
                            cliffkirchhof iobroker adm
                            • LongbowL Longbow
                              wie nutzt du das?
                              Meinst du das?
                              cliffkirchhof
                              /home/cliffkirchhof
                              cliffkirchhof
                              Dann so:
                              sudo usermod -a -G adm cliffkirchhof
                              Einmal den cliffkirchhof aus- und wieder einloggen, erst dann stehen die Gruppen richtig.
                              • LongbowL Longbow
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                Du nutzt ja sicherlich Proxmox ?!
                                Warum nutzt man nicht die offizielle Anleitung ?
                                https://www.iobroker.net/#de/documentation/install/proxmox.md
                                  LongbowL Offline
                                  LongbowL Offline
                                  Longbow
                                  @djmarc75 macht es sind, auf Ubuntu 22.04.3 von 20.04.6 update zu daten vor dem Installieren des iobrokers oder kann das auch später gemacht werden ?
                                  DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                                  • LongbowL Longbow
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    ich hab keine Ahnung, ich nutze kein Ubuntu, sondern Debian. Da kann ich Dir leider nix zu sagen.
                                    • LongbowL Longbow
                                      @longbow
                                      Es macht immer Sinn eine aktuelle stabile Distribution zu fahren. Die Reihenfolge ist da aber nicht gar so wichtig.
                                      • C Offline
                                        chuck2941
                                        schrieb am zuletzt editiert von chuck2941
                                        Abend zusammen,
                                        ich habe im Log immer wieder Fehlermeldungen von dem Adapter, kann jemand sagen was das zu bedeuten hat?
                                        Laufen tut der Adapter und auf der VIS ist auch alles korrekt.
                                        Ro75R 1 Antwort Letzte Antwort
                                        • C chuck2941
                                          Abend zusammen,
                                          Ro75R Offline
                                          Ro75R Offline
                                          Ro75
                                          @chuck2941
                                          erhöhe bei das Wetter das Zeitlimit
                                          Ro75.
                                          C 1 Antwort Letzte Antwort
