  4. Node-Red
  5. (gelöst) Whatsapp Adpter sendet nicht in Vis
    6.4k
28 Beiträge 4 Kommentatoren 2.6k Aufrufe 4 Beobachtet
  • S siporax
    @siporax Hier mal das ganze
     <block type="schedule" id="{^f2uKbIM_,(~j[DyZN-" x="163" y="63">
       <field name="SCHEDULE">0 17 * * *</field>
       <statement name="STATEMENT">
         <block type="controls_if" id="35d`a[#YM+sjpO_T%:y)">
           <value name="IF0">
             <block type="logic_compare" id="H}}`/aPSS?=i-Iwf#nYh">
               <field name="OP">EQ</field>
               <value name="A">
                 <block type="get_value" id=":K;U-/q~Vcj|Rz5i4k-d">
                   <field name="OID">trashschedule.0.next.daysLeft</field>
                 </block>
               </value>
               <value name="B">
                 <block type="math_number" id="jEh4ybuPYhz={WnKO!iv">
                   <field name="NUM">1</field>
                 </block>
               </value>
             </block>
           </value>
           <statement name="DO0">
             <block type="whatsapp-cmb" id=".FA$%yqga]!Q+.jHwF+o">
               <field name="INSTANCE">.0</field>
               <field name="LOG"></field>
               <value name="MESSAGE">
                 <shadow type="text" id="T4b-ks_2L#*ggh0t;rn9">
                 </shadow>
                 <block type="text_join" id="TKa4{a_*g+Y8PiB@AY3+">
                   <value name="ADD0">
                     <block type="text" id="*8f1fi*QG^}%,|)$kITa">
                       <field name="TEXT">Morgen wird der </field>
                     </block>
                   </value>
                   <value name="ADD1">
                     <block type="get_value" id="Q:-U~E7-lSgxd=v{fZFh">
                       <field name="OID">trashschedule.0.next.typesText</field>
                     </block>
                   </value>
                   <value name="ADD2">
                     <block type="text" id="+EGGK!EzwhkW(Qn3QRLZ">
                       <field name="TEXT">abgeholt </field>
                     </block>
                   </value>
                 </block>
               </value>
             </block>
           </statement>
         </block>
       </statement>
       <next>
         <block type="schedule" id="F$]QUy.YkJ3rO@TP:Vkn">
           <field name="SCHEDULE">18 14 * * *</field>
             <block type="controls_if" id="eWENW2-}k=2$_-_;4r4=">
               <value name="IF0">
                 <block type="logic_compare" id="GW2d]x%P,sMdi~|k~GXy">
                   <value name="A">
                     <block type="get_value" id="C:~Vh9}B=cBI2*B7M#k(">
                     </block>
                   </value>
                   <value name="B">
                     <block type="math_number" id="$lBiaQKc_jrP/4`dcqK-">
                       <field name="NUM">0</field>
                     </block>
                   </value>
                 </block>
               </value>
                 <block type="whatsapp-cmb" id="P0NP*ax=?#4oMOY/?M*A">
                     <shadow type="text">
                     </shadow>
                     <block type="text_join" id="hO;aRpd6_=kB!@eR|2s~">
                       <value name="ADD0">
                         <block type="text" id="wX,b`gnXk|V.(!w5`eFw">
                           <field name="TEXT">Heute wird der </field>
                         </block>
                       </value>
                       <value name="ADD1">
                         <block type="get_value" id="=!7:_Bs(,Cq06NrZ!#wu">
                         </block>
                       </value>
                       <value name="ADD2">
                         <block type="text" id="]morSxPm4D3UroOo17_p">
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </statement>
             </block>
           </statement>
         </block>
       </next>
     </block>
    </xml>
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @siporax Bitte noch einen Screenshot vom Blockly
    Lehrling seit 1975 !!!
    • DJMarc75D DJMarc75
      siporax
      @djmarc75
      • S siporax
        @djmarc75
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @siporax rein zum Testen mal ein Testskript erstellen, speichern und ausführen
          siporax
          @djmarc75
          kommt nichts
          • S siporax
            @djmarc75
            kommt nichts
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @siporax sagte in Whatsapp Adpter sendet nicht in Vis:
            kommt nichts
            Dann hast Du wohl eine falsche oder keine Nummer in der Adapterkonfig eingegeben.
            Diese (Deine) Nummer muss mit +49 beginnen und dann Deine Nummer ohne anführende 0 und alles ohne Leerzeichen.
            Bei mir funktionierts bestens.
              kommt nichts
              siporax
              schrieb am zuletzt editiert von siporax
              @djmarc75 said in Whatsapp Adpter sendet nicht in Vis:
              kommt nichts
              ich verstehs finde kein Fehler im Adapter
              Der Bot geht und sendet über Handy
              • ? Offline
                Halten wir fest:
                • Du hast Dich bei Callmebot angemeldet
                • Du hast die Whatsappnachricht bekommen und korrekt beantwortet ("I allow callmebot to send me messages")
                • Du hast eine Nachricht mit dem API-Key bekommen
                • Du hast im Whatsapp-Adapter den API-Key und Deine Handynummer korrekt eingegeben
                • Der Adapter ist "grün"
                Dann sollte es eigentlich funktionieren
                Einen grundsätzlichen Test kannst Du auch über den Link aus der Nachricht mit dem API-Key ausführen:
                https://api.callmebot.com/whatsapp.php?phone=[Deine Handynummer im Format "49xxxxx" ohne null]&text=This+is+a+test&apikey=[Dein API-Key]
                  Halten wir fest:
                  siporax
                  @oliver-w-leibenguth said in Whatsapp Adpter sendet nicht in Vis:
                  Halten wir fest:
                  Ja alle Punkte richtig
                  kann ja die tesmail vom bot mir immer wieder senden lassen das geht alles.
                  DJMarc75D S 2 Antworten Letzte Antwort
                  • S siporax
                    Halten wir fest:
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    @siporax
                    Dann fällt mir nur noch ein dass Du
                    einen Haken gesetzt hast der da nicht hingehört.
                    • ? Offline
                      Hmm, dann würde ich auf Verdacht mal den Adapter wieder de- und neuinstallieren und API-Key und Handynummer nochmal eintragen.
                      • S siporax
                        Halten wir fest:
                        siporax
                        @siporax said in Whatsapp Adpter sendet nicht in Vis:
                        Halten wir fest:
                        habe meine handynumer +49 ohne diese Null eingeben also +49172xxxxxxx
                        • S siporax
                          Halten wir fest:
                          Halten wir fest:
                          Im Adapter ist das korrekt. In der Testmail ohne das "+"
                          • ? Offline
                            Hast Du den API-Key evtl. mit Copy/Paste übernommen und vor oder hinter dem Key Leerzeichen? Ist ein Schuss ins Blaue, aber sowas kann Probleme verursachen.
                            • mickymM Offline
                              mickymM Offline
                              mickym
                              Warum steht der Thread eigentlich im NodeRed Bereich?
                                siporax
                                habs nochmal von hand eingegeben da tut sich nichts
                                mit oder ohne plus vor der 49 in der Handynummer.
                                • mickymM mickym
                                  siporax
                                  @mickym
                                  Sorry habe mich vertan da ich noch was anderes geschrieben habe hier.
                                    @siporax
                                    siporax
                                    @djmarc75
                                    26.8.2023, 10:40:05.515 [info ]: javascript.0 (1484) Stop script script.js.versuch
                                    26.8.2023, 10:40:05.524 [info ]: javascript.0 (1484) Start javascript script.js.versuch
                                    26.8.2023, 10:40:05.545 [info ]: javascript.0 (1484) script.js.versuch: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    26.8.2023, 10:40:11.000 [info ]: javascript.0 (1484) Stop script script.js.versuch
                                    26.8.2023, 10:40:12.072 [info ]: javascript.0 (1484) Start javascript script.js.versuch
                                    26.8.2023, 10:40:12.078 [info ]: javascript.0 (1484) script.js.versuch: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    26.8.2023, 10:41:29.382 [info ]: javascript.0 (1484) Stop script script.js.versuch
                                    26.8.2023, 10:41:29.390 [info ]: javascript.0 (1484) Start javascript script.js.versuch
                                    26.8.2023, 10:41:29.400 [info ]: javascript.0 (1484) script.js.versuch: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    • S siporax
                                      @djmarc75
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      @siporax dann weiß ich nicht weiter, aber einen Vorschlag zur Neuinstallation hast Du ja von @Oliver-W-Leibenguth
                                      bekommen. Setz das halt mal um.
                                        siporax
                                        ok,danke
                                        S mickymM 2 Antworten Letzte Antwort
                                        • S siporax
                                          ok,danke
                                          siporax
                                          ok,danke
                                          immer noch das gleiche,geht nicht
