  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    6.0k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
  • Jackl1stJ Jackl1st
    @jackl1st sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
    @arteck
    2023-08-11 10:35:40.136 - debug: bluelink.0 (8027) Set new full status for U5YH7F15GPL143495
    2023-08-11 10:35:40.137 - debug: bluelink.0 (8027) RAW {"vehicleStatus":{"airCtrlOn":false,"engine":false,"doorLock":true,"doorOpen":{"frontLeft":0,"frontRight":0,"backLeft":0,"backRight":0},"trunkOpen":false,"airTemp":{"value":"00H","unit":0,"hvacTempType":1},"defrost":false,"lowFuelLight":false,"acc":false,"hoodOpen":false,"transCond":true,"steerWheelHeat":0,"sideBackWindowHeat":0,"dte":{"value":605,"unit":1},"tirePressureLamp":{"tirePressureLampAll":0,"tirePressureLampFL":0,"tirePressureLampFR":0,"tirePressureLampRL":0,"tirePressureLampRR":0},"seatHeaterVentState":{"frSeatHeatState":2,"flSeatHeatState":2,"rlSeatHeatState":2,"rrSeatHeatState":2},"battery":{"batSoc":81,"batState":0},"lampWireStatus":{"stopLamp":{"stopLampStatus":false,"leftLamp":false,"rightLamp":false},"headLamp":{"headLampStatus":false,"leftLowLamp":false,"rightLowLamp":false,"leftHighLamp":false,"rightHighLamp":false,"leftBifuncLamp":false,"rightBifuncLamp":false},"turnSignalLamp":{"turnSignalLampStatus":false,"leftFrontLamp":false,"rightFrontLamp":false,"leftRearLamp":false,"rightRearLamp":false}},"windowOpen":{"frontLeft":0,"frontRight":0,"backLeft":0,"backRight":0},"smartKeyBatteryWarning":false,"fuelLevel":85,"washerFluidStatus":false,"breakOilStatus":false,"engineOilStatus":false,"sleepModeCheck":false,"time":"20230811063536","remoteWaitingTimeAlert":{"remoteControlAvailable":1,"remoteControlWaitingTime":168,"elapsedTime":"00:54:56"},"systemCutOffAlert":0,"tailLampStatus":0,"hazardStatus":0},"odometer":{"value":146.5,"unit":1}}
    2023-08-11 10:35:40.235 - debug: roomba.0 (6658) DEBUG MISSION DATA: {"cleanMissionStatus":{"cycle":"none","phase":"charge","expireM":0,"expireTm":0,"rechrgM":0,"error":0,"notReady":0,"mssnM":0,"mssnStrtTm":0,"sqft":0,"initiator":"","nMssn":1847},"bin":{"present":true,"full":false}}
    2023-08-11 10:35:40.602 - debug: bluelink.0 (8027) Set 81 battery state for U5YH7F15GPL143495
    2023-08-11 10:35:40.611 - info: bluelink.0 (8027) Update for U5YH7F15GPL143495 successfull
    Jetzt habe ich das endlich gerafft...
    arteckA Offline
    arteckA Offline
    arteck
    #1380
    ne leider seh ich die Daten da nicht.. scheint das die nicht geliefert werden
    Jackl1stJ 2 Antworten Letzte Antwort
    • arteckA arteck
      Jackl1stJ Offline
      Jackl1stJ Offline
      Jackl1st
      #1381
      @arteck , sehe ich auch so. Bei meinem Vorgänger , dem PHEV funktionierte das noch. Da hatte ich auch den Standort. Na was solls. Danke.
      • J Offline
        Jui
        schrieb am zuletzt editiert von Jui
        #1382
        Hallo Zusammen,
        Kia / PHEV
        ich habe folgendes Problem mit dem Adapter auch mit der vorherigen und der neuen Version 2.3.6 :
        Wenn der Adapter neu gestartet ist, funktioniert der Datenabgleich fehlerfrei, Daten werden nach Plan oder per refresh eingelesen.
        Sende ich über control einen Befehl, zb. charge läuft der auch fehlerfrei durch und wird am Fahrzeug ausgeführt.
        Danach geht der Adapter quasi nicht mehr!
        Alle gesendeten Anforderungen werden mit Fehlermeldungen quittiert, die alle in etwa gleich lauten s.u.
        Wenn ich die Instanz neu starte geht der refresh wieder und bis zum ersten control Befehl auch alles, dann wieder Schluss.
        Habt Ihr eine Idee?
        Danke.
        bluelink.0
        2023-08-12 18:12:26.167	error	Error onStateChange ManagedBluelinkyError: @EuropeVehicle.startCharge: [400] Bad Request on [POST] https://prd.eu-ccapi.kia.com:8080/api/v2/spa/vehicles/XXX/control/charge - {"retCode":"F","resCode":"4002","resMsg":"Invalid request body - Invalid deviceId. ","msgId":"XXX"}
        nik82N 1 Antwort Letzte Antwort
        • J Jui
          Hallo Zusammen,
          Kia / PHEV
          Habt Ihr eine Idee?
          Danke.
          bluelink.0
          nik82N Offline
          nik82N Offline
          nik82
          #1383
          @jui
          https://forum.iobroker.net/post/1023967
          • nik82N nik82
            @jui
            Jui
            #1384
            @nik82
            Danke, den Beitrag hatte ich nicht gefunden.
            • arteckA arteck
              Jackl1stJ Offline
              Jackl1stJ Offline
              Jackl1st
              #1385
              @arteck , fragt sich trotzdem warum nicht. Fahrzeug ist im Adapter richtig eingestellt. Hat ja mit meinem PEHV auch funktioniert.
                #1386
                Frag Hyundai/Kia... die sollten es wissen.. :-)
                Jackl1stJ 1 Antwort Letzte Antwort
                  Jackl1stJ Offline
                  Jackl1stJ Offline
                  Jackl1st
                  schrieb am zuletzt editiert von Jackl1st
                  #1387
                  @ilovegym , gute Antwort. Ich dachte echt, kannst mal den Entwickler des Adapters fragen. Wenn man immer solch tolle Antworten bekommt, kann man auch auf gewisse Dinge verzichten.
                  nik82N ? arteckA 3 Antworten Letzte Antwort
                    nik82N Offline
                    nik82N Offline
                    nik82
                    #1388
                    @jackl1st
                    Der Entwickler kann leider nur das Verarbeiten was vom Hersteller bzw. der Api kommt.
                    Wenn da nicht mehr vom Hersteller/Api kommt, dann kann der Entwickler keine Daten herbeizaubern, dann müsste man wirklich Hyundai/Kia fragen :-)
                    Was natürlich nichts bewirken wird.
                    Aber somit war die Antwort von @ilovegym nicht falsch...
                      #1389
                      ja sorry aber das ist halt mal so, wenn du das genau wissen willst, dann musst du den Entwickler der Software fragen, die die Daten uebertraegt, und das ist halt mal Hyundai und nicht der Entwickler vom iobroker-Adapter.. er kann nur das, was er bekommt, umsetzen, und das wird ja einwandfrei gemacht.
                      Wenn dir meine Antworten nicht gefallen, kann ich auch nix zu.. :-) ich haett auch gern manches anders.. :-)
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #1390
                        @jackl1st da muss ich den 2 recht geben .. zaubern kann ich nicht
                        • arteckA arteck
                          Jackl1stJ Offline
                          Jackl1stJ Offline
                          Jackl1st
                          #1391
                          @arteck , also das hat ja auch keiner verlangt. Aber deine Aussage, das die erforderlichen Daten nicht abgerufen werden, kann ich auch aus dem log heraus lesen. Ich dachte nur, du als Entwickler, hast da ein wenig mehr Einblick, und das hast du ja auch, ist unumstritten. Deshalb berblüfft mich deine Aussage ein wenig. Und scheinbar bin ich hier der Einzigste bei dem die Koordinaten nicht übertragen werden. Sonst wären da ja vielleicht noch ein paar Meinungen dazu gekommen.
                          Aber ich schlage mal vor, das Thema hiermit zu beenden. Ich werde den Adapter nun doch deinstallieren und benutze halt die Handy App. Ende.
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #1392
                            auch DE stehen ??
                              Jackl1stJ Offline
                              Jackl1stJ Offline
                              Jackl1st
                              #1393
                              @ilovegym , da ich schon mehrfach erwänt habe das das schon mein 2. Kia Xceed ist, und beim 1., einen PHEV das übertragen der GPS Daten problemlos funktioniert hat, dachte ich das jemand eine Lösung weiß. Man kann ja nie wissen. Das der Hersteller der Software dafür verantwortlich ist weiß ich auch. Braucht man eben niemanden hier im Forum unter die Nase zu reiben. Das erscheint mir wie eine Aussage wenn man eben nicht weiter weiß. Und genau so wird es sein.
                              Lasst es gut sein, das Thema ist für mich beendet.
                              Meister MopperM arteckA 2 Antworten Letzte Antwort
                              -1
                                Meister MopperM Offline
                                Meister Mopper
                                #1394
                                @jackl1st
                                Ändert aber nix, wenn die Server nicht das tun, was sie sollen.
                                Kürzlich geschehen:
                                bluelink.0	2023-08-14 19:58:18.828	error	Error on API-Request Status, ErrorCount:1
                                Ich habe für mich längst die Fehlerquelle lokalisiert, es ist Hyundai und es sind nicht die Entwickler.
                                Da hier alles open source ist und weitgehend profitlos abläuft ist es mir ein Bedürfnis, dich um eine gebotene gewaltlose Kommunikation zu bitten.
                                Wer sollte denn sonst die Adapter am Leben halten? Möchtest du?
                                Proxmox und HA ...
                                Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #1395
                                  @jackl1st ich hab nochmal in den Source code geschaut..deshlab meine Frage.. ob das jetzt dein erster oder 5-ter Kia ist ist mir persönlich egal. und acuh wenn du es schon zig mal geschrieben hast.. MERK ICH MIR SOWAS NICHT..SRY..
                                  paar Sachen könnten wir noch schaun .. aber so wie du dich hier verhält.. Sache ist für mich erledigt..
                                  • arteckA arteck
                                    Jackl1stJ Offline
                                    Jackl1stJ Offline
                                    Jackl1st
                                    #1396
                                    @arteck , ja so vertritt jeder seine Meinung. Falls ich mich im Ton vergriffen haben sollte, bitte ich um Entschuldigung. Aber ich hatte ja auch schon geschrieben das das Thema , inclusive Adapter, für mich erledigt ist.
                                    Z 1 Antwort Letzte Antwort
                                      Z Offline
                                      Z Offline
                                      zeron850
                                      #1397
                                      Hallo Zusammen,
                                      ich habe die neueste Version des Bluelink Adapters von Github installiert und bei mir kommt seit heute folgende Fehlermeldung:
                                      @EuropeVehicle.status: [503] Service Unavailable on [GET] https://prd.eu-ccapi.kia.com:8080/api/v2/spa/vehicles/202da26d-xxxx/status - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"xxx"}
                                      Abrufe sind auf 3 pro Tag eingestellt. Kann mir hier jemand weiterhelfen?
                                      DANKE
                                      • Z zeron850
                                        Hallo Zusammen,
                                        DANKE
                                        #1398
                                        @zeron850
                                        Service unavailable- die Server haben Hitzefrei..
                                        • arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #1399
                                          kommt ihr in der App an die Daten dran?? meine Streikt gerade..
                                          T ? 2 Antworten Letzte Antwort
