  4. ZigBee neue Version 1.7.x
    5.9k
1.7backupiconszigbee
217 Beiträge 40 Kommentatoren 48.0k Aufrufe 47 Beobachtet
    mirko3107
    schrieb am zuletzt editiert von mirko3107
    #207
    gibt es irgendwelche bekannten Probleme zwischen Ledvance-LEDs, Aqara-Sensoren und Tradfri-Repeatern?
    Hab einen CC2652P mit Firmware vom 26.12.22, an den ich alles anlernen konnte. Aber nach ein paar Stunden sind alle
    Aqara-Sensoren nicht mehr aktiv.
    Heute morgen kommt das im Log:
    zigbee.0 2023-03-26 10:21:22.509	debug	DeviceAvailability:Non-pingable device 0x00158d0003217295 lumi.weather was last seen '46258.094' seconds ago.
    zigbee.0 2023-03-26 10:21:22.506	debug	DeviceAvailability:Non-pingable device 0x00158d0002ad8f67 lumi.sensor_switch.aq3 was last seen '1638.633' seconds ago.
    zigbee.0 2023-03-26 10:21:22.502	debug	DeviceAvailability:Non-pingable device 0x00158d0004448d07 lumi.sensor_magnet.aq2 was last seen '48966.097' seconds ago.
    zigbee.0 2023-03-26 10:21:22.498	debug	DeviceAvailability:Non-pingable device 0x00158d00041cbb3e lumi.sensor_magnet.aq2 was last seen '2104.881' seconds ago.
    zigbee.0 2023-03-26 10:21:22.495	debug	DeviceAvailability:Non-pingable device 0x00158d0004448ccd lumi.sensor_magnet.aq2 was last seen '35402.185' seconds ago.
    zigbee.0 2023-03-26 10:21:22.491	debug	DeviceAvailability:Non-pingable device 0x00158d0004448be7 lumi.sensor_magnet.aq2 was last seen '38934.898' seconds ago.
    zigbee.0 2023-03-26 10:21:22.489	debug	DeviceAvailability:Non-pingable device 0x00158d00032c2ad0 lumi.sensor_motion.aq2 was last seen '30499.902' seconds ago.
    zigbee.0 2023-03-26 10:21:22.485	debug	DeviceAvailability:Non-pingable device 0x00158d000317587d lumi.remote.b186acn01 was last seen '370.746' seconds ago.
    zigbee.0 2023-03-26 10:21:22.482	debug	DeviceAvailability:Non-pingable device 0x00158d000346825d lumi.sensor_magnet.aq2 was last seen '845.898' seconds ago.
    zigbee.0 2023-03-26 10:21:22.480	debug	DeviceAvailability:Non-pingable device 0x00158d0003042ed0 lumi.remote.b186acn01 was last seen '37995.113' seconds ago.
    zigbee.0 2023-03-26 10:21:22.477	debug	DeviceAvailability:Non-pingable device 0x00158d00044583c7 lumi.sensor_magnet.aq2 was last seen '2736.814' seconds ago.
    zigbee.0 2023-03-26 10:21:22.475	debug	DeviceAvailability:Non-pingable device 0x00158d00036b1b6f lumi.weather was last seen '40451.71' seconds ago.
    Kanal läuft auf 16, weil 11 voll war.
    Gibts da nen Trick?
    • M mirko3107
      Gibts da nen Trick?
      #208
      @mirko3107
      wenn ich den Namen Ledvance und Zigbee hoere, dann stellen sich die Nackenhaare...
      gibt wohl irgendwo, dass das funktioniert, aber aus dem Forum hier und meine eigene Erfahrung sagt, Ledvance gibst du wieder zurueck oder verkaufst den Kram, ist sowas von unzuverlaessig...
      Hatte ne Lampe und n paar Steckdosen, waren unbrauchbar und gingen nach ein paar Tagen wieder zurueck.
        mirko3107
        #209
        die Ledvance-LEDs waren nie unzuverlässig, der Aqara-Kram verschwindet, wenn er im selben Netz wie die Ledvance schwebt.
        Hab die Systeme jetzt durch einen zweiten CC2531 getrennt, die Ledvance beim CC2652P und der Aqara-Kram beim CC2531.
        Bis jetzt läufts.
        ? arteckA 2 Antworten Letzte Antwort
        • M mirko3107
          Bis jetzt läufts.
          #210
          @mirko3107
          gibt Devices, die haben ihre Lieblings Kanäle.. vielleicht liegts jetzt daran.. wenn es geht, ist es ja gut!
          Liegt ja auch viel am Environment ..👍
          • M mirko3107
            Bis jetzt läufts.
            arteckA Offline
            arteckA Offline
            arteck
            #211
            @mirko3107 sagte in ZigBee neue Version 1.7.x:
            ja doch das ist es ja.. die erlauben keine co existenz.. die verschlucken Statusmeldungen...
            • T Tschaeens
              @Asgothian
              Ich hätte eine kurze Frage. Ich habe Rauchmelder im Einsatz. Mit dem letzten Update 1.8.10 kann ich diese nicht mehr ansprechen. Es kommt folgender Fehler.
              23-01-15 10:01:23.381 - error: zigbee.0 (748) DeviceConfigure:Failed to DeviceConfigure.configure 0x0015bc003100c256 SMSZB-120 (Error: Bind 0x0015bc003100c256/35 genBinaryInput from '0x00124b0021b49875/1' failed (AREQ - ZDO - bindRsp after 10000ms)
              Hast du eine Idee?Verbunden sind sie, weil sie lesen auch die Temperatur aus.
              Jetzt:
              Ich bin auf die 1.8.9 zurück, da geht es wieder. Dennoch kommt folgender Logauszug.
              2023-01-15 10:23:59.344 - warn: zigbee.0 (748) Device '0x0015bc003100c256' announced itself
              2023-01-15 10:23:59.401 - warn: zigbee.0 (748) Object 0015bc003100c256.reliability is invalid: obj.common.states has an invalid type! Expected "object", received "string"
              2023-01-15 10:23:59.401 - warn: zigbee.0 (748) This object will not be created in future versions. Please report this to the developer.
              2023-01-15 10:23:59.403 - warn: zigbee.0 (748) Object zigbee.0.0015bc003100c256.reliability is invalid: obj.common.states has an invalid type! Expected "object", received "string"
              2023-01-15 10:23:59.403 - warn: zigbee.0 (748) This object will not be created in future versions. Please report this to the developer.
              2023-01-15 10:24:10.881 - error: zigbee.0 (748) Failed to interview '0x0015bc003100c256', device has not successfully been paired. undefined
              Gerät lässt sich wieder ansprechen.
              Lg und danke
              Tschaeens
              schrieb am zuletzt editiert von Tschaeens
              #212
              @tschaeens sagte in ZigBee neue Version 1.7.x:
              @Asgothian
              Jetzt:
              Lg und danke
              @arteck
              Ich habe die neue github version getestet. Leider habe ich dort auch das Problem, dass ich meine Rauchmelder nicht mehr ansprechen kann. Kann dir gerne auch einen Debug Log zukommen lassen?
              Vielen Dank für deine Hilfe
              • T Tschaeens
                @Asgothian
                Jetzt:
                Lg und danke
                @arteck
                #213
                @tschaeens hab die Rauchmelder u.a. auch, gut, dass du das gemerkt hast, war auf der 1.8.11, da gehen die auch nicht mehr, werden zwar ausgelesen, aber steuern geht nicht... das kann im Brandfall doof werden, wenn se dann nicht vernetzt sind..:(
                Hab mein Update-Test-Procedure jetzt angepasst und bin wieder auf die 1.8.9 zurueck, die funktioniert einwandfrei mit meinen Devices..
                  Tschaeens
                  #214
                  @ilovegym
                  Okay dann liegt es bestimmt an die Devices. Ich konnte auch nicht per send to payload den Befehl setzen. Mir werden auch Updates angezeigt. Eins habe ich eingespielt, seit dem geht der Feuermelder überhaupt nicht mehr. Auch nicht mit 1.8.9. Das blöde ist nur, dass in dieser Version die Gruppenzuweisung nicht funzt.
                    SuFra
                    #215
                    Ich möchte nur kurz berichten das ich mit ZigBee von einem USB Gateway auf einen POE Gateway umgestiegen bin.
                    Beide haben den gleichen Chip (CC2652P), so brauchte ich im ZigBee Adapter nur den Anschluss auf tcp://ip:6638 ändern und schon lief alles.
                    Nur so zur Info für die die auch überlegen umzusteigen.
                    HA-Cluster 1x NUC11TNHI50L00, 2x NUC11TNHI30L00, 1x BSi3, 1x BSi5
                    LXC's: PiHole, Grafana, MariaDB, TasmoAdmin, NTP Server, PeaNUT, ESPHome, paperless-ai, ollama
                    VM's: PBS, ioBroker, frigate, paperless, trueNAS (Plex)
                    • arteckA arteck
                      Es ist mal wieder Zeit für eine neue Version
                      der @Asgothian war mal wieder nicht untätig und hat paar neue Sachen programmiert.. die schon zwr länger im Adapter drin sind aber ich finde man sollte es erwähnen
                      Geräte können deaktiviert werden .. somit stören sie das Netz nicht.. nützlich für die Weihnachtsbeleuchtung
                      die Kachel wird dann grau
                      zum einschalten Kachel drehen
                      Die Gruppenfunktionen wurde neu geschrieben und verbessert
                      von mir wurden im Admin die fehlenden Icons hinzugefügt. der Adapter lädt diese runter ..
                      sollte im Log nach Adapter Start solche Zeile als Warning stehen
                      download icon from https://www.zigbee2mqtt.io/images/devices/929002398602.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/929002398602.png
                      ist ein manueller upload notwendig
                      danach sollte das Icon im Admin zur verfügung stehen
                      der Object Baum wird laut dem available status eingefärbt. man kann direkt erkennen welche Geräte offline sind
                      die Möglichkeit der Adapter internen Backups wurde hinzugefügt. nützlich wenn man ehh mit dem BackItUp Adapter seine Sicherung regelmässig macht. Falls nicht werden nur die letzten 10 Files behalten..
                      für den Rest siehe Readme
                      L Online
                      L Online
                      legro
                      schrieb am zuletzt editiert von legro
                      #216
                      Von Anfang an habe ich Sorgen, was den Betrieb von OSRAM lightify Lampen betrifft. Immer mal wieder verabschieden sich die einzelnen Lampen aus dem ZigBee-Netz. Als einzige Möglichkeit fand ich bisher nur, die Lampen mühsam zurückzusetzen (ein-aus-ein-aus..) und erneut anlzuernen. Nun las ich, dass das Anlernen inklusive Zurücksetzen in einem Schritt möglich sein sollte. Nur wie leite ich dieses ein? Sind irgendwo die Symbole im ZigBee-Adapter erläutert?
                      Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
                      • L legro
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #217
                        @legro und dafür schreiben wir eine DOKU... na wo wird die wohl sein..hmmmm
