  4. Steckdose mit 2 Datenpunkten für on off
31 Beiträge 9 Kommentatoren 4.3k Aufrufe 5 Beobachtet
  • DJMarc75D DJMarc75
    @vazi dann zeig mal die jeweiligen Objektdaten (Bleistift rechts anklicken) und poste die hier in Codetags
    @djmarc75 ```
      "type": "state",
      "common": {
        "name": "",
        "type": "boolean",
        "role": "boolean",
        "write": true,
        "read": true
      "native": {},
      "from": "system.adapter.smartthings.0",
      "user": "system.user.admin",
      "ts": 1690450416943,
      "_id": "smartthings.0.cbf9a2be-420b-4f59-80f6-d47727cd9727.capabilities.switch-off",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
      "type": "state",
      "common": {
        "name": "",
        "type": "boolean",
        "role": "boolean",
        "write": true,
        "read": true
      "native": {},
      "_id": "smartthings.0.cbf9a2be-420b-4f59-80f6-d47727cd9727.capabilities.switch-on",
      "acl": {
        "object": 1636,
        "state": 1636,
      "type": "state",
      "common": {
        "name": "value",
        "role": "text",
        "type": "string",
        "write": false,
        "read": true,
        "custom": {
          "iqontrol.0": {
            "0": "",
            "1": "",
            "2": "",
            "enabled": true,
            "invert": false,
            "confirm": false,
            "pincode": "",
            "roundDigits": 2,
            "timeFormat": "x",
            "timeDisplayFormat": "dddd, DD.MM.YYYY HH:mm:ss",
            "timeDisplayDontShowDistance": false,
            "targetValueId": "",
            "statesAddInput": false,
            "statesAddInputCaption": "Enter other value...",
            "showOnlyTargetValues": false,
            "readonly": true,
            "unit": "",
            "unit_zero": "",
            "unit_one": "",
            "min": "",
            "max": "",
            "step": "",
            "type": "string",
            "role": "text",
            "states": {
              "on": "Ein",
              "off": "Aus"
      "native": {},
      "_id": "smartthings.0.cbf9a2be-420b-4f59-80f6-d47727cd9727.status.switch.switch.value",
      "acl": {
        "object": 1636,
        "state": 1636,
      "ts": 1690488136289
      @djmarc75 ```
        "type": "state",
        "common": {
          "name": "",
          "type": "boolean",
          "role": "boolean",
          "write": true,
          "read": true
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "type": "state",
        "common": {
          "name": "",
          "type": "boolean",
          "role": "boolean",
          "write": true,
          "read": true
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "type": "state",
        "common": {
          "name": "value",
          "role": "text",
          "type": "string",
          "write": false,
          "read": true,
          "custom": {
            "iqontrol.0": {
              "0": "",
              "1": "",
              "2": "",
              "enabled": true,
              "invert": false,
              "confirm": false,
              "pincode": "",
              "roundDigits": 2,
              "timeFormat": "x",
              "readonly": true,
              "unit": "",
              "unit_zero": "",
              "unit_one": "",
              "min": "",
              "max": "",
              "step": "",
              "type": "string",
              "role": "text",
              "states": {
                "on": "Ein",
                "off": "Aus"
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1690488136289
      DJMarc75D
      DJMarc75D
      DJMarc75
      @vazi Jetzt versuchen wir mal einen Schuh daraus zu machen bitte:
      Du nutzt welchen Adapter? Diesen Smarthings ??
      Kann denn dieses Ledvance auch Zigbee?
      Falls ja, dann nutze den dementsprechenden Adapter (falls Du einen Zigbee-Koordinator hast)
      Der Smarthings Adapter ist ja eigentlich für SamsungDevices, wenn ich das aus der Doku richtig lese....
      Wie kommt man dann auf die Idee eine Ledvance per SamsungAdapter zu steuern ??
      Lehrling seit 1975 !!!
        @djmarc75 sagte in Steckdose mit 2 Datenpunkten für on off:
        Du nutzt welchen Adapter? Diesen Smarthings ?? JA
        Kann denn dieses Ledvance auch Zigbee? NEIN
        Über diesen Forumsbeitrag
        DJMarc75D 2 Antworten Letzte Antwort
          DJMarc75D
          DJMarc75D
          DJMarc75
          @vazi na dann bin ich da raus und Du solltest in Deinem verlinkten Beitrag mal nachfragen ;)
          Alternativ wäre auch die Suchfunktion (oben rechts - die Lupe)
          https://forum.iobroker.net/search?term=Ledvance&in=titlesposts
            @djmarc75 Danke Dir für all Deine Bemühungen und Ratschläge.
              DJMarc75D
              DJMarc75D
              DJMarc75
              @vazi sagte in Steckdose mit 2 Datenpunkten für on off:
              Noch mal zur Sicherheit nachgefragt: Die genau Bezeichnung von dem Leuchtmittel ist ??
                • P PeterL 0
                  @armilar
                  Habe es gestern so versucht. Aber ich muss beim einschalten zuerst den switch off auf false setzen und den switch on auf true mit Verzögerung.
                  Beim ausschalten mußß ich in umgekehrter Reihenfolge schalten.
                  switch on auf false ohne Verzögerung und switch off auf true mit Verzögerung.
                  Anders funktioniert es nicht.
                  MartinPM
                  MartinPM
                  MartinP
                  @peterl-0 Vielleicht ist das eine Pulsschaltung.
                  Ein True für 500 ms auf On schaltet ein, ein True für 500 ms auf Off schaltet aus.
                  Normalerweise sind beide False...
                  Wenn man keine explizite Rückmeldung über den aktuellen Zustand hat, muss man den auch noch selbst generieren...
                  • MartinPM MartinP
                    @martinp Vielen Dank für Dein Tipp.... und wie realisiere ich dies nun genau? Sorry... stehe etwas auf der Leitung vor lauter Denken... 🤕
                      @martinp
                      Dies wird vermutlich über ein Blockly realisiert?
                      Könntest Du mir helfen, wie ich diesen auf Grund meiner obigen Angaben zusammensetzen muss?
                        @martinp
                        MartinPM
                        MartinPM
                        MartinP
                        @vazi Ich bin selber blockly rookie, sorry - bevor ich Dir etwas falsches Mitgebe
                        Man muss sehen, ob man den Zustand, den die Steckdose hat irgendwo braucht. Wenn das nicht nötig ist, dann kann man ja auch einfach die AN bzw AUS Pulse auch einfach so auslösen
                        Hier habe ich einen Puls ausgelöst ( 35 Sekunden Tauch-Pumpe im Regenfass an, um die Tomaten zu wässern)
                        Hängt aber an einem Zeitplan.
                        Man könnte da vielleich einen Datenpunkt in Userdata anlegen, den man setzen und löschen kann.
                        Der könnte dann statt des Zeitplans Auslöser der beiden Aktionen die der Zeitplan klammert sein..
                        Man braucht natürlich einen Puls zum Setzen und einen Puls zum Löschen ...
                        83.9k
