  4. Steckdose mit 2 Datenpunkten für on off
    6.0k
31 Beiträge 9 Kommentatoren 3.8k Aufrufe 5 Beobachtet
    @djmarc75
    Keine Veränderung
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @vazi dann zeig mal die jeweiligen Objektdaten (Bleistift rechts anklicken) und poste die hier in Codetags
    Lehrling seit 1975 !!!
    • DJMarc75D DJMarc75
      @djmarc75 ```
        "type": "state",
        "common": {
          "name": "",
          "type": "boolean",
          "role": "boolean",
          "write": true,
          "read": true
        "native": {},
        "from": "system.adapter.smartthings.0",
        "user": "system.user.admin",
        "ts": 1690450416943,
        "_id": "smartthings.0.cbf9a2be-420b-4f59-80f6-d47727cd9727.capabilities.switch-off",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
        "type": "state",
        "common": {
          "name": "",
          "type": "boolean",
          "role": "boolean",
          "write": true,
          "read": true
        "native": {},
        "_id": "smartthings.0.cbf9a2be-420b-4f59-80f6-d47727cd9727.capabilities.switch-on",
        "acl": {
          "object": 1636,
          "state": 1636,
        "type": "state",
        "common": {
          "name": "value",
          "role": "text",
          "type": "string",
          "write": false,
          "read": true,
          "custom": {
            "iqontrol.0": {
              "0": "",
              "1": "",
              "2": "",
              "enabled": true,
              "invert": false,
              "confirm": false,
              "pincode": "",
              "roundDigits": 2,
              "timeFormat": "x",
              "timeDisplayFormat": "dddd, DD.MM.YYYY HH:mm:ss",
              "timeDisplayDontShowDistance": false,
              "targetValueId": "",
              "statesAddInput": false,
              "statesAddInputCaption": "Enter other value...",
              "showOnlyTargetValues": false,
              "readonly": true,
              "unit": "",
              "unit_zero": "",
              "unit_one": "",
              "min": "",
              "max": "",
              "step": "",
              "type": "string",
              "role": "text",
              "states": {
                "on": "Ein",
                "off": "Aus"
        "native": {},
        "_id": "smartthings.0.cbf9a2be-420b-4f59-80f6-d47727cd9727.status.switch.switch.value",
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1690488136289
        @djmarc75 ```
          "type": "state",
          "common": {
            "name": "",
            "type": "boolean",
            "role": "boolean",
            "write": true,
            "read": true
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636,
          "type": "state",
          "common": {
            "name": "",
            "type": "boolean",
            "role": "boolean",
            "write": true,
            "read": true
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636,
          "type": "state",
          "common": {
            "name": "value",
            "role": "text",
            "type": "string",
            "write": false,
            "read": true,
            "custom": {
              "iqontrol.0": {
                "0": "",
                "1": "",
                "2": "",
                "enabled": true,
                "invert": false,
                "confirm": false,
                "pincode": "",
                "roundDigits": 2,
                "timeFormat": "x",
                "readonly": true,
                "unit": "",
                "unit_zero": "",
                "unit_one": "",
                "min": "",
                "max": "",
                "step": "",
                "type": "string",
                "role": "text",
                "states": {
                  "on": "Ein",
                  "off": "Aus"
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636,
          "ts": 1690488136289
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @vazi Jetzt versuchen wir mal einen Schuh daraus zu machen bitte:
        Du nutzt welchen Adapter? Diesen Smarthings ??
        Kann denn dieses Ledvance auch Zigbee?
        Falls ja, dann nutze den dementsprechenden Adapter (falls Du einen Zigbee-Koordinator hast)
        Der Smarthings Adapter ist ja eigentlich für SamsungDevices, wenn ich das aus der Doku richtig lese....
        Wie kommt man dann auf die Idee eine Ledvance per SamsungAdapter zu steuern ??
          @djmarc75 sagte in Steckdose mit 2 Datenpunkten für on off:
          Du nutzt welchen Adapter? Diesen Smarthings ?? JA
          Kann denn dieses Ledvance auch Zigbee? NEIN
          Über diesen Forumsbeitrag
          DJMarc75D 2 Antworten Letzte Antwort
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @vazi na dann bin ich da raus und Du solltest in Deinem verlinkten Beitrag mal nachfragen ;)
            Alternativ wäre auch die Suchfunktion (oben rechts - die Lupe)
            https://forum.iobroker.net/search?term=Ledvance&in=titlesposts
              @djmarc75 Danke Dir für all Deine Bemühungen und Ratschläge.
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @vazi sagte in Steckdose mit 2 Datenpunkten für on off:
                Noch mal zur Sicherheit nachgefragt: Die genau Bezeichnung von dem Leuchtmittel ist ??
                  • P PeterL 0
                    @armilar
                    Habe es gestern so versucht. Aber ich muss beim einschalten zuerst den switch off auf false setzen und den switch on auf true mit Verzögerung.
                    Beim ausschalten mußß ich in umgekehrter Reihenfolge schalten.
                    switch on auf false ohne Verzögerung und switch off auf true mit Verzögerung.
                    Anders funktioniert es nicht.
                    MartinPM Online
                    MartinPM Online
                    MartinP
                    @peterl-0 Vielleicht ist das eine Pulsschaltung.
                    Ein True für 500 ms auf On schaltet ein, ein True für 500 ms auf Off schaltet aus.
                    Normalerweise sind beide False...
                    Wenn man keine explizite Rückmeldung über den aktuellen Zustand hat, muss man den auch noch selbst generieren...
                    • MartinPM MartinP
                      @martinp Vielen Dank für Dein Tipp.... und wie realisiere ich dies nun genau? Sorry... stehe etwas auf der Leitung vor lauter Denken... 🤕
                      • ? Offline
                        @martinp
                        Dies wird vermutlich über ein Blockly realisiert?
                        Könntest Du mir helfen, wie ich diesen auf Grund meiner obigen Angaben zusammensetzen muss?
                          @martinp
                          MartinPM Online
                          MartinPM Online
                          MartinP
                          @vazi Ich bin selber blockly rookie, sorry - bevor ich Dir etwas falsches Mitgebe
                          Man muss sehen, ob man den Zustand, den die Steckdose hat irgendwo braucht. Wenn das nicht nötig ist, dann kann man ja auch einfach die AN bzw AUS Pulse auch einfach so auslösen
                          Hier habe ich einen Puls ausgelöst ( 35 Sekunden Tauch-Pumpe im Regenfass an, um die Tomaten zu wässern)
                          Hängt aber an einem Zeitplan.
                          Man könnte da vielleich einen Datenpunkt in Userdata anlegen, den man setzen und löschen kann.
                          Der könnte dann statt des Zeitplans Auslöser der beiden Aktionen die der Zeitplan klammert sein..
                          Man braucht natürlich einen Puls zum Setzen und einen Puls zum Löschen ...
