  4. Support Adapter Energiefluss-erweitert
vis
4.6k Beiträge 206 Kommentatoren 6.5m Aufrufe 178 Beobachtet
  • A andi2055
    @skb
    ja, hätte direkt mehr Infos geben können...
    Also die Linien sind einfach schwarz und nicht animiert
    Vor dem Update hatte es noch funktioniert
    Und wie geschrieben: auch mit einer neuen Instanz probiert.
    Im Log steht Folgendes - ich sehe aber keinen Fehler
    2023-07-29 18:21:30.662 - info: energiefluss-erweitert.0 (1113) Adapter started. Loading config!
    2023-07-29 18:21:30.684 - debug: energiefluss-erweitert.0 (1113) {"basic":{"enable_grid":true,"enable_animation":false,"enable_area_catch":true,"enable_config_icon":true,"enable_last_id":false,"enable_icon_proxy":false,"height":540,"width":530,"styles":"background-color: black","font":{"family":"\"Arial\", sans-serif","size":"20","color":"#1D00FF","fill":"#FF0000","align":"middle"},"rect":{"height":100,"width":100,"corners":10},"circle":{"radius":50},"elm":{"stroke_width":5,"color":"#1500FF","fill":"#FF0000","pos_x":50,"pos_y":50},"icon":{"height":24,"width":24,"color":"#0C00FF"}},"calculation":{"battery":{"dod":0,"capacity":0,"percent":null,"charge":null,"charge_prop":false,"charge_kw":false,"discharge":null,"discharge_prop":false,"discharge_kw":false}},"animation":{"stroke":"#ffce4a","stroke_dasharray":"10 17 10 17 10 72","stroke_width":6,"animation_duration":2000,"stroke_linecap":"round","animation_timing_function":"linear"},"animation_configuration":{"dots":3,"distance":17,"length":10},"line":{"stroke_width":8,"stroke":"#000000"},"elements":{"2":{"type":"text","subType":"datasource","id":2,"pos_x":106,"pos_y":84,"color":"none","fill":"rgb(255, 206, 74)","font_family":"Arial, sans-serif","font_size":18,"degree":0,"align":"middle","text":"ID 2","unit":"W","append":"","prepend":"","source":0,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":false,"convert":false,"decimal_places":0,"subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"6":{"type":"icon","id":"6","icon":"material-symbols:solar-power","width":24,"height":24,"color":"rgb(255, 206, 74)","pos_x":"94","pos_y":"47","shadow":"","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":"","source":-1,"threshold":0},"7":{"type":"rect","id":7,"rx":10,"height":100,"width":100,"pos_x":192,"pos_y":201,"fill":"none","color":"rgb(242, 116, 44)","stroke":3,"shadow":"","frame":"_overlay","url":"","fill_value":null,"fill_type":"percent","fill_direction":90,"fill_max":null,"border_value":null,"border_type":-1,"border_direction":"cw","border_style":"round","border_max":null,"border_reverse_value":null,"border_reverse":false,"border_start":180,"source":-1,"threshold":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"9":{"type":"text","subType":"datasource","id":9,"pos_x":242,"pos_y":243,"color":"none","fill":"rgb(242, 116, 44)","font_family":"Arial, sans-serif","font_size":18,"degree":0,"align":"middle","text":"ID 9","unit":"W","append":"","prepend":"","source":4,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":false,"convert":false,"decimal_places":0,"subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"10":{"type":"text","id":10,"pos_x":108,"pos_y":115,"color":"none","fill":"rgb(255, 206, 74)","font_family":"Arial, sans-serif","font_size":14,"degree":0,"align":"middle","text":"PV","shadow":"","css_general":""},"11":{"type":"text","id":11,"pos_x":242,"pos_y":277,"color":"none","fill":"rgb(242, 116, 44)","font_family":"Arial, sans-serif","font_size":14,"degree":0,"align":"middle","text":"Verbrauch","shadow":"","css_general":""},"12":{"type":"icon","id":"12","icon":"mdi:house-city","width":24,"height":24,"color":"rgb(242, 116, 44)","pos_x":"230","pos_y":"207","shadow":"","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":"","source":1,"threshold":0},"14":{"type":"rect","id":14,"rx":10,"height":100,"width":100,"pos_x":56,"pos_y":367,"fill":"none","color":"rgba(97, 104, 122, 0.7)","stroke":3,"shadow":"","frame":"_overlay","url":"","fill_value":null,"fill_type":"percent","fill_direction":90,"fill_max":null,"border_value":null,"border_type":-1,"border_direction":"cw","border_style":"round","border_max":null,"border_reverse_value":null,"border_reverse":false,"border_start":180,"source":-1,"threshold":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"19":{"type":"text","subType":"datasource","id":19,"pos_x":106,"pos_y":409,"color":"none","fill":"rgb(190, 195, 202)","font_family":"Arial, sans-serif","font_size":18,"degree":0,"align":"middle","text":"ID 19","unit":"W","append":"","prepend":"","source":3,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":false,"convert":false,"decimal_places":0,"subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"20":{"type":"icon","id":"20","icon":"mdi:electricity-from-grid","width":24,"height":24,"color":"rgb(190, 195, 202)","pos_x":"94","pos_y":"372","shadow":"","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":"","source":-1,"threshold":0},"21":{"type":"text","id":21,"pos_x":106,"pos_y":443,"color":"none","fill":"rgb(190, 195, 202)","font_family":"Arial, sans-serif","font_size":14,"degree":0,"align":"middle","text":"Netz","shadow":"","css_general":""},"22":{"type":"rect","id":22,"rx":10,"height":100,"width":100,"pos_x":376,"pos_y":280,"fill":"none","color":"rgb(25, 207, 25)","stroke":3,"shadow":"","frame":"_overlay","url":"","fill_value":null,"fill_type":"percent","fill_direction":90,"fill_max":null,"border_value":null,"border_type":-1,"border_direction":"cw","border_style":"round","border_max":null,"border_reverse_value":null,"border_reverse":false,"border_start":180,"source":2,"threshold":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"23":{"type":"icon","id":"23","icon":"material-symbols:heat-pump-outline","width":24,"height":24,"color":"rgb(25, 207, 25)","pos_x":"413","pos_y":"286","shadow":"","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":"","source":-1,"threshold":0},"24":{"type":"text","id":24,"pos_x":425,"pos_y":356,"color":"none","fill":"rgb(25, 207, 25)","font_family":"Arial, sans-serif","font_size":14,"degree":0,"align":"middle","text":"LWP","shadow":"","css_general":""},"26":{"type":"text","subType":"datasource","id":26,"pos_x":426,"pos_y":321,"color":"none","fill":"rgb(25, 207, 25)","font_family":"Arial, sans-serif","font_size":18,"degree":0,"align":"middle","text":"ID 26","unit":"W","append":"","prepend":"","source":2,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":false,"convert":false,"decimal_places":0,"subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"28":{"type":"rect","id":28,"rx":10,"height":100,"width":100,"pos_x":372,"pos_y":123,"fill":"none","color":"rgb(37, 214, 254)","stroke":3,"shadow":"","frame":"_overlay","url":"","fill_value":null,"fill_type":-1,"fill_direction":90,"fill_max":null,"border_value":null,"border_type":-1,"border_direction":"cw","border_style":"round","border_max":null,"border_reverse_value":null,"border_reverse":false,"border_start":180,"source":1,"threshold":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"29":{"type":"icon","id":"29","icon":"mdi:house","width":24,"height":24,"color":"rgb(0, 181, 221)","pos_x":"408","pos_y":"125","shadow":"","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":"","source":-1,"threshold":0},"30":{"type":"text","id":30,"pos_x":395,"pos_y":203,"color":"none","fill":"rgb(142, 224, 227)","font_family":"Arial, sans-serif","font_size":20,"degree":0,"align":"start","text":"Haus","shadow":"","css_general":""},"33":{"type":"text","subType":"datasource","id":33,"pos_x":421,"pos_y":172,"color":"none","fill":"rgb(0, 181, 221)","font_family":"Arial, sans-serif","font_size":18,"degree":0,"align":"middle","text":"ID 33","unit":"W","append":"","prepend":"","source":1,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":false,"convert":false,"decimal_places":0,"subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"34":{"type":"circle","id":34,"radius":60,"pos_x":106,"pos_y":82,"fill":"none","color":"rgb(255, 225, 31)","stroke":3,"shadow":"","frame":"_overlay","url":"","fill_value":null,"fill_type":"-1","fill_direction":"90","fill_max":"0","border_value":null,"border_type":"-1","border_direction":"cw","border_style":"round","border_max":"0","border_reverse_value":null,"border_reverse":false,"border_start":"180","source":-1,"threshold":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""}},"defs":{"path_14_7":{"type":"def","id":"path_14_7","d":"M126 365.5 V 352.9 A 15 15 0 0 1 141 337.9 H 207 A 15 15 0 0 0 222 322.9 V 302.5","startSlot":"top_right","endSlot":"bottom_left"},"path_7_22":{"type":"def","id":"path_7_22","d":"M293.5 271 H 309.7 A 15 15 0 0 1 324.7 286 V 315 A 15 15 0 0 0 339.7 330 H 374.5","startSlot":"right_bottom","endSlot":"left"},"path_7_28":{"type":"def","id":"path_7_28","d":"M293.5 231 H 308.9 A 15 15 0 0 0 323.9 216 V 188 A 15 15 0 0 1 338.9 173 H 370.5","startSlot":"right_top","endSlot":"left"},"path_7_34":{"type":"def","id":"path_7_34","d":"M190.5 251 H 177.9 H 141.52120859954013 A 15 15 0 0 1 126.52120859954013 236 V 139.8815572471545","startSlot":"left","endSlot":"bottom_right"},"path_34_14":{"type":"def","id":"path_34_14","d":"M106 143.5 V 365.5","startSlot":"bottom","endSlot":"top"}},"lines":{"line_path_14_7":{"type":"line","id":"line_path_14_7","href":"#path_14_7","color":"rgb(0, 0, 0)","shadow":""},"line_path_7_22":{"type":"line","id":"line_path_7_22","href":"#path_7_22","color":"rgb(0, 0, 0)","shadow":""},"line_path_7_28":{"type":"line","id":"line_path_7_28","href":"#path_7_28","color":"rgb(0, 0, 0)","shadow":""},"line_path_7_34":{"type":"line","id":"line_path_7_34","href":"#path_7_34","color":"rgb(0, 0, 0)","shadow":""},"line_path_34_14":{"type":"line","id":"line_path_34_14","href":"#path_34_14","color":"rgb(0, 0, 0)","shadow":""}},"animations":{"anim_path_14_7":{"type":"animation","id":"anim_path_14_7","href":"#path_14_7","color":"rgb(255, 206, 74)","source":3,"threshold":10,"animation_properties":"positive","animation_option":false,"dots":0,"duration":0,"power":0,"animation_type":-1,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_7_22":{"type":"animation","id":"anim_path_7_22","href":"#path_7_22","color":"rgb(255, 206, 74)","source":2,"threshold":5,"animation_properties":"positive","animation_option":false,"dots":0,"duration":0,"power":0,"animation_type":-1,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_7_28":{"type":"animation","id":"anim_path_7_28","href":"#path_7_28","color":"rgb(255, 206, 74)","source":1,"threshold":5,"animation_properties":"positive","animation_option":false,"dots":0,"duration":0,"power":0,"animation_type":"dots","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_7_34":{"type":"animation","id":"anim_path_7_34","href":"#path_7_34","color":"rgb(255, 206, 74)","source":"2","threshold":"","animation_properties":"positive","animation_option":false,"dots":0,"duration":0,"power":0,"animation_type":"-1","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_34_14":{"type":"animation","id":"anim_path_34_14","href":"#path_34_14","color":"rgb(255, 206, 74)","source":"3","threshold":"","animation_properties":"negative","animation_option":false,"dots":0,"duration":0,"power":0,"animation_type":"-1","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""}},"datasources":{"0":{"source":"alias.0.PV.30775_Measurement_GridMs_TotW","alias":"PV_Power"},"1":{"source":"alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung","alias":"Haus_Power"},"2":{"source":"alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung","alias":"LWP_Power"},"3":{"source":"alias.0.Stromzähler.Stromzähler_Haupt.Power_total","alias":"Haupt_Power"},"4":{"source":"alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung","alias":"Verbrauch_gesamt"}}}
    2023-07-29 18:21:30.685 - debug: energiefluss-erweitert.0 (1113) Datasource: {"source":"alias.0.PV.30775_Measurement_GridMs_TotW","alias":"PV_Power"}
    2023-07-29 18:21:30.705 - debug: energiefluss-erweitert.0 (1113) Datasource: {"source":"alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung","alias":"Haus_Power"}
    2023-07-29 18:21:30.716 - debug: energiefluss-erweitert.0 (1113) Datasource: {"source":"alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung","alias":"LWP_Power"}
    2023-07-29 18:21:30.729 - debug: energiefluss-erweitert.0 (1113) Datasource: {"source":"alias.0.Stromzähler.Stromzähler_Haupt.Power_total","alias":"Haupt_Power"}
    2023-07-29 18:21:30.743 - debug: energiefluss-erweitert.0 (1113) Datasource: {"source":"alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung","alias":"Verbrauch_gesamt"}
    2023-07-29 18:21:30.762 - debug: energiefluss-erweitert.0 (1113) Source for Element: 2 is: 0 Plain: alias.0.PV.30775_Measurement_GridMs_TotW
    2023-07-29 18:21:30.776 - debug: energiefluss-erweitert.0 (1113) Source for Element: 9 is: 4 Plain: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung
    2023-07-29 18:21:30.793 - debug: energiefluss-erweitert.0 (1113) Source for Element: 12 is: 1 Plain: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung
    2023-07-29 18:21:30.812 - debug: energiefluss-erweitert.0 (1113) Source for Element: 19 is: 3 Plain: alias.0.Stromzähler.Stromzähler_Haupt.Power_total
    2023-07-29 18:21:30.828 - debug: energiefluss-erweitert.0 (1113) Source for Element: 22 is: 2 Plain: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung
    2023-07-29 18:21:30.853 - debug: energiefluss-erweitert.0 (1113) Source for Element: 26 is: 2 Plain: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung
    2023-07-29 18:21:30.867 - debug: energiefluss-erweitert.0 (1113) Source for Element: 28 is: 1 Plain: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung
    2023-07-29 18:21:30.881 - debug: energiefluss-erweitert.0 (1113) Source for Element: 33 is: 1 Plain: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung
    2023-07-29 18:21:30.892 - debug: energiefluss-erweitert.0 (1113) Animation for Source: 3 is: anim_path_14_7
    2023-07-29 18:21:30.893 - debug: energiefluss-erweitert.0 (1113) Animation for Source: 2 is: anim_path_7_22
    2023-07-29 18:21:30.893 - debug: energiefluss-erweitert.0 (1113) Animation for Source: 1 is: anim_path_7_28
    2023-07-29 18:21:30.894 - debug: energiefluss-erweitert.0 (1113) Animation for Source: 2 is: anim_path_7_34
    2023-07-29 18:21:30.894 - debug: energiefluss-erweitert.0 (1113) Animation for Source: 3 is: anim_path_34_14
    2023-07-29 18:21:30.894 - debug: energiefluss-erweitert.0 (1113) CSS: {}
    2023-07-29 18:21:30.895 - debug: energiefluss-erweitert.0 (1113) Settings: {"2":{"threshold":0,"calculate_kw":false,"decimal_places":0,"convert":false,"type":"text","source_option":-1,"source_display":"value","subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"9":{"threshold":0,"calculate_kw":false,"decimal_places":0,"convert":false,"type":"text","source_option":-1,"source_display":"value","subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"12":{"threshold":0,"type":"icon","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"19":{"threshold":0,"calculate_kw":false,"decimal_places":0,"convert":false,"type":"text","source_option":-1,"source_display":"value","subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"22":{"threshold":0,"type":"rect","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"26":{"threshold":0,"calculate_kw":false,"decimal_places":0,"convert":false,"type":"text","source_option":-1,"source_display":"value","subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"28":{"threshold":0,"type":"rect","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"33":{"threshold":0,"calculate_kw":false,"decimal_places":0,"convert":false,"type":"text","source_option":-1,"source_display":"value","subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_14_7":{"properties":"positive","option":false,"threshold":10,"type":-1,"duration":0,"power":0,"dots":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_7_22":{"properties":"positive","option":false,"threshold":5,"type":-1,"duration":0,"power":0,"dots":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_7_28":{"properties":"positive","option":false,"threshold":5,"type":"dots","duration":0,"power":0,"dots":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_7_34":{"properties":"positive","option":false,"threshold":"","type":"-1","duration":0,"power":0,"dots":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_34_14":{"properties":"negative","option":false,"threshold":"","type":"-1","duration":0,"power":0,"dots":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""}}
    2023-07-29 18:21:30.895 - debug: energiefluss-erweitert.0 (1113) Initial Values: {"2":"1246","9":"393","19":"-849","26":"24","33":"373"}
    2023-07-29 18:21:30.896 - debug: energiefluss-erweitert.0 (1113) Initial Fill-Values: {"12":369,"22":24,"28":369}
    2023-07-29 18:21:30.896 - debug: energiefluss-erweitert.0 (1113) Sources: {"alias.0.PV.30775_Measurement_GridMs_TotW":{"id":0,"elmSources":["2"],"elmAnimations":[]},"alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung":{"id":1,"elmSources":["12","28","33"],"elmAnimations":["anim_path_7_28"]},"alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung":{"id":2,"elmSources":["22","26"],"elmAnimations":["anim_path_7_22","anim_path_7_34"]},"alias.0.Stromzähler.Stromzähler_Haupt.Power_total":{"id":3,"elmSources":["19"],"elmAnimations":["anim_path_14_7","anim_path_34_14"]},"alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung":{"id":4,"elmSources":["9"],"elmAnimations":[]}}
    2023-07-29 18:21:30.896 - debug: energiefluss-erweitert.0 (1113) RAW-Values: {"2":1246,"9":393,"19":-849,"26":24,"33":373}
    2023-07-29 18:21:30.897 - debug: energiefluss-erweitert.0 (1113) RAW-Source-Values: {"0":1246,"1":369,"2":24,"3":-849,"4":393}
    2023-07-29 18:21:30.899 - info: energiefluss-erweitert.0 (1113) Configuration loaded!
    2023-07-29 18:21:30.899 - info: energiefluss-erweitert.0 (1113) Requesting the following states: energiefluss-erweitert.0.configuration,alias.0.PV.30775_Measurement_GridMs_TotW,alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung,alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung,alias.0.Stromzähler.Stromzähler_Haupt.Power_total,alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung
    2023-07-29 18:21:31.296 - debug: energiefluss-erweitert.0 (1113) {"0":1246,"1":369,"2":24,"3":-849,"4":393}
    2023-07-29 18:21:31.297 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 22 found! Applying Settings!
    2023-07-29 18:21:31.297 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 26 found! Applying Settings!
    2023-07-29 18:21:31.298 - debug: energiefluss-erweitert.0 (1113) Threshold for: 26 is: 0
    2023-07-29 18:21:31.298 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung! Applying!
    2023-07-29 18:21:31.299 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_22 found! Applying Settings!
    2023-07-29 18:21:31.299 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:31.299 - debug: energiefluss-erweitert.0 (1113) Value: 24 is greater than Threshold: 5 Applying Animation!
    2023-07-29 18:21:31.300 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_34 found! Applying Settings!
    2023-07-29 18:21:31.300 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:31.300 - debug: energiefluss-erweitert.0 (1113) Value: 24 is greater than Threshold: Applying Animation!
    2023-07-29 18:21:31.301 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung with Value: 24 belongs to Elements: 22,26
    2023-07-29 18:21:31.696 - debug: energiefluss-erweitert.0 (1113) {"0":1246,"1":369,"2":24,"3":-847,"4":393}
    2023-07-29 18:21:31.697 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 19 found! Applying Settings!
    2023-07-29 18:21:31.698 - debug: energiefluss-erweitert.0 (1113) Threshold for: 19 is: 0
    2023-07-29 18:21:31.699 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Stromzähler_Haupt.Power_total! Applying!
    2023-07-29 18:21:31.700 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_14_7 found! Applying Settings!
    2023-07-29 18:21:31.701 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:31.702 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_34_14 found! Applying Settings!
    2023-07-29 18:21:31.703 - debug: energiefluss-erweitert.0 (1113) Animation has a negative factor!
    2023-07-29 18:21:31.704 - debug: energiefluss-erweitert.0 (1113) Value: -847 is greater than Threshold: 0 Applying Animation!
    2023-07-29 18:21:31.705 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Stromzähler_Haupt.Power_total with Value: -847 belongs to Elements: 19
    2023-07-29 18:21:31.716 - debug: energiefluss-erweitert.0 (1113) {"0":1246,"1":375,"2":24,"3":-847,"4":393}
    2023-07-29 18:21:31.717 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 12 found! Applying Settings!
    2023-07-29 18:21:31.718 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 28 found! Applying Settings!
    2023-07-29 18:21:31.719 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 33 found! Applying Settings!
    2023-07-29 18:21:31.720 - debug: energiefluss-erweitert.0 (1113) Threshold for: 33 is: 0
    2023-07-29 18:21:31.720 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung! Applying!
    2023-07-29 18:21:31.721 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_28 found! Applying Settings!
    2023-07-29 18:21:31.722 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:31.723 - debug: energiefluss-erweitert.0 (1113) Value: 375 is greater than Threshold: 5 Applying Animation!
    2023-07-29 18:21:31.723 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung with Value: 375 belongs to Elements: 12,28,33
    2023-07-29 18:21:31.725 - debug: energiefluss-erweitert.0 (1113) {"0":1246,"1":375,"2":24,"3":-847,"4":399}
    2023-07-29 18:21:31.726 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 9 found! Applying Settings!
    2023-07-29 18:21:31.726 - debug: energiefluss-erweitert.0 (1113) Threshold for: 9 is: 0
    2023-07-29 18:21:31.727 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung! Applying!
    2023-07-29 18:21:31.727 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung with Value: 399 belongs to Elements: 9
    2023-07-29 18:21:32.075 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":375,"2":24,"3":-847,"4":399}
    2023-07-29 18:21:32.075 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 2 found! Applying Settings!
    2023-07-29 18:21:32.076 - debug: energiefluss-erweitert.0 (1113) Threshold for: 2 is: 0
    2023-07-29 18:21:32.076 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.PV.30775_Measurement_GridMs_TotW! Applying!
    2023-07-29 18:21:32.076 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.PV.30775_Measurement_GridMs_TotW with Value: 1236 belongs to Elements: 2
    2023-07-29 18:21:32.088 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":365,"2":24,"3":-847,"4":399}
    2023-07-29 18:21:32.088 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 12 found! Applying Settings!
    2023-07-29 18:21:32.089 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 28 found! Applying Settings!
    2023-07-29 18:21:32.089 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 33 found! Applying Settings!
    2023-07-29 18:21:32.089 - debug: energiefluss-erweitert.0 (1113) Threshold for: 33 is: 0
    2023-07-29 18:21:32.090 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung! Applying!
    2023-07-29 18:21:32.090 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_28 found! Applying Settings!
    2023-07-29 18:21:32.090 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:32.091 - debug: energiefluss-erweitert.0 (1113) Value: 365 is greater than Threshold: 5 Applying Animation!
    2023-07-29 18:21:32.091 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung with Value: 365 belongs to Elements: 12,28,33
    2023-07-29 18:21:32.097 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":365,"2":24,"3":-847,"4":389}
    2023-07-29 18:21:32.098 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 9 found! Applying Settings!
    2023-07-29 18:21:32.098 - debug: energiefluss-erweitert.0 (1113) Threshold for: 9 is: 0
    2023-07-29 18:21:32.099 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung! Applying!
    2023-07-29 18:21:32.099 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung with Value: 389 belongs to Elements: 9
    2023-07-29 18:21:32.703 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":365,"2":24,"3":-848,"4":389}
    2023-07-29 18:21:32.703 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 19 found! Applying Settings!
    2023-07-29 18:21:32.704 - debug: energiefluss-erweitert.0 (1113) Threshold for: 19 is: 0
    2023-07-29 18:21:32.705 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Stromzähler_Haupt.Power_total! Applying!
    2023-07-29 18:21:32.706 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_14_7 found! Applying Settings!
    2023-07-29 18:21:32.706 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:32.707 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_34_14 found! Applying Settings!
    2023-07-29 18:21:32.708 - debug: energiefluss-erweitert.0 (1113) Animation has a negative factor!
    2023-07-29 18:21:32.708 - debug: energiefluss-erweitert.0 (1113) Value: -848 is greater than Threshold: 0 Applying Animation!
    2023-07-29 18:21:32.709 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Stromzähler_Haupt.Power_total with Value: -848 belongs to Elements: 19
    2023-07-29 18:21:32.718 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":364,"2":24,"3":-848,"4":389}
    2023-07-29 18:21:32.719 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 12 found! Applying Settings!
    2023-07-29 18:21:32.719 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 28 found! Applying Settings!
    2023-07-29 18:21:32.720 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 33 found! Applying Settings!
    2023-07-29 18:21:32.721 - debug: energiefluss-erweitert.0 (1113) Threshold for: 33 is: 0
    2023-07-29 18:21:32.722 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung! Applying!
    2023-07-29 18:21:32.723 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_28 found! Applying Settings!
    2023-07-29 18:21:32.724 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:32.725 - debug: energiefluss-erweitert.0 (1113) Value: 364 is greater than Threshold: 5 Applying Animation!
    2023-07-29 18:21:32.727 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung with Value: 364 belongs to Elements: 12,28,33
    2023-07-29 18:21:32.741 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":364,"2":24,"3":-848,"4":388}
    2023-07-29 18:21:32.743 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 9 found! Applying Settings!
    2023-07-29 18:21:32.744 - debug: energiefluss-erweitert.0 (1113) Threshold for: 9 is: 0
    2023-07-29 18:21:32.745 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung! Applying!
    2023-07-29 18:21:32.746 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung with Value: 388 belongs to Elements: 9
    2023-07-29 18:21:33.568 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":364,"2":24,"3":-848,"4":388}
    2023-07-29 18:21:33.570 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 22 found! Applying Settings!
    2023-07-29 18:21:33.571 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 26 found! Applying Settings!
    2023-07-29 18:21:33.571 - debug: energiefluss-erweitert.0 (1113) Threshold for: 26 is: 0
    2023-07-29 18:21:33.572 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung! Applying!
    2023-07-29 18:21:33.573 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_22 found! Applying Settings!
    2023-07-29 18:21:33.573 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:33.574 - debug: energiefluss-erweitert.0 (1113) Value: 24 is greater than Threshold: 5 Applying Animation!
    2023-07-29 18:21:33.575 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_34 found! Applying Settings!
    2023-07-29 18:21:33.575 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:33.576 - debug: energiefluss-erweitert.0 (1113) Value: 24 is greater than Threshold: Applying Animation!
    2023-07-29 18:21:33.577 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung with Value: 24 belongs to Elements: 22,26
    2023-07-29 18:21:33.707 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":364,"2":24,"3":-847,"4":388}
    2023-07-29 18:21:33.707 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 19 found! Applying Settings!
    2023-07-29 18:21:33.708 - debug: energiefluss-erweitert.0 (1113) Threshold for: 19 is: 0
    2023-07-29 18:21:33.709 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Stromzähler_Haupt.Power_total! Applying!
    2023-07-29 18:21:33.709 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_14_7 found! Applying Settings!
    2023-07-29 18:21:33.710 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:33.710 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_34_14 found! Applying Settings!
    2023-07-29 18:21:33.711 - debug: energiefluss-erweitert.0 (1113) Animation has a negative factor!
    2023-07-29 18:21:33.712 - debug: energiefluss-erweitert.0 (1113) Value: -847 is greater than Threshold: 0 Applying Animation!
    2023-07-29 18:21:33.712 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Stromzähler_Haupt.Power_total with Value: -847 belongs to Elements: 19
    2023-07-29 18:21:33.721 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":365,"2":24,"3":-847,"4":388}
    2023-07-29 18:21:33.722 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 12 found! Applying Settings!
    2023-07-29 18:21:33.723 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 28 found! Applying Settings!
    2023-07-29 18:21:33.723 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 33 found! Applying Settings!
    2023-07-29 18:21:33.724 - debug: energiefluss-erweitert.0 (1113) Threshold for: 33 is: 0
    2023-07-29 18:21:33.724 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung! Applying!
    2023-07-29 18:21:33.725 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_28 found! Applying Settings!
    2023-07-29 18:21:33.726 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:33.726 - debug: energiefluss-erweitert.0 (1113) Value: 365 is greater than Threshold: 5 Applying Animation!
    2023-07-29 18:21:33.727 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung with Value: 365 belongs to Elements: 12,28,33
    2023-07-29 18:21:33.734 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":365,"2":24,"3":-847,"4":389}
    2023-07-29 18:21:33.734 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 9 found! Applying Settings!
    2023-07-29 18:21:33.735 - debug: energiefluss-erweitert.0 (1113) Threshold for: 9 is: 0
    2023-07-29 18:21:33.736 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung! Applying!
    2023-07-29 18:21:33.736 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung with Value: 389 belongs to Elements: 9
    2023-07-29 18:21:34.754 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":365,"2":24,"3":2049,"4":389}
    2023-07-29 18:21:34.755 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 19 found! Applying Settings!
    2023-07-29 18:21:34.756 - debug: energiefluss-erweitert.0 (1113) Threshold for: 19 is: 0
    2023-07-29 18:21:34.756 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Stromzähler_Haupt.Power_total! Applying!
    2023-07-29 18:21:34.757 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_14_7 found! Applying Settings!
    2023-07-29 18:21:34.757 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:34.758 - debug: energiefluss-erweitert.0 (1113) Value: 2049 is greater than Threshold: 10 Applying Animation!
    2023-07-29 18:21:34.759 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_34_14 found! Applying Settings!
    2023-07-29 18:21:34.759 - debug: energiefluss-erweitert.0 (1113) Animation has a negative factor!
    2023-07-29 18:21:34.760 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Stromzähler_Haupt.Power_total with Value: 2049 belongs to Elements: 19
    2023-07-29 18:21:34.767 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":3261,"2":24,"3":2049,"4":389}
    2023-07-29 18:21:34.768 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 12 found! Applying Settings!
    2023-07-29 18:21:34.769 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 28 found! Applying Settings!
    2023-07-29 18:21:34.770 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 33 found! Applying Settings!
    2023-07-29 18:21:34.771 - debug: energiefluss-erweitert.0 (1113) Threshold for: 33 is: 0
    2023-07-29 18:21:34.771 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung! Applying!
    2023-07-29 18:21:34.772 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_28 found! Applying Settings!
    2023-07-29 18:21:34.772 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:34.773 - debug: energiefluss-erweitert.0 (1113) Value: 3261 is greater than Threshold: 5 Applying Animation!
    2023-07-29 18:21:34.774 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung with Value: 3261 belongs to Elements: 12,28,33
    2023-07-29 18:21:34.780 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":3261,"2":24,"3":2049,"4":3285}
    2023-07-29 18:21:34.781 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 9 found! Applying Settings!
    2023-07-29 18:21:34.782 - debug: energiefluss-erweitert.0 (1113) Threshold for: 9 is: 0
    2023-07-29 18:21:34.782 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung! Applying!
    2023-07-29 18:21:34.783 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung with Value: 3285 belongs to Elements: 9
    2023-07-29 18:21:35.702 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":3261,"2":24,"3":2423,"4":3285}
    2023-07-29 18:21:35.703 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 19 found! Applying Settings!
    2023-07-29 18:21:35.703 - debug: energiefluss-erweitert.0 (1113) Threshold for: 19 is: 0
    2023-07-29 18:21:35.704 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Stromzähler_Haupt.Power_total! Applying!
    2023-07-29 18:21:35.704 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_14_7 found! Applying Settings!
    2023-07-29 18:21:35.705 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:35.706 - debug: energiefluss-erweitert.0 (1113) Value: 2423 is greater than Threshold: 10 Applying Animation!
    2023-07-29 18:21:35.706 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_34_14 found! Applying Settings!
    2023-07-29 18:21:35.707 - debug: energiefluss-erweitert.0 (1113) Animation has a negative factor!
    2023-07-29 18:21:35.707 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Stromzähler_Haupt.Power_total with Value: 2423 belongs to Elements: 19
    2023-07-29 18:21:35.728 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":3635,"2":24,"3":2423,"4":3285}
    2023-07-29 18:21:35.729 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 12 found! Applying Settings!
    2023-07-29 18:21:35.730 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 28 found! Applying Settings!
    2023-07-29 18:21:35.730 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 33 found! Applying Settings!
    2023-07-29 18:21:35.731 - debug: energiefluss-erweitert.0 (1113) Threshold for: 33 is: 0
    2023-07-29 18:21:35.732 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung! Applying!
    2023-07-29 18:21:35.732 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_28 found! Applying Settings!
    2023-07-29 18:21:35.733 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:35.734 - debug: energiefluss-erweitert.0 (1113) Value: 3635 is greater than Threshold: 5 Applying Animation!
    2023-07-29 18:21:35.734 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung with Value: 3635 belongs to Elements: 12,28,33
    2023-07-29 18:21:35.741 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":3635,"2":24,"3":2423,"4":3659}
    2023-07-29 18:21:35.742 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 9 found! Applying Settings!
    2023-07-29 18:21:35.743 - debug: energiefluss-erweitert.0 (1113) Threshold for: 9 is: 0
    2023-07-29 18:21:35.744 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung! Applying!
    2023-07-29 18:21:35.744 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung with Value: 3659 belongs to Elements: 9
    2023-07-29 18:21:35.852 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":3635,"2":24,"3":2423,"4":3659}
    2023-07-29 18:21:35.852 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 22 found! Applying Settings!
    2023-07-29 18:21:35.853 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 26 found! Applying Settings!
    2023-07-29 18:21:35.853 - debug: energiefluss-erweitert.0 (1113) Threshold for: 26 is: 0
    2023-07-29 18:21:35.854 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung! Applying!
    2023-07-29 18:21:35.854 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_22 found! Applying Settings!
    2023-07-29 18:21:35.855 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:35.855 - debug: energiefluss-erweitert.0 (1113) Value: 24 is greater than Threshold: 5 Applying Animation!
    2023-07-29 18:21:35.856 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_34 found! Applying Settings!
    2023-07-29 18:21:35.856 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
    2023-07-29 18:21:35.857 - debug: energiefluss-erweitert.0 (1113) Value: 24 is greater than Threshold: Applying Animation!
    2023-07-29 18:21:35.857 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung with Value: 24 belongs to Elements: 22,26
    Bei der Objetauswahl kann ich aus dem Alias-Ast nicht alles wählen, weil die standardmäßig als Channel angelegt werden vom Alias-Manager Adapter. Da fehlt also die Ebene mit den Objekt-Werten darunter.
    Im Objektbaum sieht das so aus:
    Danke für deine Hilfe!
    SKBS Offline
    SKBS Offline
    SKB
    #1009
    @andi2055 Mit den Alias'en schaue ich mir an.
    Bekommst Du Fehler in der Browserkonsole mit F12?
    Welchen Browser verwendest Du?
    Der Adapter schaltet die Animation richtig ein, wie ich das sehe. Sie wird wohl nicht auf die Linie angewendet.
    • SKBS SKB
      andi2055
      #1010
      @skb
      Ausprobiert mit aktuellem Chrome & FF
      Chrome:
      FF:
      Attribut undefined? Welches? Muss ich irgendwas noch ausfüllen in der Config was derzeit leer/0 ist?
      SKBS 1 Antwort Letzte Antwort
      • A andi2055
        @skb
        Chrome:
        FF:
        SKBS Offline
        SKBS Offline
        SKB
        #1011
        @andi2055 Chrome ist etwas empfindlicher. Ist aber nicht tragisch.
        Firefox meldet den 'richtigen' Fehler.
        Die Anzeige wird nicht 'geupdated'.
        Wie sieht der Inhalt von 'data' unterhalb Energiefluss-erweitert aus?
        • SKBS SKB
          andi2055
          #1012
          @skb
            "values": {
              "2": "0",
              "9": "388",
              "19": "388",
              "26": "53",
              "33": "335"
            "unit": {
              "2": "W",
              "9": "W",
              "19": "W",
              "26": "W",
              "33": "W"
            "animations": {
              "anim_path_14_7": true,
              "anim_path_34_14": false,
              "anim_path_7_28": true,
              "anim_path_7_22": true,
              "anim_path_7_34": true
            "fillValues": {
              "12": 335,
              "22": 53,
              "28": 335
            "animationProperties": {
              "anim_path_14_7": {
                "option": ""
              "anim_path_34_14": {},
              "anim_path_7_28": {
                "type": "dots",
                "stroke": "",
                "option": ""
              "anim_path_7_22": {
                "option": ""
              "anim_path_7_34": {
                "option": ""
            "prepend": {
              "2": "",
              "9": "",
              "19": "",
              "26": "",
              "33": ""
            "append": {
              "2": "",
              "9": "",
              "19": "",
              "26": "",
              "33": ""
            "css": {
              "2": {
                "actPos": "",
                "inactPos": " ",
                "actNeg": "",
                "inactNeg": " "
              "9": {
                "actPos": "",
                "inactPos": "",
                "actNeg": "",
                "inactNeg": ""
              "12": {
                "actPos": "",
                "inactPos": "",
                "actNeg": "",
                "inactNeg": ""
              "19": {
                "actPos": "",
                "inactPos": "",
                "actNeg": "",
                "inactNeg": ""
              "22": {
                "actPos": "",
                "inactPos": "",
                "actNeg": "",
                "inactNeg": ""
              "26": {
                "actPos": "",
                "inactPos": "",
                "actNeg": "",
                "inactNeg": ""
              "28": {
                "actPos": "",
                "inactPos": "",
                "actNeg": "",
                "inactNeg": ""
              "33": {
                "actPos": "",
                "inactPos": "",
                "actNeg": "",
                "inactNeg": ""
              "anim_path_14_7": {
                "actPos": "",
                "inactPos": "",
                "actNeg": "",
                "inactNeg": ""
                "actPos": "",
                "inactPos": "",
                "actNeg": "",
                "inactNeg": ""
              "anim_path_7_28": {
                "actPos": "",
                "inactPos": "",
                "actNeg": "",
                "inactNeg": ""
              "anim_path_7_22": {
                "actPos": "",
                "inactPos": "",
                "actNeg": "",
                "inactNeg": ""
              "anim_path_7_34": {
                "actPos": "",
                "inactPos": "",
                "actNeg": "",
                "inactNeg": ""
          • A andi2055
            @skb
              "values": {
                "2": "0",
                "9": "388",
                "19": "388",
                "26": "53",
                "33": "335"
              "unit": {
                "2": "W",
                "9": "W",
                "19": "W",
                "26": "W",
                "33": "W"
              "animations": {
              "fillValues": {
                "12": 335,
                "22": 53,
                "28": 335
                "anim_path_14_7": {
                  "option": ""
                "anim_path_7_28": {
                  "type": "dots",
                  "stroke": "",
                  "option": ""
                "anim_path_7_22": {
                  "option": ""
                "anim_path_7_34": {
                  "option": ""
              "prepend": {
                "2": "",
                "9": "",
                "19": "",
                "26": "",
                "33": ""
              "append": {
                "2": "",
                "9": "",
                "19": "",
                "26": "",
                "33": ""
              "css": {
                "2": {
                  "actPos": "",
                  "inactPos": " ",
                  "actNeg": "",
                  "inactNeg": " "
                "9": {
                  "actPos": "",
                  "inactPos": "",
                  "actNeg": "",
                  "inactNeg": ""
                "12": {
                  "actPos": "",
                  "inactPos": "",
                  "actNeg": "",
                  "inactNeg": ""
                "19": {
                  "actPos": "",
                  "inactPos": "",
                  "actNeg": "",
                  "inactNeg": ""
                "22": {
                  "actPos": "",
                  "inactPos": "",
                  "actNeg": "",
                  "inactNeg": ""
                "26": {
                  "actPos": "",
                  "inactPos": "",
                  "actNeg": "",
                  "inactNeg": ""
                "28": {
                  "actPos": "",
                  "inactPos": "",
                  "actNeg": "",
                  "inactNeg": ""
                "33": {
                  "actPos": "",
                  "inactPos": "",
                  "actNeg": "",
                  "inactNeg": ""
                "anim_path_14_7": {
                  "actPos": "",
                  "inactPos": "",
                  "actNeg": "",
                  "inactNeg": ""
                  "actPos": "",
                  "inactPos": "",
                  "actNeg": "",
                  "inactNeg": ""
                "anim_path_7_28": {
                  "actPos": "",
                  "inactPos": "",
                  "actNeg": "",
                  "inactNeg": ""
                "anim_path_7_22": {
                  "actPos": "",
                  "inactPos": "",
                  "actNeg": "",
                  "inactNeg": ""
                "anim_path_7_34": {
                  "actPos": "",
                  "inactPos": "",
                  "actNeg": "",
                  "inactNeg": ""
            SKBS Offline
            SKBS Offline
            SKB
            #1013
            @andi2055
            Diese Animation hat keinen Inhalt. Kannst Du hier mal die Einstellungen prüfen?
            Ich stelle die Fehlerausgabe später einmal um, dann können wir besser sehen, wo es klemmt.
            Melde mich dann zurück.
            • SKBS SKB
              @andi2055
              andi2055
              #1014
              @skb
              Hatte "Animieren wenn negativ" dort gesetzt. Sonst eigentlich kein Unterschied.
              Sieht jetzt so aus. Aber immer noch Fehler
                    "option": ""
              Ich habe das Problem ja auch mit meiner neu erzeugten Instanz und meinem Mini-Testfall:
                "basic": {
                  "enable_grid": true,
                  "enable_animation": false,
                  "enable_area_catch": true,
                  "enable_config_icon": true,
                  "enable_last_id": false,
                  "enable_icon_proxy": false,
                  "height": 540,
                  "width": 530,
                  "styles": "",
                  "font": {
                    "family": "\"Arial\", sans-serif",
                    "size": "20",
                    "color": "",
                    "fill": "",
                    "align": "middle"
                  "rect": {
                    "height": 100,
                    "width": 100,
                    "corners": 10
                  "circle": {
                    "radius": 50
                  "elm": {
                    "stroke_width": 5,
                    "color": "",
                    "fill": "",
                    "pos_x": 50,
                    "pos_y": 50
                  "icon": {
                    "height": 24,
                    "width": 24,
                    "color": ""
                "calculation": {
                  "battery": {
                    "dod": 0,
                    "capacity": 0,
                    "percent": -1,
                    "charge": -1,
                    "charge_prop": false,
                    "charge_kw": false,
                    "discharge": -1,
                    "discharge_prop": false,
                    "discharge_kw": false
                "animation": {
                  "stroke": "#ffce4a",
                  "stroke_dasharray": "10 17 10 17 10  72",
                  "stroke_width": "6",
                  "animation_duration": "2000",
                  "stroke_linecap": "round",
                  "animation_timing_function": "linear"
                "animation_configuration": {
                  "dots": "3",
                  "distance": "17",
                  "length": "10"
                "line": {
                  "stroke_width": "8",
                  "stroke": "#000000"
                "elements": {
                  "2": {
                    "type": "text",
                    "subType": "datasource",
                    "id": 2,
                    "pos_x": 216,
                    "pos_y": 42,
                    "color": "none",
                    "fill": "rgb(255, 206, 74)",
                    "font_family": "Arial, sans-serif",
                    "font_size": 18,
                    "degree": 0,
                    "align": "middle",
                    "text": "ID 2",
                    "unit": "W",
                    "append": "",
                    "prepend": "",
                    "source": 1,
                    "source_option": -1,
                    "source_display": "value",
                    "shadow": "",
                    "threshold": 0,
                    "calculate_kw": false,
                    "convert": false,
                    "decimal_places": 2,
                    "subtract": [
                      -1
                    "css_general": "",
                    "css_active_positive": "",
                    "css_inactive_positive": "",
                    "css_active_negative": "",
                    "css_inactive_negative": ""
                  "5": {
                    "type": "rect",
                    "id": 5,
                    "rx": 10,
                    "height": 100,
                    "width": 100,
                    "pos_x": 167,
                    "pos_y": 2,
                    "fill": "none",
                    "color": "rgb(255, 206, 74)",
                    "stroke": 2,
                    "shadow": "rgba(0,0,0,0.7)",
                    "frame": "_overlay",
                    "url": "",
                    "fill_value": null,
                    "fill_type": "percent",
                    "fill_direction": 90,
                    "fill_max": null,
                    "border_value": null,
                    "border_type": -1,
                    "border_direction": "cw",
                    "border_style": "round",
                    "border_max": null,
                    "border_reverse_value": null,
                    "border_reverse": false,
                    "border_start": 180,
                    "source": -1,
                    "threshold": 0,
                    "css_general": "",
                  "6": {
                    "type": "icon",
                    "id": "6",
                    "icon": "mdi:solar-panel",
                    "width": 24,
                    "height": 24,
                    "color": "rgba(0, 0, 0, 0.7)",
                    "pos_x": "205",
                    "pos_y": "6",
                    "shadow": "",
                    "css_general": "",
                    "css_inactive_negative": "",
                    "source": -1,
                    "threshold": 0
                  "7": {
                    "type": "rect",
                    "id": 7,
                    "rx": 10,
                    "height": 100,
                    "width": 100,
                    "pos_x": 407,
                    "pos_y": 212,
                    "fill": "none",
                    "color": "rgb(0, 181, 221)",
                    "stroke": 2,
                    "url": "",
                    "fill_value": null,
                    "fill_max": null,
                    "border_type": -1,
                    "border_max": null,
                    "source": -1,
                    "threshold": 0,
                    "css_general": "",
                  "9": {
                    "type": "text",
                    "id": 9,
                    "pos_x": 457,
                    "pos_y": 254,
                    "color": "none",
                    "fill": "rgb(0, 181, 221)",
                    "font_size": 18,
                    "degree": 0,
                    "align": "middle",
                    "text": "ID 9",
                    "unit": "W",
                    "append": "",
                    "prepend": "",
                    "source": 1,
                    "shadow": "",
                    "threshold": 0,
                    "convert": false,
                    "subtract": [
                      -1
                    "css_general": "",
                  "10": {
                    "type": "text",
                    "id": 10,
                    "pos_x": 217,
                    "pos_y": 75,
                    "color": "none",
                    "fill": "rgba(0, 0, 0, 0.7)",
                    "font_size": 14,
                    "degree": 0,
                    "align": "middle",
                    "text": "Produktion",
                    "shadow": "",
                    "css_general": ""
                  "11": {
                    "type": "text",
                    "id": 11,
                    "pos_x": 457,
                    "pos_y": 288,
                    "color": "none",
                    "font_size": 14,
                    "degree": 0,
                    "align": "middle",
                    "text": "Verbrauch",
                    "shadow": "",
                    "css_general": ""
                  "12": {
                    "type": "icon",
                    "id": "12",
                    "icon": "mdi:house-city",
                    "width": 24,
                    "height": 24,
                    "pos_x": "445",
                    "pos_y": "218",
                    "shadow": "",
                    "css_general": "",
                    "source": -1,
                    "threshold": 0
                "defs": {
                  "path_5_7": {
                    "type": "def",
                    "id": "path_5_7",
                    "d": "M237 103  V 124.6 A 15 15 0 0 0 252 139.6  H 422 A 15 15 0 0 1 437 154.6  V 211",
                    "startSlot": "bottom_right",
                    "endSlot": "top_left"
                "lines": {
                  "line_path_5_7": {
                    "type": "line",
                    "id": "line_path_5_7",
                    "href": "#path_5_7",
                    "color": "rgb(211, 183, 135)",
                    "shadow": ""
                "animations": {
                  "anim_path_5_7": {
                    "type": "animation",
                    "id": "anim_path_5_7",
                    "color": "rgb(52, 20, 255)",
                    "source": "1",
                    "threshold": "0",
                    "animation_properties": "positive",
                    "animation_option": false,
                    "dots": 0,
                    "duration": 0,
                    "power": 0,
                    "animation_type": "-1",
                    "css_general": "",
                "datasources": {
                  "1": {
                    "source": "0_userdata.0.KG.Stromzähler.Haupt.Power_total",
                    "alias": "Haupt"
                "values": {
                  "2": "248.00",
                  "9": "248.00"
                "unit": {
                  "2": "W",
                  "9": "W"
                "animations": {
                  "anim_path_5_7": true
                "fillValues": {},
                  "anim_path_5_7": {
                    "option": ""
                "prepend": {
                  "2": "",
                  "9": ""
                "append": {
                  "2": "",
                  "9": ""
                "css": {
                  "2": {
                    "actPos": "",
                    "inactPos": "",
                    "actNeg": "",
                    "inactNeg": ""
                  "9": {
                    "actPos": "",
                    "inactPos": "",
                    "actNeg": "",
                    "inactNeg": ""
                  "anim_path_5_7": {
                    "actPos": "",
                    "inactPos": "",
                    "actNeg": "",
                    "inactNeg": ""
              Evtl. irgendein anderes Problem noch?
              • A andi2055
                @skb
                      "option": ""
                  "basic": {
                    "height": 540,
                    "width": 530,
                    "styles": "",
                    "font": {
                      "size": "20",
                      "color": "",
                      "fill": "",
                      "align": "middle"
                    "rect": {
                      "height": 100,
                      "width": 100,
                      "corners": 10
                    "circle": {
                      "radius": 50
                    "elm": {
                      "stroke_width": 5,
                      "color": "",
                      "fill": "",
                      "pos_x": 50,
                      "pos_y": 50
                    "icon": {
                      "height": 24,
                      "width": 24,
                      "color": ""
                  "calculation": {
                    "battery": {
                      "dod": 0,
                      "capacity": 0,
                      "percent": -1,
                      "charge": -1,
                      "charge_kw": false,
                      "discharge": -1,
                  "animation": {
                    "dots": "3",
                    "distance": "17",
                    "length": "10"
                  "line": {
                    "stroke": "#000000"
                  "elements": {
                    "2": {
                      "type": "text",
                      "id": 2,
                      "pos_x": 216,
                      "pos_y": 42,
                      "color": "none",
                      "font_size": 18,
                      "degree": 0,
                      "align": "middle",
                      "text": "ID 2",
                      "unit": "W",
                      "append": "",
                      "prepend": "",
                      "source": 1,
                      "shadow": "",
                      "threshold": 0,
                      "convert": false,
                      "subtract": [
                        -1
                      "css_general": "",
                    "5": {
                      "type": "rect",
                      "id": 5,
                      "rx": 10,
                      "height": 100,
                      "width": 100,
                      "pos_x": 167,
                      "pos_y": 2,
                      "fill": "none",
                      "stroke": 2,
                      "url": "",
                      "fill_value": null,
                      "fill_max": null,
                      "border_type": -1,
                      "border_max": null,
                      "source": -1,
                      "threshold": 0,
                      "css_general": "",
                    "6": {
                      "type": "icon",
                      "id": "6",
                      "width": 24,
                      "height": 24,
                      "pos_x": "205",
                      "pos_y": "6",
                      "shadow": "",
                      "css_general": "",
                      "source": -1,
                      "threshold": 0
                    "7": {
                      "type": "rect",
                      "id": 7,
                      "rx": 10,
                      "height": 100,
                      "width": 100,
                      "pos_x": 407,
                      "pos_y": 212,
                      "fill": "none",
                      "stroke": 2,
                      "url": "",
                      "fill_value": null,
                      "fill_max": null,
                      "border_type": -1,
                      "border_max": null,
                      "source": -1,
                      "threshold": 0,
                      "css_general": "",
                    "9": {
                      "type": "text",
                      "id": 9,
                      "pos_x": 457,
                      "pos_y": 254,
                      "color": "none",
                      "font_size": 18,
                      "degree": 0,
                      "align": "middle",
                      "text": "ID 9",
                      "unit": "W",
                      "append": "",
                      "prepend": "",
                      "source": 1,
                      "shadow": "",
                      "threshold": 0,
                      "convert": false,
                      "subtract": [
                        -1
                      "css_general": "",
                    "10": {
                      "type": "text",
                      "id": 10,
                      "pos_x": 217,
                      "pos_y": 75,
                      "color": "none",
                      "font_size": 14,
                      "degree": 0,
                      "align": "middle",
                      "shadow": "",
                      "css_general": ""
                    "11": {
                      "type": "text",
                      "id": 11,
                      "pos_x": 457,
                      "pos_y": 288,
                      "color": "none",
                      "font_size": 14,
                      "degree": 0,
                      "align": "middle",
                      "shadow": "",
                      "css_general": ""
                    "12": {
                      "type": "icon",
                      "id": "12",
                      "width": 24,
                      "height": 24,
                      "pos_x": "445",
                      "pos_y": "218",
                      "shadow": "",
                      "css_general": "",
                      "source": -1,
                      "threshold": 0
                  "defs": {
                    "path_5_7": {
                      "type": "def",
                      "id": "path_5_7",
                  "lines": {
                    "line_path_5_7": {
                      "type": "line",
                      "shadow": ""
                  "animations": {
                    "anim_path_5_7": {
                      "source": "1",
                      "threshold": "0",
                      "dots": 0,
                      "duration": 0,
                      "power": 0,
                      "css_general": "",
                  "datasources": {
                    "1": {
                      "alias": "Haupt"
                  "values": {
                    "2": "248.00",
                    "9": "248.00"
                  "unit": {
                    "2": "W",
                    "9": "W"
                  "animations": {
                  "fillValues": {},
                    "anim_path_5_7": {
                      "option": ""
                  "prepend": {
                    "2": "",
                    "9": ""
                  "append": {
                    "2": "",
                    "9": ""
                  "css": {
                    "2": {
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                    "9": {
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                    "anim_path_5_7": {
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                SKBS Offline
                SKBS Offline
                SKB
                #1015
                @andi2055 Ich habe das "Error"-Handling einmal etwas angepasst.
                Wenn Du nochmal drüber installierst und dann in die Konsole schaust, müsste immerhin der Fehler kommen, der auftritt.
                Mit diesem kann ich dann weiterarbeiten.
                Wärst Du so freundlich und installierst einmal drüber und schaust dann in die Konsole mit F12?
                Die Alias'se habe ich getestet und es wird etwas angezeigt. Allerdings liefert ioBroker nur die States, welche man auswählen kann. Leere Ordner usw werden nicht übermittelt.
                  andi2055
                  #1016
                  @skb
                  Anbei das Log beim Neuladen
                  Using Instance: energiefluss-erweitert.1 functions.min.js:1:192
                  Ein iframe, der sowohl "allow-scripts" als auch "allow-same-origin" für sein "sandbox"-Attribut gesetzt hat, kann seine Sandbox entfernen. index.html
                  Loading config for instance: 1 functions.min.js:1:9129
                  Using direct load via iconify-API! functions.min.js:1:117511
                  Einige Cookies verwenden das empfohlene "SameSite"-Attribut inkorrekt. 4
                  Loaded additional file: js/iconify.min.js functions.min.js:1:77018
                  Loading User Config ... functions.min.js:1:19992
                  Using direct load via iconify-API! functions.min.js:1:22453
                  [Socket] subscribed to: energiefluss-erweitert.1.configuration,energiefluss-erweitert.1.data,system.adapter.energiefluss-erweitert.1.alive,energiefluss-erweitert.1.backup at 30.7.2023, 10:40:15 functions.min.js:1:3509
                  Loading initial Data. functions.min.js:1:10155
                  An error accured, while refreshing the data! The following Error was thrown: TypeError: can't convert undefined to object functions.min.js:1:8684
                      refreshData http://192.168.3.100:8082/energiefluss-erweitert/js/functions.min.js:1
                      loadConfig http://192.168.3.100:8082/energiefluss-erweitert/js/functions.min.js:1
                      onack http://192.168.3.100:8082/socket.io/socket.io.js:8
                      onpacket http://192.168.3.100:8082/socket.io/socket.io.js:8
                      exports http://192.168.3.100:8082/socket.io/socket.io.js:8
                      emit http://192.168.3.100:8082/socket.io/socket.io.js:6
                      ondecoded http://192.168.3.100:8082/socket.io/socket.io.js:6
                      add http://192.168.3.100:8082/socket.io/socket.io.js:6
                      ondata http://192.168.3.100:8082/socket.io/socket.io.js:6
                      onPacket http://192.168.3.100:8082/socket.io/socket.io.js:6
                      setTransport http://192.168.3.100:8082/socket.io/socket.io.js:6
                      onPacket http://192.168.3.100:8082/socket.io/socket.io.js:7
                      n http://192.168.3.100:8082/socket.io/socket.io.js:7
                      decodePayload http://192.168.3.100:8082/socket.io/socket.io.js:7
                      onData http://192.168.3.100:8082/socket.io/socket.io.js:7
                      doPoll http://192.168.3.100:8082/socket.io/socket.io.js:7
                      onLoad http://192.168.3.100:8082/socket.io/socket.io.js:7
                      onreadystatechange http://192.168.3.100:8082/socket.io/socket.io.js:7
                  An error accured, while refreshing the data! The following Error was thrown: TypeError: can't convert undefined to object 5 functions.min.js:1:8684
                      displayListener http://192.168.3.100:8082/energiefluss-erweitert/js/functions.min.js:1
                  An error accured, while refreshing the data! The following Error was thrown: TypeError: can't convert undefined to object 35 functions.min.js:1:8684
                      (Async: setTimeout handler)
                      onevent http://192.168.3.100:8082/socket.io/socket.io.js:8
                      onmessage http://192.168.3.100:8082/socket.io/socket.io.js:8
                  Das Problem beim Auswählen betrifft nur "Channel"
                  Wenn ich die manuell auf "Folder" ändere, dann sind die auswählbar
                  • A andi2055
                    @skb
                    SKBS Offline
                    SKBS Offline
                    SKB
                    #1017
                    @andi2055 Danke für die Rückmeldung. Musste noch etwas erweitern. Kannst Du nochmal drüber installieren?
                    Sorry, dass das jetzt ein "Suchen nach der Nadel wird" ...
                    Nach den Objekten im Browser gucke ich die Tage nochmal.
                    • SKBS SKB
                      andi2055
                      #1018
                      @skb
                      jetzt funktioniert es wieder! Danke dir für den Support!
                      PS: super Adapter! und vor allem super flexibel! Habe dich gerade auch zu 2 Bier eingeladen...
                      • A andi2055
                        @skb
                        SKBS Offline
                        SKBS Offline
                        SKB
                        #1019
                        @andi2055 Allerdings komisch. Es sollte ja noch mindestens 1 Fehler in der Konsole auftauchen, da ja eben nichts ging.
                        Eine Funktion müsste einen Fehler werfen. Kannst Du da nochmal ins Log gucken?
                        Prost übrigens :)
                        • SKBS SKB
                          Prost übrigens :)
                          andi2055
                          #1020
                          @skb
                          hm, keine Ahnung. Ich habe nur neu von Github installiert (so wie davor auch)
                          Direkt danach hat es funktioniert. Kein Fehler mehr...
                          • A andi2055
                            @skb
                            SKBS Offline
                            SKBS Offline
                            SKB
                            #1021
                            @andi2055 Und das Mini-Projekt? Meldet dies einen Fehler?
                            • SKBS SKB
                              andi2055
                              #1022
                              @skb
                              das Mini-Projekt funktioniert nun ebenfalls ohne Fehler.
                              Wenn du nun sagst, dass du nichts außer Error-Handling geändert hast, dann weiß ich auch nicht weshalb es nun funktioniert...?
                              • A andi2055
                                @skb
                                SKBS Offline
                                SKBS Offline
                                SKB
                                #1023
                                @andi2055 Das macht mich auch etwas stutzig gerade:D
                                Beim Aktualisieren werden 4 Funktionen aufgerufen, um die Daten (Values, Styles, Animation und Borders) darzustellen. Die habe ich nun in eigene Error-Catcher gesetzt.
                                Anscheinend lieferte eine Funktion keine plausiblen Werte. Man könnte jetzt jede der 4 Funktionen aus dem Error-Handling wieder rausnehmen, um zu schauen, woran es liegt. Aber, das muss ich dir nicht zumuten :)
                                • SKBS SKB
                                  andi2055
                                  #1024
                                  @skb
                                  wenn du mir sagst wie ich die 4 hintereinander ausprobieren kann, dann kein Problem. Oder kannst du irgendwas im Log ausgeben je nach catch?
                                  Ich habe gerade noch mit der Anzahl Punkte auf der Line je nach Wert gespielt. Zweimal ist der Adapter in einem Neustart-Loop gesprungen. Neustart hat das Problem wieder gelöst. Fehler im Log:
                                  2023-07-30 12:04:58.461	error	uncaught exception: Cannot read properties of undefined (reading 'id')
                                  2023-07-30 12:04:58.459	error	Cannot read properties of undefined (reading 'id')
                                  2023-07-30 12:04:58.458	error	TypeError: Cannot read properties of undefined (reading 'id') at EnergieflussErweitert.onStateChange (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:295:27) at EnergieflussErweitert.emit (node:events:514:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8382:57) at process.processImmediate (node:internal/timers:476:21)
                                  So ganz Blicke ich bei der Anzahl Punkte pro Linie auch noch nicht durch.
                                  Hier habe ich nun z.B. Folgendes eingetragen
                                  Bedeutet: bei 13000 Leistung (Wert der Linie ist nun zum Testen dem Wert oben im gelben Kreis - Bild unten) werden knapp die maximale Anzahl Punkte dargestellt? Weshalb sehe ich dann nur 6?
                                  Versuch 2: In der Konfig 6 Punkte + 13000 eingetragen - es werden auch 6 angezeigt
                                  Hier sind 6 Punkte und 3000 in der Konfig. Obwahl nur 25W werden 3 angezeigt?
                                  Oder hängt das noch mit dem Aktualisierungs-Bug vom Anfang zusammen?
                                  • A andi2055
                                    @skb
                                    SKBS Offline
                                    SKBS Offline
                                    SKB
                                    #1025
                                    @andi2055 Die Animationen werden passend zu dem sich ändernden Wert ausgewertet. Also zum Zeitpunkt der Änderung.
                                    Dann wird die Linie mit neuen Punkten versehen. Heisst, wenn Du das Testen möchtest, Konfig abspeichern, Seite aufrufen und gucken - dann den Wert im DP ändern (lassen).
                                    Hier könnte allerdings, wie du sagst, vielleicht der Fehler in der Aktualisierung vorliegen. Erscheint denn ein Fehler im Log, wenn sich die Werte ändern?
                                    • SKBS SKB
                                      andi2055
                                      #1026
                                      @skb
                                      in welchem Log. Also im Browser F12 habe ich nichts gesehen.
                                      Im ioB habe ich auf Warnung stehen und da sehe ich auch nichts.
                                      Manchmal werden auch die vollen Punkte (wie erwartet) angezeigt. Rechts bei LWP allerdings nicht. Die 25W sind allerdings auch teilweise stundenlang konstant solange die Wärmepumpe aus ist.
                                      Startet die Grafik also immer mit 3 Punkten und erst bei Änderung wird das angepasst?
                                      Teilweise habe ich beobachtet, dass 3 angezeigt werden und diese dann bei nur minimaler Änderung des Wertes auf 1 reduziert werden (so wie ich das erwarten würde bei kleinen Werten) - danach aber wieder auf 3 springen und manchmal dann nochmal auf 1 angepasst werden usw.
                                      So ich bin nun erst wieder heute Abend am PC...
                                      • A andi2055
                                        @skb
                                        SKBS Offline
                                        SKBS Offline
                                        SKB
                                        #1027
                                        @andi2055 können wir uns gerne noch genauer anschauen, damit es zuverlässig(er) funktioniert.
                                        Ich nutze die Punkte auch und habe damit aktuell keine Probleme.
                                        • SKBS SKB
                                          andi2055
                                          #1028
                                          @skb
                                          So habe nun herausgefunden, weshalb die animierten Punkte auf den Linien bei mir nicht immer so perfekt angezeigt werden.
                                          -"Maximale Punkte auf der Linie" -> mehr als 5 machen keinen Sinn, weil mit 5 ist die Linie voll. Ich dachte auf lange Linien passen auch 10. Feld auf max 5 beschränken?
                                          -Wenn der berechnete Wert wahrscheinlich unter 0,5 fällt, dann werden 3 Punkte anstatt 1 angezeigt. Beispiel: Max Punkte 5, Max Wert 2000, Wert des Datenpunkt = 50 -> es werden 3 angezeigt, beim Wert 500 wird 1 Punkt angezeigt was ok ist. Ich hatte den Defaultwert "3 Punkte" unter "Animation" eingestellt.
                                          Workaround: unter "Animation" nun "1 Punkt" ausgewählt. Nun passt es. Aber vielleicht trotzdem irgendwas anpassen. Neueinsteiger wird das sicherlich wie mich irritieren.
                                          SKBS 2 Antworten Letzte Antwort
