  3. Off Topic
  4. ConBee2 auf Raspi 4 umziehen [gelöst]
    1.0k
    6.1k
59 Beiträge 3 Kommentatoren 5.8k Aufrufe 2 Beobachtet
    @ichwersonst
    Das hat auch keiner behauptet.
    iob diag
    in der Langfassung?
    Und schalt den Desktop-Scheiß zuvor aus!
    I Offline
    I Offline
    ichwersonst
    mit welchen befehl mache ich das den desktop ausschalten?
      @ichwersonst
      iob diag
      in der Langfassung?
      I Offline
      I Offline
      ichwersonst
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       17:43:22 up 42 min,  3 users,  load average: 0.68, 0.60, 0.56
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=50.1'C
      volt=0.9260V
      *** Time and Time Zones ***
                     Local time: Fri 2023-07-28 17:43:22 CEST
                 Universal time: Fri 2023-07-28 15:43:22 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        884M        1.9G         35M        1.0G        2.8G
      Swap:            99M          0B         99M
      Total:          3.9G        884M        2.0G
               3793 M total memory
                884 M used memory
               1358 M active memory
                383 M inactive memory
               1870 M free memory
                 49 M buffer memory
                987 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       56G  5.6G   48G  11% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     759M  1.3M  758M   1% /run
      /dev/sda1      vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
      [Fri Jul 28 17:00:33 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:37:DD:BE vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2a31fda3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Fri Jul 28 17:00:36 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Jul 28 17:00:36 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Fri Jul 28 17:00:38 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      814M    /var/
      399M    /var/log
      393M    /var/log/journal/5530f3d80baf4cc0bb1ed682675aa129
      191M    /var/cache
      Archived and active journals take up 392.0M in the file system.
      /opt/iobroker/backups:
      37M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      314M    /opt/iobroker/iobroker-data/
      271M    /opt/iobroker/iobroker-data/files
      88M     /opt/iobroker/iobroker-data/files/echarts.admin
      57M     /opt/iobroker/iobroker-data/files/echarts
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      31M     /opt/iobroker/iobroker-data/states.jsonl
      23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
      17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.0
      /usr/bin/node           v18.17.0
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.0-deb-1nodesource1
        Candidate: 18.17.0-deb-1nodesource1
        Version table:
       *** 18.17.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye-proposed-updates/main armhf Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     7.0.3
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      + system.adapter.broadlink2.1             : broadlink2            : raspberrypi                              -  enabled
      + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
      + system.adapter.pushbullet.0             : pushbullet            : raspberrypi                              -  enabled
      + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
        system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
      + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
      Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
      Adapter    "wled"         : 0.6.7    , installed 0.6.7
      Objects and States
      Objects:        4231
      States:         3203
      Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
      Hit:2 http://phoscon.de/apt/deconz bullseye InRelease
      Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16690      570/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16221      570/iobroker.js-con
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15946      585/vncserver-x11-c
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14029      560/cupsd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20844      1673/io.shelly.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12952      596/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12988      406/deCONZ
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16541      406/deCONZ
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          15945      585/vncserver-x11-c
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18185      1011/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21697      1930/io.web.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14028      560/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12954      596/sshd: /usr/sbin
      udp        0      0 0.0.0.0:47627           0.0.0.0:*                           1001       20952      1752/io.broadlink2.
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14052      616/cups-browsed
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       23689      2046/io.broadlink2.
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       18361      1752/io.broadlink2.
      udp        0      0 0.0.0.0:47976           0.0.0.0:*                           1001       18365      1752/io.broadlink2.
      udp        0      0 0.0.0.0:37808           0.0.0.0:*                           108        15333      399/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23555      1834/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15331      399/avahi-daemon: r
      udp        0      0 0.0.0.0:52584           0.0.0.0:*                           1001       21248      2046/io.broadlink2.
      udp        0      0 0.0.0.0:44635           0.0.0.0:*                           1001       18364      1752/io.broadlink2.
      udp        0      0 0.0.0.0:55030           0.0.0.0:*                           1001       22945      2046/io.broadlink2.
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       86348      23134/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       13093      406/deCONZ
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16606      506/dhcpcd
      udp        0      0 0.0.0.0:51595           0.0.0.0:*                           1001       21249      2046/io.broadlink2.
      udp6       0      0 :::5353                 :::*                                108        15332      399/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       86350      23134/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       86349      23134/io.deconz.0
      udp6       0      0 :::51200                :::*                                108        15334      399/avahi-daemon: r
      2023-07-28 17:09:41.943  - info: host.raspberrypi stopInstance system.adapter.deconz.0 send kill signal
      2023-07-28 17:09:42.434  - info: host.raspberrypi instance system.adapter.deconz.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-07-28 17:09:44.991  - info: host.raspberrypi instance system.adapter.deconz.0 started with pid 23134
      2023-07-28 17:09:47.612  - info: deconz.0 (23134) starting. Version 1.3.21 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.17.0, js-controller: 4.0.24
      2023-07-28 17:09:47.749  - info: deconz.0 (23134) deConz Version: 2.22.2; API version: 1.16.0
      2023-07-28 17:31:23.633  - error: vw-connect.0 (1795) Restart adapter
      2023-07-28 17:31:23.634  - warn: vw-connect.0 (1795) Restart initiated
      2023-07-28 17:31:23.636  - info: vw-connect.0 (1795) cleaned everything up...
      2023-07-28 17:31:23.647  - info: vw-connect.0 (1795) terminating
      2023-07-28 17:31:23.649  - info: vw-connect.0 (1795) Terminated (NO_ERROR): Without reason
      2023-07-28 17:31:24.253  - info: host.raspberrypi instance system.adapter.vw-connect.0 terminated with code 0 (NO_ERROR)
      2023-07-28 17:31:24.256  - info: host.raspberrypi Restart adapter system.adapter.vw-connect.0 because enabled
      2023-07-28 17:31:54.305  - info: host.raspberrypi instance system.adapter.vw-connect.0 started with pid 16709
      2023-07-28 17:31:57.695  - info: vw-connect.0 (16709) starting. Version 0.0.67 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.17.0, js-controller: 4.0.24
      2023-07-28 17:31:57.741  - info: vw-connect.0 (16709) Login in with skoda
      2023-07-28 17:31:59.705  - warn: vw-connect.0 (16709) /signin-service/v1/...
      2023-07-28 17:31:59.705  - warn: vw-connect.0 (16709) No valid userid, please check username and password or visit this link or logout and login in your app account:
      2023-07-28 17:31:59.706  - warn: vw-connect.0 (16709) Bitte in die App einloggen und die Nutzungsbedingungen akzeptieren.
      2023-07-28 17:31:59.707  - warn: vw-connect.0 (16709) https://identity....
      2023-07-28 17:31:59.707  - warn: vw-connect.0 (16709) Try to auto accept new consent
      2023-07-28 17:31:59.715  - error: vw-connect.0 (16709) Login Failed
      2023-07-28 17:31:59.715  - error: vw-connect.0 (16709) Restart Adapter in 30min
      2023-07-28 17:32:00.106  - error: vw-connect.0 (16709) Error in consent form
      2023-07-28 17:32:00.107  - error: vw-connect.0 (16709) SyntaxError: Unexpected token c in JSON at position 1430
      2023-07-28 17:34:59.399  - warn: deconz.0 (23134) State "deconz.0.Sensors.22.buttonpressed" has no existing object, this might lead to an error in future versions
      • I ichwersonst
        @ichwersonst
        sudo raspi-config
        Dann dort:
        1 System Options
        S5 Boot / Auto Login
        B1 Console
        I 1 Antwort Letzte Antwort
        • I ichwersonst
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          temp=50.1'C
          volt=0.9260V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       true
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   3793 M total memory
                    884 M used memory
                   1870 M free memory
                     49 M buffer memory
                    987 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          814M    /var/
          399M    /var/log
          191M    /var/cache
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     7.0.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        4231
          States:         3203
          Pending Updates: 0
          @ichwersonst sagte in ConBee2 auf Raspi 4 umziehen:
          Da läuft der Adapter doch. Zur Konfiguration kann ich dir nix sagen, hab den nicht in Benutzung.
            @ichwersonst
            sudo raspi-config
            Dann dort:
            1 System Options
            B1 Console
            I Offline
            I Offline
            ichwersonst
            okay gemacht...
            bevor ich den ausgeschalten hatte ist mir noch auf dem desktop was aufgefallen :
            beim 3b+ erscheint der stick mit bei der Interfaceauswahl
            • I ichwersonst
              okay gemacht...
              @ichwersonst
              Desktop-Geraffel ist per se uninteressant.
                @ichwersonst
                I Offline
                I Offline
                ichwersonst
                hmm dann muss ich weiter das internet durchforsten um da noch auf einen grünen zweig zu kommen.
                danke trotzdem erstmal :-)
                • I ichwersonst
                  @ichwersonst
                  Hast du denn Objects zu dem Adapter?
                  I 2 Antworten Letzte Antwort
                    @ichwersonst
                    I Offline
                    I Offline
                    ichwersonst
                    jup hab die objects ausm iob vom 3b+ exportiert und hier im iob 4b importiert
                      @ichwersonst
                      I Offline
                      I Offline
                      ichwersonst
                      und hab auch die stick config exportiert um sie im 4b wieder zu importieren .... also sämtliche dinge die im webinterface einzustellen sind
                      • I ichwersonst
                        @ichwersonst
                        Häh?
                        Die Objekte werden vom Adapter zur Laufzeit angelegt...
                        Was haste denn da kopiert?
                        • I ichwersonst
                          Vermutlich mit falschen Rechten und/oder an der falschen Stelle.
                            @ichwersonst
                            Häh?
                            I Offline
                            I Offline
                            ichwersonst
                            so hier
                            • I ichwersonst
                              so hier
                              @ichwersonst
                              Und wozu?
                                @ichwersonst
                                Und wozu?
                                I Offline
                                I Offline
                                ichwersonst
                                weil es mir sonst an allen Stellen, die Variablen, die ich steuere rausschmeißt und ich alles neu verknüpfen muss.
                                Ro75R 1 Antwort Letzte Antwort
                                • I ichwersonst
                                  Ro75R Offline
                                  Ro75R Offline
                                  Ro75
                                  Wenn du den Deconz-Adapter nutzt, ohne die Alias-Funktion, wird dir das früher oder später mehr oder weniger oft, so wieso passieren.
                                  • Ro75R Ro75
                                    I Offline
                                    I Offline
                                    ichwersonst
                                    @ro75
                                    was ist die alias funktion ?
                                    @Thomas-Braun
                                    ich würde vielleicht einfach den adapter und den conbee stick vom pi deinstallieren und nochmal von vorne beginnen.
                                    Vielleicht hilft das ja
                                    • I ichwersonst
                                      @ro75
                                      @Thomas-Braun
                                      Ro75R Offline
                                      Ro75R Offline
                                      Ro75
                                      @ichwersonst falls du vorhast die deconzsoftware komplett zu entfernen, dann schaue dir zuvor ggfs. den zigbee-adapter an.
                                      • Ro75R Ro75
                                        I Offline
                                        I Offline
                                        ichwersonst
                                        @ro75 @Thomas-Braun
                                        völlig behämmert.... der stick will an ein Verlängerungskabel gehangen werden weil er von den umliegenden usb3.0 buchsen gestört wird.... heißt: gelöst!
                                        • I ichwersonst
                                          @ro75 @Thomas-Braun
                                          Das hatte ich vorausgesetzt. Das Phänomen ist ja kein ganz unbekanntes.
