  4. BackItUp - Probleme mit wiederherstellung
    5.3k
79 Beiträge 6 Kommentatoren 7.8k Aufrufe 5 Beobachtet
  • von.cartmanV von.cartman
    @von-cartman
    Versuch an einer frische IOB Instalation
    log:
    2023-07-27 11:42:29.444 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
    2023-07-27 11:42:29.450 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-07-27 11:42:29.451 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
    2023-07-27 11:42:29.452 - info: host.raspberryPi-EG ip addresses: 192.168.0.69 fdf9:87b2:c3b6:40c6:904:57bf:8a9a:40c9 fe80::6f9e:d1a7:4432:627b 192.168.0.71 fdf9:87b2:c3b6:40c6:1782:e626:ec0e:b9f8 fe80::69d:2a37:a967:9aae
    2023-07-27 11:42:29.852 - info: host.raspberryPi-EG connected to Objects and States
    2023-07-27 11:42:29.885 - info: host.raspberryPi-EG Node.js version has changed from unknown to 16.20.1
    2023-07-27 11:42:29.931 - info: host.raspberryPi-EG Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2023-07-27 11:42:29.949 - info: host.raspberryPi-EG added notifications configuration of host
    2023-07-27 11:42:30.517 - info: host.raspberryPi-EG 3 instances found
    2023-07-27 11:42:30.526 - info: host.raspberryPi-EG starting 3 instances
    2023-07-27 11:42:30.580 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 5282
    2023-07-27 11:42:33.124 - info: admin.0 (5282) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
    2023-07-27 11:42:33.173 - info: admin.0 (5282) requesting all states
    2023-07-27 11:42:33.174 - info: admin.0 (5282) requesting all objects
    2023-07-27 11:42:33.275 - info: admin.0 (5282) received all objects
    2023-07-27 11:42:33.514 - info: admin.0 (5282) http server listening on port 8081
    2023-07-27 11:42:33.515 - info: admin.0 (5282) Use link "http://localhost:8081" to configure.
    2023-07-27 11:42:33.523 - info: admin.0 (5282) socket.io server listening on port 8081
    2023-07-27 11:42:33.602 - warn: admin.0 (5282) Repository cannot be read: Active repo - stable
    2023-07-27 11:42:33.603 - warn: admin.0 (5282) Active repository "stable" cannot be read
    2023-07-27 11:42:34.553 - info: host.raspberryPi-EG instance system.adapter.discovery.0 started with pid 5305
    2023-07-27 11:42:36.689 - info: discovery.0 (5305) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.20.1, js-controller: 4.0.24
    2023-07-27 11:42:38.578 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 5338
    2023-07-27 11:42:40.776 - info: backitup.0 (5338) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
    2023-07-27 11:42:40.902 - info: backitup.0 (5338) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-07-27 11:43:27.399 - info: admin.0 (5282) ==> Connected system.user.admin from ::ffff:192.168.0.55
    2023-07-27 11:43:27.544 - info: host.raspberryPi-EG Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-07-27 11:45:01.867 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-07-27 11:45:01.886 - info: admin.0 (5282) Got terminate signal TERMINATE_YOURSELF
    2023-07-27 11:45:01.897 - info: admin.0 (5282) terminating http server on port 8081
    2023-07-27 11:45:01.909 - info: admin.0 (5282) terminating
    2023-07-27 11:45:01.912 - info: admin.0 (5282) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-27 11:45:01.925 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 send kill signal
    2023-07-27 11:45:02.465 - info: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-27 11:45:04.957 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 5368
    2023-07-27 11:45:07.265 - info: admin.0 (5368) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
    2023-07-27 11:45:07.314 - info: admin.0 (5368) requesting all states
    2023-07-27 11:45:07.315 - info: admin.0 (5368) requesting all objects
    2023-07-27 11:45:07.924 - info: admin.0 (5368) received all objects
    2023-07-27 11:45:08.278 - info: admin.0 (5368) http server listening on port 8081
    2023-07-27 11:45:08.279 - info: admin.0 (5368) Use link "http://localhost:8081" to configure.
    2023-07-27 11:45:08.288 - info: admin.0 (5368) socket.io server listening on port 8081
    2023-07-27 11:45:09.553 - info: admin.0 (5368) failed connection to socket.io from ::ffff:192.168.0.55: Passport was not initialized
    2023-07-27 11:45:15.798 - info: admin.0 (5368) ==> Connected system.user.admin from ::ffff:192.168.0.55
    2023-07-27 11:45:21.863 - info: discovery.0 (5305) Discovering devices with a HF-LPB100 chipset...
    2023-07-27 11:45:21.906 - info: discovery.0 (5305) Discovering mDNS devices...
    2023-07-27 11:45:21.916 - info: discovery.0 (5305) Discovering ping devices...
    2023-07-27 11:45:22.104 - info: discovery.0 (5305) Discovering UPnP devices...
    2023-07-27 11:45:22.112 - info: discovery.0 (5305) Discovering wifi-mi-light devices...
    2023-07-27 11:45:22.174 - warn: discovery.0 (5305) tr-064.0 not installed
    2023-07-27 11:45:22.175 - info: discovery.0 (5305) Done discovering tr064 devices. 0 packages received
    2023-07-27 11:45:24.115 - info: discovery.0 (5305) Done discovering wifi-mi-light devices. 0 packages received
    2023-07-27 11:45:26.945 - info: discovery.0 (5305) Done discovering udp devices. 1 packages received
    2023-07-27 11:45:31.868 - info: discovery.0 (5305) Done discovering HF-LPB100 devices. 0 packages received
    2023-07-27 11:45:36.914 - info: discovery.0 (5305) Done discovering mdns devices. 307 packages received
    2023-07-27 11:45:37.110 - info: discovery.0 (5305) Done discovering upnp devices. 50 packages received
    2023-07-27 11:45:48.610 - info: discovery.0 (5305) Done discovering ping devices. 54 packages received
    2023-07-27 11:45:52.273 - info: discovery.0 (5305) Found 78 addresses
    2023-07-27 11:50:27.041 - info: discovery.0 (5305) openknx adapter already present for IP 192.168.0.8
    2023-07-27 11:50:27.044 - info: discovery.0 (5305) openknx adapter already present for IP 192.168.0.9
    2023-07-27 11:50:37.178 - info: discovery.0 (5305) Discovery finished. Found new or modified 15 instances
    2023-07-27 11:50:37.344 - info: discovery.0 (5305) Discovery finished
    2023-07-27 11:51:12.556 - info: admin.0 (5368) ==> Connected system.user.admin from ::ffff:192.168.0.55
    2023-07-27 11:51:30.950 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-07-27 11:51:30.965 - info: backitup.0 (5338) Got terminate signal TERMINATE_YOURSELF
    2023-07-27 11:51:30.969 - info: backitup.0 (5338) cleaned everything up...
    2023-07-27 11:51:30.970 - info: backitup.0 (5338) terminating
    2023-07-27 11:51:30.972 - info: backitup.0 (5338) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-27 11:51:31.004 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
    2023-07-27 11:51:31.031 - info: admin.0 (5368) <== Disconnect system.user.admin from ::ffff:192.168.0.55
    2023-07-27 11:51:31.520 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-27 11:51:34.038 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 5885
    2023-07-27 11:51:36.188 - info: backitup.0 (5885) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
    2023-07-27 11:51:36.295 - info: backitup.0 (5885) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-07-27 11:51:38.356 - info: admin.0 (5368) ==> Connected system.user.admin from ::ffff:192.168.0.55
    2023-07-27 11:51:49.127 - info: admin.0 (5368) <== Disconnect system.user.admin from ::ffff:192.168.0.55
    2023-07-27 11:51:52.030 - info: admin.0 (5368) ==> Connected system.user.admin from ::ffff:192.168.0.55
    2023-07-27 11:52:38.182 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-07-27 11:52:38.199 - info: backitup.0 (5885) Got terminate signal TERMINATE_YOURSELF
    2023-07-27 11:52:38.203 - info: backitup.0 (5885) cleaned everything up...
    2023-07-27 11:52:38.206 - info: backitup.0 (5885) terminating
    2023-07-27 11:52:38.211 - info: backitup.0 (5885) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-27 11:52:38.237 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
    2023-07-27 11:52:38.256 - info: admin.0 (5368) <== Disconnect system.user.admin from ::ffff:192.168.0.55
    2023-07-27 11:52:38.751 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-27 11:52:41.262 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 5972
    2023-07-27 11:52:43.412 - info: backitup.0 (5972) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
    2023-07-27 11:52:43.521 - info: backitup.0 (5972) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-07-27 11:52:49.433 - info: admin.0 (5368) ==> Connected system.user.admin from ::ffff:192.168.0.55
    2023-07-27 11:54:07.600 - info: host.raspberryPi-EG received SIGTERM
    2023-07-27 11:54:07.605 - info: admin.0 (5368) terminating http server on port 8081
    2023-07-27 11:54:07.601 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-07-27 11:54:07.602 - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 (force=false, process=true)
    2023-07-27 11:54:07.603 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-07-27 11:54:07.603 - info: backitup.0 (5972) cleaned everything up...
    2023-07-27 11:54:07.620 - info: discovery.0 (5305) Got terminate signal TERMINATE_YOURSELF
    2023-07-27 11:54:07.621 - info: admin.0 (5368) Got terminate signal TERMINATE_YOURSELF
    2023-07-27 11:54:07.621 - info: backitup.0 (5972) Got terminate signal TERMINATE_YOURSELF
    2023-07-27 11:54:07.625 - info: discovery.0 (5305) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-07-27 11:54:07.627 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 send kill signal
    2023-07-27 11:54:07.629 - info: backitup.0 (5972) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-07-27 11:54:07.630 - info: admin.0 (5368) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-07-27 11:54:07.636 - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 send kill signal
    2023-07-27 11:54:07.637 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
    2023-07-27 11:54:08.200 - info: host.raspberryPi-EG instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-07-27 11:54:08.210 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-07-27 11:54:08.256 - info: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-07-27 11:54:08.256 - info: host.raspberryPi-EG All instances are stopped.
    2023-07-27 11:54:08.437 - info: host.raspberryPi-EG terminated
    2023-07-27 11:55:04.499 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
    2023-07-27 11:55:04.506 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-07-27 11:55:04.507 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
    2023-07-27 11:55:04.508 - info: host.raspberryPi-EG ip addresses: 192.168.0.69 fdf9:87b2:c3b6:40c6:904:57bf:8a9a:40c9 fe80::6f9e:d1a7:4432:627b 192.168.0.71 fdf9:87b2:c3b6:40c6:1782:e626:ec0e:b9f8 fe80::69d:2a37:a967:9aae
    2023-07-27 11:55:05.177 - info: host.raspberryPi-EG connected to Objects and States
    2023-07-27 11:55:05.206 - info: host.raspberryPi-EG added notifications configuration of host
    2023-07-27 11:55:05.625 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
    2023-07-27 11:55:05.632 - info: host.raspberryPi-EG 3 instances found
    2023-07-27 11:55:05.642 - info: host.raspberryPi-EG starting 3 instances
    2023-07-27 11:55:05.697 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 6074
    2023-07-27 11:55:05.723 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
    2023-07-27 11:55:05.735 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
    2023-07-27 11:55:05.748 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
    2023-07-27 11:55:05.761 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
    2023-07-27 11:55:05.774 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
    2023-07-27 11:55:05.787 - info: host.raspberryPi-EG Some obsolete host states deleted.
    2023-07-27 11:55:08.298 - info: admin.0 (6074) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
    2023-07-27 11:55:08.347 - info: admin.0 (6074) requesting all states
    2023-07-27 11:55:08.348 - info: admin.0 (6074) requesting all objects
    2023-07-27 11:55:09.007 - info: admin.0 (6074) received all objects
    2023-07-27 11:55:09.531 - info: admin.0 (6074) http server listening on port 8081
    2023-07-27 11:55:09.533 - info: admin.0 (6074) Use link "http://localhost:8081" to configure.
    2023-07-27 11:55:09.544 - info: admin.0 (6074) socket.io server listening on port 8081
    2023-07-27 11:55:09.691 - info: host.raspberryPi-EG instance system.adapter.discovery.0 started with pid 6097
    2023-07-27 11:55:11.922 - info: discovery.0 (6097) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.20.1, js-controller: 4.0.24
    2023-07-27 11:55:13.668 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 6116
    2023-07-27 11:55:15.838 - info: backitup.0 (6116) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
    2023-07-27 11:55:15.891 - error: backitup.0 (6116) [ERROR] [iobroker] <--- Last few GCs --->
    2023-07-27 11:55:15.892 - error: backitup.0 (6116) [ERROR] [iobroker] [6006:0x478e050] 29464 ms: Mark-sweep 199.9 (205.7) -> 198.7 (202.2) MB, 37.4 / 0.1 ms (+ 0.1 ms in 1 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 5456 ms) (average mu = 0.994, current mu = 0.994) external memory [6006:0x478e050] 37010 ms: Mark-sweep (reduce) 369.0 (371.6) -> 368.6 (371.1) MB, 141.4 / 0.0 ms (+ 3.6 ms in 7 steps since start of marking, biggest step 0.9 ms, walltime since start of marking 5867 ms) (average mu = 0.985, current mu = 0.981) alloca
    2023-07-27 11:55:15.892 - error: backitup.0 (6116) [ERROR] [iobroker] <--- JS stacktrace --->
    2023-07-27 11:55:15.893 - error: backitup.0 (6116) [ERROR] [iobroker] FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
    2023-07-27 11:55:16.022 - info: backitup.0 (6116) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-07-27 11:55:36.133 - info: admin.0 (6074) ==> Connected system.user.admin from ::ffff:192.168.0.55
    2023-07-27 11:55:38.025 - info: admin.0 (6074) ==> Connected system.user.admin from ::ffff:192.168.0.55
    2023-07-27 11:55:41.021 - info: admin.0 (6074) <== Disconnect system.user.admin from ::ffff:192.168.0.55
    iob diag:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     11:58:27 up 19 min,  3 users,  load average: 0.06, 0.34, 0.34
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=48.7'C
    volt=0.9360V
    *** Time and Time Zones ***
                   Local time: Thu 2023-07-27 11:58:27 CEST
               Universal time: Thu 2023-07-27 09:58:27 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            909M         92M        514M         18M        302M        734M
    Swap:            99M         99M        0.0K
    Total:          1.0G        191M        515M
              909 M total memory
               92 M used memory
              109 M active memory
              136 M inactive memory
              514 M free memory
               15 M buffer memory
              287 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       30G  4.3G   24G  16% /
    devtmpfs       devtmpfs  197M     0  197M   0% /dev
    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
    tmpfs          tmpfs     182M  1.2M  181M   1% /run
    /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs      91M   24K   91M   1% /run/user/1000
    [Thu Jul 27 11:38:50 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:92:14:92 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c8e5e6e4-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Jul 27 11:38:51 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Jul 27 11:38:51 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Jul 27 11:38:53 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    533M    /var/
    262M    /var/cache
    250M    /var/cache/apt
    185M    /var/cache/apt/archives
    123M    /var/lib
    Archived and active journals take up 48.0M in the file system.
    /opt/iobroker/backups:
    74M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    19M     /opt/iobroker/iobroker-data/
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    4.0M    /opt/iobroker/iobroker-data/objects.jsonl
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.20.1
    /usr/bin/node           v16.20.1
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    nodejs:
      Installed: 16.20.1-deb-1nodesource1
      Candidate: 16.20.1-deb-1nodesource1
      Version table:
     *** 16.20.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    admin:          6.3.5
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberryPi-EG                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : raspberryPi-EG                           -  enabled
      system.adapter.discovery.0              : discovery             : raspberryPi-EG                           -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Objects and States
    Objects:        143
    States:         108
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          897        479/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13123      533/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13125      533/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          896        479/cupsd
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15781      430/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13108      516/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12907      340/avahi-daemon: r
    udp        0      0 0.0.0.0:33738           0.0.0.0:*                           108        12909      340/avahi-daemon: r
    udp6       0      0 :::46193                :::*                                108        12910      340/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        12908      340/avahi-daemon: r
    2023-07-27 11:56:48.790  - info: backitup.0 (6116) cleaned everything up...
    2023-07-27 11:56:48.791  - info: admin.0 (6074) terminating http server on port 8081
    2023-07-27 11:56:48.792  - info: host.raspberryPi-EG received SIGTERM
    2023-07-27 11:56:48.803  - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-07-27 11:56:48.804  - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 (force=false, process=true)
    2023-07-27 11:56:48.806  - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-07-27 11:56:48.825  - info: admin.0 (6074) Got terminate signal TERMINATE_YOURSELF
    2023-07-27 11:56:48.827  - info: backitup.0 (6116) Got terminate signal TERMINATE_YOURSELF
    2023-07-27 11:56:48.826  - info: discovery.0 (6097) Got terminate signal TERMINATE_YOURSELF
    2023-07-27 11:56:48.832  - info: discovery.0 (6097) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-07-27 11:56:48.835  - info: admin.0 (6074) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-07-27 11:56:48.835  - info: backitup.0 (6116) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-07-27 11:56:48.836  - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 send kill signal
    2023-07-27 11:56:48.840  - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 send kill signal
    2023-07-27 11:56:48.841  - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
    2023-07-27 11:56:49.419  - info: host.raspberryPi-EG instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-07-27 11:56:49.467  - info: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-07-27 11:56:49.505  - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-07-27 11:56:49.505  - info: host.raspberryPi-EG All instances are stopped.
    2023-07-27 11:56:49.651  - info: host.raspberryPi-EG terminated
    iob diag has finished.
    Press any key for a summary
    @von-cartman sagte in BackItUp - Probleme mit wiederherstellung:
    braucht's noch mehr?
    Dein RAM reicht nicht.
    zu viel Spülwasser im Glas!
    wie groß ist das Backup?
    Instanz von backitup auf debug stellen!
    da ist wieder nichts vom restore zu sehen
    von.cartmanV ? 4 Antworten Letzte Antwort
      von.cartmanV Offline
      von.cartman
      Ok. Vielen DANK
      Dann muss ich wohl warten bis der 8GB ankommt.
        Ok. Vielen DANK
        Vielen DANK
        gib lieber Antworten
          von.cartman
          @homoran sagte in BackItUp - Probleme mit wiederherstellung:
          75 MB
            von.cartman
            instanz in DEBUG
            iob diag:
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Docker          : false
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=raspbian
            ID_LIKE=debian
             12:55:14 up  1:16,  3 users,  load average: 0.81, 0.39, 0.15
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            temp=50.1'C
            volt=0.8700V
                           Local time: Thu 2023-07-27 12:55:14 CEST
                       Universal time: Thu 2023-07-27 10:55:14 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       true
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            909M        237M        381M         18M        290M        606M
            Swap:            99M         99M        0.0K
            Total:          1.0G        336M        382M
                      909 M total memory
                      237 M used memory
                      241 M active memory
                      133 M inactive memory
                      381 M free memory
                       14 M buffer memory
                      275 M swap cache
                       99 M total swap
                       99 M used swap
                        0 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            533M    /var/
            262M    /var/cache
            250M    /var/cache/apt
            123M    /var/lib
            147M    /opt/iobroker/backups/
            4.1M    /opt/iobroker/iobroker-data/objects.jsonl
            /usr/bin/npm            8.19.4
            /usr/bin/npx            8.19.4
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            Adapter State
            + system.adapter.admin.0                  : admin                 : raspberryPi-EG                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0               : backitup              : raspberryPi-EG                           -  enabled
            + system.adapter.discovery.0              : discovery             : raspberryPi-EG                           -  enabled
            + instance is alive
            Objects and States
            Objects:        143
            States:         108
            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Pending Updates: 0
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       51402      7463/iobroker.js-co
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       51395      7463/iobroker.js-co
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       51448      7481/io.admin.0
            2023-07-27 12:55:36.558  - debug: admin.0 (7481) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed
            2023-07-27 12:55:49.409  - debug: admin.0 (7481) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.*.alive
            2023-07-27 12:55:49.413  - debug: admin.0 (7481) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected
            2023-07-27 12:55:49.415  - debug: admin.0 (7481) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2023-07-27 12:55:49.420  - debug: admin.0 (7481) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount
            2023-07-27 12:55:49.426  - debug: admin.0 (7481) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2023-07-27 12:55:49.428  - debug: admin.0 (7481) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2023-07-27 12:55:49.430  - debug: admin.0 (7481) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss
            2023-07-27 12:55:49.439  - debug: admin.0 (7481) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount
            2023-07-27 12:55:49.444  - debug: admin.0 (7481) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2023-07-27 12:55:49.447  - debug: admin.0 (7481) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2023-07-27 12:55:49.449  - debug: admin.0 (7481) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel
            2023-07-27 12:55:49.458  - debug: admin.0 (7481) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.host.*.diskFree
            2023-07-27 12:55:49.463  - debug: admin.0 (7481) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2023-07-27 12:55:49.465  - debug: admin.0 (7481) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2023-07-27 12:55:49.467  - debug: admin.0 (7481) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.host.*.diskFree, system.host.*.diskSize
            2023-07-27 12:55:49.476  - debug: admin.0 (7481) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning
            2023-07-27 12:55:49.482  - debug: admin.0 (7481) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2023-07-27 12:55:49.484  - debug: admin.0 (7481) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2023-07-27 12:55:49.486  - debug: admin.0 (7481) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem
            2023-07-27 12:55:49.498  - debug: admin.0 (7481) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection
            2023-07-27 12:55:49.501  - debug: admin.0 (7481) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension
            2023-07-27 12:55:49.556  - debug: admin.0 (7481) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2023-07-27 12:55:49.557  - debug: admin.0 (7481) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            2023-07-27 12:55:49.558  - debug: admin.0 (7481) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            Zwietes Teil:
            Copy text starting here:
                                 v.2023-04-16
            Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
            Kernel:                 6.1.21-v8+
            Installation:           Native
            User-ID:                1000
            X-Server:               true
            Pending OS-Updates:     0
            Pending iob updates:    0
            Nodejs-Installation:    /usr/bin/nodejs         v16.20.1
                                    /usr/bin/npm            8.19.4
                                    /usr/bin/npx            8.19.4
            Recommended versions are nodejs 18.x.y and npm 9.x.y
            MEMORY:
            Mem:            909M        245M        216M         18M        446M        598M
            Swap:            99M         99M        0.0K
            Total:          1.0G        345M        217M
            Active iob-Instances:   4
            ioBroker Core:          js-controller           4.0.24
                                    admin                   6.3.5
            Objects type: jsonl
            States  type: jsonl
            Objects:                143
            States:                 108
            Size of iob-Database:
            240K    /opt/iobroker/iobroker-data/states.jsonl
            pi@raspberryPi-EG:~ $
              instanz in DEBUG
              iob diag:
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=raspbian
              ID_LIKE=debian
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              temp=50.1'C
              volt=0.8700V
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       true
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M         99M        0.0K
                        909 M total memory
                        237 M used memory
                        241 M active memory
                        381 M free memory
                         14 M buffer memory
                        275 M swap cache
                         99 M total swap
                         99 M used swap
                          0 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              533M    /var/
              262M    /var/cache
              250M    /var/cache/apt
              123M    /var/lib
              /usr/bin/npm            8.19.4
              /usr/bin/npx            8.19.4
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.5
              Adapter State
              + instance is alive
              Objects and States
              Objects:        143
              States:         108
              Pending Updates: 0
              Zwietes Teil:
                                   v.2023-04-16
              Kernel:                 6.1.21-v8+
              User-ID:                1000
              X-Server:               true
                                      /usr/bin/npm            8.19.4
                                      /usr/bin/npx            8.19.4
              MEMORY:
              Swap:            99M         99M        0.0K
                                      admin                   6.3.5
              Objects type: jsonl
              States  type: jsonl
              Objects:                143
              States:                 108
              instanz in DEBUG
              und das debug-log vom restore?
              bitte vollständig lesen und beachten:
                Moin,
                eigentlich wollte ich ja lieber einen Fruchtzwerg essen, aber der Nährwert ist auch zu gering und für Hefeweizen ist es zu früh :)
                Zudem, ich kann einfach nicht anders :)
                Das ist das, was ich mit 0,5 Liter und 0,1 Liter meinte, wenn das Backup 75 MB groß ist, dann ist es 3 bis 7 Mal so groß, wenn es im Speicher ausgepackt wird, dabei geht Dir der Speicher aus
                Bernd
                P.S.: der Adapter Discovery braucht nicht zu laufen, spart auch noch mal etwas Speicher.
                P.P.S.: Wie viele Adapter laufen denn auf dem Spender ioBroker, denn auch das wird Dir, selbst wenn Du das Backup hinbekommst, zur Falle, geh mal von ~75 MB pro Adapter aus, dann braucht das Betriebssystem ja auch noch was zum Arbeiten.
                P.P.P.S.: dan wurde Dir ja schon zwei mal gesagt, das Du Speicher durch X verschwendest
                X-Server:       true
                Desktop:
                Terminal:       tty
                • von.cartmanV Offline
                  von.cartman
                  @dp20eic sagte in BackItUp - Probleme mit wiederherstellung:
                  39 Prozesse am Laufen
                  du meinst falsches IMAGE für RASPI genomen?
                  HomoranH DJMarc75D ? 5 Antworten Letzte Antwort
                    was meinst du damit?
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      naja, eben nicht das LITE genommen !
                      Lehrling seit 1975 !!!
                      • DJMarc75D DJMarc75
                        @djmarc75 oder 32bit, oder ein fertiges Iobroker image, oder.....
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          39 Instanzen ??? Alter Verwalter... da sind ja 1 GB schon 4 mal überfordert ;)
                          oder.....
                          ja, es wird leider nichts im Detail geliefert :)
                            oder.....
                            @djmarc75 sagte in BackItUp - Probleme mit wiederherstellung:
                            39 Instanzen
                            wo steht was von Instanzen?
                            Prozesse sind auf OS-Ebene.
                            sind das nur iob Prozesse?
                              Moin,
                              Du hast ja schon Reaktionen auf diese Aussage bekommen, was bedeutet in Deinem Sprachgebrauch
                              Prozesse  ≠ Adapter
                              oder
                              Prozesse = Adapter
                              Wenn Du uns von Deinem Spender ioBroker die Informationen zeigen könntest, dann kann man da schauen und muss nicht raten.
                              iob diag
                              Bernd
                                Moin,
                                im Zweifel ja, es gibt da wohl immer ein Image für Desktop und eins für Server, meist wohl lite betitelt.
                                Wenn man sich auskennt, kann man auch aus dem Desktop Image die unnötigen Dinge nach der Installation wieder hinausschmeißen, ist aber unnötig kompliziert.
                                Bernd
                                  Moin,
                                  Bernd
                                  andreas.kerzel
                                  @dp20eic
                                  versuche gerade mit ioBroker Installation von einer Sysnolog auf einen Mini PC mit Proxmox umzuziehen. Proxmox läuft und die iOBroker Grund-Konfig auch. Nur wenn ich die Sicherung einspiele läuft nix mehr. Ich komme über einen Browser nicht mehr drauf. Keine Rekation mehr. Softwarestand ist aktuell und sowie bei Spender als auch Empfänger identisch.
                                  Auf was muss man achten?? IP Adresse würde sich ändern.
                                                       v.2023-04-16
                                  Operatingsystem:        Ubuntu 23.04
                                  Kernel:                 6.2.16-5-pve
                                  Installation:           lxc
                                  Timezone:               Etc/UTC (UTC, +0000)
                                  User-ID:                0
                                  X-Server:               false
                                  Nodejs-Installation:    /usr/bin/nodejs         v18.17.0
                                                          /usr/bin/node           v18.17.0
                                                          /usr/bin/npm            9.6.7
                                                          /usr/bin/npx            9.6.7
                                  MEMORY:
                                  Mem:             10G        308M         10G        122K        423M         10G
                                  Swap:           536M          0B        536M
                                  Total:           11G        308M         10G
                                  Active iob-Instances:   1
                                                          admin                   6.3.5
                                  Objects type: jsonl
                                  States  type: jsonl
                                    system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    system.adapter.web.0                    : web                   : ioBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  Objects:                10609
                                  States:                 9132
                                  17M     /opt/iobroker/iobroker-data/objects.jsonl
                                  2.4M    /opt/iobroker/iobroker-data/states.jsonl
                                  • A andreas.kerzel
                                    @dp20eic
                                                         v.2023-04-16
                                    Installation:           lxc
                                    User-ID:                0
                                    X-Server:               false
                                                            /usr/bin/npm            9.6.7
                                                            /usr/bin/npx            9.6.7
                                    MEMORY:
                                    Swap:           536M          0B        536M
                                    Total:           11G        308M         10G
                                                            admin                   6.3.5
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                10609
                                    States:                 9132
                                    @andreas-kerzel sagte in BackItUp - Probleme mit wiederherstellung:
                                    Nimm kein Interims-Release sondern ein LTS-Release, wenn es schon Ubuntu sein muss.
                                    Auch im LXC gilt: KEIN root!
                                    Zeitzone ist auch zu setzen.
                                      andreas.kerzel
                                      ich hatte vergessen zu erwähnen das ich mit Proxmox heute erst angefangen habe.
                                      Können wir deine Punkte einzeln und etwas verständlicher durchgehen???
                                      Sorry stehe wirklich noch am Anfang
                                      Danke dir
                                      • A andreas.kerzel
                                        Danke dir
                                        @andreas-kerzel
                                        Lies die Dokumentation dazu:
                                        https://www.iobroker.net/#de/documentation/install/proxmox.md
                                          @andreas-kerzel
                                          andreas.kerzel
                                          Danke dir. Bevor ich jetzt aber mir eine LTS Ubuntu Version von 20.04 runterlade die Frage ob du für ioBroker grundsätzlich eine anderes Template empfiehlst? Vorschläge nehme ich sehr gerne entgegen
