  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Shelly Plus 2PM und shuttercontrol [gelöst]
    5.1k
52 Beiträge 4 Kommentatoren 8.5k Aufrufe 3 Beobachtet
  • D docsnyder7
    2023-07-25 06:51:53.309 - info: admin.0 (1995) ==> Connected system.user.admin from ::ffff:192.168.178.72
    2023-07-25 06:53:30.157 - info: host.evccpi stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
    2023-07-25 06:53:30.165 - info: shuttercontrol.0 (16955) Got terminate signal TERMINATE_YOURSELF
    2023-07-25 06:53:30.168 - info: shuttercontrol.0 (16955) cleaned everything up...
    2023-07-25 06:53:30.171 - info: shuttercontrol.0 (16955) terminating
    2023-07-25 06:53:30.173 - info: shuttercontrol.0 (16955) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-25 06:53:30.205 - info: host.evccpi stopInstance system.adapter.shuttercontrol.0 send kill signal
    2023-07-25 06:53:30.583 - info: admin.0 (1995) <== Disconnect system.user.admin from ::ffff:192.168.178.72
    2023-07-25 06:53:30.738 - info: host.evccpi instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-25 06:53:33.237 - info: host.evccpi instance system.adapter.shuttercontrol.0 started with pid 16971
    2023-07-25 06:53:36.029 - info: shuttercontrol.0 (16971) starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.17.0, js-controller: 4.0.24
    2023-07-25 06:54:45.982 - info: homee.0 (13720) initialize 1 homeegrams
    2023-07-25 06:55:05.230 - info: homee.0 (13720) initialize 1 homeegrams
    2023-07-25 06:55:41.355 - info: admin.0 (1995) ==> Connected system.user.admin from ::ffff:192.168.178.72
    2023-07-25 06:55:54.486 - info: admin.0 (1995) <== Disconnect system.user.admin from ::ffff:192.168.178.72
    Guten Morgen...
    anbei die Einstellungen in shuttercontrol und das log von heute...
    aufgefallen ist mir, dass die Richtungspfeile im shuttercontrol grau bleiben, egal welchen eintrag aus dem shelly ich verwende..
    Prosst Kaffee
    @docsnyder7 sagte in Shelly Plus 2PM und shuttercontrol:
    das sind keine Richtungspfeile für die Rollläden, sondern für die Reihenfolge der konfigurierten Geräte. Bei nur einem Rollladen kann man die Reihenfolge nicht ändern.
    • D docsnyder7
      Guten Morgen...
      Prosst Kaffee
      T Nicht stören
      T Nicht stören
      ticaki
      @docsnyder7
      Damit schiebt man Geräte hoch runter. Die Pfeile haben nix mit der Position zu tun.
      https://github.com/simatec/ioBroker.shuttercontrol/blob/master/docs/de/shuttercontrol.md#grundlegendes
      Stelle den positionsstate dort ein, stelle das öffenen und schließen nach Uhrzeit so ein dass es passt und lass das mal in ruhe :) wenn er nicht öffnet und schließt können wir hier weiter machen.
      Für die ganzen anderen Funktionen brauchst du auch die entsprechenden Sensoren.
      Spenden
        leider kein debug-log.
        nimm mal nicht...(Automatik)
        docsnyder7
        @homoran hilf mir mal bitte bzgl debug log…im Reiter ist doch debug ausgewählt?
        Ok…mit den Pfeile hab ich kapiert 👍
        Ändere das ganze ab und lasse es mal stehen
        HomoranH OstfrieseUnterwegsO 2 Antworten Letzte Antwort
        • D docsnyder7
          bitte vollständig lesen!
          da steht alles drin.
          • D docsnyder7
            OstfrieseUnterwegsO Offline
            OstfrieseUnterwegs
            @docsnyder7 In dem screenshot sieht die ID komisch aus. Leerzeichen sollten da normalerweise nicht drin sein.
            Außerdem hast du bei Name 'Position' vergeben, da würde ich sowas nehmen wie 'Schlafzimmer.rechts.Position'
            • OstfrieseUnterwegsO OstfrieseUnterwegs
              docsnyder7
              @ostfrieseunterwegs
              da hab ich die ID wegretuschiert... Entschuldigung
              OstfrieseUnterwegsO 1 Antwort Letzte Antwort
              • T ticaki
                @docsnyder7
                docsnyder7
                @ticaki
                es gibt Position….level.blind. oder cover status…..state
                • D docsnyder7
                  @ticaki
                  @ticaki
                  das Feld ist frei beschreibbar, damit du weisst um welchen Rollladen es da geht.
                  bei vielen Rollläden wird es sonst unübersichtlich wenn alle Sensoren gleich heißen
                  • D docsnyder7
                    @ostfrieseunterwegs
                    OstfrieseUnterwegs
                    @docsnyder7 Kannst du denn im Objecttree mit der ID, die du dort eingetragen hast den Level/Position der Jalousie steuern? Also wenn du da 50 reinschreibst, geht sie dann auf 50% und fährt sie bei 0 und 100 die Endlagen an? Außerdem muss der Adapter wissen, ob 100=auf oder 100=zu ist (Ich hab gerade keine Shellys als shutter konfiguriert, deher weiss ich es nicht)
                      @ticaki
                      docsnyder7
                      @homoran das hab ich verstanden, aber bei dem einen Testrollo war das momentan nicht ganz so dramatisch…Aber prinzipiell werden die natürlich korrekt benannt
                        docsnyder7
                        @ostfrieseunterwegs ja das geht
                        100% sind auf
                        T OstfrieseUnterwegsO 2 Antworten Letzte Antwort
                        • D docsnyder7
                          100% sind auf
                          T Nicht stören
                          T Nicht stören
                          ticaki
                          @docsnyder7
                          Diesen State setzt du bei shuttercontrol ein, änderst den öffnungszeitpunkt auf jetzt +5Minuten und machst ihn zu. Dann warten.
                          Spenden
                            @docsnyder7
                            @homoran sagte in Shelly Plus 2PM und shuttercontrol:
                            hast du das geändert?
                            • D docsnyder7
                              100% sind auf
                              OstfrieseUnterwegs
                              Dann passt das soweit, Was anderes, als den Zielwert reinschreiben macht ja Shuttercontrol auch nicht.
                              Hast du das gesehen?
                              • Wohnbereich (Automatik):
                                Der Rollladen fährt zu den Zeiten wie in Einstellungen für den Wohnbereich konfiguriert und zusätzlich wird auf den unter Extra-Einstellungen festgelegten Trigger Objekt-ID zum aktivieren/deaktivieren des Auto-Wohnbereichs geachtet. Steht dieser auf false wird der Rollladen nicht automatisch gefahren.
                                @docsnyder7
                                docsnyder7
                                @homoran hab ich auf Wohnbereich ohne Automatik geändert
                                @OstfrieseUnterwegs das checke ich gleich
                                @ticaki das ist der Position….level.blind
                                • D docsnyder7
                                  docsnyder7
                                  So... erschlagt mich bitte nicht...
                                  Fehler gefunden.. mich hat gestört, dass die logs alle ne Stunden weniger anzeigen, als meine Uhr zeigte...
                                  da ich den PI erst die Tage auf 64 bit gewechselt hatte, ist mir wohl die zeitzone durchgerutscht😠
                                  Hab die geändert und siehe da, der shutter fährt!
                                  @Homoran
                                  @OstfrieseUnterwegs
                                  @ticaki
                                  ganz herzlichen Dank für eure Geduld und eure Hilfe!!!
                                  • D docsnyder7
                                    @Homoran
                                    @OstfrieseUnterwegs
                                    @ticaki
                                    T Nicht stören
                                    T Nicht stören
                                    ticaki
                                    @docsnyder7
                                    Den "Bug" hatte ich vor ein paar Tagen auch 😁 ... viel zu einfach, muß ja an was komplizierten liegen und man sucht und sucht...
                                    PEBCAK
                                    Spenden
                                    • T ticaki
                                      @docsnyder7
                                      PEBCAK
                                      docsnyder7
                                      @ticaki 😂
                                      • D docsnyder7
                                        @Homoran
                                        @OstfrieseUnterwegs
                                        @ticaki
                                        OstfrieseUnterwegs
                                        @docsnyder7 Jo, kommt vor. Das nimmt hier keiner übel.
                                        Editiere bitte mal das Thema der Threads und schreib [Gelöst] dazu
                                          docsnyder7
                                          @ostfrieseunterwegs
                                          Eine letzte Frage zum shuttercontrol….hab die Anleitung mehrere Male gelesen und einige Einstellungen gemacht….was mir aber nicht beantwortet wird… wenn ich keinen automatikmodus nehme, reagiert das Tool dann trotzdem, auf dem im Aktor hinterlegten Sensor? Der Sensor in den Extra-Einstellungen im hauptordner dient ja nur dem aktivieren der Automatik, was auch immer das sein könnte.
