  3. Einsteigerfragen
  4. [gelöst] sql Instanz wird immer beendet
    5.5k
39 Beiträge 6 Kommentatoren 5.0k Aufrufe 4 Beobachtet
    @init5
    iob stop
    iob fix
    iob start
    Wenn der ioBroker wieder am Start ist:
    iob diag
    Oder über die URL aus meiner Signatur.
    I Offline
    I Offline
    init5
    schrieb am zuletzt editiert von init5
    @thomas-braun Das hat funktioniert. Hier einmal der Output von iob diag. Für mich eher kryptisch.
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     22:27:50 up 16 days, 13 min,  2 users,  load average: 1.87, 0.93, 0.73
    CPU threads: 4
    Raspberry only:
    throttled=0x50000
    Other values than 0x0 hint to temperature/voltage problems
    temp=54.0'C
    volt=0.8500V
    *** Time and Time Zones ***
                   Local time: Fri 2023-06-30 22:27:51 CEST
               Universal time: Fri 2023-06-30 20:27:51 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        917M        2.3G         20M        629M        2.8G
    Swap:           99M         76M         23M
    Total:         3.9G        993M        2.3G
             3837 M total memory
              917 M used memory
              291 M active memory
             1077 M inactive memory
             2291 M free memory
              235 M buffer memory
              393 M swap cache
               99 M total swap
               76 M used swap
               23 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      110G   16G   88G  16% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G   17M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/114
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Wed Jun 14 22:13:55 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1280x720M@60D smsc95xx.macaddr=DC:A6:32:1D:FF:B9 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Wed Jun 14 22:13:57 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Wed Jun 14 22:13:57 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed Jun 14 22:13:58 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    TARGET               SOURCE     FSTYPE          OPTIONS
    /                    /dev/sda2  ext4            rw,noatime,stripe=8191
    |-/sys/fs/bpf        none       bpf             rw,nosuid,nodev,noexec,relatime,mode=700
    |-/run/user/114/gvfs gvfsd-fuse fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=114,group_id=123
    `-/boot              /dev/sda1  vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.0G    /var/
    2.4G    /var/cache/apt/archives
    2.4G    /var/cache/apt
    2.4G    /var/cache
    455M    /var/lib
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    824M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    521M    /opt/iobroker/iobroker-data/
    334M    /opt/iobroker/iobroker-data/files
    132M    /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    53M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    20M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.20.0
    /usr/bin/node           v16.20.0
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    nodejs:
      Installed: 16.20.0-deb-1nodesource1
      Candidate: 16.20.1-deb-1nodesource1
      Version table:
         16.20.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
     *** 16.20.0-deb-1nodesource1 100
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: dahuadorbell2mqtt@1.0.0 /opt/iobroker/node_modules/dahuadorbell2mqtt
    npm ERR!     /home/pi/.npm/_logs/2023-06-30T20_28_30_188Z-debug-0.log
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : IoT-RasPi-ioBroker-Master                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : IoT-RasPi-ioBroker-Master                -  enabled
    + system.adapter.backitup.0               : backitup              : IoT-RasPi-ioBroker-Master                -  enabled
    + system.adapter.backitup.1               : backitup              : IoT-raspi-ioBroker-slave1                -  enabled
      system.adapter.cloud.0                  : cloud                 : IoT-RasPi-ioBroker-Master                -  enabled
      system.adapter.daswetter.0              : daswetter             : IoT-RasPi-ioBroker-Master                -  enabled
      system.adapter.device-reminder.0        : device-reminder       : IoT-RasPi-ioBroker-Master                -  enabled
      system.adapter.devices.0                : devices               : IoT-RasPi-ioBroker-Master                -  enabled
    + system.adapter.discovery.0              : discovery             : IoT-RasPi-ioBroker-Master                -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : IoT-RasPi-ioBroker-Master                -  enabled
      system.adapter.flot.0                   : flot                  : IoT-RasPi-ioBroker-Master                - disabled
    + system.adapter.fritzdect.0              : fritzdect             : IoT-RasPi-ioBroker-Master                -  enabled
    + system.adapter.history.0                : history               : IoT-RasPi-ioBroker-Master                -  enabled
      system.adapter.ical.0                   : ical                  : IoT-RasPi-ioBroker-Master                -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : IoT-RasPi-ioBroker-Master                - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoT-RasPi-ioBroker-Master                - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IoT-RasPi-ioBroker-Master                - disabled
      system.adapter.iot.0                    : iot                   : IoT-RasPi-ioBroker-Master                -  enabled
      system.adapter.jarvis.0                 : jarvis                : IoT-RasPi-ioBroker-Master                -  enabled
    + system.adapter.javascript.0             : javascript            : IoT-RasPi-ioBroker-Master                -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : IoT-RasPi-ioBroker-Master                -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.oilfox.0                 : oilfox                : IoT-RasPi-ioBroker-Master                -  enabled
      system.adapter.rickshaw.0               : rickshaw              : IoT-RasPi-ioBroker-Master                - disabled
    + system.adapter.shelly.0                 : shelly                : IoT-RasPi-ioBroker-Master                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : IoT-RasPi-ioBroker-Master                -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.solarmanpv.0             : solarmanpv            : IoT-RasPi-ioBroker-Master                -  enabled
    + system.adapter.sonoff.0                 : sonoff                : IoT-RasPi-ioBroker-Master                -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : IoT-RasPi-ioBroker-Master                -  enabled, port: 3306
      system.adapter.statistics.0             : statistics            : IoT-RasPi-ioBroker-Master                -  enabled
    + system.adapter.synology.0               : synology              : IoT-RasPi-ioBroker-Master                -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : IoT-RasPi-ioBroker-Master                -  enabled
    + system.adapter.telegram.0               : telegram              : IoT-RasPi-ioBroker-Master                -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : IoT-RasPi-ioBroker-Master                -  enabled
      system.adapter.tr-064.0                 : tr-064                : IoT-RasPi-ioBroker-Master                - disabled
      system.adapter.vw-connect.0             : vw-connect            : IoT-RasPi-ioBroker-Master                -  enabled
    + system.adapter.weatherunderground.0     : weatherunderground    : IoT-RasPi-ioBroker-Master                -  enabled
    + system.adapter.web.0                    : web                   : IoT-RasPi-ioBroker-Master                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : IoT-raspi-ioBroker-slave1                -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alias-manager": 1.2.4    , installed 1.2.6
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "oilfox"       : 4.1.2    , installed 4.1.2
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        23130
    States:         22166
    Hit:1 http://phoscon.de/apt/deconz buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
    Reading package lists...
    Pending Updates: 28
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       23659867   28802/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17177      721/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          22279974   22821/cupsd
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       23659172   28519/io.shelly.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       23649924   28356/io.sonoff.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       23659156   28393/io.mqtt.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       23659157   28393/io.mqtt.0
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       23649712   28219/iobroker.js-c
    tcp        1      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       23649705   28219/iobroker.js-c
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          17382      710/vncserver-x11-c
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23649795   28238/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23659349   28659/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17179      721/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          22279973   22821/cupsd
    tcp6       0      0 :::3306                 :::*                    LISTEN      116        20717      945/mysqld
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          17381      710/vncserver-x11-c
    udp        0      0 0.0.0.0:38435           0.0.0.0:*                           108        17588      448/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       23655818   28341/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17811      698/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          22281098   22822/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17586      448/avahi-daemon: r
    udp6       0      0 :::50684                :::*                                108        17589      448/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          17823      698/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        17587      448/avahi-daemon: r
    2023-06-30 22:29:47.966  - info: cloud.0 (28729) Connection changed: connect
    2023-06-30 22:29:48.191  - info: fb-checkpresence.0 (28860) createMemberObjects finished successfully
    2023-06-30 22:29:48.431  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecast.1d.windDirectionMax" has to be type "string" but received type "number"
    2023-06-30 22:29:50.232  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecast.2d.icon" has to be type "string" but received type "number"
    2023-06-30 22:29:51.764  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecast.2d.windDirectionMax" has to be type "string" but received type "number"
    2023-06-30 22:29:54.191  - info: solarmanpv.0 (28866) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2023-06-30 22:29:54.447  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecast.3d.icon" has to be type "string" but received type "number"
    2023-06-30 22:29:55.180  - info: host.IoT-RasPi-ioBroker-Master instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-06-30 22:29:56.959  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecast.3d.windDirectionMax" has to be type "string" but received type "number"
    2023-06-30 22:29:59.036  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecastHourly.0h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-06-30 22:29:59.388  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecastHourly.1h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-06-30 22:29:59.704  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecastHourly.2h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-06-30 22:30:00.349  - info: fritzdect.0 (28620) DECT ID: 099950530805 identified for command (tsoll) : 18
    2023-06-30 22:30:00.404  - info: host.IoT-RasPi-ioBroker-Master instance system.adapter.solarmanpv.0 started with pid 29380
    2023-06-30 22:30:00.461  - info: fritzdect.0 (28620) DECT ID: 099950530805 identified for command (hkrmode) : 0
    2023-06-30 22:30:00.598  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecastHourly.3h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-06-30 22:30:01.108  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecastHourly.4h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-06-30 22:30:01.612  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecastHourly.5h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-06-30 22:30:02.106  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecastHourly.6h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-06-30 22:30:02.626  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecastHourly.7h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-06-30 22:30:03.025  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecastHourly.8h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-06-30 22:30:03.382  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecastHourly.9h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-06-30 22:30:03.832  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecastHourly.10h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-06-30 22:30:04.492  - info: host.IoT-RasPi-ioBroker-Master instance system.adapter.daswetter.0 started with pid 29395
    2023-06-30 22:30:04.573  - info: weatherunderground.0 (28378) State value to set for "weatherunderground.0.forecastHourly.11h.precipitation" has to be type "value.precipitation" but received type "number"
    • I init5
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        10
      Codename:       buster
      VERSION_ID="10"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x50000
      temp=54.0'C
      volt=0.8500V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M         76M         23M
               3837 M total memory
                917 M used memory
                291 M active memory
               2291 M free memory
                235 M buffer memory
                393 M swap cache
                 99 M total swap
                 76 M used swap
                 23 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      3.0G    /var/
      2.4G    /var/cache/apt
      2.4G    /var/cache
      455M    /var/lib
      /usr/bin/npm            8.19.4
      /usr/bin/npx            8.19.4
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        23130
      States:         22166
      Pending Updates: 28
      @init5 sagte in sql Instanz wird immer beendet:
      Tot, installier da Raspian OS 11 'Bullseye'. 64bit Lite.
      throttled=0x50000
      temp=54.0'C
      volt=0.8500V
      Netzteil wohl zu schwach auf der Brust. Die Kiste riegelt ab.
      X-Server: true
      Boot Target: graphical.target
      Auf Servern keine GUI/Desktop-Umgebung
      Kenn ich nicht, aber da ist irgendwas krumm.
      Pending Updates: 28
      Betriebssystem auf Stand halten.
      I 1 Antwort Letzte Antwort
        throttled=0x50000
        temp=54.0'C
        volt=0.8500V
        X-Server: true
        Pending Updates: 28
        I Offline
        I Offline
        init5
        @thomas-braun said in sql Instanz wird immer beendet:
        Ok, dazu habe ich eben eine Anleitung gefunden. Das scheint was größeres zu werden, wenn man nicht neu installieren will
        throttled=0x50000
        temp=54.0'C
        volt=0.8500V
        Woran siehst du das? Welcher Wert passt da nicht?
        X-Server: true
        Auf der Kiste lief früher Deconz, dafür was das damals einfacher. Kann man den Teil nachträglich deinstallieren?
        Das ist ein Skript aus diesem Forum, um der Türsprechanlage MQTT beizubringen. Da gibt es einen Fehler, aber meine JS-Kenntnisse erlauben leider kein debugging.
        Pending Updates: 28
        Ist behoben. Vielleicht reicht das und das iob fix ja schon, um es etwas zu stabilisieren.
        • I init5
          throttled=0x50000
          temp=54.0'C
          volt=0.8500V
          X-Server: true
          Pending Updates: 28
          Wechsel auf 64bit geht nur per Neuinstallation.
          • Thomas BraunT Online
            throttled=0x50000
            temp=54.0'C
            volt=0.8500V
            0x50000 ist nicht 0x0.
            Die Spannung ist sehr niedrig. Ergo wohl das Netzteil zu schwach.
            Ja, aber
            Dann kannste es auch gleich ohne Desktop (aka. Lite) installieren.
              I Offline
              I Offline
              init5
              Na super. Das Ding läuft seit Jahren. Das dauert Ewigkeiten das alles wiederherzustellen. Das wird mal ein Projekt für ein gesamtes Wochenende :D
              • I init5
                throttled=0x50000
                temp=54.0'C
                volt=0.8500V
                X-Server: true
                Pending Updates: 28
                Dann ist es ja ein guter Zeitpunkt für eine General-Sanierung.
                Ich würde dann aber noch ein paar Wochen abwarten, bis Raspberry OS 12 ' Bookworm' offiziell veröffentlicht wurde.
                  I Offline
                  I Offline
                  init5
                  Wird das dann automatisch von iobroker empfohlen, oder sollte man nach dem release dann erst noch warten, bis entsprechende Anpassungen erfolgt sind?
                  • I init5
                    @init5
                    ioBroker läuft auf 'Bookworm' ohne weiteres, weil ioBroker nur 'nodeJS' als Laufzeitumgebung braucht.
                    Hier z. B. mein derzeitiges System:
                              Kernel: Linux 6.1.21-v8+
                        Architecture: arm64
                    Kernel:                 aarch64
                    Userland:               arm64
                      @init5
                          Architecture: arm64
                      Kernel:                 aarch64
                      Userland:               arm64
                      I Offline
                      I Offline
                      init5
                      Ich habe mich nun endlich mal dazu durchgerungen, den ioBroker neu zu installieren. Also System einmal komplett platt gemacht, Raspian mit 64Bit drauf und ioBroker neu installiert. Leider hat das absolut nichts am Verhalten des SQL Adapters geändert. Irgendetwas sorgt um täglich um 2:02Uhr dafür, dass der SQL Adapter gestoppt und nicht mehr gestartet wird.
                        @init5
                        Dann schau zu dem Zeitpunkt in das journal.
                          @init5
                          I Offline
                          I Offline
                          init5
                          @thomas-braun Meinst du das Protokoll? Da stehen wieder nur die selben Einträge drin, wie schon vor der Neuinstallation.
                          2023-07-22 02:02:03.281 - info: host.IoT-raspi-iobroker-master instance "system.adapter.sql.0" disabled via .alive
                          2023-07-22 02:02:03.325 - info: host.IoT-raspi-iobroker-master "system.adapter.sql.0" disabled
                          2023-07-22 02:02:03.327 - info: host.IoT-raspi-iobroker-master stopInstance system.adapter.sql.0 (force=false, process=true)
                          2023-07-22 02:02:03.311 - info: sql.0 (1795) Adapter is disabled => stop
                          2023-07-22 02:02:03.366 - info: host.IoT-raspi-iobroker-master stopInstance system.adapter.sql.0 (force=false, process=true)
                          2023-07-22 02:02:03.369 - info: sql.0 (1795) Adapter is disabled => stop
                          2023-07-22 02:02:03.890 - info: sql.0 (1795) terminating
                          2023-07-22 02:02:03.892 - info: sql.0 (1795) Terminated (NO_ERROR): Without reason
                          2023-07-22 02:02:04.616 - info: host.IoT-raspi-iobroker-master instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
                          2023-07-22 02:02:04.617 - info: host.IoT-raspi-iobroker-master Do not restart adapter system.adapter.sql.0 because disabled or deleted
                          Der Zeit nach zu urteilen, habe ich noch immer den BackItUp Adapter im Verdacht. Ich vermute, der beendet alle laufenden Instanzen und vergisst dann den SQL wieder zu starten. Ich weiß aber nicht, was ich dagegen tun kann
                          • I init5
                            @init5
                            Dann schalte den Backitup mal testhalber aus oder leg den auf eine andere Zeit. Wenn sql dann immer noch rumspinnt liegt es nicht am Backitup... :-)
                              @init5
                              I Offline
                              I Offline
                              init5
                              @thomas-braun ok, wie vermutet. Ich habe das Backup wie vorgeschlagen um 2h nach hinten versschoben und nun stürzt auch der SQL Adapter 2h später ab. Also scheinen sich die beiden bei mir einfach nicht zu vertragen. Leider will ich auf keinen der Beiden so wirklich verzichten 🙄
                                Supermicha
                                Läuft deine SQL-Datenbank auch auf dem Raspi?
                                kann es sein, das sich die Datenbank beim Backup aufhängt wegen zuwenig RAM oder weil die Spannung zusammenbricht?
                                • S Supermicha
                                  I Offline
                                  I Offline
                                  init5
                                  @supermicha Das mit der Spannung kann ich mir nicht vorstellen. Der Raspi ist in meinem Verteilerschrank für TV und Netzwerk verbaut und hängt da an einem Meanwell Netzteil. Also kein billig Netzteil zum Handy laden. RAM könnte schon eher sein. Die SQL DB läuft mit auf dem Raspi. Dann werde ich die wohl umziehen müssen. Ich war davon ausgegangen, dass der Raspi4 mit 4GB das verkraftet.
                                  Thomas BraunT T 2 Antworten Letzte Antwort
                                  • I init5
                                    Kann man so generell nicht bewerten. Hängt halt vom jeweiligen Umfang der Installation ab.
                                    • I init5
                                      T Nicht stören
                                      T Nicht stören
                                      ticaki
                                      @init5
                                      du könntest wohl auch dir den Speicher rum die Zeit herum in eine Datei schreiben lassen
                                      nano /home/pi/getfree.sh
                                      #!/bin/bash
                                      i=180
                                      while [ $i -ge 1 ]
                                      do
                                        ((i--))
                                        /bin/free >> /home/pi/speicher.txt
                                        sleep 1
                                      done
                                      chmod 0770 /home/pi/getfree.sh
                                      crontab -e
                                      0 2 * * * /bin/free >> /home/pi/speicher.txt
                                      // speichern
                                      Das sollte dir um 2 Uhr für 3 Minuten jede sekunde den freien Speicher in die Datei speicher.txt schreiben. Keine Ahnung ob man dafür sudo oder root braucht. Und will keine Mecker von Thomas bekommen das ich jemanden rum rooten lasse :)
                                      EDIT: wenn du keinen Swap willst must das Skript so aussehen
                                      #!/bin/bash
                                      i=180
                                      while [ $i -ge 1 ]
                                      do
                                        ((i--))
                                        /bin/free | /bin/grep Mem: >> /home/pi/speicher.txt
                                        sleep 1
                                      done
                                      Spenden
                                      • T ticaki
                                        @init5
                                        #!/bin/bash
                                        i=180
                                        while [ $i -ge 1 ]
                                        do
                                          ((i--))
                                          sleep 1
                                        done
                                        crontab -e
                                        // speichern
                                        #!/bin/bash
                                        i=180
                                        while [ $i -ge 1 ]
                                        do
                                          ((i--))
                                          sleep 1
                                        done
                                        @ticaki
                                        Warum sollte es root Rechte brauchen? free kann jeder aufrufen.
                                          @ticaki
                                          T Nicht stören
                                          T Nicht stören
                                          ticaki
                                          @thomas-braun sagte in sql Instanz wird immer beendet:
                                          @ticaki
                                          Weiß ich nicht deshalb hab ichs geschrieben, und weil ich gerade mit free nicht klar komme. Das sagt 90% Auslastung davon 10% buffer/caches - htop sagt 50%... könnte ja an Rechten liegen. Ist aber auch nicht so wichtig.
                                          Spenden
