  4. Probleme mit HomeMatic RPC
168 Beiträge 32 Kommentatoren 45.9k Aufrufe 29 Beobachtet
    sunny9999
    #68
    Servus,
    seit ca. 1 Woche auch selbes Problem....
    Nach Update auf Node.js v18.16.1
    hm-rpc.0
    2023-07-20 07:09:39.961	info	new HMIP devices/channels after filter: 0
    hm-rpc.0
    2023-07-20 07:09:39.914	info	xmlrpc <- newDevices 135
    hm-rpc.0
    2023-07-20 07:09:39.722	info	xmlrpc -> 0 devices
    hm-rpc.0
    2023-07-20 07:09:39.676	info	xmlrpc <- listDevices ["IOBROKER:hm-rpc.0:f2527166436f6b3475572711cd4879fa"]
    hm-rpc.0
    2023-07-20 07:09:39.641	info	Connected
    hm-rpc.0
    2023-07-20 07:09:39.606	info	xmlrpc client is trying to connect to 192.168.30.22:2010/ with ["http://192.168.30.16:2010","IOBROKER:hm-rpc.0:f2527166436f6b3475572711cd4879fa"]
    hm-rpc.0
    2023-07-20 07:09:39.606	info	xmlrpc server is trying to listen on 192.168.30.16:2010
    hm-rpc.0
    2023-07-20 07:09:39.456	info	starting. Version 1.15.18 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.16.1, js-controller: 4.0.24
    hm-rpc.0
    2023-07-20 07:09:08.005	info	Terminated (NO_ERROR): Without reason
    hm-rpc.0
    2023-07-20 07:09:08.005	info	terminating
    hm-rpc.0
    2023-07-20 07:09:08.004	error	Cannot call init: [http://192.168.30.16:2010, ""] Unexpected end Line: 0 Column: 0 Char:
    hm-rpc.0
    2023-07-20 07:09:07.993	info	xmlrpc -> 192.168.30.22:2010/ init ["http://192.168.30.16:2010",""]
    hm-rpc.0
    2023-07-20 07:09:07.992	error	Init not possible, going to stop: Unexpected end Line: 0 Column: 0 Char:
    hm-rpc.0
    2023-07-20 07:08:37.993	error	Init not possible, going to stop: Unexpected end Line: 0 Column: 0 Char:
    hm-rpc.0
    2023-07-20 07:08:07.976	info	Disconnected
    hm-rpc.0
    2023-07-20 07:08:07.976	error	Ping error [IOBROKER:hm-rpc.0:65c87fdf10e9c7b9cb3cd1afde10f6d1]: Unexpected end Line: 0 Column: 0 Char:
    hm-rpc.0
    2023-07-20 07:06:37.957	info	Connected
    hm-rpc.0
    2023-07-20 07:06:27.847	info	Disconnected
    hm-rpc.0
    2023-07-20 07:06:27.847	error	Ping error [IOBROKER:hm-rpc.0:65c87fdf10e9c7b9cb3cd1afde10f6d1]: Unexpected end Line: 0 Column: 0 Char:
    hm-rpc.0
    2023-07-20 07:04:57.831	info	Connected
    hm-rpc.0
    2023-07-20 07:04:33.496	info	Disconnected
    hm-rpc.0
    2023-07-20 07:04:33.495	error	Ping error [IOBROKER:hm-rpc.0:65c87fdf10e9c7b9cb3cd1afde10f6d1]: Unexpected end Line: 0 Column: 0 Char:
    Alle 1-2 Stunden restartet der Adapter.....
    Sunny
      Str_n
      #69
      Das Problem lässt sich übrigens stabil reproduzieren, indem man die ping Zeit in den Adaptereinstellungen auf 10 Sekunden stellt. Nach ein paar Minuten ist es dann immer wieder da.
      Starte ich mit einem 2 Wochen alten Backup ist alles ok. Leider habe ich zu viel in der Zwischenzeit geupdated um noch nachzuvollziehen wer der Übeltäter war.
        ticaki
        #70
        @teletapi
        Proxmox ist sowas wie docker nur das es den ganzen Rechner kontrolliert und darauf läuft unter anderem auch iobroker.
        Spenden
        • FeuersturmF Offline
          FeuersturmF Offline
          Feuersturm
          #71
          Hat jemand auch das Problem mit einer Node.js Version ungleich v18.16.1?
          Die 18.16.1 ist glaub ich relativ frisch.
          F Thomas BraunT 2 Antworten Letzte Antwort
          • FeuersturmF Feuersturm
            Farmer-cb
            #72
            @feuersturm sagte in Probleme mit HomeMatic RPC:
            Node.js v16.20.0 (Es gibt eine neuere Version: v16.20.1 - Empfohlene Version v18.17.0)
            smartes Haus durch Digitalstrom, enocean, SPS S7-1215, Homematik, Shelly, Alexa, iobroker auf einem HP-mini mit Proxmox
              #73
              Und bereits durch 18.17.0 abgelöst.
              • teletapiT teletapi
                @homoran Das ist so nicht ganz richtig
                Ich hatte bis zur Host Version 5.0.6 überhaupt keine fehler, dann kam das Host Update zur 5.0.8.... Die 5.0.7 hatte ich garnicht auf dem Schirm. In jedem fall nach diesem Update fingen kurze Zeit später diese Fehler an. (Wie hier desöfteren beschrieben) dann habe ich auf das System wo die 5.0.8 drauf war zunächst die 4.0.24 geschrieben aber wieder kurze Zeit später waren die Fehler wieder da , das gleiche mit der 5.0.6. Da ich aber alle Woche eine komplett Sicherung meiner M.2 festplatte des raspi´s mache habe ich diese Sicherung (Hostversion 5.0.6) auf die Festplatte geschrieben das war vorgestern Abend. Und seiddem sind keine Fehler mehr aufgetaucht. Was für mich ganz klar auf das Hostupdate hindeutet. Was den fehler letztendlich aber verursacht in diesem Update kann ich daraus nicht ableiten.
                Und ja mir ist klar das es sich bei dem Host update um eine beta handelt und damit Fehler verursachen kann. Damit kann ich umgehen und deswegen wird von mir ständig vor und nach Updates Sicherungen erstellt
                #74
                @teletapi sagte in Probleme mit HomeMatic RPC:
                Ich hatte...
                aber das ist
                @homoran sagte in Probleme mit HomeMatic RPC:
                keine allgemeingültige Übereinstimmungen bei allen Betroffenen.
                teletapiT 1 Antwort Letzte Antwort
                  Ich hatte...
                  aber das ist
                  teletapiT Offline
                  teletapiT Offline
                  teletapi
                  #75
                  Bisher hatte ich keine weiteren Fehler nachdem ich das Backup (komplette Sicherung der Festplatte) drauf gezogen und gestern das Update auf die Node.js 18.7.0 und NPM 9.6.7 gemacht habe.
                  Host ist jetzt immer noch 5.0.6
                  iob Diag(2).txt
                  Im laufe des Tages werde ich aber auf meiner Ersatzplatte das gleiche machen und nochmal den Host auf 5.0.8 draufziehen m,al schauen was sich dann tut
                    iob Diag(2).txt
                    #76
                    das Problem tritt auch bei Usern mit host v4 auf
                      teletapiT Offline
                      teletapiT Offline
                      teletapi
                      schrieb am zuletzt editiert von teletapi
                      #77
                      @homoran said in Probleme mit HomeMatic RPC:
                      das könnte meine Vermutung stützen das ein Adapter mit verantwortlich ist
                      Wobei ich das jetzt hier nur einmal gelesen habe das die V4.XX betroffen ist
                      Die V4.XXX war bei mir ebenfalls betroffen aber nur wenn ich ein Downgrade von der 5.0.8 durchgeführt habe
                      Jetzt gerade habe ich eine 2te M.2 Festplatte mit meiner alten Sicherung beschrieben und alle Updates durchgeführt also ebenfalls neuster Stand und mache jetzt nochmal den Host 5.0.8 drauf mal schauen was dann kommt
                      Diesmal werde ich das Update des Host mal so probieren
                        #78
                        Vermutungen hatte ich auch, bis nach und nach jede einzelne davon von den Fakten bei anderen Usern widerlegt wurde.
                        Es muss ja etwas sein, das für alle gilt.
                          teletapiT Offline
                          teletapiT Offline
                          teletapi
                          #79
                          Und schon sind die fehler wieder da.
                            #80
                            das ist ja unstrittig!
                            aber
                            @ma sagte in Probleme mit HomeMatic RPC:
                            bin auf 4.0.24 (nie auf 5.x.x gewesen)
                            ...und bei anderen tauchte das Problem "vor ein paar Tagen" auf, ohne dass "irgendwas verändert" wurde.
                            • R Offline
                              rascal
                              #81
                              Ich habe, bevor die Probleme anfingen, auf nodejs 18 und den aktuellen Host ge-updated, auf einem Ubuntu System.
                              Jetzt habe ich einen Rasp 4 mit Ubuntu aufgesetzt, iobroker installiert und ein Backup mit Host 5.0.7 eingespielt.
                              Es ist npm 9.2.0 und nodejs 18.13.0 drauf.
                              Nach ein paar "Umzugsschwierigkeiten" läuft das System einmal ohne großartige Fehler.
                              R 1 Antwort Letzte Antwort
                                FeuersturmF Offline
                                Feuersturm
                                #82
                                Stellt doch einmal eure Instanz auf debug log Level. Vielleicht bekommen wir darüber noch etwas raus.
                                Auf meiner raspberrymatic (unter proxmox) läuft die Version 3.69.7.20230626
                                • R rascal
                                  rascal
                                  #83
                                  Ich habe wieder ein paar Fehlermeldunge....
                                  Zeit
                                  error
                                  Nachricht
                                  hm-rpc.2
                                  2023-07-20 12:31:41.339	error	Cannot call init: [http://192.168.1.226:2010, ""] Unexpected endLine: 0Column: 0Char:
                                  hm-rpc.2
                                  2023-07-20 12:31:41.323	error	Init not possible, going to stop: Unexpected endLine: 0Column: 0Char:
                                  hm-rpc.2
                                  2023-07-20 12:31:11.325	error	Init not possible, going to stop: Unexpected endLine: 0Column: 0Char:
                                  hm-rpc.2
                                  2023-07-20 12:30:41.305	error	Ping error [iobroker:hm-rpc.2:fb3416f7897b52e870029128aa102b2e]: Unexpected endLine: 0Column: 0Char:
                                  hm-rpc.2
                                  2023-07-20 12:30:15.451	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
                                  hm-rpc.2
                                  2023-07-20 12:30:15.449	error	xmlrpc -> setValue ["001118A9A58F1B:4","LEVEL",0] FLOAT
                                  hm-rpc.2
                                  2023-07-20 12:30:13.448	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
                                  hm-rpc.2
                                  2023-07-20 12:30:13.447	error	xmlrpc -> setValue ["00111A49A8DE25:4","LEVEL",0] FLOAT
                                  hm-rpc.2
                                  2023-07-20 12:30:09.450	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
                                  hm-rpc.2
                                  2023-07-20 12:30:09.449	error	xmlrpc -> setValue ["00111D89AB034E:4","LEVEL",0] FLOAT
                                  hm-rpc.2
                                  2023-07-20 12:29:57.679	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
                                  hm-rpc.2
                                  2023-07-20 12:29:57.678	error	xmlrpc -> setValue ["001118A9925408:4","LEVEL",0] FLOAT
                                  hm-rpc.2
                                  2023-07-20 12:29:56.675	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
                                  hm-rpc.2
                                  2023-07-20 12:29:56.674	error	xmlrpc -> setValue ["001118A9A58F1B:4","LEVEL",0] FLOAT
                                  hm-rpc.2
                                  2023-07-20 12:29:54.684	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
                                  hm-rpc.2
                                  2023-07-20 12:29:54.683	error	xmlrpc -> setValue ["00111A49A8DE25:4","LEVEL",0] FLOAT
                                  das sind alles HM-IP Rolladenaktoren, die Datenpunkte sind allerdings vorhanden und die Rolläden werden auch gefahren, trotz der Fehlermeldungen.
                                  • L Offline
                                    Lucky_ESA
                                    schrieb am zuletzt editiert von Lucky_ESA
                                    #84
                                    könnt ihr mal Sentry für die netroffenen Instanzen deaktivieren.
                                    Ich habe seit dem kein Problem mehr...Kann aber auch Zufall sein. Bei mir kam das Thema mit einem Update auf 5.0.8.
                                    Edit:
                                    Wer nicht weiß wie es geht. Den grünen Button drücken:
                                    Gruß//Lucky
                                    D S FeuersturmF M T 6 Antworten Letzte Antwort
                                    • L Lucky_ESA
                                      Edit:
                                      Gruß//Lucky
                                      darkiop
                                      #85
                                      @lucky_esa
                                      Kann ich bestätigen.
                                      js-controller 5.0.8
                                      npm 9.6.7
                                      node 18.17.0
                                      Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                                      • L Lucky_ESA
                                        Edit:
                                        Gruß//Lucky
                                        Str_n
                                        #86
                                        @lucky_esa
                                        Das sieht gut aus bei mir. Habe die Ping Zeit im Adapter auf 10 Sekunden gestellt. Nach spätestens 5 Minuten ist der Fehler dann da. Mit deaktiviertem Sentry scheint der Fehler nicht mehr zu kommen.
                                          darkiop
                                          #87
                                          Klingt nach einen Fall für Ingo :) @apollon77
