  3. Einsteigerfragen
  4. Zigbee lässt sich nicht verbinden
    5.5k
50 Beiträge 6 Kommentatoren 7.5k Aufrufe 6 Beobachtet
  • S Shakira1972
    @oliver1972 hab mal ZigBee Neu Installiert, funktioniert immer noch nicht, COM-Anschlussname einggegeben; hier die ganzen Fehlermeldungen:
    host.raspberrypi
    	2023-07-17 16:20:45.355	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
    host.raspberrypi
    	2023-07-17 16:20:45.355	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.raspberrypi
    	2023-07-17 16:20:45.355	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.raspberrypi
    	2023-07-17 16:20:45.355	error	Caught by controller[1]: at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:345:18)
    host.raspberrypi
    	2023-07-17 16:20:45.355	error	Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
    host.raspberrypi
    	2023-07-17 16:20:45.354	error	Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
    host.raspberrypi
    	2023-07-17 16:20:45.354	error	Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
    host.raspberrypi
    	2023-07-17 16:20:45.354	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
    host.raspberrypi
    	2023-07-17 16:20:45.354	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
    host.raspberrypi
    	2023-07-17 16:20:45.353	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    	2023-07-17 16:20:44.747	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    	2023-07-17 16:20:44.745	info	terminating
    zigbee.0
    	2023-07-17 16:20:44.259	info	Zigbee: disabling joining new devices.
    zigbee.0
    	2023-07-17 16:20:44.244	info	cleaned everything up...
    zigbee.0
    	2023-07-17 16:20:44.223	error	Cannot read properties of undefined (reading 'Error')
    zigbee.0
    	2023-07-17 16:20:44.222	error	TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:345:18)
    zigbee.0
    	2023-07-17 16:20:44.171	error	unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
    zigbee.0
    	2023-07-17 16:20:44.170	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2023-07-17 16:20:44.168	error	Error herdsman start
    zigbee.0
    	2023-07-17 16:20:44.167	error	Failed to start Zigbee
    zigbee.0
    	2023-07-17 16:20:44.166	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    	2023-07-17 16:20:43.992	error	Re-commissioning your network will require re-pairing of all devices!
    zigbee.0
    	2023-07-17 16:20:43.990	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0
    	2023-07-17 16:20:43.990	error	Please update configuration to prevent further issues.
    zigbee.0
    	2023-07-17 16:20:43.989	error	- Channel List: configured=11, adapter=12
    zigbee.0
    	2023-07-17 16:20:43.988	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0
    	2023-07-17 16:20:43.987	error	- Extended PAN ID: configured=00124b0024c69259, adapter=00124b0024c69259
    zigbee.0
    	2023-07-17 16:20:43.985	error	- PAN ID: configured=6754, adapter=6754
    zigbee.0
    	2023-07-17 16:20:43.984	error	Configuration is not consistent with adapter state/backup!
    zigbee.0
    	2023-07-17 16:20:43.757	info	Installed Version: iobroker.zigbee@1.8.16
    zigbee.0
    	2023-07-17 16:20:42.742	info	Starting Zigbee npm ...
    zigbee.0
    	2023-07-17 16:20:42.739	info	delete old Backup files. keep only last 10
    zigbee.0
    	2023-07-17 16:20:42.525	info	starting. Version 1.8.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
    host.raspberrypi
    	2023-07-17 16:20:37.514	info	instance system.adapter.zigbee.0 started with pid 198235
    admin.0
    	2023-07-17 16:20:34.464	info	<== Disconnect system.user.admin from ::ffff:192.168.178.70
    admin.0
    	2023-07-17 16:20:31.235	info	==> Connected system.user.admin from ::ffff:192.168.178.70
    host.raspberrypi
    	2023-07-17 16:20:20.179	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.raspberrypi
    	2023-07-17 16:20:20.179	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.raspberrypi
    	2023-07-17 16:20:20.179	error	Caught by controller[1]: at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:345:18)
    host.raspberrypi
    	2023-07-17 16:20:20.179	error	Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
    host.raspberrypi
    	2023-07-17 16:20:20.178	error	Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
    host.raspberrypi
    	2023-07-17 16:20:20.178	error	Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
    host.raspberrypi
    	2023-07-17 16:20:20.178	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
    host.raspberrypi
    	2023-07-17 16:20:20.178	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
    host.raspberrypi
    	2023-07-17 16:20:20.178	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    	2023-07-17 16:20:19.576	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    	2023-07-17 16:20:19.574	info	terminating
    zigbee.0
    	2023-07-17 16:20:19.073	info	Zigbee: disabling joining new devices.
    zigbee.0
    	2023-07-17 16:20:19.065	info	cleaned everything up...
    zigbee.0
    	2023-07-17 16:20:19.041	error	Cannot read properties of undefined (reading 'Error')
    zigbee.0
    	2023-07-17 16:20:19.040	error	TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:345:18)
    zigbee.0
    	2023-07-17 16:20:19.000	error	unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
    zigbee.0
    	2023-07-17 16:20:18.999	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2023-07-17 16:20:18.998	error	Error herdsman start
    zigbee.0
    	2023-07-17 16:20:18.998	error	Failed to start Zigbee
    zigbee.0
    	2023-07-17 16:20:18.997	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    	2023-07-17 16:20:18.856	error	Re-commissioning your network will require re-pairing of all devices!
    zigbee.0
    	2023-07-17 16:20:18.855	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0
    	2023-07-17 16:20:18.854	error	Please update configuration to prevent further issues.
    zigbee.0
    	2023-07-17 16:20:18.854	error	- Channel List: configured=11, adapter=12
    zigbee.0
    	2023-07-17 16:20:18.853	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0
    	2023-07-17 16:20:18.853	error	- Extended PAN ID: configured=00124b0024c69259, adapter=00124b0024c69259
    zigbee.0
    	2023-07-17 16:20:18.851	error	- PAN ID: configured=6754, adapter=6754
    zigbee.0
    	2023-07-17 16:20:18.850	error	Configuration is not consistent with adapter state/backup!
    zigbee.0
    	2023-07-17 16:20:18.661	info	Installed Version: iobroker.zigbee@1.8.16
    zigbee.0
    	2023-07-17 16:20:17.905	info	Starting Zigbee npm ...
    zigbee.0
    	2023-07-17 16:20:17.902	info	delete old Backup files. keep only last 10
    zigbee.0
    	2023-07-17 16:20:17.771	info	starting. Version 1.8.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
    admin.0
    	2023-07-17 16:20:12.829	info	<== Disconnect system.user.admin from ::ffff:192.168.178.70
    host.raspberrypi
    	2023-07-17 16:20:12.580	info	instance system.adapter.zigbee.0 started with pid 197761
    host.raspberrypi
    	2023-07-17 16:20:05.362	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.raspberrypi
    	2023-07-17 16:20:05.362	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.raspberrypi
    	2023-07-17 16:20:05.362	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.raspberrypi
    	2023-07-17 16:20:05.361	error	Caught by controller[1]: at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:345:18)
    host.raspberrypi
    	2023-07-17 16:20:05.361	error	Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
    host.raspberrypi
    	2023-07-17 16:20:05.361	error	Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
    host.raspberrypi
    	2023-07-17 16:20:05.361	error	Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
    host.raspberrypi
    	2023-07-17 16:20:05.361	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
    host.raspberrypi
    	2023-07-17 16:20:05.361	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
    host.raspberrypi
    	2023-07-17 16:20:05.360	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    	2023-07-17 16:20:04.769	info	Installed Version: iobroker.zigbee@1.8.16
    zigbee.0
    	2023-07-17 16:20:04.737	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    	2023-07-17 16:20:04.736	info	terminating
    zigbee.0
    	2023-07-17 16:20:04.735	warn	Failed to stop zigbee during startup
    zigbee.0
    	2023-07-17 16:20:04.717	info	Zigbee: disabling joining new devices.
    zigbee.0
    	2023-07-17 16:20:04.704	info	cleaned everything up...
    zigbee.0
    	2023-07-17 16:20:04.686	error	Cannot read properties of undefined (reading 'Error')
    zigbee.0
    	2023-07-17 16:20:04.686	error	TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:345:18) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    zigbee.0
    	2023-07-17 16:20:04.669	error	unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
    zigbee.0
    	2023-07-17 16:20:04.667	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2023-07-17 16:20:04.666	error	Error herdsman start
    zigbee.0
    	2023-07-17 16:20:04.666	error	Failed to start Zigbee
    zigbee.0
    	2023-07-17 16:20:04.664	error	Starting zigbee-herdsman problem : "No path provided and failed to auto detect path"
    zigbee.0
    	2023-07-17 16:20:03.783	info	Starting Zigbee npm ...
    zigbee.0
    	2023-07-17 16:20:03.781	info	delete old Backup files. keep only last 10
    zigbee.0
    	2023-07-17 16:20:03.485	error	Serial port not selected! Go to settings page.
    zigbee.0
    	2023-07-17 16:20:03.433	info	starting. Version 1.8.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
    admin.0
    	2023-07-17 16:19:59.289	info	==> Connected system.user.admin from ::ffff:192.168.178.70
    host.raspberrypi
    	2023-07-17 16:19:58.987	info	instance system.adapter.zigbee.0 started with pid 197256
    host.raspberrypi
    	2023-07-17 16:19:56.962	info	iobroker exit 0
    host.raspberrypi
    	2023-07-17 16:19:55.905	info	iobroker host.raspberrypi object system.adapter.zigbee.0 created
    host.raspberrypi
    	2023-07-17 16:19:55.884	info	iobroker host.raspberrypi Set default value of zigbee.0.info.debugmessages:
    host.raspberrypi
    	2023-07-17 16:19:55.879	info	iobroker host.raspberrypi Set default value of zigbee.0.info.undefinedDevices:
    host.raspberrypi
    	2023-07-17 16:19:55.873	info	iobroker host.raspberrypi Set default value of zigbee.0.info.groups:
    host.raspberrypi
    	2023-07-17 16:19:55.868	info	iobroker host.raspberrypi Set default value of zigbee.0.info.pairingMessage:
    host.raspberrypi
    	2023-07-17 16:19:55.862	info	iobroker host.raspberrypi Set default value of zigbee.0.info.pairingCountdown: 0
    host.raspberrypi
    	2023-07-17 16:19:55.857	info	iobroker host.raspberrypi Set default value of zigbee.0.info.pairingMode: false
    host.raspberrypi
    	2023-07-17 16:19:55.851	info	iobroker host.raspberrypi Set default value of zigbee.0.info.connection: false
    host.raspberrypi
    	2023-07-17 16:19:55.846	info	iobroker host.raspberrypi Set default value of zigbee.0.exclude.all: []
    host.raspberrypi
    	2023-07-17 16:19:55.840	info	iobroker host.raspberrypi object zigbee.0.info.debugmessages created
    host.raspberrypi
    	2023-07-17 16:19:55.832	info	iobroker host.raspberrypi object zigbee.0.info.undefinedDevices created
    host.raspberrypi
    	2023-07-17 16:19:55.824	info	iobroker host.raspberrypi object zigbee.0.info.groups created
    host.raspberrypi
    	2023-07-17 16:19:55.816	info	iobroker host.raspberrypi object zigbee.0.info.pairingMessage created
    host.raspberrypi
    	2023-07-17 16:19:55.807	info	iobroker host.raspberrypi object zigbee.0.info.pairingCountdown created
    host.raspberrypi
    	2023-07-17 16:19:55.799	info	iobroker host.raspberrypi object zigbee.0.info.pairingMode created
    host.raspberrypi
    	2023-07-17 16:19:55.791	info	iobroker host.raspberrypi object zigbee.0.info.connection created
    host.raspberrypi
    	2023-07-17 16:19:55.783	info	iobroker host.raspberrypi object zigbee.0.info created
    host.raspberrypi
    	2023-07-17 16:19:55.776	info	iobroker host.raspberrypi object zigbee.0.exclude.all created
    host.raspberrypi
    	2023-07-17 16:19:55.767	info	iobroker host.raspberrypi object zigbee.0.exclude created
    host.raspberrypi
    	2023-07-17 16:19:55.754	info	iobroker host.raspberrypi object system.adapter.zigbee.0.logLevel created
    host.raspberrypi
    	2023-07-17 16:19:55.741	info	iobroker host.raspberrypi object system.adapter.zigbee.0.sigKill created
    host.raspberrypi
    	2023-07-17 16:19:55.728	info	iobroker host.raspberrypi object system.adapter.zigbee.0.eventLoopLag created
    host.raspberrypi
    	2023-07-17 16:19:55.715	info	iobroker host.raspberrypi object system.adapter.zigbee.0.outputCount created
    host.raspberrypi
    	2023-07-17 16:19:55.702	info	iobroker host.raspberrypi object system.adapter.zigbee.0.inputCount created
    host.raspberrypi
    	2023-07-17 16:19:55.687	info	iobroker host.raspberrypi object system.adapter.zigbee.0.uptime created
    host.raspberrypi
    	2023-07-17 16:19:55.673	info	iobroker host.raspberrypi object system.adapter.zigbee.0.memRss created
    host.raspberrypi
    	2023-07-17 16:19:55.661	info	iobroker host.raspberrypi object system.adapter.zigbee.0.memHeapTotal created
    host.raspberrypi
    	2023-07-17 16:19:55.649	info	iobroker host.raspberrypi object system.adapter.zigbee.0.memHeapUsed created
    host.raspberrypi
    	2023-07-17 16:19:55.639	info	iobroker host.raspberrypi object system.adapter.zigbee.0.cputime created
    host.raspberrypi
    	2023-07-17 16:19:55.628	info	iobroker host.raspberrypi object system.adapter.zigbee.0.cpu created
    host.raspberrypi
    	2023-07-17 16:19:55.612	info	iobroker host.raspberrypi object system.adapter.zigbee.0.compactMode created
    host.raspberrypi
    	2023-07-17 16:19:55.601	info	iobroker host.raspberrypi object system.adapter.zigbee.0.connected created
    host.raspberrypi
    	2023-07-17 16:19:55.589	info	iobroker host.raspberrypi object system.adapter.zigbee.0.alive created
    host.raspberrypi
    	2023-07-17 16:19:55.574	info	iobroker host.raspberrypi create instance zigbee
    host.raspberrypi
    	2023-07-17 16:19:55.481	info	iobroker host.raspberrypi object system.adapter.zigbee created/updated
    host.raspberrypi
    	2023-07-17 16:19:55.384	info	iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
    host.raspberrypi
    	2023-07-17 16:19:55.374	info	iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
    host.raspberrypi
    	2023-07-17 16:19:55.363	info	iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
    host.raspberrypi
    	2023-07-17 16:19:55.342	info	iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
    host.raspberrypi
    	2023-07-17 16:19:55.330	info	iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
    host.raspberrypi
    	2023-07-17 16:19:55.320	info	iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
    host.raspberrypi
    	2023-07-17 16:19:55.309	info	iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
    host.raspberrypi
    	2023-07-17 16:19:55.289	info	iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
    host.raspberrypi
    	2023-07-17 16:19:55.279	info	iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
    host.raspberrypi
    	2023-07-17 16:19:55.267	info	iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
    host.raspberrypi
    	2023-07-17 16:19:55.255	info	iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
    host.raspberrypi
    	2023-07-17 16:19:55.245	info	iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
    host.raspberrypi
    	2023-07-17 16:19:55.234	info	iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
    host.raspberrypi
    	2023-07-17 16:19:55.224	info	iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
    host.raspberrypi
    	2023-07-17 16:19:55.213	info	iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
    host.raspberrypi
    	2023-07-17 16:19:55.204	info	iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
    host.raspberrypi
    	2023-07-17 16:19:55.195	info	iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
    host.raspberrypi
    	2023-07-17 16:19:55.185	info	iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
    host.raspberrypi
    	2023-07-17 16:19:55.176	info	iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
    host.raspberrypi
    	2023-07-17 16:19:55.166	info	iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
    host.raspberrypi
    	2023-07-17 16:19:55.156	info	iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
    host.raspberrypi
    	2023-07-17 16:19:55.077	info	iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
    host.raspberrypi
    	2023-07-17 16:19:54.996	info	iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
    host.raspberrypi
    	2023-07-17 16:19:54.921	info	iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
    host.raspberrypi
    	2023-07-17 16:19:54.846	info	iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/plug.png img/plug.png image/png
    host.raspberrypi
    	2023-07-17 16:19:54.771	info	iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ltc021.png img/philips_hue_ltc021.png image/png
    host.raspberrypi
    	2023-07-17 16:19:54.697	info	iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_e27_ambiance.png img/philips_hue_e27_ambiance.png image/png
    host.raspberrypi
    	2023-07-17 16:19:54.594	info	iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ambiance.png img/philips_hue_ambiance.png image/png
    host.raspberrypi
    	2023-07-17 16:19:54.520	info	iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_amaze.png img/philips_amaze.png image/png
    host.raspberrypi
    	2023-07-17 16:19:54.167	info	iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lh_32Zb.png img/lh_32Zb.png image/png
    host.raspberrypi
    	2023-07-17 16:19:53.779	info	iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
    host.raspberrypi
    	2023-07-17 16:19:53.418	info	iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_motion.png img/bitron_motion.png image/png
    host.raspberrypi
    	2023-07-17 16:19:53.084	info	iobroker upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
    host.raspberrypi
    	2023-07-17 16:19:52.884	info	iobroker upload [322] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
    host.raspberrypi
    	2023-07-17 16:19:52.818	info	iobroker host.raspberrypi install adapter zigbee
    host.raspberrypi
    	2023-07-17 16:19:52.758	info	iobroker added 53 packages in 20s131 packages are looking for funding run `npm fund` for details
    host.raspberrypi
    	2023-07-17 16:19:52.756	info	iobroker
    host.raspberrypi
    	2023-07-17 16:19:31.999	info	iobroker Installing iobroker.zigbee@1.8.16... (System call)
    host.raspberrypi
    	2023-07-17 16:19:31.993	info	iobroker NPM version: 9.5.1
    @oliver1972 sagte in Zigbee lässt sich nicht verbinden:
    Die Einstellungen müssen deckungsgleich sein. Beim Kanal hast du aber eine Abweichung drin. Prüf die anderen Dinge auch.
      Shakira1972
      @thomas-braun hab den Kanal richtiggestellt, trotzdem funktioniert es nicht. Bei den anderen Dingen konnte ich nichts finden. Hab auf der Alten SD Karte, also auf den Raspberry 32BIT System, den ZigBee Stick mit der Neuesten Software geupdatetet und dann nochmal einen Versuch gestartet, aber es bleiben immer die gleichen Verbindungsprobleme. Ist es möglich, das das Backup, das ich von 32Bit System auf den Neuen 64Bit System hochgeladen habe, die Probleme verursacht?
      • S Shakira1972
        @oliver1972
        Eigentlich ist die Architektur dem Backup egal, es handelt sich ja nicht um kompilierten Code.
        • S Shakira1972
          ich habe einen Zigbee Sonoff 3.0 usb, ich hatte diesen in einen Raspberry 32 Bit im Einsatz, hat immer alles funktioniert. Nun habe ich auf einer Neuen SD Karte, ein 64Bit System hochgeladen, IoBroker installiert und das Backup hochgeladen.
          Soweit gut, nun habe ich bemerkt, das mein Zigbee nicht funktioniert. Also wollte ich den Com Anschlussname herauslesen, was aber nicht funktioniert hat. Darauf habe ich nach der Anleitungen, dieses Forum Beitrages ```
          hier das Problem gelöst. Den Com Anschluss eingetragen, trotzdem funktioniert er nicht. Ich bekomme eine Reihe von Fehlermeldungen:
          host.raspberrypi
          2023-07-14 20:38:50.112 info Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
          host.raspberrypi
          2023-07-14 20:38:50.111 error instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
          zigbee.0
          2023-07-14 20:38:49.527 warn Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
          zigbee.0
          2023-07-14 20:38:49.451 error adapter disabled
          host.raspberrypi
          2023-07-14 20:38:17.706 info "system.adapter.zigbee.0" disabled
          host.raspberrypi
          2023-07-14 20:38:15.293 info Restart adapter system.adapter.zigbee.0 because enabled
          host.raspberrypi
          2023-07-14 20:38:15.293 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          host.raspberrypi
          2023-07-14 20:38:15.293 error Caught by controller[1]: at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:345:18)
          host.raspberrypi
          2023-07-14 20:38:15.292 error Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
          host.raspberrypi
          2023-07-14 20:38:15.292 error Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
          host.raspberrypi
          2023-07-14 20:38:15.292 error Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
          host.raspberrypi
          2023-07-14 20:38:15.292 error Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
          host.raspberrypi
          2023-07-14 20:38:15.292 error Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
          host.raspberrypi
          2023-07-14 20:38:15.292 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          zigbee.0
          2023-07-14 20:38:14.733 info debug devices set to []
          zigbee.0
          2023-07-14 20:38:14.732 info Installed Version: iobroker.zigbee@1.8.16
          zigbee.0
          2023-07-14 20:38:14.699 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
          zigbee.0
          2023-07-14 20:38:14.697 info terminating
          zigbee.0
          2023-07-14 20:38:14.696 warn Failed to stop zigbee during startup
          zigbee.0
          2023-07-14 20:38:14.641 info Zigbee: disabling joining new devices.
          zigbee.0
          2023-07-14 20:38:14.349 info cleaned everything up...
          zigbee.0
          2023-07-14 20:38:14.001 error Cannot read properties of undefined (reading 'Error')
          zigbee.0
          2023-07-14 20:38:13.999 error TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:345:18)
          zigbee.0
          2023-07-14 20:38:13.976 error unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
          zigbee.0
          2023-07-14 20:38:13.975 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          zigbee.0
          2023-07-14 20:38:13.973 error Error herdsman start
          zigbee.0
          2023-07-14 20:38:13.972 error Failed to start Zigbee
          zigbee.0
          2023-07-14 20:38:13.971 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0afb8cee4fc9eb119b7a8b4f1d69213e-if00-port0 '"
          zigbee.0
          2023-07-14 20:38:13.621 info Starting Zigbee npm ...
          zigbee.0
          2023-07-14 20:38:13.619 info delete old Backup files. keep only last 10
          zigbee.0
          2023-07-14 20:38:13.492 info starting. Version 1.8.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
          host.raspberrypi
          2023-07-14 20:38:08.412 info instance system.adapter.zigbee.0 started with pid 162680
          host.raspberrypi
          2023-07-14 20:38:07.836 info instance system.adapter.zigbee.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          zigbee.0
          2023-07-14 20:38:07.598 info starting. Version 1.8.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
          zigbee.0
          2023-07-14 20:38:07.233 info Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          host.raspberrypi
          2023-07-14 20:38:06.339 info stopInstance system.adapter.zigbee.0 killing pid 162286
          host.raspberrypi
          2023-07-14 20:38:05.337 info stopInstance system.adapter.zigbee.0 send kill signal
          host.raspberrypi
          2023-07-14 20:38:05.261 info stopInstance system.adapter.zigbee.0 (force=false, process=true)
          host.raspberrypi
          2023-07-14 20:38:02.486 info instance system.adapter.zigbee.0 started with pid 162286
          host.raspberrypi
          2023-07-14 20:38:02.413 info "system.adapter.zigbee.0" enabled
          Woran kann das liegen, wenn ich die Alte SD mit den 32 Bit System wieder in Raspberry lege, funktioniert alles?
          Oliver
          @oliver1972
          Installier doch mal die Version 1.8.18 vom Zigbee-Adapter... vielleicht gehts ja damit.. ?
          Glaub die 1.8.16 hatte nochn paar Fehlerchen...
            @oliver1972
            Shakira1972
            @thomas-braun @ilovegym hat leider auch nichts gebracht. Die selben Fehlermeldungen mit 1.8.18 .
            Habe einen weiteren Test mit einer weiteren SD Karte gemacht. Formatiert, Raspberry 64Bit installiert. IoBroker Installiert und dazu nur ZigBee, nichts anderes.
            Darauf musste ich wieder Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev) machen und den COM Anschluss eingeben. Auch auf dieser SD kommen die gleichen Fehler, somit kann ich das Backup, was ich bei der einen hochgeladen habe, als Fehlerquelle 100% ausschließen.
            Warum funktioniert der Sonoff Zigbee Stick beim 32Bit System ohne Probleme und bei den nun zwei 64Bit Systemen nicht?
            Könnte dieses 247.3-7+deb11u4 Schuld sein?
            • S Shakira1972
              @oliver1972
              Nein, die Version von udev funktioniert.
              • Matthias 0M Offline
                Matthias 0M Offline
                Matthias 0
                schrieb am zuletzt editiert von Matthias 0
                Guten Tag zusammen,
                ich versuche nun auch seit mehreren Tagen erfolglos meinen Sonoff Zigbee 3.0 plus Stick über meine Proxmox Umgebung in den IOBroker Adapter zu integrieren.
                Ich habe verschiedene Möglichkeiten, dass gerät an meinen LXC durchzureichen probiert.
                Leider bislang ohne Erfolg. Vielleicht kann mir hier jemand einen entscheiden Tipp geben, wo es denn hängt....
                Hier das LOG
                2023-07-19 11:06:05.005  - info: host.IOBroker Restart adapter system.adapter.zigbee.0 because enabled
                2023-07-19 11:06:05.005  - warn: host.IOBroker Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                2023-07-19 11:06:09.894  - info: admin.0 (338) <== Disconnect system.user.admin from ::ffff:192.168.2.32
                2023-07-19 11:07:24.942  - info: host.IOBroker "system.adapter.zigbee.0" disabled
                2023-07-19 11:07:27.835  - info: admin.0 (338) ==> Connected system.user.admin from ::ffff:192.168.2.32
                2023-07-19 11:07:44.279  - info: admin.0 (338) <== Disconnect system.user.admin from ::ffff:192.168.2.32
                2023-07-19 11:08:10.370  - info: host.IOBroker "system.adapter.zigbee.0" enabled
                2023-07-19 11:08:10.381  - info: host.IOBroker instance system.adapter.zigbee.0 started with pid 678
                2023-07-19 11:08:11.331  - info: zigbee.0 (678) starting. Version 1.8.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
                2023-07-19 11:08:11.369  - info: zigbee.0 (678) delete old Backup files. keep only last 10
                2023-07-19 11:08:11.369  - info: zigbee.0 (678) Starting Zigbee  npm ...
                2023-07-19 11:08:11.512  - info: zigbee.0 (678) Installed Version: iobroker.zigbee@1.8.16
                2023-07-19 11:08:27.889  - info: zigbee.0 (678) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                2023-07-19 11:08:27.894  - info: zigbee.0 (678) Unable to disable LED, unsupported function.
                2023-07-19 11:08:27.899  - info: zigbee.0 (678)   --> transmitPower : high
                2023-07-19 11:08:27.903  - info: zigbee.0 (678) Currently no devices.
                2023-07-19 11:08:27.903  - info: zigbee.0 (678) Zigbee started
                2023-07-19 11:08:27.978  - error: zigbee.0 (678) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
                2023-07-19 11:08:27.978  - error: zigbee.0 (678) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2023-07-19 11:08:27.978  - error: zigbee.0 (678) unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
                2023-07-19 11:08:27.989  - error: zigbee.0 (678) TypeError: Cannot read properties of undefined (reading 'Error')
                    at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
                2023-07-19 11:08:27.989  - error: zigbee.0 (678) Cannot read properties of undefined (reading 'Error')
                2023-07-19 11:08:27.995  - info: zigbee.0 (678) cleaned everything up...
                2023-07-19 11:08:27.995  - info: zigbee.0 (678) Zigbee: disabling joining new devices.
                2023-07-19 11:08:28.495  - info: zigbee.0 (678) terminating
                2023-07-19 11:08:28.496  - warn: zigbee.0 (678) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2023-07-19 11:08:29.013  - error: host.IOBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                2023-07-19 11:08:29.013  - error: host.IOBroker Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'Error')
                2023-07-19 11:08:29.013  - error: host.IOBroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
                2023-07-19 11:08:29.013  - error: host.IOBroker Caught by controller[0]:     at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
                2023-07-19 11:08:29.013  - error: host.IOBroker Caught by controller[0]:     at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
                2023-07-19 11:08:29.013  - error: host.IOBroker Caught by controller[0]:     at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
                2023-07-19 11:08:29.013  - error: host.IOBroker Caught by controller[0]:     at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
                2023-07-19 11:08:29.013  - error: host.IOBroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2023-07-19 11:08:29.014  - info: host.IOBroker Restart adapter system.adapter.zigbee.0 because enabled
                ^[[1;2B2023-07-19 11:08:59.023  - i
                Als Geräte anschluss habe ich diverse Varianten probiert:
                1. serial by-id:
                /dev/serial/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                als ttyUSB0
                /dev/ttyUSB0
                leider ohne erfolg.....
                im lsusb wird der stick erkannt ...
                Bus 001 Device 002: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
                vorgegangen bin ich final nach dem ansatz von Matthias Kleine von @haus-automatisierung
                (zum Blogbeitrag)
                ich hoffe, hier finde ich eine Lösung.
                Viele Grüße & herzlichen Dank
                Matthias
                Thomas BraunT haus-automatisierungH 3 Antworten Letzte Antwort
                • Matthias 0M Matthias 0
                  Guten Tag zusammen,
                  Hier das LOG
                  1. serial by-id:
                  als ttyUSB0
                  /dev/ttyUSB0
                  (zum Blogbeitrag)
                  Matthias
                  @matthias-0
                  Zeig mal die Einstellungen zu dem Stick.
                  Ich glaube der braucht auch statt des zStack3x0 den ez...-Stack.
                  Edit: Bei den Sonoff-Sticks ist das echt unübersichtlich mit den Stacks... Schau da besser selber nochmal nach. Die Firmware revision":20210708 ist allerdings steinalt, die würde ich aktualisieren, wenn es denn die richtige ist.
                  Matthias 0M 1 Antwort Letzte Antwort
                    @matthias-0
                    Matthias 0M Offline
                    Matthias 0M Offline
                    Matthias 0
                    Hallo Thomas,
                    vielen Dank für Deine Antwort.
                    hier die Einstellungen des Sticks:zbe.PNG
                    um die FW habe ich mich noch gar nicht gekümmert...
                    Mich wundert, dass die ID des Sticks sehr kurz ist. Alle Referenzen, welche ich bis jetzt gesehen habe haben eine längere ID . Kann das evtl. schon ein Fehler sein?
                    Viele Grüße aus Leverkusen
                      Hallo Thomas,
                      @matthias-0
                      ist nicht unüblich lang/kurz. Passt.
                      Zur Firmware findet sich hier was:
                      https://forum.iobroker.net/topic/50180/anleitung-zigbee-firmware-auf-der-kommandozeile-flashen/
                        @matthias-0
                        Matthias 0M Offline
                        Matthias 0M Offline
                        Matthias 0
                        Herzlichen Dank, ich werde das Update gleich einmal durchführen und berichte dann.
                          Guten Tag zusammen,
                          Hier das LOG
                          1. serial by-id:
                          als ttyUSB0
                          /dev/ttyUSB0
                          (zum Blogbeitrag)
                          Matthias
                          haus-automatisierungH Offline
                          @matthias-0 sagte in Zigbee lässt sich nicht verbinden:
                          Ist das auch der -P Stick und nicht der mit -E am Ende? Es gibt zwei verschiedene. Letzterer hat einen ganz anderen Chip verbaut, weswegen Du den Typ auf EZSP (oder so ähnlich) stellen musst.
                            Matthias 0M Offline
                            Matthias 0M Offline
                            Matthias 0
                            Hallo Matthias,
                            es handelt sich hier um den "P"- Stick (CC2652P).
                            Es ist mir wirklich ein Rätzel, auch die Anschlussliste im Adapter bietet keine Auswahlmöglichkeiten.
                            Herzlichen dank für die Unterstützung.
                            Matthias
                              Hallo Matthias,
                              Matthias
                              @matthias-0
                              Den würde ich definitiv mit aktueller Firmware versehen wollen.
                                @matthias-0
                                Matthias 0M Offline
                                Matthias 0M Offline
                                Matthias 0
                                @thomas-braun sagte in Zigbee lässt sich nicht verbinden:
                                @matthias-0
                                So, neue Firmware ist drauf, Ergebnis unverändert.
                                zigbee.0
                                2023-07-19 16:58:39.899	info	Installed Version: iobroker.zigbee@1.8.16
                                zigbee.0
                                2023-07-19 16:58:39.897	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                zigbee.0
                                2023-07-19 16:58:39.896	info	terminating
                                zigbee.0
                                2023-07-19 16:58:39.896	warn	Failed to stop zigbee during startup
                                zigbee.0
                                2023-07-19 16:58:39.872	info	Zigbee: disabling joining new devices.
                                zigbee.0
                                2023-07-19 16:58:39.870	info	cleaned everything up...
                                zigbee.0
                                2023-07-19 16:58:39.805	error	Cannot read properties of undefined (reading 'Error')
                                zigbee.0
                                2023-07-19 16:58:39.805	error	TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:345:18)
                                zigbee.0
                                2023-07-19 16:58:39.799	error	unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
                                zigbee.0
                                2023-07-19 16:58:39.799	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                zigbee.0
                                2023-07-19 16:58:39.798	error	Error herdsman start
                                zigbee.0
                                2023-07-19 16:58:39.798	error	Failed to start Zigbee
                                zigbee.0
                                2023-07-19 16:58:39.798	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
                                zigbee.0
                                2023-07-19 16:58:39.716	info	Starting Zigbee npm ...
                                zigbee.0
                                2023-07-19 16:58:39.716	info	delete old Backup files. keep only last 10
                                zigbee.0
                                2023-07-19 16:58:39.679	info	starting. Version 1.8.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
                                zigbee.0
                                2023-07-19 14:58:08.216	info	Installed Version: iobroker.zigbee@1.8.16
                                zigbee.0
                                2023-07-19 14:58:08.214	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                zigbee.0
                                2023-07-19 14:58:08.213	info	terminating
                                zigbee.0
                                2023-07-19 14:58:08.213	warn	Failed to stop zigbee during startup
                                zigbee.0
                                2023-07-19 14:58:08.190	info	Zigbee: disabling joining new devices.
                                zigbee.0
                                2023-07-19 14:58:08.188	info	cleaned everything up...
                                zigbee.0
                                2023-07-19 14:58:08.122	error	Cannot read properties of undefined (reading 'Error')
                                zigbee.0
                                2023-07-19 14:58:08.121	error	TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:345:18)
                                zigbee.0
                                2023-07-19 14:58:08.116	error	unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
                                zigbee.0
                                2023-07-19 14:58:08.115	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                zigbee.0
                                2023-07-19 14:58:08.115	error	Error herdsman start
                                zigbee.0
                                2023-07-19 14:58:08.115	error	Failed to start Zigbee
                                zigbee.0
                                2023-07-19 14:58:08.115	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
                                zigbee.0
                                2023-07-19 14:58:08.032	info	Starting Zigbee npm ...
                                zigbee.0
                                2023-07-19 14:58:08.031	info	delete old Backup files. keep only last 10
                                zigbee.0
                                2023-07-19 14:58:07.994	info	starting. Version 1.8.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
                                zigbee.0
                                2023-07-19 14:58:05.352	info	Got terminate signal TERMINATE_YOURSELF
                                zigbee.0
                                2023-07-19 14:58:04.867	info	Installed Version: iobroker.zigbee@1.8.16
                                zigbee.0
                                2023-07-19 14:58:04.864	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                zigbee.0
                                2023-07-19 14:58:04.864	info	terminating
                                zigbee.0
                                2023-07-19 14:58:04.863	warn	Failed to stop zigbee during startup
                                zigbee.0
                                2023-07-19 14:58:04.840	info	Zigbee: disabling joining new devices.
                                zigbee.0
                                2023-07-19 14:58:04.838	info	cleaned everything up...
                                Auffällig, finde ich auch, dass der Adapter direkt rot bleibt und nicht einmal versucht zu laufen (gelb)....
                                Hat noch jemand eine Idee?
                                DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                                  @matthias-0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  Den Adapter auf 1.8.18 anheben
                                  Lehrling seit 1975 !!!
                                  • DJMarc75D DJMarc75
                                    Matthias 0M Offline
                                    Matthias 0M Offline
                                    Matthias 0
                                    @djmarc75 sagte in Zigbee lässt sich nicht verbinden:
                                    Den Adapter auf anheben
                                    vielen Dank für Deine Hilfe.
                                    Ich habe die neuste Version nun installiert.
                                    Jetzt :
                                    Ergebnis mit ID:
                                    zigbee.0
                                    2023-07-19 15:11:50.479	error	Failed to start Zigbee
                                    zigbee.0
                                    2023-07-19 15:11:50.478	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
                                    zigbee.0
                                    2023-07-19 15:11:50.474	info	Starting Zigbee npm ...
                                    zigbee.0
                                    2023-07-19 15:11:50.474	info	Try to reconnect. 1 attempts left
                                    zigbee.0
                                    2023-07-19 15:11:40.544	info	Installed Version: ioBroker/ioBroker.zigbee
                                    zigbee.0
                                    2023-07-19 15:11:40.472	error	Error herdsman start
                                    zigbee.0
                                    2023-07-19 15:11:40.472	error	Failed to start Zigbee
                                    zigbee.0
                                    2023-07-19 15:11:40.472	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
                                    zigbee.0
                                    2023-07-19 15:11:40.390	info	Starting Zigbee npm ...
                                    zigbee.0
                                    2023-07-19 15:11:40.389	info	delete old Backup files. keep only last 10
                                    zigbee.0
                                    2023-07-19 15:11:40.352	info	starting. Version 1.8.18 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
                                    Es scheint als ob er den Stick nicht findet.... oder ?
                                    Ergebnis mit ttyUSB0 (jetzt aus der Liste zu wählen)
                                    zigbee.0
                                    2023-07-19 15:17:22.830	error	Error herdsman start
                                    zigbee.0
                                    2023-07-19 15:17:22.830	error	Failed to start Zigbee
                                    zigbee.0
                                    2023-07-19 15:17:22.830	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyUSB0'"
                                      @matthias-0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      @matthias-0
                                      Prüf das:
                                        @matthias-0
                                        Prüf das:
                                        Matthias 0M Offline
                                        Matthias 0M Offline
                                        Matthias 0
                                        @matthias-0
                                        Prüf das:
                                        das scheint am LXC zu liegen.... Dieses Verzeichnis gibt es nicht im LXC.
                                        Deshalb habe ich alternativ ttyUSB0 genommen.
                                        Dieser sollte wie bei @haus-automatisierung auch im LXC laufen...
                                        Ich stehe hier glaube ich jetzt echt auf dem Schlauch 😕
                                        auch mit ttyUSB0 jetzt diese fehler:
                                        zigbee.0
                                        2023-07-19 18:02:26.034	error	Error herdsman start
                                        zigbee.0
                                        2023-07-19 18:02:26.034	error	Failed to start Zigbee
                                        zigbee.0
                                        2023-07-19 18:02:26.034	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                        Zusätzlich klappt nun auch wieder die Auswahlliste unter dem COM Anschluss nicht mehr aus....
                                          @matthias-0
                                          Prüf das:
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          Wäre mir neu. Aber aus genau solchen Gründen befasse ich mich eigentlich nicht mit Docker, Containern und sonstigem eingedostem Zeug.
