  4. Probleme mit HomeMatic RPC
168 Beiträge 32 Kommentatoren 45.9k Aufrufe 29 Beobachtet
  • R rascal
    selbe Problem hier auf einem Ubuntu Rechner mit aktuellem npm und node.
    Betrifft fast alle hmip Geräte.... allerdings nicht alle.
    hm-rpc.2
    2023-07-18 15:26:24.854	error	Error on getParamsetDescription for [HmIP-RCV-1:30, 'VALUES']": Unknown XML-RPC tag 'TITLE'
    hm-rpc.2
    2023-07-18 15:26:24.838	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:30","VALUES"]
    hm-rpc.2
    2023-07-18 15:26:24.838	error	Error on getParamsetDescription for [HmIP-RCV-1:29, 'VALUES']": Unknown XML-RPC tag 'TITLE'
    hm-rpc.2
    2023-07-18 15:26:24.821	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:29","VALUES"]
    hm-rpc.2
    2023-07-18 15:26:24.820	error	Error on getParamsetDescription for [HmIP-RCV-1:28, 'VALUES']": Unexpected end Line: 0 Column: 0 Char:
    hm-rpc.2
    2023-07-18 15:26:24.803	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:28","VALUES"]
    hm-rpc.2
    2023-07-18 15:26:24.802	error	Error on getParamsetDescription for [HmIP-RCV-1:27, 'VALUES']": Unexpected end Line: 0 Column: 0 Char:
    hm-rpc.2
    2023-07-18 15:26:24.785	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:27","VALUES"]
    hm-rpc.2
    2023-07-18 15:26:20.658	error	Error on getParamsetDescription for [000A58A9A5B664:1, 'VALUES']": Unexpected end Line: 0 Column: 0 Char:
    hm-rpc.2
    2023-07-18 15:26:20.648	info	xmlrpc -> getParamsetDescription ["000A58A9A5B664:1","VALUES"]
    hm-rpc.2
    2023-07-18 15:26:20.647	error	Error on getParamsetDescription for [000A58A9A5B664:0, 'VALUES']": Unexpected end Line: 0 Column: 0 Char:
    hm-rpc.2
    2023-07-18 15:26:20.638	info	xmlrpc -> getParamsetDescription ["000A58A9A5B664:0","VALUES"]
    hm-rpc.2
    2023-07-18 15:26:20.637	error	Error on getParamsetDescription for [00089D8992C6F3:7, 'VALUES']": Unexpected end Line: 0 Column: 0 Char:
    hm-rpc.2
    2023-07-18 15:26:20.625	info	xmlrpc -> getParamsetDescription ["00089D8992C6F3:7","VALUES"]
    hm-rpc.2
    2023-07-18 15:26:20.613	info	xmlrpc -> getParamsetDescription ["00089D8992C6F3:6","VALUES"]
    hm-rpc.2
    2023-07-18 15:26:20.395	info	xmlrpc -> getParamsetDescription ["00089D8992C6F3:5","VALUES"]
    hm-rpc.2
    2023-07-18 15:26:20.249	info	xmlrpc -> getParamsetDescription ["00089D8992C6F3:4","VALUES"]
    hm-rpc.2
    2023-07-18 15:26:20.114	info	xmlrpc -> getParamsetDescription ["00089D8992C6F3:3","VALUES"]
    hm-rpc.2
    2023-07-18 15:26:19.979	info	xmlrpc -> getParamsetDescription ["00089D8992C6F3:2","VALUES"]
    hm-rpc.2
    2023-07-18 15:26:19.902	info	xmlrpc -> getParamsetDescription ["00089D8992C6F3:1","VALUES"]
    Er legt auch nicht alle Datenpunkte bei den betroffenen Geräten an:
    teletapiT Offline
    teletapiT Offline
    teletapi
    schrieb am zuletzt editiert von teletapi
    @rascal Es muss am Host Update liegen.
    Ich hab heute nochmal getestet den Host down zu graden auf die 4.0.24 oder auch die 5.0.6 bei beiden treten die Fehler nach kurzer Zeit trotzdem auf
    Dann hab ich ne Sicherung mit dem Host 5.0.6 drauf gemacht wo noch keine 5.0.8 drauf war und siehe da bisher keine fehler mehr. ( Bin ich aber noch am beobachten)
    bedeutet das auch ein Downgrade den fehler nicht mehr rückgängig machen kann den die Installation der 5.0.8 verursacht
    HomoranH R 2 Antworten Letzte Antwort
    • teletapiT teletapi
      @teletapi das wäre dann ja ein Thema für das Betatester Programm
      • W Offline
        W Offline
        Walter Weiss
        Ich habe nach einem js-contoller update von 4.0.24 auf 5.0.8 bei den hm-rpc.x Instanzen auch den ping - Fehler erhalten. Nachdem ich bei den Instanzeinstellungen der hm-rpc.x Instanzen "Geräte neu einlesen (einmalig)"
        angewählt hatte sind nach Instanzstart keine ping-Fehler mehr aufgetreten.
        teletapiT M 2 Antworten Letzte Antwort
          rascal
          @teletapi , danke für die Hilfe.
          ich habe jetzt mit
          npm i iobroker.js-controller@5.0.7 --omit=dev
          den alten js-Controller installiertsud, danach mit
          iob backups restore -backup_file-
          das Backup wieder eingespielt und nach elends langen Deinstallations- und Installationsprozessen funktioniert iobroker wieder
          • W Walter Weiss
            teletapiT Offline
            teletapiT Offline
            teletapi
            @walter-weiss HAbe ich alles mehrfach probiert einige zeit später sind die fehler wieder da
            • G Offline
              goat116
              ich habe auch den RPC Fehler.
              Fehler trat auch zum ersten mal nach dem Update des js-controller auf. 5.0.?
              Downgrade auf 4.0.24 hat den Fehler leider nicht wieder behoben.
              • G goat116
                @goat116 sagte in Probleme mit HomeMatic RPC:
                wenn alle, die Probleme mit dem hm-rpc haben, Betatester für den controller v5 sind, gehört das Thema in den Betatest-Bereich.
                Siggi0904S T 2 Antworten Letzte Antwort
                  Siggi0904S Offline
                  Siggi0904S Offline
                  Siggi0904
                  @homoran nein, ich bin auf dem letzten 4er und hab das Problem auch.
                    ma
                    bei mir ebenfals bin auch auf 4.0.24 und habe das problem, habe keine updates gemacht das ganze lief lange ohne probleme der fehler war plötzlich da
                      ticaki
                      @homoran sagte in Probleme mit HomeMatic RPC:
                      und wo ist der? :)
                      Spenden
                      • Siggi0904S Offline
                        Siggi0904S Offline
                        Siggi0904
                        Vielleicht ist es ja ein Problem auf der Basis aus dem Fehler in 2018:
                        Da war es auch ein Thema aus einer neuen Firmware.
                        https://github.com/ioBroker/ioBroker.hm-rpc/issues/125
                          ticaki
                          Jeder hat ein
                          debian ableger
                          am laufen?
                          Spenden
                          • T ticaki
                            Jeder hat ein
                            debian ableger
                            am laufen?
                            sigi234S Online
                            sigi234S Online
                            @ticaki sagte in Probleme mit HomeMatic RPC:
                            Jeder hat ein
                            debian ableger
                            am laufen?
                            Nein, auch unter Windows.
                            • sigi234S sigi234
                              Jeder hat ein
                              debian ableger
                              am laufen?
                              ticaki
                              @sigi234
                              am WE mache mal ne Testreihe
                              Spenden
                              • W Walter Weiss
                                ma
                                @walter-weiss said in Probleme mit HomeMatic RPC:
                                4.0.24
                                kann ich leider nicht bestätigen, nach ca 1h ist das problem wieder aufgetreten
                                bin auf 4.0.24 (nie auf 5.x.x gewesen)
                                • FeuersturmF Offline
                                  FeuersturmF Offline
                                  Feuersturm
                                  Ich hab bei mir folgenden Fehler mit dem hm-rpc Adapter (v1.15.18) auf meinem Testsystem wo auch Admin 6.1.1 und js-controller 5.0.8 läuft.
                                  Soweit ich mich erinner kann, tritt der Fehler erst seit kurzem auf und war bei den ersten 5.0.x Versionen noch nicht da.
                                  Auf meinem Produktivsystem mit js-controller 4.0.24 tritt der Fehler nicht auf.
                                  Ich verwende Proxmox und ioBroker läuft in einzelnen Container unter Ubuntu
                                  2023-07-18 21:43:58.616 - error: hm-rpc.0 (492) Ping error [ioBrokerTestsystem:hm-rpc.0:5e569f66d6935a29247f8fc51c61d0fc]: Unknown XML-RPC tag 'TITLE'
                                  2023-07-18 21:43:58.618 - info: hm-rpc.0 (492) Disconnected
                                  2023-07-18 21:44:04.153 - info: hm-rpc.0 (492) Connected
                                  2023-07-18 21:45:34.190 - error: hm-rpc.0 (492) Ping error [ioBrokerTestsystem:hm-rpc.0:5e569f66d6935a29247f8fc51c61d0fc]: Unknown XML-RPC tag 'TITLE'
                                  2023-07-18 21:45:34.192 - info: hm-rpc.0 (492) Disconnected
                                  2023-07-18 21:45:39.861 - info: hm-rpc.0 (492) Connected
                                  2023-07-18 21:47:09.902 - error: hm-rpc.0 (492) Ping error [ioBrokerTestsystem:hm-rpc.0:5e569f66d6935a29247f8fc51c61d0fc]: Unknown XML-RPC tag 'TITLE'
                                  2023-07-18 21:47:09.905 - info: hm-rpc.0 (492) Disconnected
                                  2023-07-18 21:47:11.300 - info: hm-rpc.0 (492) Connected
                                  2023-07-18 21:48:41.335 - error: hm-rpc.0 (492) Ping error [ioBrokerTestsystem:hm-rpc.0:5e569f66d6935a29247f8fc51c61d0fc]: Unknown XML-RPC tag 'TITLE'
                                  2023-07-18 21:48:41.339 - info: hm-rpc.0 (492) Disconnected
                                  2023-07-18 21:49:04.164 - info: hm-rpc.0 (492) Connected
                                  2023-07-18 21:50:34.186 - error: hm-rpc.0 (492) Ping error [ioBrokerTestsystem:hm-rpc.0:5e569f66d6935a29247f8fc51c61d0fc]: Unknown XML-RPC tag 'TITLE'
                                  2023-07-18 21:50:34.187 - info: hm-rpc.0 (492) Disconnected
                                  • T ticaki
                                    und wo ist der? :)
                                    und wo ist der? :)
                                    zu prominent angepinnt?
                                      und wo ist der? :)
                                      ticaki
                                      Ne ich hab nach nem Forum gesucht, nicht nach nem Thread :)
                                      Spenden
                                        ticaki
                                        Ist die npm version relevant?
                                        pi4:
                                        npm 9.7.2
                                        rpc ok
                                        Proxmox 8 bookworm:
                                        npm 9.5.1
                                        rpc fehler
                                        Spenden
                                        • T ticaki
                                          pi4:
                                          npm 9.7.2
                                          rpc ok
                                          Proxmox 8 bookworm:
                                          npm 9.5.1
                                          rpc fehler
                                          npm 9.7.2
                                          Ist zumindest nicht die Version die mit nodejs@18 selber ausgeliefert wird. Ist also von Hand dran rumgestrickt worden. Oder nodejs@20 installiert.
