  4. js-controller 5.0.x jetzt in der BETA
    6.7k
580 Beiträge 71 Kommentatoren 247.1k Aufrufe 67 Beobachtet
  • Marius SchäferM Offline
    Marius Schäfer
    #405
    Seit dem Update von js-controller 5.0.7 -> 5.0.8 startet mein zigbee v1.8.17 nicht mehr.
    host.iobroker 2023-07-16 07:23:46.497	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker 2023-07-16 07:23:46.497	error	Caught by controller[0]: Node.js v18.16.1
    host.iobroker 2023-07-16 07:23:46.497	error	Caught by controller[0]: at node:internal/main/run_main_module:23:47
    host.iobroker 2023-07-16 07:23:46.497	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    host.iobroker 2023-07-16 07:23:46.497	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
    host.iobroker 2023-07-16 07:23:46.497	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    host.iobroker 2023-07-16 07:23:46.497	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    host.iobroker 2023-07-16 07:23:46.497	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1220:27)
    host.iobroker 2023-07-16 07:23:46.497	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1178:20)
    host.iobroker 2023-07-16 07:23:46.497	error	Caught by controller[0]: at internalCompileFunction (node:internal/vm:73:18)
    host.iobroker 2023-07-16 07:23:46.496	error	Caught by controller[0]: SyntaxError: missing ) after argument list
    host.iobroker 2023-07-16 07:23:46.496	error	Caught by controller[0]: ^^^^^
    host.iobroker 2023-07-16 07:23:46.496	error	Caught by controller[0]: this.log.error(`Error ${error.code} on send command to ${payload.device}.` + ` Error: ${error.stack} ` + `Send command to ${payload.device} failed with ` + error;
    host.iobroker 2023-07-16 07:23:46.496	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/main.js:791
    J arteckA 2 Antworten Letzte Antwort
    • Marius SchäferM Marius Schäfer
      Jan1
      #406
      @marius-schäfer
      Das liegt aber am Zigbee ;)
      Weil v1.8.17 läuft auch mit 5.0.7 nicht.
      https://forum.iobroker.net/topic/66893/zigbee-1-8-17-bleibt-rot/2
      • J Jan1
        Ist das Problem mit Iqontrol bekannt?
        2023-07-16 09:21:35.737 - info: host.Beelink "system.adapter.iqontrol.0" enabled
        2023-07-16 09:21:35.794 - info: host.Beelink instance system.adapter.iqontrol.0 started with pid 20691
        2023-07-16 09:21:36.657 - info: iqontrol.0 (20691) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.iqontrol, node: v18.16.1, js-controller: 5.0.8
        2023-07-16 09:21:36.673 - error: iqontrol.0 (20691) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-07-16 09:21:36.673 - error: iqontrol.0 (20691) unhandled promise rejection: Parameter "options" needs to be a real object but type "string" has been passed
        2023-07-16 09:21:36.821 - error: iqontrol.0 (20691) Error: Parameter "options" needs to be a real object but type "string" has been passed
        at Function.assertObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:301:19)
        at Iqontrol.getObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:3587:23)
        at /opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2312:16
        at new Promise ()
        at Iqontrol.getObjectAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2311:16)
        at Iqontrol.createOrUpdateObject (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:1673:25)
        at Iqontrol.createInfoConnection (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:413:14)
        at Iqontrol.onReady (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:1779:14)
        at Iqontrol.emit (node:events:513:28)
        at Iqontrol.emit (node:domain:489:12)
        2023-07-16 09:21:36.822 - error: iqontrol.0 (20691) Parameter "options" needs to be a real object but type "string" has been passed
        2023-07-16 09:21:36.831 - info: iqontrol.0 (20691) Stop trigger intervals...
        2023-07-16 09:21:36.832 - info: iqontrol.0 (20691) cleaned everything up...
        2023-07-16 09:21:36.832 - info: iqontrol.0 (20691) terminating
        2023-07-16 09:21:36.833 - warn: iqontrol.0 (20691) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-07-16 09:21:37.336 - info: iqontrol.0 (20691) terminating
        2023-07-16 09:21:37.408 - error: host.Beelink Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        2023-07-16 09:21:37.408 - error: host.Beelink Caught by controller[1]: Error: Parameter "options" needs to be a real object but type "string" has been passed
        2023-07-16 09:21:37.408 - error: host.Beelink Caught by controller[1]: at Function.assertObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:301:19)
        2023-07-16 09:21:37.408 - error: host.Beelink Caught by controller[1]: at Iqontrol.getObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:3587:23)
        2023-07-16 09:21:37.408 - error: host.Beelink Caught by controller[1]: at /opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2312:16
        2023-07-16 09:21:37.408 - error: host.Beelink Caught by controller[1]: at new Promise ()
        2023-07-16 09:21:37.408 - error: host.Beelink Caught by controller[1]: at Iqontrol.getObjectAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2311:16)
        2023-07-16 09:21:37.408 - error: host.Beelink Caught by controller[1]: at Iqontrol.createOrUpdateObject (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:1673:25)
        2023-07-16 09:21:37.408 - error: host.Beelink Caught by controller[1]: at Iqontrol.createInfoConnection (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:413:14)
        2023-07-16 09:21:37.408 - error: host.Beelink Caught by controller[1]: at Iqontrol.onReady (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:1779:14)
        2023-07-16 09:21:37.408 - error: host.Beelink Caught by controller[1]: at Iqontrol.emit (node:events:513:28)
        2023-07-16 09:21:37.408 - error: host.Beelink Caught by controller[1]: at Iqontrol.emit (node:domain:489:12)
        2023-07-16 09:21:37.408 - error: host.Beelink instance system.adapter.iqontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-07-16 09:21:37.409 - info: host.Beelink Restart adapter system.adapter.iqontrol.0 because enabled
        Mit der stable Version läufts
        mcm1957M Online
        mcm1957M Online
        mcm1957
        #407
        @jan1 said in js-controller 5.0.x jetzt in der BETA:
        https://github.com/sbormann/ioBroker.iqontrol/issues/279
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • J Jan1
          @marius-schäfer
          mcm1957M Online
          mcm1957M Online
          mcm1957
          #408
          @jan1
          Should be fixed with https://github.com/ioBroker/ioBroker.zigbee/pull/1801 and next release.
          @arteck FYI
            arteckA Offline
            arteckA Offline
            arteck
            #409
            @marius-schäfer installier die GIT version oder warte auf 1.8.18..
            • foxriver76F foxriver76
              Controller 5.0.8 auf dem Weg:
              • remove duplicate logging and fix https prefix on ssl server (controller upgrade)
              • requireLog should not throw on invalid permissions
              • fixed multihost communication upgrade manager (erstmals testbar beim update von v5.0.8 auf eine potentielle 5.0.9)
              • try to solve ENOTEMPTY errors automatically on adapter upgrades/installations
              Update von 5.0.7 auf 5.0.8 kann auch erstmals mit offiziellem Docker Container (mindestens v8.1.0-beta.3) erfolgreich stattfinden. Hierzu gerne Feedback geben.
              FeuersturmF Offline
              FeuersturmF Offline
              Feuersturm
              #410
              @foxriver76 Update auf Master Slave Testsystem war erfolgreich
              Beim Master kommt nach dem Update auf 5.0.8 und starten des Controllers folgende Warnung
              2023-07-16 12:37:00.799 - warn: host.ioBrokerTestsystem-Server Objects 192.168.178.78:58884 Error from InMemDB: Error: Unknown Script b0bd9e6fd92479ccf43654a7ba7443c915d0a742
              at RedisHandler. (/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/build/lib/objects/objectsInMemServerRedis.js:301:59)
              at RedisHandler.emit (node:events:513:28)
              at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-base/build/lib/redisHandler.js:132:37)
              at process.processImmediate (node:internal/timers:476:21)
              Log Master:
              2023-07-16 12:35:28.691 - info: host.ioBrokerTestsystem All instances are stopped.
              2023-07-16 12:35:28.827 - info: host.ioBrokerTestsystem terminated
              2023-07-16 12:35:33.225 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
              2023-07-16 12:35:33.242 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
              2023-07-16 12:36:48.197 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE]
              removed 123 packages, and changed 21 packages in 1m
              143 packages are looking for funding
              run `npm fund` for details
              2023-07-16 12:36:48.872 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:36:54.084 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Successfully started js-controller
              2023-07-16 12:36:58.279 - info: host.ioBrokerTestsystem iobroker.js-controller version 5.0.8 js-controller starting
              2023-07-16 12:36:58.292 - info: host.ioBrokerTestsystem Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
              2023-07-16 12:36:58.295 - info: host.ioBrokerTestsystem hostname: ioBrokerTestsystem, node: v18.16.1
              2023-07-16 12:36:58.308 - info: host.ioBrokerTestsystem ip addresses: 192.168.178.77 fe80::f854:cfff:fe5f:6c25
              2023-07-16 12:37:02.688 - info: host.ioBrokerTestsystem connected to Objects and States
              2023-07-16 12:37:02.834 - info: host.ioBrokerTestsystem added notifications configuration of host
              2023-07-16 12:37:04.623 - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.nodeCurrent"
              2023-07-16 12:37:04.627 - info: host.ioBrokerTestsystem 62 instances found
              2023-07-16 12:37:04.812 - info: host.ioBrokerTestsystem starting 36 instances
              Im Log vom Slave taucht ein paar Mal diese Meldung auf (während der Master aktualisiert wird).
              2023-07-16 12:36:34.300 - error: host.ioBrokerNew Could not execute primary host determination: Error Unknown Script b0bd9e6fd92479ccf43654a7ba7443c915d0a742
              2023-07-16 02:12:48.100 - info: host.ioBrokerNew Delete log file iobroker.2023-07-08.log.gz
              2023-07-16 12:35:33.812 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:35:33.848 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:35:38.832 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:35:38.860 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:35:43.842 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:35:43.870 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:35:48.858 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:35:48.883 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:35:53.864 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:35:53.905 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:35:58.892 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:35:58.912 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:36:03.900 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:36:03.923 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:36:08.907 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:36:08.935 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:36:13.922 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:36:13.943 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:36:18.929 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:36:18.950 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:36:23.946 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:36:23.956 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:36:28.953 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:36:28.963 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:36:33.967 - info: host.ioBrokerNew Objects database successfully reconnected
              2023-07-16 12:36:33.974 - info: host.ioBrokerNew Objects database successfully reconnected
              2023-07-16 12:36:34.302 - error: host.ioBrokerNew Could not execute primary host determination: Error Unknown Script b0bd9e6fd92479ccf43654a7ba7443c915d0a742
              2023-07-16 12:36:45.498 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:36:45.575 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:36:50.505 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:36:50.584 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:36:55.517 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
              2023-07-16 12:36:55.589 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:37:00.524 - info: host.ioBrokerNew Objects database successfully reconnected
              2023-07-16 12:37:00.595 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
              2023-07-16 12:37:00.859 - error: host.ioBrokerNew Could not execute primary host determination: Error Unknown Script b0bd9e6fd92479ccf43654a7ba7443c915d0a742
              2023-07-16 12:37:05.601 - info: host.ioBrokerNew Objects database successfully reconnected
              2023-07-16 12:42:21.065 - info: host.ioBrokerNew Controller will upgrade itself to version 5.0.8
              2023-07-16 12:42:25.561 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Stopping controller
              2023-07-16 12:42:25.701 - info: host.ioBrokerNew received SIGTERM
              2023-07-16 12:42:25.707 - info: host.ioBrokerNew stopInstance system.adapter.history.1 (force=false, process=false)
              2023-07-16 12:42:25.708 - info: host.ioBrokerNew stopInstance system.adapter.sql.0 (force=false, process=false)
              2023-07-16 12:42:25.710 - info: host.ioBrokerNew stopInstance system.adapter.discovery.0 (force=false, process=false)
              2023-07-16 12:42:25.789 - info: host.ioBrokerNew terminated
              2023-07-16 12:42:29.896 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
              2023-07-16 12:42:29.915 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
              2023-07-16 12:43:21.442 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE]
              changed 19 packages in 48s
              81 packages are looking for funding
              2023-07-16 12:43:22.417 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:23.423 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:25.447 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:26.460 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:27.468 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:28.480 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:29.495 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:30.498 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:31.504 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:32.508 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:33.521 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:34.534 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:35.549 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:36.548 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:37.562 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:38.582 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:39.589 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:40.596 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:41.602 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:42.605 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:43.620 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:44.631 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:45.636 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:46.650 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:47.655 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:48.665 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:49.676 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:50.682 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:51.687 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:52.699 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:53.700 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:54.709 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:55.736 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:56.722 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:57.727 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:58.747 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:43:59.745 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:00.754 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:01.760 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:02.768 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:03.776 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:04.783 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:05.796 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:06.789 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:07.806 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:08.810 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:09.819 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:10.828 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:11.842 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:12.851 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:13.855 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:14.874 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:15.878 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:16.883 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:17.905 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:18.905 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:19.915 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:20.922 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:21.934 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
              2023-07-16 12:44:24.588 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Successfully started js-controller
              2023-07-16 12:44:26.169 - info: host.ioBrokerNew iobroker.js-controller version 5.0.8 js-controller starting
              2023-07-16 12:44:26.180 - info: host.ioBrokerNew Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
              2023-07-16 12:44:26.182 - info: host.ioBrokerNew hostname: ioBrokerNew, node: v18.16.0
              2023-07-16 12:44:26.185 - info: host.ioBrokerNew ip addresses: 192.168.178.78 fe80::d4a0:37ff:fe8e:f0c1
              2023-07-16 12:44:26.843 - info: host.ioBrokerNew connected to Objects and States
              2023-07-16 12:44:26.900 - info: host.ioBrokerNew added notifications configuration of host
              2023-07-16 12:44:28.166 - info: host.ioBrokerNew 62 instances found
              2023-07-16 12:44:28.214 - warn: host.ioBrokerNew does not start any instances on this host
              Diese Warnung/Fehler ist mir bisher noch nicht aufgefallen. Vielleicht könnt ihr damit etwas anfangen.
              R 1 Antwort Letzte Antwort
              • FeuersturmF Feuersturm
                Log Master:
                Rogni
                schrieb am zuletzt editiert von Rogni
                #411
                R
                Rogni
                25 minutes ago
                Hi Leute,
                Seit dem Update auf NodeJS 18 und JS Controller 5.05 hat der Nanoleaf Adapter keine Funktion mehr, da er wohl noch nicht mit dem neuen Node JS zurecht kommt. Gibt es hierfür eine Alternative bzw. Update?? ICh finde hierzu leider nichts.
                Vielen Dank schonmal für Eure Infos
                Log beim Start:
                2023-07-16 13:48:17.068  - info: host.IOBroker-Neu instance system.adapter.nanoleaf-lightpanels.0 started with pid 32183
                2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]: node:internal/modules/cjs/loader:1080
                2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]:   throw err;
                2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]:   ^
                2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
                2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]: Require stack:
                2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/lib/utils.js
                2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/main.js
                2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
                2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
                2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:110:18)
                2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/lib/utils.js:63:25)
                2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
                2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
                2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
                2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19) {
                2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:   requireStack: [
                2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/lib/utils.js',
                2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/main.js'
                2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:   ]
                2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]: }
                2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]: Node.js v18.16.1
                2023-07-16 13:48:17.295  - error: host.IOBroker-Neu instance system.adapter.nanoleaf-lightpanels.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2023-07-16 13:48:17.295  - info: host.IOBroker-Neu Rebuild for adapter system.adapter.nanoleaf-lightpanels.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                2023-07-16 13:48:18.940  - info: host.IOBroker-Neu instance system.adapter.nanoleaf-lightpanels.1 started with pid 32190
                2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]: node:internal/modules/cjs/loader:1080
                2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]:   throw err;
                2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]:   ^
                2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
                2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]: Require stack:
                2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/lib/utils.js
                2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/main.js
                2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
                2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:110:18)
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/lib/utils.js:63:25)
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19) {
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:   requireStack: [
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/lib/utils.js',
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/main.js'
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:   ]
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]: }
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]: Node.js v18.16.1
                2023-07-16 13:48:19.147  - error: host.IOBroker-Neu instance system.adapter.nanoleaf-lightpanels.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2023-07-16 13:48:19.147  - info: host.IOBroker-Neu Rebuild for adapter system.adapter.nanoleaf-lightpanels.1 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                2023-07-16 13:49:00.012  - info: hm-rpc.1 (32124) Scheduled restart.
                Issue ist eröffnet
                Erik :mrgreen: :mrgreen:
                • ESP8266E Offline
                  ESP8266E Offline
                  ESP8266
                  schrieb am zuletzt editiert von ESP8266
                  #412
                  Es betrifft zwar nicht den js.controller, aber ein Upgrade von Node 16.x.x auf 18.x.x bringt den Maxcul Adapter nicht mehr zum laufen....Issue ist eröffnet.
                  Zur Info:
                  https://github.com/ioBroker/ioBroker.maxcul/issues/63
                  Also scheint es so, als hätten noch andere Adapter das Problem.
                  G 1 Antwort Letzte Antwort
                  • R Rogni
                    R
                    Rogni
                    25 minutes ago
                    Hi Leute,
                    Log beim Start:
                    Issue ist eröffnet
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #413
                    @rogni said in js-controller 5.0.x jetzt in der BETA:
                    R
                    Rogni
                    25 minutes ago
                    Hi Leute,
                    Da Adaptername hier unvollständig angegeben, link zum Adapter:
                    https://github.com/daniel-2k/ioBroker.nanoleaf-lightpanels
                    • mcm1957M mcm1957
                      @apollon77 said in js-controller 5.0.x jetzt in der BETA:
                      Neue erkannte Probleme, die noch nicht behandelt sind:
                      • stiebel-isg update nötig
                      • lgtv sollte fixed sein mit 1.1.12
                      • web kann crashen falls Widgets in vis falsch konfiguriert sind (PR in socket-classes existiert bereits)
                      • js-controller upgrade via Admin startet js-controller nicht wieder
                      • Admin zeigt falsche Log grösse an -> Fixed in Admin 6.5.8+
                      • km200 sollte gefixt sein mit 2.0.4
                      • miio muss geprüft werden
                      • fakeroku GitHub Version gefixt, release fehlt noch
                      • pi-hole update nötig
                      • node-red muss geprüft werden
                      • enigma2.0 mindestens 1.4.0+
                      • doorbird update nötig
                      • linux-control update nötig
                      Liste wär anzupassen:
                      Km200 funktioniert weder in 1.4 noch 1.5 stabil.
                      Km200 wurde deprecated und wir - sollte sich nicht noch ein dev finden - ab js controller 5.x nicht mehr laufen. ems-esp existiert als ersatz.
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      #414
                      @mcm57 said in js-controller 5.0.x jetzt in der BETA:
                      @apollon77
                      Weitere Anpassung:
                      nanoleaf-lights benötigt update - Version 1.4.0 sollte ab morgen im Latest sein. (@rogni)
                      • ESP8266E ESP8266
                        Zur Info:
                        guergen
                        #415
                        @esp8266 Maxcul läuft hier schon ewig fehlerfrei mit Node 18; mittlerweile 18.16.1
                        ESP8266E 1 Antwort Letzte Antwort
                        • G guergen
                          ESP8266E Offline
                          ESP8266E Offline
                          ESP8266
                          #416
                          @guergen , komisch über die Schwelle gehe ich nicht. Das war schon nachdem die Empfehlung raus war für Node 18.X.X und mit dem alten 4.x.x Controller. Damals unbeachtet von mir.
                          Vielleicht liegt eine Verwechseung vor mit dem MaxCube Adapter !?
                          Ich wüsste nicht wo dran es liegen sollte.....
                          • ESP8266E ESP8266
                            guergen
                            #417
                            @esp8266 Ich habe den Maxcul definitiv. Ich bin mit meinem System komplett auf Beta unterwegs!
                            Maxcul 1.3.1, js-controller aktuell ; seit 5 Minuten auch auf 5.0.8
                            ESP8266E 2 Antworten Letzte Antwort
                            • G guergen
                              ESP8266E Offline
                              ESP8266E Offline
                              ESP8266
                              #418
                              @guergen , nichts anderes wie bei mir. Ich setze kommende Woche eh neu auf Bookworm auf.
                              Ja, richtig, nichts mit Upgrade von Bullseye auf Bookworm. Ich möchte ein sauberes System und keine alten versteckte Leichen haben. Ist zwar einiges vor zuinstallieren, aber egal.
                              Da bin ich gespannt mit Node 18.x.x. und dem Restore von iob.
                              • ESP8266E ESP8266
                                guergen
                                #419
                                @esp8266 Ich komme mittlerweile sogar als Upgrades von Deb 9
                                • G guergen
                                  Marty56
                                  #420
                                  Update auf JS-Controller 5.0.9 hat Fehlfunktion im VW-Adapter zur Folger
                                  vw-connect.0
                                  2023-07-21 01:00:11.076	error	SyntaxError: Unexpected token c in JSON at position 1412
                                  vw-connect.0
                                  2023-07-21 01:00:11.075	error	Error in consent form
                                  vw-connect.0
                                  2023-07-21 01:00:10.888	error	Restart Adapter in 30min
                                  vw-connect.0
                                  2023-07-21 01:00:10.887	error	Login Failed
                                  vw-connect.0
                                  2023-07-21 01:00:05.752	error	Restart adapter
                                  HW:NUC (16 GB Ram)
                                  OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                                  mcm1957M FeuersturmF 2 Antworten Letzte Antwort
                                  • M Marty56
                                    vw-connect.0
                                    vw-connect.0
                                    vw-connect.0
                                    vw-connect.0
                                    vw-connect.0
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    #421
                                    @marty56
                                    Bitte auch immer die Adappter Version angeben.
                                    Und mach ein issue beim Adapter auf wenn noch nicht existent.
                                    • mcm1957M mcm1957
                                      @marty56
                                      Marty56
                                      #422
                                      @mcm57 ist die latest.
                                      Vermutlich liegt es aber an der Schrott Infrastruktur von VW/Skoda.
                                      Es gibt dazu ein Issue. Bei mir, war es, vielleicht zufällig, mit dem Update auf js-controller 5.0.9 korreliert.
                                      HW:NUC (16 GB Ram)
                                      • M Marty56
                                        mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        #423
                                        @marty56
                                        Danke f Feedback.
                                        Generell bitte immer die Versionen numerisch Ngeben. Warum? Latest ist heute klar. Liegt ein issue aus irgendeinem grund ab dann ist latest ev unklar da es schon eine neuere version geben könnte. Ist für entwickler mügsam zu checken zu welcher release ein issue gehört.
                                        Aber hier ist durch den verweis aus issue alles klar.
                                        • GaspodeG Offline
                                          GaspodeG Offline
                                          Gaspode
                                          #424
                                          Ich wollte mir mal das Upgrade des JS-Controllers unter Linux anschauen. Dazu hab ich einen ioBroker unter WSL installiert, ihn auf JS-Controller 5.0.7 gebracht und dann auf der Admin Seite Hosts das Upgrade gestartet. Es kommt nur eine einzige Fehlermeldung:
                                          SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
                                          Im Log steht
                                          2023-07-21 11:03:24.112 - debug: host.iobHost Incoming Host message getLogs
                                          2023-07-21 11:03:26.112 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount
                                          2023-07-21 11:03:26.114 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount
                                          2023-07-21 11:03:26.115 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount, system.host.iobHost.cpu
                                          2023-07-21 11:03:26.115 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount, system.host.iobHost.cpu, system.host.iobHost.mem
                                          2023-07-21 11:03:26.115 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount, system.host.iobHost.cpu, system.host.iobHost.mem, system.host.iobHost.uptime
                                          2023-07-21 11:03:26.115 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount, system.host.iobHost.cpu, system.host.iobHost.mem, system.host.iobHost.uptime, system.host.iobHost.diskFree
                                          2023-07-21 11:03:26.116 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount, system.host.iobHost.cpu, system.host.iobHost.mem, system.host.iobHost.uptime, system.host.iobHost.diskFree, system.host.iobHost.diskSize
                                          2023-07-21 11:03:26.119 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount, system.host.iobHost.cpu, system.host.iobHost.mem, system.host.iobHost.uptime, system.host.iobHost.diskFree, system.host.iobHost.diskSize, system.host.iobHost.diskWarning
                                          2023-07-21 11:03:26.120 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount, system.host.iobHost.cpu, system.host.iobHost.mem, system.host.iobHost.uptime, system.host.iobHost.diskFree, system.host.iobHost.diskSize, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                          2023-07-21 11:03:29.760 - debug: host.iobHost Incoming Host message upgradeController
                                          2023-07-21 11:03:29.761 - info: host.iobHost Controller will upgrade itself to version 5.0.8
                                          2023-07-21 11:03:51.836 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.outputCount, system.host.iobHost.cpu, system.host.iobHost.mem, system.host.iobHost.uptime, system.host.iobHost.diskFree, system.host.iobHost.diskSize, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                          2023-07-21 11:03:51.836 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.cpu, system.host.iobHost.mem, system.host.iobHost.uptime, system.host.iobHost.diskFree, system.host.iobHost.diskSize, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                          2023-07-21 11:03:51.836 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.mem, system.host.iobHost.uptime, system.host.iobHost.diskFree, system.host.iobHost.diskSize, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                          2023-07-21 11:03:51.837 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.uptime, system.host.iobHost.diskFree, system.host.iobHost.diskSize, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                          2023-07-21 11:03:51.837 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.diskFree, system.host.iobHost.diskSize, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                          2023-07-21 11:03:51.838 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.diskSize, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                          2023-07-21 11:03:51.838 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                          2023-07-21 11:03:51.838 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.logLevel
                                          2023-07-21 11:03:51.842 - debug: host.iobHost Incoming Host message getLogFiles
                                          2023-07-21 11:03:51.885 - debug: host.iobHost Incoming Host message getLogs
                                          2023-07-21 11:04:01.682 - debug: host.iobHost Incoming Host message getLogFile
                                          Log Level für Admin und Controller steht auf Debug.
                                          Gibt's da gerade ein bekanntes Problem oder liegt es an mir?
