  3. Einsteigerfragen
  4. Installation
  5. Bekomme die nodejs Installation nicht vernünftig hin
Geplant Angeheftet Gesperrt Verschoben Ungelöst Installation
nodejs 18
28 Beiträge 5 Kommentatoren 2.8k Aufrufe 4 Beobachtet
  • Dustin F.D Dustin F.
    @djmarc75
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     20:39:25 up 3 min,  1 user,  load average: 1.34, 0.86, 0.37
    CPU threads: 4
    Raspberry only:
    throttled=0x50000
    Other values than 0x0 hint to temperature/voltage problems
    temp=62.8'C
    volt=0.8500V
    *** Time and Time Zones ***
                   Local time: Mon 2023-07-10 20:39:25 BST
               Universal time: Mon 2023-07-10 19:39:25 UTC
                     RTC time: n/a
                    Time zone: Europe/London (BST, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        392M        3.1G        0.0K        323M        3.3G
    Swap:            99M          0B         99M
    Total:          3.9G        392M        3.2G
             3838 M total memory
              393 M used memory
              179 M active memory
              447 M inactive memory
             3122 M free memory
               74 M buffer memory
              248 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       15G  9.1G  4.6G  67% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     768M  752K  767M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Mon Jul 10 20:35:49 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:AA:71:36 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e52a9d10-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Mon Jul 10 20:35:50 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Jul 10 20:35:50 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Jul 10 20:35:51 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.3G    /var/
    619M    /var/lib
    508M    /var/lib/piVCCU3
    492M    /var/cache
    486M    /var/cache/apt
    Archived and active journals take up 48.0M in the file system.
    /opt/iobroker/backups:
    121M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    411M    /opt/iobroker/iobroker-data/
    339M    /opt/iobroker/iobroker-data/files
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    49M     /opt/iobroker/iobroker-data/backup-objects
    48M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/objects.jsonl
    8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.1
    /usr/bin/node           v18.16.1
    /usr/local/bin/npm              9.3.1
    /usr/local/bin/npx              9.3.1
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
     *** 18.16.1-deb-1nodesource1 100
         16.20.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u4 500
    Temp directories causing npm8 problem: 5
    Some problems detected, please run iob fix
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.0.3
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: has-binary2@1.0.3 /opt/iobroker/node_modules/has-binary2
    npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
    npm ERR! invalid: iobroker.backitup@2.6.23 /opt/iobroker/node_modules/iobroker.backitup
    npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
    npm ERR! invalid: iobroker.js-controller@4.0.24 /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! extraneous: iobroker.simple-api@2.7.2 /opt/iobroker/node_modules/iobroker.simple-api
    npm ERR! extraneous: iobroker.socketio@4.2.0 /opt/iobroker/node_modules/iobroker.socketio
    npm ERR! extraneous: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
    npm ERR! extraneous: iobroker.ws.server@1.0.1 /opt/iobroker/node_modules/iobroker.ws.server
    npm ERR! extraneous: iobroker.ws@1.3.0 /opt/iobroker/node_modules/iobroker.ws
    npm ERR!     /home/pi/.npm/_logs/2023-07-10T19_40_00_074Z-debug-0.log
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker-Pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : ioBroker-Pi                              -  enabled
      system.adapter.chromecast.0             : chromecast            : ioBroker-Pi                              - disabled
      system.adapter.cloud.0                  : cloud                 : ioBroker-Pi                              - disabled
      system.adapter.daikin.0                 : daikin                : ioBroker-Pi                              - disabled
      system.adapter.deconz.0                 : deconz                : ioBroker-Pi                              - disabled, port: 80
      system.adapter.devices.0                : devices               : ioBroker-Pi                              - disabled
    + system.adapter.discovery.0              : discovery             : ioBroker-Pi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker-Pi                              -  enabled
      system.adapter.history.0                : history               : ioBroker-Pi                              - disabled
      system.adapter.hm-rega.0                : hm-rega               : ioBroker-Pi                              - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-Pi                              - disabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-Pi                              - disabled, port: 0
      system.adapter.hmip.0                   : hmip                  : ioBroker-Pi                              -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-Pi                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-Pi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-Pi                              - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker-Pi                              - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-Pi                              - disabled
      system.adapter.info.0                   : info                  : ioBroker-Pi                              - disabled
      system.adapter.javascript.0             : javascript            : ioBroker-Pi                              - disabled
      system.adapter.lovelace.0               : lovelace              : ioBroker-Pi                              - disabled, port: 8091, bind: 0.0.0.0, run as: admin
      system.adapter.luftdaten.0              : luftdaten             : ioBroker-Pi                              -  enabled
      system.adapter.material.0               : material              : ioBroker-Pi                              - disabled
      system.adapter.melcloud.0               : melcloud              : ioBroker-Pi                              -  enabled
      system.adapter.mqtt.0                   : mqtt                  : ioBroker-Pi                              - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : ioBroker-Pi                              - disabled
      system.adapter.ping.0                   : ping                  : ioBroker-Pi                              - disabled
      system.adapter.rpi2.0                   : rpi2                  : ioBroker-Pi                              - disabled
      system.adapter.samsung.0                : samsung               : ioBroker-Pi                              - disabled
      system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker-Pi                              - disabled
      system.adapter.solarmanpv.0             : solarmanpv            : ioBroker-Pi                              - disabled
      system.adapter.sonos.0                  : sonos                 : ioBroker-Pi                              - disabled
      system.adapter.terminal.0               : terminal              : ioBroker-Pi                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.tr-064.0                 : tr-064                : ioBroker-Pi                              - disabled
      system.adapter.tr-064.1                 : tr-064                : ioBroker-Pi                              - disabled
      system.adapter.tr-064.2                 : tr-064                : ioBroker-Pi                              - disabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker-Pi                              - disabled
      system.adapter.vis-history.0            : vis-history           : ioBroker-Pi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-Pi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker-Pi                              - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-Pi                              - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-Pi                              - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker-Pi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker-Pi                              - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : ioBroker-Pi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-Pi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-Pi                              - disabled
      system.adapter.vis.0                    : vis                   : ioBroker-Pi                              - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker-Pi                              -  enabled
      system.adapter.web.0                    : web                   : ioBroker-Pi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.zwave2.0                 : zwave2                : ioBroker-Pi                              - disabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "chromecast"   : 3.0.3    , installed 2.3.1  [Updatable]
    Adapter    "cloud"        : 4.4.1    , installed 4.2.2  [Updatable]
    Adapter    "daikin"       : 1.4.2    , installed 1.4.2
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.12 [Updatable]
    Adapter    "info"         : 1.9.26   , installed 1.9.19 [Updatable]
    Adapter    "javascript"   : 7.0.3    , installed 6.0.3  [Updatable]
    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
    Adapter    "material"     : 1.3.1    , installed 1.1.2  [Updatable]
    Adapter    "mqtt"         : 4.1.1    , installed 4.0.7  [Updatable]
    Adapter    "openweathermap": 0.3.9   , installed 0.3.0  [Updatable]
    Adapter    "samsung"      : 0.5.11   , installed 0.5.8  [Updatable]
    Adapter    "shuttercontrol": 1.5.0   , installed 1.4.18 [Updatable]
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Objects and States
    Objects:        4142
    States:         3530
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          13899      716/dnsmasq
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14026      649/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15915      649/iobroker.js-con
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       14687      385/deCONZ
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13874      674/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13734      385/deCONZ
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13876      674/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16023      1132/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3053       379/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       13737      385/deCONZ
    udp        0      0 0.0.0.0:54252           0.0.0.0:*                           108        3055       379/avahi-daemon: r
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          13898      716/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          13895      716/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15407      514/dhclient
    udp6       0      0 :::5353                 :::*                                108        3054       379/avahi-daemon: r
    udp6       0      0 :::51997                :::*                                108        3056       379/avahi-daemon: r
    2023-07-10 20:38:46.630  - info: host.ioBroker-Pi iobroker install hmip@1.20.0 using installedFrom
    2023-07-10 20:38:50.931  - info: host.ioBroker-Pi iobroker npm-install: NPM version: 9.3.1
    2023-07-10 20:38:50.934  - info: host.ioBroker-Pi iobroker npm-install: Installing iobroker.hmip@1.20.0... (System call)
    2023-07-10 20:39:10.954  - error: host.ioBroker-Pi iobroker npm-install: host.ioBroker-Pi Cannot install iobroker.hmip@1.20.0: 217
    2023-07-10 20:39:11.979  - info: host.ioBroker-Pi iobroker npm-install: exit 25
    2023-07-10 20:39:12.979  - warn: host.ioBroker-Pi startInstance cannot find adapter "weatherunderground@3.4.2". Try to install it... 1 attempt
    2023-07-10 20:39:12.980  - info: host.ioBroker-Pi iobroker install weatherunderground@3.4.2 using installedFrom
    2023-07-10 20:39:17.273  - info: host.ioBroker-Pi iobroker npm-install: NPM version: 9.3.1
    2023-07-10 20:39:17.276  - info: host.ioBroker-Pi iobroker npm-install: Installing iobroker.weatherunderground@3.4.2... (System call)
    2023-07-10 20:39:40.539  - error: host.ioBroker-Pi iobroker npm-install: host.ioBroker-Pi Cannot install iobroker.weatherunderground@3.4.2: 217
    2023-07-10 20:39:41.571  - info: host.ioBroker-Pi iobroker npm-install: exit 25
    2023-07-10 20:39:42.571  - warn: host.ioBroker-Pi startInstance cannot find adapter "melcloud@1.3.4". Try to install it... 1 attempt
    2023-07-10 20:39:42.572  - info: host.ioBroker-Pi iobroker install melcloud@1.3.4 using installedFrom
    2023-07-10 20:39:47.498  - info: host.ioBroker-Pi iobroker npm-install: NPM version: 9.3.1
    2023-07-10 20:39:47.504  - info: host.ioBroker-Pi iobroker npm-install: Installing iobroker.melcloud@1.3.4... (System call)
    2023-07-10 20:40:13.281  - error: host.ioBroker-Pi iobroker npm-install: host.ioBroker-Pi Cannot install iobroker.melcloud@1.3.4: 217
    2023-07-10 20:40:14.336  - info: host.ioBroker-Pi iobroker npm-install: exit 25
    2023-07-10 20:40:15.338  - warn: host.ioBroker-Pi startInstance cannot find adapter "dwd@2.8.3". Try to install it... 1 attempt
    2023-07-10 20:40:15.339  - info: host.ioBroker-Pi iobroker install dwd@2.8.3 using installedFrom
    2023-07-10 20:40:20.260  - info: host.ioBroker-Pi iobroker npm-install: NPM version: 9.3.1
    2023-07-10 20:40:20.264  - info: host.ioBroker-Pi iobroker npm-install: Installing iobroker.dwd@2.8.3... (System call)
    2023-07-10 20:40:43.143  - error: host.ioBroker-Pi iobroker npm-install: host.ioBroker-Pi Cannot install iobroker.dwd@2.8.3: 217
    2023-07-10 20:40:44.168  - info: host.ioBroker-Pi iobroker npm-install: exit 25
    2023-07-10 20:40:45.169  - warn: host.ioBroker-Pi startInstance cannot find adapter "luftdaten@2.2.4". Try to install it... 1 attempt
    2023-07-10 20:40:45.169  - info: host.ioBroker-Pi iobroker install luftdaten@2.2.4 using installedFrom
    iob diag has finished.
    sorry, konnte hier gerade nicht antworten
    @dustin-f sagte in Bekomme die nodejs Installation nicht vernünftig hin:
    throttled=0x50000
    temp=62.8'C
    Dustin F.D 1 Antwort Letzte Antwort
      throttled=0x50000
      temp=62.8'C
      Dustin F.D Offline
      Dustin F.D Offline
      Dustin F.
         Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      wenn ich
      iob diag
      erneut durchlaufen lasse, erhalte ich dieselbe Fehlermeldung. Meine Vermutung ist, dass es damit zutun haben könnte, dass
      nodejs:
        Version table:
      npm und npx im /usr/local/bin sind. Die Ordner aber beim Versuch zu löschen nicht existieren. Habe versucht mit der nodejs Anleitung es zu fixen, bekomme es aber nicht hin.
      Wichtig dabei ist:
      nodejs liegt in /usr/bin
      node liegt in /usr/bin
      npm liegt in /usr/bin
      npx liegt in /usr/bin
      die Versionsnummern von nodejs und node sowie von npm und npx stimmen jeweils überein.
      Falsch ist eine Installation in /usr/local/bin oder irgendwelchen anderen Verzeichnissen als /usr/bin
      HomoranH DJMarc75D 2 Antworten Letzte Antwort
        wenn ich
        iob diag
        nodejs:
          Version table:
        Wichtig dabei ist:
        @dustin-f was sagt which npm oder npx?
          wenn ich
          iob diag
          nodejs:
            Version table:
          Wichtig dabei ist:
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @dustin-f bei Dir ist halt das Ganze auch krumm und schief.... schau in der Signatur von @Thomas-Braun und bieg das halt hin
          Lehrling seit 1975 !!!
          HomoranH Dustin F.D 2 Antworten Letzte Antwort
          • DJMarc75D DJMarc75
            @djmarc75 sagte in Bekomme die nodejs Installation nicht vernünftig hin:
            will er ja!
            aber die angeblichen falschen Pfade scheinen nicht zu existieren
              root@ioBroker-Pi:/home/pi# sudo rm /usr/local/bin/core*
              rm: cannot remove '/usr/local/bin/core*': No such file or directory
              root@ioBroker-Pi:/home/pi# sudo rm /use/local/bin/n*
              rm: cannot remove '/use/local/bin/n*': No such file or directory
              @dustin-f
              Mann Mann Mann...
              Die verfummelsten Systeme kommen dann natürlich auch IMMER mit root daher.
              IHR TUT EUCH NULL GEFALLEN MIT DEM SCHEISS-ROOT!
              Bin dann für heute raus, keinen Bock auf den Kram.
              Thomas BraunT Dustin F.D 2 Antworten Letzte Antwort
                @dustin-f
                Mann Mann Mann...
                sudo rm /usr/local/bin/n*
                heißt das. BashCompletion ftw....
                  Dustin F.D Offline
                  Dustin F.D Offline
                  Dustin F.
                  @homoran sagte in Bekomme die nodejs Installation nicht vernünftig hin:
                  which npm
                  pi@ioBroker-Pi:~ $ which npm
                  /usr/local/bin/npm
                    Dustin F.D Offline
                    Dustin F.D Offline
                    Dustin F.
                    @djmarc75
                    das versuche ich ja leider vergeblich.
                      @dustin-f
                      Mann Mann Mann...
                      Dustin F.D Offline
                      Dustin F.D Offline
                      Dustin F.
                      ohne root konnte ich aber nicht mehr weiter, da das update zu bullseye nicht anders zu installieren war
                      HomoranH crunchipC Thomas BraunT 3 Antworten Letzte Antwort
                        @dustin-f ein weiteter Hinweis dass alles verbogen ist.
                          crunchipC Offline
                          crunchipC Offline
                          @dustin-f wär mir neu, warum sollte das nicht funktionieren?
                            Dustin F.D Offline
                            Dustin F.D Offline
                            Dustin F.
                            @thomas-braun sagte in Bekomme die nodejs Installation nicht vernünftig hin:
                            das war schon mal sehr hilfreich
                            /usr/bin/npm
                              Quatsch.
                                Quatsch.
                                Dustin F.D Offline
                                Dustin F.D Offline
                                Dustin F.
                                /usr/bin/nodejs         v16.20.1
                                /usr/bin/node           v16.20.1
                                /usr/bin/npm            8.19.4
                                /usr/bin/npx            8.19.4
                                nodejs:
                                  Installed: 16.20.1-deb-1nodesource1
                                  Candidate: 16.20.1-deb-1nodesource1
                                  Version table:
                                 *** 16.20.1-deb-1nodesource1 500
                                Danke sehr!
                                • Dustin F.D Offline
                                  Dustin F.D Offline
                                  Dustin F.
                                  Ich verzweifel
                                  pi@ioBroker-Pi:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                  uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  /usr/local/bin/npx
                                  v18.16.1
                                  v18.16.1
                                  9.5.1
                                  -bash: /usr/local/bin/npx: No such file or directory
                                  wo verdammt noch mal kommt der local Ordner nun wieder her? Ich habe mich penibelst an diese Anleitung gehalten [HowTo] Nodejs-Installation und Upgrades unter Debian
                                  ok
                                  which npx
                                  ergibt
                                  /usr/bin/npx
                                    Ich verzweifel
                                    armv7l
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    /usr/local/bin/npx
                                    v18.16.1
                                    v18.16.1
                                    9.5.1
                                    ok
                                    which npx
                                    ergibt
                                    /usr/bin/npx
                                    /usr/local/bin/
                                    ls -lAh /usr/local/bin
                                    sagt?
                                    Kiste einmal sauber neugestartet? Kann sein das der $PATH nochmal neu eingelesen werden muss.
