  4. Wann ist die Waschmaschine fertig - Abfrage mit Blockly machen
    6.0k
33 Beiträge 12 Kommentatoren 7.5k Aufrufe
    mandragora
    Anbei mal mein letzer Versuch.
    Trockner Bereich bitte ignorieren.. ist noch nicht in Verwendung
    <xml xmlns="http://www.w3.org/1999/xhtml"><block type="create" id="3(+ht|)}pjx@g*jlMSP-" x="-1387" y="-713"><field name="NAME">stateWasch</field>
    <statement name="STATEMENT"><block type="on" id="CsK8ICF@K6:%TQ{T;]G0"><field name="OID">hm-rpc.0.LEQ1316334.2.CURRENT</field>
        <statement name="STATEMENT"><block type="controls_if" id="38^rWSB,U/l?Oe]ZI_);"><value name="IF0"><block type="logic_compare" id="qEY)`V_u~Lnx[+.OF,I9"><field name="OP">LT</field>
                <value name="A"><block type="get_value" id="EZCeKlk7}6}Bm`W:T7.6"><field name="ATTR">val</field>
                    <field name="OID">hm-rpc.0.LEQ1316334.2.CURRENT</field></block></value>
                <value name="B"><block type="math_number" id="!5SMR~:H+B4^Lj04C2E:"><field name="NUM">1</field></block></value></block></value>
            <statement name="DO0"><block type="control" id=".gwn]7b(a6)Ex90*v^VR"><mutation delay_input="false"></mutation>
                <field name="OID">javascript.0.stateWasch</field>
                <value name="VALUE"><block type="math_number" id="H,B.aEIs6M4{)~PC_,1r"><field name="NUM">0</field></block></value></block></statement>
            <next><block type="controls_if" id="IaZ^6]{gl~zsw=fz:~z@"><value name="IF0"><block type="logic_operation" id="tc?Y7NMf%4wGa.aTdDVo"><field name="OP">AND</field>
                    <value name="A"><block type="logic_compare" id="VTUe#]ql]FoOSz^=aHe{"><field name="OP">GT</field>
                        <value name="A"><block type="get_value" id="o2K[KO@01wL9ZL8Z,i}Q"><field name="ATTR">val</field>
                        <value name="B"><block type="math_number" id="Dh;8ZOw#hrWN9(U8_psS"><field name="NUM">1</field></block></value></block></value>
                    <value name="B"><block type="logic_compare" id="_0uLC)9..jZd|4%A!/*f"><field name="OP">LT</field>
                        <value name="A"><block type="get_value" id="O^4W:elKh=1tcN66;U8I"><field name="ATTR">val</field>
                        <value name="B"><block type="math_number" id="xRH*euSUD}1eBT@ZG4O?"><field name="NUM">32</field></block></value></block></value></block></value>
                <statement name="DO0"><block type="control" id="o);2:pPxiV+J7NmNhimA"><mutation delay_input="false"></mutation>
                    <value name="VALUE"><block type="math_number" id="%M)IG}iYVy4|W!mFa])L"><field name="NUM">1</field></block></value></block></statement>
                <next><block type="controls_if" id="`-^N2yzGJlgLxn9wy|pi"><value name="IF0"><block type="logic_compare" id="HP/.rftYe[^BnefRgt[e"><field name="OP">GT</field>
                        <value name="A"><block type="get_value" id="MU_~(}S#DQ?bm|jc2A=s"><field name="ATTR">val</field>
                        <value name="B"><block type="math_number" id="Z8[tfbfAF[,`,ruzX2|a"><field name="NUM">32</field></block></value></block></value>
                    <statement name="DO0"><block type="control" id="UCgVIVIFeLPaXZZ*}RFl"><mutation delay_input="false"></mutation>
                        <value name="VALUE"><block type="math_number" id=",*!Sw~XG5KGq|JxgU5ih"><field name="NUM">2</field></block></value></block></statement></block></next></block></next></block></statement></block></statement>
    <next><block type="create" id="CVfT2kuKJTJvlUAcu#9C"><field name="NAME">statezaehlerWasch</field>
        <statement name="STATEMENT"><block type="on" id="c@kQWqJBPfUI)z=~-^0:"><field name="OID">javascript.0.statezaehlerWasch</field>
            <statement name="STATEMENT"><block type="controls_if" id="Q_vh(2V]-EbwC{HRyX9O"><mutation else="1"></mutation>
                <value name="IF0"><block type="logic_compare" id="v3l+dzdP,S,gI:MR%|,="><field name="OP">EQ</field>
                    <value name="A"><block type="get_value" id="}42JAzBt4w#TEfKJIMRN"><field name="ATTR">val</field>
                        <field name="OID">javascript.0.stateWasch</field></block></value>
                    <value name="B"><block type="math_number" id="7W/(Gtr{SD#[Q@ieLk,E"><field name="NUM">1</field></block></value></block></value>
                <statement name="DO0"><block type="timeouts_setinterval" id="5=05m9sOMS{exPZ*QN)1"><field name="NAME">Intervall</field>
                    <field name="INTERVAL">5000</field>
                    <field name="UNIT">ms</field>
                    <statement name="STATEMENT"><block type="control" id="6[x`g+9O%XeWACOIfr(D"><mutation delay_input="false"></mutation>
                        <value name="VALUE"><block type="math_arithmetic" id="C!rG2gsCN7B+jc_I!Z9m"><field name="OP">ADD</field>
                            <value name="A"><shadow id="=g!l[t]GGE9+QQ,_jztH" type="math_number"><field name="NUM">1</field></shadow>
                              <block type="get_value" id="EW2l7[y3_7^uAP/O}D+`"><field name="ATTR">val</field>
                                <field name="OID">javascript.0.statezaehlerWasch</field></block></value>
                            <value name="B"><shadow type="math_number" id="/%[=M1Ayq7iO^N]Auc.2"><field name="NUM">1</field></shadow></value></block></value></block></statement></block></statement>
                <statement name="ELSE"><block type="control" id="(=UAym=utHp-F(AgM^U("><mutation delay_input="false"></mutation>
                    <value name="VALUE"><block type="math_number" id="]l,%?rBfpjkZr8,8tE7+"><field name="NUM">0</field></block></value>
                    <next><block type="timeouts_clearinterval" id="[A0fIzPHC%{(o)-Qu+7t"><field name="NAME">Intervall</field></block></next></block></statement>
                <next><block type="controls_if" id="t6Sg|:W0Pu{1wn)DVM?z"><value name="IF0"><block type="logic_compare" id="2ZRj0F`Ha9y:j*HNr_/0"><field name="OP">EQ</field>
                        <value name="A"><block type="get_value" id="UthuHe}U]TIocNJByE4e"><field name="ATTR">val</field>
                        <value name="B"><block type="math_number" id="PVu?6ccG37bfg-ZndfNu"><field name="NUM">0</field></block></value></block></value>
                    <statement name="DO0"><block type="timeouts_clearinterval" id="#Mzpiks?caIw)G3EhPq/"><field name="NAME">Intervall</field>
                        <next><block type="timeouts_clearinterval" id=".iY=1l9ZBrqn98@X?kps"><field name="NAME">Intervall2</field></block></next></block></statement>
                    <next><block type="controls_if" id="F/gS8yNM}hWM_sP.|5V#"><value name="IF0"><block type="logic_compare" id="l!-I+Ac9(xNn^Pv_S^(("><field name="OP">EQ</field>
                            <value name="A"><block type="get_value" id="QksI6_-MnmIgnE1@#=rr"><field name="ATTR">val</field>
                            <value name="B"><block type="math_number" id="=}4Y%8K?l1;~_5YS[_sK"><field name="NUM">2</field></block></value></block></value>
                        <statement name="DO0"><block type="timeouts_clearinterval" id="E1}rcxzy}1nG3V`cCDrU"><field name="NAME">Intervall2</field></block></statement></block></next></block></next></block></statement>
            <next><block type="on" id="g{,DubcFl~T`:#,:P)ar"><field name="OID">javascript.0.statezaehlerWasch</field>
                <statement name="STATEMENT"><block type="controls_if" id="X/px+_@O_[*^`+):;2o)"><value name="IF0"><block type="logic_operation" id="vD[WmR{r2H,ZNPI6#HGj"><field name="OP">AND</field>
                        <value name="A"><block type="logic_compare" id="Z0^w](df`urTMV_^,A.S"><field name="OP">GT</field>
                            <value name="A"><block type="get_value" id="b,:eZedEzIVu+izbkP4/"><field name="ATTR">val</field>
                            <value name="B"><block type="math_number" id="srtuo?7[DU+{dOWKd`hM"><field name="NUM">38</field></block></value></block></value>
                        <value name="B"><block type="logic_compare" id="d,u``{1:{2|R5g-=-xo="><field name="OP">GT</field>
                            <value name="A"><block type="get_value" id="fTm4=ZqjmXU]HUJIox|N"><field name="ATTR">val</field>
                            <value name="B"><block type="math_number" id="_b3jer/*Yc-6CX9Zp6JR"><field name="NUM">0</field></block></value></block></value></block></value>
                    <statement name="DO0"><block type="timeouts_setinterval" id="A]_OJZPbB;jhHb0N%XRS"><field name="NAME">Intervall2</field>
                        <field name="INTERVAL">60000</field>
                        <statement name="STATEMENT"><block type="sayit" id="2C-5!u3RZ9r:8PIpSAM3"><field name="INSTANCE">.0</field>
                            <field name="LANGUAGE">de</field>
                            <value name="MESSAGE"><shadow type="text" id="CqY5`YVq1tV]RT5EZ%_I"><field name="TEXT">Die Waschmaschine ist fertig</field></shadow></value>
                            <next><block type="sendto_custom" id="QGC.*r?hlDsWXIHPX`eu"><mutation items="parameter1" with_statement="false"></mutation>
                                <field name="INSTANCE">telegram.0</field>
                                <field name="COMMAND">send</field>
                                <field name="WITH_STATEMENT">FALSE</field>
                                <value name="ARG0"><shadow type="text" id="RagxaiCzCu{hx?r@%q4u"><field name="TEXT">Die Waschmaschine ist fertig</field></shadow></value></block></next></block></statement>
                        <next><block type="timeouts_clearinterval" id="k0e5C{uzr8/tHvzuS-tm"><field name="NAME">Intervall</field></block></next></block></statement></block></statement></block></next></block></statement>
        <next><block type="create" id="qvtk2OM{p[BEiS1AXaGf"><field name="NAME">stateTrockner</field>
            <statement name="STATEMENT"><block type="on" id="G,xQ;Vg^-2)bY;+3~qT)"><field name="OID">hm-rpc.0.NEQ1559439.2.POWER</field>
                <statement name="STATEMENT"><block type="controls_if" id="cqmr|49igl8hFT)mAA6~"><value name="IF0"><block type="logic_compare" id="extv07ywJozNX:ohE=m="><field name="OP">LT</field>
                        <value name="A"><block type="get_value" id="0f^YtOvC:[Bwd5]JY{4*"><field name="ATTR">val</field>
                            <field name="OID">hm-rpc.0.NEQ1559439.2.POWER</field></block></value>
                        <value name="B"><block type="math_number" id="IMh}f29~]X;h^1kl-Fjy"><field name="NUM">0.5</field></block></value></block></value>
                    <statement name="DO0"><block type="control" id="@4tIZ3aDV]DT2.VTrFD)"><mutation delay_input="false"></mutation>
                        <field name="OID">javascript.2.stateTrockner</field>
                        <value name="VALUE"><block type="math_number" id="T!=ALTiZkg|r7*L+SNeW"><field name="NUM">0</field></block></value></block></statement>
                    <next><block type="controls_if" id="oeE%%Jn@X(]G:+N[IpF1"><value name="IF0"><block type="logic_operation" id="@Ghr^`#lg2[65cF_J=mV"><field name="OP">AND</field>
                            <value name="A"><block type="logic_compare" id="43RO~zx+SeUCKZAUEg6o"><field name="OP">GT</field>
                                <value name="A"><block type="get_value" id="KUVRX;YkZ67x.4`r@O%A"><field name="ATTR">val</field>
                                <value name="B"><block type="math_number" id="3Qq5d|Hzq78q9~zd?~c!"><field name="NUM">0.5</field></block></value></block></value>
                            <value name="B"><block type="logic_compare" id="!X0dgH+P6bl:1FPxTkGh"><field name="OP">LT</field>
                                <value name="A"><block type="get_value" id="]%Wtu]?k!Sj~B_`fIKUl"><field name="ATTR">val</field>
                                <value name="B"><block type="math_number" id="(e9ib?:F6k.o,fWV34px"><field name="NUM">100</field></block></value></block></value></block></value>
                        <statement name="DO0"><block type="control" id="a[Cd3f,O/GJOZzOvQ;KX"><mutation delay_input="false"></mutation>
                            <value name="VALUE"><block type="math_number" id="xA,J7,fMmt!Z~E)?F5!v"><field name="NUM">1</field></block></value></block></statement>
                        <next><block type="controls_if" id="|6HqaA6l`Y[p!A^@PT1}"><value name="IF0"><block type="logic_compare" id=".Aw=F,T~jS)tTESpd%)?"><field name="OP">GT</field>
                                <value name="A"><block type="get_value" id="mc~6m/H7|9;_2%1os!o*"><field name="ATTR">val</field>
                                <value name="B"><block type="math_number" id="ik_)SNS93V_XnDe8#0bF"><field name="NUM">100</field></block></value></block></value>
                            <statement name="DO0"><block type="control" id="A]kU+5Y|I*nVM?q;#l4="><mutation delay_input="false"></mutation>
                                <value name="VALUE"><block type="math_number" id="}[mJg~]/bCCxgbhj=d~k"><field name="NUM">2</field></block></value></block></statement></block></next></block></next></block></statement></block></statement>
            <next><block type="create" id="/K|y2EEZak[tFo:c{%W]"><field name="NAME">statezaehlerTrockner</field>
                <statement name="STATEMENT"><block type="on" id="AqH{:ZSr`giIi8x(N8qB"><field name="OID">javascript.2.stateTrockner</field>
                    <statement name="STATEMENT"><block type="controls_if" id="F?5}P5C7#_uD*mD#VR:+"><mutation else="1"></mutation>
                        <value name="IF0"><block type="logic_compare" id="ns=pqy^-JL))LK^15eEM"><field name="OP">EQ</field>
                            <value name="A"><block type="get_value" id=";Tc!_Xy{{b]kUpI=jodG"><field name="ATTR">val</field>
                                <field name="OID">javascript.2.stateTrockner</field></block></value>
                            <value name="B"><block type="math_number" id="=u8N=i-umNo-gc@~;)jO"><field name="NUM">1</field></block></value></block></value>
                        <statement name="DO0"><block type="timeouts_setinterval" id="h5YW99[o2AaEr%H?0n.]"><field name="NAME">Intervall3</field>
                            <statement name="STATEMENT"><block type="control" id="CEM8kc.tClL6(AJxDN@9"><mutation delay_input="false"></mutation>
                                <field name="OID">javascript.2.statezaehlerTrockner</field>
                                <value name="VALUE"><block type="math_arithmetic" id="5s3mCI|Oiq,-[I1%Ipm#"><field name="OP">ADD</field>
                                      <block type="get_value" id="i|tfxXum`I_h,OkHZc!E"><field name="ATTR">val</field>
                                        <field name="OID">javascript.2.statezaehlerTrockner</field></block></value>
                                    <value name="B"><shadow type="math_number" id="#*I-lA0g;.h*ynbm~mg~"><field name="NUM">1</field></shadow></value></block></value></block></statement></block></statement>
                        <statement name="ELSE"><block type="control" id="9XUVGw:(#._(uIhK_|P:"><mutation delay_input="false"></mutation>
                            <value name="VALUE"><block type="math_number" id="5aY.f_sfkFt}p1I)Jq.G"><field name="NUM">0</field></block></value>
                            <next><block type="timeouts_clearinterval" id="z|Y6mG/2l[tVVeg]^x)7"><field name="NAME">Intervall3</field></block></next></block></statement>
                        <next><block type="controls_if" id="^eVjyxqus6EC=jr7CvNe"><value name="IF0"><block type="logic_compare" id="VZVwb+K?tx!*21m2GNY#"><field name="OP">EQ</field>
                                <value name="A"><block type="get_value" id="F6l6|sNgmL;o;Xe^WeiB"><field name="ATTR">val</field>
                                <value name="B"><block type="math_number" id="OWSjVH41E4lBFXwX,bV%"><field name="NUM">0</field></block></value></block></value>
                            <statement name="DO0"><block type="timeouts_clearinterval" id="k3!U1JyZ;eA-}l2J(4_4"><field name="NAME">Intervall3</field>
                                <next><block type="timeouts_clearinterval" id="o-CHv+]%gNAFb1?l%~yL"><field name="NAME">Intervall4</field></block></next></block></statement>
                            <next><block type="controls_if" id="okxL3sCA?%37hB~9bSxZ"><value name="IF0"><block type="logic_compare" id="@=xOL@c[8O5}qACF/1on"><field name="OP">EQ</field>
                                    <value name="A"><block type="get_value" id="bEAvO3gqS@?O5B+9o2kD"><field name="ATTR">val</field>
                                    <value name="B"><block type="math_number" id="TE}{eLj3(`))xS,]u)R9"><field name="NUM">2</field></block></value></block></value>
                                <statement name="DO0"><block type="timeouts_clearinterval" id="3ZgYfNZ(7C|a/y_Eat7I"><field name="NAME">Intervall4</field></block></statement></block></next></block></next></block></statement>
                    <next><block type="on" id="|c#jU_BLifB;J}_WLNo|"><field name="OID">javascript.2.statezaehlerTrockner</field>
                        <statement name="STATEMENT"><block type="controls_if" id="rkskfXWd{oZ._!a?ZiG?"><value name="IF0"><block type="logic_operation" id="`UA#c_#QsVd#Dh8:d}cS"><field name="OP">AND</field>
                                <value name="A"><block type="logic_compare" id="GiT!f~Ma@8GC4Fs])A^="><field name="OP">GT</field>
                                    <value name="A"><block type="get_value" id="?{7IGh9yT2)3LG7ezWc{"><field name="ATTR">val</field>
                                    <value name="B"><block type="math_number" id="|ULbCPq:/n;w`g(uU[Ik"><field name="NUM">60</field></block></value></block></value>
                                <value name="B"><block type="logic_compare" id="ju9;n=j;Z@8;D_1l3@:m"><field name="OP">GT</field>
                                    <value name="A"><block type="get_value" id="@[Ji:kv|^(/Dwn9Fu,t)"><field name="ATTR">val</field>
                                    <value name="B"><block type="math_number" id="l(i0M8z,|Sl{q{LcP:)N"><field name="NUM">0</field></block></value></block></value></block></value>
                            <statement name="DO0"><block type="timeouts_setinterval" id="G{*mYUDCdUP*z;Zw`4gy"><field name="NAME">Intervall4</field>
                                <statement name="STATEMENT"><block type="sayit" id="_|Z[}KSb=]K-n~PDvZE:"><field name="INSTANCE">.0</field>
                                    <value name="MESSAGE"><shadow type="text" id="}2,DR{d8]%6!mu82uFkl"><field name="TEXT">Der Trockner ist fertig</field></shadow></value></block></statement>
                                <next><block type="timeouts_clearinterval" id="WrE,7jh|4Q9.}d!r8]9U"><field name="NAME">Intervall3</field></block></next></block></statement></block></statement></block></next></block></statement></block></next></block></next></block></next></block></xml>
    @ dna909
    Ich hab .current in Verwendung. Wie gesagt verstehe ich den Ablauf hier anscheinend nicht genau denn nach verschiedenem Anpassen der Werte funktioniert es noch nicht
    @ lesliflo
    Ich würde halte gerne alles was möglich ist in Blockly umsetzen da mir das Webinterface der CCU2 noch nie wirklich gefallen hat und ich es hier übersichtlicher finde.
    Vielen Dank Leute
    lg
    mandragora
    ioBroker auf Synology DS218+ (Docker); VIS: 2x8" Tablets; Homematic CCU2 und Komponenten; Echo DOT; Unifi Ap-Ac Pro; Landroid S; Jovision IPCams
    • L Online
      L Online
      lesiflo
      Ok, das Webinterface ist eine Sache für sich. Aber ob nun dein Script hier übersichtlicher finde ich nicht so.
      Aber okay jeder so wie er mag. Jedenfalls funktioniert die Sache über die CCU mit wesentlicher weniger Aufwand als über Blockly.
        michi050
        Hallo, ich helfe Dir sehr gerne weiter.
        Im oberen Bereich wird die Leistung der Waschmaschine ermittelt. Ich habe die Leistungsbereiche in 3 Stufen unterteilt. In der Stufe 1 ist die Maschine aus (0 Watt, Schalter aus), in der Stufe 2 ist die Maschine im Knitterschutzbetrieb oder im Modus zwischen den Betriebsszenarien (Leerlauf zwischen spülen, schleudern usw.). In der Stufe 3 wird gewaschen, bei meiner Maschine wäre das dann ein Leistungsvolumen von über 40 Watt.
        Im unteren Bereich (statewasch) werden die Ruhezeiten anhand der Intervallschleife ermittelt. Ist die Maschine bspw. längere Zeit im Knitterschutzbetrieb (also fertig mit waschen), dann zählt der Zähler hoch und gibt dann bei überschreiten der Zählerschwelle die Meldung im 3. Bereich des Scripts (statezählerwasch) eine Sprachmeldung aus. Nimmt die Maschine jedoch nach einer Ruhezeit (Einweichphase) wieder den Waschbetrieb auf, dann wird der zyklische Intervallzähler bis zur nächsten Spülpause wieder resettet und zählt nach nach der nächsten Ruhepause wieder hoch.
        Du solltest auf jeden Fall Deine Messung über die Leistung (Watt) ermitteln und nicht über den Strom (mA). Ich weiß, dass die Parameter (P=U*I) das gleiche Ergebnis liefern, könnte also Geschmackssache sein, was man benutzt. Die Intervalle solltest Du auch an die Maschine anpassen, da das Leistungs- und Ruheverhalten der Waschmaschinen unterschiedlich ist.
        Ich bin auch froh, wenn ich im Forum Hilfe bekomme, deswegen nehme ich mir auch für Dich sehr gerne Zeit.
        Gruß Michael
          michi050
          @lesiflo
          Eine Programmierung über die CCU finde ich bescheiden, ich versuche jedes Programm aus der CCU fern zu halten. Sie ist für mich nur noch der Torso um Funksignale zu senden, sonst nix.
          • L Online
            L Online
            lesiflo
            Ok, warum einfach wenn's auch kompliziert geht. Jedenfalls ist mir dein Script etwas zu aufwendig. Mag aber auch sein das das an der Waschmaschine liegt das ganze so kompliziert zu machen. Aber was soll's jeder so wie er mag. Ich bin dann raus.
            Gesendet von meinem FRD-L09 mit Tapatalk
              tempestas
              Skurriler Auftritt :lol:
              <size="85">ioBroker | 21 Adapter | Ubuntu Server | intel NUC | Homematic CCU2 | Hue | Osram Lightify| Sonos | 2x Instar Cam | Samsung Tab A 2016 im Holzrahmen| 3x Echo dot | 1x Echo | Neato Botvac D5</size>
                michi050
                So ist es, ich dachte auch anfänglich, dass es einfacher zu lösen wäre. Bis zu dem Zeitpunkt, als ich das Eigenleben einer Waschmaschine erleben durfte. Für findige Programmierer ist das sicherlich einfacher zu lösen, aber für einen Scriptanwender der in Ermangelung der Kenntnisse scheitert, ist Blocky einfach genial. Deswegen einen herzlichen Dank an die Entwickler, die solchen Leuten wie meine Wenigkeit die Möglichkeit einer einfachen vielleicht auch etwas komplizierteren aber funktionierenden Lösung eröffnen. Mit Blockly habe ich, wenn auch in einer immer wieder abgewandelten Form, eigentlich alles hinbekommen.
                  mandragora
                  Hallo nochmals und vielen Dank @michi050 für die Erklärung.
                  Mir ist jetzt schon einiges klarer geworden und ich werde mal ein paar Änderungen vornehmen und das weiterhin testen.
                  Falls ich noch weitere Fragen habe würde ich mich gerne wieder hier melden.
                  Vielen Dank nochmals an alle die mir bei meinen Probleme und Fragen helfen und auch die Geduld dafür aufbringen auch wenn die Fragen oftmals "blöd" klingen.
                  iOBroker ist echt ein mächtiges Werkzeug und hat so viele Bereiche wo man sich als Anfänger gerne verrennen kann.
                  Die Hilfsbereitschaft hier im Forum ist aber gigantisch und es wird keiner alleine gelassen… und das finde ich super...
                  DANKE
                  lg
                  mandragora
                    marce802
                    Hi zusammen,
                    @michi050 ich habe es mit deinem Script so versucht nur habe ich es statt sayit mit Pushover versucht, soweit klappt es auch nur wenn die Maschine fertig ist bekomme ich im Sek. Takt push Benachrichtigungen.
                    Könnte mir jemand sagen wie ich das einstellen muss, dass wenn die Maschine fertig ist sie mir nur eine Nachricht schickt?
                    marce802
                    • DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      @marce802:
                      marce802 `
                      Oh man ich habe Mal wieder meine Glaskugel verlegt so ein Mist…
                      Poste doch Mal dein Script dann können wir drüber schauen und helfen ;)
                      Send from mobile device
                        marce802
                        sorry :) , aber wie gesagt habe alles gleich bis auf Pushover, anbei ein paar screenshots:
                          dna909
                          Dann musst Du den Intervall rausnehmen. Dann kommt die Meldung auch nur einmalig.
                          dna909
                          Intel NUC7PJYH mit Proxmox, Odroid U2, CCU2, Philips Hue, ESP8266, Xiaomi Robot, Google Chromecast Audio, Instar 6012HD, Bosch HNG6764S6
                            StefanH.
                            Hi Leute,
                            mal eine generelle Frage. Ist die Homematic Steckdose (bedingungslos) empfehlenswert, oder gibt es eventuell "weitaus" bessere Alternativen für dieses Projekt?
                            Stefan, der auf die Lieferung des OrangePis aus Nahost wartet, damit er endlich iobroker installieren kann ;-)
                              Kueppert
                              Hallo Stefan,
                              wichtig ist dass die Steckdose nicht nur 2500 Watt verkraftet. Ich hatte schon das Problem das meine Fibaro, die nur 2500 Watt mit macht, einfach aus ging wegen über Belastung. Hab mit dann die homematic Dosen bestellt und diese an große Verbraucher gehangen.
                              Nur so als Tipp am Rande.
                              VG Thorsten
                              Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk
