  4. Test Adapter vis 2.0 (Alpha)
    6.8k
780 Beiträge 108 Kommentatoren 352.4k Aufrufe 140 Beobachtet
  • M Morluktom
    ich bekomme den Editor nicht zum laufen.
    Der Editor sieht bei mir wie folgt aus:
    Browser Konsole
    [Log] iobroker.vis-2-beta@2.0.33 using theme "colored" (167.d9e48650.chunk.js, line 1)
    [Error] Failed to load resource: the server responded with a status of 404 (Not Found) (main.39cd355f.js.map, line 0)
    [Error] Failed to load resource: the server responded with a status of 404 (Not Found) (3.fcae646b.chunk.js.map, line 0)
    [Log]  (main.39cd355f.js, line 2)
    [Log] Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters (main.39cd355f.js, line 2)
    [Log] Help us to create open source project with reactJS! (main.39cd355f.js, line 2)
    [Log] See you :) (main.39cd355f.js, line 2)
    [Log] [2023-06-17T20:06:02.124Z] Try to connect (socket.io.js, line 83)
    [Log] [Object, Object, Object, Object, Object, Object, Object, Object, Object, Object, …] (24) (3.fcae646b.chunk.js, line 2)
    [Log] Metro version: "1.2.0" (3.fcae646b.chunk.js, line 2)
    [Log] Version lg-ess-home: 0.0.1 (3.fcae646b.chunk.js, line 2)
    [Log] Version Info-Adapter-Widget: 0.0.9 (3.fcae646b.chunk.js, line 2)
    [Error] Failed to load resource: the server responded with a status of 404 (Not Found) (words.js, line 0)
    [Error] Failed to load resource: the server responded with a status of 404 (Not Found) (echarts.js.map, line 0)
    [Info] Download the Vue Devtools extension for a better development experience: (3.fcae646b.chunk.js, line 2)
    https://github.com/vuejs/vue-devtools
    [Info] You are running Vue in development mode. (3.fcae646b.chunk.js, line 2)
    Make sure to turn on production mode when deploying for production.
    See more tips at https://vuejs.org/guide/deployment.html
    [Error] Cannot load script http://iobroker.local:8082/vis-2-beta/widgets/materialdesign/lib/raw/sentry/bundle.min.js. Failed integrity metadata check. Content length: 66956, Expected content length: -1, Expected metadata: sha384-S9ussaVrGYHtod/SiHF797c08MZHpGkpAdHM1VtFSxMr3YSA2w82OMfAJOg+knm/
    [Log] Version time-switch: 2.2.2 (3.fcae646b.chunk.js, line 2)
    FeuersturmF Offline
    FeuersturmF Offline
    Feuersturm
    #691
    @morluktom Ist das "main" Projekt die Übernahme aus deiner Vis1 Umgebung? Kannst du unter vis2 ein neues leeres Projekt anlegen, wo dann der Editor startet?
    • FeuersturmF Feuersturm
      Morluktom
      #692
      @feuersturm Das Projekt das übernommen wurde habe ich schon gelöscht. Das "main" ist ein neu erstelltes leeres Projekt.
      • M Morluktom
        FeuersturmF Offline
        FeuersturmF Offline
        Feuersturm
        #693
        @morluktom Da hilft vermutlich nur ein issue bei github https://github.com/ioBroker/ioBroker.vis/issues einzustellen.
          Marsx79
          schrieb am zuletzt editiert von Marsx79
          #694
          Moin.
          Wo finde ich denn das Vis Log? Gibt es überhaupt ein Separates?
          Wenn ich meine "Main" View (Startseite) aufrufe wird der Bildschirm weiß und die Seite lädt neu. Muss also irgendwo ein Fehler drin sein.
          Im "normalen" ioBroker Log sind keine Fehler.
          • M Marsx79
            Moin.
            #695
            @marsx79 sagte in Test Adapter vis 2.0 (Alpha):
            nein, aber man kann die Logstufe der Instanz auf debug schalten, dann ist es schonmal nicht mehr
            dann nach vis2 filtern.
            das würde dir u.a. die Browserkonsole erzählen
              Marsx79
              #696
              Danke für die Infos!
              Diese Fehler werden über die Konsole ausgegeben.
              DevTools failed to load source map: Could not load content for http://192.168.178.3:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
              DevTools failed to load source map: Could not load content for http://192.168.178.3:8082/vis-2-beta/static/js/main.39cd355f.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
              DevTools failed to load source map: Could not load content for chrome-extension://mmhlniccooihdimnnjhamobppdhaolme/lib/tp/browser-polyfill.min.js.map: System error: net::ERR_BLOCKED_BY_CLIENT
              DevTools failed to load source map: Could not load content for http://192.168.178.3:8082/vis-2-beta/static/js/3.fcae646b.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
              bootstrap.jsx:20 iobroker.vis-2-beta@2.0.33 using theme "colored"
              main.39cd355f.js:2
              main.39cd355f.js:2 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
              main.39cd355f.js:2 Help us to create open source project with reactJS!
              main.39cd355f.js:2 See you :)
              api.js:13 (24) [{…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}]
              3.fcae646b.chunk.js:2 Translate: background
              3.fcae646b.chunk.js:2 Version vis-google-fonts: 0.0.1
              3.fcae646b.chunk.js:2 Version vis-jqui-mfd: 1.0.12
              3.fcae646b.chunk.js:2 Metro version: "1.2.0"
              3.fcae646b.chunk.js:2 Version players: 0.1.0
              3.fcae646b.chunk.js:2 Version Info-Adapter-Widget: 0.0.9
              3.fcae646b.chunk.js:2 Download the Vue Devtools extension for a better development experience:
              3.fcae646b.chunk.js:2 You are running Vue in development mode.
              3.fcae646b.chunk.js:2 Version vis-materialdesign: 0.5.9
              3.fcae646b.chunk.js:2 Translate: jqui_html_dialog
              3.fcae646b.chunk.js:2 Translate: jqui_icon_dialog
              3.fcae646b.chunk.js:2 Translate: jqui_container_dialog
              3.fcae646b.chunk.js:2 Translate: bars
              3.fcae646b.chunk.js:2 Translate: dwd
              3.fcae646b.chunk.js:2 Translate: hqwidgets
              3.fcae646b.chunk.js:2 Translate: info
              3.fcae646b.chunk.js:2 Translate: jqplot
              3.fcae646b.chunk.js:2 Translate: jqui-mfd
              3.fcae646b.chunk.js:2 Translate: materialdesign
              3.fcae646b.chunk.js:2 Translate: metro
              3.fcae646b.chunk.js:2 Translate: players
              3.fcae646b.chunk.js:2 Translate: swipe
              3.fcae646b.chunk.js:2 Translate: timeandweather
              3.fcae646b.chunk.js:2 Translate: tabs
              3.fcae646b.chunk.js:2 vis-materialdesign: sentry datapoint 'vis-materialdesign.0.sentry' not exist! Go to the adapter settings to activate it.
              (anonymous) @ 3.fcae646b.chunk.js:2
              initializeSentry @ widgets.min.js:1
              await in initializeSentry (async)
              (anonymous) @ materialdesign.js:35
              (anonymous) @ widgets.min.js:1
              (anonymous) @ visEngine.jsx:1165
              Promise.then (async)
              emit @ visEngine.jsx:1165
              getObject @ widgets.min.js:1
              getVersion @ widgets.min.js:1
              (anonymous) @ materialdesign.js:32
              i @ 3.fcae646b.chunk.js:2
              setTimeout (async)
              waitForVisConnected @ widgets.min.js:1
              showVersion @ materialdesign.js:31
              3.fcae646b.chunk.js:2 Someone installs handler without to remove it!
              n.registerChangeHandler @ visEngine.jsx:1509
              i @ visCanWidget.jsx:90
              Wo @ main.39cd355f.js:2
              Li @ main.39cd355f.js:2
              Cs @ main.39cd355f.js:2
              Hl @ main.39cd355f.js:2
              gl @ main.39cd355f.js:2
              zl @ main.39cd355f.js:2
              al @ main.39cd355f.js:2
              ol @ main.39cd355f.js:2
              V @ main.39cd355f.js:2
              T @ main.39cd355f.js:2
              3.fcae646b.chunk.js:2 TypeError: Cannot read properties of undefined (reading 'length')
                  at Function.value (visRxWidget.jsx:118:46)
                  at new i (visRxWidget.jsx:95:48)
                  at i.<anonymous> (createSuper.js:11:24)
                  at new i (BasicViewInWidget8.jsx:23:25)
                  at Wo (main.39cd355f.js:2:6743048)
                  at Li (main.39cd355f.js:2:6763489)
                  at Cs (main.39cd355f.js:2:6809634)
                  at Hl (main.39cd355f.js:2:6797775)
                  at gl (main.39cd355f.js:2:6797703)
                  at zl (main.39cd355f.js:2:6797566)
                  at al (main.39cd355f.js:2:6794346)
                  at ol (main.39cd355f.js:2:6792897)
                  at V (main.39cd355f.js:2:8223976)
                  at MessagePort.T (main.39cd355f.js:2:8224510)
              di @ main.39cd355f.js:2
              n.callback @ main.39cd355f.js:2
              Do @ main.39cd355f.js:2
              xs @ main.39cd355f.js:2
              Hs @ main.39cd355f.js:2
              Ms @ main.39cd355f.js:2
              (anonymous) @ main.39cd355f.js:2
              Vl @ main.39cd355f.js:2
              main.39cd355f.js:2 Uncaught TypeError: Cannot read properties of undefined (reading 'length')
              value @ visRxWidget.jsx:118
              i @ visRxWidget.jsx:95
              (anonymous) @ createSuper.js:11
              i @ BasicViewInWidget8.jsx:23
                duesterk
                schrieb am zuletzt editiert von duesterk
                #697
                ich habe ein Problem mit dem hinzufügen eines Objekts im Vis.2 Material Widget.
                Ich habe dazu ein Issue beim Vis2 Widget Material Adapter eröffnet.
                Ich bin aber nicht sicher, ob es von Vis.2 oder eben vom Material Widget kommt.
                Eventuell kann mir ja hier jemand helfen.
                https://github.com/ioBroker/ioBroker.vis-2-widgets-material/issues/153
                • D duesterk
                  FeuersturmF Offline
                  FeuersturmF Offline
                  Feuersturm
                  #698
                  @duesterk Ich hab dir mal im github issue geantwortet. Kann versuchen es bei mir nachzustellen.
                  Mittlerweile gibt es auch vis2 version v2.0.35 auf npm
                    duesterk
                    #699
                    @feuersturm Danke fürs prüfen, ich habe auch mit V2.0.35 das gleiche Problem.
                    Es ist auch sehr seltsam, habe noch weiter an meiner Vis in Vis.2 gearbeitet und konnte keinweiteres Objekt finden, welches nicht funktioniert.
                    Nur das genannte Objekt und ein paar wenige andere bekomme ich einfach nicht eingebunden.
                    Habe auch die Objekte schon gelöscht und nachdem der Adapter die Objekte wieder neu hinzugefügt hat, habe ich immer noch das selbe Problem.
                    • W Offline
                      W Offline
                      wolfgam
                      #700
                      ich stehe hier irgendwie am Schlauch.
                      • wie funktioniert der Steal von Attributen?
                      • wie bekomme ich die Auswahlliste möglicher CSS Attribute angezeigt (z.B. border-style = dotted, dashed, solid,...)?
                      Wolfgang
                      • MichaelScM Offline
                        MichaelScM Offline
                        MichaelSc
                        #701
                        Neue VIS2-Installation, zeigt sich wie folgt:
                        Was muss ich noch tun?
                        iOBroker (and the other stuff) on a Proxmox Installation on an Intel NUC10.
                        IoT: Discarded Zigbee-System and all the hardware related to Zigbee; replaced with HomeMatic IP - very reliable.
                        • MichaelScM MichaelSc
                          #702
                          @michaelsc versuch nochmal manuell zu migrieren, da scheint wohl die automatische übernahme nicht geklappt zuhaben. siehe post #1
                          MichaelScM 1 Antwort Letzte Antwort
                          • apollon77A apollon77
                            MichaelScM Offline
                            MichaelScM Offline
                            MichaelSc
                            #703
                            @apollon77 said in Test Adapter vis 2.0 (Alpha):
                            @michaelsc versuch nochmal manuell zu migrieren...
                            Mein Fehler. Der Hinweis auf Post #1 war schon goldrichtig: Der Adapter vis-metro war nicht richtig installiert.
                            Nachdem ich den dann nochmal installiert hatte, kam im Aufruf "192.168.178.201:8082/vis-2-beta/edit.html?ALF1#..." sofort der Editor.
                            Danke sehr!
                              MichaelScM Offline
                              MichaelSc
                              #704
                              Auf den ersten Blick: Da funktioniert ja schon soooooooviel in meinem großen Projekt - ich bin erstaunt und hocherfreut.
                              Auf den zweiten Blick:
                              • Scrollen in längeren Views scheint noch nicht zu gehen, oder ich muss da noch eine Einstellung anpassen.
                              • Die von mir gerne benutzten Pop-Up-Views kommen anscheinend noch nicht.
                              Aber das schau ich mir noch in Ruhe an und werde dann Details anfragen.
                              Vielen Dank!
                              ice987I 1 Antwort Letzte Antwort
                                Vielen Dank!
                                ice987I Offline
                                ice987I Offline
                                ice987
                                #705
                                @michaelsc sagte in Test Adapter vis 2.0 (Alpha):
                                https://github.com/ioBroker/ioBroker.vis/issues/612 ?
                                husqvarna-automower, meteoblue, wiserbyfeller, spritmonitor
                                • ice987I ice987
                                  MichaelScM Offline
                                  MichaelScM Offline
                                  MichaelSc
                                  #706
                                  @ice987 Danke, ist also nach meinem Verständnis dann ein erkanntes Issue und noch offen. Okay.
                                    MichaelScM Offline
                                    MichaelSc
                                    #707
                                    Wenn ich jetzt der Ansicht bin, dass ein Vis-Inventwo Universal Widget mit der Popup-Funktion...
                                    ...bei Änderung des zur Steuerung eingestellten Datenpunktes...
                                    nicht reagiert, sprich: Den Popup nicht einleitet - WAS muss ich dann tun? Das hier erst als Frage einstellen (was hiermit geschehen ist) oder beim Widget-Hersteller vis-inventwo anfragen, ob ihr Widget schon unter VIS-2-beta lauffähig ist?
                                      MichaelScM Offline
                                      MichaelSc
                                      #708
                                      web.0
                                      2023-07-06 08:02:14.902 error Error: can't update states object for zoe2.0.VF1AG000X65218215.charge_level(TypeError: RGraph.Effects.Gauge is undefined): "tplRGgauge/elem.rgraphValueChange@http://192.168.178.201:8082/vis-2-beta/edit.html?ALF1#**ALF1_Solaranzeige_4** line 1 > injectedScript:973:21\nonchange@http://192.168.178.201:8082/vis-2-beta/edit.html?ALF1#ALF1_Solaranzeige_4 line 1 > injectedScript:138:30\n36167/i/n.onStateChange/<@http://192.168.178.201:8082/vis-2-beta/static/js/167.5a545327.chunk.js:1:348602\n36167/i/n.onStateChange@http://192.168.178.201:8082/vis-2-beta/static/js/167.5a545327.chunk.js:1:348575\n83251/value/<@http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:721569\nvalue@http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:721543\n83251/value/</<@http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:713606\ni@http://192.168.178.201:8082/vis-2-beta/static/js/618.b9cdaf52.chunk.js:2:90250\n"
                                      web.0
                                      2023-07-06 08:00:08.960 error Error: can't update states object for zoe2.0.VF1AG000X65218215.charge_level(TypeError: Cannot read properties of undefined (reading 'Grow')): "TypeError: Cannot read properties of undefined (reading 'Grow')\n at elem.rgraphValueChange (<anonymous>:973:42)\n at Object.onchange [as callback] (<anonymous>:138:30)\n at http://192.168.178.201:8082/vis-2-beta/static/js/167.5a545327.chunk.js:1:348602\n at Array.forEach (<anonymous>)\n at n.onStateChange (http://192.168.178.201:8082/vis-2-beta/static/js/167.5a545327.chunk.js:1:348575)\n at http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:721568\n at Array.forEach (<anonymous>)\n at t.value (http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:721543)\n at http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:713606\n at i (http://192.168.178.201:8082/vis-2-beta/static/js/618.b9cdaf52.chunk.js:2:90250)"
                                      Zeigt dieser Fehler auf ein bestimmtes Widget?
                                      Ich kann nur raten:
                                      allerdings wird hier ja der richtige Wert angezeigt.
                                      Wie kommt man dem Verursacher auf die Spur?
                                        web.0
                                        web.0
                                        Ich kann nur raten:
                                        #709
                                        @michaelsc mach doch mal Github issue bei vis2 und/oder gauge?
                                          MichaelScM Offline
                                          MichaelScM Offline
                                          MichaelSc
                                          schrieb am zuletzt editiert von MichaelSc
                                          #710
                                          @apollon77 Trotz "Suche" finde ich kein VIS2 in Github, kannst Du bitte helfen?
                                          sigi234S arteckA 2 Antworten Letzte Antwort
