  4. ZigBee neue Version 1.8.x
385 Beiträge 55 Kommentatoren 111.0k Aufrufe 49 Beobachtet
  • arteckA arteck
    @xsev sagte in ZigBee neue Version 1.8.x:
    evtl. ist meine Firmware auf dem Stick auch zu alt mittlerweile?
    das hat damit nix zu tun..
    instellier mal die GIT version und schau nochmal
    XsevX Offline
    XsevX Offline
    Xsev
    schrieb am zuletzt editiert von Xsev
    #117
    @arteck Danke für deine Hilfe. Ich hab die 1.8.11 über Git installiert. Leider kam es nach ein paar Stunden wieder zum absturz.
    2023-06-27 11:30:43.149	info	Currently 75 devices are joined:
    zigbee.0
    2023-06-27 11:30:43.055	info	--> transmitPower : high
    zigbee.0
    2023-06-27 11:30:43.021	info	Unable to disable LED, unsupported function.
    zigbee.0
    2023-06-27 11:30:43.013	info	Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
    zigbee.0
    2023-06-27 11:30:42.689	info	Installed Version: ioBroker/ioBroker.zigbee#ad21578c484248392fd8580b85e581548a0f80ba
    zigbee.0
    2023-06-27 11:30:41.283	info	Starting Zigbee npm ...
    zigbee.0
    2023-06-27 11:30:41.279	info	delete old Backup files. keep only last 10
    zigbee.0
    2023-06-27 11:30:41.012	info	starting. Version 1.8.11 (non-npm: ioBroker/ioBroker.zigbee#ad21578c484248392fd8580b85e581548a0f80ba) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
    zigbee.0
    2023-06-27 11:30:00.690	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    2023-06-27 11:30:00.687	info	terminating
    zigbee.0
    2023-06-27 11:30:00.611	info	Zigbee: disabling joining new devices.
    zigbee.0
    2023-06-27 11:29:59.761	info	cleaned everything up...
    zigbee.0
    2023-06-27 11:29:59.705	error	Cannot read properties of undefined (reading 'Error')
    zigbee.0
    2023-06-27 11:29:59.704	error	TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:142:18) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:699:22
    zigbee.0
    2023-06-27 11:29:59.607	error	unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
    zigbee.0
    2023-06-27 11:29:59.606	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2023-06-27 11:29:59.602	error	Send command to 0x001788010333e08a failed with no error code (Timeout - 53693 - 11 - 42 - 6 - 11 after 10000ms)
    anbei die Fehlermeldung. Auslöser war diesmal wieder eine Hue Lampe (wobei ich 2 davon habe aber nur eine dauernd im Fehlerlog auftaucht).
    • arteckA Offline
      arteckA Offline
      arteck
      #118
      @xsev das scheint sentry zu sein.. da passt was nicht.
      schalte es für den adapter aus.. im Admin . instanzen ganz links ist so ein grünes Symbol..da drauf klicken bis es grau wird
      XsevX 2 Antworten Letzte Antwort
      • arteckA arteck
        XsevX Offline
        XsevX Offline
        Xsev
        #119
        @arteck Ich finde da leider nix mit Sentry, Admin - Instanzen is klar aber ich hab da nur die grünen Symbole für aktive Adapter.
        edit:
        Habs gefunden, sieht man nur im Expertenmodus. Ok habs deaktiviert werde berichten, danke!
        • XsevX Xsev
          edit:
          #120
          edit:
          Moin,
          hier ein Beispiel:
          Bernd
          • arteckA arteck
            XsevX Offline
            XsevX Offline
            Xsev
            #121
            @arteck Adapter läuft jetzt seit über 15 Stunden wieder durch. Das deaktivieren von Sentry hat funktioniert.
            Merci!
            • XsevX Xsev
              Merci!
              MP_Trixi
              #122
              ich habe einige Sonoff SNZB-02 Temp.-/Luftfeuchtesensoren. Koppeln ging. Bei einigen haben ich nach einiger Zeit aber die Verbindung verloren (disconnected). Bisher war es immer so, dass wenn man im Adapter auf Pairing gegangen ist und am Gerät eben die Bereitschaft hergestellt hat, er es wieder verbunden hat. Heute habe ich etwas Systempflege betrieben. Jetzt ist mir der Fehler beim Pairen aufgefallen, sprich die Geräte bleiben auf disconnected:
              2023-06-30 16:29:45.463 - error: zigbee.0 (1074) DeviceConfigure:Failed to DeviceConfigure.configure 0x00124b00290f0c38 TH01 (TypeError: Cannot read properties of undefined (reading 'error')
              im Adapter sieht es so aus:
              Hat mir jemand einen Tipp? Danke
              iob diag sagt:
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Model           : Raspberry Pi 4 Model B Rev 1.4
              Architecture    : aarch64
              Docker          : false
              Virtualization  : none
              Distributor ID: Debian
              Description:    Debian GNU/Linux 11 (bullseye)
              Release:        11
              Codename:       bullseye
              PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
              NAME="Debian GNU/Linux"
              VERSION_ID="11"
              VERSION="11 (bullseye)"
              VERSION_CODENAME=bullseye
              ID=debian
              HOME_URL="https://www.debian.org/"
              SUPPORT_URL="https://www.debian.org/support"
              BUG_REPORT_URL="https://bugs.debian.org/"
              Systemuptime and Load:
               14:39:10 up 5 min,  2 users,  load average: 2.96, 2.38, 1.09
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              Other values than 0x0 hint to temperature/voltage problems
              temp=59.4'C
              volt=0.9160V
              *** Time and Time Zones ***
                             Local time: Fri 2023-06-30 14:39:11 CEST
                         Universal time: Fri 2023-06-30 12:39:11 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            3.8G        2.5G        1.1G        0.0K        265M        1.3G
              Swap:            99M        2.0M         97M
              Total:          3.9G        2.5G        1.2G
                       3794 M total memory
                       2458 M used memory
                        617 M active memory
                       1974 M inactive memory
                       1069 M free memory
                         10 M buffer memory
                        255 M swap cache
                         99 M total swap
                          2 M used swap
                         97 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /dev/root      ext4       28G   12G   15G  45% /
              devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
              tmpfs          tmpfs     759M  844K  759M   1% /run
              /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
              tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
              [Fri Jun 30 14:33:37 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:62:A2:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=cf73e54d-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Fri Jun 30 14:33:38 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
              [Fri Jun 30 14:33:38 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
              [Fri Jun 30 14:33:39 2023] EXT4-fs (mmcblk0p2): recovery complete
              [Fri Jun 30 14:33:39 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Fri Jun 30 14:33:39 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Fri Jun 30 14:33:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              TARGET  SOURCE         FSTYPE OPTIONS
              /       /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
              /var:
              3.9G    /var/
              3.1G    /var/log
              2.7G    /var/log/journal/6c5b87a59f584c03b6491451f2e5b6da
              468M    /var/lib
              Archived and active journals take up 2.6G in the file system.
              /opt/iobroker/backups:
              4.0K    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              3.6G    /opt/iobroker/iobroker-data/
              3.0G    /opt/iobroker/iobroker-data/history
              458M    /opt/iobroker/iobroker-data/files
              95M     /opt/iobroker/iobroker-data/backup-objects
              78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
              55M     /opt/iobroker/iobroker-data/objects.jsonl
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              16M     /opt/iobroker/iobroker-data/states.jsonl
              15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
              8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.16.1
              /usr/bin/node           v18.16.1
              /usr/bin/npm            9.5.1
              /usr/bin/npx            9.5.1
              nodejs:
                Installed: 18.16.1-deb-1nodesource1
                Candidate: 18.16.1-deb-1nodesource1
                Version table:
               *** 18.16.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                   12.22.12~dfsg-1~deb11u3 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
              No problems detected
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              admin:          6.3.5
              javascript:     7.0.3
              Adapters from github:   1
              Adapter State
              + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
              + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
              + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
                system.adapter.bmw.0                    : bmw                   : smarthome                                - disabled
                system.adapter.devices.0                : devices               : smarthome                                -  enabled
                system.adapter.discovery.0              : discovery             : smarthome                                - disabled
              + system.adapter.energiefluss.0           : energiefluss          : smarthome                                -  enabled
                system.adapter.feiertage.0              : feiertage             : smarthome                                -  enabled
                system.adapter.habpanel.0               : habpanel              : smarthome                                - disabled
              + system.adapter.harmony.0                : harmony               : smarthome                                -  enabled
                system.adapter.heatingcontrol.0         : heatingcontrol        : smarthome                                - disabled
              + system.adapter.history.0                : history               : smarthome                                -  enabled
                system.adapter.homeconnect.0            : homeconnect           : smarthome                                - disabled
              + system.adapter.hue-extended.0           : hue-extended          : smarthome                                -  enabled
                system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: smarthome                                - disabled
                system.adapter.icons-icons8.0           : icons-icons8          : smarthome                                -  enabled
                system.adapter.icons-material-png.0     : icons-material-png    : smarthome                                - disabled
                system.adapter.icons-material-svg.0     : icons-material-svg    : smarthome                                -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : smarthome                                - disabled
                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: smarthome                                -  enabled
                system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : smarthome                                - disabled
              + system.adapter.influxdb.0               : influxdb              : smarthome                                -  enabled, port: 8086
              + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
                system.adapter.javascript.1             : javascript            : smarthome                                - disabled
              + system.adapter.logparser.0              : logparser             : smarthome                                -  enabled
              + system.adapter.meross.0                 : meross                : smarthome                                -  enabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : smarthome                                -  enabled, port: 54321
              + system.adapter.modbus.0                 : modbus                : smarthome                                -  enabled
              + system.adapter.myenergi.0               : myenergi              : smarthome                                -  enabled
              + system.adapter.net-tools.0              : net-tools             : smarthome                                -  enabled
                system.adapter.openweathermap.0         : openweathermap        : smarthome                                -  enabled
                system.adapter.powerfox2.0              : powerfox2             : smarthome                                -  enabled
              + system.adapter.pvforecast.0             : pvforecast            : smarthome                                -  enabled
              + system.adapter.rpi2.0                   : rpi2                  : smarthome                                -  enabled
                system.adapter.schoolfree.0             : schoolfree            : smarthome                                -  enabled
              + system.adapter.selverf.0                : selverf               : smarthome                                -  enabled
              + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.simple-api.0             : simple-api            : smarthome                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                -  enabled
              + system.adapter.synology.0               : synology              : smarthome                                -  enabled, port: 5501
              + system.adapter.telegram.0               : telegram              : smarthome                                -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : smarthome                                -  enabled
                system.adapter.vis-google-fonts.0       : vis-google-fonts      : smarthome                                -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : smarthome                                -  enabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : smarthome                                -  enabled
                system.adapter.vis-inventwo.0           : vis-inventwo          : smarthome                                - disabled
                system.adapter.vis-map.0                : vis-map               : smarthome                                -  enabled
                system.adapter.vis-material-advanced.0  : vis-material-advanced : smarthome                                -  enabled
                system.adapter.vis-material-webfont.0   : vis-material-webfont  : smarthome                                -  enabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : smarthome                                -  enabled
                system.adapter.vis-metro.0              : vis-metro             : smarthome                                -  enabled
                system.adapter.vis-plumb.0              : vis-plumb             : smarthome                                -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : smarthome                                -  enabled
                system.adapter.vis-weather.0            : vis-weather           : smarthome                                -  enabled
                system.adapter.vis.0                    : vis                   : smarthome                                -  enabled
              + system.adapter.vw-connect.0             : vw-connect            : smarthome                                -  enabled
              + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.ws.0                     : ws                    : smarthome                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
              + system.adapter.yahka.0                  : yahka                 : smarthome                                -  enabled
              + system.adapter.zigbee.0                 : zigbee                : smarthome                                -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_626a1ae89b93eb11ac711b4f3d98b6d1-if00-port0
              + instance is alive
              ioBroker-Repositories
              live-stable   : http://iobroker.live/repo/sources-dist.json
              Active repo(s): live-stable
              Installed ioBroker-Instances
              Used repository: live-stable
              Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
              Adapter    "backitup"     : 2.6.23   , installed 2.6.23
              Adapter    "bmw"          : 2.5.7    , installed 2.5.7
              Adapter    "devices"      : 1.1.5    , installed 1.1.5
              Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
              Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
              Adapter    "harmony"      : 1.2.2    , installed 1.2.2
              Adapter    "heatingcontrol": 2.10.6  , installed 2.10.6
              Adapter    "history"      : 2.2.4    , installed 2.2.4
              Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
              Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
              Adapter    "ical"         : 1.13.3   , installed 1.13.3
              Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
              Adapter    "javascript"   : 7.0.3    , installed 7.0.3
              Adapter    "logparser"    : 2.2.0    , installed 2.2.0
              Adapter    "meross"       : 1.15.1   , installed 1.15.1
              Adapter    "mihome-vacuum": 3.11.0   , installed 3.8.8  [Updatable]
              Adapter    "modbus"       : 5.0.11   , installed 5.0.5  [Updatable]
              Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
              Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
              Adapter    "openweathermap": 0.3.9   , installed 0.3.9
              Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
              Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
              Adapter    "schoolfree"   : 1.1.1    , installed 1.1.1
              Adapter    "selverf"      : 0.6.2    , installed 0.6.2
              Adapter    "shelly"       : 6.4.1    , installed 6.4.1
              Adapter    "synology"     : 2.1.13   , installed 2.1.13
              Adapter    "telegram"     : 1.15.6   , installed 1.15.6
              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
              Adapter    "vis-icontwo"  : 0.94.0   , installed 0.94.0
              Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
              Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
              Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
              Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
              Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
              Adapter    "yahka"        : 0.17.0   , installed 0.17.0
              Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
              Objects and States
              Objects:        22941
              States:         20154
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 https://repos.influxdata.com/debian stable InRelease
              Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
              Hit:7 https://apt.grafana.com stable InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13248      740/iobroker.js-con
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13255      740/iobroker.js-con
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11262      565/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:41421         0.0.0.0:*               LISTEN      1001       21828      1642/io.yahka.0
              tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        14024      684/influxd
              tcp        0      0 0.0.0.0:35981           0.0.0.0:*               LISTEN      1001       18744      1642/io.yahka.0
              tcp6       0      0 :::61991                :::*                    LISTEN      1001       16222      1679/io.harmony.0
              tcp6       0      0 :::3000                 :::*                    LISTEN      109        15373      735/grafana
              tcp6       0      0 :::22                   :::*                    LISTEN      0          11264      565/sshd: /usr/sbin
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19951      1482/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14638      935/io.admin.0
              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       19916      1493/io.simple-api.
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        12230      684/influxd
              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21568      1771/io.ws.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11223      449/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15918      1215/io.shelly.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12140      680/dhcpcd
              udp        0      0 0.0.0.0:57516           0.0.0.0:*                           108        11225      449/avahi-daemon: r
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       16850      1238/io.mihome-vacu
              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       16223      1679/io.harmony.0
              udp6       0      0 :::5353                 :::*                                108        11224      449/avahi-daemon: r
              udp6       0      0 :::58916                :::*                                108        11226      449/avahi-daemon: r
              2023-06-30 14:38:56.492  - info: sourceanalytix.0 (1723) Initialization of 0_userdata.0.Strom.WallboxGaN_Vortagesverbrauch_Gesamt successfully
              2023-06-30 14:38:56.515  - info: sourceanalytix.0 (1723) Successfully activated SourceAnalytix for 8 of 8 states, will do my Job until you stop me!
              2023-06-30 14:38:57.184  - info: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available
              2023-06-30 14:38:57.185  - warn: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined
              2023-06-30 14:39:00.105  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 2062
              2023-06-30 14:39:03.697  - info: powerfox2.0 (2062) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24
              2023-06-30 14:39:05.531  - info: alexa2.0 (1245) Unknown Device, but enabling commands, Try it and report back if commands work.
              2023-06-30 14:39:05.533  - info: alexa2.0 (1245) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
              2023-06-30 14:39:05.533  - info: alexa2.0 (1245)     Device-type:A93SQJNJQLDSS - TV Schlafzimmer (CHANGE_NAME,SHARKNADO,MULTI_WAKEWORDS_SUPPORTED,SUPPORTS_LOCALE_SWITCH,SUPPORTS_LOCALE,ACTIVE_AFTER_FRO,SPEECH_RECOGNIZER_USS,VOLUME_SETTING,TIMERS_AND_ALARMS,PERSISTENT_CONNECTION,ARTHUR_TARGET,EQUALIZER_CONTROLLER_MIDRANGE,DIALOG_INTERFACE_VERSION,SOUND_SETTINGS,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,MICROPHONE,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,CUSTOM_ALARM_TONE,EARCONS,REMINDERS,FLASH_BRIEFING,AUDIO_CONTROLS)
              2023-06-30 14:39:08.790  - info: powerfox2.0 (2062) Terminated (NO_ERROR): Without reason
              2023-06-30 14:39:09.497  - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
              2023-06-30 14:39:17.583  - info: alexa2.0 (1245) Unknown Device, but enabling commands, Try it and report back if commands work.
              2023-06-30 14:39:17.584  - info: alexa2.0 (1245) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
              2023-06-30 14:39:17.585  - info: alexa2.0 (1245)     Device-type:A2N49KXGVA18AR - Philipps Fire (NO_TIME_ZONE_SETTING,ASX_TIME_ZONE,MICROPHONE,VOLUME_SETTING,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,TIMERS_AND_ALARMS,PERSISTENT_CONNECTION,REMINDERS)
              2023-06-30 14:39:47.062  - info: alexa2.0 (1245) No smart home devices to query
              2023-06-30 14:39:48.509  - info: alexa2.0 (1245) Subscribing to states...
              2023-06-30 14:39:48.516  - info: alexa2.0 (1245) Deleting the following states: ["Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#enabled","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#delete","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.powerState","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.connectivity","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.connectivity-reason","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#query","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#enabled","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#delete","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.powerState","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.connectivity","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.connectivity-reason","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#query","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.#enabled","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.#delete","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.powerState","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.connectivity","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.connectivity-reason","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.#query","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#enabled","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#delete","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.powerState","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.connectivity","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.connectivity-reason","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#query","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#enabled","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#delete","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.powerState","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.connectivity","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.connectivity-reason","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#query","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.#delete","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.powerState","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.brightness","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorName","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.color-hue","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.color-saturation","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.color-brightness","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorRgb","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorTemperatureName","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorTemperatureInKelvin","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.connectivity","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.connectivity-reason","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.#enabled","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.#delete","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.powerState","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.connectivity","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.connectivity-reason","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.#query","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#includeInAllQuery","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#includeInAllQuery","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#includeInAllQuery","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#includeInAllQuery"]
              2023-06-30 14:39:50.615  - info: alexa2.0 (1245) Alexa-Push-Connection (macDms = true) established. Disable Polling
              2023-06-30 14:40:00.573  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 2419
              2023-06-30 14:40:03.328  - info: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available
              2023-06-30 14:40:03.329  - warn: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined
              2023-06-30 14:40:04.250  - info: powerfox2.0 (2419) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24
              2023-06-30 14:40:06.674  - info: powerfox2.0 (2419) Terminated (NO_ERROR): Without reason
              2023-06-30 14:40:07.276  - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
              2023-06-30 14:40:08.594  - info: alexa2.0 (1245) Initialization Done ...
              • M MP_Trixi
                iob diag sagt:
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Docker          : false
                Release:        11
                Codename:       bullseye
                VERSION_ID="11"
                ID=debian
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                temp=59.4'C
                volt=0.9160V
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M        2.0M         97M
                         3794 M total memory
                         2458 M used memory
                          617 M active memory
                         1069 M free memory
                           10 M buffer memory
                          255 M swap cache
                           99 M total swap
                            2 M used swap
                           97 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                3.9G    /var/
                3.1G    /var/log
                468M    /var/lib
                /usr/bin/npm            9.5.1
                /usr/bin/npx            9.5.1
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.3.5
                javascript:     7.0.3
                Adapter State
                + instance is alive
                Objects and States
                Objects:        22941
                States:         20154
                Pending Updates: 0
                arteckA Offline
                arteckA Offline
                arteck
                #123
                @mp_trixi sagte in ZigBee neue Version 1.8.x:
                probier mal mit der neuen adapter version
                • arteckA arteck
                  MP_Trixi
                  #124
                  @arteck
                  Hi. Danke für die Antwort. Welche ist das? In der stable wird mir keine andere angeboten. Ist die via Github zu installieren?
                  • M MP_Trixi
                    @arteck
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #125
                    @mp_trixi https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                    • arteckA arteck
                      MP_Trixi
                      schrieb am zuletzt editiert von MP_Trixi
                      #126
                      @arteck
                      danke - habe ich gemacht. Ist nun die 1.8.12 drauf. Scheint noch nicht besser zu sein. Irgendwie erreicht er meine Router-Steckdosen nicht und damit auch nicht die anderen Geräte. Wie lange sollte da max. dauern, nach der Installation? Hier noch der Screenshot vom Adapter:
                      Und das log zu Zigbee sieht so aus (ab 10:11 mit der neuen Version):
                      zigbee.0 2023-07-02 10:12:02.077	warn	DeviceAvailability:Failed to ping 0xa4c1385e4f940aa8 TS011F
                      zigbee.0 2023-07-02 10:12:01.073	warn	DeviceAvailability:Failed to ping 0xa4c138394267e33d TS011F
                      zigbee.0 2023-07-02 10:12:00.946	warn	DeviceAvailability:Failed to ping 0xc4988600000fc1b2 SP 220
                      zigbee.0 2023-07-02 10:12:00.736	warn	DeviceAvailability:Failed to ping 0xa4c1388c67dcc204 TS011F
                      zigbee.0 2023-07-02 10:12:00.455	warn	DeviceAvailability:Failed to ping 0x18fc26000004a8e1 SP 220
                      zigbee.0 2023-07-02 10:11:54.197	warn	DeviceAvailability:Failed to ping 0xa4c138f1b70d8be7 TS011F
                      zigbee.0 2023-07-02 10:11:49.366	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"626a1ae89b93eb11ac711b4f3d98b6d1","pnpId":"usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_626a1ae89b93eb11ac711b4f3d98b6d1-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"FTDI","serialNumber":"DM01F5RM","pnpId":"usb-FTDI_FT230X_Basic_UART_DM01F5RM-if00-port0","vendorId":"0403","productId":"6015"},{"path":"/dev/ttyAMA0"}]
                      zigbee.0 2023-07-02 10:11:43.044	info	DeviceConfigure successful 0x00124b00290f0c38 TH01
                      zigbee.0 2023-07-02 10:11:43.021	error	DeviceConfigure:Configure failed: Error: Bind 0x00124b00290f0c38/1 msTemperatureMeasurement from '0x00124b0024c2b43a/1' failed (AREQ - ZDO - bindRsp after 10000ms)
                      zigbee.0 2023-07-02 10:11:33.650	error	Device 0xa4c1385e4f940aa8 "A1Z" not described in statesMapping.
                      zigbee.0 2023-07-02 10:11:33.613	error	Device 0xa4c138394267e33d "A1Z" not described in statesMapping.
                      zigbee.0 2023-07-02 10:11:33.606	error	Device 0xa4c1388c67dcc204 "A1Z" not described in statesMapping.
                      zigbee.0 2023-07-02 10:11:33.394	error	Device 0xa4c1388ffe36decc "A1Z" not described in statesMapping.
                      zigbee.0 2023-07-02 10:11:32.755	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                      zigbee.0 2023-07-02 10:11:32.678	info	Zigbee started
                      zigbee.0 2023-07-02 10:11:32.677	info	0x00158d000911f1ac (addr 11855): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.675	info	0x00158d00090d8fa4 (addr 48824): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.673	info	0xa4c138f1b70d8be7 (addr 49228): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                      zigbee.0 2023-07-02 10:11:32.670	info	0xa4c1385e4f940aa8 (addr 1047): A1Z - NOUS Smart plug (with power monitoring) (Router)
                      zigbee.0 2023-07-02 10:11:32.668	info	0x00124b00290fe1f8 (addr 39009): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.666	info	0x00124b00290fe28c (addr 25949): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.664	info	0x00124b00290fd65b (addr 61986): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.663	info	0x00124b00290f8649 (addr 5483): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.662	info	0x00124b00290fda20 (addr 59334): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.660	info	0x00124b00290fd917 (addr 47233): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.659	info	0x00124b00290f0c38 (addr 18417): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.657	info	0x00124b00290f0c60 (addr 38503): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.656	info	0x00124b0029202889 (addr 34778): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.654	info	0x00124b00290fefe9 (addr 46783): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.653	info	0xa4c138394267e33d (addr 250): A1Z - NOUS Smart plug (with power monitoring) (Router)
                      zigbee.0 2023-07-02 10:11:32.651	info	0xa4c1388c67dcc204 (addr 49199): A1Z - NOUS Smart plug (with power monitoring) (Router)
                      zigbee.0 2023-07-02 10:11:32.649	info	0x84ba20fffe567412 (addr 26000): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.647	info	0x00158d0008c97feb (addr 44083): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.646	info	0xa4c138e29b759d31 (addr 12252): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.644	info	0x84ba20fffe56851a (addr 2021): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.641	info	0xa4c1382cc75bfab7 (addr 36665): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.637	info	0x84ba20fffe504f79 (addr 32527): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.634	info	0xc4988600000fc1b2 (addr 6351): SP 220 - Innr Smart plug (Router)
                      zigbee.0 2023-07-02 10:11:32.632	info	0x84ba20fffe566f6f (addr 20732): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.629	info	0x54ef4410000c39c2 (addr 12431): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.627	info	0x00158d0008c9c98a (addr 62477): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.625	info	0x84ba20fffe82e9d2 (addr 53011): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.623	info	0x84ba20fffe50527f (addr 12231): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.621	info	0x18fc26000004a8e1 (addr 54644): SP 220 - Innr Smart plug (Router)
                      zigbee.0 2023-07-02 10:11:32.619	info	0x00158d0007f80dd4 (addr 40938): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                      zigbee.0 2023-07-02 10:11:32.617	info	0xa4c1388ffe36decc (addr 43646): A1Z - NOUS Smart plug (with power monitoring) (Router)
                      zigbee.0 2023-07-02 10:11:32.602	info	0xc4988600000fc431 (addr 25243): SP 220 - Innr Smart plug (Router)
                      zigbee.0 2023-07-02 10:11:32.597	info	Configuring 0x00124b00290f0c38 TH01
                      zigbee.0 2023-07-02 10:11:32.382	info	Currently 32 devices are joined:
                      zigbee.0 2023-07-02 10:11:32.357	info	--> transmitPower : normal
                      zigbee.0 2023-07-02 10:11:32.339	info	Unable to disable LED, unsupported function.
                      zigbee.0 2023-07-02 10:11:32.329	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221102}}
                      zigbee.0 2023-07-02 10:11:31.925	info	Installed Version: ioBroker/ioBroker.zigbee#a63ee8fce6c013953b33e6d81737aa9815a65683
                      zigbee.0 2023-07-02 10:11:31.220	info	Starting Zigbee npm ...
                      zigbee.0 2023-07-02 10:11:31.217	info	delete old Backup files. keep only last 10
                      zigbee.0 2023-07-02 10:11:31.076	info	starting. Version 1.8.12 (non-npm: ioBroker/ioBroker.zigbee#a63ee8fce6c013953b33e6d81737aa9815a65683) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
                      zigbee.0 2023-07-02 10:11:21.514	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      zigbee.0 2023-07-02 10:11:21.511	info	terminating
                      zigbee.0 2023-07-02 10:11:21.114	info	Zigbee: disabling joining new devices.
                      zigbee.0 2023-07-02 10:11:20.989	info	cleaned everything up...
                      zigbee.0 2023-07-02 10:11:20.986	info	Got terminate signal TERMINATE_YOURSELF
                      zigbee.0 2023-07-02 10:09:18.924	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"626a1ae89b93eb11ac711b4f3d98b6d1","pnpId":"usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_626a1ae89b93eb11ac711b4f3d98b6d1-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"FTDI","serialNumber":"DM01F5RM","pnpId":"usb-FTDI_FT230X_Basic_UART_DM01F5RM-if00-port0","vendorId":"0403","productId":"6015"},{"path":"/dev/ttyAMA0"}]
                      zigbee.0 2023-07-02 10:05:48.454	warn	Device '0x54ef4410000c39c2' announced itself
                      zigbee.0 2023-07-02 10:04:58.623	warn	DeviceAvailability:Failed to ping 0xa4c1388c67dcc204 TS011F
                      zigbee.0 2023-07-02 10:04:58.529	warn	DeviceAvailability:Failed to ping 0xc4988600000fc1b2 SP 220
                      zigbee.0 2023-07-02 10:04:57.651	warn	DeviceAvailability:Failed to ping 0x18fc26000004a8e1 SP 220
                      zigbee.0 2023-07-02 10:04:57.630	warn	DeviceAvailability:Failed to ping 0xa4c1385e4f940aa8 TS011F
                      zigbee.0 2023-07-02 10:04:57.148	warn	DeviceAvailability:Failed to ping 0xa4c138394267e33d TS011F
                      zigbee.0 2023-07-02 10:04:53.424	warn	DeviceAvailability:Failed to ping 0xa4c138f1b70d8be7 TS011F
                      zigbee.0 2023-07-02 10:04:40.087	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x00124b00290f0c38 TH01 (TypeError: Cannot read properties of undefined (reading 'error') at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/sonoff.js:171:24) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:134:13) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:112:17) at DeviceConfigure.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:54:21) at async Promise.all (index 1))
                      zigbee.0 2023-07-02 10:04:29.767	info	Zigbee started
                      zigbee.0 2023-07-02 10:04:29.765	info	0x00158d000911f1ac (addr 11855): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.764	info	0x00158d00090d8fa4 (addr 48824): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.759	info	0xa4c138f1b70d8be7 (addr 49228): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                      zigbee.0 2023-07-02 10:04:29.755	info	0xa4c1385e4f940aa8 (addr 1047): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                      zigbee.0 2023-07-02 10:04:29.753	info	0x00124b00290fe1f8 (addr 39009): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.751	info	0x00124b00290fe28c (addr 25949): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.749	info	0x00124b00290fd65b (addr 61986): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.748	info	0x00124b00290f8649 (addr 5483): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.746	info	0x00124b00290fda20 (addr 59334): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.744	info	0x00124b00290fd917 (addr 47233): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.742	info	0x00124b00290f0c38 (addr 18417): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.741	info	0x00124b00290f0c60 (addr 38503): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.739	info	0x00124b0029202889 (addr 34778): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.738	info	0x00124b00290fefe9 (addr 46783): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.736	info	0xa4c138394267e33d (addr 250): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                      zigbee.0 2023-07-02 10:04:29.734	info	0xa4c1388c67dcc204 (addr 49199): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                      zigbee.0 2023-07-02 10:04:29.730	info	0x84ba20fffe567412 (addr 26000): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.728	info	0x00158d0008c97feb (addr 44083): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.726	info	0xa4c138e29b759d31 (addr 12252): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.724	info	0x84ba20fffe56851a (addr 2021): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.721	info	0xa4c1382cc75bfab7 (addr 36665): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.719	info	0x84ba20fffe504f79 (addr 32527): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.716	info	0xc4988600000fc1b2 (addr 6351): SP 220 - Innr Smart plug (Router)
                      zigbee.0 2023-07-02 10:04:29.714	info	0x84ba20fffe566f6f (addr 20732): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.710	info	0x54ef4410000c39c2 (addr 12431): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.708	info	0x00158d0008c9c98a (addr 62477): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.707	info	0x84ba20fffe82e9d2 (addr 53011): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.704	info	0x84ba20fffe50527f (addr 12231): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.701	info	0x18fc26000004a8e1 (addr 54644): SP 220 - Innr Smart plug (Router)
                      zigbee.0 2023-07-02 10:04:29.699	info	0x00158d0007f80dd4 (addr 40938): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                      zigbee.0 2023-07-02 10:04:29.696	info	0xa4c1388ffe36decc (addr 43646): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                      zigbee.0 2023-07-02 10:04:29.679	info	0xc4988600000fc431 (addr 25243): SP 220 - Innr Smart plug (Router)
                      zigbee.0 2023-07-02 10:04:29.671	info	Configuring 0x00124b00290f0c38 TH01
                      zigbee.0 2023-07-02 10:04:29.508	info	Currently 32 devices are joined:
                      zigbee.0 2023-07-02 10:04:29.484	info	--> transmitPower : normal
                      zigbee.0 2023-07-02 10:04:29.458	info	Unable to disable LED, unsupported function.
                      zigbee.0 2023-07-02 10:04:29.449	info	Coordinator firmware version: {"type":"zStack3x0","meta":"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221102}}
                      zigbee.0 2023-07-02 10:04:25.774	info	Installed Version: iobroker.zigbee@1.8.10
                      zigbee.0 2023-07-02 10:04:24.567	info	Starting Zigbee npm ...
                      zigbee.0 2023-07-02 10:04:24.564	info	delete old Backup files. keep only last 10
                      zigbee.0 2023-07-02 10:04:24.212	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
                      • M MP_Trixi
                        @arteck
                        MP_Trixi
                        #127
                        @arteck
                        so siehts nun nach ca. 9h aus:
                        • M MP_Trixi
                          @arteck
                          #128
                          @mp_trixi
                          du bist auf Kanal 11, ist der auch frei? Schau mal in den Settings vom Adapter, da wird der beste ja angezeigt..
                          Hast ja nur 32 Devices.. die sind gleich wieder angelernt..
                            @mp_trixi
                            MP_Trixi
                            #129
                            @ilovegym
                            eigentlich war er das mal. Hatte aber mal mein Mesh WLAN sich optimieren lassen - gut möglich, dass es da herkommt. Habe mal ein paar Messungen durchgeführt (allerdings jetzt halt alle innerhalb der ca. letzten Stunde). Da wäre dann wohl 18 oder 23 der Gewinner (wobei die auch nicht immer 0 waren):
                            Wie geht man da am Besten vor? Erst alle Geräte löschen, dann Kanal umstellen und neu anlernen. Oder Nicht löschen? Schön wäre wenn die Aliase erhalten blieben :)
                            • M MP_Trixi
                              @ilovegym
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #130
                              18 oder 23
                              mit den 2 bist du ausserhalb des Notmalen Bereicht. du wirst probleme haben mit dem Geräten
                              nimm 15 oder 25
                              und stelle das WLAN eher um
                              ? M 2 Antworten Letzte Antwort
                              • arteckA arteck
                                18 oder 23
                                nimm 15 oder 25
                                #131
                                @arteck
                                hast du dir das issue von mir mal angeschaut?
                                Wenn du die Hardware brauchst, schreib mir deine Adresse im Chat, kommt dann umgehend per Amazon von mir gesponsort.. :-)
                                Irgendwas muss sich bei den FRIENT Devices im Adapter von Version 1.8.9 auf alle hoeheren geaendert haben.. auch mit der aktuellen von Git reagiert der Melder nicht mehr auf manual start..
                                Kann ja noch auf der 1.8.9 bleiben.. aber irgendwann wird das auch mal doof.. :-)
                                  @arteck
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #132
                                  @ilovegym auch nicht wenn du den unter ausschliessen packst ?
                                  • arteckA arteck
                                    #133
                                    @arteck sagte in ZigBee neue Version 1.8.x:
                                    auch dann nicht... auf die neueste wieder geupdated, Device in Ausschliessen hinzugefuegt, Adapter gestoppt, gewartet... Adapter gestartet... gewartet... (bis die Karte sich aufgebaut hat..) dann nochmal getestet.. einmal von der Gui und einmal den Datenpunkt im Object-browser... keine Reaktion.. keine Fehlermeldung.. nix.. :'(
                                    Edit doch Error:
                                    2023-07-03 11:36:03.190  - error: zigbee.0 (1196700) uncaught exception: Cannot read properties of null (reading 'toString')
                                    2023-07-03 11:36:03.190  - error: zigbee.0 (1196700) TypeError: Cannot read properties of null (reading 'toString')
                                        at assertNumber (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/utils.ts:502:111)
                                        at calibrateAndPrecisionRoundOptions (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/utils.ts:90:5)
                                        at Object.convert (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/fromZigbee.js:414:37)
                                        at /opt/iobroker/node_modules/iobroker.zigbee/main.js:534:43
                                        at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:183:25)
                                        at processImmediate (node:internal/timers:478:21)
                                    2023-07-03 11:36:03.191  - error: zigbee.0 (1196700) Cannot read properties of null (reading 'toString')
                                    2023-07-03 11:36:03.217  - info: zigbee.0 (1196700) cleaned everything up...
                                    2023-07-03 11:36:06.614  - error: host.iobrokerS2 Caught by controller[0]: TypeError: Cannot read properties of null (reading 'toString')
                                    2023-07-03 11:36:06.615  - error: host.iobrokerS2 Caught by controller[0]:     at assertNumber (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/utils.ts:502:111)
                                    2023-07-03 11:36:06.615  - error: host.iobrokerS2 Caught by controller[0]:     at calibrateAndPrecisionRoundOptions (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/utils.ts:90:5)
                                    2023-07-03 11:36:06.615  - error: host.iobrokerS2 Caught by controller[0]:     at Object.convert (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/fromZigbee.js:414:37)
                                    2023-07-03 11:36:06.615  - error: host.iobrokerS2 Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.zigbee/main.js:534:43
                                    2023-07-03 11:36:06.615  - error: host.iobrokerS2 Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:183:25)
                                    2023-07-03 11:36:06.615  - error: host.iobrokerS2 Caught by controller[0]:     at processImmediate (node:internal/timers:478:21)
                                    2023-07-03 11:36:06.616  - error: host.iobrokerS2 instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2023-07-03 11:36:06.616  - info: host.iobrokerS2 Restart adapter system.adapter.zigbee.0 because enabled
                                    R 1 Antwort Letzte Antwort
                                      Edit doch Error:
                                      rewenode
                                      #134
                                      @arteck Habe gestern ein Update auf 1.8.12 durchgeführt. Das letzte Update stammt von 02.23 ich meine auf 1.8.11.
                                      Soweit alles gut.
                                      Da ich ion diesem Zusammenhang mal wieder meine Tabellen genauer angesehen. Dabei fiel mir auf, das die batteriebetriebenen Zigbee-Geräte scheinbar keinen Stromverbrauch mehr haben??
                                      Laut Zeitstempel werden bei ALLEN meinen batteriebetriebenen Zigbee-Geräte keine Spannung oder Prozentwert mehr angezeigt wird.
                                      Hab ich da irgend eine Info verpasst?
                                      Alle anderen Werte kommen wie gewohnt. Deshalb ist mir das bisher nicht aufgefallen.
                                      Zum Test habe ich mal einen Sensor neu gepairt. Das hat keine Änderung gebracht.
                                      Was kann ich tun?
                                      Gruß Reiner
                                      • arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #135
                                        @ilovegym der herdsamn hat da ein problem..
                                        • arteckA arteck
                                          #136
                                          @arteck ah hab mir sowas schon gedacht.. also Issue beim Herdsmann aufmachen.. falls noch keins ist..
