    6.5k
7.5k Beiträge 335 Kommentatoren 11.6m Aufrufe 254 Beobachtet
    @tobitobsta sagte in Test Adapter shuttercontrol v1.5.x:
    Temperatur outside: 31.3 > 24 AND Light: 0 > 15
    die Logik stimmt ja wohl nicht ganz 😂
    Wobei ich mich frage wieso das Licht 0 ist.
    ist der Sensor im Zimmer?
    tobitobsta
    #6127
    @homoran said in Test Adapter shuttercontrol v1.5.x:
    Touche ;-) also insofern habe ich nicht "dasselbe Problem". Ich habe gar keine Sensoren, die ich für die Sunprotect Entscheidung anziehe außer Himmelsrichtung:
    shuttercontrol.0 | 2023-06-24 16:31:21.029 | debug | Shutter state changed: Badezimmer old value = 100 new value = 30
    shuttercontrol.0 | 2023-06-24 16:31:21.028 | debug | #0 wait for shutter check end
    shuttercontrol.0 | 2023-06-24 16:31:07.350 | debug | Shutter state changed: Badezimmer old value = 100 new value = 30
    shuttercontrol.0 | 2023-06-24 16:31:07.349 | debug | #0 wait for shutter check end
    shuttercontrol.0 | 2023-06-24 16:31:07.327 | debug | Shutter state changed: Badezimmer old value = 100 new value = 30
    shuttercontrol.0 | 2023-06-24 16:31:07.326 | debug | #0 wait for shutter check end
    shuttercontrol.0 | 2023-06-24 16:30:21.026 | debug | #0 wait for shutter check started
    shuttercontrol.0 | 2023-06-24 16:30:07.348 | debug | #0 wait for shutter check started
    shuttercontrol.0 | 2023-06-24 16:30:07.330 | debug | Sunprotect Badezimmer old height: 100% new height: 30%
    shuttercontrol.0 | 2023-06-24 16:30:07.330 | debug | last automatic Action for Badezimmer: down_Sunprotect
    shuttercontrol.0 | 2023-06-24 16:30:07.330 | debug | RangeMinus: 184 < 248.7RangePlus: 310 > 248.7
    shuttercontrol.0 | 2023-06-24 16:30:07.329 | debug | Sunprotect for Badezimmer is active
    shuttercontrol.0 | 2023-06-24 16:30:07.323 | debug | #0 wait for shutter check started
    shuttercontrol.0 | 2023-06-24 16:30:07.319 | info | Sunprotect #416 Set ID: Badezimmer value: 30%
    shuttercontrol.0 | 2023-06-24 16:30:07.318 | debug | Badezimmer: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
    shuttercontrol.0 | 2023-06-24 16:30:00.039 | debug | Sun Elevation: 44.4°
    shuttercontrol.0 | 2023-06-24 16:30:00.038 | debug | Sun Azimut: 248.7°
    shuttercontrol.0 | 2023-06-24 16:30:00.036 | debug | calculate astrodata ...
    shuttercontrol.0 | 2023-06-24 16:25:43.425 | debug | #1 currentShutterStateTime: 60 seconds
    shuttercontrol.0 | 2023-06-24 16:25:43.424 | debug | #1 currentShutterState: activated
    shuttercontrol.0 | 2023-06-24 16:25:43.424 | debug | #1 oldHeight: 30 %
    shuttercontrol.0 | 2023-06-24 16:25:43.424 | debug | #1 currentHeight: 100 %
    shuttercontrol.0 | 2023-06-24 16:25:43.424 | debug | #1 triggerAction: up
    shuttercontrol.0 | 2023-06-24 16:25:43.424 | debug | #1 currentAction: up
    shuttercontrol.0 | 2023-06-24 16:25:43.423 | debug | #1 shutterState: 100 %
    shuttercontrol.0 | 2023-06-24 16:25:43.423 | debug | #1 shutterName: Badezimmer
    shuttercontrol.0 | 2023-06-24 16:25:43.423 | debug | Badezimmer Old value = 30. New value = 100. automatic is active
    shuttercontrol.0 | 2023-06-24 16:25:43.422 | debug | Shutter state changed: Badezimmer old value = 30 new value = 100
    • T tobitobsta
      #6128
      und wie ist dann der Sonnenschutz konfiguriert?
        tobitobsta
        #6129
        Himmelsrichtung
        • T tobitobsta
          Himmelsrichtung
          #6130
          Himmelsrichtung
          zeigen!
            Himmelsrichtung
            zeigen!
            tobitobsta
            #6131
            Himmelsrichtung
            zeigen!
            • T tobitobsta
              Himmelsrichtung
              zeigen!
              #6132
              @tobitobsta siehste!
              zeigen hilft.
              das ist das Badezimmer, nicht die Kueche
                zeigen hilft.
                tobitobsta
                #6133
                meine Logs zeigen auch Badezimmer
                • T tobitobsta
                  #6134
                  @tobitobsta das von mir zitierte und kommentierte nicht!
                  edit:
                  im neuen log sehe ich nichts von Manu_Mode
                    edit:
                    tobitobsta
                    #6135
                    uff... da stand ein "@tobitobsta". Sorry... mein Fehler... ich glaube das führt hier gerade zu nix und ich will hier nicht alle mit dem hin und her nerven.
                    Dass der Rolladen bei manueller Anpassung nicht auf Manu_Mode geht, wundert mich auch.
                    Ich ziehe mich jetzt erstmal zurück aber antworte gerne noch bei Bedarf.
                    • T tobitobsta
                      #6136
                      wer sagt das?
                      ist nur für mich in dem log-Ausschnitt nicht zu sehen.
                      Aber wir wollen/sollen doch helfen 🤔
                      das versteh ich jetzt nicht
                        wer sagt das?
                        tobitobsta
                        #6137
                        wer sagt das?
                        Kann ich das irgednwie anders rausfinden? habe ja nur die Logs. Ich versuche es jetzt einfach mal und schaue in den Datenpunkt...
                        nehme gerne eure Hilfe in Anspruch und bin auch sehr dankbar - hatte nur das Gefühl, dass ich hier gerade eher auf die Nerven falle...
                        alles gut - lass uns beim inhaltlichen bleiben.
                        • T tobitobsta
                          wer sagt das?
                          #6138
                          1. Kueche meldet seltsames
                          2. Badezimmer geht in den Sonnenschutz
                            tobitobsta
                            schrieb am zuletzt editiert von tobitobsta
                            #6139
                            habs jetzt gerade mit "Küche Tür" ausprobiert (da der jetzt gerade in SunProtect ist, es verhalten sich aber alle gleich bei mir).
                            nach dem manuellen hochfahren geht der State in "up" und der AutoLevel bleibt bei "26%"
                            nach 5 min fährt er wieder unter ( @Homoran edited - thx):
                            shuttercontrol.0 2023-06-27 11:51:32.609	debug	Shutter state changed: Küche Tür old value = 100 new value = 26
                            shuttercontrol.0 2023-06-27 11:51:32.608	debug	#0 wait for shutter check end
                            shuttercontrol.0 2023-06-27 11:51:13.168	debug	Shutter state changed: Küche Tür old value = 100 new value = 26
                            shuttercontrol.0 2023-06-27 11:51:13.165	debug	#0 wait for shutter check end
                            shuttercontrol.0 2023-06-27 11:51:13.140	debug	Shutter state changed: Küche Tür old value = 100 new value = 26
                            shuttercontrol.0 2023-06-27 11:51:13.138	debug	#0 wait for shutter check end
                            shuttercontrol.0 2023-06-27 11:50:32.607	debug	#0 wait for shutter check started
                            shuttercontrol.0 2023-06-27 11:50:13.165	debug	#0 wait for shutter check started
                            shuttercontrol.0 2023-06-27 11:50:13.147	debug	Sunprotect Küche Tür old height: 100% new height: 26%
                            shuttercontrol.0 2023-06-27 11:50:13.147	debug	last automatic Action for Küche Tür: down_Sunprotect
                            shuttercontrol.0 2023-06-27 11:50:13.147	debug	RangeMinus: 115 < 139.1RangePlus: 243 > 139.1
                            shuttercontrol.0 2023-06-27 11:50:13.146	debug	Sunprotect for Küche Tür is active
                            shuttercontrol.0 2023-06-27 11:50:13.137	debug	#0 wait for shutter check started
                            shuttercontrol.0 2023-06-27 11:50:13.124	info	Sunprotect #416 Set ID: Küche Tür value: 26%
                            shuttercontrol.0 2023-06-27 11:50:13.123	debug	Küche Tür: Check basis for sunprotect. Height:100 > HeightDownSun: 26 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                            shuttercontrol.0 2023-06-27 11:50:00.083	debug	Sun Elevation: 55.7°
                            shuttercontrol.0 2023-06-27 11:50:00.082	debug	Sun Azimut: 139.1°
                            shuttercontrol.0 2023-06-27 11:50:00.081	debug	calculate astrodata ...
                            shuttercontrol.0 2023-06-27 11:45:35.915	debug	#1 currentShutterStateTime: 60 seconds
                            shuttercontrol.0 2023-06-27 11:45:35.914	debug	#1 currentShutterState: activated
                            shuttercontrol.0 2023-06-27 11:45:35.914	debug	#1 oldHeight: 26 %
                            shuttercontrol.0 2023-06-27 11:45:35.913	debug	#1 currentHeight: 100 %
                            shuttercontrol.0 2023-06-27 11:45:35.912	debug	#1 triggerAction: up
                            shuttercontrol.0 2023-06-27 11:45:35.911	debug	#1 currentAction: up
                            shuttercontrol.0 2023-06-27 11:45:35.910	debug	#1 shutterState: 100 %
                            shuttercontrol.0 2023-06-27 11:45:35.910	debug	#1 shutterName: Küche Tür
                            shuttercontrol.0 2023-06-27 11:45:35.909	debug	Küche Tür Old value = 26. New value = 100. automatic is active
                            shuttercontrol.0 2023-06-27 11:45:35.904	debug	Shutter state changed: Küche Tür old value = 26 new value = 100
                            shuttercontrol.0 2023-06-27 11:45:35.901	debug	#0 wait for shutter check end
                            shuttercontrol.0 2023-06-27 11:45:00.028	debug	Sun Elevation: 55.2°
                            shuttercontrol.0 2023-06-27 11:45:00.027	debug	Sun Azimut: 137.3°
                            shuttercontrol.0 2023-06-27 11:45:00.026	debug	calculate astrodata ...
                            shuttercontrol.0 2023-06-27 11:44:35.901	debug	#0 wait for shutter check started
                            und dann ist der State wieder "sunprotect":
                            HomoranH T 2 Antworten Letzte Antwort
                            • T tobitobsta
                              #6140
                              nach 5 min fährt er wieder unter:
                              bitte als Text in code-tags!
                              ist am Handy nicht zu entziffern
                              und zitieren klappt irgendwie auch nicht so richtig
                                @raspiuser Dann lies es bitte nochmal im Zusammenhang!
                                Doku und meine Erklärungen
                                RaspiUserR Offline
                                RaspiUserR Offline
                                RaspiUser
                                #6141
                                Hab ich und hab ich auch verstanden ... aber eigentlich sollten deine Erläuterungen zur Anleitung garnicht notwendig sein ...
                                Dann braucht es nachher 500 Seiten Kommentare
                                Natürlich nicht ... aber auch nicht über 6000 Diskussionsbeiträge die keiner mehr überblicken oder sinnvoll durchsuchen kann, oder ?
                                • RaspiUserR RaspiUser
                                  #6142
                                  @raspiuser sagte in Test Adapter shuttercontrol v1.5.x:
                                  richtig!
                                  Weil es bereits eindeutig ist ;-)
                                  RaspiUserR 1 Antwort Letzte Antwort
                                  • simatecS simatec
                                    @rtwl sagte in Test Adapter shuttercontrol v1.5.x:
                                    Ein generelles auffrischen der Anleitung wirst wohl du auch zustimmen @homoran, unabhängig von der aktuellen Frage. Oder?
                                    Ich hatte bereits mehrmals dazu eingeladen, sich aktiv an der Anleitung zu beteiligen... Leider gibt es halt hier nicht viele User, die sich da einbringen
                                    RaspiUserR Offline
                                    RaspiUserR Offline
                                    RaspiUser
                                    #6143
                                    @simatec said in Test Adapter shuttercontrol v1.5.x:
                                    Ich kann deine Meinung verstehen.
                                    Ich selbst würde gern helfen, sehe mich aber nicht in der Lage dies zu tun, weil ich selbst nicht durchblicke um es zu beschreiben.
                                    Aber Hinweise, das die Anleitung an dieser oder jener Stelle besser werden kann darf man geben, oder?
                                      richtig!
                                      RaspiUserR Offline
                                      RaspiUserR Offline
                                      RaspiUser
                                      #6144
                                      Nein, sehe ich nicht so ... aber wir kommen hier nicht weiter ...
                                        #6145
                                        du hast im letzten Satz zuerst immer Aussentemperatursensor gelesen und das hat zur Verwirrung geführt.
                                        Diese Verknüpfung bekommst du jetzt nicht mehr aus dem Kopf.
                                        Natürlich!
                                        Du kannst aber auch direkt eine für alle bessere Formulierung als pullrequest für die Doku zur Verfügung stellen.
                                          Natürlich!
                                          RaspiUserR Offline
                                          RaspiUserR Offline
                                          RaspiUser
                                          #6146
                                          Stimmt genau ... wir nähern uns an ... das zeigt, dass die Anleitung verbessert (aktualisiert) werden kann / sollte / muss.
                                          (Wenn beim (1.) Sensor (fast) alles auf "Temperatur" hindeutet und im letzten Anleitungssatz "ALLES" erlaubt wird (Ich gehe mal davon aus, dass auch andere User verwirrt wurden ...) sollte man doch die Adapter-EInstellungen und die Anleitung gleich von der "Temperatur" lösen und "frei" formulieren.)
                                          Natürlich!
                                          ... eine Formulierung für eine bestehende (verbesserungswürdige) Beschreibung wäre nicht so das Problem (Neue Funktionen zu beschreiben würde ich mir weniger zutrauen).
                                          Mit PR kenne ich mich wenig aus (und habe da eher die Befürchtung etwas "kaputt" zu machen).
                                          Ich melde mich ....
