  4. js-controller 5.0.x jetzt in der BETA
    6.3k
580 Beiträge 71 Kommentatoren 245.5k Aufrufe 67 Beobachtet
  • NinjaTurtle85N NinjaTurtle85
    mein Zigbee Adapter startet in unregelmäßigem Abstand, seid dem upgrade auf 5.0.5, immer neu.
    Node.js v18.16.0
    NPM 9.5.1
    Mein LOG:
    2023-06-21 21:19:19.971 - error: zigbee.0 (25876) Send command to 0x847127fffe8aeb61 failed with no error code (no response received)
    2023-06-21 21:19:19.973 - error: zigbee.0 (25876) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-06-21 21:19:19.973 - error: zigbee.0 (25876) unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
    2023-06-21 21:19:19.995 - error: zigbee.0 (25876) TypeError: Cannot read properties of undefined (reading 'Error')
    at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
    at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
    at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
    at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
    at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:142:18)
    at /opt/iobroker/node_modules/iobroker.zigbee/main.js:699:22
    2023-06-21 21:19:19.996 - error: zigbee.0 (25876) Cannot read properties of undefined (reading 'Error')
    2023-06-21 21:19:20.009 - info: zigbee.0 (25876) cleaned everything up...
    2023-06-21 21:19:20.080 - info: zigbee.0 (25876) Zigbee: disabling joining new devices.
    2023-06-21 21:19:20.165 - info: zigbee.0 (25876) terminating
    2023-06-21 21:19:20.165 - warn: zigbee.0 (25876) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-06-21 21:19:20.509 - info: zigbee.0 (25876) terminating
    2023-06-21 21:19:20.766 - error: host.IoBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2023-06-21 21:19:20.766 - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'Error')
    2023-06-21 21:19:20.766 - error: host.IoBroker Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
    2023-06-21 21:19:20.766 - error: host.IoBroker Caught by controller[0]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
    2023-06-21 21:19:20.766 - error: host.IoBroker Caught by controller[0]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
    2023-06-21 21:19:20.766 - error: host.IoBroker Caught by controller[0]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
    2023-06-21 21:19:20.766 - error: host.IoBroker Caught by controller[0]: at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:142:18)
    2023-06-21 21:19:20.766 - error: host.IoBroker Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:699:22
    2023-06-21 21:19:20.766 - error: host.IoBroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-06-21 21:19:20.766 - info: host.IoBroker Restart adapter system.adapter.zigbee.0 because enabled
    Diamand2k22
    #286
    @ninjaturtle85
    Sentry verursacht das Problem. Schalte Sentry bei dem Zigbee Adapter ab dann stürzt er nicht mehr ab.
    NinjaTurtle85N 1 Antwort Letzte Antwort
    • D Diamand2k22
      @ninjaturtle85
      NinjaTurtle85N Offline
      NinjaTurtle85
      #287
      @diamand2k22 Super, läuft 👍
      Vielen Dank!
      • apollon77A apollon77
        Neue erkannte Probleme, die noch nicht behandelt sind:
        • stiebel-isg update nötig
        • lgtv sollte fixed sein mit 1.1.12
        • web kann crashen falls Widgets in vis falsch konfiguriert sind (PR in socket-classes existiert bereits)
        • js-controller upgrade via Admin startet js-controller nicht wieder
        • Admin zeigt falsche Log grösse an -> Fixed in Admin 6.5.8+
        • km200 sollte gefixt sein mit 2.0.4
        • miio muss geprüft werden
        • fakeroku GitHub Version gefixt, release fehlt noch
        • pi-hole update nötig
        • node-red muss geprüft werden
        • enigma2.0 mindestens 1.4.0+
        • doorbird update nötig
        • linux-control update nötig
        W Offline
        W Offline
        Werner303
        #288
        @apollon77 km200 als auch samsung_tizen laufen nach dem Update auf 5.04 nicht. Arbeiten sie mit der Version 5.05?
        • W Werner303
          mcm1957M Online
          mcm1957M Online
          mcm1957
          #289
          @werner303 said in js-controller 5.0.x jetzt in der BETA:
          Schau doch mal in die liste der bekannten Probleme:
          https://forum.iobroker.net/topic/66108/js-controller-5-0-x-jetzt-in-der-beta/2#
          Gibts zu den Problemen offene Issues im Adapter Repo? Dort wirst du für den km200 die Antwort finden.
          Generell: Gibts zu "laufen nicht" eine Fehlermeldung / ein Log?
          Warum testet du nicht 5.0.5 selbst? js-controller 5.x ist BETA und ein Upgarde auf deinem Testsystem sollte ja kein Problem darstellen.
          samsung_tizen finde ich übrigends nicht im iobroker repository. Heißt der Adapter ev. leicht anders oder hast du den von GitHub installiert? Meinst du den iobroker.samsung Adapter?
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
          hotspot_2H 1 Antwort Letzte Antwort
          • mcm1957M mcm1957
            hotspot_2H Offline
            hotspot_2H Offline
            hotspot_2
            #290
            Ich wollte mir auch die 5.0 Beta der js-controller drauf machen aber wenn ich nach Anleitung (oben) vorgehe bleibt die js-controller immer die gleiche (4.0.24) Kann mir jemand sagen was ich da falsch mache?
            Danke schon mal.
            ESP8266E mcm1957M 2 Antworten Letzte Antwort
            • hotspot_2H hotspot_2
              Danke schon mal.
              ESP8266E Offline
              ESP8266E Offline
              ESP8266
              schrieb am zuletzt editiert von ESP8266
              #291
              @hotspot_2 , dann machst du was falsch, was kann dir keiner sagen. Am besten du bleibst bei der stable.
                Danke schon mal.
                mcm1957M Online
                mcm1957M Online
                mcm1957
                #292
                @hotspot_2
                Weiss nicht genau was du machst.
                ABER ich würde mal tippen dass du nicht auf latest repository bist.
                Ansonsten gikt immer
                Vollständiges log
                Was genau gemacht
                Error meldungen
                Bitte beachte aber dass die 5er BETA ist und keinesfalls auf produktiven Systeme6n eingesetzt werden sollte. Einige Adapter haben mit der 5er noch Probleme.
                • foxriver76F foxriver76
                  @chaot Bitte mal allgemein jemand das Issue im Web Adapter melden, dass der bei sowas nicht mehr crasht.
                  Ansonsten ja im Falle von @Feuersturm war es auch ein selbst erstelltes Binding, das aus Versehen die kompeltte Logik als ID hatte. Also einerseits schön, weil so auffällt, dass ein Binding kaputt ist, aber hart crashen sollte Adapter nicht.
                  #293
                  @foxriver76 @Chaot Und bitte issue im ws adapter ... "ws-server" klingt eher danach
                  @foxriver76 vllt besser in socket-classes catchen ? Das sollte ans ich von allen genutzt werden
                  • ste_gleiS ste_glei
                    Update auf 5.0.5 hat problemlos geklappt.
                    Einzig der bosch-ebike Adapter funktioniert nicht und wirft nur Fehler aus
                    host.iobroker
                    2023-06-19 12:51:36.695	info	Restart adapter system.adapter.bosch-ebike.0 because enabled
                    host.iobroker
                    2023-06-19 12:51:36.695	error	instance system.adapter.bosch-ebike.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    host.iobroker
                    2023-06-19 12:51:36.695	error	Caught by controller[1]: at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
                    host.iobroker
                    2023-06-19 12:51:36.695	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                    host.iobroker
                    2023-06-19 12:51:36.695	error	Caught by controller[1]: at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:51)
                    host.iobroker
                    2023-06-19 12:51:36.695	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'replace')
                    host.iobroker
                    2023-06-19 12:51:36.694	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                    bosch-ebike.0
                    2023-06-19 12:51:35.993	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    bosch-ebike.0
                    2023-06-19 12:51:35.992	info	terminating
                    bosch-ebike.0
                    2023-06-19 12:51:35.975	error	Cannot read properties of undefined (reading 'replace')
                    bosch-ebike.0
                    2023-06-19 12:51:35.974	error	TypeError: Cannot read properties of undefined (reading 'replace') at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:51) at processTicksAndRejections (node:internal/process/task_queues:95:5) at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
                    bosch-ebike.0
                    2023-06-19 12:51:35.972	error	unhandled promise rejection: Cannot read properties of undefined (reading 'replace')
                    bosch-ebike.0
                    2023-06-19 12:51:35.971	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    bosch-ebike.0
                    2023-06-19 12:51:34.011	info	Login to eBike flow
                    #294
                    @ste_glei sagte in js-controller 5.0.x jetzt in der BETA:
                    bosch-ebike
                    Nicht js-controller related. Aber Adapter issue öffnen.
                    • M Marty56
                      Ich habe bemerkt, dass "sendToAsync" jetzt wieder Probleme macht.
                      Folgende Funktion bricht mit Fehler ab.
                      Die Errormeldung liefere ich nach.
                      async function write_influxDB2(id,time,value,db) {
                          var timestamp = new Date(new Date(time).toISOString()).getTime();
                          try {
                              await sendToAsync(db, 'storeState', [{ id: id, state: {ts: timestamp, val: value, ack: false}}]);
                              log('Write DB:' + db + ' id:'+ id + " Value: " + value.toFixed(2) + " Time: " + time)
                          catch (error) {
                              log('InfluxDB Error trying to write ' + id ,error)
                          return;
                      Update: Fehlermeldung. Ich kann damit nichts anfangen.
                      Unknown severity level "[object Object]" by log of [InfluxDB Error trying to write 0_userdata.0.Energie.Auto.price_tibber]
                      #295
                      @marty56 Bitte isssue im javascript oder influxdb adapter öffnen (je nachdem wo der fehler herkommt). Und biotte mit vollständigem Log und so und nicht teile ausgeschnitten
                      • dontobiD dontobi
                        @foxriver76 Ich habe eben meine Installation aktualisiert. Leider klappt danach nichts mehr. Grund hierfür sind die UI Upgrade Changes. Ich nutze nämlich einen eigenen ioBroker Docker Container. Wäre es möglich da was dran zu ändern?
                        #296
                        @dontobi Also abstürzen soll er nicht ... das wäre ein Fehler. mit vollem log und stacktrace bitte GitHub issue im js-controller anlegen!
                        • B bommel_030
                          @foxriver76
                          Ich hab ein neues "Problem" mit den Aliasen. Kann leider nicht sagen ob es nach dem Update js-controller 5.0.5 oder Admin 6.5.9 kommt, das waren die letzten beiden Aktualisierungen, davor gab es das Problem nicht.
                          Die Aliase funktionieren an sich weiterhin, d.h. Skripte die von einem Alias getriggert werden starten, geänderte Werte werden in die influxdb gespeichert.
                          Es werden aber alle Aliase mit Werte (null) angezeigt. Hier beispielhaft ein Bewegungsmelder:
                          Sobald der Bewegungsmelder auslöst, also Datenpunkte aktualisiert/geändert werden sieht es so aus:
                          Klappe ich den Ordner Galerie zu und wieder auf habe ich wieder den Zustand vom ersten Bild.
                          "iob fix" und reboot hab ich nach den Updates schon gemacht, hat leider nichts geändert. Ebenfalls mehrere Computer/Browser getestet.
                          Die originalen Datenpunkte haben natürlich dauerhaft einen Inhalt.
                          #297
                          @bommel_030 Sind die in der InfluxDB gespeicherten Werte korrekt? Dann bitte Admin ossue anlegen. Sonst js-controller Issue
                          • S solver
                            Hallo zusammen!
                            Ich habe nun auch versucht, auf den 5.0.5 das Update bei meiner Testinstallation durchzuführen. Ging doch relativ schnell. Nur 2 meiner Adapter beenden sich immer wieder der Fehlermeldung bzgl. "Probleme mit häufig abstürzenden Adapterinstanzen".
                            Folgende Adapter betrifft das:
                            iqontrol v2.2.0
                            node-red v4.0.3
                            Meine Installation:
                            Node.js v18.16.0
                            npm 9.5.1
                            Admin v6.5.9
                            Vielleicht habe ich da auch etwas falsch gemacht. Habt ihr da vielleicht eine Lösung für mich?
                            Bzw. kennt ihr das Problem?
                            Ich habe nun wieder auf die alte Version umgestellt und läuft alle ohne Probleme.
                            Danke für die tolle Arbeit, die ihr da macht!
                            lg
                            Solver
                            #298
                            @solver Naja also lesen des ersten Beitrags wäre schonmal super ... da steht nämluch das du iqontrol mindestens 2.2.1 brauchst und node-red gerade noch bekannte Issues hat.
                            Manchmal frag ich mich warum ich so einen Aufwand in die Kommunikation stecke wenn es eh "keiner" liesst :-((
                            ? mcm1957M 2 Antworten Letzte Antwort
                              #299
                              @apollon77 sagte in js-controller 5.0.x jetzt in der BETA:
                              Na fuer Diejenigen, die es lesen! :-)
                              Aergert mich auch immer, wenn einfach drauf los installiert wird und dann nur ein "geht nicht".. hat ja auch keine Fuess.. ne.. :-)
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                #300
                                @apollon77 said in js-controller 5.0.x jetzt in der BETA:
                                Dann sag ich mal ein ganz großes DANKE.
                                Und es gibt sicher genug Leser die darüber dankbar sind !
                                McM
                                • mcm1957M mcm1957
                                  @hotspot_2
                                  Vollständiges log
                                  Was genau gemacht
                                  Error meldungen
                                  hotspot_2H Offline
                                  hotspot_2H Offline
                                  hotspot_2
                                  schrieb am zuletzt editiert von hotspot_2
                                  #301
                                  @mcm57 sagte in js-controller 5.0.x jetzt in der BETA:
                                  @hotspot_2
                                  Vollständiges log
                                  Was genau gemacht
                                  Error meldungen
                                  Vielen Dank! Ich demke das mit dem repo trifft es. Ist ja oben nicht beschrieben wie man den Wechsel durchführt, ich mache mich mal auf die Recherche dazu.
                                  Vorher würde mich noch interessieren worin das Problem mit NodeRED aktuell liegt. Ich habe diesen Adapter und der ist mir mitterlweile auch wirklich sehr ans Herz gewachsen ;-) (Grüsse an @mickym).
                                  ? GaspodeG ESP8266E mcm1957M 4 Antworten Letzte Antwort
                                    @hotspot_2
                                    Vollständiges log
                                    Was genau gemacht
                                    Error meldungen
                                    #302
                                    @hotspot_2
                                    Probleme zu den Adaptern ist immer auf der jeweiligen Seite auf Github bei Issues zu finden.
                                    Hier auch immer die Readme, Wiki, Requirements etc lesen.. ist nie verkehrt :-)
                                      @hotspot_2
                                      Vollständiges log
                                      Was genau gemacht
                                      Error meldungen
                                      GaspodeG Online
                                      GaspodeG Online
                                      Gaspode
                                      #303
                                      @hotspot_2 said in js-controller 5.0.x jetzt in der BETA:
                                      Ich nehme mal an, es geht darum: https://github.com/ioBroker/ioBroker.node-red/issues/380
                                      Das Problem wird natürlich gesucht und ich gehe davon aus auch behoben, bevor Controller 5 offiziell freigegeben wird.
                                      Nochmal der Hinweis: Es handelt sich hier gerade um einen Betatest und sollte noch nicht auf einem produktivem System eingesetzt werden.
                                        @hotspot_2
                                        Vollständiges log
                                        Was genau gemacht
                                        Error meldungen
                                        ESP8266E Offline
                                        ESP8266E Offline
                                        ESP8266
                                        #304
                                        @hotspot_2 , Hauptsache du weisst was du machst. Am besten du lässt die Finger davon....Ruck Zuck ist das System geschrottet. So lange Fakeroku nicht gefixt wurde, bleibe ich auf 4.0.24.
                                        @mcm57 , ich habe den Enigma2 Adpter nicht vergessen. Er wird noch vollständig getestet von mir...nur leider fehlt die Zeit etwas.
                                          @hotspot_2
                                          Vollständiges log
                                          Was genau gemacht
                                          Error meldungen
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          #305
                                          @hotspot_2
                                          Vollständiges log
                                          Was genau gemacht
                                          Error meldungen
                                          Ehrlich gesagt:
                                          Wenn dir der Hinweis auf "Verwenden des Latest Repo" so wenig sagt, dass du erst suchen gehen musst überlege BITTE noch 3 mal ob du wirklich js-controller 5 - BETA (!) testen willst. Du musst dir im Klaren sein, dass das auch ein zerschossenes System bedeuten kann. Und eine Reinstallation von Scratch incl. einspielen eines hoffentlich vorhandenen Backups sollte dir VOR Installation der Beta Testversion geläufig sein.
