  4. web0 startet nicht - versehentlich Beta Updates gemacht
    5.4k
53 Beiträge 4 Kommentatoren 5.3k Aufrufe 2 Beobachtet
  • F fraso
    rm erledigt.
    @fraso
    Dann jubel jetzt nochmal
    iob diag
    durch. Die Langfassung bitte.
    F 1 Antwort Letzte Antwort
      @fraso
      iob diag
      fraso
      gekürzt da nur 10000 Zeichen ..
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : none
      Distributor ID:	Debian
      Description:	Debian GNU/Linux 11 (bullseye)
      Release:	11
      Codename:	bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       14:14:44 up 5 days, 13:06,  2 users,  load average: 1.63, 1.72, 1.74
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Sun 2023-06-25 14:14:44 CEST
                 Universal time: Sun 2023-06-25 12:14:44 UTC
                       RTC time: Sun 2023-06-25 12:14:44
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      e6iob
      /home/e6iob
      e6iob cdrom floppy sudo audio dip video plugdev netdev iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:             15G        4.2G        7.7G        0.0K        3.8G         11G
      Swap:           976M         27M        949M
      Total:           16G        4.3G        8.7G
              15722 M total memory
               4224 M used memory
               2614 M active memory
               4872 M inactive memory
               7741 M free memory
                740 M buffer memory
               3015 M swap cache
                976 M total swap
                 27 M used swap
                949 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  7.7G     0  7.7G   0% /dev
      tmpfs          tmpfs     1.6G  896K  1.6G   1% /run
      /dev/nvme0n1p2 ext4      233G   43G  179G  20% /
      tmpfs          tmpfs     7.7G     0  7.7G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/nvme0n1p1 vfat      511M  3.5M  508M   1% /boot/efi
      tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
      [Tue Jun 20 01:08:36 2023] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
      [Tue Jun 20 01:08:37 2023] EXT4-fs (nvme0n1p2): re-mounted. Opts: errors=remount-ro
      TARGET      SOURCE         FSTYPE OPTIONS
      /           /dev/nvme0n1p2 ext4   rw,relatime,errors=remount-ro
      `-/boot/efi /dev/nvme0n1p1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      /var:
      20G	/var/
      12G	/var/lib
      9.8G	/var/lib/motioneye
      7.2G	/var/log
      5.1G	/var/lib/motioneye/Camera11
      Archived and active journals take up 80.0M in the file system.
      /opt/iobroker/backups:
      11G	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.2G	/opt/iobroker/iobroker-data/
      526M	/opt/iobroker/iobroker-data/files
      461M	/opt/iobroker/iobroker-data/backup-objects
      88M	/opt/iobroker/iobroker-data/files/echarts.admin
      72M	/opt/iobroker/iobroker-data/files/telegram.admin
      92M	/opt/iobroker/iobroker-data/states.jsonl
      56M	/opt/iobroker/iobroker-data/objects.jsonl
      35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
      23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v16.17.1
      /usr/bin/node 		v16.17.1
      /usr/bin/npm 		9.2.0
      /usr/bin/npx 		9.2.0
      nodejs:
        Installed: 16.17.1-deb-1nodesource1
        Candidate: 16.20.1-deb-1nodesource1
        Version table:
           16.20.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
       *** 16.17.1-deb-1nodesource1 100
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	4.0.24
      admin: 		6.5.9
      javascript: 	5.7.0
      Adapters from github: 	1
      Adapter State
      + system.adapter.admin.0                  : admin                 : NUCioBroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : NUCioBroker                              -  enabled
      + system.adapter.backitup.0               : backitup              : NUCioBroker                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : NUCioBroker                              -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : NUCioBroker                              -  enabled
        system.adapter.devices.0                : devices               : NUCioBroker                              - disabled
        system.adapter.discovery.0              : discovery             : NUCioBroker                              - disabled
      + system.adapter.echarts.0                : echarts               : NUCioBroker                              -  enabled
      + system.adapter.email.0                  : email                 : NUCioBroker                              -  enabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : NUCioBroker                              - disabled
        system.adapter.flot.0                   : flot                  : NUCioBroker                              - disabled
      + system.adapter.fritzdect.0              : fritzdect             : NUCioBroker                              -  enabled
      + system.adapter.fronius.0                : fronius               : NUCioBroker                              -  enabled
        system.adapter.habpanel.0               : habpanel              : NUCioBroker                              - disabled
        system.adapter.ham.0                    : ham                   : NUCioBroker                              - disabled
      + system.adapter.history.0                : history               : NUCioBroker                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : NUCioBroker                              -  enabled
      + system.adapter.hm-rega.1                : hm-rega               : NUCioBroker                              -  enabled
      + system.adapter.hm-rega.2                : hm-rega               : NUCioBroker                              -  enabled
      + system.adapter.hm-rega.3                : hm-rega               : NUCioBroker                              -  enabled
      + system.adapter.hm-rega.4                : hm-rega               : NUCioBroker                              -  enabled
        system.adapter.hm-rega.5                : hm-rega               : NUCioBroker                              - disabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
      + system.adapter.hm-rpc.3                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
      + system.adapter.hm-rpc.4                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
        system.adapter.hm-rpc.5                 : hm-rpc                : NUCioBroker                              - disabled, port: 0
      + system.adapter.hs100.0                  : hs100                 : NUCioBroker                              -  enabled
        system.adapter.ical.0                   : ical                  : NUCioBroker                              - disabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: NUCioBroker                              - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : NUCioBroker                              - disabled
      + system.adapter.influxdb.0               : influxdb              : NUCioBroker                              -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : NUCioBroker                              -  enabled
      + system.adapter.javascript.0             : javascript            : NUCioBroker                              -  enabled
      + system.adapter.libre.0                  : libre                 : NUCioBroker                              -  enabled
      + system.adapter.modbus.0                 : modbus                : NUCioBroker                              -  enabled
      + system.adapter.modbus.1                 : modbus                : NUCioBroker                              -  enabled
      + system.adapter.modbus.2                 : modbus                : NUCioBroker                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : NUCioBroker                              -  enabled, port: 1887, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : NUCioBroker                              - disabled, port: 1885, bind: 0.0.0.0
      + system.adapter.niu.0                    : niu                   : NUCioBroker                              -  enabled
        system.adapter.node-red.0               : node-red              : NUCioBroker                              - disabled, port: 1880, bind: 192.168.178.35
        system.adapter.openhab.0                : openhab               : NUCioBroker                              - disabled, port: 8080
        system.adapter.openweathermap.0         : openweathermap        : NUCioBroker                              -  enabled
      + system.adapter.parser.0                 : parser                : NUCioBroker                              -  enabled
      + system.adapter.ping.0                   : ping                  : NUCioBroker                              -  enabled
      + system.adapter.puppeteer.0              : puppeteer             : NUCioBroker                              -  enabled
      + system.adapter.ring.0                   : ring                  : NUCioBroker                              -  enabled
      + system.adapter.senec.0                  : senec                 : NUCioBroker                              -  enabled
      + system.adapter.shelly.0                 : shelly                : NUCioBroker                              -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : NUCioBroker                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : NUCioBroker                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.systeminfo.0             : systeminfo            : NUCioBroker                              - disabled
      + system.adapter.telegram.0               : telegram              : NUCioBroker                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tesla-motors.0           : tesla-motors          : NUCioBroker                              -  enabled
      + system.adapter.text2command.0           : text2command          : NUCioBroker                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : NUCioBroker                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : NUCioBroker                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : NUCioBroker                              - disabled
        system.adapter.vis-weather.0            : vis-weather           : NUCioBroker                              - disabled
        system.adapter.vis.0                    : vis                   : NUCioBroker                              -  enabled
      + system.adapter.web.0                    : web                   : NUCioBroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : NUCioBroker                              -  enabled
      + system.adapter.withings.0               : withings              : NUCioBroker                              -  enabled
      + system.adapter.wled.0                   : wled                  : NUCioBroker                              -  enabled
      + system.adapter.yeelight-2.0             : yeelight-2            : NUCioBroker                              -  enabled
        system.adapter.zigbee.0                 : zigbee                : NUCioBroker                              - disabled, port: tcp://192.168.178.63:6638
      + instance is alive
      ioBroker-Repositories
      live-stable   : http://iobroker.live/repo/sources-dist.json
      live-beta     : http://iobroker.live/repo/sources-dist-latest.json
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.5.9
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "cloud"        : 4.4.1    , installed 4.1.1  [Updatable]
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "discovery"    : 3.1.0    , installed 3.2.0
      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
      Adapter    "fritzdect"    : 2.2.6    , installed 2.3.1
      Adapter    "fronius"      : 1.1.3    , installed 2.0.1
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
      Adapter    "hs100"        : 2.1.2    , installed 2.1.2
      Adapter    "iot"          : 1.14.5   , installed 1.11.4 [Updatable]
      Adapter    "javascript"   : 7.0.3    , installed 5.7.0  [Updatable]
      Adapter    "libre"        : 0.0.4    , installed 0.0.5
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "niu"          : 0.0.3    , installed 0.0.3
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "openhab"      : 1.1.0    , installed 1.1.0
      Adapter    "openweathermap": 0.3.9   , installed 0.3.9
      Adapter    "parser"       : 1.3.2    , installed 1.3.2
      Adapter    "puppeteer"    : 0.2.7    , installed 0.2.6  [Updatable]
      Adapter    "ring"         : 3.2.2    , installed 3.4.0
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
      Adapter    "telegram"     : 1.15.6   , installed 1.16.0
      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "withings"     : 0.0.13   , installed 0.0.13
      Adapter    "wled"         : 0.6.7    , installed 0.6.7
      Adapter    "ws"           : 1.3.0    , installed 2.3.6
      Adapter    "yeelight-2"   : 1.1.2    , installed 1.2.1
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects: 	71663
      States: 	56228
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
      Get:4 https://repos.influxdata.com/debian bullseye InRelease [7040 B]
      Err:4 https://repos.influxdata.com/debian bullseye InRelease
      Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:6 https://packages.grafana.com/oss/deb stable InRelease
      Fetched 7040 B in 5s (1347 B/s)
      Reading package lists...
      Pending Updates: 178
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       24974926   189036/iobroker.js-
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       24976512   189036/iobroker.js-
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9775       1/init
      tcp        0      0 192.168.178.35:2000     0.0.0.0:*               LISTEN      1001       24978875   189498/io.hm-rpc.1
      tcp        0      0 127.0.0.1:40881         0.0.0.0:*               LISTEN      1001       24982798   189922/chrome
      tcp        0      0 192.168.178.35:2001     0.0.0.0:*               LISTEN      1001       24977938   189483/io.hm-rpc.0
      tcp        0      0 192.168.178.35:2002     0.0.0.0:*               LISTEN      1001       24978930   189543/io.hm-rpc.4
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13630      488/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        15295      439/influxd
      tcp        0      0 192.168.178.35:2010     0.0.0.0:*               LISTEN      1001       24980819   189528/io.hm-rpc.3
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       24979080   189645/io.sonoff.0
      tcp        0      0 192.168.178.35:8701     0.0.0.0:*               LISTEN      1001       24980767   189513/io.hm-rpc.2
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       24979031   189630/io.shelly.0
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       24978082   189588/io.mqtt.0
      tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       24978083   189588/io.mqtt.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          9779       1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24975961   189054/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       24984917   190071/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      998        15303      439/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13632      488/sshd: /usr/sbin
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       24982438   189987/io.simple-ap
      tcp6       0      0 :::3000                 :::*                    LISTEN      109        10224      432/grafana-server
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24985974   190112/io.wled.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       24979098   189659/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       24979099   189659/io.tuya.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15884      411/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9776       1/init
      udp6       0      0 :::111                  :::*                                0          9782       1/init
      LOG gekürzt...
      2023-06-25 14:15:24.739  - debug: mqtt.0 (189588) Client [shellyplusi4-a8032ab61ad4]  pingreq
      2023-06-25 14:15:26.041  - info: tesla-motors.0 (190011) State value to set for "tesla-motors.0.LRWYGCEK5NC453432.vehicle_state.media_info.now_playing_source" has to be type "string" but received type "number"
      2023-06-25 14:15:26.544  - warn: shelly.0 (189630) [Mqtt.rpcNotifications] 192.168.178.198 (shellyplus1pm / shellyplus1pm-7c87ce64be70 / shellyplus1pm#7c87ce64be70#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
      2023-06-25 14:15:26.555  - warn: shelly.0 (189630) [Mqtt.rpcNotifications] 192.168.178.17 (shellyplus1pm / shellyplus1pm-7c87ce64a74c / shellyplus1pm#7c87ce64a74c#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
      2023-06-25 14:15:27.601  - debug: withings.0 (190086) {"status":0,"body":{"activities":[],"more":false,"offset":200}}
      2023-06-25 14:15:27.776  - debug: withings.0 (190086) {"status":0,"body":{"series":[],"more":false,"offset":0}}
      2023-06-25 14:15:27.916  - debug: withings.0 (190086) {"status":0,"body":{"series":[],"more":false,"offset":0}}
      2023-06-25 14:15:28.102  - debug: withings.0 (190086) {"status":0,"body":{"series":[],"model":16}}
      2023-06-25 14:15:28.336  - debug: withings.0 (190086) {"status":0,"body":{"updatetime":1654279381,"timezone":"Europe/Berlin","measuregrps":[]}}
      2023-06-25 14:15:28.347  - error: shelly.0 (189630) [MQTT] (Shelly?) device unknown, configuration for client with id "shellyplugus-083af2018100" does not exist!
      2023-06-25 14:15:28.347  - error: shelly.0 (189630) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
      2023-06-25 14:15:28.496  - info: shelly.0 (189630) [MQTT] Client Close:  (shellyplugus / shellyplugus-083af2018100 / undefined) (false)
      2023-06-25 14:15:28.578  - debug: withings.0 (190086) {"status":0,"body":{"activities":[],"more":false,"offset":200}}
      2023-06-25 14:15:28.646  - info: shelly.0 (189630) [MQTT] Client Error: 192.168.178.61 (shelly1 / shelly1-485519C9D34D / SHSW-1#485519C9D34D#1) (Error: read ECONNRESET)
      2023-06-25 14:15:28.727  - debug: withings.0 (190086) {"status":0,"body":{"series":[],"more":false,"offset":0}}
      2023-06-25 14:15:28.765  - debug: wled.0 (190112) Watchdog for {"ip":"192.168.178.103","mac":"ac0bfbd8570c","connected":false,"initialized":false}
      2023-06-25 14:15:28.766  - debug: wled.0 (190112) getDeviceJSON called for : 192.168.178.103
      2023-06-25 14:15:30.654  - debug: yeelight-2.0 (190127) ERROR YEELIGHT CONNECTION: 6: Error: client quota exceeded: undefined
      paul53P Thomas BraunT 3 Antworten Letzte Antwort
      • F fraso
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:	11
        Codename:	bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        e6iob
        /home/e6iob
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
        Swap:           976M         27M        949M
                 4224 M used memory
                 7741 M free memory
                  740 M buffer memory
                 3015 M swap cache
                  976 M total swap
                   27 M used swap
                  949 M free swap
        *** FILESYSTEM ***
        /var:
        20G	/var/
        12G	/var/lib
        7.2G	/var/log
        /usr/bin/npm 		9.2.0
        /usr/bin/npx 		9.2.0
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin: 		6.5.9
        javascript: 	5.7.0
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	71663
        States: 	56228
        LOG gekürzt...
        @fraso
        Es laufen immer noch einige Instanzen auf Loglevel "debug".
        • F fraso
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:	11
          Codename:	bullseye
          VERSION_ID="11"
          ID=debian
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          e6iob
          /home/e6iob
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Swap:           976M         27M        949M
                   4224 M used memory
                   7741 M free memory
                    740 M buffer memory
                   3015 M swap cache
                    976 M total swap
                     27 M used swap
                    949 M free swap
          *** FILESYSTEM ***
          /var:
          20G	/var/
          12G	/var/lib
          7.2G	/var/log
          /usr/bin/npm 		9.2.0
          /usr/bin/npx 		9.2.0
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin: 		6.5.9
          javascript: 	5.7.0
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	71663
          States: 	56228
          LOG gekürzt...
          @fraso
          Setz deinen primären User in die Gruppe 'adm'.
            @fraso
            fraso
            @thomas-braun sagte in web0 startet nicht - versehentlich Beta Updates gemacht:
            Keinen Plan wie, aber ist bestimmt ganz einfach. Wie mache ich das?
            • F fraso
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:	11
              Codename:	bullseye
              VERSION_ID="11"
              ID=debian
              CPU threads: 4
                            NTP service: active
                        RTC in local TZ: no
              e6iob
              /home/e6iob
              X-Server: 	false
              Desktop:
              Terminal: 	tty
              *** MEMORY ***
              Swap:           976M         27M        949M
                       4224 M used memory
                       7741 M free memory
                        740 M buffer memory
                       3015 M swap cache
                        976 M total swap
                         27 M used swap
                        949 M free swap
              *** FILESYSTEM ***
              /var:
              20G	/var/
              12G	/var/lib
              7.2G	/var/log
              /usr/bin/npm 		9.2.0
              /usr/bin/npx 		9.2.0
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 		6.5.9
              javascript: 	5.7.0
              Adapter State
              + instance is alive
              Objects and States
              Objects: 	71663
              States: 	56228
              LOG gekürzt...
              @fraso
              Und dann reparierst du dein influx-Repository, bringst nodejs auf v18 und den Rest vom System auf Stand und danach ziehst du die ganzen iob-Adapter noch auf den aktuellen Stand aus 'stable'.
              F 3 Antworten Letzte Antwort
                @fraso
                fraso
                schrieb am zuletzt editiert von fraso
                bis auf das letzte... brauche ich Hilfe.
                hier DIAG: (UPDATED)
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Docker          : false
                Release:	11
                Codename:	bullseye
                VERSION_ID="11"
                ID=debian
                 14:35:47 up 5 days, 13:27,  2 users,  load average: 1.16, 1.67, 1.58
                CPU threads: 4
                               Local time: Sun 2023-06-25 14:35:47 CEST
                           Universal time: Sun 2023-06-25 12:35:47 UTC
                                 RTC time: Sun 2023-06-25 12:35:47
                              NTP service: active
                          RTC in local TZ: no
                e6iob
                /home/e6iob
                X-Server: 	false
                Desktop:
                Terminal: 	tty
                *** MEMORY ***
                Mem:             15G        5.8G        6.1G        0.0K        3.8G        9.9G
                Swap:           976M         27M        949M
                Total:           16G        5.8G        7.1G
                         5757 M used memory
                         2700 M active memory
                         6364 M inactive memory
                         6142 M free memory
                          749 M buffer memory
                         3072 M swap cache
                          976 M total swap
                           27 M used swap
                          949 M free swap
                *** FILESYSTEM ***
                /var:
                20G	/var/
                12G	/var/lib
                7.2G	/var/log
                132M	/opt/iobroker/iobroker-data/states.jsonl
                61M	/opt/iobroker/iobroker-data/objects.jsonl
                /usr/bin/npm 		9.2.0
                /usr/bin/npx 		9.2.0
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin: 		6.5.9
                javascript: 	5.7.0
                Adapter State
                  system.adapter.zigbee.0                 : zigbee                : NUCioBroker                              -  enabled, port: tcp://192.168.178.63:6638
                + instance is alive
                Objects and States
                Objects: 	70621
                States: 	55318
                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                Get:3 https://repos.influxdata.com/debian bullseye InRelease [7040 B]
                Err:3 https://repos.influxdata.com/debian bullseye InRelease
                Hit:4 http://deb.debian.org/debian bullseye InRelease
                Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                Fetched 7040 B in 10s (688 B/s)
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       25037364   191816/iobroker.js-
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       25039001   191816/iobroker.js-
                tcp        0      0 127.0.0.1:41071         0.0.0.0:*               LISTEN      1001       25042956   191964/chrome
                tcp        0      0 192.168.178.35:2000     0.0.0.0:*               LISTEN      1001       25042399   192359/io.hm-rpc.1
                tcp        0      0 192.168.178.35:2001     0.0.0.0:*               LISTEN      1001       25043389   192258/io.hm-rpc.0
                tcp        0      0 192.168.178.35:2002     0.0.0.0:*               LISTEN      1001       25043543   192513/io.hm-rpc.4
                tcp        0      0 127.0.0.1:38259         0.0.0.0:*               LISTEN      1001       25054721   193990/chrome
                tcp        0      0 192.168.178.35:2010     0.0.0.0:*               LISTEN      1001       25041575   192466/io.hm-rpc.3
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       25046610   192860/io.sonoff.0
                tcp        0      0 192.168.178.35:8701     0.0.0.0:*               LISTEN      1001       25042463   192432/io.hm-rpc.2
                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       25046208   192638/io.shelly.0
                tcp        0      0 127.0.0.1:36063         0.0.0.0:*               LISTEN      1001       25044710   192686/chrome
                tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       25042685   192594/io.mqtt.0
                tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       25042686   192594/io.mqtt.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       25039033   191834/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25054198   194132/io.web.0
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       25053916   194072/io.simple-ap
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       25055154   194158/io.wled.0
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       25049034   193039/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       25049035   193039/io.tuya.0
                2023-06-25 14:36:00.033  - error: javascript.0 (191909)     at processTimers (node:internal/timers:502:7)
                2023-06-25 14:36:00.115  - warn: javascript.0 (191909) You are assigning a string to the state "alias.0.SOLAR.SOLAR_LAMPE_FARBE" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
                2023-06-25 14:36:00.116  - warn: javascript.0 (191909)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1532:20)
                2023-06-25 14:36:00.116  - warn: javascript.0 (191909)     at Object.<anonymous> (script.js.E6-HAUS.SOLAR.SOLAR_FARB_LAMPE:43:7)
                2023-06-25 14:36:00.116  - warn: javascript.0 (191909)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1408:34)
                2023-06-25 14:36:00.116  - warn: javascript.0 (191909)     at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
                2023-06-25 14:36:00.116  - warn: javascript.0 (191909)     at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
                2023-06-25 14:36:00.116  - warn: javascript.0 (191909)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
                2023-06-25 14:36:00.116  - warn: javascript.0 (191909)     at listOnTimeout (node:internal/timers:559:17)
                2023-06-25 14:36:00.116  - warn: javascript.0 (191909)     at processTimers (node:internal/timers:502:7)
                2023-06-25 14:36:02.191  - error: tesla-motors.0 (194087) Error: getaddrinfo EAI_AGAIN owner-api.teslamotors.com
                2023-06-25 14:36:03.659  - warn: shelly.0 (192638) [Mqtt.rpcNotifications] 192.168.178.198 (shellyplus1pm / shellyplus1pm-7c87ce64be70 / shellyplus1pm#7c87ce64be70#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
                2023-06-25 14:36:04.949  - warn: shelly.0 (192638) [Mqtt.rpcNotifications] 192.168.178.17 (shellyplus1pm / shellyplus1pm-7c87ce64a74c / shellyplus1pm#7c87ce64a74c#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
                2023-06-25 14:36:09.024  - warn: shelly.0 (192638) [Mqtt.rpcNotifications] 192.168.178.198 (shellyplus1pm / shellyplus1pm-7c87ce64be70 / shellyplus1pm#7c87ce64be70#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
                2023-06-25 14:36:10.337  - warn: shelly.0 (192638) [Mqtt.rpcNotifications] 192.168.178.17 (shellyplus1pm / shellyplus1pm-7c87ce64a74c / shellyplus1pm#7c87ce64a74c#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
                2023-06-25 14:36:14.384  - warn: shelly.0 (192638) [Mqtt.rpcNotifications] 192.168.178.198 (shellyplus1pm / shellyplus1pm-7c87ce64be70 / shellyplus1pm#7c87ce64be70#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
                2023-06-25 14:36:16.783  - warn: shelly.0 (192638) [Mqtt.rpcNotifications] 192.168.178.17 (shellyplus1pm / shellyplus1pm-7c87ce64a74c / shellyplus1pm#7c87ce64a74c#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
                2023-06-25 14:36:19.701  - warn: shelly.0 (192638) [Mqtt.rpcNotifications] 192.168.178.198 (shellyplus1pm / shellyplus1pm-7c87ce64be70 / shellyplus1pm#7c87ce64be70#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
                2023-06-25 14:36:22.248  - warn: shelly.0 (192638) [Mqtt.rpcNotifications] 192.168.178.17 (shellyplus1pm / shellyplus1pm-7c87ce64a74c / shellyplus1pm#7c87ce64a74c#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
                2023-06-25 14:36:25.108  - warn: shelly.0 (192638) [Mqtt.rpcNotifications] 192.168.178.198 (shellyplus1pm / shellyplus1pm-7c87ce64be70 / shellyplus1pm#7c87ce64be70#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
                2023-06-25 14:36:27.598  - warn: shelly.0 (192638) [Mqtt.rpcNotifications] 192.168.178.17 (shellyplus1pm / shellyplus1pm-7c87ce64a74c / shellyplus1pm#7c87ce64a74c#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
                2023-06-25 14:36:29.779  - error: alexa2.0 (192159) e384a6bc65914d75976dda2bcac1c3f8 Error getting connected speaker setting: Error: Timeout
                2023-06-25 14:36:30.475  - warn: shelly.0 (192638) [Mqtt.rpcNotifications] 192.168.178.198 (shellyplus1pm / shellyplus1pm-7c87ce64be70 / shellyplus1pm#7c87ce64be70#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
                2023-06-25 14:36:33.018  - warn: shelly.0 (192638) [Mqtt.rpcNotifications] 192.168.178.17 (shellyplus1pm / shellyplus1pm-7c87ce64a74c / shellyplus1pm#7c87ce64a74c#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
                2023-06-25 14:36:35.783  - warn: shelly.0 (192638) [Mqtt.rpcNotifications] 192.168.178.198 (shellyplus1pm / shellyplus1pm-7c87ce64be70 / shellyplus1pm#7c87ce64be70#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
                • F fraso
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:	11
                  Codename:	bullseye
                  VERSION_ID="11"
                  ID=debian
                  CPU threads: 4
                                NTP service: active
                            RTC in local TZ: no
                  e6iob
                  /home/e6iob
                  X-Server: 	false
                  Desktop:
                  Terminal: 	tty
                  *** MEMORY ***
                  Swap:           976M         27M        949M
                           5757 M used memory
                           6142 M free memory
                            749 M buffer memory
                           3072 M swap cache
                            976 M total swap
                             27 M used swap
                            949 M free swap
                  *** FILESYSTEM ***
                  /var:
                  20G	/var/
                  12G	/var/lib
                  7.2G	/var/log
                  /usr/bin/npm 		9.2.0
                  /usr/bin/npx 		9.2.0
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin: 		6.5.9
                  javascript: 	5.7.0
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects: 	70621
                  States: 	55318
                  @fraso
                  sudo usermod -a -G adm e6iob
                  exit
                  • F fraso
                    Der Hinweis: Du musst zuvor nach /opt/iobroker wechseln. war genau das
                    was ich brauchte. DANKE!
                    ich sag ja, das kann so einfach sein. wenn man es weiß.
                    web.0 läuft
                    vis.0 läuft
                    Soll ich noch was anderes gerade biegen?
                    e6iob@NUCioBroker:/opt/iobroker$ npm install iobroker.js-controller@4.0.24
                    added 4 packages, removed 691 packages, and changed 16 packages in 26s
                    162 packages are looking for funding
                      run `npm fund` for details
                    e6iob@NUCioBroker:/opt/iobroker$ iob version
                    4.0.24
                    HomoranH Offline
                    HomoranH Offline
                    @fraso sagte in web0 startet nicht - versehentlich Beta Updates gemacht:
                    war genau das
                    warum antwortest du nicht wenn man danach fragt?
                    @homoran sagte in web0 startet nicht - versehentlich Beta Updates gemacht:
                    Ich habe das ausgeführt:
                    wo???
                    alles zeigen!
                    keine Nacherzählung
                    rm erledigt.
                    auch hier: zeigen!!
                    dann kann auch so etwas
                    Hast du die falsche Version von npx gelöscht?
                    nicht passieren oder wir sehen es wenigstens
                      @fraso
                      fraso
                      will nur vorher fragen .. so?
                      iob stop influxdb
                      iob del influxdb
                      ion add influxdb
                      iob start influxdb
                        war genau das
                        wo???
                        alles zeigen!
                        keine Nacherzählung
                        rm erledigt.
                        auch hier: zeigen!!
                        fraso
                        kann ich nicht mehr zeigen :) ist auf der console weg.
                        wenn ich es noch mal machen möchte kommt die Fehlermeldung = hat beim ersten mal geklappt. da kam (wie üblich bei rm erfolgreich gar keine rückmeldung)
                        rm ist ein stiller killer
                        e6iob@NUCioBroker:~$ sudo rm /usr/local/bin/npx
                        rm: das Entfernen von '/usr/local/bin/npx' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                        • F fraso
                          iob stop influxdb
                          iob del influxdb
                          ion add influxdb
                          iob start influxdb
                          @fraso
                          Nein. Influx wird über apt installiert und daher muss auch das Repo dort angepackt werden. Ist in dem Thread zu 'grafana muss aktualisiert werden' von mir aber im weiteren Verlauf auch abgehandelt worden.
                          Nicht nur rm. Es werden nur Fehler in der Konsole zurückgegeben, erfolgreich ausgeführte Befehle halten den Schnabel.
                          • F fraso
                            kann ich nicht mehr zeigen ist auf der console weg.
                            Pfeil-nach-oben blättert durch die Historie.
                            Erfolgreich ausgeführte Kommandos werden nicht nochmal bestätigt. Nur Fehler siehst du.
                              @fraso
                              fraso
                              uiui ist da viel passiert bei dem influx:
                              e6iob@NUCioBroker:~$ iob stop
                              e6iob@NUCioBroker:~$ ls -lA /etc/apt/sources.list.d/
                              sudo apt update
                              insgesamt 16
                              -rw-r--r-- 1 root root 104  4. Feb 19:45 influxdb.list
                              -rw-r--r-- 1 root root 104  4. Feb 19:45 influxdb.list.save
                              -rw-r--r-- 1 root root 208  4. Feb 19:45 nodesource.list
                              -rw-r--r-- 1 root root 208  4. Feb 19:45 nodesource.list.save
                              [sudo] Passwort für e6iob:
                              OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                              OK:2 http://deb.debian.org/debian bullseye InRelease
                              OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                              OK:4 https://packages.grafana.com/oss/deb stable InRelease
                              OK:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                              Holen:6 https://repos.influxdata.com/debian bullseye InRelease [7.040 B]
                              Fehl:6 https://repos.influxdata.com/debian bullseye InRelease
                                Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                              Es wurden 7.040 B in 10 s geholt (691 B/s).
                              Aktualisierung für 179 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                              W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian bullseye InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                              W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/bullseye/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                              W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
                              e6iob@NUCioBroker:~$ sudo rm /etc/apt/sources.list.d/influxdb.list
                              e6iob@NUCioBroker:~$ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                               echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                               echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                               sudo apt update
                               sudo apt full-upgrade
                              influxdata-archive_compat.key: OK
                              OK:1 http://deb.debian.org/debian bullseye InRelease
                              OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                              OK:3 http://security.debian.org/debian-security bullseye-security InRelease
                              Holen:5 https://repos.influxdata.com/debian stable InRelease [6.892 B]
                              Holen:6 https://repos.influxdata.com/debian stable/main amd64 Packages [5.071 B]
                              Fehl:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                                Temporärer Fehlschlag beim Auflösen von »deb.nodesource.com«
                              Es wurden 12,0 kB in 30 s geholt (397 B/s).
                              W: Fehlschlag beim Holen von https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease Temporärer Fehlschlag beim Auflösen von »deb.nodesource.com«
                              Paketaktualisierung (Upgrade) wird berechnet… Fertig
                              Die folgenden NEUEN Pakete werden installiert:
                                linux-image-5.10.0-23-amd64
                                at-spi2-core base-files bash bind9-dnsutils bind9-host bind9-libs cifs-utils curl dbus dbus-user-session debian-archive-keyring
                                distro-info-data dpkg dpkg-dev ffmpeg ghostscript gir1.2-gdkpixbuf-2.0 git git-man grafana grep grub-common grub-efi-amd64
                                grub-efi-amd64-bin grub-efi-amd64-signed grub2-common gtk-update-icon-cache gzip imagemagick-6-common isc-dhcp-client isc-dhcp-common
                                krb5-locales libatspi2.0-0 libavahi-client-dev libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3
                                libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4 libavutil56
                                libbluray2 libc-bin libc-dev-bin libc-devtools libc-l10n libc6 libc6-dev libcups2 libcurl3-gnutls libcurl4 libcurl4-openssl-dev
                                libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libexpat1 libexpat1-dev libfreetype-dev libfreetype6 libfreetype6-dev libfribidi-dev
                                libfribidi0 libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common libgnutls30 libgs9 libgs9-common
                                libgssapi-krb5-2 libgtk-3-0 libgtk-3-bin libgtk-3-common libhttp-daemon-perl libk5crypto3 libkrb5-3 libkrb5support0 libksba8
                                libldap-2.4-2 libldap-common liblzma-dev liblzma5 libmagick++-6-headers libmagick++-6.q16-8 libmagick++-6.q16-dev libmagick++-dev
                                libmagickcore-6-arch-config libmagickcore-6-headers libmagickcore-6.q16-6 libmagickcore-6.q16-6-extra libmagickcore-6.q16-dev
                                libmagickwand-6-headers libmagickwand-6.q16-6 libmagickwand-6.q16-dev libmariadb3 libncurses6 libncursesw6 libnftables1 libnss-systemd
                                libnss3 libopenexr-dev libopenexr25 libpam-systemd libpcre2-16-0 libpcre2-32-0 libpcre2-8-0 libpcre2-dev libpcre2-posix2 libpixman-1-0
                                libpixman-1-dev libpostproc55 libpq5 libsdl2-2.0-0 libssh-gcrypt-4 libssl-dev libssl1.1 libswresample3 libswscale5 libsystemd0
                                libtasn1-6 libtiff-dev libtiff5 libtiffxx5 libtinfo6 libtirpc-common libtirpc-dev libtirpc3 libudev-dev libudev1 libwbclient0 libwebp6
                                libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev libx11-xcb1 libxml2 libxml2-dev libxpm4 linux-image-amd64 linux-libc-dev
                                locales logrotate mariadb-common mokutil nano ncurses-base ncurses-bin ncurses-term nftables nodejs openssh-client openssh-server
                                openssh-sftp-server openssl publicsuffix rsyslog shim-helpers-amd64-signed shim-signed shim-signed-common shim-unsigned sudo systemd
                                systemd-sysv systemd-timesyncd traceroute tzdata udev unzip xz-utils zlib1g zlib1g-dev
                              179 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                              Es müssen 269 MB an Archiven heruntergeladen werden.
                              Nach dieser Operation werden 347 MB Plattenplatz zusätzlich benutzt.
                              Möchten Sie fortfahren? [J/n] J
                              Holen:1 http://deb.debian.org/debian bullseye/main amd64 base-files amd64 11.1+deb11u7 [70,1 kB]
                              Holen:2 http://deb.debian.org/debian bullseye/main amd64 bash amd64 5.1-2+deb11u1 [1.417 kB]
                              Holen:3 https://deb.nodesource.com/node_16.x bullseye/main amd64 nodejs amd64 16.20.1-deb-1nodesource1 [27,2 MB]
                              Holen:4 http://deb.debian.org/debian bullseye/main amd64 dpkg amd64 1.20.12 [2.536 kB]
                              Holen:5 http://deb.debian.org/debian bullseye/main amd64 grep amd64 3.6-1+deb11u1 [398 kB]
                              Holen:6 http://deb.debian.org/debian bullseye/main amd64 gzip amd64 1.10-4+deb11u1 [132 kB]
                              Holen:7 http://deb.debian.org/debian bullseye/main amd64 ncurses-bin amd64 6.2+20201114-2+deb11u1 [429 kB]
                              Holen:8 http://deb.debian.org/debian bullseye/main amd64 libc-devtools amd64 2.31-13+deb11u6 [246 kB]
                              Holen:9 http://deb.debian.org/debian bullseye/main amd64 libc6-dev amd64 2.31-13+deb11u6 [2.360 kB]
                              Holen:10 http://deb.debian.org/debian bullseye/main amd64 libc-dev-bin amd64 2.31-13+deb11u6 [276 kB]
                              Holen:11 http://deb.debian.org/debian bullseye/main amd64 libc6 amd64 2.31-13+deb11u6 [2.827 kB]
                              Holen:12 http://deb.debian.org/debian bullseye/main amd64 libc-bin amd64 2.31-13+deb11u6 [824 kB]
                              Holen:13 http://deb.debian.org/debian bullseye/main amd64 ncurses-base all 6.2+20201114-2+deb11u1 [272 kB]
                              Holen:14 http://deb.debian.org/debian bullseye/main amd64 libnss-systemd amd64 247.3-7+deb11u2 [199 kB]
                              Holen:15 http://deb.debian.org/debian bullseye/main amd64 libudev-dev amd64 247.3-7+deb11u2 [123 kB]
                              Holen:16 http://deb.debian.org/debian bullseye/main amd64 libsystemd0 amd64 247.3-7+deb11u2 [376 kB]
                              Holen:17 http://deb.debian.org/debian bullseye/main amd64 systemd-timesyncd amd64 247.3-7+deb11u2 [131 kB]
                              Holen:18 http://deb.debian.org/debian bullseye/main amd64 libpam-systemd amd64 247.3-7+deb11u2 [283 kB]
                              Holen:19 http://deb.debian.org/debian bullseye/main amd64 systemd amd64 247.3-7+deb11u2 [4.501 kB]
                              Holen:20 http://deb.debian.org/debian bullseye/main amd64 udev amd64 247.3-7+deb11u2 [1.465 kB]
                              Holen:21 http://deb.debian.org/debian bullseye/main amd64 libudev1 amd64 247.3-7+deb11u2 [168 kB]
                              Holen:22 http://deb.debian.org/debian bullseye/main amd64 systemd-sysv amd64 247.3-7+deb11u2 [113 kB]
                              Holen:23 http://deb.debian.org/debian bullseye/main amd64 libdbus-1-dev amd64 1.12.24-0+deb11u1 [260 kB]
                              Holen:24 http://deb.debian.org/debian bullseye/main amd64 dbus amd64 1.12.24-0+deb11u1 [243 kB]
                              Holen:25 http://deb.debian.org/debian bullseye/main amd64 libdbus-1-3 amd64 1.12.24-0+deb11u1 [222 kB]
                              Holen:26 http://deb.debian.org/debian bullseye/main amd64 libexpat1-dev amd64 2.2.10-2+deb11u5 [141 kB]
                              Holen:27 http://deb.debian.org/debian bullseye/main amd64 libexpat1 amd64 2.2.10-2+deb11u5 [98,2 kB]
                              Holen:28 http://deb.debian.org/debian bullseye/main amd64 libtasn1-6 amd64 4.16.0-2+deb11u1 [54,9 kB]
                              Holen:29 http://deb.debian.org/debian bullseye/main amd64 libgnutls30 amd64 3.7.1-5+deb11u3 [1.340 kB]
                              Holen:30 http://deb.debian.org/debian bullseye/main amd64 nftables amd64 0.9.8-3.1+deb11u1 [68,7 kB]
                              Holen:31 http://deb.debian.org/debian bullseye/main amd64 libnftables1 amd64 0.9.8-3.1+deb11u1 [261 kB]
                              Holen:32 http://deb.debian.org/debian bullseye/main amd64 zlib1g-dev amd64 1:1.2.11.dfsg-2+deb11u2 [191 kB]
                              Holen:33 http://deb.debian.org/debian bullseye/main amd64 zlib1g amd64 1:1.2.11.dfsg-2+deb11u2 [91,4 kB]
                              Holen:34 http://deb.debian.org/debian bullseye/main amd64 rsyslog amd64 8.2102.0-2+deb11u1 [703 kB]
                              Holen:35 http://deb.debian.org/debian bullseye/main amd64 libmagick++-6.q16-dev amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [281 kB]
                              Holen:36 http://deb.debian.org/debian bullseye/main amd64 libmagick++-dev all 8:6.9.11.60+dfsg-1.3+deb11u1 [1.368 B]
                              Holen:37 http://deb.debian.org/debian bullseye/main amd64 libmagick++-6-headers all 8:6.9.11.60+dfsg-1.3+deb11u1 [47,5 kB]
                              Holen:38 http://deb.debian.org/debian bullseye/main amd64 libmagickwand-6.q16-dev amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [450 kB]
                              Holen:39 http://deb.debian.org/debian bullseye/main amd64 libmagickwand-6-headers all 8:6.9.11.60+dfsg-1.3+deb11u1 [10,5 kB]
                              Holen:40 http://deb.debian.org/debian bullseye/main amd64 libmagickcore-6.q16-dev amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [1.142 kB]
                              Holen:41 http://deb.debian.org/debian bullseye/main amd64 libmagickcore-6-arch-config amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [174 kB]
                              Holen:42 http://deb.debian.org/debian bullseye/main amd64 libmagickcore-6-headers all 8:6.9.11.60+dfsg-1.3+deb11u1 [50,9 kB]
                              Holen:43 http://deb.debian.org/debian bullseye/main amd64 imagemagick-6-common all 8:6.9.11.60+dfsg-1.3+deb11u1 [211 kB]
                              Holen:44 http://deb.debian.org/debian bullseye/main amd64 libmagickwand-6.q16-6 amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [453 kB]
                              Holen:45 http://deb.debian.org/debian bullseye/main amd64 libopenexr-dev amd64 2.5.4-2+deb11u1 [160 kB]
                              Holen:46 http://deb.debian.org/debian bullseye/main amd64 libopenexr25 amd64 2.5.4-2+deb11u1 [689 kB]
                              Holen:47 http://deb.debian.org/debian bullseye/main amd64 libxml2-dev amd64 2.9.10+dfsg-6.7+deb11u4 [790 kB]
                              Holen:48 http://deb.debian.org/debian bullseye/main amd64 liblzma-dev amd64 5.2.5-2.1~deb11u1 [229 kB]
                              Holen:49 http://deb.debian.org/debian bullseye/main amd64 liblzma5 amd64 5.2.5-2.1~deb11u1 [168 kB]
                              Holen:50 http://deb.debian.org/debian bullseye/main amd64 libxml2 amd64 2.9.10+dfsg-6.7+deb11u4 [693 kB]
                              Holen:51 http://deb.debian.org/debian bullseye/main amd64 libmagickcore-6.q16-6-extra amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [216 kB]
                              Holen:52 http://deb.debian.org/debian bullseye/main amd64 libfreetype6-dev amd64 2.10.4+dfsg-1+deb11u1 [82,6 kB]
                              Holen:53 http://deb.debian.org/debian bullseye/main amd64 libfreetype-dev amd64 2.10.4+dfsg-1+deb11u1 [571 kB]
                              Holen:54 http://deb.debian.org/debian bullseye/main amd64 libfreetype6 amd64 2.10.4+dfsg-1+deb11u1 [418 kB]
                              Holen:55 http://deb.debian.org/debian bullseye/main amd64 libtiff-dev amd64 4.2.0-1+deb11u4 [416 kB]
                              Holen:56 http://deb.debian.org/debian bullseye/main amd64 libtiff5 amd64 4.2.0-1+deb11u4 [290 kB]
                              Holen:57 http://deb.debian.org/debian bullseye/main amd64 libtiffxx5 amd64 4.2.0-1+deb11u4 [129 kB]
                              Holen:58 http://deb.debian.org/debian bullseye/main amd64 libmagickcore-6.q16-6 amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [1.812 kB]
                              Holen:59 http://deb.debian.org/debian bullseye/main amd64 libmagick++-6.q16-8 amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [290 kB]
                              Holen:60 http://deb.debian.org/debian bullseye/main amd64 libwbclient0 amd64 2:4.13.13+dfsg-1~deb11u5 [313 kB]
                              Holen:61 http://deb.debian.org/debian bullseye/main amd64 debian-archive-keyring all 2021.1.1+deb11u1 [110 kB]
                              Holen:62 http://deb.debian.org/debian bullseye/main amd64 libk5crypto3 amd64 1.18.3-6+deb11u3 [114 kB]
                              Holen:63 http://deb.debian.org/debian bullseye/main amd64 libkrb5support0 amd64 1.18.3-6+deb11u3 [65,5 kB]
                              Holen:64 http://deb.debian.org/debian bullseye/main amd64 libkrb5-3 amd64 1.18.3-6+deb11u3 [364 kB]
                              Holen:65 http://deb.debian.org/debian bullseye/main amd64 libgssapi-krb5-2 amd64 1.18.3-6+deb11u3 [165 kB]
                              Holen:66 http://deb.debian.org/debian bullseye/main amd64 libpcre2-dev amd64 10.36-2+deb11u1 [733 kB]
                              Holen:67 http://deb.debian.org/debian bullseye/main amd64 libpcre2-16-0 amd64 10.36-2+deb11u1 [232 kB]
                              Holen:68 http://deb.debian.org/debian bullseye/main amd64 libpcre2-32-0 amd64 10.36-2+deb11u1 [220 kB]
                              Holen:69 http://deb.debian.org/debian bullseye/main amd64 libpcre2-posix2 amd64 10.36-2+deb11u1 [49,1 kB]
                              Holen:70 http://deb.debian.org/debian bullseye/main amd64 libpcre2-8-0 amd64 10.36-2+deb11u1 [248 kB]
                              Holen:71 http://deb.debian.org/debian bullseye/main amd64 libncurses6 amd64 6.2+20201114-2+deb11u1 [102 kB]
                              Holen:72 http://deb.debian.org/debian bullseye/main amd64 libncursesw6 amd64 6.2+20201114-2+deb11u1 [132 kB]
                              Holen:73 http://deb.debian.org/debian bullseye/main amd64 libtinfo6 amd64 6.2+20201114-2+deb11u1 [341 kB]
                              Holen:74 http://deb.debian.org/debian bullseye/main amd64 libtirpc-common all 1.3.1-1+deb11u1 [13,5 kB]
                              Holen:75 http://deb.debian.org/debian bullseye/main amd64 libtirpc-dev amd64 1.3.1-1+deb11u1 [191 kB]
                              Holen:76 http://deb.debian.org/debian bullseye/main amd64 libtirpc3 amd64 1.3.1-1+deb11u1 [84,1 kB]
                              Holen:77 http://deb.debian.org/debian bullseye/main amd64 tzdata all 2021a-1+deb11u10 [286 kB]
                              Holen:78 http://deb.debian.org/debian bullseye/main amd64 isc-dhcp-client amd64 4.4.1-2.3+deb11u2 [343 kB]
                              Holen:79 http://deb.debian.org/debian bullseye/main amd64 isc-dhcp-common amd64 4.4.1-2.3+deb11u2 [145 kB]
                              Holen:80 http://deb.debian.org/debian bullseye/main amd64 logrotate amd64 3.18.0-2+deb11u1 [72,7 kB]
                              Holen:81 http://deb.debian.org/debian bullseye/main amd64 nano amd64 5.4-2+deb11u2 [657 kB]
                              Holen:82 http://deb.debian.org/debian bullseye/main amd64 bind9-dnsutils amd64 1:9.16.37-1~deb11u1 [404 kB]
                              Holen:83 http://deb.debian.org/debian bullseye/main amd64 bind9-libs amd64 1:9.16.37-1~deb11u1 [1.424 kB]
                              Holen:84 http://deb.debian.org/debian bullseye/main amd64 bind9-host amd64 1:9.16.37-1~deb11u1 [308 kB]
                              Holen:85 http://deb.debian.org/debian bullseye/main amd64 krb5-locales all 1.18.3-6+deb11u3 [95,5 kB]
                              Holen:86 http://deb.debian.org/debian bullseye/main amd64 libc-l10n all 2.31-13+deb11u6 [865 kB]
                              Holen:87 http://deb.debian.org/debian bullseye/main amd64 locales all 2.31-13+deb11u6 [4.086 kB]
                              Holen:88 http://deb.debian.org/debian bullseye/main amd64 ncurses-term all 6.2+20201114-2+deb11u1 [505 kB]
                              Holen:89 http://deb.debian.org/debian bullseye/main amd64 openssh-sftp-server amd64 1:8.4p1-5+deb11u1 [52,4 kB]
                              Holen:90 http://deb.debian.org/debian bullseye/main amd64 openssh-server amd64 1:8.4p1-5+deb11u1 [385 kB]
                              Holen:91 http://deb.debian.org/debian bullseye/main amd64 git-man all 1:2.30.2-1+deb11u2 [1.828 kB]
                              Holen:92 http://deb.debian.org/debian bullseye/main amd64 libldap-2.4-2 amd64 2.4.57+dfsg-3+deb11u1 [232 kB]
                              Holen:93 http://deb.debian.org/debian bullseye/main amd64 libcurl3-gnutls amd64 7.74.0-1.3+deb11u7 [343 kB]
                              Holen:94 http://deb.debian.org/debian bullseye/main amd64 git amd64 1:2.30.2-1+deb11u2 [5.518 kB]
                              Holen:95 http://deb.debian.org/debian bullseye/main amd64 openssh-client amd64 1:8.4p1-5+deb11u1 [929 kB]
                              Holen:96 http://deb.debian.org/debian bullseye/main amd64 traceroute amd64 1:2.1.0-2+deb11u1 [55,7 kB]
                              Holen:97 http://deb.debian.org/debian bullseye/main amd64 xz-utils amd64 5.2.5-2.1~deb11u1 [220 kB]
                              Holen:98 http://deb.debian.org/debian bullseye/main amd64 libatspi2.0-0 amd64 2.38.0-4+deb11u1 [72,4 kB]
                              Holen:99 http://deb.debian.org/debian bullseye/main amd64 at-spi2-core amd64 2.38.0-4+deb11u1 [72,5 kB]
                              Holen:100 http://deb.debian.org/debian bullseye/main amd64 cifs-utils amd64 2:6.11-3.1+deb11u1 [90,4 kB]
                              Holen:101 http://deb.debian.org/debian bullseye/main amd64 libcurl4-openssl-dev amd64 7.74.0-1.3+deb11u7 [436 kB]
                              Holen:102 http://deb.debian.org/debian bullseye/main amd64 curl amd64 7.74.0-1.3+deb11u7 [270 kB]
                              Holen:103 http://deb.debian.org/debian bullseye/main amd64 libcurl4 amd64 7.74.0-1.3+deb11u7 [346 kB]
                              Holen:104 http://deb.debian.org/debian bullseye/main amd64 dbus-user-session amd64 1.12.24-0+deb11u1 [99,7 kB]
                              Holen:105 http://deb.debian.org/debian bullseye/main amd64 distro-info-data all 0.51+deb11u3 [7.812 B]
                              Holen:106 http://deb.debian.org/debian bullseye/main amd64 dpkg-dev all 1.20.12 [2.312 kB]
                              Holen:107 http://deb.debian.org/debian bullseye/main amd64 libdpkg-perl all 1.20.12 [1.551 kB]
                              Holen:108 http://deb.debian.org/debian bullseye/main amd64 libsdl2-2.0-0 amd64 2.0.14+dfsg2-3+deb11u1 [506 kB]
                              Holen:109 http://deb.debian.org/debian bullseye/main amd64 libfribidi-dev amd64 1.0.8-2+deb11u1 [105 kB]
                              Holen:110 http://deb.debian.org/debian bullseye/main amd64 libfribidi0 amd64 1.0.8-2+deb11u1 [64,9 kB]
                              Holen:111 http://deb.debian.org/debian bullseye/main amd64 libbluray2 amd64 1:1.2.1-4+deb11u2 [139 kB]
                              Holen:112 http://deb.debian.org/debian bullseye/main amd64 ghostscript amd64 9.53.3~dfsg-7+deb11u4 [98,2 kB]
                              Holen:113 http://deb.debian.org/debian bullseye/main amd64 libgs9 amd64 9.53.3~dfsg-7+deb11u4 [2.244 kB]
                              Holen:114 http://deb.debian.org/debian bullseye/main amd64 libgs9-common all 9.53.3~dfsg-7+deb11u4 [734 kB]
                              Holen:115 http://deb.debian.org/debian bullseye/main amd64 libavahi-compat-libdnssd-dev amd64 0.8-5+deb11u2 [68,1 kB]
                              Holen:116 http://deb.debian.org/debian bullseye/main amd64 libavahi-compat-libdnssd1 amd64 0.8-5+deb11u2 [53,2 kB]
                              Holen:117 http://deb.debian.org/debian bullseye/main amd64 libavahi-client-dev amd64 0.8-5+deb11u2 [71,0 kB]
                              Holen:118 http://deb.debian.org/debian bullseye/main amd64 libavahi-client3 amd64 0.8-5+deb11u2 [62,6 kB]
                              Holen:119 http://deb.debian.org/debian bullseye/main amd64 libavahi-common-dev amd64 0.8-5+deb11u2 [73,7 kB]
                              Holen:120 http://deb.debian.org/debian bullseye/main amd64 libavahi-common3 amd64 0.8-5+deb11u2 [58,7 kB]
                              Holen:121 http://deb.debian.org/debian bullseye/main amd64 libavahi-common-data amd64 0.8-5+deb11u2 [124 kB]
                              Holen:122 http://deb.debian.org/debian bullseye/main amd64 libcups2 amd64 2.3.3op2-3+deb11u2 [350 kB]
                              Holen:123 http://deb.debian.org/debian bullseye/main amd64 libgdk-pixbuf-2.0-dev amd64 2.42.2+dfsg-1+deb11u1 [56,9 kB]
                              Holen:124 http://deb.debian.org/debian bullseye/main amd64 libgdk-pixbuf-2.0-0 amd64 2.42.2+dfsg-1+deb11u1 [147 kB]
                              Holen:125 http://deb.debian.org/debian bullseye/main amd64 libgdk-pixbuf2.0-common all 2.42.2+dfsg-1+deb11u1 [320 kB]
                              Holen:126 http://deb.debian.org/debian bullseye/main amd64 libgdk-pixbuf2.0-bin amd64 2.42.2+dfsg-1+deb11u1 [25,7 kB]
                              Holen:127 http://deb.debian.org/debian bullseye/main amd64 gir1.2-gdkpixbuf-2.0 amd64 2.42.2+dfsg-1+deb11u1 [19,9 kB]
                              Holen:128 http://deb.debian.org/debian bullseye/main amd64 grub-efi-amd64 amd64 2.06-3~deb11u5 [40,2 kB]
                              Holen:129 http://deb.debian.org/debian bullseye/main amd64 grub2-common amd64 2.06-3~deb11u5 [611 kB]
                              Holen:130 http://deb.debian.org/debian bullseye/main amd64 grub-efi-amd64-bin amd64 2.06-3~deb11u5 [1.566 kB]
                              Holen:131 http://deb.debian.org/debian bullseye/main amd64 grub-common amd64 2.06-3~deb11u5 [2.761 kB]
                              Holen:132 http://deb.debian.org/debian bullseye/main amd64 grub-efi-amd64-signed amd64 1+2.06+3~deb11u5 [1.241 kB]
                              Holen:133 http://deb.debian.org/debian bullseye/main amd64 gtk-update-icon-cache amd64 3.24.24-4+deb11u3 [88,4 kB]
                              Holen:134 http://deb.debian.org/debian bullseye/main amd64 libde265-0 amd64 1.0.11-0+deb11u1 [179 kB]
                              Holen:135 http://deb.debian.org/debian bullseye/main amd64 libgtk-3-common all 3.24.24-4+deb11u3 [3.757 kB]
                              Holen:136 http://deb.debian.org/debian bullseye/main amd64 libgtk-3-0 amd64 3.24.24-4+deb11u3 [2.716 kB]
                              Holen:137 http://deb.debian.org/debian bullseye/main amd64 libgtk-3-bin amd64 3.24.24-4+deb11u3 [125 kB]
                              Holen:138 http://deb.debian.org/debian bullseye/main amd64 libhttp-daemon-perl all 6.12-1+deb11u1 [23,4 kB]
                              Holen:139 http://deb.debian.org/debian bullseye/main amd64 libksba8 amd64 1.5.0-3+deb11u2 [123 kB]
                              Holen:140 http://deb.debian.org/debian bullseye/main amd64 libldap-common all 2.4.57+dfsg-3+deb11u1 [95,8 kB]
                              Holen:141 http://deb.debian.org/debian bullseye/main amd64 mariadb-common all 1:10.5.19-0+deb11u2 [37,0 kB]
                              Holen:142 http://deb.debian.org/debian bullseye/main amd64 libmariadb3 amd64 1:10.5.19-0+deb11u2 [176 kB]
                              Holen:143 http://deb.debian.org/debian bullseye/main amd64 libnss3 amd64 2:3.61-1+deb11u3 [1.305 kB]
                              Holen:144 http://deb.debian.org/debian bullseye/main amd64 libpixman-1-dev amd64 0.40.0-1.1~deb11u1 [561 kB]
                              Holen:145 http://deb.debian.org/debian bullseye/main amd64 libpixman-1-0 amd64 0.40.0-1.1~deb11u1 [543 kB]
                              Holen:146 http://deb.debian.org/debian bullseye/main amd64 libxpm4 amd64 1:3.5.12-1.1~deb11u1 [49,6 kB]
                              Holen:147 http://deb.debian.org/debian bullseye/main amd64 mokutil amd64 0.6.0-2~deb11u1 [26,6 kB]
                              Holen:148 http://deb.debian.org/debian bullseye/main amd64 publicsuffix all 20220811.1734-0+deb11u1 [127 kB]
                              Holen:149 http://deb.debian.org/debian bullseye/main amd64 shim-unsigned amd64 15.7-1~deb11u1 [439 kB]
                              Holen:150 http://deb.debian.org/debian bullseye/main amd64 shim-helpers-amd64-signed amd64 1+15.7+1~deb11u1 [301 kB]
                              Holen:151 http://deb.debian.org/debian bullseye/main amd64 shim-signed-common all 1.39~1+deb11u1+15.7-1~deb11u1 [13,8 kB]
                              Holen:152 http://deb.debian.org/debian bullseye/main amd64 shim-signed amd64 1.39~1+deb11u1+15.7-1~deb11u1 [327 kB]
                              Holen:153 http://deb.debian.org/debian bullseye/main amd64 sudo amd64 1.9.5p2-3+deb11u1 [1.061 kB]
                              Holen:154 http://deb.debian.org/debian bullseye/main amd64 unzip amd64 6.0-26+deb11u1 [172 kB]
                              Holen:155 http://security.debian.org/debian-security bullseye-security/main amd64 linux-libc-dev amd64 5.10.179-1 [1.618 kB]
                              Holen:156 http://security.debian.org/debian-security bullseye-security/main amd64 libx11-data all 2:1.7.2-1+deb11u1 [311 kB]
                              Holen:157 http://security.debian.org/debian-security bullseye-security/main amd64 libx11-dev amd64 2:1.7.2-1+deb11u1 [843 kB]
                              Holen:158 http://security.debian.org/debian-security bullseye-security/main amd64 libx11-6 amd64 2:1.7.2-1+deb11u1 [772 kB]
                              Holen:159 http://security.debian.org/debian-security bullseye-security/main amd64 libx11-xcb1 amd64 2:1.7.2-1+deb11u1 [203 kB]
                              Holen:160 http://security.debian.org/debian-security bullseye-security/main amd64 libwebp6 amd64 0.6.1-2.1+deb11u1 [258 kB]
                              Holen:161 http://security.debian.org/debian-security bullseye-security/main amd64 libwebpdemux2 amd64 0.6.1-2.1+deb11u1 [87,8 kB]
                              Holen:162 http://security.debian.org/debian-security bullseye-security/main amd64 libwebpmux3 amd64 0.6.1-2.1+deb11u1 [97,7 kB]
                              Holen:163 http://security.debian.org/debian-security bullseye-security/main amd64 libssl-dev amd64 1.1.1n-0+deb11u5 [1.815 kB]
                              Holen:164 http://security.debian.org/debian-security bullseye-security/main amd64 libssl1.1 amd64 1.1.1n-0+deb11u5 [1.559 kB]
                              Holen:165 http://security.debian.org/debian-security bullseye-security/main amd64 ffmpeg amd64 7:4.3.6-0+deb11u1 [1.599 kB]
                              Holen:166 http://security.debian.org/debian-security bullseye-security/main amd64 libavdevice58 amd64 7:4.3.6-0+deb11u1 [128 kB]
                              Holen:167 http://security.debian.org/debian-security bullseye-security/main amd64 libavfilter7 amd64 7:4.3.6-0+deb11u1 [1.300 kB]
                              Holen:168 http://security.debian.org/debian-security bullseye-security/main amd64 libswscale5 amd64 7:4.3.6-0+deb11u1 [211 kB]
                              Holen:169 http://security.debian.org/debian-security bullseye-security/main amd64 libavformat58 amd64 7:4.3.6-0+deb11u1 [1.056 kB]
                              Holen:170 http://security.debian.org/debian-security bullseye-security/main amd64 libavcodec58 amd64 7:4.3.6-0+deb11u1 [4.961 kB]
                              Holen:171 http://security.debian.org/debian-security bullseye-security/main amd64 libswresample3 amd64 7:4.3.6-0+deb11u1 [110 kB]
                              Holen:172 http://security.debian.org/debian-security bullseye-security/main amd64 libpostproc55 amd64 7:4.3.6-0+deb11u1 [108 kB]
                              Holen:173 http://security.debian.org/debian-security bullseye-security/main amd64 libavresample4 amd64 7:4.3.6-0+deb11u1 [106 kB]
                              Holen:174 http://security.debian.org/debian-security bullseye-security/main amd64 libavutil56 amd64 7:4.3.6-0+deb11u1 [312 kB]
                              Holen:175 http://security.debian.org/debian-security bullseye-security/main amd64 libssh-gcrypt-4 amd64 0.9.7-0+deb11u1 [220 kB]
                              Holen:176 http://security.debian.org/debian-security bullseye-security/main amd64 libpq5 amd64 13.11-0+deb11u1 [180 kB]
                              Holen:177 http://security.debian.org/debian-security bullseye-security/main amd64 linux-image-5.10.0-23-amd64 amd64 5.10.179-1 [55,6 MB]
                              Holen:178 http://security.debian.org/debian-security bullseye-security/main amd64 linux-image-amd64 amd64 5.10.179-1 [1.484 B]
                              Holen:179 http://security.debian.org/debian-security bullseye-security/main amd64 openssl amd64 1.1.1n-0+deb11u5 [854 kB]
                              Holen:180 https://packages.grafana.com/oss/deb stable/main amd64 grafana amd64 10.0.1 [83,4 MB]
                              Es wurden 269 MB in 17 s geholt (16,1 MB/s).
                              Changelogs werden gelesen... Fertig
                              Extrahiere Vorlagen aus Paketen: 100%
                              Vorkonfiguration der Pakete ...
                              (Lese Datenbank ... 73705 Dateien und Verzeichnisse sind derzeit installiert.)
                              Vorbereitung zum Entpacken von .../base-files_11.1+deb11u7_amd64.deb ...
                              Entpacken von base-files (11.1+deb11u7) über (11.1+deb11u3) ...
                              base-files (11.1+deb11u7) wird eingerichtet ...
                              Neue Version der Konfigurationsdatei /etc/debian_version wird installiert ...
                              Vorbereitung zum Entpacken von .../bash_5.1-2+deb11u1_amd64.deb ...
                              Entpacken von bash (5.1-2+deb11u1) über (5.1-2+b3) ...
                              bash (5.1-2+deb11u1) wird eingerichtet ...
                              update-alternatives: /usr/share/man/man7/bash-builtins.7.gz wird verwendet, um /usr/share/man/man7/builtins.7.gz (builtins.7.gz) im automatischen Modus bereitzustellen
                              (Lese Datenbank ... 73704 Dateien und Verzeichnisse sind derzeit installiert.)
                              Vorbereitung zum Entpacken von .../dpkg_1.20.12_amd64.deb ...
                              Entpacken von dpkg (1.20.12) über (1.20.9) ...
                              dpkg (1.20.12) wird eingerichtet ...
                              (Lese Datenbank ... 73713 Dateien und Verzeichnisse sind derzeit installiert.)
                              Vorbereitung zum Entpacken von .../grep_3.6-1+deb11u1_amd64.deb ...
                              Entpacken von grep (3.6-1+deb11u1) über (3.6-1) ...
                              grep (3.6-1+deb11u1) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../gzip_1.10-4+deb11u1_amd64.deb ...
                              Entpacken von gzip (1.10-4+deb11u1) über (1.10-4) ...
                              gzip (1.10-4+deb11u1) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../ncurses-bin_6.2+20201114-2+deb11u1_amd64.deb ...
                              Entpacken von ncurses-bin (6.2+20201114-2+deb11u1) über (6.2+20201114-2) ...
                              ncurses-bin (6.2+20201114-2+deb11u1) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libc-devtools_2.31-13+deb11u6_amd64.deb ...
                              Entpacken von libc-devtools (2.31-13+deb11u6) über (2.31-13+deb11u3) ...
                              Vorbereitung zum Entpacken von .../libc6-dev_2.31-13+deb11u6_amd64.deb ...
                              Entpacken von libc6-dev:amd64 (2.31-13+deb11u6) über (2.31-13+deb11u3) ...
                              Vorbereitung zum Entpacken von .../libc-dev-bin_2.31-13+deb11u6_amd64.deb ...
                              Entpacken von libc-dev-bin (2.31-13+deb11u6) über (2.31-13+deb11u3) ...
                              Vorbereitung zum Entpacken von .../linux-libc-dev_5.10.179-1_amd64.deb ...
                              Entpacken von linux-libc-dev:amd64 (5.10.179-1) über (5.10.106-1) ...
                              Vorbereitung zum Entpacken von .../libc6_2.31-13+deb11u6_amd64.deb ...
                              Entpacken von libc6:amd64 (2.31-13+deb11u6) über (2.31-13+deb11u3) ...
                              libc6:amd64 (2.31-13+deb11u6) wird eingerichtet ...
                              (Lese Datenbank ... 73714 Dateien und Verzeichnisse sind derzeit installiert.)
                              Vorbereitung zum Entpacken von .../libc-bin_2.31-13+deb11u6_amd64.deb ...
                              Entpacken von libc-bin (2.31-13+deb11u6) über (2.31-13+deb11u3) ...
                              libc-bin (2.31-13+deb11u6) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../ncurses-base_6.2+20201114-2+deb11u1_all.deb ...
                              Entpacken von ncurses-base (6.2+20201114-2+deb11u1) über (6.2+20201114-2) ...
                              ncurses-base (6.2+20201114-2+deb11u1) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libnss-systemd_247.3-7+deb11u2_amd64.deb ...
                              Entpacken von libnss-systemd:amd64 (247.3-7+deb11u2) über (247.3-7) ...
                              Vorbereitung zum Entpacken von .../libudev-dev_247.3-7+deb11u2_amd64.deb ...
                              Entpacken von libudev-dev:amd64 (247.3-7+deb11u2) über (247.3-7) ...
                              Vorbereitung zum Entpacken von .../libsystemd0_247.3-7+deb11u2_amd64.deb ...
                              Entpacken von libsystemd0:amd64 (247.3-7+deb11u2) über (247.3-7) ...
                              libsystemd0:amd64 (247.3-7+deb11u2) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../systemd-timesyncd_247.3-7+deb11u2_amd64.deb ...
                              Entpacken von systemd-timesyncd (247.3-7+deb11u2) über (247.3-7) ...
                              Vorbereitung zum Entpacken von .../libpam-systemd_247.3-7+deb11u2_amd64.deb ...
                              Entpacken von libpam-systemd:amd64 (247.3-7+deb11u2) über (247.3-7) ...
                              Vorbereitung zum Entpacken von .../systemd_247.3-7+deb11u2_amd64.deb ...
                              Entpacken von systemd (247.3-7+deb11u2) über (247.3-7) ...
                              Vorbereitung zum Entpacken von .../udev_247.3-7+deb11u2_amd64.deb ...
                              Entpacken von udev (247.3-7+deb11u2) über (247.3-7) ...
                              Vorbereitung zum Entpacken von .../libudev1_247.3-7+deb11u2_amd64.deb ...
                              Entpacken von libudev1:amd64 (247.3-7+deb11u2) über (247.3-7) ...
                              libudev1:amd64 (247.3-7+deb11u2) wird eingerichtet ...
                              systemd (247.3-7+deb11u2) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../0-systemd-sysv_247.3-7+deb11u2_amd64.deb ...
                              Entpacken von systemd-sysv (247.3-7+deb11u2) über (247.3-7) ...
                              Vorbereitung zum Entpacken von .../1-libdbus-1-dev_1.12.24-0+deb11u1_amd64.deb ...
                              Entpacken von libdbus-1-dev:amd64 (1.12.24-0+deb11u1) über (1.12.20-2) ...
                              Vorbereitung zum Entpacken von .../2-dbus_1.12.24-0+deb11u1_amd64.deb ...
                              Entpacken von dbus (1.12.24-0+deb11u1) über (1.12.20-2) ...
                              Vorbereitung zum Entpacken von .../3-libdbus-1-3_1.12.24-0+deb11u1_amd64.deb ...
                              Entpacken von libdbus-1-3:amd64 (1.12.24-0+deb11u1) über (1.12.20-2) ...
                              Vorbereitung zum Entpacken von .../4-libexpat1-dev_2.2.10-2+deb11u5_amd64.deb ...
                              Entpacken von libexpat1-dev:amd64 (2.2.10-2+deb11u5) über (2.2.10-2+deb11u3) ...
                              Vorbereitung zum Entpacken von .../5-libexpat1_2.2.10-2+deb11u5_amd64.deb ...
                              Entpacken von libexpat1:amd64 (2.2.10-2+deb11u5) über (2.2.10-2+deb11u3) ...
                              Vorbereitung zum Entpacken von .../6-libtasn1-6_4.16.0-2+deb11u1_amd64.deb ...
                              Entpacken von libtasn1-6:amd64 (4.16.0-2+deb11u1) über (4.16.0-2) ...
                              libtasn1-6:amd64 (4.16.0-2+deb11u1) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libgnutls30_3.7.1-5+deb11u3_amd64.deb ...
                              Entpacken von libgnutls30:amd64 (3.7.1-5+deb11u3) über (3.7.1-5) ...
                              libgnutls30:amd64 (3.7.1-5+deb11u3) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../nftables_0.9.8-3.1+deb11u1_amd64.deb ...
                              Entpacken von nftables (0.9.8-3.1+deb11u1) über (0.9.8-3.1) ...
                              Vorbereitung zum Entpacken von .../libnftables1_0.9.8-3.1+deb11u1_amd64.deb ...
                              Entpacken von libnftables1:amd64 (0.9.8-3.1+deb11u1) über (0.9.8-3.1) ...
                              Vorbereitung zum Entpacken von .../zlib1g-dev_1%3a1.2.11.dfsg-2+deb11u2_amd64.deb ...
                              Entpacken von zlib1g-dev:amd64 (1:1.2.11.dfsg-2+deb11u2) über (1:1.2.11.dfsg-2+deb11u1) ...
                              Vorbereitung zum Entpacken von .../zlib1g_1%3a1.2.11.dfsg-2+deb11u2_amd64.deb ...
                              Entpacken von zlib1g:amd64 (1:1.2.11.dfsg-2+deb11u2) über (1:1.2.11.dfsg-2+deb11u1) ...
                              zlib1g:amd64 (1:1.2.11.dfsg-2+deb11u2) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../00-rsyslog_8.2102.0-2+deb11u1_amd64.deb ...
                              Entpacken von rsyslog (8.2102.0-2+deb11u1) über (8.2102.0-2) ...
                              Vorbereitung zum Entpacken von .../01-libmagick++-6.q16-dev_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                              Entpacken von libmagick++-6.q16-dev:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                              Vorbereitung zum Entpacken von .../02-libmagick++-dev_8%3a6.9.11.60+dfsg-1.3+deb11u1_all.deb ...
                              Entpacken von libmagick++-dev (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                              Vorbereitung zum Entpacken von .../03-libmagick++-6-headers_8%3a6.9.11.60+dfsg-1.3+deb11u1_all.deb ...
                              Entpacken von libmagick++-6-headers (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                              Vorbereitung zum Entpacken von .../04-libmagickwand-6.q16-dev_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                              Entpacken von libmagickwand-6.q16-dev:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                              Vorbereitung zum Entpacken von .../05-libmagickwand-6-headers_8%3a6.9.11.60+dfsg-1.3+deb11u1_all.deb ...
                              Entpacken von libmagickwand-6-headers (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                              Vorbereitung zum Entpacken von .../06-libmagickcore-6.q16-dev_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                              Entpacken von libmagickcore-6.q16-dev:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                              Vorbereitung zum Entpacken von .../07-libmagickcore-6-arch-config_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                              Entpacken von libmagickcore-6-arch-config:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                              Vorbereitung zum Entpacken von .../08-libmagickcore-6-headers_8%3a6.9.11.60+dfsg-1.3+deb11u1_all.deb ...
                              Entpacken von libmagickcore-6-headers (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                              Vorbereitung zum Entpacken von .../09-imagemagick-6-common_8%3a6.9.11.60+dfsg-1.3+deb11u1_all.deb ...
                              Entpacken von imagemagick-6-common (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                              Vorbereitung zum Entpacken von .../10-libx11-data_2%3a1.7.2-1+deb11u1_all.deb ...
                              Entpacken von libx11-data (2:1.7.2-1+deb11u1) über (2:1.7.2-1) ...
                              Vorbereitung zum Entpacken von .../11-libx11-dev_2%3a1.7.2-1+deb11u1_amd64.deb ...
                              Entpacken von libx11-dev:amd64 (2:1.7.2-1+deb11u1) über (2:1.7.2-1) ...
                              Vorbereitung zum Entpacken von .../12-libx11-6_2%3a1.7.2-1+deb11u1_amd64.deb ...
                              Entpacken von libx11-6:amd64 (2:1.7.2-1+deb11u1) über (2:1.7.2-1) ...
                              Vorbereitung zum Entpacken von .../13-libx11-xcb1_2%3a1.7.2-1+deb11u1_amd64.deb ...
                              Entpacken von libx11-xcb1:amd64 (2:1.7.2-1+deb11u1) über (2:1.7.2-1) ...
                              Vorbereitung zum Entpacken von .../14-libmagickwand-6.q16-6_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                              Entpacken von libmagickwand-6.q16-6:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                              Vorbereitung zum Entpacken von .../15-libopenexr-dev_2.5.4-2+deb11u1_amd64.deb ...
                              Entpacken von libopenexr-dev (2.5.4-2+deb11u1) über (2.5.4-2) ...
                              Vorbereitung zum Entpacken von .../16-libopenexr25_2.5.4-2+deb11u1_amd64.deb ...
                              Entpacken von libopenexr25:amd64 (2.5.4-2+deb11u1) über (2.5.4-2) ...
                              Vorbereitung zum Entpacken von .../17-libxml2-dev_2.9.10+dfsg-6.7+deb11u4_amd64.deb ...
                              Entpacken von libxml2-dev:amd64 (2.9.10+dfsg-6.7+deb11u4) über (2.9.10+dfsg-6.7+deb11u1) ...
                              Vorbereitung zum Entpacken von .../18-liblzma-dev_5.2.5-2.1~deb11u1_amd64.deb ...
                              Entpacken von liblzma-dev:amd64 (5.2.5-2.1~deb11u1) über (5.2.5-2) ...
                              Vorbereitung zum Entpacken von .../19-liblzma5_5.2.5-2.1~deb11u1_amd64.deb ...
                              Entpacken von liblzma5:amd64 (5.2.5-2.1~deb11u1) über (5.2.5-2) ...
                              liblzma5:amd64 (5.2.5-2.1~deb11u1) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../00-libxml2_2.9.10+dfsg-6.7+deb11u4_amd64.deb ...
                              Entpacken von libxml2:amd64 (2.9.10+dfsg-6.7+deb11u4) über (2.9.10+dfsg-6.7+deb11u1) ...
                              Vorbereitung zum Entpacken von .../01-libmagickcore-6.q16-6-extra_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                              Entpacken von libmagickcore-6.q16-6-extra:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                              Vorbereitung zum Entpacken von .../02-libfreetype6-dev_2.10.4+dfsg-1+deb11u1_amd64.deb ...
                              Entpacken von libfreetype6-dev:amd64 (2.10.4+dfsg-1+deb11u1) über (2.10.4+dfsg-1) ...
                              Vorbereitung zum Entpacken von .../03-libfreetype-dev_2.10.4+dfsg-1+deb11u1_amd64.deb ...
                              Entpacken von libfreetype-dev:amd64 (2.10.4+dfsg-1+deb11u1) über (2.10.4+dfsg-1) ...
                              Vorbereitung zum Entpacken von .../04-libfreetype6_2.10.4+dfsg-1+deb11u1_amd64.deb ...
                              Entpacken von libfreetype6:amd64 (2.10.4+dfsg-1+deb11u1) über (2.10.4+dfsg-1) ...
                              Vorbereitung zum Entpacken von .../05-libwebp6_0.6.1-2.1+deb11u1_amd64.deb ...
                              Entpacken von libwebp6:amd64 (0.6.1-2.1+deb11u1) über (0.6.1-2.1) ...
                              Vorbereitung zum Entpacken von .../06-libtiff-dev_4.2.0-1+deb11u4_amd64.deb ...
                              Entpacken von libtiff-dev:amd64 (4.2.0-1+deb11u4) über (4.2.0-1+deb11u1) ...
                              Vorbereitung zum Entpacken von .../07-libtiff5_4.2.0-1+deb11u4_amd64.deb ...
                              Entpacken von libtiff5:amd64 (4.2.0-1+deb11u4) über (4.2.0-1+deb11u1) ...
                              Vorbereitung zum Entpacken von .../08-libtiffxx5_4.2.0-1+deb11u4_amd64.deb ...
                              Entpacken von libtiffxx5:amd64 (4.2.0-1+deb11u4) über (4.2.0-1+deb11u1) ...
                              Vorbereitung zum Entpacken von .../09-libwebpdemux2_0.6.1-2.1+deb11u1_amd64.deb ...
                              Entpacken von libwebpdemux2:amd64 (0.6.1-2.1+deb11u1) über (0.6.1-2.1) ...
                              Vorbereitung zum Entpacken von .../10-libwebpmux3_0.6.1-2.1+deb11u1_amd64.deb ...
                              Entpacken von libwebpmux3:amd64 (0.6.1-2.1+deb11u1) über (0.6.1-2.1) ...
                              Vorbereitung zum Entpacken von .../11-libmagickcore-6.q16-6_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                              Entpacken von libmagickcore-6.q16-6:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                              Vorbereitung zum Entpacken von .../12-libmagick++-6.q16-8_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                              Entpacken von libmagick++-6.q16-8:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                              Vorbereitung zum Entpacken von .../13-libwbclient0_2%3a4.13.13+dfsg-1~deb11u5_amd64.deb ...
                              Entpacken von libwbclient0:amd64 (2:4.13.13+dfsg-1~deb11u5) über (2:4.13.13+dfsg-1~deb11u3) ...
                              Vorbereitung zum Entpacken von .../14-debian-archive-keyring_2021.1.1+deb11u1_all.deb ...
                              Entpacken von debian-archive-keyring (2021.1.1+deb11u1) über (2021.1.1) ...
                              debian-archive-keyring (2021.1.1+deb11u1) wird eingerichtet ...
                              Removing obsolete conffile /etc/apt/trusted.gpg.d/debian-archive-stretch-automatic.gpg ...
                              Removing obsolete conffile /etc/apt/trusted.gpg.d/debian-archive-stretch-security-automatic.gpg ...
                              Removing obsolete conffile /etc/apt/trusted.gpg.d/debian-archive-stretch-stable.gpg ...
                              Vorbereitung zum Entpacken von .../libk5crypto3_1.18.3-6+deb11u3_amd64.deb ...
                              Entpacken von libk5crypto3:amd64 (1.18.3-6+deb11u3) über (1.18.3-6+deb11u1) ...
                              libk5crypto3:amd64 (1.18.3-6+deb11u3) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libkrb5support0_1.18.3-6+deb11u3_amd64.deb ...
                              Entpacken von libkrb5support0:amd64 (1.18.3-6+deb11u3) über (1.18.3-6+deb11u1) ...
                              libkrb5support0:amd64 (1.18.3-6+deb11u3) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libkrb5-3_1.18.3-6+deb11u3_amd64.deb ...
                              Entpacken von libkrb5-3:amd64 (1.18.3-6+deb11u3) über (1.18.3-6+deb11u1) ...
                              libkrb5-3:amd64 (1.18.3-6+deb11u3) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libgssapi-krb5-2_1.18.3-6+deb11u3_amd64.deb ...
                              Entpacken von libgssapi-krb5-2:amd64 (1.18.3-6+deb11u3) über (1.18.3-6+deb11u1) ...
                              libgssapi-krb5-2:amd64 (1.18.3-6+deb11u3) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libssl-dev_1.1.1n-0+deb11u5_amd64.deb ...
                              Entpacken von libssl-dev:amd64 (1.1.1n-0+deb11u5) über (1.1.1n-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../libssl1.1_1.1.1n-0+deb11u5_amd64.deb ...
                              Entpacken von libssl1.1:amd64 (1.1.1n-0+deb11u5) über (1.1.1n-0+deb11u1) ...
                              libssl1.1:amd64 (1.1.1n-0+deb11u5) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libpcre2-dev_10.36-2+deb11u1_amd64.deb ...
                              Entpacken von libpcre2-dev:amd64 (10.36-2+deb11u1) über (10.36-2) ...
                              Vorbereitung zum Entpacken von .../libpcre2-16-0_10.36-2+deb11u1_amd64.deb ...
                              Entpacken von libpcre2-16-0:amd64 (10.36-2+deb11u1) über (10.36-2) ...
                              Vorbereitung zum Entpacken von .../libpcre2-32-0_10.36-2+deb11u1_amd64.deb ...
                              Entpacken von libpcre2-32-0:amd64 (10.36-2+deb11u1) über (10.36-2) ...
                              Vorbereitung zum Entpacken von .../libpcre2-posix2_10.36-2+deb11u1_amd64.deb ...
                              Entpacken von libpcre2-posix2:amd64 (10.36-2+deb11u1) über (10.36-2) ...
                              Vorbereitung zum Entpacken von .../libpcre2-8-0_10.36-2+deb11u1_amd64.deb ...
                              Entpacken von libpcre2-8-0:amd64 (10.36-2+deb11u1) über (10.36-2) ...
                              libpcre2-8-0:amd64 (10.36-2+deb11u1) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libncurses6_6.2+20201114-2+deb11u1_amd64.deb ...
                              Entpacken von libncurses6:amd64 (6.2+20201114-2+deb11u1) über (6.2+20201114-2) ...
                              Vorbereitung zum Entpacken von .../libncursesw6_6.2+20201114-2+deb11u1_amd64.deb ...
                              Entpacken von libncursesw6:amd64 (6.2+20201114-2+deb11u1) über (6.2+20201114-2) ...
                              Vorbereitung zum Entpacken von .../libtinfo6_6.2+20201114-2+deb11u1_amd64.deb ...
                              Entpacken von libtinfo6:amd64 (6.2+20201114-2+deb11u1) über (6.2+20201114-2) ...
                              libtinfo6:amd64 (6.2+20201114-2+deb11u1) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libtirpc-common_1.3.1-1+deb11u1_all.deb ...
                              Entpacken von libtirpc-common (1.3.1-1+deb11u1) über (1.3.1-1) ...
                              libtirpc-common (1.3.1-1+deb11u1) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libtirpc-dev_1.3.1-1+deb11u1_amd64.deb ...
                              Entpacken von libtirpc-dev:amd64 (1.3.1-1+deb11u1) über (1.3.1-1) ...
                              Vorbereitung zum Entpacken von .../libtirpc3_1.3.1-1+deb11u1_amd64.deb ...
                              Entpacken von libtirpc3:amd64 (1.3.1-1+deb11u1) über (1.3.1-1) ...
                              libtirpc3:amd64 (1.3.1-1+deb11u1) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../00-tzdata_2021a-1+deb11u10_all.deb ...
                              Entpacken von tzdata (2021a-1+deb11u10) über (2021a-1+deb11u3) ...
                              Vorbereitung zum Entpacken von .../01-isc-dhcp-client_4.4.1-2.3+deb11u2_amd64.deb ...
                              Entpacken von isc-dhcp-client (4.4.1-2.3+deb11u2) über (4.4.1-2.3) ...
                              Vorbereitung zum Entpacken von .../02-isc-dhcp-common_4.4.1-2.3+deb11u2_amd64.deb ...
                              Entpacken von isc-dhcp-common (4.4.1-2.3+deb11u2) über (4.4.1-2.3) ...
                              Vorbereitung zum Entpacken von .../03-logrotate_3.18.0-2+deb11u1_amd64.deb ...
                              Entpacken von logrotate (3.18.0-2+deb11u1) über (3.18.0-2) ...
                              Vorbereitung zum Entpacken von .../04-nano_5.4-2+deb11u2_amd64.deb ...
                              Entpacken von nano (5.4-2+deb11u2) über (5.4-2) ...
                              Vorbereitung zum Entpacken von .../05-bind9-dnsutils_1%3a9.16.37-1~deb11u1_amd64.deb ...
                              Entpacken von bind9-dnsutils (1:9.16.37-1~deb11u1) über (1:9.16.27-1~deb11u1) ...
                              Vorbereitung zum Entpacken von .../06-bind9-libs_1%3a9.16.37-1~deb11u1_amd64.deb ...
                              Entpacken von bind9-libs:amd64 (1:9.16.37-1~deb11u1) über (1:9.16.27-1~deb11u1) ...
                              Vorbereitung zum Entpacken von .../07-bind9-host_1%3a9.16.37-1~deb11u1_amd64.deb ...
                              Entpacken von bind9-host (1:9.16.37-1~deb11u1) über (1:9.16.27-1~deb11u1) ...
                              Vorbereitung zum Entpacken von .../08-krb5-locales_1.18.3-6+deb11u3_all.deb ...
                              Entpacken von krb5-locales (1.18.3-6+deb11u3) über (1.18.3-6+deb11u1) ...
                              Vorbereitung zum Entpacken von .../09-libc-l10n_2.31-13+deb11u6_all.deb ...
                              Entpacken von libc-l10n (2.31-13+deb11u6) über (2.31-13+deb11u3) ...
                              Vorbereitung zum Entpacken von .../10-locales_2.31-13+deb11u6_all.deb ...
                              Entpacken von locales (2.31-13+deb11u6) über (2.31-13+deb11u3) ...
                              Vorbereitung zum Entpacken von .../11-ncurses-term_6.2+20201114-2+deb11u1_all.deb ...
                              Entpacken von ncurses-term (6.2+20201114-2+deb11u1) über (6.2+20201114-2) ...
                              Vorbereitung zum Entpacken von .../12-openssh-sftp-server_1%3a8.4p1-5+deb11u1_amd64.deb ...
                              Entpacken von openssh-sftp-server (1:8.4p1-5+deb11u1) über (1:8.4p1-5) ...
                              Vorbereitung zum Entpacken von .../13-openssh-server_1%3a8.4p1-5+deb11u1_amd64.deb ...
                              Entpacken von openssh-server (1:8.4p1-5+deb11u1) über (1:8.4p1-5) ...
                              Vorbereitung zum Entpacken von .../14-git-man_1%3a2.30.2-1+deb11u2_all.deb ...
                              Entpacken von git-man (1:2.30.2-1+deb11u2) über (1:2.30.2-1) ...
                              Vorbereitung zum Entpacken von .../15-libldap-2.4-2_2.4.57+dfsg-3+deb11u1_amd64.deb ...
                              Entpacken von libldap-2.4-2:amd64 (2.4.57+dfsg-3+deb11u1) über (2.4.57+dfsg-3) ...
                              Vorbereitung zum Entpacken von .../16-libcurl3-gnutls_7.74.0-1.3+deb11u7_amd64.deb ...
                              Entpacken von libcurl3-gnutls:amd64 (7.74.0-1.3+deb11u7) über (7.74.0-1.3+deb11u1) ...
                              Vorbereitung zum Entpacken von .../17-git_1%3a2.30.2-1+deb11u2_amd64.deb ...
                              Entpacken von git (1:2.30.2-1+deb11u2) über (1:2.30.2-1) ...
                              Vorbereitung zum Entpacken von .../18-openssh-client_1%3a8.4p1-5+deb11u1_amd64.deb ...
                              Entpacken von openssh-client (1:8.4p1-5+deb11u1) über (1:8.4p1-5) ...
                              Vorbereitung zum Entpacken von .../19-traceroute_1%3a2.1.0-2+deb11u1_amd64.deb ...
                              Entpacken von traceroute (1:2.1.0-2+deb11u1) über (1:2.1.0-2+b1) ...
                              Vorbereitung zum Entpacken von .../20-xz-utils_5.2.5-2.1~deb11u1_amd64.deb ...
                              Entpacken von xz-utils (5.2.5-2.1~deb11u1) über (5.2.5-2) ...
                              Vorbereitung zum Entpacken von .../21-libatspi2.0-0_2.38.0-4+deb11u1_amd64.deb ...
                              Entpacken von libatspi2.0-0:amd64 (2.38.0-4+deb11u1) über (2.38.0-4) ...
                              Vorbereitung zum Entpacken von .../22-at-spi2-core_2.38.0-4+deb11u1_amd64.deb ...
                              Entpacken von at-spi2-core (2.38.0-4+deb11u1) über (2.38.0-4) ...
                              Vorbereitung zum Entpacken von .../23-cifs-utils_2%3a6.11-3.1+deb11u1_amd64.deb ...
                              Entpacken von cifs-utils (2:6.11-3.1+deb11u1) über (2:6.11-3.1) ...
                              Vorbereitung zum Entpacken von .../24-libcurl4-openssl-dev_7.74.0-1.3+deb11u7_amd64.deb ...
                              Entpacken von libcurl4-openssl-dev:amd64 (7.74.0-1.3+deb11u7) über (7.74.0-1.3+deb11u5) ...
                              Vorbereitung zum Entpacken von .../25-curl_7.74.0-1.3+deb11u7_amd64.deb ...
                              Entpacken von curl (7.74.0-1.3+deb11u7) über (7.74.0-1.3+deb11u5) ...
                              Vorbereitung zum Entpacken von .../26-libcurl4_7.74.0-1.3+deb11u7_amd64.deb ...
                              Entpacken von libcurl4:amd64 (7.74.0-1.3+deb11u7) über (7.74.0-1.3+deb11u5) ...
                              Vorbereitung zum Entpacken von .../27-dbus-user-session_1.12.24-0+deb11u1_amd64.deb ...
                              Entpacken von dbus-user-session (1.12.24-0+deb11u1) über (1.12.20-2) ...
                              Vorbereitung zum Entpacken von .../28-distro-info-data_0.51+deb11u3_all.deb ...
                              Entpacken von distro-info-data (0.51+deb11u3) über (0.51+deb11u1) ...
                              Vorbereitung zum Entpacken von .../29-dpkg-dev_1.20.12_all.deb ...
                              Entpacken von dpkg-dev (1.20.12) über (1.20.9) ...
                              Vorbereitung zum Entpacken von .../30-libdpkg-perl_1.20.12_all.deb ...
                              Entpacken von libdpkg-perl (1.20.12) über (1.20.9) ...
                              Vorbereitung zum Entpacken von .../31-ffmpeg_7%3a4.3.6-0+deb11u1_amd64.deb ...
                              Entpacken von ffmpeg (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../32-libavdevice58_7%3a4.3.6-0+deb11u1_amd64.deb ...
                              Entpacken von libavdevice58:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../33-libavfilter7_7%3a4.3.6-0+deb11u1_amd64.deb ...
                              Entpacken von libavfilter7:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../34-libswscale5_7%3a4.3.6-0+deb11u1_amd64.deb ...
                              Entpacken von libswscale5:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../35-libavformat58_7%3a4.3.6-0+deb11u1_amd64.deb ...
                              Entpacken von libavformat58:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../36-libavcodec58_7%3a4.3.6-0+deb11u1_amd64.deb ...
                              Entpacken von libavcodec58:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../37-libswresample3_7%3a4.3.6-0+deb11u1_amd64.deb ...
                              Entpacken von libswresample3:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../38-libpostproc55_7%3a4.3.6-0+deb11u1_amd64.deb ...
                              Entpacken von libpostproc55:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../39-libavresample4_7%3a4.3.6-0+deb11u1_amd64.deb ...
                              Entpacken von libavresample4:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../40-libavutil56_7%3a4.3.6-0+deb11u1_amd64.deb ...
                              Entpacken von libavutil56:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../41-libsdl2-2.0-0_2.0.14+dfsg2-3+deb11u1_amd64.deb ...
                              Entpacken von libsdl2-2.0-0:amd64 (2.0.14+dfsg2-3+deb11u1) über (2.0.14+dfsg2-3) ...
                              Vorbereitung zum Entpacken von .../42-libfribidi-dev_1.0.8-2+deb11u1_amd64.deb ...
                              Entpacken von libfribidi-dev:amd64 (1.0.8-2+deb11u1) über (1.0.8-2) ...
                              Vorbereitung zum Entpacken von .../43-libfribidi0_1.0.8-2+deb11u1_amd64.deb ...
                              Entpacken von libfribidi0:amd64 (1.0.8-2+deb11u1) über (1.0.8-2) ...
                              Vorbereitung zum Entpacken von .../44-libbluray2_1%3a1.2.1-4+deb11u2_amd64.deb ...
                              Entpacken von libbluray2:amd64 (1:1.2.1-4+deb11u2) über (1:1.2.1-4+deb11u1) ...
                              Vorbereitung zum Entpacken von .../45-libssh-gcrypt-4_0.9.7-0+deb11u1_amd64.deb ...
                              Entpacken von libssh-gcrypt-4:amd64 (0.9.7-0+deb11u1) über (0.9.5-1+deb11u1) ...
                              Vorbereitung zum Entpacken von .../46-ghostscript_9.53.3~dfsg-7+deb11u4_amd64.deb ...
                              Entpacken von ghostscript (9.53.3~dfsg-7+deb11u4) über (9.53.3~dfsg-7+deb11u2) ...
                              Vorbereitung zum Entpacken von .../47-libgs9_9.53.3~dfsg-7+deb11u4_amd64.deb ...
                              Entpacken von libgs9:amd64 (9.53.3~dfsg-7+deb11u4) über (9.53.3~dfsg-7+deb11u2) ...
                              Vorbereitung zum Entpacken von .../48-libgs9-common_9.53.3~dfsg-7+deb11u4_all.deb ...
                              Entpacken von libgs9-common (9.53.3~dfsg-7+deb11u4) über (9.53.3~dfsg-7+deb11u2) ...
                              Vorbereitung zum Entpacken von .../49-libavahi-compat-libdnssd-dev_0.8-5+deb11u2_amd64.deb ...
                              Entpacken von libavahi-compat-libdnssd-dev:amd64 (0.8-5+deb11u2) über (0.8-5) ...
                              Vorbereitung zum Entpacken von .../50-libavahi-compat-libdnssd1_0.8-5+deb11u2_amd64.deb ...
                              Entpacken von libavahi-compat-libdnssd1:amd64 (0.8-5+deb11u2) über (0.8-5) ...
                              Vorbereitung zum Entpacken von .../51-libavahi-client-dev_0.8-5+deb11u2_amd64.deb ...
                              Entpacken von libavahi-client-dev:amd64 (0.8-5+deb11u2) über (0.8-5) ...
                              Vorbereitung zum Entpacken von .../52-libavahi-client3_0.8-5+deb11u2_amd64.deb ...
                              Entpacken von libavahi-client3:amd64 (0.8-5+deb11u2) über (0.8-5) ...
                              Vorbereitung zum Entpacken von .../53-libavahi-common-dev_0.8-5+deb11u2_amd64.deb ...
                              Entpacken von libavahi-common-dev:amd64 (0.8-5+deb11u2) über (0.8-5) ...
                              Vorbereitung zum Entpacken von .../54-libavahi-common3_0.8-5+deb11u2_amd64.deb ...
                              Entpacken von libavahi-common3:amd64 (0.8-5+deb11u2) über (0.8-5) ...
                              Vorbereitung zum Entpacken von .../55-libavahi-common-data_0.8-5+deb11u2_amd64.deb ...
                              Entpacken von libavahi-common-data:amd64 (0.8-5+deb11u2) über (0.8-5) ...
                              Vorbereitung zum Entpacken von .../56-libcups2_2.3.3op2-3+deb11u2_amd64.deb ...
                              Entpacken von libcups2:amd64 (2.3.3op2-3+deb11u2) über (2.3.3op2-3+deb11u1) ...
                              Vorbereitung zum Entpacken von .../57-libgdk-pixbuf-2.0-dev_2.42.2+dfsg-1+deb11u1_amd64.deb ...
                              Entpacken von libgdk-pixbuf-2.0-dev:amd64 (2.42.2+dfsg-1+deb11u1) über (2.42.2+dfsg-1) ...
                              Vorbereitung zum Entpacken von .../58-libgdk-pixbuf-2.0-0_2.42.2+dfsg-1+deb11u1_amd64.deb ...
                              Entpacken von libgdk-pixbuf-2.0-0:amd64 (2.42.2+dfsg-1+deb11u1) über (2.42.2+dfsg-1) ...
                              Vorbereitung zum Entpacken von .../59-libgdk-pixbuf2.0-common_2.42.2+dfsg-1+deb11u1_all.deb ...
                              Entpacken von libgdk-pixbuf2.0-common (2.42.2+dfsg-1+deb11u1) über (2.42.2+dfsg-1) ...
                              Vorbereitung zum Entpacken von .../60-libgdk-pixbuf2.0-bin_2.42.2+dfsg-1+deb11u1_amd64.deb ...
                              Entpacken von libgdk-pixbuf2.0-bin (2.42.2+dfsg-1+deb11u1) über (2.42.2+dfsg-1) ...
                              Vorbereitung zum Entpacken von .../61-gir1.2-gdkpixbuf-2.0_2.42.2+dfsg-1+deb11u1_amd64.deb ...
                              Entpacken von gir1.2-gdkpixbuf-2.0:amd64 (2.42.2+dfsg-1+deb11u1) über (2.42.2+dfsg-1) ...
                              Vorbereitung zum Entpacken von .../62-grafana_10.0.1_amd64.deb ...
                              Entpacken von grafana (10.0.1) über (9.3.6) ...
                              Vorbereitung zum Entpacken von .../63-grub-efi-amd64_2.06-3~deb11u5_amd64.deb ...
                              Entpacken von grub-efi-amd64 (2.06-3~deb11u5) über (2.04-20) ...
                              Vorbereitung zum Entpacken von .../64-grub2-common_2.06-3~deb11u5_amd64.deb ...
                              Entpacken von grub2-common (2.06-3~deb11u5) über (2.04-20) ...
                              Vorbereitung zum Entpacken von .../65-grub-efi-amd64-bin_2.06-3~deb11u5_amd64.deb ...
                              Entpacken von grub-efi-amd64-bin (2.06-3~deb11u5) über (2.04-20) ...
                              Vorbereitung zum Entpacken von .../66-grub-common_2.06-3~deb11u5_amd64.deb ...
                              Entpacken von grub-common (2.06-3~deb11u5) über (2.04-20) ...
                              Vorbereitung zum Entpacken von .../67-grub-efi-amd64-signed_1+2.06+3~deb11u5_amd64.deb ...
                              Entpacken von grub-efi-amd64-signed (1+2.06+3~deb11u5) über (1+2.04+20) ...
                              Vorbereitung zum Entpacken von .../68-gtk-update-icon-cache_3.24.24-4+deb11u3_amd64.deb ...
                              Entpacken von gtk-update-icon-cache (3.24.24-4+deb11u3) über (3.24.24-4+deb11u2) ...
                              Vorbereitung zum Entpacken von .../69-libde265-0_1.0.11-0+deb11u1_amd64.deb ...
                              Entpacken von libde265-0:amd64 (1.0.11-0+deb11u1) über (1.0.8-1) ...
                              Vorbereitung zum Entpacken von .../70-libgtk-3-common_3.24.24-4+deb11u3_all.deb ...
                              Entpacken von libgtk-3-common (3.24.24-4+deb11u3) über (3.24.24-4+deb11u2) ...
                              Vorbereitung zum Entpacken von .../71-libgtk-3-0_3.24.24-4+deb11u3_amd64.deb ...
                              Entpacken von libgtk-3-0:amd64 (3.24.24-4+deb11u3) über (3.24.24-4+deb11u2) ...
                              Vorbereitung zum Entpacken von .../72-libgtk-3-bin_3.24.24-4+deb11u3_amd64.deb ...
                              Entpacken von libgtk-3-bin (3.24.24-4+deb11u3) über (3.24.24-4+deb11u2) ...
                              Vorbereitung zum Entpacken von .../73-libhttp-daemon-perl_6.12-1+deb11u1_all.deb ...
                              Entpacken von libhttp-daemon-perl (6.12-1+deb11u1) über (6.12-1) ...
                              Vorbereitung zum Entpacken von .../74-libksba8_1.5.0-3+deb11u2_amd64.deb ...
                              Entpacken von libksba8:amd64 (1.5.0-3+deb11u2) über (1.5.0-3) ...
                              Vorbereitung zum Entpacken von .../75-libldap-common_2.4.57+dfsg-3+deb11u1_all.deb ...
                              Entpacken von libldap-common (2.4.57+dfsg-3+deb11u1) über (2.4.57+dfsg-3) ...
                              Vorbereitung zum Entpacken von .../76-mariadb-common_1%3a10.5.19-0+deb11u2_all.deb ...
                              Entpacken von mariadb-common (1:10.5.19-0+deb11u2) über (1:10.5.15-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../77-libmariadb3_1%3a10.5.19-0+deb11u2_amd64.deb ...
                              Entpacken von libmariadb3:amd64 (1:10.5.19-0+deb11u2) über (1:10.5.15-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../78-libnss3_2%3a3.61-1+deb11u3_amd64.deb ...
                              Entpacken von libnss3:amd64 (2:3.61-1+deb11u3) über (2:3.61-1+deb11u2) ...
                              Vorbereitung zum Entpacken von .../79-libpixman-1-dev_0.40.0-1.1~deb11u1_amd64.deb ...
                              Entpacken von libpixman-1-dev:amd64 (0.40.0-1.1~deb11u1) über (0.40.0-1) ...
                              Vorbereitung zum Entpacken von .../80-libpixman-1-0_0.40.0-1.1~deb11u1_amd64.deb ...
                              Entpacken von libpixman-1-0:amd64 (0.40.0-1.1~deb11u1) über (0.40.0-1) ...
                              Vorbereitung zum Entpacken von .../81-libpq5_13.11-0+deb11u1_amd64.deb ...
                              Entpacken von libpq5:amd64 (13.11-0+deb11u1) über (13.5-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../82-libxpm4_1%3a3.5.12-1.1~deb11u1_amd64.deb ...
                              Entpacken von libxpm4:amd64 (1:3.5.12-1.1~deb11u1) über (1:3.5.12-1) ...
                              Vormals nicht ausgewähltes Paket linux-image-5.10.0-23-amd64 wird gewählt.
                              Vorbereitung zum Entpacken von .../83-linux-image-5.10.0-23-amd64_5.10.179-1_amd64.deb ...
                              Entpacken von linux-image-5.10.0-23-amd64 (5.10.179-1) ...
                              Vorbereitung zum Entpacken von .../84-linux-image-amd64_5.10.179-1_amd64.deb ...
                              Entpacken von linux-image-amd64 (5.10.179-1) über (5.10.106-1) ...
                              Vorbereitung zum Entpacken von .../85-mokutil_0.6.0-2~deb11u1_amd64.deb ...
                              Entpacken von mokutil (0.6.0-2~deb11u1) über (0.3.0+1538710437.fb6250f-1+b1) ...
                              Vorbereitung zum Entpacken von .../86-nodejs_16.20.1-deb-1nodesource1_amd64.deb ...
                              Entpacken von nodejs (16.20.1-deb-1nodesource1) über (16.17.1-deb-1nodesource1) ...
                              Vorbereitung zum Entpacken von .../87-openssl_1.1.1n-0+deb11u5_amd64.deb ...
                              Entpacken von openssl (1.1.1n-0+deb11u5) über (1.1.1n-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../88-publicsuffix_20220811.1734-0+deb11u1_all.deb ...
                              Entpacken von publicsuffix (20220811.1734-0+deb11u1) über (20211207.1025-0+deb11u1) ...
                              Vorbereitung zum Entpacken von .../89-shim-unsigned_15.7-1~deb11u1_amd64.deb ...
                              Entpacken von shim-unsigned (15.7-1~deb11u1) über (15.4-7) ...
                              Vorbereitung zum Entpacken von .../90-shim-helpers-amd64-signed_1+15.7+1~deb11u1_amd64.deb ...
                              Entpacken von shim-helpers-amd64-signed (1+15.7+1~deb11u1) über (1+15.4+7) ...
                              Vorbereitung zum Entpacken von .../91-shim-signed-common_1.39~1+deb11u1+15.7-1~deb11u1_all.deb ...
                              Entpacken von shim-signed-common (1.39~1+deb11u1+15.7-1~deb11u1) über (1.38+15.4-7) ...
                              Vorbereitung zum Entpacken von .../92-shim-signed_1.39~1+deb11u1+15.7-1~deb11u1_amd64.deb ...
                              Entpacken von shim-signed:amd64 (1.39~1+deb11u1+15.7-1~deb11u1) über (1.38+15.4-7) ...
                              Vorbereitung zum Entpacken von .../93-sudo_1.9.5p2-3+deb11u1_amd64.deb ...
                              Entpacken von sudo (1.9.5p2-3+deb11u1) über (1.9.5p2-3) ...
                              Vorbereitung zum Entpacken von .../94-unzip_6.0-26+deb11u1_amd64.deb ...
                              Entpacken von unzip (6.0-26+deb11u1) über (6.0-26) ...
                              libssh-gcrypt-4:amd64 (0.9.7-0+deb11u1) wird eingerichtet ...
                              libksba8:amd64 (1.5.0-3+deb11u2) wird eingerichtet ...
                              libgs9-common (9.53.3~dfsg-7+deb11u4) wird eingerichtet ...
                              logrotate (3.18.0-2+deb11u1) wird eingerichtet ...
                              logrotate.service is a disabled or a static unit not running, not starting it.
                              libexpat1:amd64 (2.2.10-2+deb11u5) wird eingerichtet ...
                              libpixman-1-0:amd64 (0.40.0-1.1~deb11u1) wird eingerichtet ...
                              systemd-sysv (247.3-7+deb11u2) wird eingerichtet ...
                              imagemagick-6-common (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                              libc-l10n (2.31-13+deb11u6) wird eingerichtet ...
                              libnftables1:amd64 (0.9.8-3.1+deb11u1) wird eingerichtet ...
                              libpixman-1-dev:amd64 (0.40.0-1.1~deb11u1) wird eingerichtet ...
                              nftables (0.9.8-3.1+deb11u1) wird eingerichtet ...
                              mokutil (0.6.0-2~deb11u1) wird eingerichtet ...
                              traceroute (1:2.1.0-2+deb11u1) wird eingerichtet ...
                              update-alternatives: /usr/bin/traceroute.db wird verwendet, um /usr/bin/traceroute (traceroute) im automatischen Modus bereitzustellen
                              update-alternatives: /usr/bin/traceroute6.db wird verwendet, um /usr/bin/traceroute6 (traceroute6) im automatischen Modus bereitzustellen
                              update-alternatives: /usr/bin/lft.db wird verwendet, um /usr/bin/lft (lft) im automatischen Modus bereitzustellen
                              update-alternatives: /usr/bin/traceproto.db wird verwendet, um /usr/bin/traceproto (traceproto) im automatischen Modus bereitzustellen
                              update-alternatives: /usr/sbin/tcptraceroute.db wird verwendet, um /usr/sbin/tcptraceroute (tcptraceroute) im automatischen Modus bereitzustellen
                              distro-info-data (0.51+deb11u3) wird eingerichtet ...
                              openssh-client (1:8.4p1-5+deb11u1) wird eingerichtet ...
                              linux-image-5.10.0-23-amd64 (5.10.179-1) wird eingerichtet ...
                              I: /vmlinuz.old is now a symlink to boot/vmlinuz-5.10.0-13-amd64
                              I: /initrd.img.old is now a symlink to boot/initrd.img-5.10.0-13-amd64
                              I: /vmlinuz is now a symlink to boot/vmlinuz-5.10.0-23-amd64
                              I: /initrd.img is now a symlink to boot/initrd.img-5.10.0-23-amd64
                              /etc/kernel/postinst.d/initramfs-tools:
                              update-initramfs: Generating /boot/initrd.img-5.10.0-23-amd64
                              /etc/kernel/postinst.d/zz-update-grub:
                              Generating grub configuration file ...
                              Found linux image: /boot/vmlinuz-5.10.0-23-amd64
                              Found initrd image: /boot/initrd.img-5.10.0-23-amd64
                              Found linux image: /boot/vmlinuz-5.10.0-13-amd64
                              Found initrd image: /boot/initrd.img-5.10.0-13-amd64
                              Found linux image: /boot/vmlinuz-5.10.0-11-amd64
                              Found initrd image: /boot/initrd.img-5.10.0-11-amd64
                              Adding boot menu entry for EFI firmware configuration
                              done
                              unzip (6.0-26+deb11u1) wird eingerichtet ...
                              libgdk-pixbuf2.0-common (2.42.2+dfsg-1+deb11u1) wird eingerichtet ...
                              rsyslog (8.2102.0-2+deb11u1) wird eingerichtet ...
                              linux-libc-dev:amd64 (5.10.179-1) wird eingerichtet ...
                              isc-dhcp-client (4.4.1-2.3+deb11u2) wird eingerichtet ...
                              libldap-2.4-2:amd64 (2.4.57+dfsg-3+deb11u1) wird eingerichtet ...
                              libnss-systemd:amd64 (247.3-7+deb11u2) wird eingerichtet ...
                              libcurl3-gnutls:amd64 (7.74.0-1.3+deb11u7) wird eingerichtet ...
                              krb5-locales (1.18.3-6+deb11u3) wird eingerichtet ...
                              libnss3:amd64 (2:3.61-1+deb11u3) wird eingerichtet ...
                              linux-image-amd64 (5.10.179-1) wird eingerichtet ...
                              locales (2.31-13+deb11u6) wird eingerichtet ...
                              Generating locales (this might take a while)...
                                de_DE.UTF-8... done
                              Generation complete.
                              nodejs (16.20.1-deb-1nodesource1) wird eingerichtet ...
                              libldap-common (2.4.57+dfsg-3+deb11u1) wird eingerichtet ...
                              libwbclient0:amd64 (2:4.13.13+dfsg-1~deb11u5) wird eingerichtet ...
                              libpcre2-16-0:amd64 (10.36-2+deb11u1) wird eingerichtet ...
                              tzdata (2021a-1+deb11u10) wird eingerichtet ...
                              Current default time zone: 'Europe/Berlin'
                              Local time is now:      Sun Jun 25 15:15:34 CEST 2023.
                              Universal Time is now:  Sun Jun 25 13:15:34 UTC 2023.
                              Run 'dpkg-reconfigure tzdata' if you wish to change it.
                              libopenexr25:amd64 (2.5.4-2+deb11u1) wird eingerichtet ...
                              mariadb-common (1:10.5.19-0+deb11u2) wird eingerichtet ...
                              libpcre2-32-0:amd64 (10.36-2+deb11u1) wird eingerichtet ...
                              libopenexr-dev (2.5.4-2+deb11u1) wird eingerichtet ...
                              libtirpc-dev:amd64 (1.3.1-1+deb11u1) wird eingerichtet ...
                              libfreetype6:amd64 (2.10.4+dfsg-1+deb11u1) wird eingerichtet ...
                              libx11-data (2:1.7.2-1+deb11u1) wird eingerichtet ...
                              libavahi-common-data:amd64 (0.8-5+deb11u2) wird eingerichtet ...
                              libncurses6:amd64 (6.2+20201114-2+deb11u1) wird eingerichtet ...
                              libdbus-1-3:amd64 (1.12.24-0+deb11u1) wird eingerichtet ...
                              dbus (1.12.24-0+deb11u1) wird eingerichtet ...
                              A reboot is required to replace the running dbus-daemon.
                              Please reboot the system when convenient.
                              dbus.service is a disabled or a static unit, not starting it.
                              dbus.socket is a disabled or a static unit, not starting it.
                              xz-utils (5.2.5-2.1~deb11u1) wird eingerichtet ...
                              libfribidi0:amd64 (1.0.8-2+deb11u1) wird eingerichtet ...
                              libssl-dev:amd64 (1.1.1n-0+deb11u5) wird eingerichtet ...
                              shim-signed-common (1.39~1+deb11u1+15.7-1~deb11u1) wird eingerichtet ...
                              No DKMS packages installed: not changing Secure Boot validation state.
                              systemd-timesyncd (247.3-7+deb11u2) wird eingerichtet ...
                              udev (247.3-7+deb11u2) wird eingerichtet ...
                              libwebp6:amd64 (0.6.1-2.1+deb11u1) wird eingerichtet ...
                              sudo (1.9.5p2-3+deb11u1) wird eingerichtet ...
                              libmariadb3:amd64 (1:10.5.19-0+deb11u2) wird eingerichtet ...
                              libudev-dev:amd64 (247.3-7+deb11u2) wird eingerichtet ...
                              libpcre2-posix2:amd64 (10.36-2+deb11u1) wird eingerichtet ...
                              libncursesw6:amd64 (6.2+20201114-2+deb11u1) wird eingerichtet ...
                              libdpkg-perl (1.20.12) wird eingerichtet ...
                              liblzma-dev:amd64 (5.2.5-2.1~deb11u1) wird eingerichtet ...
                              nano (5.4-2+deb11u2) wird eingerichtet ...
                              libhttp-daemon-perl (6.12-1+deb11u1) wird eingerichtet ...
                              libpam-systemd:amd64 (247.3-7+deb11u2) wird eingerichtet ...
                              libcurl4:amd64 (7.74.0-1.3+deb11u7) wird eingerichtet ...
                              git-man (1:2.30.2-1+deb11u2) wird eingerichtet ...
                              libx11-6:amd64 (2:1.7.2-1+deb11u1) wird eingerichtet ...
                              isc-dhcp-common (4.4.1-2.3+deb11u2) wird eingerichtet ...
                              libtiff5:amd64 (4.2.0-1+deb11u4) wird eingerichtet ...
                              curl (7.74.0-1.3+deb11u7) wird eingerichtet ...
                              libmagickcore-6-headers (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                              libde265-0:amd64 (1.0.11-0+deb11u1) wird eingerichtet ...
                              libc-dev-bin (2.31-13+deb11u6) wird eingerichtet ...
                              libsdl2-2.0-0:amd64 (2.0.14+dfsg2-3+deb11u1) wird eingerichtet ...
                              openssl (1.1.1n-0+deb11u5) wird eingerichtet ...
                              libwebpmux3:amd64 (0.6.1-2.1+deb11u1) wird eingerichtet ...
                              grafana (10.0.1) wird eingerichtet ...
                              Neue Version der Konfigurationsdatei /etc/init.d/grafana-server wird installiert ...
                              Neue Version der Konfigurationsdatei /usr/lib/systemd/system/grafana-server.service wird installiert ...
                              Restarting grafana-server service... OK
                              publicsuffix (20220811.1734-0+deb11u1) wird eingerichtet ...
                              libxml2:amd64 (2.9.10+dfsg-6.7+deb11u4) wird eingerichtet ...
                              shim-unsigned (15.7-1~deb11u1) wird eingerichtet ...
                              libgtk-3-common (3.24.24-4+deb11u3) wird eingerichtet ...
                              libtiffxx5:amd64 (4.2.0-1+deb11u4) wird eingerichtet ...
                              libc-devtools (2.31-13+deb11u6) wird eingerichtet ...
                              ncurses-term (6.2+20201114-2+deb11u1) wird eingerichtet ...
                              openssh-sftp-server (1:8.4p1-5+deb11u1) wird eingerichtet ...
                              libx11-xcb1:amd64 (2:1.7.2-1+deb11u1) wird eingerichtet ...
                              libmagickcore-6-arch-config:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                              libxpm4:amd64 (1:3.5.12-1.1~deb11u1) wird eingerichtet ...
                              openssh-server (1:8.4p1-5+deb11u1) wird eingerichtet ...
                              rescue-ssh.target is a disabled or a static unit, not starting it.
                              bind9-libs:amd64 (1:9.16.37-1~deb11u1) wird eingerichtet ...
                              libmagickwand-6-headers (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                              libfribidi-dev:amd64 (1.0.8-2+deb11u1) wird eingerichtet ...
                              libwebpdemux2:amd64 (0.6.1-2.1+deb11u1) wird eingerichtet ...
                              cifs-utils (2:6.11-3.1+deb11u1) wird eingerichtet ...
                              libavahi-common3:amd64 (0.8-5+deb11u2) wird eingerichtet ...
                              libpq5:amd64 (13.11-0+deb11u1) wird eingerichtet ...
                              libx11-dev:amd64 (2:1.7.2-1+deb11u1) wird eingerichtet ...
                              libatspi2.0-0:amd64 (2.38.0-4+deb11u1) wird eingerichtet ...
                              libavutil56:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                              dpkg-dev (1.20.12) wird eingerichtet ...
                              grub-common (2.06-3~deb11u5) wird eingerichtet ...
                              Neue Version der Konfigurationsdatei /etc/grub.d/10_linux wird installiert ...
                              Neue Version der Konfigurationsdatei /etc/grub.d/20_linux_xen wird installiert ...
                              Neue Version der Konfigurationsdatei /etc/grub.d/30_os-prober wird installiert ...
                              Neue Version der Konfigurationsdatei /etc/grub.d/30_uefi-firmware wird installiert ...
                              Neue Version der Konfigurationsdatei /etc/grub.d/41_custom wird installiert ...
                              dbus-user-session (1.12.24-0+deb11u1) wird eingerichtet ...
                              libmagickcore-6.q16-6:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                              libxml2-dev:amd64 (2.9.10+dfsg-6.7+deb11u4) wird eingerichtet ...
                              libdbus-1-dev:amd64 (1.12.24-0+deb11u1) wird eingerichtet ...
                              libcurl4-openssl-dev:amd64 (7.74.0-1.3+deb11u7) wird eingerichtet ...
                              libpostproc55:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                              git (1:2.30.2-1+deb11u2) wird eingerichtet ...
                              shim-helpers-amd64-signed (1+15.7+1~deb11u1) wird eingerichtet ...
                              x86_64-efi wird für Ihre Plattform installiert.
                              installation beendet. Keine Fehler aufgetreten.
                              at-spi2-core (2.38.0-4+deb11u1) wird eingerichtet ...
                              libavahi-common-dev:amd64 (0.8-5+deb11u2) wird eingerichtet ...
                              libc6-dev:amd64 (2.31-13+deb11u6) wird eingerichtet ...
                              libmagickwand-6.q16-6:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                              libgdk-pixbuf-2.0-0:amd64 (2.42.2+dfsg-1+deb11u1) wird eingerichtet ...
                              libswscale5:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                              libbluray2:amd64 (1:1.2.1-4+deb11u2) wird eingerichtet ...
                              grub-efi-amd64-bin (2.06-3~deb11u5) wird eingerichtet ...
                              libmagick++-6.q16-8:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                              bind9-host (1:9.16.37-1~deb11u1) wird eingerichtet ...
                              libavahi-client3:amd64 (0.8-5+deb11u2) wird eingerichtet ...
                              gtk-update-icon-cache (3.24.24-4+deb11u3) wird eingerichtet ...
                              libpcre2-dev:amd64 (10.36-2+deb11u1) wird eingerichtet ...
                              grub-efi-amd64-signed (1+2.06+3~deb11u5) wird eingerichtet ...
                              libmagick++-6-headers (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                              gir1.2-gdkpixbuf-2.0:amd64 (2.42.2+dfsg-1+deb11u1) wird eingerichtet ...
                              libmagickcore-6.q16-6-extra:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                              grub2-common (2.06-3~deb11u5) wird eingerichtet ...
                              Neue Version der Konfigurationsdatei /etc/kernel/postinst.d/zz-update-grub wird installiert ...
                              Neue Version der Konfigurationsdatei /etc/kernel/postrm.d/zz-update-grub wird installiert ...
                              libavahi-client-dev:amd64 (0.8-5+deb11u2) wird eingerichtet ...
                              libswresample3:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                              libavahi-compat-libdnssd1:amd64 (0.8-5+deb11u2) wird eingerichtet ...
                              shim-signed:amd64 (1.39~1+deb11u1+15.7-1~deb11u1) wird eingerichtet ...
                              libavresample4:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                              libexpat1-dev:amd64 (2.2.10-2+deb11u5) wird eingerichtet ...
                              grub-efi-amd64 (2.06-3~deb11u5) wird eingerichtet ...
                              Warning: os-prober will be executed to detect other bootable partitions.
                              Its output will be used to detect bootable binaries on them and create new boot entries.
                              Adding boot menu entry for UEFI Firmware Settings ...
                              done
                              libcups2:amd64 (2.3.3op2-3+deb11u2) wird eingerichtet ...
                              zlib1g-dev:amd64 (1:1.2.11.dfsg-2+deb11u2) wird eingerichtet ...
                              libgdk-pixbuf2.0-bin (2.42.2+dfsg-1+deb11u1) wird eingerichtet ...
                              libavcodec58:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                              bind9-dnsutils (1:9.16.37-1~deb11u1) wird eingerichtet ...
                              libgdk-pixbuf-2.0-dev:amd64 (2.42.2+dfsg-1+deb11u1) wird eingerichtet ...
                              libgs9:amd64 (9.53.3~dfsg-7+deb11u4) wird eingerichtet ...
                              libavformat58:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                              libavahi-compat-libdnssd-dev:amd64 (0.8-5+deb11u2) wird eingerichtet ...
                              ghostscript (9.53.3~dfsg-7+deb11u4) wird eingerichtet ...
                              libfreetype-dev:amd64 (2.10.4+dfsg-1+deb11u1) wird eingerichtet ...
                              libtiff-dev:amd64 (4.2.0-1+deb11u4) wird eingerichtet ...
                              libavfilter7:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                              libfreetype6-dev:amd64 (2.10.4+dfsg-1+deb11u1) wird eingerichtet ...
                              libavdevice58:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                              ffmpeg (7:4.3.6-0+deb11u1) wird eingerichtet ...
                              libmagickcore-6.q16-dev:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                              libmagickwand-6.q16-dev:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                              libmagick++-6.q16-dev:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                              libmagick++-dev (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                              Trigger für libc-bin (2.31-13+deb11u6) werden verarbeitet ...
                              Trigger für man-db (2.9.4-2) werden verarbeitet ...
                              Trigger für mailcap (3.69) werden verarbeitet ...
                              Trigger für initramfs-tools (0.140) werden verarbeitet ...
                              Trigger für libglib2.0-0:amd64 (2.66.8-1) werden verarbeitet ...
                              libgtk-3-0:amd64 (3.24.24-4+deb11u3) wird eingerichtet ...
                              libgtk-3-bin (3.24.24-4+deb11u3) wird eingerichtet ...
                              Trigger für shim-signed:amd64 (1.39~1+deb11u1+15.7-1~deb11u1) werden verarbeitet ...
                              e6iob@NUCioBroker:~$
                              • F fraso
                                uiui ist da viel passiert bei dem influx:
                                e6iob@NUCioBroker:~$ iob stop
                                e6iob@NUCioBroker:~$ ls -lA /etc/apt/sources.list.d/
                                sudo apt update
                                insgesamt 16
                                -rw-r--r-- 1 root root 104  4. Feb 19:45 influxdb.list
                                -rw-r--r-- 1 root root 104  4. Feb 19:45 influxdb.list.save
                                -rw-r--r-- 1 root root 208  4. Feb 19:45 nodesource.list
                                -rw-r--r-- 1 root root 208  4. Feb 19:45 nodesource.list.save
                                [sudo] Passwort für e6iob:
                                OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                                OK:2 http://deb.debian.org/debian bullseye InRelease
                                OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                                OK:4 https://packages.grafana.com/oss/deb stable InRelease
                                OK:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                Holen:6 https://repos.influxdata.com/debian bullseye InRelease [7.040 B]
                                Fehl:6 https://repos.influxdata.com/debian bullseye InRelease
                                  Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                Es wurden 7.040 B in 10 s geholt (691 B/s).
                                Aktualisierung für 179 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian bullseye InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/bullseye/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
                                e6iob@NUCioBroker:~$ sudo rm /etc/apt/sources.list.d/influxdb.list
                                e6iob@NUCioBroker:~$ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                 echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                                 echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                 sudo apt update
                                 sudo apt full-upgrade
                                influxdata-archive_compat.key: OK
                                OK:1 http://deb.debian.org/debian bullseye InRelease
                                OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                                OK:3 http://security.debian.org/debian-security bullseye-security InRelease
                                Holen:5 https://repos.influxdata.com/debian stable InRelease [6.892 B]
                                Holen:6 https://repos.influxdata.com/debian stable/main amd64 Packages [5.071 B]
                                Fehl:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                                  Temporärer Fehlschlag beim Auflösen von »deb.nodesource.com«
                                Es wurden 12,0 kB in 30 s geholt (397 B/s).
                                W: Fehlschlag beim Holen von https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease Temporärer Fehlschlag beim Auflösen von »deb.nodesource.com«
                                Paketaktualisierung (Upgrade) wird berechnet… Fertig
                                Die folgenden NEUEN Pakete werden installiert:
                                  at-spi2-core base-files bash bind9-dnsutils bind9-host bind9-libs cifs-utils curl dbus dbus-user-session debian-archive-keyring
                                  distro-info-data dpkg dpkg-dev ffmpeg ghostscript gir1.2-gdkpixbuf-2.0 git git-man grafana grep grub-common grub-efi-amd64
                                  grub-efi-amd64-bin grub-efi-amd64-signed grub2-common gtk-update-icon-cache gzip imagemagick-6-common isc-dhcp-client isc-dhcp-common
                                  krb5-locales libatspi2.0-0 libavahi-client-dev libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3
                                  libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4 libavutil56
                                  libbluray2 libc-bin libc-dev-bin libc-devtools libc-l10n libc6 libc6-dev libcups2 libcurl3-gnutls libcurl4 libcurl4-openssl-dev
                                  libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libexpat1 libexpat1-dev libfreetype-dev libfreetype6 libfreetype6-dev libfribidi-dev
                                  libfribidi0 libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common libgnutls30 libgs9 libgs9-common
                                  libgssapi-krb5-2 libgtk-3-0 libgtk-3-bin libgtk-3-common libhttp-daemon-perl libk5crypto3 libkrb5-3 libkrb5support0 libksba8
                                  libldap-2.4-2 libldap-common liblzma-dev liblzma5 libmagick++-6-headers libmagick++-6.q16-8 libmagick++-6.q16-dev libmagick++-dev
                                  libmagickcore-6-arch-config libmagickcore-6-headers libmagickcore-6.q16-6 libmagickcore-6.q16-6-extra libmagickcore-6.q16-dev
                                  libmagickwand-6-headers libmagickwand-6.q16-6 libmagickwand-6.q16-dev libmariadb3 libncurses6 libncursesw6 libnftables1 libnss-systemd
                                  libnss3 libopenexr-dev libopenexr25 libpam-systemd libpcre2-16-0 libpcre2-32-0 libpcre2-8-0 libpcre2-dev libpcre2-posix2 libpixman-1-0
                                  libpixman-1-dev libpostproc55 libpq5 libsdl2-2.0-0 libssh-gcrypt-4 libssl-dev libssl1.1 libswresample3 libswscale5 libsystemd0
                                  libtasn1-6 libtiff-dev libtiff5 libtiffxx5 libtinfo6 libtirpc-common libtirpc-dev libtirpc3 libudev-dev libudev1 libwbclient0 libwebp6
                                  libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev libx11-xcb1 libxml2 libxml2-dev libxpm4 linux-image-amd64 linux-libc-dev
                                  locales logrotate mariadb-common mokutil nano ncurses-base ncurses-bin ncurses-term nftables nodejs openssh-client openssh-server
                                  openssh-sftp-server openssl publicsuffix rsyslog shim-helpers-amd64-signed shim-signed shim-signed-common shim-unsigned sudo systemd
                                  systemd-sysv systemd-timesyncd traceroute tzdata udev unzip xz-utils zlib1g zlib1g-dev
                                179 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                Es müssen 269 MB an Archiven heruntergeladen werden.
                                Nach dieser Operation werden 347 MB Plattenplatz zusätzlich benutzt.
                                Möchten Sie fortfahren? [J/n] J
                                Holen:1 http://deb.debian.org/debian bullseye/main amd64 base-files amd64 11.1+deb11u7 [70,1 kB]
                                Holen:2 http://deb.debian.org/debian bullseye/main amd64 bash amd64 5.1-2+deb11u1 [1.417 kB]
                                Holen:3 https://deb.nodesource.com/node_16.x bullseye/main amd64 nodejs amd64 16.20.1-deb-1nodesource1 [27,2 MB]
                                Holen:4 http://deb.debian.org/debian bullseye/main amd64 dpkg amd64 1.20.12 [2.536 kB]
                                Holen:5 http://deb.debian.org/debian bullseye/main amd64 grep amd64 3.6-1+deb11u1 [398 kB]
                                Holen:6 http://deb.debian.org/debian bullseye/main amd64 gzip amd64 1.10-4+deb11u1 [132 kB]
                                Holen:7 http://deb.debian.org/debian bullseye/main amd64 ncurses-bin amd64 6.2+20201114-2+deb11u1 [429 kB]
                                Holen:8 http://deb.debian.org/debian bullseye/main amd64 libc-devtools amd64 2.31-13+deb11u6 [246 kB]
                                Holen:9 http://deb.debian.org/debian bullseye/main amd64 libc6-dev amd64 2.31-13+deb11u6 [2.360 kB]
                                Holen:10 http://deb.debian.org/debian bullseye/main amd64 libc-dev-bin amd64 2.31-13+deb11u6 [276 kB]
                                Holen:11 http://deb.debian.org/debian bullseye/main amd64 libc6 amd64 2.31-13+deb11u6 [2.827 kB]
                                Holen:12 http://deb.debian.org/debian bullseye/main amd64 libc-bin amd64 2.31-13+deb11u6 [824 kB]
                                Holen:13 http://deb.debian.org/debian bullseye/main amd64 ncurses-base all 6.2+20201114-2+deb11u1 [272 kB]
                                Holen:14 http://deb.debian.org/debian bullseye/main amd64 libnss-systemd amd64 247.3-7+deb11u2 [199 kB]
                                Holen:15 http://deb.debian.org/debian bullseye/main amd64 libudev-dev amd64 247.3-7+deb11u2 [123 kB]
                                Holen:16 http://deb.debian.org/debian bullseye/main amd64 libsystemd0 amd64 247.3-7+deb11u2 [376 kB]
                                Holen:17 http://deb.debian.org/debian bullseye/main amd64 systemd-timesyncd amd64 247.3-7+deb11u2 [131 kB]
                                Holen:18 http://deb.debian.org/debian bullseye/main amd64 libpam-systemd amd64 247.3-7+deb11u2 [283 kB]
                                Holen:19 http://deb.debian.org/debian bullseye/main amd64 systemd amd64 247.3-7+deb11u2 [4.501 kB]
                                Holen:20 http://deb.debian.org/debian bullseye/main amd64 udev amd64 247.3-7+deb11u2 [1.465 kB]
                                Holen:21 http://deb.debian.org/debian bullseye/main amd64 libudev1 amd64 247.3-7+deb11u2 [168 kB]
                                Holen:22 http://deb.debian.org/debian bullseye/main amd64 systemd-sysv amd64 247.3-7+deb11u2 [113 kB]
                                Holen:23 http://deb.debian.org/debian bullseye/main amd64 libdbus-1-dev amd64 1.12.24-0+deb11u1 [260 kB]
                                Holen:24 http://deb.debian.org/debian bullseye/main amd64 dbus amd64 1.12.24-0+deb11u1 [243 kB]
                                Holen:25 http://deb.debian.org/debian bullseye/main amd64 libdbus-1-3 amd64 1.12.24-0+deb11u1 [222 kB]
                                Holen:26 http://deb.debian.org/debian bullseye/main amd64 libexpat1-dev amd64 2.2.10-2+deb11u5 [141 kB]
                                Holen:27 http://deb.debian.org/debian bullseye/main amd64 libexpat1 amd64 2.2.10-2+deb11u5 [98,2 kB]
                                Holen:28 http://deb.debian.org/debian bullseye/main amd64 libtasn1-6 amd64 4.16.0-2+deb11u1 [54,9 kB]
                                Holen:29 http://deb.debian.org/debian bullseye/main amd64 libgnutls30 amd64 3.7.1-5+deb11u3 [1.340 kB]
                                Holen:30 http://deb.debian.org/debian bullseye/main amd64 nftables amd64 0.9.8-3.1+deb11u1 [68,7 kB]
                                Holen:31 http://deb.debian.org/debian bullseye/main amd64 libnftables1 amd64 0.9.8-3.1+deb11u1 [261 kB]
                                Holen:32 http://deb.debian.org/debian bullseye/main amd64 zlib1g-dev amd64 1:1.2.11.dfsg-2+deb11u2 [191 kB]
                                Holen:33 http://deb.debian.org/debian bullseye/main amd64 zlib1g amd64 1:1.2.11.dfsg-2+deb11u2 [91,4 kB]
                                Holen:34 http://deb.debian.org/debian bullseye/main amd64 rsyslog amd64 8.2102.0-2+deb11u1 [703 kB]
                                Holen:35 http://deb.debian.org/debian bullseye/main amd64 libmagick++-6.q16-dev amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [281 kB]
                                Holen:36 http://deb.debian.org/debian bullseye/main amd64 libmagick++-dev all 8:6.9.11.60+dfsg-1.3+deb11u1 [1.368 B]
                                Holen:37 http://deb.debian.org/debian bullseye/main amd64 libmagick++-6-headers all 8:6.9.11.60+dfsg-1.3+deb11u1 [47,5 kB]
                                Holen:38 http://deb.debian.org/debian bullseye/main amd64 libmagickwand-6.q16-dev amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [450 kB]
                                Holen:39 http://deb.debian.org/debian bullseye/main amd64 libmagickwand-6-headers all 8:6.9.11.60+dfsg-1.3+deb11u1 [10,5 kB]
                                Holen:40 http://deb.debian.org/debian bullseye/main amd64 libmagickcore-6.q16-dev amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [1.142 kB]
                                Holen:41 http://deb.debian.org/debian bullseye/main amd64 libmagickcore-6-arch-config amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [174 kB]
                                Holen:42 http://deb.debian.org/debian bullseye/main amd64 libmagickcore-6-headers all 8:6.9.11.60+dfsg-1.3+deb11u1 [50,9 kB]
                                Holen:43 http://deb.debian.org/debian bullseye/main amd64 imagemagick-6-common all 8:6.9.11.60+dfsg-1.3+deb11u1 [211 kB]
                                Holen:44 http://deb.debian.org/debian bullseye/main amd64 libmagickwand-6.q16-6 amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [453 kB]
                                Holen:45 http://deb.debian.org/debian bullseye/main amd64 libopenexr-dev amd64 2.5.4-2+deb11u1 [160 kB]
                                Holen:46 http://deb.debian.org/debian bullseye/main amd64 libopenexr25 amd64 2.5.4-2+deb11u1 [689 kB]
                                Holen:47 http://deb.debian.org/debian bullseye/main amd64 libxml2-dev amd64 2.9.10+dfsg-6.7+deb11u4 [790 kB]
                                Holen:48 http://deb.debian.org/debian bullseye/main amd64 liblzma-dev amd64 5.2.5-2.1~deb11u1 [229 kB]
                                Holen:49 http://deb.debian.org/debian bullseye/main amd64 liblzma5 amd64 5.2.5-2.1~deb11u1 [168 kB]
                                Holen:50 http://deb.debian.org/debian bullseye/main amd64 libxml2 amd64 2.9.10+dfsg-6.7+deb11u4 [693 kB]
                                Holen:51 http://deb.debian.org/debian bullseye/main amd64 libmagickcore-6.q16-6-extra amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [216 kB]
                                Holen:52 http://deb.debian.org/debian bullseye/main amd64 libfreetype6-dev amd64 2.10.4+dfsg-1+deb11u1 [82,6 kB]
                                Holen:53 http://deb.debian.org/debian bullseye/main amd64 libfreetype-dev amd64 2.10.4+dfsg-1+deb11u1 [571 kB]
                                Holen:54 http://deb.debian.org/debian bullseye/main amd64 libfreetype6 amd64 2.10.4+dfsg-1+deb11u1 [418 kB]
                                Holen:55 http://deb.debian.org/debian bullseye/main amd64 libtiff-dev amd64 4.2.0-1+deb11u4 [416 kB]
                                Holen:56 http://deb.debian.org/debian bullseye/main amd64 libtiff5 amd64 4.2.0-1+deb11u4 [290 kB]
                                Holen:57 http://deb.debian.org/debian bullseye/main amd64 libtiffxx5 amd64 4.2.0-1+deb11u4 [129 kB]
                                Holen:58 http://deb.debian.org/debian bullseye/main amd64 libmagickcore-6.q16-6 amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [1.812 kB]
                                Holen:59 http://deb.debian.org/debian bullseye/main amd64 libmagick++-6.q16-8 amd64 8:6.9.11.60+dfsg-1.3+deb11u1 [290 kB]
                                Holen:60 http://deb.debian.org/debian bullseye/main amd64 libwbclient0 amd64 2:4.13.13+dfsg-1~deb11u5 [313 kB]
                                Holen:61 http://deb.debian.org/debian bullseye/main amd64 debian-archive-keyring all 2021.1.1+deb11u1 [110 kB]
                                Holen:62 http://deb.debian.org/debian bullseye/main amd64 libk5crypto3 amd64 1.18.3-6+deb11u3 [114 kB]
                                Holen:63 http://deb.debian.org/debian bullseye/main amd64 libkrb5support0 amd64 1.18.3-6+deb11u3 [65,5 kB]
                                Holen:64 http://deb.debian.org/debian bullseye/main amd64 libkrb5-3 amd64 1.18.3-6+deb11u3 [364 kB]
                                Holen:65 http://deb.debian.org/debian bullseye/main amd64 libgssapi-krb5-2 amd64 1.18.3-6+deb11u3 [165 kB]
                                Holen:66 http://deb.debian.org/debian bullseye/main amd64 libpcre2-dev amd64 10.36-2+deb11u1 [733 kB]
                                Holen:67 http://deb.debian.org/debian bullseye/main amd64 libpcre2-16-0 amd64 10.36-2+deb11u1 [232 kB]
                                Holen:68 http://deb.debian.org/debian bullseye/main amd64 libpcre2-32-0 amd64 10.36-2+deb11u1 [220 kB]
                                Holen:69 http://deb.debian.org/debian bullseye/main amd64 libpcre2-posix2 amd64 10.36-2+deb11u1 [49,1 kB]
                                Holen:70 http://deb.debian.org/debian bullseye/main amd64 libpcre2-8-0 amd64 10.36-2+deb11u1 [248 kB]
                                Holen:71 http://deb.debian.org/debian bullseye/main amd64 libncurses6 amd64 6.2+20201114-2+deb11u1 [102 kB]
                                Holen:72 http://deb.debian.org/debian bullseye/main amd64 libncursesw6 amd64 6.2+20201114-2+deb11u1 [132 kB]
                                Holen:73 http://deb.debian.org/debian bullseye/main amd64 libtinfo6 amd64 6.2+20201114-2+deb11u1 [341 kB]
                                Holen:74 http://deb.debian.org/debian bullseye/main amd64 libtirpc-common all 1.3.1-1+deb11u1 [13,5 kB]
                                Holen:75 http://deb.debian.org/debian bullseye/main amd64 libtirpc-dev amd64 1.3.1-1+deb11u1 [191 kB]
                                Holen:76 http://deb.debian.org/debian bullseye/main amd64 libtirpc3 amd64 1.3.1-1+deb11u1 [84,1 kB]
                                Holen:77 http://deb.debian.org/debian bullseye/main amd64 tzdata all 2021a-1+deb11u10 [286 kB]
                                Holen:78 http://deb.debian.org/debian bullseye/main amd64 isc-dhcp-client amd64 4.4.1-2.3+deb11u2 [343 kB]
                                Holen:79 http://deb.debian.org/debian bullseye/main amd64 isc-dhcp-common amd64 4.4.1-2.3+deb11u2 [145 kB]
                                Holen:80 http://deb.debian.org/debian bullseye/main amd64 logrotate amd64 3.18.0-2+deb11u1 [72,7 kB]
                                Holen:81 http://deb.debian.org/debian bullseye/main amd64 nano amd64 5.4-2+deb11u2 [657 kB]
                                Holen:82 http://deb.debian.org/debian bullseye/main amd64 bind9-dnsutils amd64 1:9.16.37-1~deb11u1 [404 kB]
                                Holen:83 http://deb.debian.org/debian bullseye/main amd64 bind9-libs amd64 1:9.16.37-1~deb11u1 [1.424 kB]
                                Holen:84 http://deb.debian.org/debian bullseye/main amd64 bind9-host amd64 1:9.16.37-1~deb11u1 [308 kB]
                                Holen:85 http://deb.debian.org/debian bullseye/main amd64 krb5-locales all 1.18.3-6+deb11u3 [95,5 kB]
                                Holen:86 http://deb.debian.org/debian bullseye/main amd64 libc-l10n all 2.31-13+deb11u6 [865 kB]
                                Holen:87 http://deb.debian.org/debian bullseye/main amd64 locales all 2.31-13+deb11u6 [4.086 kB]
                                Holen:88 http://deb.debian.org/debian bullseye/main amd64 ncurses-term all 6.2+20201114-2+deb11u1 [505 kB]
                                Holen:89 http://deb.debian.org/debian bullseye/main amd64 openssh-sftp-server amd64 1:8.4p1-5+deb11u1 [52,4 kB]
                                Holen:90 http://deb.debian.org/debian bullseye/main amd64 openssh-server amd64 1:8.4p1-5+deb11u1 [385 kB]
                                Holen:91 http://deb.debian.org/debian bullseye/main amd64 git-man all 1:2.30.2-1+deb11u2 [1.828 kB]
                                Holen:92 http://deb.debian.org/debian bullseye/main amd64 libldap-2.4-2 amd64 2.4.57+dfsg-3+deb11u1 [232 kB]
                                Holen:93 http://deb.debian.org/debian bullseye/main amd64 libcurl3-gnutls amd64 7.74.0-1.3+deb11u7 [343 kB]
                                Holen:94 http://deb.debian.org/debian bullseye/main amd64 git amd64 1:2.30.2-1+deb11u2 [5.518 kB]
                                Holen:95 http://deb.debian.org/debian bullseye/main amd64 openssh-client amd64 1:8.4p1-5+deb11u1 [929 kB]
                                Holen:96 http://deb.debian.org/debian bullseye/main amd64 traceroute amd64 1:2.1.0-2+deb11u1 [55,7 kB]
                                Holen:97 http://deb.debian.org/debian bullseye/main amd64 xz-utils amd64 5.2.5-2.1~deb11u1 [220 kB]
                                Holen:98 http://deb.debian.org/debian bullseye/main amd64 libatspi2.0-0 amd64 2.38.0-4+deb11u1 [72,4 kB]
                                Holen:99 http://deb.debian.org/debian bullseye/main amd64 at-spi2-core amd64 2.38.0-4+deb11u1 [72,5 kB]
                                Holen:100 http://deb.debian.org/debian bullseye/main amd64 cifs-utils amd64 2:6.11-3.1+deb11u1 [90,4 kB]
                                Holen:101 http://deb.debian.org/debian bullseye/main amd64 libcurl4-openssl-dev amd64 7.74.0-1.3+deb11u7 [436 kB]
                                Holen:102 http://deb.debian.org/debian bullseye/main amd64 curl amd64 7.74.0-1.3+deb11u7 [270 kB]
                                Holen:103 http://deb.debian.org/debian bullseye/main amd64 libcurl4 amd64 7.74.0-1.3+deb11u7 [346 kB]
                                Holen:104 http://deb.debian.org/debian bullseye/main amd64 dbus-user-session amd64 1.12.24-0+deb11u1 [99,7 kB]
                                Holen:105 http://deb.debian.org/debian bullseye/main amd64 distro-info-data all 0.51+deb11u3 [7.812 B]
                                Holen:106 http://deb.debian.org/debian bullseye/main amd64 dpkg-dev all 1.20.12 [2.312 kB]
                                Holen:107 http://deb.debian.org/debian bullseye/main amd64 libdpkg-perl all 1.20.12 [1.551 kB]
                                Holen:108 http://deb.debian.org/debian bullseye/main amd64 libsdl2-2.0-0 amd64 2.0.14+dfsg2-3+deb11u1 [506 kB]
                                Holen:109 http://deb.debian.org/debian bullseye/main amd64 libfribidi-dev amd64 1.0.8-2+deb11u1 [105 kB]
                                Holen:110 http://deb.debian.org/debian bullseye/main amd64 libfribidi0 amd64 1.0.8-2+deb11u1 [64,9 kB]
                                Holen:111 http://deb.debian.org/debian bullseye/main amd64 libbluray2 amd64 1:1.2.1-4+deb11u2 [139 kB]
                                Holen:112 http://deb.debian.org/debian bullseye/main amd64 ghostscript amd64 9.53.3~dfsg-7+deb11u4 [98,2 kB]
                                Holen:113 http://deb.debian.org/debian bullseye/main amd64 libgs9 amd64 9.53.3~dfsg-7+deb11u4 [2.244 kB]
                                Holen:114 http://deb.debian.org/debian bullseye/main amd64 libgs9-common all 9.53.3~dfsg-7+deb11u4 [734 kB]
                                Holen:115 http://deb.debian.org/debian bullseye/main amd64 libavahi-compat-libdnssd-dev amd64 0.8-5+deb11u2 [68,1 kB]
                                Holen:116 http://deb.debian.org/debian bullseye/main amd64 libavahi-compat-libdnssd1 amd64 0.8-5+deb11u2 [53,2 kB]
                                Holen:117 http://deb.debian.org/debian bullseye/main amd64 libavahi-client-dev amd64 0.8-5+deb11u2 [71,0 kB]
                                Holen:118 http://deb.debian.org/debian bullseye/main amd64 libavahi-client3 amd64 0.8-5+deb11u2 [62,6 kB]
                                Holen:119 http://deb.debian.org/debian bullseye/main amd64 libavahi-common-dev amd64 0.8-5+deb11u2 [73,7 kB]
                                Holen:120 http://deb.debian.org/debian bullseye/main amd64 libavahi-common3 amd64 0.8-5+deb11u2 [58,7 kB]
                                Holen:121 http://deb.debian.org/debian bullseye/main amd64 libavahi-common-data amd64 0.8-5+deb11u2 [124 kB]
                                Holen:122 http://deb.debian.org/debian bullseye/main amd64 libcups2 amd64 2.3.3op2-3+deb11u2 [350 kB]
                                Holen:123 http://deb.debian.org/debian bullseye/main amd64 libgdk-pixbuf-2.0-dev amd64 2.42.2+dfsg-1+deb11u1 [56,9 kB]
                                Holen:124 http://deb.debian.org/debian bullseye/main amd64 libgdk-pixbuf-2.0-0 amd64 2.42.2+dfsg-1+deb11u1 [147 kB]
                                Holen:125 http://deb.debian.org/debian bullseye/main amd64 libgdk-pixbuf2.0-common all 2.42.2+dfsg-1+deb11u1 [320 kB]
                                Holen:126 http://deb.debian.org/debian bullseye/main amd64 libgdk-pixbuf2.0-bin amd64 2.42.2+dfsg-1+deb11u1 [25,7 kB]
                                Holen:127 http://deb.debian.org/debian bullseye/main amd64 gir1.2-gdkpixbuf-2.0 amd64 2.42.2+dfsg-1+deb11u1 [19,9 kB]
                                Holen:128 http://deb.debian.org/debian bullseye/main amd64 grub-efi-amd64 amd64 2.06-3~deb11u5 [40,2 kB]
                                Holen:129 http://deb.debian.org/debian bullseye/main amd64 grub2-common amd64 2.06-3~deb11u5 [611 kB]
                                Holen:130 http://deb.debian.org/debian bullseye/main amd64 grub-efi-amd64-bin amd64 2.06-3~deb11u5 [1.566 kB]
                                Holen:131 http://deb.debian.org/debian bullseye/main amd64 grub-common amd64 2.06-3~deb11u5 [2.761 kB]
                                Holen:132 http://deb.debian.org/debian bullseye/main amd64 grub-efi-amd64-signed amd64 1+2.06+3~deb11u5 [1.241 kB]
                                Holen:133 http://deb.debian.org/debian bullseye/main amd64 gtk-update-icon-cache amd64 3.24.24-4+deb11u3 [88,4 kB]
                                Holen:134 http://deb.debian.org/debian bullseye/main amd64 libde265-0 amd64 1.0.11-0+deb11u1 [179 kB]
                                Holen:135 http://deb.debian.org/debian bullseye/main amd64 libgtk-3-common all 3.24.24-4+deb11u3 [3.757 kB]
                                Holen:136 http://deb.debian.org/debian bullseye/main amd64 libgtk-3-0 amd64 3.24.24-4+deb11u3 [2.716 kB]
                                Holen:137 http://deb.debian.org/debian bullseye/main amd64 libgtk-3-bin amd64 3.24.24-4+deb11u3 [125 kB]
                                Holen:138 http://deb.debian.org/debian bullseye/main amd64 libhttp-daemon-perl all 6.12-1+deb11u1 [23,4 kB]
                                Holen:139 http://deb.debian.org/debian bullseye/main amd64 libksba8 amd64 1.5.0-3+deb11u2 [123 kB]
                                Holen:140 http://deb.debian.org/debian bullseye/main amd64 libldap-common all 2.4.57+dfsg-3+deb11u1 [95,8 kB]
                                Holen:141 http://deb.debian.org/debian bullseye/main amd64 mariadb-common all 1:10.5.19-0+deb11u2 [37,0 kB]
                                Holen:142 http://deb.debian.org/debian bullseye/main amd64 libmariadb3 amd64 1:10.5.19-0+deb11u2 [176 kB]
                                Holen:143 http://deb.debian.org/debian bullseye/main amd64 libnss3 amd64 2:3.61-1+deb11u3 [1.305 kB]
                                Holen:144 http://deb.debian.org/debian bullseye/main amd64 libpixman-1-dev amd64 0.40.0-1.1~deb11u1 [561 kB]
                                Holen:145 http://deb.debian.org/debian bullseye/main amd64 libpixman-1-0 amd64 0.40.0-1.1~deb11u1 [543 kB]
                                Holen:146 http://deb.debian.org/debian bullseye/main amd64 libxpm4 amd64 1:3.5.12-1.1~deb11u1 [49,6 kB]
                                Holen:147 http://deb.debian.org/debian bullseye/main amd64 mokutil amd64 0.6.0-2~deb11u1 [26,6 kB]
                                Holen:148 http://deb.debian.org/debian bullseye/main amd64 publicsuffix all 20220811.1734-0+deb11u1 [127 kB]
                                Holen:149 http://deb.debian.org/debian bullseye/main amd64 shim-unsigned amd64 15.7-1~deb11u1 [439 kB]
                                Holen:150 http://deb.debian.org/debian bullseye/main amd64 shim-helpers-amd64-signed amd64 1+15.7+1~deb11u1 [301 kB]
                                Holen:151 http://deb.debian.org/debian bullseye/main amd64 shim-signed-common all 1.39~1+deb11u1+15.7-1~deb11u1 [13,8 kB]
                                Holen:152 http://deb.debian.org/debian bullseye/main amd64 shim-signed amd64 1.39~1+deb11u1+15.7-1~deb11u1 [327 kB]
                                Holen:153 http://deb.debian.org/debian bullseye/main amd64 sudo amd64 1.9.5p2-3+deb11u1 [1.061 kB]
                                Holen:154 http://deb.debian.org/debian bullseye/main amd64 unzip amd64 6.0-26+deb11u1 [172 kB]
                                Holen:155 http://security.debian.org/debian-security bullseye-security/main amd64 linux-libc-dev amd64 5.10.179-1 [1.618 kB]
                                Holen:156 http://security.debian.org/debian-security bullseye-security/main amd64 libx11-data all 2:1.7.2-1+deb11u1 [311 kB]
                                Holen:157 http://security.debian.org/debian-security bullseye-security/main amd64 libx11-dev amd64 2:1.7.2-1+deb11u1 [843 kB]
                                Holen:158 http://security.debian.org/debian-security bullseye-security/main amd64 libx11-6 amd64 2:1.7.2-1+deb11u1 [772 kB]
                                Holen:159 http://security.debian.org/debian-security bullseye-security/main amd64 libx11-xcb1 amd64 2:1.7.2-1+deb11u1 [203 kB]
                                Holen:160 http://security.debian.org/debian-security bullseye-security/main amd64 libwebp6 amd64 0.6.1-2.1+deb11u1 [258 kB]
                                Holen:161 http://security.debian.org/debian-security bullseye-security/main amd64 libwebpdemux2 amd64 0.6.1-2.1+deb11u1 [87,8 kB]
                                Holen:162 http://security.debian.org/debian-security bullseye-security/main amd64 libwebpmux3 amd64 0.6.1-2.1+deb11u1 [97,7 kB]
                                Holen:163 http://security.debian.org/debian-security bullseye-security/main amd64 libssl-dev amd64 1.1.1n-0+deb11u5 [1.815 kB]
                                Holen:164 http://security.debian.org/debian-security bullseye-security/main amd64 libssl1.1 amd64 1.1.1n-0+deb11u5 [1.559 kB]
                                Holen:165 http://security.debian.org/debian-security bullseye-security/main amd64 ffmpeg amd64 7:4.3.6-0+deb11u1 [1.599 kB]
                                Holen:166 http://security.debian.org/debian-security bullseye-security/main amd64 libavdevice58 amd64 7:4.3.6-0+deb11u1 [128 kB]
                                Holen:167 http://security.debian.org/debian-security bullseye-security/main amd64 libavfilter7 amd64 7:4.3.6-0+deb11u1 [1.300 kB]
                                Holen:168 http://security.debian.org/debian-security bullseye-security/main amd64 libswscale5 amd64 7:4.3.6-0+deb11u1 [211 kB]
                                Holen:169 http://security.debian.org/debian-security bullseye-security/main amd64 libavformat58 amd64 7:4.3.6-0+deb11u1 [1.056 kB]
                                Holen:170 http://security.debian.org/debian-security bullseye-security/main amd64 libavcodec58 amd64 7:4.3.6-0+deb11u1 [4.961 kB]
                                Holen:171 http://security.debian.org/debian-security bullseye-security/main amd64 libswresample3 amd64 7:4.3.6-0+deb11u1 [110 kB]
                                Holen:172 http://security.debian.org/debian-security bullseye-security/main amd64 libpostproc55 amd64 7:4.3.6-0+deb11u1 [108 kB]
                                Holen:173 http://security.debian.org/debian-security bullseye-security/main amd64 libavresample4 amd64 7:4.3.6-0+deb11u1 [106 kB]
                                Holen:174 http://security.debian.org/debian-security bullseye-security/main amd64 libavutil56 amd64 7:4.3.6-0+deb11u1 [312 kB]
                                Holen:175 http://security.debian.org/debian-security bullseye-security/main amd64 libssh-gcrypt-4 amd64 0.9.7-0+deb11u1 [220 kB]
                                Holen:176 http://security.debian.org/debian-security bullseye-security/main amd64 libpq5 amd64 13.11-0+deb11u1 [180 kB]
                                Holen:177 http://security.debian.org/debian-security bullseye-security/main amd64 linux-image-5.10.0-23-amd64 amd64 5.10.179-1 [55,6 MB]
                                Holen:178 http://security.debian.org/debian-security bullseye-security/main amd64 linux-image-amd64 amd64 5.10.179-1 [1.484 B]
                                Holen:179 http://security.debian.org/debian-security bullseye-security/main amd64 openssl amd64 1.1.1n-0+deb11u5 [854 kB]
                                Holen:180 https://packages.grafana.com/oss/deb stable/main amd64 grafana amd64 10.0.1 [83,4 MB]
                                Es wurden 269 MB in 17 s geholt (16,1 MB/s).
                                Changelogs werden gelesen... Fertig
                                Extrahiere Vorlagen aus Paketen: 100%
                                Vorkonfiguration der Pakete ...
                                (Lese Datenbank ... 73705 Dateien und Verzeichnisse sind derzeit installiert.)
                                Vorbereitung zum Entpacken von .../base-files_11.1+deb11u7_amd64.deb ...
                                Entpacken von base-files (11.1+deb11u7) über (11.1+deb11u3) ...
                                base-files (11.1+deb11u7) wird eingerichtet ...
                                Neue Version der Konfigurationsdatei /etc/debian_version wird installiert ...
                                Vorbereitung zum Entpacken von .../bash_5.1-2+deb11u1_amd64.deb ...
                                Entpacken von bash (5.1-2+deb11u1) über (5.1-2+b3) ...
                                bash (5.1-2+deb11u1) wird eingerichtet ...
                                update-alternatives: /usr/share/man/man7/bash-builtins.7.gz wird verwendet, um /usr/share/man/man7/builtins.7.gz (builtins.7.gz) im automatischen Modus bereitzustellen
                                (Lese Datenbank ... 73704 Dateien und Verzeichnisse sind derzeit installiert.)
                                Vorbereitung zum Entpacken von .../dpkg_1.20.12_amd64.deb ...
                                Entpacken von dpkg (1.20.12) über (1.20.9) ...
                                dpkg (1.20.12) wird eingerichtet ...
                                (Lese Datenbank ... 73713 Dateien und Verzeichnisse sind derzeit installiert.)
                                Vorbereitung zum Entpacken von .../grep_3.6-1+deb11u1_amd64.deb ...
                                Entpacken von grep (3.6-1+deb11u1) über (3.6-1) ...
                                grep (3.6-1+deb11u1) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../gzip_1.10-4+deb11u1_amd64.deb ...
                                Entpacken von gzip (1.10-4+deb11u1) über (1.10-4) ...
                                gzip (1.10-4+deb11u1) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../ncurses-bin_6.2+20201114-2+deb11u1_amd64.deb ...
                                Entpacken von ncurses-bin (6.2+20201114-2+deb11u1) über (6.2+20201114-2) ...
                                ncurses-bin (6.2+20201114-2+deb11u1) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../libc-devtools_2.31-13+deb11u6_amd64.deb ...
                                Entpacken von libc-devtools (2.31-13+deb11u6) über (2.31-13+deb11u3) ...
                                Vorbereitung zum Entpacken von .../libc6-dev_2.31-13+deb11u6_amd64.deb ...
                                Entpacken von libc6-dev:amd64 (2.31-13+deb11u6) über (2.31-13+deb11u3) ...
                                Vorbereitung zum Entpacken von .../libc-dev-bin_2.31-13+deb11u6_amd64.deb ...
                                Entpacken von libc-dev-bin (2.31-13+deb11u6) über (2.31-13+deb11u3) ...
                                Vorbereitung zum Entpacken von .../linux-libc-dev_5.10.179-1_amd64.deb ...
                                Entpacken von linux-libc-dev:amd64 (5.10.179-1) über (5.10.106-1) ...
                                Vorbereitung zum Entpacken von .../libc6_2.31-13+deb11u6_amd64.deb ...
                                Entpacken von libc6:amd64 (2.31-13+deb11u6) über (2.31-13+deb11u3) ...
                                libc6:amd64 (2.31-13+deb11u6) wird eingerichtet ...
                                (Lese Datenbank ... 73714 Dateien und Verzeichnisse sind derzeit installiert.)
                                Vorbereitung zum Entpacken von .../libc-bin_2.31-13+deb11u6_amd64.deb ...
                                Entpacken von libc-bin (2.31-13+deb11u6) über (2.31-13+deb11u3) ...
                                libc-bin (2.31-13+deb11u6) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../ncurses-base_6.2+20201114-2+deb11u1_all.deb ...
                                Entpacken von ncurses-base (6.2+20201114-2+deb11u1) über (6.2+20201114-2) ...
                                ncurses-base (6.2+20201114-2+deb11u1) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../libnss-systemd_247.3-7+deb11u2_amd64.deb ...
                                Entpacken von libnss-systemd:amd64 (247.3-7+deb11u2) über (247.3-7) ...
                                Vorbereitung zum Entpacken von .../libudev-dev_247.3-7+deb11u2_amd64.deb ...
                                Entpacken von libudev-dev:amd64 (247.3-7+deb11u2) über (247.3-7) ...
                                Vorbereitung zum Entpacken von .../libsystemd0_247.3-7+deb11u2_amd64.deb ...
                                Entpacken von libsystemd0:amd64 (247.3-7+deb11u2) über (247.3-7) ...
                                libsystemd0:amd64 (247.3-7+deb11u2) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../systemd-timesyncd_247.3-7+deb11u2_amd64.deb ...
                                Entpacken von systemd-timesyncd (247.3-7+deb11u2) über (247.3-7) ...
                                Vorbereitung zum Entpacken von .../libpam-systemd_247.3-7+deb11u2_amd64.deb ...
                                Entpacken von libpam-systemd:amd64 (247.3-7+deb11u2) über (247.3-7) ...
                                Vorbereitung zum Entpacken von .../systemd_247.3-7+deb11u2_amd64.deb ...
                                Entpacken von systemd (247.3-7+deb11u2) über (247.3-7) ...
                                Vorbereitung zum Entpacken von .../udev_247.3-7+deb11u2_amd64.deb ...
                                Entpacken von udev (247.3-7+deb11u2) über (247.3-7) ...
                                Vorbereitung zum Entpacken von .../libudev1_247.3-7+deb11u2_amd64.deb ...
                                Entpacken von libudev1:amd64 (247.3-7+deb11u2) über (247.3-7) ...
                                libudev1:amd64 (247.3-7+deb11u2) wird eingerichtet ...
                                systemd (247.3-7+deb11u2) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../0-systemd-sysv_247.3-7+deb11u2_amd64.deb ...
                                Entpacken von systemd-sysv (247.3-7+deb11u2) über (247.3-7) ...
                                Vorbereitung zum Entpacken von .../1-libdbus-1-dev_1.12.24-0+deb11u1_amd64.deb ...
                                Entpacken von libdbus-1-dev:amd64 (1.12.24-0+deb11u1) über (1.12.20-2) ...
                                Vorbereitung zum Entpacken von .../2-dbus_1.12.24-0+deb11u1_amd64.deb ...
                                Entpacken von dbus (1.12.24-0+deb11u1) über (1.12.20-2) ...
                                Vorbereitung zum Entpacken von .../3-libdbus-1-3_1.12.24-0+deb11u1_amd64.deb ...
                                Entpacken von libdbus-1-3:amd64 (1.12.24-0+deb11u1) über (1.12.20-2) ...
                                Vorbereitung zum Entpacken von .../4-libexpat1-dev_2.2.10-2+deb11u5_amd64.deb ...
                                Entpacken von libexpat1-dev:amd64 (2.2.10-2+deb11u5) über (2.2.10-2+deb11u3) ...
                                Vorbereitung zum Entpacken von .../5-libexpat1_2.2.10-2+deb11u5_amd64.deb ...
                                Entpacken von libexpat1:amd64 (2.2.10-2+deb11u5) über (2.2.10-2+deb11u3) ...
                                Vorbereitung zum Entpacken von .../6-libtasn1-6_4.16.0-2+deb11u1_amd64.deb ...
                                Entpacken von libtasn1-6:amd64 (4.16.0-2+deb11u1) über (4.16.0-2) ...
                                libtasn1-6:amd64 (4.16.0-2+deb11u1) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../libgnutls30_3.7.1-5+deb11u3_amd64.deb ...
                                Entpacken von libgnutls30:amd64 (3.7.1-5+deb11u3) über (3.7.1-5) ...
                                libgnutls30:amd64 (3.7.1-5+deb11u3) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../nftables_0.9.8-3.1+deb11u1_amd64.deb ...
                                Entpacken von nftables (0.9.8-3.1+deb11u1) über (0.9.8-3.1) ...
                                Vorbereitung zum Entpacken von .../libnftables1_0.9.8-3.1+deb11u1_amd64.deb ...
                                Entpacken von libnftables1:amd64 (0.9.8-3.1+deb11u1) über (0.9.8-3.1) ...
                                Vorbereitung zum Entpacken von .../zlib1g-dev_1%3a1.2.11.dfsg-2+deb11u2_amd64.deb ...
                                Entpacken von zlib1g-dev:amd64 (1:1.2.11.dfsg-2+deb11u2) über (1:1.2.11.dfsg-2+deb11u1) ...
                                Vorbereitung zum Entpacken von .../zlib1g_1%3a1.2.11.dfsg-2+deb11u2_amd64.deb ...
                                Entpacken von zlib1g:amd64 (1:1.2.11.dfsg-2+deb11u2) über (1:1.2.11.dfsg-2+deb11u1) ...
                                zlib1g:amd64 (1:1.2.11.dfsg-2+deb11u2) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../00-rsyslog_8.2102.0-2+deb11u1_amd64.deb ...
                                Entpacken von rsyslog (8.2102.0-2+deb11u1) über (8.2102.0-2) ...
                                Vorbereitung zum Entpacken von .../01-libmagick++-6.q16-dev_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                                Entpacken von libmagick++-6.q16-dev:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                                Vorbereitung zum Entpacken von .../02-libmagick++-dev_8%3a6.9.11.60+dfsg-1.3+deb11u1_all.deb ...
                                Entpacken von libmagick++-dev (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                                Vorbereitung zum Entpacken von .../03-libmagick++-6-headers_8%3a6.9.11.60+dfsg-1.3+deb11u1_all.deb ...
                                Entpacken von libmagick++-6-headers (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                                Vorbereitung zum Entpacken von .../04-libmagickwand-6.q16-dev_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                                Entpacken von libmagickwand-6.q16-dev:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                                Vorbereitung zum Entpacken von .../05-libmagickwand-6-headers_8%3a6.9.11.60+dfsg-1.3+deb11u1_all.deb ...
                                Entpacken von libmagickwand-6-headers (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                                Vorbereitung zum Entpacken von .../06-libmagickcore-6.q16-dev_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                                Entpacken von libmagickcore-6.q16-dev:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                                Vorbereitung zum Entpacken von .../07-libmagickcore-6-arch-config_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                                Entpacken von libmagickcore-6-arch-config:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                                Vorbereitung zum Entpacken von .../08-libmagickcore-6-headers_8%3a6.9.11.60+dfsg-1.3+deb11u1_all.deb ...
                                Entpacken von libmagickcore-6-headers (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                                Vorbereitung zum Entpacken von .../09-imagemagick-6-common_8%3a6.9.11.60+dfsg-1.3+deb11u1_all.deb ...
                                Entpacken von imagemagick-6-common (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                                Vorbereitung zum Entpacken von .../10-libx11-data_2%3a1.7.2-1+deb11u1_all.deb ...
                                Entpacken von libx11-data (2:1.7.2-1+deb11u1) über (2:1.7.2-1) ...
                                Vorbereitung zum Entpacken von .../11-libx11-dev_2%3a1.7.2-1+deb11u1_amd64.deb ...
                                Entpacken von libx11-dev:amd64 (2:1.7.2-1+deb11u1) über (2:1.7.2-1) ...
                                Vorbereitung zum Entpacken von .../12-libx11-6_2%3a1.7.2-1+deb11u1_amd64.deb ...
                                Entpacken von libx11-6:amd64 (2:1.7.2-1+deb11u1) über (2:1.7.2-1) ...
                                Vorbereitung zum Entpacken von .../13-libx11-xcb1_2%3a1.7.2-1+deb11u1_amd64.deb ...
                                Entpacken von libx11-xcb1:amd64 (2:1.7.2-1+deb11u1) über (2:1.7.2-1) ...
                                Vorbereitung zum Entpacken von .../14-libmagickwand-6.q16-6_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                                Entpacken von libmagickwand-6.q16-6:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                                Vorbereitung zum Entpacken von .../15-libopenexr-dev_2.5.4-2+deb11u1_amd64.deb ...
                                Entpacken von libopenexr-dev (2.5.4-2+deb11u1) über (2.5.4-2) ...
                                Vorbereitung zum Entpacken von .../16-libopenexr25_2.5.4-2+deb11u1_amd64.deb ...
                                Entpacken von libopenexr25:amd64 (2.5.4-2+deb11u1) über (2.5.4-2) ...
                                Vorbereitung zum Entpacken von .../17-libxml2-dev_2.9.10+dfsg-6.7+deb11u4_amd64.deb ...
                                Entpacken von libxml2-dev:amd64 (2.9.10+dfsg-6.7+deb11u4) über (2.9.10+dfsg-6.7+deb11u1) ...
                                Vorbereitung zum Entpacken von .../18-liblzma-dev_5.2.5-2.1~deb11u1_amd64.deb ...
                                Entpacken von liblzma-dev:amd64 (5.2.5-2.1~deb11u1) über (5.2.5-2) ...
                                Vorbereitung zum Entpacken von .../19-liblzma5_5.2.5-2.1~deb11u1_amd64.deb ...
                                Entpacken von liblzma5:amd64 (5.2.5-2.1~deb11u1) über (5.2.5-2) ...
                                liblzma5:amd64 (5.2.5-2.1~deb11u1) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../00-libxml2_2.9.10+dfsg-6.7+deb11u4_amd64.deb ...
                                Entpacken von libxml2:amd64 (2.9.10+dfsg-6.7+deb11u4) über (2.9.10+dfsg-6.7+deb11u1) ...
                                Vorbereitung zum Entpacken von .../01-libmagickcore-6.q16-6-extra_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                                Entpacken von libmagickcore-6.q16-6-extra:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                                Vorbereitung zum Entpacken von .../02-libfreetype6-dev_2.10.4+dfsg-1+deb11u1_amd64.deb ...
                                Entpacken von libfreetype6-dev:amd64 (2.10.4+dfsg-1+deb11u1) über (2.10.4+dfsg-1) ...
                                Vorbereitung zum Entpacken von .../03-libfreetype-dev_2.10.4+dfsg-1+deb11u1_amd64.deb ...
                                Entpacken von libfreetype-dev:amd64 (2.10.4+dfsg-1+deb11u1) über (2.10.4+dfsg-1) ...
                                Vorbereitung zum Entpacken von .../04-libfreetype6_2.10.4+dfsg-1+deb11u1_amd64.deb ...
                                Entpacken von libfreetype6:amd64 (2.10.4+dfsg-1+deb11u1) über (2.10.4+dfsg-1) ...
                                Vorbereitung zum Entpacken von .../05-libwebp6_0.6.1-2.1+deb11u1_amd64.deb ...
                                Entpacken von libwebp6:amd64 (0.6.1-2.1+deb11u1) über (0.6.1-2.1) ...
                                Vorbereitung zum Entpacken von .../06-libtiff-dev_4.2.0-1+deb11u4_amd64.deb ...
                                Entpacken von libtiff-dev:amd64 (4.2.0-1+deb11u4) über (4.2.0-1+deb11u1) ...
                                Vorbereitung zum Entpacken von .../07-libtiff5_4.2.0-1+deb11u4_amd64.deb ...
                                Entpacken von libtiff5:amd64 (4.2.0-1+deb11u4) über (4.2.0-1+deb11u1) ...
                                Vorbereitung zum Entpacken von .../08-libtiffxx5_4.2.0-1+deb11u4_amd64.deb ...
                                Entpacken von libtiffxx5:amd64 (4.2.0-1+deb11u4) über (4.2.0-1+deb11u1) ...
                                Vorbereitung zum Entpacken von .../09-libwebpdemux2_0.6.1-2.1+deb11u1_amd64.deb ...
                                Entpacken von libwebpdemux2:amd64 (0.6.1-2.1+deb11u1) über (0.6.1-2.1) ...
                                Vorbereitung zum Entpacken von .../10-libwebpmux3_0.6.1-2.1+deb11u1_amd64.deb ...
                                Entpacken von libwebpmux3:amd64 (0.6.1-2.1+deb11u1) über (0.6.1-2.1) ...
                                Vorbereitung zum Entpacken von .../11-libmagickcore-6.q16-6_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                                Entpacken von libmagickcore-6.q16-6:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                                Vorbereitung zum Entpacken von .../12-libmagick++-6.q16-8_8%3a6.9.11.60+dfsg-1.3+deb11u1_amd64.deb ...
                                Entpacken von libmagick++-6.q16-8:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) über (8:6.9.11.60+dfsg-1.3) ...
                                Vorbereitung zum Entpacken von .../13-libwbclient0_2%3a4.13.13+dfsg-1~deb11u5_amd64.deb ...
                                Entpacken von libwbclient0:amd64 (2:4.13.13+dfsg-1~deb11u5) über (2:4.13.13+dfsg-1~deb11u3) ...
                                Vorbereitung zum Entpacken von .../14-debian-archive-keyring_2021.1.1+deb11u1_all.deb ...
                                Entpacken von debian-archive-keyring (2021.1.1+deb11u1) über (2021.1.1) ...
                                debian-archive-keyring (2021.1.1+deb11u1) wird eingerichtet ...
                                Removing obsolete conffile /etc/apt/trusted.gpg.d/debian-archive-stretch-automatic.gpg ...
                                Removing obsolete conffile /etc/apt/trusted.gpg.d/debian-archive-stretch-security-automatic.gpg ...
                                Removing obsolete conffile /etc/apt/trusted.gpg.d/debian-archive-stretch-stable.gpg ...
                                Vorbereitung zum Entpacken von .../libk5crypto3_1.18.3-6+deb11u3_amd64.deb ...
                                Entpacken von libk5crypto3:amd64 (1.18.3-6+deb11u3) über (1.18.3-6+deb11u1) ...
                                libk5crypto3:amd64 (1.18.3-6+deb11u3) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../libkrb5support0_1.18.3-6+deb11u3_amd64.deb ...
                                Entpacken von libkrb5support0:amd64 (1.18.3-6+deb11u3) über (1.18.3-6+deb11u1) ...
                                libkrb5support0:amd64 (1.18.3-6+deb11u3) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../libkrb5-3_1.18.3-6+deb11u3_amd64.deb ...
                                Entpacken von libkrb5-3:amd64 (1.18.3-6+deb11u3) über (1.18.3-6+deb11u1) ...
                                libkrb5-3:amd64 (1.18.3-6+deb11u3) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../libgssapi-krb5-2_1.18.3-6+deb11u3_amd64.deb ...
                                Entpacken von libgssapi-krb5-2:amd64 (1.18.3-6+deb11u3) über (1.18.3-6+deb11u1) ...
                                libgssapi-krb5-2:amd64 (1.18.3-6+deb11u3) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../libssl-dev_1.1.1n-0+deb11u5_amd64.deb ...
                                Entpacken von libssl-dev:amd64 (1.1.1n-0+deb11u5) über (1.1.1n-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../libssl1.1_1.1.1n-0+deb11u5_amd64.deb ...
                                Entpacken von libssl1.1:amd64 (1.1.1n-0+deb11u5) über (1.1.1n-0+deb11u1) ...
                                libssl1.1:amd64 (1.1.1n-0+deb11u5) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../libpcre2-dev_10.36-2+deb11u1_amd64.deb ...
                                Entpacken von libpcre2-dev:amd64 (10.36-2+deb11u1) über (10.36-2) ...
                                Vorbereitung zum Entpacken von .../libpcre2-16-0_10.36-2+deb11u1_amd64.deb ...
                                Entpacken von libpcre2-16-0:amd64 (10.36-2+deb11u1) über (10.36-2) ...
                                Vorbereitung zum Entpacken von .../libpcre2-32-0_10.36-2+deb11u1_amd64.deb ...
                                Entpacken von libpcre2-32-0:amd64 (10.36-2+deb11u1) über (10.36-2) ...
                                Vorbereitung zum Entpacken von .../libpcre2-posix2_10.36-2+deb11u1_amd64.deb ...
                                Entpacken von libpcre2-posix2:amd64 (10.36-2+deb11u1) über (10.36-2) ...
                                Vorbereitung zum Entpacken von .../libpcre2-8-0_10.36-2+deb11u1_amd64.deb ...
                                Entpacken von libpcre2-8-0:amd64 (10.36-2+deb11u1) über (10.36-2) ...
                                libpcre2-8-0:amd64 (10.36-2+deb11u1) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../libncurses6_6.2+20201114-2+deb11u1_amd64.deb ...
                                Entpacken von libncurses6:amd64 (6.2+20201114-2+deb11u1) über (6.2+20201114-2) ...
                                Vorbereitung zum Entpacken von .../libncursesw6_6.2+20201114-2+deb11u1_amd64.deb ...
                                Entpacken von libncursesw6:amd64 (6.2+20201114-2+deb11u1) über (6.2+20201114-2) ...
                                Vorbereitung zum Entpacken von .../libtinfo6_6.2+20201114-2+deb11u1_amd64.deb ...
                                Entpacken von libtinfo6:amd64 (6.2+20201114-2+deb11u1) über (6.2+20201114-2) ...
                                libtinfo6:amd64 (6.2+20201114-2+deb11u1) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../libtirpc-common_1.3.1-1+deb11u1_all.deb ...
                                Entpacken von libtirpc-common (1.3.1-1+deb11u1) über (1.3.1-1) ...
                                libtirpc-common (1.3.1-1+deb11u1) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../libtirpc-dev_1.3.1-1+deb11u1_amd64.deb ...
                                Entpacken von libtirpc-dev:amd64 (1.3.1-1+deb11u1) über (1.3.1-1) ...
                                Vorbereitung zum Entpacken von .../libtirpc3_1.3.1-1+deb11u1_amd64.deb ...
                                Entpacken von libtirpc3:amd64 (1.3.1-1+deb11u1) über (1.3.1-1) ...
                                libtirpc3:amd64 (1.3.1-1+deb11u1) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../00-tzdata_2021a-1+deb11u10_all.deb ...
                                Entpacken von tzdata (2021a-1+deb11u10) über (2021a-1+deb11u3) ...
                                Vorbereitung zum Entpacken von .../01-isc-dhcp-client_4.4.1-2.3+deb11u2_amd64.deb ...
                                Entpacken von isc-dhcp-client (4.4.1-2.3+deb11u2) über (4.4.1-2.3) ...
                                Vorbereitung zum Entpacken von .../02-isc-dhcp-common_4.4.1-2.3+deb11u2_amd64.deb ...
                                Entpacken von isc-dhcp-common (4.4.1-2.3+deb11u2) über (4.4.1-2.3) ...
                                Vorbereitung zum Entpacken von .../03-logrotate_3.18.0-2+deb11u1_amd64.deb ...
                                Entpacken von logrotate (3.18.0-2+deb11u1) über (3.18.0-2) ...
                                Vorbereitung zum Entpacken von .../04-nano_5.4-2+deb11u2_amd64.deb ...
                                Entpacken von nano (5.4-2+deb11u2) über (5.4-2) ...
                                Vorbereitung zum Entpacken von .../05-bind9-dnsutils_1%3a9.16.37-1~deb11u1_amd64.deb ...
                                Entpacken von bind9-dnsutils (1:9.16.37-1~deb11u1) über (1:9.16.27-1~deb11u1) ...
                                Vorbereitung zum Entpacken von .../06-bind9-libs_1%3a9.16.37-1~deb11u1_amd64.deb ...
                                Entpacken von bind9-libs:amd64 (1:9.16.37-1~deb11u1) über (1:9.16.27-1~deb11u1) ...
                                Vorbereitung zum Entpacken von .../07-bind9-host_1%3a9.16.37-1~deb11u1_amd64.deb ...
                                Entpacken von bind9-host (1:9.16.37-1~deb11u1) über (1:9.16.27-1~deb11u1) ...
                                Vorbereitung zum Entpacken von .../08-krb5-locales_1.18.3-6+deb11u3_all.deb ...
                                Entpacken von krb5-locales (1.18.3-6+deb11u3) über (1.18.3-6+deb11u1) ...
                                Vorbereitung zum Entpacken von .../09-libc-l10n_2.31-13+deb11u6_all.deb ...
                                Entpacken von libc-l10n (2.31-13+deb11u6) über (2.31-13+deb11u3) ...
                                Vorbereitung zum Entpacken von .../10-locales_2.31-13+deb11u6_all.deb ...
                                Entpacken von locales (2.31-13+deb11u6) über (2.31-13+deb11u3) ...
                                Vorbereitung zum Entpacken von .../11-ncurses-term_6.2+20201114-2+deb11u1_all.deb ...
                                Entpacken von ncurses-term (6.2+20201114-2+deb11u1) über (6.2+20201114-2) ...
                                Vorbereitung zum Entpacken von .../12-openssh-sftp-server_1%3a8.4p1-5+deb11u1_amd64.deb ...
                                Entpacken von openssh-sftp-server (1:8.4p1-5+deb11u1) über (1:8.4p1-5) ...
                                Vorbereitung zum Entpacken von .../13-openssh-server_1%3a8.4p1-5+deb11u1_amd64.deb ...
                                Entpacken von openssh-server (1:8.4p1-5+deb11u1) über (1:8.4p1-5) ...
                                Vorbereitung zum Entpacken von .../14-git-man_1%3a2.30.2-1+deb11u2_all.deb ...
                                Entpacken von git-man (1:2.30.2-1+deb11u2) über (1:2.30.2-1) ...
                                Vorbereitung zum Entpacken von .../15-libldap-2.4-2_2.4.57+dfsg-3+deb11u1_amd64.deb ...
                                Entpacken von libldap-2.4-2:amd64 (2.4.57+dfsg-3+deb11u1) über (2.4.57+dfsg-3) ...
                                Vorbereitung zum Entpacken von .../16-libcurl3-gnutls_7.74.0-1.3+deb11u7_amd64.deb ...
                                Entpacken von libcurl3-gnutls:amd64 (7.74.0-1.3+deb11u7) über (7.74.0-1.3+deb11u1) ...
                                Vorbereitung zum Entpacken von .../17-git_1%3a2.30.2-1+deb11u2_amd64.deb ...
                                Entpacken von git (1:2.30.2-1+deb11u2) über (1:2.30.2-1) ...
                                Vorbereitung zum Entpacken von .../18-openssh-client_1%3a8.4p1-5+deb11u1_amd64.deb ...
                                Entpacken von openssh-client (1:8.4p1-5+deb11u1) über (1:8.4p1-5) ...
                                Vorbereitung zum Entpacken von .../19-traceroute_1%3a2.1.0-2+deb11u1_amd64.deb ...
                                Entpacken von traceroute (1:2.1.0-2+deb11u1) über (1:2.1.0-2+b1) ...
                                Vorbereitung zum Entpacken von .../20-xz-utils_5.2.5-2.1~deb11u1_amd64.deb ...
                                Entpacken von xz-utils (5.2.5-2.1~deb11u1) über (5.2.5-2) ...
                                Vorbereitung zum Entpacken von .../21-libatspi2.0-0_2.38.0-4+deb11u1_amd64.deb ...
                                Entpacken von libatspi2.0-0:amd64 (2.38.0-4+deb11u1) über (2.38.0-4) ...
                                Vorbereitung zum Entpacken von .../22-at-spi2-core_2.38.0-4+deb11u1_amd64.deb ...
                                Entpacken von at-spi2-core (2.38.0-4+deb11u1) über (2.38.0-4) ...
                                Vorbereitung zum Entpacken von .../23-cifs-utils_2%3a6.11-3.1+deb11u1_amd64.deb ...
                                Entpacken von cifs-utils (2:6.11-3.1+deb11u1) über (2:6.11-3.1) ...
                                Vorbereitung zum Entpacken von .../24-libcurl4-openssl-dev_7.74.0-1.3+deb11u7_amd64.deb ...
                                Entpacken von libcurl4-openssl-dev:amd64 (7.74.0-1.3+deb11u7) über (7.74.0-1.3+deb11u5) ...
                                Vorbereitung zum Entpacken von .../25-curl_7.74.0-1.3+deb11u7_amd64.deb ...
                                Entpacken von curl (7.74.0-1.3+deb11u7) über (7.74.0-1.3+deb11u5) ...
                                Vorbereitung zum Entpacken von .../26-libcurl4_7.74.0-1.3+deb11u7_amd64.deb ...
                                Entpacken von libcurl4:amd64 (7.74.0-1.3+deb11u7) über (7.74.0-1.3+deb11u5) ...
                                Vorbereitung zum Entpacken von .../27-dbus-user-session_1.12.24-0+deb11u1_amd64.deb ...
                                Entpacken von dbus-user-session (1.12.24-0+deb11u1) über (1.12.20-2) ...
                                Vorbereitung zum Entpacken von .../28-distro-info-data_0.51+deb11u3_all.deb ...
                                Entpacken von distro-info-data (0.51+deb11u3) über (0.51+deb11u1) ...
                                Vorbereitung zum Entpacken von .../29-dpkg-dev_1.20.12_all.deb ...
                                Entpacken von dpkg-dev (1.20.12) über (1.20.9) ...
                                Vorbereitung zum Entpacken von .../30-libdpkg-perl_1.20.12_all.deb ...
                                Entpacken von libdpkg-perl (1.20.12) über (1.20.9) ...
                                Vorbereitung zum Entpacken von .../31-ffmpeg_7%3a4.3.6-0+deb11u1_amd64.deb ...
                                Entpacken von ffmpeg (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../32-libavdevice58_7%3a4.3.6-0+deb11u1_amd64.deb ...
                                Entpacken von libavdevice58:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../33-libavfilter7_7%3a4.3.6-0+deb11u1_amd64.deb ...
                                Entpacken von libavfilter7:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../34-libswscale5_7%3a4.3.6-0+deb11u1_amd64.deb ...
                                Entpacken von libswscale5:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../35-libavformat58_7%3a4.3.6-0+deb11u1_amd64.deb ...
                                Entpacken von libavformat58:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../36-libavcodec58_7%3a4.3.6-0+deb11u1_amd64.deb ...
                                Entpacken von libavcodec58:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../37-libswresample3_7%3a4.3.6-0+deb11u1_amd64.deb ...
                                Entpacken von libswresample3:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../38-libpostproc55_7%3a4.3.6-0+deb11u1_amd64.deb ...
                                Entpacken von libpostproc55:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../39-libavresample4_7%3a4.3.6-0+deb11u1_amd64.deb ...
                                Entpacken von libavresample4:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../40-libavutil56_7%3a4.3.6-0+deb11u1_amd64.deb ...
                                Entpacken von libavutil56:amd64 (7:4.3.6-0+deb11u1) über (7:4.3.3-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../41-libsdl2-2.0-0_2.0.14+dfsg2-3+deb11u1_amd64.deb ...
                                Entpacken von libsdl2-2.0-0:amd64 (2.0.14+dfsg2-3+deb11u1) über (2.0.14+dfsg2-3) ...
                                Vorbereitung zum Entpacken von .../42-libfribidi-dev_1.0.8-2+deb11u1_amd64.deb ...
                                Entpacken von libfribidi-dev:amd64 (1.0.8-2+deb11u1) über (1.0.8-2) ...
                                Vorbereitung zum Entpacken von .../43-libfribidi0_1.0.8-2+deb11u1_amd64.deb ...
                                Entpacken von libfribidi0:amd64 (1.0.8-2+deb11u1) über (1.0.8-2) ...
                                Vorbereitung zum Entpacken von .../44-libbluray2_1%3a1.2.1-4+deb11u2_amd64.deb ...
                                Entpacken von libbluray2:amd64 (1:1.2.1-4+deb11u2) über (1:1.2.1-4+deb11u1) ...
                                Vorbereitung zum Entpacken von .../45-libssh-gcrypt-4_0.9.7-0+deb11u1_amd64.deb ...
                                Entpacken von libssh-gcrypt-4:amd64 (0.9.7-0+deb11u1) über (0.9.5-1+deb11u1) ...
                                Vorbereitung zum Entpacken von .../46-ghostscript_9.53.3~dfsg-7+deb11u4_amd64.deb ...
                                Entpacken von ghostscript (9.53.3~dfsg-7+deb11u4) über (9.53.3~dfsg-7+deb11u2) ...
                                Vorbereitung zum Entpacken von .../47-libgs9_9.53.3~dfsg-7+deb11u4_amd64.deb ...
                                Entpacken von libgs9:amd64 (9.53.3~dfsg-7+deb11u4) über (9.53.3~dfsg-7+deb11u2) ...
                                Vorbereitung zum Entpacken von .../48-libgs9-common_9.53.3~dfsg-7+deb11u4_all.deb ...
                                Entpacken von libgs9-common (9.53.3~dfsg-7+deb11u4) über (9.53.3~dfsg-7+deb11u2) ...
                                Vorbereitung zum Entpacken von .../49-libavahi-compat-libdnssd-dev_0.8-5+deb11u2_amd64.deb ...
                                Entpacken von libavahi-compat-libdnssd-dev:amd64 (0.8-5+deb11u2) über (0.8-5) ...
                                Vorbereitung zum Entpacken von .../50-libavahi-compat-libdnssd1_0.8-5+deb11u2_amd64.deb ...
                                Entpacken von libavahi-compat-libdnssd1:amd64 (0.8-5+deb11u2) über (0.8-5) ...
                                Vorbereitung zum Entpacken von .../51-libavahi-client-dev_0.8-5+deb11u2_amd64.deb ...
                                Entpacken von libavahi-client-dev:amd64 (0.8-5+deb11u2) über (0.8-5) ...
                                Vorbereitung zum Entpacken von .../52-libavahi-client3_0.8-5+deb11u2_amd64.deb ...
                                Entpacken von libavahi-client3:amd64 (0.8-5+deb11u2) über (0.8-5) ...
                                Vorbereitung zum Entpacken von .../53-libavahi-common-dev_0.8-5+deb11u2_amd64.deb ...
                                Entpacken von libavahi-common-dev:amd64 (0.8-5+deb11u2) über (0.8-5) ...
                                Vorbereitung zum Entpacken von .../54-libavahi-common3_0.8-5+deb11u2_amd64.deb ...
                                Entpacken von libavahi-common3:amd64 (0.8-5+deb11u2) über (0.8-5) ...
                                Vorbereitung zum Entpacken von .../55-libavahi-common-data_0.8-5+deb11u2_amd64.deb ...
                                Entpacken von libavahi-common-data:amd64 (0.8-5+deb11u2) über (0.8-5) ...
                                Vorbereitung zum Entpacken von .../56-libcups2_2.3.3op2-3+deb11u2_amd64.deb ...
                                Entpacken von libcups2:amd64 (2.3.3op2-3+deb11u2) über (2.3.3op2-3+deb11u1) ...
                                Vorbereitung zum Entpacken von .../57-libgdk-pixbuf-2.0-dev_2.42.2+dfsg-1+deb11u1_amd64.deb ...
                                Entpacken von libgdk-pixbuf-2.0-dev:amd64 (2.42.2+dfsg-1+deb11u1) über (2.42.2+dfsg-1) ...
                                Vorbereitung zum Entpacken von .../58-libgdk-pixbuf-2.0-0_2.42.2+dfsg-1+deb11u1_amd64.deb ...
                                Entpacken von libgdk-pixbuf-2.0-0:amd64 (2.42.2+dfsg-1+deb11u1) über (2.42.2+dfsg-1) ...
                                Vorbereitung zum Entpacken von .../59-libgdk-pixbuf2.0-common_2.42.2+dfsg-1+deb11u1_all.deb ...
                                Entpacken von libgdk-pixbuf2.0-common (2.42.2+dfsg-1+deb11u1) über (2.42.2+dfsg-1) ...
                                Vorbereitung zum Entpacken von .../60-libgdk-pixbuf2.0-bin_2.42.2+dfsg-1+deb11u1_amd64.deb ...
                                Entpacken von libgdk-pixbuf2.0-bin (2.42.2+dfsg-1+deb11u1) über (2.42.2+dfsg-1) ...
                                Vorbereitung zum Entpacken von .../61-gir1.2-gdkpixbuf-2.0_2.42.2+dfsg-1+deb11u1_amd64.deb ...
                                Entpacken von gir1.2-gdkpixbuf-2.0:amd64 (2.42.2+dfsg-1+deb11u1) über (2.42.2+dfsg-1) ...
                                Vorbereitung zum Entpacken von .../62-grafana_10.0.1_amd64.deb ...
                                Entpacken von grafana (10.0.1) über (9.3.6) ...
                                Vorbereitung zum Entpacken von .../63-grub-efi-amd64_2.06-3~deb11u5_amd64.deb ...
                                Entpacken von grub-efi-amd64 (2.06-3~deb11u5) über (2.04-20) ...
                                Vorbereitung zum Entpacken von .../64-grub2-common_2.06-3~deb11u5_amd64.deb ...
                                Entpacken von grub2-common (2.06-3~deb11u5) über (2.04-20) ...
                                Vorbereitung zum Entpacken von .../65-grub-efi-amd64-bin_2.06-3~deb11u5_amd64.deb ...
                                Entpacken von grub-efi-amd64-bin (2.06-3~deb11u5) über (2.04-20) ...
                                Vorbereitung zum Entpacken von .../66-grub-common_2.06-3~deb11u5_amd64.deb ...
                                Entpacken von grub-common (2.06-3~deb11u5) über (2.04-20) ...
                                Vorbereitung zum Entpacken von .../67-grub-efi-amd64-signed_1+2.06+3~deb11u5_amd64.deb ...
                                Entpacken von grub-efi-amd64-signed (1+2.06+3~deb11u5) über (1+2.04+20) ...
                                Vorbereitung zum Entpacken von .../68-gtk-update-icon-cache_3.24.24-4+deb11u3_amd64.deb ...
                                Entpacken von gtk-update-icon-cache (3.24.24-4+deb11u3) über (3.24.24-4+deb11u2) ...
                                Vorbereitung zum Entpacken von .../69-libde265-0_1.0.11-0+deb11u1_amd64.deb ...
                                Entpacken von libde265-0:amd64 (1.0.11-0+deb11u1) über (1.0.8-1) ...
                                Vorbereitung zum Entpacken von .../70-libgtk-3-common_3.24.24-4+deb11u3_all.deb ...
                                Entpacken von libgtk-3-common (3.24.24-4+deb11u3) über (3.24.24-4+deb11u2) ...
                                Vorbereitung zum Entpacken von .../71-libgtk-3-0_3.24.24-4+deb11u3_amd64.deb ...
                                Entpacken von libgtk-3-0:amd64 (3.24.24-4+deb11u3) über (3.24.24-4+deb11u2) ...
                                Vorbereitung zum Entpacken von .../72-libgtk-3-bin_3.24.24-4+deb11u3_amd64.deb ...
                                Entpacken von libgtk-3-bin (3.24.24-4+deb11u3) über (3.24.24-4+deb11u2) ...
                                Vorbereitung zum Entpacken von .../73-libhttp-daemon-perl_6.12-1+deb11u1_all.deb ...
                                Entpacken von libhttp-daemon-perl (6.12-1+deb11u1) über (6.12-1) ...
                                Vorbereitung zum Entpacken von .../74-libksba8_1.5.0-3+deb11u2_amd64.deb ...
                                Entpacken von libksba8:amd64 (1.5.0-3+deb11u2) über (1.5.0-3) ...
                                Vorbereitung zum Entpacken von .../75-libldap-common_2.4.57+dfsg-3+deb11u1_all.deb ...
                                Entpacken von libldap-common (2.4.57+dfsg-3+deb11u1) über (2.4.57+dfsg-3) ...
                                Vorbereitung zum Entpacken von .../76-mariadb-common_1%3a10.5.19-0+deb11u2_all.deb ...
                                Entpacken von mariadb-common (1:10.5.19-0+deb11u2) über (1:10.5.15-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../77-libmariadb3_1%3a10.5.19-0+deb11u2_amd64.deb ...
                                Entpacken von libmariadb3:amd64 (1:10.5.19-0+deb11u2) über (1:10.5.15-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../78-libnss3_2%3a3.61-1+deb11u3_amd64.deb ...
                                Entpacken von libnss3:amd64 (2:3.61-1+deb11u3) über (2:3.61-1+deb11u2) ...
                                Vorbereitung zum Entpacken von .../79-libpixman-1-dev_0.40.0-1.1~deb11u1_amd64.deb ...
                                Entpacken von libpixman-1-dev:amd64 (0.40.0-1.1~deb11u1) über (0.40.0-1) ...
                                Vorbereitung zum Entpacken von .../80-libpixman-1-0_0.40.0-1.1~deb11u1_amd64.deb ...
                                Entpacken von libpixman-1-0:amd64 (0.40.0-1.1~deb11u1) über (0.40.0-1) ...
                                Vorbereitung zum Entpacken von .../81-libpq5_13.11-0+deb11u1_amd64.deb ...
                                Entpacken von libpq5:amd64 (13.11-0+deb11u1) über (13.5-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../82-libxpm4_1%3a3.5.12-1.1~deb11u1_amd64.deb ...
                                Entpacken von libxpm4:amd64 (1:3.5.12-1.1~deb11u1) über (1:3.5.12-1) ...
                                Vormals nicht ausgewähltes Paket linux-image-5.10.0-23-amd64 wird gewählt.
                                Vorbereitung zum Entpacken von .../83-linux-image-5.10.0-23-amd64_5.10.179-1_amd64.deb ...
                                Entpacken von linux-image-5.10.0-23-amd64 (5.10.179-1) ...
                                Vorbereitung zum Entpacken von .../84-linux-image-amd64_5.10.179-1_amd64.deb ...
                                Entpacken von linux-image-amd64 (5.10.179-1) über (5.10.106-1) ...
                                Vorbereitung zum Entpacken von .../85-mokutil_0.6.0-2~deb11u1_amd64.deb ...
                                Entpacken von mokutil (0.6.0-2~deb11u1) über (0.3.0+1538710437.fb6250f-1+b1) ...
                                Vorbereitung zum Entpacken von .../86-nodejs_16.20.1-deb-1nodesource1_amd64.deb ...
                                Entpacken von nodejs (16.20.1-deb-1nodesource1) über (16.17.1-deb-1nodesource1) ...
                                Vorbereitung zum Entpacken von .../87-openssl_1.1.1n-0+deb11u5_amd64.deb ...
                                Entpacken von openssl (1.1.1n-0+deb11u5) über (1.1.1n-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../88-publicsuffix_20220811.1734-0+deb11u1_all.deb ...
                                Entpacken von publicsuffix (20220811.1734-0+deb11u1) über (20211207.1025-0+deb11u1) ...
                                Vorbereitung zum Entpacken von .../89-shim-unsigned_15.7-1~deb11u1_amd64.deb ...
                                Entpacken von shim-unsigned (15.7-1~deb11u1) über (15.4-7) ...
                                Vorbereitung zum Entpacken von .../90-shim-helpers-amd64-signed_1+15.7+1~deb11u1_amd64.deb ...
                                Entpacken von shim-helpers-amd64-signed (1+15.7+1~deb11u1) über (1+15.4+7) ...
                                Vorbereitung zum Entpacken von .../91-shim-signed-common_1.39~1+deb11u1+15.7-1~deb11u1_all.deb ...
                                Entpacken von shim-signed-common (1.39~1+deb11u1+15.7-1~deb11u1) über (1.38+15.4-7) ...
                                Vorbereitung zum Entpacken von .../92-shim-signed_1.39~1+deb11u1+15.7-1~deb11u1_amd64.deb ...
                                Entpacken von shim-signed:amd64 (1.39~1+deb11u1+15.7-1~deb11u1) über (1.38+15.4-7) ...
                                Vorbereitung zum Entpacken von .../93-sudo_1.9.5p2-3+deb11u1_amd64.deb ...
                                Entpacken von sudo (1.9.5p2-3+deb11u1) über (1.9.5p2-3) ...
                                Vorbereitung zum Entpacken von .../94-unzip_6.0-26+deb11u1_amd64.deb ...
                                Entpacken von unzip (6.0-26+deb11u1) über (6.0-26) ...
                                libssh-gcrypt-4:amd64 (0.9.7-0+deb11u1) wird eingerichtet ...
                                libksba8:amd64 (1.5.0-3+deb11u2) wird eingerichtet ...
                                libgs9-common (9.53.3~dfsg-7+deb11u4) wird eingerichtet ...
                                logrotate (3.18.0-2+deb11u1) wird eingerichtet ...
                                logrotate.service is a disabled or a static unit not running, not starting it.
                                libexpat1:amd64 (2.2.10-2+deb11u5) wird eingerichtet ...
                                libpixman-1-0:amd64 (0.40.0-1.1~deb11u1) wird eingerichtet ...
                                systemd-sysv (247.3-7+deb11u2) wird eingerichtet ...
                                imagemagick-6-common (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                                libc-l10n (2.31-13+deb11u6) wird eingerichtet ...
                                libnftables1:amd64 (0.9.8-3.1+deb11u1) wird eingerichtet ...
                                libpixman-1-dev:amd64 (0.40.0-1.1~deb11u1) wird eingerichtet ...
                                nftables (0.9.8-3.1+deb11u1) wird eingerichtet ...
                                mokutil (0.6.0-2~deb11u1) wird eingerichtet ...
                                traceroute (1:2.1.0-2+deb11u1) wird eingerichtet ...
                                update-alternatives: /usr/bin/traceroute.db wird verwendet, um /usr/bin/traceroute (traceroute) im automatischen Modus bereitzustellen
                                update-alternatives: /usr/bin/traceroute6.db wird verwendet, um /usr/bin/traceroute6 (traceroute6) im automatischen Modus bereitzustellen
                                update-alternatives: /usr/bin/lft.db wird verwendet, um /usr/bin/lft (lft) im automatischen Modus bereitzustellen
                                update-alternatives: /usr/bin/traceproto.db wird verwendet, um /usr/bin/traceproto (traceproto) im automatischen Modus bereitzustellen
                                update-alternatives: /usr/sbin/tcptraceroute.db wird verwendet, um /usr/sbin/tcptraceroute (tcptraceroute) im automatischen Modus bereitzustellen
                                distro-info-data (0.51+deb11u3) wird eingerichtet ...
                                openssh-client (1:8.4p1-5+deb11u1) wird eingerichtet ...
                                linux-image-5.10.0-23-amd64 (5.10.179-1) wird eingerichtet ...
                                I: /vmlinuz.old is now a symlink to boot/vmlinuz-5.10.0-13-amd64
                                I: /initrd.img.old is now a symlink to boot/initrd.img-5.10.0-13-amd64
                                I: /vmlinuz is now a symlink to boot/vmlinuz-5.10.0-23-amd64
                                I: /initrd.img is now a symlink to boot/initrd.img-5.10.0-23-amd64
                                /etc/kernel/postinst.d/initramfs-tools:
                                update-initramfs: Generating /boot/initrd.img-5.10.0-23-amd64
                                /etc/kernel/postinst.d/zz-update-grub:
                                Generating grub configuration file ...
                                Found linux image: /boot/vmlinuz-5.10.0-23-amd64
                                Found initrd image: /boot/initrd.img-5.10.0-23-amd64
                                Found linux image: /boot/vmlinuz-5.10.0-13-amd64
                                Found initrd image: /boot/initrd.img-5.10.0-13-amd64
                                Found linux image: /boot/vmlinuz-5.10.0-11-amd64
                                Found initrd image: /boot/initrd.img-5.10.0-11-amd64
                                Adding boot menu entry for EFI firmware configuration
                                done
                                unzip (6.0-26+deb11u1) wird eingerichtet ...
                                libgdk-pixbuf2.0-common (2.42.2+dfsg-1+deb11u1) wird eingerichtet ...
                                rsyslog (8.2102.0-2+deb11u1) wird eingerichtet ...
                                linux-libc-dev:amd64 (5.10.179-1) wird eingerichtet ...
                                isc-dhcp-client (4.4.1-2.3+deb11u2) wird eingerichtet ...
                                libldap-2.4-2:amd64 (2.4.57+dfsg-3+deb11u1) wird eingerichtet ...
                                libnss-systemd:amd64 (247.3-7+deb11u2) wird eingerichtet ...
                                libcurl3-gnutls:amd64 (7.74.0-1.3+deb11u7) wird eingerichtet ...
                                krb5-locales (1.18.3-6+deb11u3) wird eingerichtet ...
                                libnss3:amd64 (2:3.61-1+deb11u3) wird eingerichtet ...
                                linux-image-amd64 (5.10.179-1) wird eingerichtet ...
                                locales (2.31-13+deb11u6) wird eingerichtet ...
                                Generating locales (this might take a while)...
                                  de_DE.UTF-8... done
                                Generation complete.
                                nodejs (16.20.1-deb-1nodesource1) wird eingerichtet ...
                                libldap-common (2.4.57+dfsg-3+deb11u1) wird eingerichtet ...
                                libwbclient0:amd64 (2:4.13.13+dfsg-1~deb11u5) wird eingerichtet ...
                                libpcre2-16-0:amd64 (10.36-2+deb11u1) wird eingerichtet ...
                                tzdata (2021a-1+deb11u10) wird eingerichtet ...
                                Current default time zone: 'Europe/Berlin'
                                Local time is now:      Sun Jun 25 15:15:34 CEST 2023.
                                Universal Time is now:  Sun Jun 25 13:15:34 UTC 2023.
                                Run 'dpkg-reconfigure tzdata' if you wish to change it.
                                libopenexr25:amd64 (2.5.4-2+deb11u1) wird eingerichtet ...
                                mariadb-common (1:10.5.19-0+deb11u2) wird eingerichtet ...
                                libpcre2-32-0:amd64 (10.36-2+deb11u1) wird eingerichtet ...
                                libopenexr-dev (2.5.4-2+deb11u1) wird eingerichtet ...
                                libtirpc-dev:amd64 (1.3.1-1+deb11u1) wird eingerichtet ...
                                libfreetype6:amd64 (2.10.4+dfsg-1+deb11u1) wird eingerichtet ...
                                libx11-data (2:1.7.2-1+deb11u1) wird eingerichtet ...
                                libavahi-common-data:amd64 (0.8-5+deb11u2) wird eingerichtet ...
                                libncurses6:amd64 (6.2+20201114-2+deb11u1) wird eingerichtet ...
                                libdbus-1-3:amd64 (1.12.24-0+deb11u1) wird eingerichtet ...
                                dbus (1.12.24-0+deb11u1) wird eingerichtet ...
                                A reboot is required to replace the running dbus-daemon.
                                Please reboot the system when convenient.
                                dbus.service is a disabled or a static unit, not starting it.
                                dbus.socket is a disabled or a static unit, not starting it.
                                xz-utils (5.2.5-2.1~deb11u1) wird eingerichtet ...
                                libfribidi0:amd64 (1.0.8-2+deb11u1) wird eingerichtet ...
                                libssl-dev:amd64 (1.1.1n-0+deb11u5) wird eingerichtet ...
                                shim-signed-common (1.39~1+deb11u1+15.7-1~deb11u1) wird eingerichtet ...
                                No DKMS packages installed: not changing Secure Boot validation state.
                                systemd-timesyncd (247.3-7+deb11u2) wird eingerichtet ...
                                udev (247.3-7+deb11u2) wird eingerichtet ...
                                libwebp6:amd64 (0.6.1-2.1+deb11u1) wird eingerichtet ...
                                sudo (1.9.5p2-3+deb11u1) wird eingerichtet ...
                                libmariadb3:amd64 (1:10.5.19-0+deb11u2) wird eingerichtet ...
                                libudev-dev:amd64 (247.3-7+deb11u2) wird eingerichtet ...
                                libpcre2-posix2:amd64 (10.36-2+deb11u1) wird eingerichtet ...
                                libncursesw6:amd64 (6.2+20201114-2+deb11u1) wird eingerichtet ...
                                libdpkg-perl (1.20.12) wird eingerichtet ...
                                liblzma-dev:amd64 (5.2.5-2.1~deb11u1) wird eingerichtet ...
                                nano (5.4-2+deb11u2) wird eingerichtet ...
                                libhttp-daemon-perl (6.12-1+deb11u1) wird eingerichtet ...
                                libpam-systemd:amd64 (247.3-7+deb11u2) wird eingerichtet ...
                                libcurl4:amd64 (7.74.0-1.3+deb11u7) wird eingerichtet ...
                                git-man (1:2.30.2-1+deb11u2) wird eingerichtet ...
                                libx11-6:amd64 (2:1.7.2-1+deb11u1) wird eingerichtet ...
                                isc-dhcp-common (4.4.1-2.3+deb11u2) wird eingerichtet ...
                                libtiff5:amd64 (4.2.0-1+deb11u4) wird eingerichtet ...
                                curl (7.74.0-1.3+deb11u7) wird eingerichtet ...
                                libmagickcore-6-headers (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                                libde265-0:amd64 (1.0.11-0+deb11u1) wird eingerichtet ...
                                libc-dev-bin (2.31-13+deb11u6) wird eingerichtet ...
                                libsdl2-2.0-0:amd64 (2.0.14+dfsg2-3+deb11u1) wird eingerichtet ...
                                openssl (1.1.1n-0+deb11u5) wird eingerichtet ...
                                libwebpmux3:amd64 (0.6.1-2.1+deb11u1) wird eingerichtet ...
                                grafana (10.0.1) wird eingerichtet ...
                                Neue Version der Konfigurationsdatei /etc/init.d/grafana-server wird installiert ...
                                Neue Version der Konfigurationsdatei /usr/lib/systemd/system/grafana-server.service wird installiert ...
                                Restarting grafana-server service... OK
                                publicsuffix (20220811.1734-0+deb11u1) wird eingerichtet ...
                                libxml2:amd64 (2.9.10+dfsg-6.7+deb11u4) wird eingerichtet ...
                                shim-unsigned (15.7-1~deb11u1) wird eingerichtet ...
                                libgtk-3-common (3.24.24-4+deb11u3) wird eingerichtet ...
                                libtiffxx5:amd64 (4.2.0-1+deb11u4) wird eingerichtet ...
                                libc-devtools (2.31-13+deb11u6) wird eingerichtet ...
                                ncurses-term (6.2+20201114-2+deb11u1) wird eingerichtet ...
                                openssh-sftp-server (1:8.4p1-5+deb11u1) wird eingerichtet ...
                                libx11-xcb1:amd64 (2:1.7.2-1+deb11u1) wird eingerichtet ...
                                libmagickcore-6-arch-config:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                                libxpm4:amd64 (1:3.5.12-1.1~deb11u1) wird eingerichtet ...
                                openssh-server (1:8.4p1-5+deb11u1) wird eingerichtet ...
                                rescue-ssh.target is a disabled or a static unit, not starting it.
                                bind9-libs:amd64 (1:9.16.37-1~deb11u1) wird eingerichtet ...
                                libmagickwand-6-headers (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                                libfribidi-dev:amd64 (1.0.8-2+deb11u1) wird eingerichtet ...
                                libwebpdemux2:amd64 (0.6.1-2.1+deb11u1) wird eingerichtet ...
                                cifs-utils (2:6.11-3.1+deb11u1) wird eingerichtet ...
                                libavahi-common3:amd64 (0.8-5+deb11u2) wird eingerichtet ...
                                libpq5:amd64 (13.11-0+deb11u1) wird eingerichtet ...
                                libx11-dev:amd64 (2:1.7.2-1+deb11u1) wird eingerichtet ...
                                libatspi2.0-0:amd64 (2.38.0-4+deb11u1) wird eingerichtet ...
                                libavutil56:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                                dpkg-dev (1.20.12) wird eingerichtet ...
                                grub-common (2.06-3~deb11u5) wird eingerichtet ...
                                Neue Version der Konfigurationsdatei /etc/grub.d/10_linux wird installiert ...
                                Neue Version der Konfigurationsdatei /etc/grub.d/20_linux_xen wird installiert ...
                                Neue Version der Konfigurationsdatei /etc/grub.d/30_os-prober wird installiert ...
                                Neue Version der Konfigurationsdatei /etc/grub.d/30_uefi-firmware wird installiert ...
                                Neue Version der Konfigurationsdatei /etc/grub.d/41_custom wird installiert ...
                                dbus-user-session (1.12.24-0+deb11u1) wird eingerichtet ...
                                libmagickcore-6.q16-6:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                                libxml2-dev:amd64 (2.9.10+dfsg-6.7+deb11u4) wird eingerichtet ...
                                libdbus-1-dev:amd64 (1.12.24-0+deb11u1) wird eingerichtet ...
                                libcurl4-openssl-dev:amd64 (7.74.0-1.3+deb11u7) wird eingerichtet ...
                                libpostproc55:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                                git (1:2.30.2-1+deb11u2) wird eingerichtet ...
                                shim-helpers-amd64-signed (1+15.7+1~deb11u1) wird eingerichtet ...
                                x86_64-efi wird für Ihre Plattform installiert.
                                installation beendet. Keine Fehler aufgetreten.
                                at-spi2-core (2.38.0-4+deb11u1) wird eingerichtet ...
                                libavahi-common-dev:amd64 (0.8-5+deb11u2) wird eingerichtet ...
                                libc6-dev:amd64 (2.31-13+deb11u6) wird eingerichtet ...
                                libmagickwand-6.q16-6:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                                libgdk-pixbuf-2.0-0:amd64 (2.42.2+dfsg-1+deb11u1) wird eingerichtet ...
                                libswscale5:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                                libbluray2:amd64 (1:1.2.1-4+deb11u2) wird eingerichtet ...
                                grub-efi-amd64-bin (2.06-3~deb11u5) wird eingerichtet ...
                                libmagick++-6.q16-8:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                                bind9-host (1:9.16.37-1~deb11u1) wird eingerichtet ...
                                libavahi-client3:amd64 (0.8-5+deb11u2) wird eingerichtet ...
                                gtk-update-icon-cache (3.24.24-4+deb11u3) wird eingerichtet ...
                                libpcre2-dev:amd64 (10.36-2+deb11u1) wird eingerichtet ...
                                grub-efi-amd64-signed (1+2.06+3~deb11u5) wird eingerichtet ...
                                libmagick++-6-headers (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                                gir1.2-gdkpixbuf-2.0:amd64 (2.42.2+dfsg-1+deb11u1) wird eingerichtet ...
                                libmagickcore-6.q16-6-extra:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                                grub2-common (2.06-3~deb11u5) wird eingerichtet ...
                                Neue Version der Konfigurationsdatei /etc/kernel/postinst.d/zz-update-grub wird installiert ...
                                Neue Version der Konfigurationsdatei /etc/kernel/postrm.d/zz-update-grub wird installiert ...
                                libavahi-client-dev:amd64 (0.8-5+deb11u2) wird eingerichtet ...
                                libswresample3:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                                libavahi-compat-libdnssd1:amd64 (0.8-5+deb11u2) wird eingerichtet ...
                                shim-signed:amd64 (1.39~1+deb11u1+15.7-1~deb11u1) wird eingerichtet ...
                                libavresample4:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                                libexpat1-dev:amd64 (2.2.10-2+deb11u5) wird eingerichtet ...
                                grub-efi-amd64 (2.06-3~deb11u5) wird eingerichtet ...
                                Warning: os-prober will be executed to detect other bootable partitions.
                                Its output will be used to detect bootable binaries on them and create new boot entries.
                                Adding boot menu entry for UEFI Firmware Settings ...
                                done
                                libcups2:amd64 (2.3.3op2-3+deb11u2) wird eingerichtet ...
                                zlib1g-dev:amd64 (1:1.2.11.dfsg-2+deb11u2) wird eingerichtet ...
                                libgdk-pixbuf2.0-bin (2.42.2+dfsg-1+deb11u1) wird eingerichtet ...
                                libavcodec58:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                                bind9-dnsutils (1:9.16.37-1~deb11u1) wird eingerichtet ...
                                libgdk-pixbuf-2.0-dev:amd64 (2.42.2+dfsg-1+deb11u1) wird eingerichtet ...
                                libgs9:amd64 (9.53.3~dfsg-7+deb11u4) wird eingerichtet ...
                                libavformat58:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                                libavahi-compat-libdnssd-dev:amd64 (0.8-5+deb11u2) wird eingerichtet ...
                                ghostscript (9.53.3~dfsg-7+deb11u4) wird eingerichtet ...
                                libfreetype-dev:amd64 (2.10.4+dfsg-1+deb11u1) wird eingerichtet ...
                                libtiff-dev:amd64 (4.2.0-1+deb11u4) wird eingerichtet ...
                                libavfilter7:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                                libfreetype6-dev:amd64 (2.10.4+dfsg-1+deb11u1) wird eingerichtet ...
                                libavdevice58:amd64 (7:4.3.6-0+deb11u1) wird eingerichtet ...
                                ffmpeg (7:4.3.6-0+deb11u1) wird eingerichtet ...
                                libmagickcore-6.q16-dev:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                                libmagickwand-6.q16-dev:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                                libmagick++-6.q16-dev:amd64 (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                                libmagick++-dev (8:6.9.11.60+dfsg-1.3+deb11u1) wird eingerichtet ...
                                Trigger für libc-bin (2.31-13+deb11u6) werden verarbeitet ...
                                Trigger für man-db (2.9.4-2) werden verarbeitet ...
                                Trigger für mailcap (3.69) werden verarbeitet ...
                                Trigger für initramfs-tools (0.140) werden verarbeitet ...
                                Trigger für libglib2.0-0:amd64 (2.66.8-1) werden verarbeitet ...
                                libgtk-3-0:amd64 (3.24.24-4+deb11u3) wird eingerichtet ...
                                libgtk-3-bin (3.24.24-4+deb11u3) wird eingerichtet ...
                                Trigger für shim-signed:amd64 (1.39~1+deb11u1+15.7-1~deb11u1) werden verarbeitet ...
                                e6iob@NUCioBroker:~$
                                @fraso
                                Unbedingt einen reboot einlegen.
                                Und dann nochmal schauen.
                                F 1 Antwort Letzte Antwort
                                  @fraso
                                  fraso
                                  mach ich.
                                  was gebe ich ein um die relevanten Informationen zu erhalten ?
                                  • F fraso
                                    mach ich.
                                    @fraso
                                    Jag
                                    iob diag
                                    nochmals drüber.
                                      @fraso
                                      Jag
                                      iob diag
                                      nochmals drüber.
                                      fraso
                                      @thomas-braun sagte in web0 startet nicht - versehentlich Beta Updates gemacht:
                                      iob diag
                                      Skript v.2023-04-16
                                      *** BASE SYSTEM ***
                                      Architecture    : x86_64
                                      Docker          : false
                                      Virtualization  : none
                                      Distributor ID:	Debian
                                      Description:	Debian GNU/Linux 11 (bullseye)
                                      Release:	11
                                      Codename:	bullseye
                                      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                      NAME="Debian GNU/Linux"
                                      VERSION_ID="11"
                                      VERSION="11 (bullseye)"
                                      VERSION_CODENAME=bullseye
                                      ID=debian
                                      HOME_URL="https://www.debian.org/"
                                      SUPPORT_URL="https://www.debian.org/support"
                                      BUG_REPORT_URL="https://bugs.debian.org/"
                                      Systemuptime and Load:
                                       15:37:51 up 5 min,  1 user,  load average: 1.88, 1.60, 0.72
                                      CPU threads: 4
                                      *** Time and Time Zones ***
                                                     Local time: Sun 2023-06-25 15:37:51 CEST
                                                 Universal time: Sun 2023-06-25 13:37:51 UTC
                                                       RTC time: Sun 2023-06-25 13:37:51
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** User and Groups ***
                                      e6iob
                                      /home/e6iob
                                      e6iob adm cdrom floppy sudo audio dip video plugdev netdev iobroker
                                      *** X-Server-Setup ***
                                      X-Server: 	false
                                      Desktop:
                                      Terminal: 	tty
                                      Boot Target: 	graphical.target
                                      *** MEMORY ***
                                      Mem:             15G        5.4G        9.3G        1.0M        1.1G         10G
                                      Swap:           976M          0B        976M
                                      Total:           16G        5.4G         10G
                                              15710 M total memory
                                               5383 M used memory
                                                346 M active memory
                                               5740 M inactive memory
                                               9273 M free memory
                                                 71 M buffer memory
                                                982 M swap cache
                                                976 M total swap
                                                  0 M used swap
                                                976 M free swap
                                      *** FILESYSTEM ***
                                      udev           devtmpfs  7.7G     0  7.7G   0% /dev
                                      tmpfs          tmpfs     1.6G  884K  1.6G   1% /run
                                      /dev/nvme0n1p2 ext4      233G   43G  178G  20% /
                                      tmpfs          tmpfs     7.7G     0  7.7G   0% /dev/shm
                                      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                      /dev/nvme0n1p1 vfat      511M  5.8M  506M   2% /boot/efi
                                      tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
                                      [Sun Jun 25 15:32:41 2023] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
                                      [Sun Jun 25 15:32:41 2023] EXT4-fs (nvme0n1p2): re-mounted. Opts: errors=remount-ro
                                      TARGET      SOURCE         FSTYPE OPTIONS
                                      /           /dev/nvme0n1p2 ext4   rw,relatime,errors=remount-ro
                                      `-/boot/efi /dev/nvme0n1p1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
                                      /var:
                                      19G	/var/
                                      12G	/var/lib
                                      9.8G	/var/lib/motioneye
                                      7.1G	/var/log
                                      5.1G	/var/lib/motioneye/Camera11
                                      Archived and active journals take up 4.0G in the file system.
                                      /opt/iobroker/backups:
                                      11G	/opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      1.3G	/opt/iobroker/iobroker-data/
                                      566M	/opt/iobroker/iobroker-data/files
                                      461M	/opt/iobroker/iobroker-data/backup-objects
                                      88M	/opt/iobroker/iobroker-data/files/echarts.admin
                                      72M	/opt/iobroker/iobroker-data/files/telegram.admin
                                      136M	/opt/iobroker/iobroker-data/states.jsonl
                                      85M	/opt/iobroker/iobroker-data/objects.jsonl
                                      35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                      23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                                      23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                                      *** NodeJS-Installation ***
                                      /usr/bin/nodejs 	v16.20.1
                                      /usr/bin/node 		v16.20.1
                                      /usr/bin/npm 		8.19.4
                                      /usr/bin/npx 		8.19.4
                                      nodejs:
                                        Installed: 16.20.1-deb-1nodesource1
                                        Candidate: 16.20.1-deb-1nodesource1
                                        Version table:
                                       *** 16.20.1-deb-1nodesource1 500
                                              500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                                           12.22.12~dfsg-1~deb11u4 500
                                              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                                           12.22.12~dfsg-1~deb11u3 500
                                              500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                      No problems detected
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Core adapters versions
                                      js-controller: 	4.0.24
                                      admin: 		6.5.9
                                      javascript: 	7.0.3
                                      Adapters from github: 	1
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : NUCioBroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.alexa2.0                 : alexa2                : NUCioBroker                              -  enabled
                                      + system.adapter.backitup.0               : backitup              : NUCioBroker                              -  enabled
                                      + system.adapter.cloud.0                  : cloud                 : NUCioBroker                              -  enabled
                                      + system.adapter.device-reminder.0        : device-reminder       : NUCioBroker                              -  enabled
                                        system.adapter.devices.0                : devices               : NUCioBroker                              - disabled
                                        system.adapter.discovery.0              : discovery             : NUCioBroker                              - disabled
                                      + system.adapter.echarts.0                : echarts               : NUCioBroker                              -  enabled
                                      + system.adapter.email.0                  : email                 : NUCioBroker                              -  enabled
                                        system.adapter.fb-checkpresence.0       : fb-checkpresence      : NUCioBroker                              - disabled
                                        system.adapter.flot.0                   : flot                  : NUCioBroker                              - disabled
                                      + system.adapter.fritzdect.0              : fritzdect             : NUCioBroker                              -  enabled
                                      + system.adapter.fronius.0                : fronius               : NUCioBroker                              -  enabled
                                        system.adapter.habpanel.0               : habpanel              : NUCioBroker                              - disabled
                                        system.adapter.ham.0                    : ham                   : NUCioBroker                              - disabled
                                      + system.adapter.history.0                : history               : NUCioBroker                              -  enabled
                                      + system.adapter.hm-rega.0                : hm-rega               : NUCioBroker                              -  enabled
                                      + system.adapter.hm-rega.1                : hm-rega               : NUCioBroker                              -  enabled
                                      + system.adapter.hm-rega.2                : hm-rega               : NUCioBroker                              -  enabled
                                      + system.adapter.hm-rega.3                : hm-rega               : NUCioBroker                              -  enabled
                                      + system.adapter.hm-rega.4                : hm-rega               : NUCioBroker                              -  enabled
                                        system.adapter.hm-rega.5                : hm-rega               : NUCioBroker                              - disabled
                                      + system.adapter.hm-rpc.0                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
                                      + system.adapter.hm-rpc.1                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
                                      + system.adapter.hm-rpc.2                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
                                      + system.adapter.hm-rpc.3                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
                                      + system.adapter.hm-rpc.4                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
                                        system.adapter.hm-rpc.5                 : hm-rpc                : NUCioBroker                              - disabled, port: 0
                                      + system.adapter.hs100.0                  : hs100                 : NUCioBroker                              -  enabled
                                        system.adapter.ical.0                   : ical                  : NUCioBroker                              - disabled
                                        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: NUCioBroker                              - disabled
                                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : NUCioBroker                              - disabled
                                      + system.adapter.influxdb.0               : influxdb              : NUCioBroker                              -  enabled, port: 8086
                                      + system.adapter.iot.0                    : iot                   : NUCioBroker                              -  enabled
                                      + system.adapter.javascript.0             : javascript            : NUCioBroker                              -  enabled
                                      + system.adapter.libre.0                  : libre                 : NUCioBroker                              -  enabled
                                      + system.adapter.modbus.0                 : modbus                : NUCioBroker                              -  enabled
                                      + system.adapter.modbus.1                 : modbus                : NUCioBroker                              -  enabled
                                      + system.adapter.modbus.2                 : modbus                : NUCioBroker                              -  enabled
                                      + system.adapter.mqtt.0                   : mqtt                  : NUCioBroker                              -  enabled, port: 1887, bind: 0.0.0.0
                                        system.adapter.mqtt.1                   : mqtt                  : NUCioBroker                              - disabled, port: 1885, bind: 0.0.0.0
                                      + system.adapter.niu.0                    : niu                   : NUCioBroker                              -  enabled
                                        system.adapter.node-red.0               : node-red              : NUCioBroker                              - disabled, port: 1880, bind: 192.168.178.35
                                        system.adapter.openhab.0                : openhab               : NUCioBroker                              - disabled, port: 8080
                                        system.adapter.openweathermap.0         : openweathermap        : NUCioBroker                              -  enabled
                                      + system.adapter.parser.0                 : parser                : NUCioBroker                              -  enabled
                                      + system.adapter.ping.0                   : ping                  : NUCioBroker                              -  enabled
                                      + system.adapter.puppeteer.0              : puppeteer             : NUCioBroker                              -  enabled
                                      + system.adapter.ring.0                   : ring                  : NUCioBroker                              -  enabled
                                      + system.adapter.senec.0                  : senec                 : NUCioBroker                              -  enabled
                                      + system.adapter.shelly.0                 : shelly                : NUCioBroker                              -  enabled, port: 1886, bind: 0.0.0.0
                                      + system.adapter.simple-api.0             : simple-api            : NUCioBroker                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      + system.adapter.sonoff.0                 : sonoff                : NUCioBroker                              -  enabled, port: 1883, bind: 0.0.0.0
                                        system.adapter.systeminfo.0             : systeminfo            : NUCioBroker                              - disabled
                                      + system.adapter.telegram.0               : telegram              : NUCioBroker                              -  enabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.tesla-motors.0           : tesla-motors          : NUCioBroker                              -  enabled
                                      + system.adapter.text2command.0           : text2command          : NUCioBroker                              -  enabled
                                      + system.adapter.tuya.0                   : tuya                  : NUCioBroker                              -  enabled
                                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : NUCioBroker                              - disabled
                                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : NUCioBroker                              - disabled
                                        system.adapter.vis-weather.0            : vis-weather           : NUCioBroker                              - disabled
                                        system.adapter.vis.0                    : vis                   : NUCioBroker                              -  enabled
                                      + system.adapter.web.0                    : web                   : NUCioBroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : NUCioBroker                              -  enabled
                                      + system.adapter.withings.0               : withings              : NUCioBroker                              -  enabled
                                      + system.adapter.wled.0                   : wled                  : NUCioBroker                              -  enabled
                                      + system.adapter.yeelight-2.0             : yeelight-2            : NUCioBroker                              -  enabled
                                        system.adapter.zigbee.0                 : zigbee                : NUCioBroker                              -  enabled, port: tcp://192.168.178.63:6638
                                      + instance is alive
                                      ioBroker-Repositories
                                      live-stable   : http://iobroker.live/repo/sources-dist.json
                                      live-beta     : http://iobroker.live/repo/sources-dist-latest.json
                                      Active repo(s): stable
                                      Installed ioBroker-Instances
                                      Used repository: stable
                                      Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
                                      Adapter    "admin"        : 6.3.5    , installed 6.5.9
                                      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                                      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                                      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                                      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                                      Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                      Adapter    "discovery"    : 3.1.0    , installed 3.2.0
                                      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                                      Adapter    "email"        : 1.2.0    , installed 1.2.0
                                      Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
                                      Adapter    "fritzdect"    : 2.2.6    , installed 2.3.1
                                      Adapter    "fronius"      : 1.1.3    , installed 2.0.1
                                      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                      Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                      Adapter    "history"      : 2.2.4    , installed 2.2.4
                                      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                                      Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
                                      Adapter    "hs100"        : 2.1.2    , installed 2.1.2
                                      Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                                      Adapter    "libre"        : 0.0.4    , installed 0.0.5
                                      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                                      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                                      Adapter    "niu"          : 0.0.3    , installed 0.0.3
                                      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                                      Adapter    "openhab"      : 1.1.0    , installed 1.1.0
                                      Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                                      Adapter    "parser"       : 1.3.2    , installed 1.3.2
                                      Adapter    "puppeteer"    : 0.2.7    , installed 0.2.6  [Updatable]
                                      Adapter    "ring"         : 3.2.2    , installed 3.4.0
                                      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                                      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                                      Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
                                      Adapter    "telegram"     : 1.15.6   , installed 1.16.0
                                      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
                                      Adapter    "text2command" : 3.0.2    , installed 3.0.2
                                      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                                      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                      Adapter    "withings"     : 0.0.13   , installed 0.0.13
                                      Adapter    "wled"         : 0.6.7    , installed 0.6.7
                                      Adapter    "ws"           : 1.3.0    , installed 2.3.6
                                      Adapter    "yeelight-2"   : 1.1.2    , installed 1.2.1
                                      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                                      Objects and States
                                      Objects: 	71655
                                      States: 	56221
                                      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                      Hit:2 https://packages.grafana.com/oss/deb stable InRelease
                                      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                      Hit:4 https://repos.influxdata.com/debian stable InRelease
                                      Hit:5 http://deb.debian.org/debian bullseye InRelease
                                      Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
                                      Reading package lists...
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 192.168.178.35:8701     0.0.0.0:*               LISTEN      1001       21022      1059/io.hm-rpc.2
                                      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       21931      1169/io.shelly.0
                                      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       20038      1137/io.mqtt.0
                                      tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       20039      1137/io.mqtt.0
                                      tcp        0      0 127.0.0.1:38881         0.0.0.0:*               LISTEN      1001       18699      726/chrome
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15752      540/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16876      540/iobroker.js-con
                                      tcp        0      0 127.0.0.1:45325         0.0.0.0:*               LISTEN      1001       25022      1484/chrome
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12137      1/init
                                      tcp        0      0 192.168.178.35:2000     0.0.0.0:*               LISTEN      1001       19031      1040/io.hm-rpc.1
                                      tcp        0      0 192.168.178.35:2001     0.0.0.0:*               LISTEN      1001       19024      1017/io.hm-rpc.0
                                      tcp        0      0 192.168.178.35:2002     0.0.0.0:*               LISTEN      1001       21083      1092/io.hm-rpc.4
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15661      467/sshd: /usr/sbin
                                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        10724      463/influxd
                                      tcp        0      0 192.168.178.35:2010     0.0.0.0:*               LISTEN      1001       19941      1077/io.hm-rpc.3
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21977      1184/io.sonoff.0
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          12141      1/init
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15345      569/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       26084      1614/io.web.0
                                      tcp6       0      0 :::8086                 :::*                    LISTEN      998        10730      463/influxd
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          15663      467/sshd: /usr/sbin
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       25832      1539/io.simple-api.
                                      tcp6       0      0 :::3000                 :::*                    LISTEN      109        10809      539/grafana
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       25415      1644/io.wled.0
                                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19277      1199/io.tuya.0
                                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19278      1199/io.tuya.0
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16801      400/dhclient
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12138      1/init
                                      udp6       0      0 :::111                  :::*                                0          12144      1/init
                                      2023-06-25 15:39:00.204  - warn: javascript.0 (629)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
                                      2023-06-25 15:39:00.204  - warn: javascript.0 (629)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
                                      2023-06-25 15:39:00.204  - warn: javascript.0 (629)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
                                      2023-06-25 15:39:00.204  - warn: javascript.0 (629)     at listOnTimeout (node:internal/timers:559:17)
                                      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at processTimers (node:internal/timers:502:7)
                                      2023-06-25 15:39:00.205  - warn: javascript.0 (629) getState "javascript.0.System.System.akt_Datum_Tag" not found (3)
                                      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at Sicherung_Data (script.js.IOS.SchichtPlanFtpUpload:15:143)
                                      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at Object.<anonymous> (script.js.IOS.SchichtPlanFtpUpload:10:41)
                                      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1606:34)
                                      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
                                      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
                                      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
                                      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at listOnTimeout (node:internal/timers:559:17)
                                      2023-06-25 15:39:00.206  - error: javascript.0 (629) script.js.IOS.SchichtPlanFtpUpload: TypeError: Cannot read properties of undefined (reading 'Client')
                                      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at kopieren (script.js.IOS.SchichtPlanFtpUpload:23:28)
                                      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at Sicherung_Data (script.js.IOS.SchichtPlanFtpUpload:17:15)
                                      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at Object.<anonymous> (script.js.IOS.SchichtPlanFtpUpload:10:41)
                                      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1606:34)
                                      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
                                      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
                                      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
                                      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at listOnTimeout (node:internal/timers:559:17)
                                      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at processTimers (node:internal/timers:502:7)
                                      2023-06-25 15:39:02.881  - warn: shelly.0 (1169) [Mqtt.rpcNotifications] 192.168.178.17 (shellyplus1pm / shellyplus1pm-7c87ce64a74c / shellyplus1pm#7c87ce64a74c#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
                                      paul53P Thomas BraunT 2 Antworten Letzte Antwort
                                      • F fraso
                                        iob diag
                                        Skript v.2023-04-16
                                        *** BASE SYSTEM ***
                                        Docker          : false
                                        Release:	11
                                        Codename:	bullseye
                                        VERSION_ID="11"
                                        ID=debian
                                        CPU threads: 4
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        e6iob
                                        /home/e6iob
                                        X-Server: 	false
                                        Desktop:
                                        Terminal: 	tty
                                        *** MEMORY ***
                                        Swap:           976M          0B        976M
                                        Total:           16G        5.4G         10G
                                                 5383 M used memory
                                                  346 M active memory
                                                 9273 M free memory
                                                   71 M buffer memory
                                                  982 M swap cache
                                                  976 M total swap
                                                    0 M used swap
                                                  976 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        19G	/var/
                                        12G	/var/lib
                                        7.1G	/var/log
                                        /usr/bin/npm 		8.19.4
                                        /usr/bin/npx 		8.19.4
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin: 		6.5.9
                                        javascript: 	7.0.3
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects: 	71655
                                        States: 	56221
                                        Pending Updates: 0
                                        @fraso sagte: IOS.SchichtPlanFtpUpload
                                        Dieses Skript enthält Fehler: Erst mal deaktivieren und Fehler beheben.
                                        • F fraso
                                          iob diag
                                          Skript v.2023-04-16
                                          *** BASE SYSTEM ***
                                          Docker          : false
                                          Release:	11
                                          Codename:	bullseye
                                          VERSION_ID="11"
                                          ID=debian
                                          CPU threads: 4
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          e6iob
                                          /home/e6iob
                                          X-Server: 	false
                                          Desktop:
                                          Terminal: 	tty
                                          *** MEMORY ***
                                          Swap:           976M          0B        976M
                                          Total:           16G        5.4G         10G
                                                   5383 M used memory
                                                    346 M active memory
                                                   9273 M free memory
                                                     71 M buffer memory
                                                    982 M swap cache
                                                    976 M total swap
                                                      0 M used swap
                                                    976 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          19G	/var/
                                          12G	/var/lib
                                          7.1G	/var/log
                                          /usr/bin/npm 		8.19.4
                                          /usr/bin/npx 		8.19.4
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin: 		6.5.9
                                          javascript: 	7.0.3
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects: 	71655
                                          States: 	56221
                                          Pending Updates: 0
                                          @fraso
                                          Dann bring nodes jetzt noch auf die derzeitige Empfehlung nodejs@18.
