  4. Admin5 und Raspberry Pi 3B+?
    5.3k
39 Beiträge 6 Kommentatoren 1.3k Aufrufe 4 Beobachtet
  • padrinoP padrino
    @thomas-braun sagte in Admin5 und Raspberry Pi 3B+?:
    @padrino
    Das ist eigentlich nicht zu viel. Auch wenn das natürlich für den 1GB Pi3 das Ende der Fahnenstange sein dürfte.
    iob diag
    sagt dazu?
    Vielleicht kann man da noch was rausziehen.
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     13:01:15 up 29 min,  1 user,  load average: 0.22, 0.12, 0.30
    CPU threads: 4
    Raspberry only:
    throttled=0x20000
    Other values than 0x0 hint to temperature/voltage problems
    temp=64.5'C
    volt=1.3062V
    *** Time and Time Zones ***
                   Local time: Thu 2023-06-22 13:01:16 CEST
               Universal time: Thu 2023-06-22 11:01:16 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            909M        711M         69M        0.0K        128M        137M
    Swap:            99M         64M         35M
    Total:          1.0G        776M        104M
              909 M total memory
              711 M used memory
              303 M active memory
              452 M inactive memory
               68 M free memory
                8 M buffer memory
              120 M swap cache
               99 M total swap
               64 M used swap
               35 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      7.1G  3.2G  3.6G  47% /
    devtmpfs       devtmpfs  325M     0  325M   0% /dev
    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
    tmpfs          tmpfs     182M 1008K  181M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
    [Thu Jun 22 12:31:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=dad2dc8b-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Thu Jun 22 12:31:49 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Thu Jun 22 12:31:49 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Thu Jun 22 12:31:57 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Thu Jun 22 12:31:57 2023] EXT4-fs (mmcblk0p2): 3 orphan inodes deleted
    [Thu Jun 22 12:31:57 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Thu Jun 22 12:32:01 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Jun 22 12:32:01 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Jun 22 12:32:05 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    558M    /var/
    179M    /var/cache
    174M    /var/cache/apt
    147M    /var/lib
    132M    /var/log
    Archived and active journals take up 128.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    185M    /opt/iobroker/iobroker-data/
    89M     /opt/iobroker/iobroker-data/files
    70M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    33M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    12M     /opt/iobroker/iobroker-data/objects.json.bak
    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.807d9b89.js
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/910.e1389bdb.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: file
    States  type: file
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.5.8
    javascript:     7.1.0
    Adapters from github:   1
    Adapter State
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      system.adapter.firetv.0                 : firetv                : raspberrypi                              - disabled
      system.adapter.info.0                   : info                  : raspberrypi                              - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
    + system.adapter.rflink.0                 : rflink                : raspberrypi                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.5.9    , installed 6.5.8  [Updatable]
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.23   , installed 2.6.19 [Updatable]
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.0  [Updatable]
    Adapter    "discovery"    : 3.2.0    , installed 3.1.0  [Updatable]
    Adapter    "firetv"       : 1.0.0    , installed 1.0.0
    Adapter    "info"         : 1.9.26   , installed 1.9.19 [Updatable]
    Adapter    "iot"          : 2.0.11   , installed 2.0.8  [Updatable]
    Adapter    "javascript"   : 7.1.1    , installed 7.1.0  [Updatable]
    Controller "js-controller": 5.0.5    , installed 4.0.24 [Updatable]
    Adapter    "parser"       : 2.0.5    , installed 2.0.5
    Adapter    "rflink"       : 2.1.6    , installed 2.1.6
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "socketio"     : 6.3.5    , installed 6.3.5
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "web"          : 5.5.3    , installed 2.4.1  [Updatable]
    Objects and States
    Objects:        5769
    States:         5004
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12935      502/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1907       502/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11922      523/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       14867      1120/io.simple-api.
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12165      1067/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11924      523/sshd: /usr/sbin
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       15445      1095/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       15446      1095/io.tuya.0
    udp        0      0 0.0.0.0:35880           0.0.0.0:*                           1001       16385      1134/io.broadlink2.
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1758       730/dhcpcd
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       12286      1134/io.broadlink2.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14488      398/avahi-daemon: r
    udp        0      0 0.0.0.0:56050           0.0.0.0:*                           1001       16427      1134/io.broadlink2.
    udp        0      0 0.0.0.0:57090           0.0.0.0:*                           108        14490      398/avahi-daemon: r
    udp6       0      0 :::54661                :::*                                108        14491      398/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14522      730/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        14489      398/avahi-daemon: r
    2023-06-22 12:34:21.202  - info: javascript.0 (1094) Start javascript script.js.common.schlaf_log
    2023-06-22 12:34:21.248  - info: javascript.0 (1094) script.js.common.schlaf_log: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-06-22 12:34:21.250  - info: javascript.0 (1094) Start javascript script.js.common.Broadlink_check
    2023-06-22 12:34:21.268  - info: javascript.0 (1094) script.js.common.Broadlink_check: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-06-22 12:34:21.270  - info: javascript.0 (1094) Start javascript script.js.common.küche_fenster
    2023-06-22 12:34:21.290  - info: javascript.0 (1094) script.js.common.küche_fenster: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-06-22 12:34:21.292  - info: javascript.0 (1094) Start javascript script.js.common.finde_mein_handy
    2023-06-22 12:34:21.312  - info: javascript.0 (1094) script.js.common.finde_mein_handy: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-06-22 12:34:21.314  - info: javascript.0 (1094) Start javascript script.js.common.spülmaschine
    2023-06-22 12:34:21.336  - info: javascript.0 (1094) script.js.common.spülmaschine: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-06-22 12:34:21.337  - info: javascript.0 (1094) Start javascript script.js.common.broadlink_schalten
    2023-06-22 12:34:21.355  - info: javascript.0 (1094) script.js.common.broadlink_schalten: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-06-22 12:34:21.357  - info: javascript.0 (1094) Start javascript script.js.common.Kurzfassung
    2023-06-22 12:34:21.376  - info: javascript.0 (1094) script.js.common.Kurzfassung: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-06-22 12:34:21.378  - info: javascript.0 (1094) Start javascript script.js.common.handy_laden_aus
    2023-06-22 12:34:21.398  - info: javascript.0 (1094) script.js.common.handy_laden_aus: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-06-22 12:34:21.400  - info: javascript.0 (1094) Start javascript script.js.common.radio_italia
    2023-06-22 12:34:21.418  - info: javascript.0 (1094) script.js.common.radio_italia: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-06-22 12:34:21.420  - info: javascript.0 (1094) Start javascript script.js.common.nachschub_bitte
    2023-06-22 12:34:21.439  - info: javascript.0 (1094) script.js.common.nachschub_bitte: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-06-22 12:36:12.544  - info: alexa2.0 (1108) No smart home devices to query
    2023-06-22 12:36:15.644  - info: alexa2.0 (1108) Subscribing to states...
    2023-06-22 12:36:15.655  - info: alexa2.0 (1108) Deleting the following states: ["Smart-Home-Devices.4abca8aa-0041-4392-ba51-20344644df4e","Smart-Home-Devices.5caef919-74c1-442b-b804-cb8b4fdb297e","Smart-Home-Devices.6544441d-389d-4192-a6ff-13354907c0be","Smart-Home-Devices.247ce00a-9aed-4ac9-bd50-6604d1ed5804","Smart-Home-Devices.217aaa6f-f9be-4619-acb2-3260e45116fe","Smart-Home-Devices.d4778074-817a-48bf-a091-15d05182527c","Smart-Home-Devices.f30b3cb6-56e9-4c8b-a2ce-38d10b2748f3","Smart-Home-Devices.c85b89f0-9181-494a-807b-6f9ba37cd893","Smart-Home-Devices.3185c871-261d-4a73-a8a7-2e39cf6c74d3","Smart-Home-Devices.20c58c78-3cfa-49a9-8ded-1d74707ae6c3","Smart-Home-Devices.158df824-dd06-4fb9-875b-ec5f347da0d0","Smart-Home-Devices.cc4e0ac1-c0ff-45c4-8a7a-7e025315f93a","Smart-Home-Devices.d04b9464-e6d1-4168-88a4-0fd595e8d6db","Smart-Home-Devices.44554b70-0e67-48e0-b184-829e93599879","Smart-Home-Devices.8c1cea9d-54a9-4355-a318-55c66adb4a7f","Smart-Home-Devices.3f5e9367-d721-48ad-9480-3200cd2c46c7","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772","Smart-Home-Devices.4abca8aa-0041-4392-ba51-20344644df4e.#enabled","Smart-Home-Devices.4abca8aa-0041-4392-ba51-20344644df4e.#delete","Smart-Home-Devices.4abca8aa-0041-4392-ba51-20344644df4e.powerState","Smart-Home-Devices.4abca8aa-0041-4392-ba51-20344644df4e.colorName","Smart-Home-Devices.4abca8aa-0041-4392-ba51-20344644df4e.color-hue","Smart-Home-Devices.4abca8aa-0041-4392-ba51-20344644df4e.color-saturation","Smart-Home-Devices.4abca8aa-0041-4392-ba51-20344644df4e.color-brightness","Smart-Home-Devices.4abca8aa-0041-4392-ba51-20344644df4e.colorRgb","Smart-Home-Devices.4abca8aa-0041-4392-ba51-20344644df4e.brightness","Smart-Home-Devices.4abca8aa-0041-4392-ba51-20344644df4e.connectivity","Smart-Home-Devices.4abca8aa-0041-4392-ba51-20344644df4e.connectivity-reason","Smart-Home-Devices.4abca8aa-0041-4392-ba51-20344644df4e.#query","Smart-Home-Devices.5caef919-74c1-442b-b804-cb8b4fdb297e.#enabled","Smart-Home-Devices.5caef919-74c1-442b-b804-cb8b4fdb297e.#delete","Smart-Home-Devices.5caef919-74c1-442b-b804-cb8b4fdb297e.active","Smart-Home-Devices.6544441d-389d-4192-a6ff-13354907c0be.#enabled","Smart-Home-Devices.6544441d-389d-4192-a6ff-13354907c0be.#delete","Smart-Home-Devices.6544441d-389d-4192-a6ff-13354907c0be.powerState","Smart-Home-Devices.6544441d-389d-4192-a6ff-13354907c0be.colorName","Smart-Home-Devices.6544441d-389d-4192-a6ff-13354907c0be.color-hue","Smart-Home-Devices.6544441d-389d-4192-a6ff-13354907c0be.color-saturation","Smart-Home-Devices.6544441d-389d-4192-a6ff-13354907c0be.color-brightness","Smart-Home-Devices.6544441d-389d-4192-a6ff-13354907c0be.colorRgb","Smart-Home-Devices.6544441d-389d-4192-a6ff-13354907c0be.brightness","Smart-Home-Devices.6544441d-389d-4192-a6ff-13354907c0be.connectivity","Smart-Home-Devices.6544441d-389d-4192-a6ff-13354907c0be.connectivity-reason","Smart-Home-Devices.6544441d-389d-4192-a6ff-13354907c0be.#query","Smart-Home-Devices.247ce00a-9aed-4ac9-bd50-6604d1ed5804.#enabled","Smart-Home-Devices.247ce00a-9aed-4ac9-bd50-6604d1ed5804.#delete","Smart-Home-Devices.247ce00a-9aed-4ac9-bd50-6604d1ed5804.active","Smart-Home-Devices.217aaa6f-f9be-4619-acb2-3260e45116fe.#enabled","Smart-Home-Devices.217aaa6f-f9be-4619-acb2-3260e45116fe.#delete","Smart-Home-Devices.217aaa6f-f9be-4619-acb2-3260e45116fe.powerState","Smart-Home-Devices.217aaa6f-f9be-4619-acb2-3260e45116fe.percentage","Smart-Home-Devices.d4778074-817a-48bf-a091-15d05182527c.#enabled","Smart-Home-Devices.d4778074-817a-48bf-a091-15d05182527c.#delete","Smart-Home-Devices.d4778074-817a-48bf-a091-15d05182527c.powerState","Smart-Home-Devices.f30b3cb6-56e9-4c8b-a2ce-38d10b2748f3.#enabled","Smart-Home-Devices.f30b3cb6-56e9-4c8b-a2ce-38d10b2748f3.#delete","Smart-Home-Devices.f30b3cb6-56e9-4c8b-a2ce-38d10b2748f3.powerState","Smart-Home-Devices.c85b89f0-9181-494a-807b-6f9ba37cd893.#enabled","Smart-Home-Devices.c85b89f0-9181-494a-807b-6f9ba37cd893.#delete","Smart-Home-Devices.c85b89f0-9181-494a-807b-6f9ba37cd893.powerState","Smart-Home-Devices.4abca8aa-0041-4392-ba51-20344644df4e.#includeInAllQuery","Smart-Home-Devices.6544441d-389d-4192-a6ff-13354907c0be.#includeInAllQuery","Smart-Home-Devices.3185c871-261d-4a73-a8a7-2e39cf6c74d3.#enabled","Smart-Home-Devices.3185c871-261d-4a73-a8a7-2e39cf6c74d3.#delete","Smart-Home-Devices.3185c871-261d-4a73-a8a7-2e39cf6c74d3.active","Smart-Home-Devices.20c58c78-3cfa-49a9-8ded-1d74707ae6c3.#enabled","Smart-Home-Devices.20c58c78-3cfa-49a9-8ded-1d74707ae6c3.#delete","Smart-Home-Devices.20c58c78-3cfa-49a9-8ded-1d74707ae6c3.active","Smart-Home-Devices.158df824-dd06-4fb9-875b-ec5f347da0d0.#enabled","Smart-Home-Devices.158df824-dd06-4fb9-875b-ec5f347da0d0.#delete","Smart-Home-Devices.158df824-dd06-4fb9-875b-ec5f347da0d0.active","Smart-Home-Devices.cc4e0ac1-c0ff-45c4-8a7a-7e025315f93a.#enabled","Smart-Home-Devices.cc4e0ac1-c0ff-45c4-8a7a-7e025315f93a.#delete","Smart-Home-Devices.d04b9464-e6d1-4168-88a4-0fd595e8d6db.#enabled","Smart-Home-Devices.d04b9464-e6d1-4168-88a4-0fd595e8d6db.#delete","Smart-Home-Devices.44554b70-0e67-48e0-b184-829e93599879.#enabled","Smart-Home-Devices.44554b70-0e67-48e0-b184-829e93599879.#delete","Smart-Home-Devices.8c1cea9d-54a9-4355-a318-55c66adb4a7f.#enabled","Smart-Home-Devices.8c1cea9d-54a9-4355-a318-55c66adb4a7f.#delete","Smart-Home-Devices.3f5e9367-d721-48ad-9480-3200cd2c46c7.#enabled","Smart-Home-Devices.3f5e9367-d721-48ad-9480-3200cd2c46c7.#delete","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.#enabled","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.#delete","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.powerState","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.colorTemperatureName","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.colorTemperatureInKelvin","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.colorName","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.color-hue","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.color-saturation","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.color-brightness","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.colorRgb","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.brightness","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.connectivity","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.connectivity-reason","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.#query","Smart-Home-Devices.c816b450-fcb4-42d7-a4ce-5e10310ee772.#includeInAllQuery"]
    2023-06-22 12:36:18.463  - info: alexa2.0 (1108) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-06-22 12:36:35.032  - info: alexa2.0 (1108) Initialization Done ...
    @paul53 sagte in Admin5 und Raspberry Pi 3B+?:
    Das sind mit aktuellen Adapter-Versionen wohl schon zu viele aktive Instanzen für nur 1 GB RAM.
    Eben genau, was ich damals befürchtete und daher nicht wechseln wollte. 😌
    @homoran sagte in Admin5 und Raspberry Pi 3B+?:
    @padrino sagte in Admin5 und Raspberry Pi 3B+?:
    Du willst die Adapter sehen?
    Bitte schön (wie gesagt waren mit den alten System eher 1,2 mehr).
    wie gesagt hat sich der Funktionsumfang erhöht, so dass etwa bei 10 Instanzen Schluss ist mit 1GB.
    Was mich wieder zu einer, wohl mutigen, Aussage bringt (auch wenn ich damals nicht von ioB gesprochen habe), so läuft es heute all zu gerne, es gibt immer mehr Leistung, auch wenn man diese gar nicht möchte, bzw. gar nicht braucht.
    Man zahlt "überall" mehr, man bekommt dafür auch mehr, dass man es nicht braucht, ist egal.
    Ich wäre mit meinem alten System (und dessen Funktionsumfang) ja zufrieden gewesen und wäre die SD nicht gestorben, hätte ich es wohl auch gerne einfach so weiter genutzt (dann eben ohne Support, ohne neue Features...).
    Aber man wird ja fast gesteinigt, wenn man ein altes System hat... dann ist man an allen Problemen selbst Schuld.
    Nur fingen die Probleme hier mit einem aktuellen System (also zumindest bei der Software) an. 😌
    Und neue HW kann und will ich mir eigentlich auch nicht leisten. :/
    Werde mich jetzt wohl mal schlau machen müssen, wie/ob ich hier wieder ein "Admin4 System" aufgesetzt bekomme...
    Raspberry only:
    throttled=0x20000
    temp=64.5'C
    Abgesehen von zu wenig RAM wird die Kiste auch zu warm und riegelt ab.
    Folge vom 'Strom weg':
    HomoranH padrinoP 2 Antworten Letzte Antwort
    • padrinoP padrino
      wie ist es eigentlich um den Resourcenhunger von Admin5 bestellt.
      Bin jetzt kein echter smart power user ;) und daher mit meinem kleinen 3er Pi als Zentrale zufrieden.
      Auch, wenn da nicht mehr viel Luft ist, so hat er doch noch ein paar Reserven, sodass das System hier eigentlich gut läuft.
      Nun habe ich Angst, das ihm mit Admin5 die Luft ausgeht?
      Wie sieht es da aus?
      Leider ist der Trend heutzutage ja so, dass Hardware mit der Software wachsen muss, optimiert wird leider nur noch zu selten. 😌
      CodierknechtC Offline
      Codierknecht
      Aus Gründen.
      Es war tatsächlich mal so, dass aufgrund der durchweg begrenzten Ressourcen jede Software von Anfang an nicht nur auf Performance, sondern auch auf Speicherbedarf optimiert wurde.
      Heute ist eine ausreichende Speicherausstattung aber die Regel. Optimierungen im Vorfeld sind daher eigentlich unnötig und fressen ihrerseits Ressourcen (Entwicklungszeit) und bergen die Gefahr von Fehlern. Das schenkt man sich daher.
      https://clean-code-developer.com/grades/grade-1-red/#Beware_of_Optimizations
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
        @homoran sagte: er brauch dann noch eine alte nodejs Version
        Sicher?
        @paul53 ja!
        das Kopieren von /opt/iobroker ohne weitere Anpassungen geht nur bei gleicher OS und Node-Version
        Ansonsten muss zumindest ein rebuild gefahren werden, und ob das klappt weiß ich nicht.
        Abgesehen davon verstehe ich nicht, wenn man hunderte von Euro in sein Smarthome investiert, dass man dann nicht bereit ist nach 5 Jahren + nochmal 90 Euro für einen C4
        https://www.reichelt.de/odroid-c4-4x-2-0-ghz-4-gb-ram-odroid-c4-p283467.html?&trstct=pol_9&nbc=1
        zu bezahlen, oder 110 für ein pi4 8gb bundle
        • CodierknechtC Codierknecht
          Aus Gründen.
          @codierknecht
          wieso?
          wird denn wirklich "nicht optimiert"??
          Das halte ich für eine Unterstellung.
          Es kommen weitere Funktionen hinzu.
          Dass das nicht mit noch weniger Ressourcen funktioniert ist doch klar
            @padrino sagte: Ich muss nur raus finden, welche alte Versionen hier liefen
            Kein Backup (Image) der SD-Card oder des Verzeichnisses "/opt/iobroker" vorhanden?
            padrinoP Offline
            padrinoP Offline
            padrino
            Doch, das ist da.
            Ich dachte nur, evtl. wäre es besser nochmal "sauber" aufzusetzen...
            Raspberry only:
            throttled=0x20000
            temp=64.5'C
            Hmm, dann muss ich mich mal mit Kühlung beschäftigen...
            Wie gesagt, mache ich ja nicht zum Spaß. Ist immer der letzte Schritt, zumindet meine Meingung, wenn sonst nix mehr geht.
            • padrinoP padrino
              Doch, das ist da.
              Raspberry only:
              throttled=0x20000
              temp=64.5'C
              Besser: Abwarten, abwarten, abwarten.
              Wenn dann doch gar nichts mehr gehen sollte:
              https://de.wikipedia.org/wiki/Klammergriff#Linux
                Raspberry only:
                throttled=0x20000
                temp=64.5'C
                Vielleicht geht auch die Hardware nach 5+ Jahren am Limit langsam in die Knie
                  @paul53 ja!
                  padrinoP Offline
                  padrinoP Offline
                  padrino
                  @paul53 ja!
                  Ja, es gibt Menschen, die nicht verstehen, dass es manche gibt, die sich mal was nicht leisten können...
                  Das SH ist auch über die Jahre gewachsen, quasi in Raten, und dabei aber auch in überschaubarem finanziellem Rahmen...
                  Würde sowas
                  Libre ALL-H3-CC H5 2 GB
                  es nicht auch tun?
                  Da bald mein Geburtstag ansteht, könnte ich das mal durchklingen lassen...
                    @codierknecht
                    wieso?
                    Codierknecht
                    Das würde bei mir nicht unter den Begriff "Optimierung" fallen, sondern wären eher neue Features.
                    Was der TE und ich mit "Optimierung" meinen, ist wohl eher das Tuning auf minimalen Speicherbedarf und optimale Performance. Beides macht man heute in der Regel nicht ohne einen trifftigen Grund.
                    • padrinoP padrino
                      @paul53 ja!
                      Würde sowas
                      es nicht auch tun?
                      Warum denn jetzt schon wiefer am nächsten Limit?
                      aber nach 5+ Jahren muss man auch mit dem Ableben der Hardware rechnen.
                      die 115 Kröten für den Pi4B 8GB auf die nächsten 5 Jahre sind auch nur eine Schachtel Zigaretten im Quartal.
                        Ja, der RPi3 war auch damals schon nicht wirklich üppig ausgestattet.
                        Würde sowas
                        es nicht auch tun?
                        Damit bist du auch wieder am unteren Ende. Ich würde da was mit 4GB RAM suchen. Ist zumindest perspektivisch eine bessere Wahl.
                          padrinoP Offline
                          padrinoP Offline
                          padrino
                          Wie gesagt, habe schon Tage gewartet... :/
                          Mit dem Klammergriff muss ich mir mal merken.
                          Wobei ich befürchte (hier ist keine Tastatur angeschlossen), dass im Fall der Fälle, beim Anschließen, wenn die Maschine "im Crash/Loop" ist, da auch nix mehr erkannt/gemacht wird...
                            padrinoP Offline
                            padrinoP Offline
                            padrino
                            schrieb am zuletzt editiert von padrino
                            Wieso Limit?
                            Bekomme doch das GB gerade so voll und dann hätte ich noch ein weiters...
                            Wenn ich 5 Jahre brauche um die HW an ihr Limit zu bringen und die HW eh nach 5 Jahren für die Tonne ist, dann isses doch besser, nicht mehr gezahlt zu haben, oder?
                            Zum Glück muss ich mir Rauchen nicht leisten. 😌
                            Edit:
                            Nach dem letzten Crash werden im Admin nun meine Skripte nicht mehr angezeigt, ausgeführt werden sie allerdings, sind also noch da...
                            Alles sehr merkwürdig...
                            Naja, keine Zeit jetzt dafür, muss gleich arbeiten gehen.
                            • padrinoP padrino
                              Wieso Limit?
                              Edit:
                              oder!
                              die Hardware ist seit 5 Jahren am Limit
                              • padrinoP padrino
                                Wieso Limit?
                                Edit:
                                kann an deiner Betaversion liegen
                                  padrinoP Offline
                                  padrinoP Offline
                                  padrino
                                  Eigentlich lasse ich mir betas nur gerne Anzeigen, nutze sie aber eher selten...
                                  Jetzt mit dem ganzen Ärger, habe ich das wohl vernachlässigt, bzw. zu viel automatisch erlaubt...
                                  Naja, habe versucht den JS Adapter auf V4 downzugraden, was fehlschlug, aber immerhin werden jetzt die Skripte wieder im Admin angezeigt. 😌
                                    Raspberry only:
                                    throttled=0x20000
                                    temp=64.5'C
                                    padrinoP Offline
                                    padrinoP Offline
                                    padrino
                                    Raspberry only:
                                    throttled=0x20000
                                    temp=64.5'C
                                    Hatte hier noch einen mini Lüfter rum liegen, den habe ich jetzt mal auf/über die CPU gelegt...
                                    Ergebnis:
                                    pi@raspberrypi:~ $ vcgencmd measure_temp
                                    temp=42.4'C
                                    Kann mir evtl. jemand kurz die Speicher Situation erklären? 🤔
                                    Also, jetzt nicht jeden Punkt, denke, die oberen sind die wichtigsten/aussagekräftigsten.
                                    Irgendwie sehr verwirrend, mit den unterschiedlichen Werten... :man-shrugging:
                                    pi@raspberrypi:~ $ cat /proc/meminfo | more
                                    MemTotal:         931432 kB
                                    MemFree:           93404 kB
                                    MemAvailable:     235668 kB
                                    Buffers:            3344 kB
                                    Cached:           167152 kB
                                    SwapCached:         1624 kB
                                    Active:           535400 kB
                                    Inactive:         214308 kB
                                    Active(anon):     399188 kB
                                    Inactive(anon):   180212 kB
                                    Active(file):     136212 kB
                                    Inactive(file):    34096 kB
                                    Unevictable:          16 kB
                                    Mlocked:              16 kB
                                    SwapTotal:        102396 kB
                                    SwapFree:          89844 kB
                                    Zswap:                 0 kB
                                    Zswapped:              0 kB
                                    Dirty:              1764 kB
                                    Writeback:             0 kB
                                    AnonPages:        578956 kB
                                    Mapped:            70908 kB
                                    Shmem:               188 kB
                                    KReclaimable:      34024 kB
                                    Slab:              57152 kB
                                    SReclaimable:      34024 kB
                                    SUnreclaim:        23128 kB
                                    KernelStack:        3628 kB
                                    PageTables:         4816 kB
                                    SecPageTables:         0 kB
                                    NFS_Unstable:          0 kB
                                    Bounce:                0 kB
                                    WritebackTmp:          0 kB
                                    CommitLimit:      568112 kB
                                    Committed_AS:    1006916 kB
                                    VmallocTotal:   259653632 kB
                                    VmallocUsed:        9504 kB
                                    VmallocChunk:          0 kB
                                    Percpu:              656 kB
                                    • padrinoP padrino
                                      Raspberry only:
                                      throttled=0x20000
                                      temp=64.5'C
                                      Ergebnis:
                                      temp=42.4'C
                                      MemTotal:         931432 kB
                                      MemFree:           93404 kB
                                      Buffers:            3344 kB
                                      Cached:           167152 kB
                                      SwapCached:         1624 kB
                                      Active:           535400 kB
                                      Inactive:         214308 kB
                                      Unevictable:          16 kB
                                      Mlocked:              16 kB
                                      SwapFree:          89844 kB
                                      Zswap:                 0 kB
                                      Zswapped:              0 kB
                                      Dirty:              1764 kB
                                      Writeback:             0 kB
                                      Mapped:            70908 kB
                                      Shmem:               188 kB
                                      Slab:              57152 kB
                                      PageTables:         4816 kB
                                      SecPageTables:         0 kB
                                      NFS_Unstable:          0 kB
                                      Bounce:                0 kB
                                      WritebackTmp:          0 kB
                                      VmallocChunk:          0 kB
                                      Percpu:              656 kB
                                      Das schaut schon gesünder aus.
                                      Die einzelnen Speicherbereiche sind echt eine Wissenschaft für sich. Könnte ich auch nicht erklären. Ich denke da wirst du im Netz recherchieren müssen für die Details.
