  4. [gelöst!] Docker update schlägt fehl!
    5.4k
28 Beiträge 4 Kommentatoren 3.6k Aufrufe 2 Beobachtet
  • GlasfaserG Glasfaser
    @mikeecho sagte in Docker update schlägt fehl!:
    Die Befehl funktionieren , was @FredF dir gegeben hat
    Das liegt daran :
    Server Configured backup period 120 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
    https://forum.iobroker.net/topic/54655/probleme-von-4-0-21-auf-4-0-23
    MikeEchoM Offline
    MikeEchoM Offline
    MikeEcho
    schrieb am zuletzt editiert von MikeEcho
    @glasfaser Danke für den Link.
    root@iobroker:/opt/iobroker# maintenance upgrade
    You are now going to upgrade your js-controller.
    As this will change data in /opt/iobroker, make sure you have a backup!
    During the upgrade process, the container will automatically switch into maintenance mode and stop ioBroker.
    Depending on the restart policy, your container will be stopped or restarted automatically after the upgrade.
    Do you want to continue [yes/no]? y
    You are now going to stop ioBroker and activate maintenance mode for this container.
    This command was already confirmed by the -y or --yes option.
    Activating maintenance mode...
    Done.
    Stopping ioBroker............
    Done.
    Upgrading js-controller...
    Used repository: beta
    Adapter    "admin"        : 6.5.9    , installed 6.4.3  [Updatable]
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.23   , installed 2.6.16 [Updatable]
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "daikin-cloud" : 0.2.3    , installed 0.2.3
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "denon"        : 1.15.2   , installed 1.15.0 [Updatable]
    Adapter    "discovery"    : 3.2.0    , installed 3.1.0  [Updatable]
    Adapter    "dwd"          : 2.8.5    , installed 2.8.3  [Updatable]
    Adapter    "esphome"      : 0.2.4    , installed 0.2.4
    Adapter    "fronius"      : 2.0.1    , installed 1.1.3  [Updatable]
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.16 [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
    Adapter    "iot"          : 2.0.11   , installed 1.14.5 [Updatable]
    Adapter    "javascript"   : 7.1.1    , installed 7.0.3  [Updatable]
    Adapter    "jeelink"      : 1.0.3    , installed 1.0.3
    Controller "js-controller": 5.0.5    , installed 4.0.24 [Updatable]
    Adapter    "meater"       : 1.0.0    , installed 0.2.2  [Updatable]
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.9.5  [Updatable]
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "openweathermap": 0.3.9   , installed 0.3.8  [Updatable]
    Adapter    "ring"         : 3.4.0    , installed 3.2.7  [Updatable]
    Adapter    "shelly"       : 6.4.1    , installed 6.4.0  [Updatable]
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.3.5    , installed 6.3.5
    Adapter    "telegram"     : 1.16.0   , installed 1.15.6 [Updatable]
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vw-connect"   : 0.0.71   , installed 0.0.66 [Updatable]
    Adapter    "web"          : 5.5.3    , installed 5.5.3
    Adapter    "ws"           : 2.3.6    , installed 2.3.6
    Adapter    "zoneminder"   : 0.3.3    , installed 0.3.3
    Server Objects 10.10.10.110:39420 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
    Server Objects 10.10.10.110:39452 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
    Server Objects 10.10.10.110:39454 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
    Update js-controller from @4.0.24 to @5.0.5
    Stopped Objects DB
    Stopped States DB
    NPM version: 9.5.1
    Installing iobroker.js-controller@5.0.5... (System call)
    Done.
    Container will be stopped or restarted in 5 seconds...
    Leider löst es das Problem nicht, obwohl die vermeintliche Ursache behoben ist.
    • MikeEchoM MikeEcho
      Done.
      Done.
      Stopped Objects DB
      Stopped States DB
      NPM version: 9.5.1
      Done.
      GlasfaserG Offline
      GlasfaserG Offline
      Das kann ich gerade nicht einordnen ... hast du das immer schon gehabt !?
      MikeEchoM 1 Antwort Letzte Antwort
        MikeEchoM Offline
        MikeEchoM Offline
        MikeEcho
        @glasfaser said in Docker update schlägt fehl!:
        Das kann ich leider nicht genau sagen. Gefühlt erst seit dem Update.
          GlasfaserG Offline
          GlasfaserG Offline
          @mikeecho
          Teste mal mit
          pkill -u iobroker
          sudo -H -u iobroker npm cache clean --force
          iob upgrade self
          wenns durchläuft , dann den Container neu starten
            @mikeecho
            Teste mal mit
            pkill -u iobroker
            iob upgrade self
            MikeEchoM Offline
            MikeEchoM Offline
            MikeEcho
            iob upgrade self
            root@iobroker:/opt/iobroker# pkill -u iobroker
            root@iobroker:/opt/iobroker# sudo -H -u iobroker npm cache clean --force
            npm WARN using --force Recommended protections disabled.
            root@iobroker:/opt/iobroker# iob upgrade self
            Stopped Objects DB
            Stopped States DB
            NPM version: 9.5.1
            So wie es aussieht ist es durchgelaufen.
            Nach Container-Neustart leider:
            • GlasfaserG Offline
              GlasfaserG Offline
              @mikeecho
              zeige
              iobroker update
                @mikeecho
                zeige
                iobroker update
                MikeEchoM Offline
                MikeEchoM Offline
                MikeEcho
                @glasfaser
                root@iobroker:/opt/iobroker# iobroker update
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @mikeecho
                  pkill -u iobroker
                  iobroker upgrade self --debug
                  Ausgabe posten
                    @mikeecho
                    pkill -u iobroker
                    Ausgabe posten
                    MikeEchoM Offline
                    MikeEchoM Offline
                    MikeEcho
                    root@iobroker:/opt/iobroker# iobroker upgrade self --debug
                    Stopped Objects DB
                    Stopped States DB
                    NPM version: 9.5.1
                    npm ERR! code EBADENGINE
                    npm ERR! engine Unsupported engine
                    npm ERR! engine Not compatible with your version of node/npm: iobroker.daikin-cloud@0.2.3
                    npm ERR! notsup Not compatible with your version of node/npm: iobroker.daikin-cloud@0.2.3
                    npm ERR! notsup Required: {"node":"^12.19.0 || ^14.15.0 || ^16.13.0"}
                    npm ERR! notsup Actual:   {"npm":"9.5.1","node":"v18.16.0"}
                    npm ERR!     /opt/iobroker/.npm/_logs/2023-06-21T17_11_44_239Z-debug-0.log
                      GlasfaserG Offline
                      https://forum.iobroker.net/post/1000386
                        MikeEchoM Offline
                        MikeEchoM Offline
                        MikeEcho
                        @glasfaser
                        root@iobroker:/opt/iobroker# iob del daikin-cloud --debug
                        Delete adapter "daikin-cloud"
                        removed 136 packages in 10s
                        149 packages are looking for funding
                          run `npm fund` for details
                        root@iobroker:/opt/iobroker# iobroker url Apollon77/ioBroker.daikin-cloud --host iobroker --debug
                        install Apollon77/ioBroker.daikin-cloud
                        NPM version: 9.5.1
                        Installing Apollon77/ioBroker.daikin-cloud... (System call)
                        Server Objects 10.10.10.110:57324 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
                        Server Objects 10.10.10.110:57324 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
                        Server Objects 10.10.10.110:57324 Error from InMemDB: Error: eval NOT SUPPORTED
                        Server Objects 10.10.10.110:57356 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
                        Server Objects 10.10.10.110:57378 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
                        added 36 packages in 15s
                        152 packages are looking for funding
                        upload [6] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/admin.d.ts admin.d.ts video/mp2t
                        upload [5] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin-cloud.jpg daikin-cloud.jpg image/jpeg
                        upload [4] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin_logo.jpg daikin_logo.jpg image/jpeg
                        upload [3] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/index_m.html index_m.html text/html
                        upload [2] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/style.css style.css text/css
                        upload [1] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/warning.png warning.png image/png
                        upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
                        Ich vermute, der LUA-time-limit Fehler kommt von dort!?
                          @glasfaser
                          NPM version: 9.5.1
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @mikeecho
                          lösche nur den daikin-cloud .
                          dann nochmal
                            @mikeecho
                            dann nochmal
                            MikeEchoM Offline
                            MikeEchoM Offline
                            MikeEcho
                            YES!
                            Vielen Dank!!!
                              YES!
                              Vielen Dank!!!
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Vielen Dank!!!
                              Kein Thema .
                              Dann weiterhin viel Spaß ... als Beta Tester ;) 😀
