  4. [gelöst!] Docker update schlägt fehl!
    5.4k
28 Beiträge 4 Kommentatoren 3.6k Aufrufe 2 Beobachtet
  • MikeEchoM MikeEcho
    @fredf said in Docker update schlägt fehl!:
    Glaube ich eher nicht. Aber Versuch macht kluch...
    So siehts aus. Leider klappt es auch so nicht.
    root@iobroker:/opt/iobroker# maintenance upgrade
    You are now going to upgrade your js-controller.
    As this will change data in /opt/iobroker, make sure you have a backup!
    During the upgrade process, the container will automatically switch into maintenance mode and stop ioBroker.
    Depending on the restart policy, your container will be stopped or restarted automatically after the upgrade.
    Do you want to continue [yes/no]? y
    You are now going to stop ioBroker and activate maintenance mode for this container.
    This command was already confirmed by the -y or --yes option.
    Activating maintenance mode...
    Done.
    Stopping ioBroker...........
    Done.
    Upgrading js-controller...
    Server Configured backup period 120 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
    Used repository: beta
    Adapter    "admin"        : 6.5.9    , installed 6.4.3  [Updatable]
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.23   , installed 2.6.16 [Updatable]
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "daikin-cloud" : 0.2.3    , installed 0.2.3
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "denon"        : 1.15.2   , installed 1.15.0 [Updatable]
    Adapter    "discovery"    : 3.2.0    , installed 3.1.0  [Updatable]
    Adapter    "dwd"          : 2.8.5    , installed 2.8.3  [Updatable]
    Adapter    "esphome"      : 0.2.4    , installed 0.2.4
    Adapter    "fronius"      : 2.0.1    , installed 1.1.3  [Updatable]
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.16 [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
    Adapter    "iot"          : 2.0.11   , installed 1.14.5 [Updatable]
    Adapter    "javascript"   : 7.1.1    , installed 7.0.3  [Updatable]
    Adapter    "jeelink"      : 1.0.3    , installed 1.0.3
    Controller "js-controller": 5.0.5    , installed 4.0.24 [Updatable]
    Adapter    "meater"       : 1.0.0    , installed 0.2.2  [Updatable]
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.9.5  [Updatable]
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "openweathermap": 0.3.9   , installed 0.3.8  [Updatable]
    Adapter    "ring"         : 3.4.0    , installed 3.2.7  [Updatable]
    Adapter    "shelly"       : 6.4.1    , installed 6.4.0  [Updatable]
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.3.5    , installed 6.3.5
    Adapter    "telegram"     : 1.16.0   , installed 1.15.6 [Updatable]
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vw-connect"   : 0.0.71   , installed 0.0.66 [Updatable]
    Adapter    "web"          : 5.5.3    , installed 5.5.3
    Adapter    "ws"           : 2.3.6    , installed 2.3.6
    Adapter    "zoneminder"   : 0.3.3    , installed 0.3.3
    Server Objects 10.10.10.110:40690 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
    Server Objects 10.10.10.110:40730 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
    Server Objects 10.10.10.110:40716 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
    Update js-controller from @4.0.24 to @5.0.5
    Stopped Objects DB
    Stopped States DB
    NPM version: 9.5.1
    Installing iobroker.js-controller@5.0.5... (System call)
    Done!
    GlasfaserG Offline
    GlasfaserG Offline
    @mikeecho sagte in Docker update schlägt fehl!:
    Die Befehl funktionieren , was @FredF dir gegeben hat
    Das liegt daran :
    https://forum.iobroker.net/topic/54655/probleme-von-4-0-21-auf-4-0-23
    MikeEchoM 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      Das liegt daran :
      MikeEchoM Offline
      MikeEchoM Offline
      MikeEcho
      schrieb am zuletzt editiert von MikeEcho
      @glasfaser Danke für den Link.
      Done.
      Stopping ioBroker............
      Done.
      Server Objects 10.10.10.110:39420 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
      Server Objects 10.10.10.110:39452 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
      Server Objects 10.10.10.110:39454 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
      Stopped Objects DB
      Stopped States DB
      NPM version: 9.5.1
      Done.
      Container will be stopped or restarted in 5 seconds...
      Leider löst es das Problem nicht, obwohl die vermeintliche Ursache behoben ist.
        Done.
        Done.
        Stopped Objects DB
        Stopped States DB
        NPM version: 9.5.1
        Done.
        GlasfaserG Offline
        GlasfaserG Offline
        Das kann ich gerade nicht einordnen ... hast du das immer schon gehabt !?
          MikeEchoM Offline
          MikeEchoM Offline
          MikeEcho
          @glasfaser said in Docker update schlägt fehl!:
          Das kann ich leider nicht genau sagen. Gefühlt erst seit dem Update.
            GlasfaserG Offline
            GlasfaserG Offline
            @mikeecho
            Teste mal mit
            pkill -u iobroker
            sudo -H -u iobroker npm cache clean --force
            iob upgrade self
            wenns durchläuft , dann den Container neu starten
              @mikeecho
              Teste mal mit
              pkill -u iobroker
              iob upgrade self
              MikeEchoM Offline
              MikeEchoM Offline
              MikeEcho
              iob upgrade self
              root@iobroker:/opt/iobroker# pkill -u iobroker
              root@iobroker:/opt/iobroker# sudo -H -u iobroker npm cache clean --force
              npm WARN using --force Recommended protections disabled.
              root@iobroker:/opt/iobroker# iob upgrade self
              Stopped Objects DB
              Stopped States DB
              NPM version: 9.5.1
              So wie es aussieht ist es durchgelaufen.
              Nach Container-Neustart leider:
              • GlasfaserG Offline
                GlasfaserG Offline
                @mikeecho
                zeige
                iobroker update
                  @mikeecho
                  zeige
                  iobroker update
                  MikeEchoM Offline
                  MikeEchoM Offline
                  MikeEcho
                  @glasfaser
                  root@iobroker:/opt/iobroker# iobroker update
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @mikeecho
                    pkill -u iobroker
                    iobroker upgrade self --debug
                    Ausgabe posten
                      @mikeecho
                      pkill -u iobroker
                      Ausgabe posten
                      MikeEchoM Offline
                      MikeEchoM Offline
                      MikeEcho
                      root@iobroker:/opt/iobroker# iobroker upgrade self --debug
                      Stopped Objects DB
                      Stopped States DB
                      NPM version: 9.5.1
                      npm ERR! code EBADENGINE
                      npm ERR! engine Unsupported engine
                      npm ERR! engine Not compatible with your version of node/npm: iobroker.daikin-cloud@0.2.3
                      npm ERR! notsup Not compatible with your version of node/npm: iobroker.daikin-cloud@0.2.3
                      npm ERR! notsup Required: {"node":"^12.19.0 || ^14.15.0 || ^16.13.0"}
                      npm ERR! notsup Actual:   {"npm":"9.5.1","node":"v18.16.0"}
                      npm ERR!     /opt/iobroker/.npm/_logs/2023-06-21T17_11_44_239Z-debug-0.log
                        GlasfaserG Offline
                        https://forum.iobroker.net/post/1000386
                          MikeEchoM Offline
                          MikeEchoM Offline
                          MikeEcho
                          @glasfaser
                          root@iobroker:/opt/iobroker# iob del daikin-cloud --debug
                          Delete adapter "daikin-cloud"
                          removed 136 packages in 10s
                          149 packages are looking for funding
                            run `npm fund` for details
                          root@iobroker:/opt/iobroker# iobroker url Apollon77/ioBroker.daikin-cloud --host iobroker --debug
                          install Apollon77/ioBroker.daikin-cloud
                          NPM version: 9.5.1
                          Installing Apollon77/ioBroker.daikin-cloud... (System call)
                          Server Objects 10.10.10.110:57324 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
                          Server Objects 10.10.10.110:57324 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
                          Server Objects 10.10.10.110:57324 Error from InMemDB: Error: eval NOT SUPPORTED
                          Server Objects 10.10.10.110:57356 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
                          Server Objects 10.10.10.110:57378 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
                          added 36 packages in 15s
                          152 packages are looking for funding
                          upload [6] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/admin.d.ts admin.d.ts video/mp2t
                          upload [5] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin-cloud.jpg daikin-cloud.jpg image/jpeg
                          upload [4] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin_logo.jpg daikin_logo.jpg image/jpeg
                          upload [3] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/index_m.html index_m.html text/html
                          upload [2] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/style.css style.css text/css
                          upload [1] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/warning.png warning.png image/png
                          upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
                          Ich vermute, der LUA-time-limit Fehler kommt von dort!?
                            @glasfaser
                            NPM version: 9.5.1
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @mikeecho
                            lösche nur den daikin-cloud .
                            dann nochmal
                              @mikeecho
                              dann nochmal
                              MikeEchoM Offline
                              MikeEchoM Offline
                              MikeEcho
                              YES!
                              Vielen Dank!!!
                                YES!
                                Vielen Dank!!!
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Vielen Dank!!!
                                Kein Thema .
                                Dann weiterhin viel Spaß ... als Beta Tester ;) 😀
