  4. [gelöst!] Docker update schlägt fehl!
    5.4k
28 Beiträge 4 Kommentatoren 3.6k Aufrufe 2 Beobachtet
  • FredFF FredF
    @mikeecho sagte in Docker update schlägt fehl!:
    Vielleicht hat das ja noch eine "geheime" Zutat.
    Glaube ich eher nicht. Aber Versuch macht kluch...
    MikeEchoM Offline
    MikeEchoM Offline
    MikeEcho
    schrieb am zuletzt editiert von MikeEcho
    @fredf said in Docker update schlägt fehl!:
    So siehts aus. Leider klappt es auch so nicht.
    root@iobroker:/opt/iobroker# maintenance upgrade
    You are now going to upgrade your js-controller.
    As this will change data in /opt/iobroker, make sure you have a backup!
    During the upgrade process, the container will automatically switch into maintenance mode and stop ioBroker.
    Depending on the restart policy, your container will be stopped or restarted automatically after the upgrade.
    Do you want to continue [yes/no]? y
    You are now going to stop ioBroker and activate maintenance mode for this container.
    This command was already confirmed by the -y or --yes option.
    Activating maintenance mode...
    Done.
    Stopping ioBroker...........
    Done.
    Upgrading js-controller...
    Server Configured backup period 120 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
    Used repository: beta
    Adapter    "admin"        : 6.5.9    , installed 6.4.3  [Updatable]
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.23   , installed 2.6.16 [Updatable]
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "daikin-cloud" : 0.2.3    , installed 0.2.3
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "denon"        : 1.15.2   , installed 1.15.0 [Updatable]
    Adapter    "discovery"    : 3.2.0    , installed 3.1.0  [Updatable]
    Adapter    "dwd"          : 2.8.5    , installed 2.8.3  [Updatable]
    Adapter    "esphome"      : 0.2.4    , installed 0.2.4
    Adapter    "fronius"      : 2.0.1    , installed 1.1.3  [Updatable]
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.16 [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
    Adapter    "iot"          : 2.0.11   , installed 1.14.5 [Updatable]
    Adapter    "javascript"   : 7.1.1    , installed 7.0.3  [Updatable]
    Adapter    "jeelink"      : 1.0.3    , installed 1.0.3
    Controller "js-controller": 5.0.5    , installed 4.0.24 [Updatable]
    Adapter    "meater"       : 1.0.0    , installed 0.2.2  [Updatable]
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.9.5  [Updatable]
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "openweathermap": 0.3.9   , installed 0.3.8  [Updatable]
    Adapter    "ring"         : 3.4.0    , installed 3.2.7  [Updatable]
    Adapter    "shelly"       : 6.4.1    , installed 6.4.0  [Updatable]
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.3.5    , installed 6.3.5
    Adapter    "telegram"     : 1.16.0   , installed 1.15.6 [Updatable]
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vw-connect"   : 0.0.71   , installed 0.0.66 [Updatable]
    Adapter    "web"          : 5.5.3    , installed 5.5.3
    Adapter    "ws"           : 2.3.6    , installed 2.3.6
    Adapter    "zoneminder"   : 0.3.3    , installed 0.3.3
    Server Objects 10.10.10.110:40690 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
    Server Objects 10.10.10.110:40730 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
    Server Objects 10.10.10.110:40716 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
    Update js-controller from @4.0.24 to @5.0.5
    Stopped Objects DB
    Stopped States DB
    NPM version: 9.5.1
    Installing iobroker.js-controller@5.0.5... (System call)
    Done!
    • MikeEchoM MikeEcho
      Done.
      Done.
      Stopped Objects DB
      Stopped States DB
      NPM version: 9.5.1
      Done!
      GlasfaserG Offline
      GlasfaserG Offline
      Die Befehl funktionieren , was @FredF dir gegeben hat
      Das liegt daran :
      https://forum.iobroker.net/topic/54655/probleme-von-4-0-21-auf-4-0-23
      MikeEchoM 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        Das liegt daran :
        MikeEchoM Offline
        MikeEchoM Offline
        MikeEcho
        @glasfaser Danke für den Link.
        Done.
        Stopping ioBroker............
        Done.
        Server Objects 10.10.10.110:39420 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
        Server Objects 10.10.10.110:39452 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
        Server Objects 10.10.10.110:39454 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
        Stopped Objects DB
        Stopped States DB
        NPM version: 9.5.1
        Done.
        Container will be stopped or restarted in 5 seconds...
        Leider löst es das Problem nicht, obwohl die vermeintliche Ursache behoben ist.
          Done.
          Done.
          Stopped Objects DB
          Stopped States DB
          NPM version: 9.5.1
          Done.
          GlasfaserG Offline
          GlasfaserG Offline
          Das kann ich gerade nicht einordnen ... hast du das immer schon gehabt !?
            MikeEchoM Offline
            MikeEchoM Offline
            MikeEcho
            @glasfaser said in Docker update schlägt fehl!:
            Das kann ich leider nicht genau sagen. Gefühlt erst seit dem Update.
              GlasfaserG Offline
              GlasfaserG Offline
              @mikeecho
              Teste mal mit
              pkill -u iobroker
              sudo -H -u iobroker npm cache clean --force
              iob upgrade self
              wenns durchläuft , dann den Container neu starten
                @mikeecho
                Teste mal mit
                pkill -u iobroker
                iob upgrade self
                MikeEchoM Offline
                MikeEchoM Offline
                MikeEcho
                iob upgrade self
                root@iobroker:/opt/iobroker# pkill -u iobroker
                root@iobroker:/opt/iobroker# sudo -H -u iobroker npm cache clean --force
                npm WARN using --force Recommended protections disabled.
                root@iobroker:/opt/iobroker# iob upgrade self
                Stopped Objects DB
                Stopped States DB
                NPM version: 9.5.1
                So wie es aussieht ist es durchgelaufen.
                Nach Container-Neustart leider:
                • GlasfaserG Offline
                  GlasfaserG Offline
                  @mikeecho
                  zeige
                  iobroker update
                    @mikeecho
                    zeige
                    iobroker update
                    MikeEchoM Offline
                    MikeEchoM Offline
                    MikeEcho
                    @glasfaser
                    root@iobroker:/opt/iobroker# iobroker update
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @mikeecho
                      pkill -u iobroker
                      iobroker upgrade self --debug
                      Ausgabe posten
                        @mikeecho
                        pkill -u iobroker
                        Ausgabe posten
                        MikeEchoM Offline
                        MikeEchoM Offline
                        MikeEcho
                        root@iobroker:/opt/iobroker# iobroker upgrade self --debug
                        Stopped Objects DB
                        Stopped States DB
                        NPM version: 9.5.1
                        npm ERR! code EBADENGINE
                        npm ERR! engine Unsupported engine
                        npm ERR! engine Not compatible with your version of node/npm: iobroker.daikin-cloud@0.2.3
                        npm ERR! notsup Not compatible with your version of node/npm: iobroker.daikin-cloud@0.2.3
                        npm ERR! notsup Required: {"node":"^12.19.0 || ^14.15.0 || ^16.13.0"}
                        npm ERR! notsup Actual:   {"npm":"9.5.1","node":"v18.16.0"}
                        npm ERR!     /opt/iobroker/.npm/_logs/2023-06-21T17_11_44_239Z-debug-0.log
                          GlasfaserG Offline
                          https://forum.iobroker.net/post/1000386
                            MikeEchoM Offline
                            MikeEchoM Offline
                            MikeEcho
                            @glasfaser
                            root@iobroker:/opt/iobroker# iob del daikin-cloud --debug
                            Delete adapter "daikin-cloud"
                            removed 136 packages in 10s
                            149 packages are looking for funding
                              run `npm fund` for details
                            root@iobroker:/opt/iobroker# iobroker url Apollon77/ioBroker.daikin-cloud --host iobroker --debug
                            install Apollon77/ioBroker.daikin-cloud
                            NPM version: 9.5.1
                            Installing Apollon77/ioBroker.daikin-cloud... (System call)
                            Server Objects 10.10.10.110:57324 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
                            Server Objects 10.10.10.110:57324 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
                            Server Objects 10.10.10.110:57324 Error from InMemDB: Error: eval NOT SUPPORTED
                            Server Objects 10.10.10.110:57356 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
                            Server Objects 10.10.10.110:57378 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
                            added 36 packages in 15s
                            152 packages are looking for funding
                            upload [6] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/admin.d.ts admin.d.ts video/mp2t
                            upload [5] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin-cloud.jpg daikin-cloud.jpg image/jpeg
                            upload [4] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin_logo.jpg daikin_logo.jpg image/jpeg
                            upload [3] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/index_m.html index_m.html text/html
                            upload [2] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/style.css style.css text/css
                            upload [1] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/warning.png warning.png image/png
                            upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
                            Ich vermute, der LUA-time-limit Fehler kommt von dort!?
                              @glasfaser
                              NPM version: 9.5.1
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @mikeecho
                              lösche nur den daikin-cloud .
                              dann nochmal
                                @mikeecho
                                dann nochmal
                                MikeEchoM Offline
                                MikeEchoM Offline
                                MikeEcho
                                YES!
                                Vielen Dank!!!
                                  YES!
                                  Vielen Dank!!!
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Vielen Dank!!!
                                  Kein Thema .
                                  Dann weiterhin viel Spaß ... als Beta Tester ;) 😀
