  4. Backitup-/influxd - Error: unknown flag: --bucket
    5.4k
19 Beiträge 5 Kommentatoren 890 Aufrufe 3 Beobachtet
    @tt-tom
    Bei Verwendung von influxdb2 keiner.
    Bzw. könnte dann da wohl /usr/bin/influx eingetragen werden.
    TT-Tom
    danke werde es mal testen. Habe das Feld leer gelassen und es ist laut Backupit durch gelaufen.
    Started iobroker ...
    [DEBUG] [iobroker] - host.iobtest 2359 states saved
    [DEBUG] [iobroker] - host.iobtest 2313 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_06_18-21_06_13_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - InfluxDB-Backup started ...
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Packed 171MB so far...
    [DEBUG] [influxDB] - Packed 326MB so far...
    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_06_18-21_06_16_backupiobroker.tar.gz
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_06_18-21_06_16_backupiobroker"
    [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_06_18-21_06_16_backupiobroker" successfully deleted
    [DEBUG] [influxDB] - InfluxDB-Backup for is finish
    [DEBUG] [influxDB] - done
    [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [EXIT] 0
    der Restore lief nicht durch, wollte die aktuelle DB einfach mal mit dem Backup überschreiben.
    Started restore ...
    [DEBUG] [influxDB] - Created tmp directory
    [DEBUG] [influxDB] - Start infuxDB Restore ...
    [DEBUG] [influxDB] - influxdb.0 is stopped
    [ERROR] [influxDB] - 2023/06/18 21:11:39 INFO: Restoring bucket "ea25e11851af6754" as "ioBrokerBucket"
    Error: failed to restore bucket "ioBrokerBucket": 422 Unprocessable Entity: bucket with name ioBrokerBucket already exists
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [DEBUG] [influxDB] - infuxDB Restore completed successfully
    [EXIT] influxDB restore done
    [DEBUG] [influxDB] - influxdb.0 started
    muss für den Restore influx gestoppt werden?
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    • T TT-Tom
      [EXIT] 0
      Started restore ...
      @tt-tom
      Musst du hier mal nachlesen:
      https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup
        @tt-tom
        TT-Tom
        danke für den Hinweis. Das ist die entscheidende Stelle in der Anleitung:
        ioBroker.backitup löscht/ergänzt/überschreibt etc. aktuell kein Bucket mit identischem Namen beim Restore.
        Gruß Tom
        Public Transport
        • T TT-Tom
          Ich kapier es nicht. Backup für grafana sowie influxdb ist aktiv:
          Aber im log keine Spur der beiden, nicht mal Fehlermeldungen.
          [DEBUG] [mount] - noserverino option: true
          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,noserverino,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/fritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups"
          [DEBUG] [mount] - mount successfully completed
          [DEBUG] [mount] - done
          [DEBUG] [iobroker] - host.chet 7866 states saved
          [DEBUG] [iobroker] - host.chet 9746 objects saved
          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_06_19-19_40_36_chet_backupiobroker.tar.gz
          [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
          [DEBUG] [historyDB] - compress from historyDB started ...
          [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2023_06_19-19_40_49_chet_backupiobroker.tar.gz
          [DEBUG] [historyDB] - done
          [DEBUG] [zigbee] - found zigbee database: zigbee.0
          [DEBUG] [zigbee] - done
          [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
          [DEBUG] [javascripts] - found Script: dwd_uwz_nina_warnungen
          [DEBUG] [javascripts] - found Script: lautstaerke_bad
          [DEBUG] [javascripts] - found Script: lautstaerke_kueche
          [DEBUG] [javascripts] - found Script: paketlieferungen
          [DEBUG] [javascripts] - found Script: pakettruhe_offen
          [DEBUG] [javascripts] - found Script: ps4_waker
          [DEBUG] [javascripts] - found Script: sonnenaufgang
          [DEBUG] [javascripts] - found Script: sonnenuntergang
          [DEBUG] [javascripts] - found Script: speedtest
          [DEBUG] [javascripts] - found Script: telefon_klingelt
          [DEBUG] [javascripts] - found Script: treppenhaus_licht_ble
          [DEBUG] [javascripts] - found Script: treppenhaus_licht_hub
          [DEBUG] [javascripts] - found Script: tuerklingel_laeutet
          [DEBUG] [javascripts] - found Script: vorhaenge-sonnenschutz
          [DEBUG] [javascripts] - found Script: wohnung_verlassen
          [DEBUG] [javascripts] - found Script: wohnungstuer_entriegelt
          [DEBUG] [javascripts] - found Script: awtrix
          [DEBUG] [javascripts] - found Script: zuhause_verlassen
          [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
          [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
          [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2023_06_19-19_40_50_chet_backupiobroker.tar.gz
          [DEBUG] [javascripts] - done
          [DEBUG] [cifs] - used copy path: /fritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet
          [DEBUG] [cifs] - done
          [DEBUG] [googledrive] - Google Drive: Copy iobroker_2023_06_19-19_40_36_chet_backupiobroker.tar.gz...
          [DEBUG] [googledrive] - Google Drive: Copy historyDB_2023_06_19-19_40_49_chet_backupiobroker.tar.gz...
          [DEBUG] [googledrive] - Google Drive: Copy zigbee.0_2023_06_19-19_40_50_chet_backupiobroker.tar.gz...
          [DEBUG] [googledrive] - Google Drive: Copy javascripts_2023_06_19-19_40_50_chet_backupiobroker.tar.gz...
          [DEBUG] [googledrive] - done
          [DEBUG] [whatsapp] - done
          [DEBUG] [umount] - mount activ, umount is started ...
          [DEBUG] [umount] - umount successfully completed
          [DEBUG] [umount] - done
          [EXIT] 0
          Was mach ich denn wo falsch?
            [EXIT] 0
            crunchipC Offline
            crunchipC Offline
            @thomas-braun hast du denn auch etwas in Grafana bzw Influx angelegt, wenn noch leer gibts kein backup
              @crunchip Grafana ist in der Tat noch nix drin, aber in influxdb laufen die ersten Werte rein.
                crunchipC Offline
                crunchipC Offline
                @thomas-braun ok, soviel ich weiß, funktioniert das backup erst wenn ein dashboard vorhanden ist, wenn influx läuft sollte da ne Ausgabe kommen
                  @crunchip
                  Mit so'm Grafikgedöns wie Dashboards hab ich mich noch nicht beschäftigt. Dann wird es wohl daran liegen.
                  Irgendwie wird mir das aber auch alles zu doof. Ist mir zu viel.
                  Ich beschränke mich dann wohl doch auf echarts.
                  Schwuppdiwupp, 400 MB mehr frei auf dem Datenträger....
                  The following packages will be REMOVED:
                    grafana influxdb2
                  0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
                  After this operation, 399 MB disk space will be freed.
                  Do you want to continue? [Y/n] Y
                  crunchipC HomoranH 2 Antworten Letzte Antwort
                    @crunchip
                      grafana influxdb2
                    crunchipC Offline
                    crunchipC Offline
                    @thomas-braun hat mich eh schon gewundert 😂 , nutz du ja eigentlich gar nicht
                      @crunchip
                      Ich hatte gedacht, Grafana 10 könnte ich mir ja mal anschauen, wenn ich mein Balkonkraftwerk etwas monitoren will. Aber das ist ja komplett mit Kanonen auf Spatzen geschossen. >400MB nur für buntere Graphen und die Einarbeitungszeit in die beiden Dinger ist es mir dann doch nicht wert.
                        @crunchip
                        crunchipC Offline
                        crunchipC Offline
                        @thomas-braun naja, nur für ein Dashboard ist es natürlich Blödsinn.
                        Aber es gibt ja noch sooooooo viel mehr zum monitoren, abseits vom iobroker
                        alle möglichen Daten, die du mit telegraf, node exporter oder was auch immer, einholen kannst
                          @crunchip
                          Nö, ist für mich nix.
                            @crunchip
                              grafana influxdb2
                            @thomas-braun sagte in Backitup-/influxd - Error: unknown flag: --bucket:
                            Ist mir zu viel.
                            Die Folge davon bei mir
                            54GB History Daten wegen gefühlt hunderter Flot Diagramme in Hochauflösung
                              Ist mir zu viel.
                              @homoran Werden es bei mir nicht werden. Ich habe gerade ein echart für die Bandbreitenmessung und dann wollte ich für das Balkonkraftwerk noch was kleines zusammenzimmern. Und dann fällt mir auch nix mehr ein, was ich in bunte Bilder gießen wollte.
