  4. Solved: BackITUp: MySQL DB Sicherung schlägt fehl
    5.4k
53 Beiträge 5 Kommentatoren 7.3k Aufrufe 3 Beobachtet
  • Azrael42A Azrael42
    @glasfaser
    User für IOBroker ist "iobroker"
    mein Admin User ist "richard"
    der Sudo User ist "root"
    Welchen User ich für die MariaDB verwendet habe muss ich gerade noch herausfinden...
    richard@RKO-Central:~$ sudo apt install mariadb-client
    Reading package lists... Done
    The following NEW packages will be installed:
      mariadb-client
    0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
    Need to get 35.4 kB of archives.
    After this operation, 73.7 kB of additional disk space will be used.
    Get:1 http://deb.debian.org/debian bullseye/main amd64 mariadb-client all 1:10.5.19-0+deb11u2 [35.4 kB]
    Fetched 35.4 kB in 0s (216 kB/s)
    Selecting previously unselected package mariadb-client.
    (Reading database ... 54110 files and directories currently installed.)
    Preparing to unpack .../mariadb-client_1%3a10.5.19-0+deb11u2_all.deb ...
    Unpacking mariadb-client (1:10.5.19-0+deb11u2) ...
    Setting up mariadb-client (1:10.5.19-0+deb11u2) ...
    Den Client habe ich noch einmal installiert, leider keine Änderung.
    mariadb.service - MariaDB 10.5.19 database server
         Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
         Active: active (running) since Sat 2023-06-10 19:58:28 CEST; 29min ago
           Docs: man:mariadbd(8)
                 https://mariadb.com/kb/en/library/systemd/
       Main PID: 7416 (mariadbd)
         Status: "Taking your SQL requests now..."
          Tasks: 47 (limit: 4560)
         Memory: 198.5M
            CPU: 48.547s
         CGroup: /system.slice/mariadb.service
                 └─7416 /usr/sbin/mariadbd
    Jun 10 19:58:28 RKO-Central mariadbd[7416]: 2023-06-10 19:58:28 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
    Jun 10 19:58:28 RKO-Central mariadbd[7416]: 2023-06-10 19:58:28 0 [Note] Server socket created on IP: '0.0.0.0'.
    Jun 10 19:58:28 RKO-Central mariadbd[7416]: 2023-06-10 19:58:28 0 [Note] Reading of all Master_info entries succeeded
    Jun 10 19:58:28 RKO-Central mariadbd[7416]: 2023-06-10 19:58:28 0 [Note] Added new Master_info '' to hash table
    Jun 10 19:58:28 RKO-Central mariadbd[7416]: 2023-06-10 19:58:28 0 [Note] /usr/sbin/mariadbd: ready for connections.
    Jun 10 19:58:28 RKO-Central mariadbd[7416]: Version: '10.5.19-MariaDB-0+deb11u2'  socket: '/run/mysqld/mysqld.sock'  port: 3306  Debian 11
    Jun 10 19:58:28 RKO-Central mariadbd[7416]: 2023-06-10 19:58:28 0 [Note] InnoDB: Buffer pool(s) load completed at 230610 19:58:28
    Jun 10 19:58:28 RKO-Central systemd[1]: Started MariaDB 10.5.19 database server.
    Jun 10 19:58:28 RKO-Central /etc/mysql/debian-start[7438]: Upgrading MySQL tables if necessary.
    @azrael42 sagte in BackITUp: MySQL DB Sicherung schlägt fehl:
    Moin,
    noch mal, hast Du im ioBroker Adapter den vollen Pfad zum mariadb-dump/mysqldump angegeben? Du scheinst jetzt beide Clients MariaDB und MySQL installiert zu haben. da mal den richtigen Pfad im Adapter einstellen, Zeigen.
    Der User iobroker findet das Programm nicht, lies noch mal was Du checken solltest
    In der /etc/sudoers ist der User "root" angegeben. Den könnte man da ja auch anpassen.
    Spiel doch nicht an etwas herum, wo Du mehr kaputt machen kannst als, dass es Dir hilft.
    Bernd
    Azrael42A 1 Antwort Letzte Antwort
      Ich glaube du hast dir irgendwie bei den Rechten was komplett zerfummelt...
        Moin,
        Bernd
        Azrael42A Offline
        Azrael42A Offline
        Azrael42
        @dp20eic said in BackITUp: MySQL DB Sicherung schlägt fehl:
        Ja, ich habe den vollen Pfad eingetragen.
        Leider kann ich mich nicht als User "iobroker" anmelden, der scheint keine Rechte zu haben.
        Ich lese jetzt nochmal exakt welchen Client ich wie zu installieren habe.
        Hab ich nicht. Wollte nur schlau klingen und habe das Ergebnis der Google Suche raus gehauen. ;) Wie du merkst, ist Linux nicht so meine Stärke...
        Aber ich vermute langsam auch, das es an den Rechten liegt.
        @thomas-braun said in BackITUp: MySQL DB Sicherung schlägt fehl:
        Das Gefühl drängt sich mir auch auf...
        KNX - Modbus - EBus - Smartmeter
        PV Überschuss Steuerung für Wallbox und WP mit Node-Red, SQL Programmierung, eigens entwickelte KNX Komponenten
        Thomas BraunT ? 3 Antworten Letzte Antwort
          @azrael42
          Was hast du denn am 25. Mai gemacht?
            @azrael42
            Gib mal die Langfassung von
            iob diag
            Da kann man schon mal sehen in welchem Umfeld du da überhaupt unterwegs bist.
              Moin,
              na dann begeben wir uns mal auf die Suche
              Was kommt, bei:
              dp20eic@iobroker:~$ lslogins iobroker
              Username:                           iobroker
              UID:                                1000
              Gecos field:                        iobroker,0815,1234567890,0987654321
              Home directory:                     /home/iobroker
              Shell:                              /bin/bash
              No login:                           no
              Primary group:                      iobroker
              GID:                                1000
              Supplementary groups:               bluetooth,tty,dialout,audio,video,wheel
              Supplementary group IDs:            116,5,20,29,44,1001
              Last terminal:
              Last hostname:
              Hushed:                             no
              Running processes:                  25
              Last logs:
              Was steht denn genau in Deiner Datei?
              sudo cat /etc/sudoers
              !!!Achtung!!!
              Die Datei nicht mit einem normalen Editor bearbeiten, das ist ganz böse und jeder der das macht, dem gehören die Finger abgehackt :)
              Es gibt einen speziellen Befehl, den ich aber nur verrate, wenn man mir drei Fragen richtig beantwortet :)
              !!!Achtung!!!
              Bernd
              Thomas BraunT Azrael42A 2 Antworten Letzte Antwort
                Moin,
                Was kommt, bei:
                Username:                           iobroker
                UID:                                1000
                Shell:                              /bin/bash
                No login:                           no
                GID:                                1000
                Last terminal:
                Last hostname:
                Hushed:                             no
                Last logs:
                !!!Achtung!!!
                !!!Achtung!!!
                Bernd
                @dp20eic sagte in BackITUp: MySQL DB Sicherung schlägt fehl:
                Dann schieß mal los. Ich bin neugierig! :-D
                  @thomas-braun sagte in BackITUp: MySQL DB Sicherung schlägt fehl:
                  Moin,
                  1. Wurzel von 1764?
                  2. was ist 101010?
                  3. die Antwort auf die Frage aller Fragen, nämlich die "nach dem Leben, dem Universum und dem ganzen Rest"?
                  Bernd
                    Moin,
                    1. Wurzel von 1764?
                    2. was ist 101010?
                    Bernd
                    @dp20eic
                    1. vi
                    2. su
                    3. do
                    Das hat mir der Teufel gesagt! :-)
                      @dp20eic
                      1. vi
                      2. su
                      3. do
                      der mit den drei goldenen Haaren?
                      ich biete 42,42,42
                        Moin,
                        Was kommt, bei:
                        Username:                           iobroker
                        UID:                                1000
                        Shell:                              /bin/bash
                        No login:                           no
                        GID:                                1000
                        Last terminal:
                        Last hostname:
                        Hushed:                             no
                        Last logs:
                        !!!Achtung!!!
                        !!!Achtung!!!
                        Bernd
                        Azrael42A Offline
                        Azrael42A Offline
                        Azrael42
                        @dp20eic
                        Danke für deine Geduld!
                        richard@RKO-Central:~$ lslogins iobroker
                        Username:                           iobroker
                        UID:                                1001
                        Gecos field:
                        Shell:                              /bin/sbin/nologin
                        No login:                           yes
                        GID:                                1001
                        Supplementary groups:               video,tty,dialout,audio
                        Supplementary group IDs:            44,5,20,29
                        Last terminal:
                        Last hostname:
                        Hushed:                             no
                        Running processes:                  20
                        Last logs:
                        /etc/sudoers
                        Defaults        env_reset
                        Defaults        mail_badpass
                        Defaults        secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/b>
                        # Host alias specification
                        # User alias specification
                        # Cmnd alias specification
                        # User privilege specification
                        root    ALL=(ALL:ALL) ALL
                        # Allow members of group sudo to execute any command
                        %sudo   ALL=(ALL:ALL) ALL
                        # See sudoers(5) for more information on "@include" directives:
                        @includedir /etc/sudoers.d
                        iob diag
                        Habe ich hier schon geposted:
                        https://forum.iobroker.net/topic/66067/backitup-mysql-db-sicherung-schlägt-fehl/12?_=1686421368503
                        Meine neue Wärmepumpe eingebunden. Neue Modbus Objekte erstellt, die im Logging aktiviert, im SQL neue Views und Proceduren erstellt, neue Scripte erstellt. Sowas.
                          @dp20eic
                          Username:                           iobroker
                          UID:                                1001
                          Gecos field:
                          No login:                           yes
                          GID:                                1001
                          Last terminal:
                          Last hostname:
                          Hushed:                             no
                          Last logs:
                          /etc/sudoers
                          Defaults        env_reset
                          iob diag
                          /bin/sbin/nologin
                          Moin,
                          Dein ioBroker User hat keine Login shell daher kannst Du Dich da auch nicht anmelden!
                          Bernd
                          P.S.: Da ich schon vor langer Zeit, meinen ioBroker angelegt habe, da habe ich den User noch von Hand angelegt, daher ist das aber vielleicht heute anders gelöst.
                            /bin/sbin/nologin
                            Moin,
                            Bernd
                            Dein ioBroker User hat keine Login shell daher kannst Du Dich da auch nicht mehr anmelden!
                            Das ist aber die Voreinstellung.
                            echad@chet:~ $ lslogins iobroker
                            Username:                           iobroker
                            UID:                                1001
                            Gecos field:
                            Shell:                              /usr/sbin/nologin
                            No login:                           yes
                            GID:                                1001
                            Supplementary groups:               nut,tty,dialout,audio,video,bluetooth,i2c,gpio
                            Supplementary group IDs:            116,5,20,29,44,112,998,997
                            Last terminal:
                            Last hostname:
                            Hushed:                             no
                            Running processes:                  38
                              Username:                           iobroker
                              UID:                                1001
                              Gecos field:
                              No login:                           yes
                              GID:                                1001
                              Last terminal:
                              Last hostname:
                              Hushed:                             no
                              Moin,
                              ja, das habe ich mir fast schon gedacht, da ich damals so 2 Jahre her, ioBroker eingerichtet habe, habe ich mir den User selbst angelegt.
                              Ist es dann nur möglich zum User iobroker zu werden, in dem man das macht?
                              sudo su - iobroker -s /bin/bash
                              Ist interessant, sollte ich mal für diese quasi System-User auch so einrichten.
                              Bernd
                                Moin,
                                Bernd
                                sudo -H -u iobroker COMMAND
                                Der iobroker bekommt keine login shell.
                                  Moin,
                                  Bernd
                                  Azrael42A Offline
                                  Azrael42A Offline
                                  Azrael42
                                  @dp20eic
                                  Wenn ich mich so als iobroker anmelde, gibt "which mysqldump" den richtigen Pfad aus.
                                  iobroker@RKO-Central:~$ which mysqldump
                                  /usr/bin/mysqldump
                                    @dp20eic
                                    /usr/bin/mysqldump
                                    ls -la /usr/bin/mysqldump
                                    sagt?
                                    Ich vermute ja, der user der für das Backup herangezogen wird hat in der Datenbank nicht genügend Rechte.
                                    Oder wird /opt/iobroker/backups als Mountpunkt für ein NAS oder sowas verwendet?
                                    Azrael42A ? 2 Antworten Letzte Antwort
                                      sagt?
                                      Azrael42A Offline
                                      Azrael42A Offline
                                      Azrael42
                                      iobroker@RKO-Central:~$ ls -la /usr/bin/mysqldump
                                      lrwxrwxrwx 1 root root 12 Apr 15 21:50 /usr/bin/mysqldump -> mariadb-dump
                                      Nein, NAS habe ich nicht. Verwende für das Backup OneDrive.
                                      cat /proc/mounts
                                      Gibt auch kein Ergebnis dafür.
                                      Thomas BraunT ? 2 Antworten Letzte Antwort
                                        cat /proc/mounts
                                        ls -la /usr/bin/mariadb-dump
                                          sagt?
                                          @Azrael42 @thomas-braun sagte in BackITUp: MySQL DB Sicherung schlägt fehl:
                                          Moin,
                                          da Du ja irgendwo mal geschrieben hast, dass Du HeidiSQL nutzt, kannst Du Dir ja dort mal anschauen wie Dein User und die Rechte sind.
                                          dann musst Du das auf die mariadb-dump machen
                                          Bernd
