  4. Tuya lief eigentlich recht gut aber jetzt Probleme.
    5.4k
70 Beiträge 4 Kommentatoren 6.6k Aufrufe 3 Beobachtet
  • K kg36304
    Hallo, also Bullseye auf dem Master und Slave installiert.
    Es scheint aktuell zu laufen (nach dem reboot) mal schauen, ob es dauerhaft geht.
    Danke für den mega Support.
    @kg36304
    Dann lass mal dein Werk sehen.
    iob diag
    für beide Kisten.
      kg36304
      Hier der Master.
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model		: Raspberry Pi 4 Model B Rev 1.1
      Architecture    : armv7l
      Docker          : false
      Virtualization  : none
      Distributor ID:	Raspbian
      Description:	Raspbian GNU/Linux 11 (bullseye)
      Release:	11
      Codename:	bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       21:15:23 up 9 min,  1 user,  load average: 1.51, 1.56, 0.97
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=68.1'C
      volt=0.8500V
      *** Time and Time Zones ***
                     Local time: Thu 2023-06-08 21:15:24 CEST
                 Universal time: Thu 2023-06-08 19:15:24 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:            3.8G        1.8G        1.4G        0.0K        660M        1.9G
      Swap:            99M          0B         99M
      Total:          3.9G        1.8G        1.5G
               3837 M total memory
               1787 M used memory
                190 M active memory
               2148 M inactive memory
               1389 M free memory
                 71 M buffer memory
                588 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      459G  7.9G  432G   2% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     768M  692K  767M   1% /run
      /dev/sda1      vfat      253M   50M  203M  20% /boot
      tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
      [Thu Jun  8 21:06:05 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:50:A2:AC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Thu Jun  8 21:06:07 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Thu Jun  8 21:06:07 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Thu Jun  8 21:06:09 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      818M	/var/
      573M	/var/cache
      567M	/var/cache/apt
      503M	/var/cache/apt/archives
      106M	/var/lib
      Archived and active journals take up 32.0M in the file system.
      /opt/iobroker/backups:
      915M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      780M	/opt/iobroker/iobroker-data/
      403M	/opt/iobroker/iobroker-data/files
      170M	/opt/iobroker/iobroker-data/backup-objects
      72M	/opt/iobroker/iobroker-data/files/telegram.admin
      69M	/opt/iobroker/iobroker-data/sonosCache
      65M	/opt/iobroker/iobroker-data/states.jsonl
      22M	/opt/iobroker/iobroker-data/objects.jsonl
      19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
      15M	/opt/iobroker/iobroker-data/objects.json.migrated
      15M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.16.0
      /usr/bin/node 		v18.16.0
      /usr/bin/npm 		9.5.1
      /usr/bin/npx 		9.5.1
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
       *** 18.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	4.0.24
      admin: 		6.3.5
      javascript: 	6.1.4
      Adapters from github: 	2
      Adapter State
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
        system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
      + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
      + system.adapter.ds18b20.0                : ds18b20               : Slave                                    -  enabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
      + system.adapter.hm-rega.1                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
      + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.kodi.0                   : kodi                  : raspberrypi                              -  enabled, port: 9090
      + system.adapter.kodi.1                   : kodi                  : Slave                                    -  enabled, port: 9090
      + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
        system.adapter.mobile.0                 : mobile                : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : Slave                                    -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.octoprint.0              : octoprint             : Slave                                    -  enabled
      + system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartgarden.0            : smartgarden           : raspberrypi                              -  enabled
      + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : Slave                                    -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
      + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
      + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
      + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
      + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "backitup"     : 2.6.19   , installed 2.6.19
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "cloud"        : 4.3.0    , installed 4.3.0
      Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
      Adapter    "denon"        : 1.15.0   , installed 1.15.0
      Adapter    "ds18b20"      : 1.6.1    , installed 1.6.1
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
      Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
      Adapter    "iot"          : 1.14.2   , installed 1.14.2
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Adapter    "kodi"         : 2.0.9    , installed 2.0.9
      Adapter    "meross"       : 1.14.0   , installed 1.14.0
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
      Adapter    "openligadb"   : 1.2.4    , installed 1.2.4
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
      Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "sonos"        : 2.2.3    , installed 2.2.3
      Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
      Adapter    "tado"         : 0.4.8    , installed 0.4.8
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.13.1   , installed 3.14.2
      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "wled"         : 0.6.7    , installed 0.6.7
      Adapter    "worx"         : 2.1.3    , installed 2.1.3
      Adapter    "yahka"        : 0.17.0   , installed 0.17.0
      Objects and States
      Objects: 	24255
      States: 	21062
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://repos.influxdata.com/debian stable InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:46321           0.0.0.0:*               LISTEN      1001       21236      1762/io.yahka.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13414      494/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        12701      368/influxd
      tcp        0      0 192.168.62.93:2010      0.0.0.0:*               LISTEN      1001       14911      908/io.hm-rpc.3
      tcp        0      0 192.168.62.93:8701      0.0.0.0:*               LISTEN      1001       13160      915/io.hm-rpc.4
      tcp        0      0 127.0.0.1:33183         0.0.0.0:*               LISTEN      1001       21464      1762/io.yahka.0
      tcp        0      0 192.168.62.93:12001     0.0.0.0:*               LISTEN      1001       14879      891/io.hm-rpc.2
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       13553      581/iobroker.js-con
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       13545      581/iobroker.js-con
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11230      799/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18311      1617/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       18658      1501/io.socketio.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        14481      368/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13416      494/sshd: /usr/sbin
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18047      1484/io.simple-api.
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16403      1040/io.sonos.0
      udp        0      0 0.0.0.0:33732           0.0.0.0:*                           1001       14180      1234/io.broadlink2.
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15289      1136/io.shelly.0
      udp        0      0 0.0.0.0:55352           0.0.0.0:*                           1001       16066      1234/io.broadlink2.
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14475      729/dhcpcd
      udp        0      0 0.0.0.0:45684           0.0.0.0:*                           108        14357      345/avahi-daemon: r
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       17542      1234/io.broadlink2.
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17271      1717/io.wled.0
      udp        0      0 192.168.62.93:5353      0.0.0.0:*                           1001       16475      1102/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14355      345/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       22657      1915/io.deconz.0
      udp6       0      0 :::546                  :::*                                0          14490      729/dhcpcd
      udp6       0      0 :::55941                :::*                                108        14358      345/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        14356      345/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       22659      1915/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       22658      1915/io.deconz.0
      2023-06-08 21:15:54.870  - debug: daswetter.0 (2773) insert NextHours2.Location_1.Day_5.Hour_8.wind_dir with E
      2023-06-08 21:15:54.877  - debug: daswetter.0 (2773) insert NextHours2.Location_1.Day_5.Hour_8.wind_symbol with 11
      2023-06-08 21:15:54.885  - debug: daswetter.0 (2773) insert NextHours2.Location_1.Day_5.Hour_8.wind_symbolB with 35
      2023-06-08 21:15:54.892  - debug: daswetter.0 (2773) insert NextHours2.Location_1.Day_5.Hour_8.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/35.png
      2023-06-08 21:15:54.898  - debug: daswetter.0 (2773) insert NextHours2.Location_1.Day_5.Hour_8.wind_gusts with 26
      2023-06-08 21:15:54.905  - debug: daswetter.0 (2773) insert NextHours2.Location_1.Day_5.Hour_8.rain with 0 mm
      2023-06-08 21:15:54.912  - debug: daswetter.0 (2773) insert NextHours2.Location_1.Day_5.Hour_8.humidity with 37
      2023-06-08 21:15:54.919  - debug: daswetter.0 (2773) insert NextHours2.Location_1.Day_5.Hour_8.pressure with 1017 mb
      2023-06-08 21:15:54.932  - debug: daswetter.0 (2773) insert NextHours2.Location_1.Day_5.Hour_8.clouds with 0%
      2023-06-08 21:15:54.939  - debug: daswetter.0 (2773) insert NextHours2.Location_1.Day_5.Hour_8.snowline with 3400 m
      2023-06-08 21:15:54.947  - debug: daswetter.0 (2773) insert NextHours2.Location_1.Day_5.Hour_8.uv_index with 0
      2023-06-08 21:15:54.955  - debug: daswetter.0 (2773) insert NextHours2.Location_1.Day_5.Hour_8.windchill with 18
      2023-06-08 21:15:54.963  - debug: daswetter.0 (2773) insert NextHours2.Location_1.Day_5.sunshineDuration with 18
      2023-06-08 21:15:54.979  - debug: daswetter.0 (2773) exit, all done
      2023-06-08 21:15:54.980  - debug: daswetter.0 (2773) timer killed
      2023-06-08 21:15:54.981  - debug: daswetter.0 (2773) Plugin sentry destroyed
      2023-06-08 21:15:54.981  - info: daswetter.0 (2773) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-06-08 21:15:55.623  - info: daswetter.0 (2773) cleaned everything up...
      2023-06-08 21:15:55.652  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-06-08 21:16:00.080  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 3049
      2023-06-08 21:16:04.646  - info: dwd.0 (3049) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
      2023-06-08 21:16:05.698  - info: dwd.0 (3049) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-06-08 21:16:06.298  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-06-08 21:16:41.003  - info: meross.0 (1147) Can not get Data for Device 2102034230510490841348e1e94a67d1: Error: Device has no data connection available
      2023-06-08 21:16:41.003  - warn: meross.0 (1147) Can not get Data for Device 2102034230510490841348e1e94a67d1: undefined
      		     v.2023-04-16
      Operatingsystem: 	Raspbian GNU/Linux 11 (bullseye)
      Kernel: 		5.10.103-v7l+
      Installation: 		Native
      Timezone: 		Europe/Berlin (CEST, +0200)
      User-ID: 		1000
      X-Server: 		false
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.0
      			/usr/bin/npm 		9.5.1
      			/usr/bin/npx 		9.5.1
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            3.8G        1.8G        1.3G        0.0K        768M        1.9G
      Swap:            99M          0B         99M
      Total:          3.9G        1.8G        1.4G
      Active iob-Instances: 	49
      ioBroker Core: 		js-controller 		4.0.24
      			admin 			6.3.5
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Objects: 		24255
      States: 		21062
      Size of iob-Database:
      7.9M	/opt/iobroker/iobroker-data/objects.json.broken
      44K	/opt/iobroker/iobroker-data/objects.json.old
      9.2M	/opt/iobroker/iobroker-data/states.jsonl
      5.1M	/opt/iobroker/iobroker-data/states.json.migrated
      5.1M	/opt/iobroker/iobroker-data/states.json.bak.migrated
      4.1M	/opt/iobroker/iobroker-data/states.json.old
      0	/opt/iobroker/iobroker-data/states.json.broken
      Und der Slave
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model		: Raspberry Pi 3 Model B Rev 1.2
      Docker          : false
      Release:	11
      Codename:	bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
       20:19:52 up 39 min,  1 user,  load average: 0.00, 0.04, 0.07
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=47.2'C
      volt=1.2688V
                     Local time: Thu 2023-06-08 20:19:52 BST
                 Universal time: Thu 2023-06-08 19:19:52 UTC
                       RTC time: n/a
                      Time zone: Europe/London (BST, +0100)
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Mem:            923M        215M        396M        0.0K        311M        655M
      Swap:            99M          0B         99M
      Total:          1.0G        215M        496M
                923 M total memory
                215 M used memory
                183 M active memory
                294 M inactive memory
                396 M free memory
                 35 M buffer memory
                276 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       29G  4.3G   24G  16% /
      devtmpfs       devtmpfs  430M     0  430M   0% /dev
      tmpfs          tmpfs     462M     0  462M   0% /dev/shm
      tmpfs          tmpfs     185M  580K  185M   1% /run
      /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
      tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
      [Thu Jun  8 19:39:52 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=56cd6262-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Thu Jun  8 19:39:55 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Thu Jun  8 19:39:55 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Thu Jun  8 19:39:58 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      740M	/var/
      492M	/var/cache
      487M	/var/cache/apt
      423M	/var/cache/apt/archives
      95M	/var/lib
      Archived and active journals take up 48.0M in the file system.
      203M	/opt/iobroker/backups/
      6.2M	/opt/iobroker/iobroker-data/
      3.3M	/opt/iobroker/iobroker-data/files
      2.8M	/opt/iobroker/iobroker-data/files/info.admin
      2.4M	/opt/iobroker/iobroker-data/files/info.admin/lib
      1.1M	/opt/iobroker/iobroker-data/files/info.admin/lib/fonts
      1.2M	/opt/iobroker/iobroker-data/objects.json.bak
      440K	/opt/iobroker/iobroker-data/files/info.admin/lib/fonts/fontawesome-webfont.svg
      264K	/opt/iobroker/iobroker-data/files/info.admin/lib/js/simplemde.min.js
      244K	/opt/iobroker/iobroker-data/files/info.admin/words.js
      /usr/bin/npm 		9.5.1
      /usr/bin/npx 		9.5.1
      nodejs:
        Version table:
      ioBroker Status
      At least one iobroker host is running.
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.3.5
      javascript: 	6.1.4
      Adapters from github: 	0
      Adapter State
      + instance is alive
      Adapter    "info"         : 1.9.26   , installed 1.9.19 [Updatable]
      Adapter    "kodi"         : 2.0.9    , installed 2.0.8  [Updatable]
      Adapter    "mqtt"         : 4.0.7    , installed 2.4.0  [Updatable]
      Adapter    "philips-tv"   : 0.5.3    , installed 0.5.2  [Updatable]
      Adapter    "tuya"         : 3.13.1   , installed 3.13.1
      Objects and States
      Objects: 	24255
      States: 	21062
      Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
      Pending Updates: 0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11596      479/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       13495      687/io.sonoff.0
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       11059      676/io.mqtt.0
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       11060      676/io.mqtt.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          11598      479/sshd: /usr/sbin
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          8078       665/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10699      356/avahi-daemon: r
      udp        0      0 0.0.0.0:40980           0.0.0.0:*                           108        10701      356/avahi-daemon: r
      udp6       0      0 :::51334                :::*                                108        10702      356/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        10700      356/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          8094       665/dhcpcd
      2023-06-08 20:06:13.339  - error: kodi.1 (811) States database error: connect ETIMEDOUT
      2023-06-08 20:06:19.262  - error: octoprint.0 (822) Objects database error: connect ECONNREFUSED 192.168.62.93:9001
      2023-06-08 20:06:19.266  - error: kodi.1 (811) Objects database error: connect ECONNREFUSED 192.168.62.93:9001
      2023-06-08 20:06:19.275  - error: ds18b20.0 (792) Objects database error: connect ECONNREFUSED 192.168.62.93:9001
      2023-06-08 20:06:19.289  - error: sonoff.0 (687) Objects database error: connect ECONNREFUSED 192.168.62.93:9001
      2023-06-08 20:06:19.339  - error: host.Slave Objects database error: connect ECONNREFUSED 192.168.62.93:9001
      2023-06-08 20:06:19.344  - error: mqtt.0 (676) Objects database error: connect ECONNREFUSED 192.168.62.93:9001
      2023-06-08 20:06:19.347  - error: sonoff.0 (687) States database error: connect ECONNREFUSED 192.168.62.93:9000
      2023-06-08 20:06:19.416  - error: host.Slave States database error: connect ECONNREFUSED 192.168.62.93:9000
      2023-06-08 20:06:19.416  - error: ds18b20.0 (792) States database error: connect ECONNREFUSED 192.168.62.93:9000
      2023-06-08 20:06:19.419  - error: mqtt.0 (676) States database error: connect ECONNREFUSED 192.168.62.93:9000
      2023-06-08 20:06:19.417  - error: kodi.1 (811) States database error: connect ECONNREFUSED 192.168.62.93:9000
      2023-06-08 20:06:19.420  - error: octoprint.0 (822) States database error: connect ECONNREFUSED 192.168.62.93:9000
      2023-06-08 20:06:24.276  - info: kodi.1 (811) Objects database successfully reconnected
      2023-06-08 20:06:24.279  - info: octoprint.0 (822) Objects database successfully reconnected
      2023-06-08 20:06:24.286  - info: ds18b20.0 (792) Objects database successfully reconnected
      2023-06-08 20:06:24.300  - info: sonoff.0 (687) Objects database successfully reconnected
      2023-06-08 20:06:24.347  - info: host.Slave Objects database successfully reconnected
      2023-06-08 20:06:24.355  - info: mqtt.0 (676) Objects database successfully reconnected
      2023-06-08 20:06:24.355  - info: sonoff.0 (687) Objects database successfully reconnected
      2023-06-08 20:06:24.422  - info: host.Slave Objects database successfully reconnected
      2023-06-08 20:06:24.423  - info: ds18b20.0 (792) Objects database successfully reconnected
      2023-06-08 20:06:24.431  - info: mqtt.0 (676) Objects database successfully reconnected
      2023-06-08 20:06:24.429  - info: octoprint.0 (822) Objects database successfully reconnected
      2023-06-08 20:06:24.434  - info: kodi.1 (811) Objects database successfully reconnected
      		     v.2023-04-16
      Kernel: 		5.10.103-v7+
      Timezone: 		Europe/London (BST, +0100)
      User-ID: 		1000
      X-Server: 		false
      Pending iob updates: 	4
      			/usr/bin/npm 		9.5.1
      			/usr/bin/npx 		9.5.1
      MEMORY:
      Mem:            923M        216M        344M        0.0K        362M        648M
      Swap:            99M          0B         99M
      Total:          1.0G        216M        444M
      			admin 			6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects: 		24255
      States: 		21062
      180K	/opt/iobroker/iobroker-data/states.json.bak
        kg36304
        So, das Tuya Problem sieht wie folgt aus, wenn ich über die Hand App steuer geht es und der Status wird auch in der Vis angezeigt. wenn ich über die Vis schalten möchte geht nichts.
        • K kg36304
          Hier der Master.
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:	11
          Codename:	bullseye
          VERSION_ID="11"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          temp=68.1'C
          volt=0.8500V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   3837 M total memory
                   1787 M used memory
                    190 M active memory
                   1389 M free memory
                     71 M buffer memory
                    588 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          818M	/var/
          573M	/var/cache
          567M	/var/cache/apt
          106M	/var/lib
          /usr/bin/npm 		9.5.1
          /usr/bin/npx 		9.5.1
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin: 		6.3.5
          javascript: 	6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	24255
          States: 	21062
          Pending Updates: 0
          		     v.2023-04-16
          User-ID: 		1000
          X-Server: 		false
          			/usr/bin/npm 		9.5.1
          			/usr/bin/npx 		9.5.1
          MEMORY:
          Swap:            99M          0B         99M
          			admin 			6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects: 		24255
          States: 		21062
          Und der Slave
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:	11
          Codename:	bullseye
          VERSION_ID="11"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          temp=47.2'C
          volt=1.2688V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                    923 M total memory
                    215 M used memory
                    183 M active memory
                    396 M free memory
                     35 M buffer memory
                    276 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          740M	/var/
          492M	/var/cache
          487M	/var/cache/apt
          95M	/var/lib
          /usr/bin/npm 		9.5.1
          /usr/bin/npx 		9.5.1
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin: 		6.3.5
          javascript: 	6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	24255
          States: 	21062
          Pending Updates: 0
          		     v.2023-04-16
          User-ID: 		1000
          X-Server: 		false
          			/usr/bin/npm 		9.5.1
          			/usr/bin/npx 		9.5.1
          MEMORY:
          Swap:            99M          0B         99M
          			admin 			6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects: 		24255
          States: 		21062
          @kg36304
          Komplette Neuinstallation oder von einer Vorversion upgegraded?
            kg36304
            upgegraded
              kg36304
              oder meintest Du Tuya?
              • K kg36304
                @kg36304
                Nein, das Betriebssystem.
                • K kg36304
                  @kg36304
                  Der Slave hat die falsche Zeitzone.
                  Hostnames schreibt man gemeinhin klein.
                  Und der Multihost-Betrieb ist nicht oder falsch eingerichtet.
                    kg36304
                    Auweia, was Du alles siehst, wahnsinn.
                    Wie änder ich das?
                    Laufen tut alle so ;-)
                    • K kg36304
                      Wie änder ich das?
                      @kg36304 sagte in Tuya lief eigentlich recht gut aber jetzt Probleme.:
                      Wie änder ich das?
                      Die Zeitzone?
                      In
                      sudo raspi-config
                      oder
                      sudo timedatectl set-timezone "Europe/Berlin"
                        kg36304
                        #66
                        Moin,
                        den Hostnamen habe ich nicht geändert, kann ich das einfach so tun oder läuft dann etwas nicht mehr richtig?
                        • K kg36304
                          Moin,
                          #67
                          Kommt darauf an was genau du mit 'einfach so' meinst.
                          Ja, man kann den natürlich ändern, muss es dann aber in allen Ecken tun.
                          Lass es jetzt so, merk es dir fürs nächste Mal.
                            kg36304
                            #68
                            OK, danke.
                            jetzt nochmal zum Tuya Problem ;-)
                            Wenn ich in der Handy App (Iphone) die Geräte schalte, wird der Zutand auch im VIS angezeigt.
                            Wenn ich aber über die VIS schalte tut sich am Gerät und in der App nichts.
                            Geht also nur in eine Richtung. Hast Du da eventuell auch nen Lösungsansatz?
                            Danke.
                            • K kg36304
                              OK, danke.
                              Danke.
                              #69
                              @kg36304
                              Hab keine Vis Einsatz.
                                @kg36304
                                kg36304
                                #70
                                OK, dann stelle ich die Frage nochmal separat Allgemeines rein.
                                Vielen Dank nochmal.
